  4. Probleme mit FullyBrowser-Adapter
    6.4k
32 Beiträge 5 Kommentatoren 3.4k Aufrufe 4 Beobachtet
  • OmnedonO Omnedon
    @lessthanmore
    Ja, das habe ich gemacht und das Passwort start reduziert und vereinfacht.
    Leider keine Verbesserung.
    Ich habe auch mal die IP-Adresse geändert und dann sehe ich, dass die Verbindung nicht klappt - weil es die IP Adresse nicht gibt:
    fullybrowser.0 23621	2021-09-30 13:45:02.189	info	Start with IP : 192.168.178.60
    fullybrowser.0 23621	2021-09-30 13:45:02.187	debug	create state
    fullybrowser.0 23621	2021-09-30 13:45:02.142	info	starting. Version 2.0.8 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v12.22.6, js-controller: 3.3.18
    fullybrowser.0 23475	2021-09-30 13:44:54.815	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    fullybrowser.0 23475	2021-09-30 13:44:54.813	info	terminating
    fullybrowser.0 23475	2021-09-30 13:44:54.812	info	cleaned everything up...
    fullybrowser.0 23475	2021-09-30 13:44:54.811	info	Got terminate signal TERMINATE_YOURSELF
    fullybrowser.0 23475	2021-09-30 13:44:13.829	warn	updateDeviceERROR 192.168.178.61
    fullybrowser.0 23475	2021-09-30 13:44:11.821	debug	get Information
    fullybrowser.0 23475	2021-09-30 13:43:11.809	warn	updateDeviceERROR 192.168.178.61
    fullybrowser.0 23475	2021-09-30 13:43:11.802	debug	get Information
    fullybrowser.0 23475	2021-09-30 13:43:11.395	warn	Generate State problem 192_168_178_61 {"message":"connect ECONNREFUSED 192.168.178.61:2323","name":"Error","stack":"Error: connect ECONNREFUSED 192.168.178.61:2323\n at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16)","config":{"url":"http://192.168.178.61:2323/?cmd=deviceInfo&type=json&password=MasterFully2021","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":2000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1},"code":"ECONNREFUSED"}
    fullybrowser.0 23475	2021-09-30 13:43:11.259	info	Start with IP : 192.168.178.61
    lessthanmore
    @omnedon Doofe Frage, aber läuft denn fully auch gerade aktiv auf dem Tablet?
    OmnedonO 1 Antwort Letzte Antwort
    • OmnedonO Omnedon
      @lessthanmore
      arteckA Offline
      arteckA Offline
      arteck
      @omnedon warte mal.. ist das nur der indikator der Rot ist...oder werden die Felder bzw. der Status in den Objekten nicht aktualisiert.. nicht das es nur ein Anzeige fehler ist mit dem roten pömpel
      • L lessthanmore
        OmnedonO Offline
        OmnedonO Offline
        Omnedon
        @lessthanmore
        ja, sicher.
        • arteckA arteck
          OmnedonO Offline
          OmnedonO Offline
          Omnedon
          @arteck
          Die Felder werden leider nicht in den Objekten aktualisiert.
          Das ist was mir aufgefallen ist - ich zeige den Akku-Stand in der View.
          Der hat aber nicht gestimmt mit dem was ich direkt am Tablet gesehen habe.
          Den basierend auf diesem Wert schalte ich den Strom ein oder aus.
          L 1 Antwort Letzte Antwort
          • OmnedonO Omnedon
            @arteck
            lessthanmore
            @omnedon Du hast geschrieben, dass es bis gestern Abend ging.
            Was hat sich seitdem geändert? Ist das ein anderes Tablet oder ein zusätzliches Tablet?
            OmnedonO 2 Antworten Letzte Antwort
            • L lessthanmore
              OmnedonO Offline
              OmnedonO Offline
              Omnedon
              @lessthanmore Nein, das Tablet ist gleich, die IP-Adresse auch.
              Der FullyBrowser ist über diese IP Adresse und den Port auch vom anderen Rechner im Browser erreichbar.
              Passwort wurde auch mehrmals geprüft.
              An dieser Konfiguration habe ich gestern Abend nicht angepasst.
              Ich habe allgemein im Netzwerk verschiedenen Geräte ein feste IP Adresse zugeordnet.
              • arteckA Offline
                arteckA Offline
                arteck
                irgendwas ist anders.. wenns bis dato funktioniert hat.. von sich aus mcht der adapter nicht zu..
                • L lessthanmore
                  OmnedonO Offline
                  OmnedonO Offline
                  Omnedon
                  @lessthanmore Auch die Neuinstallation des Adapters brach keine Verbesserung.
                  arteckA L 2 Antworten Letzte Antwort
                  • OmnedonO Omnedon
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @omnedon am Adapter liegt es nicht... was hat sich in der Hardwarestruktur geändert .. firewall neu ?? pihole ?? neue fritte?? neuer AP oder oder.. das Tabled antwortet zwar aber gibt die daten nicht rus..oder darf nicht..
                    upgrade des Andoid System vielleicht ?? wie siehts mit den rechten auf dem Tabled aus.. darf die Fully Browser Verion immer noch alles auslesen.. admin rechte ?? ugriff auf den internen Speicher ?
                    • arteckA arteck
                      OmnedonO Offline
                      OmnedonO Offline
                      Omnedon
                      @arteck Keine Änderungen an der Hardwarestruktur, Fritte ist auch die gleiche, AP auch.
                      Das Tablet antwortet schon - nur nicht dem Adapter. Vom Browser kann ich den über <IP>:2323/? erreichen - von einem anderen Rechner aus.
                      • OmnedonO Omnedon
                        lessthanmore
                        @omnedon 2.0.9 (Beta) mal probiert?
                        • L lessthanmore
                          OmnedonO Offline
                          OmnedonO Offline
                          Omnedon
                          @lessthanmore ich habe auf das beta-Repository umgestellt, sehe aber die 2.0.9 Version nicht
                          • L lessthanmore
                            OmnedonO Offline
                            OmnedonO Offline
                            Omnedon
                            @lessthanmore Habe es gefunden. Aber immer noch keine Verbindung.
                            Ich habe auch die IP Adresse geändert, auch kein Erfolg.
                            • OmnedonO Omnedon
                              arteckA Offline
                              arteckA Offline
                              arteck
                              @omnedon irgendwas ist ander bei dir in der Hardware oder Software ... der Adapter denkt sich nicht heute funktioniere ich ..ach morgen nicht..
                              • arteckA arteck
                                OmnedonO Offline
                                OmnedonO Offline
                                Omnedon
                                @arteck
                                Ich habe alles nochmal installiert, aber kein Erfolg.
                                Aber mit einem anderen Gerät geht es einwandfrei.
                                Der Fully Kiosk Browser mit dem Problem läuft auf einem Chromebook, der eine feste IP Adresse hat: 192.xxx.yyy.72.
                                Der Fully zeigt mir aber eine andere bei der Remote Administration: 100.115.95.14
                                Diese passt nicht zu meinem Netzwerk. Eine Idee warum das ist?
                                • OmnedonO Omnedon
                                  @arteck
                                  BananaJoeB Online
                                  BananaJoeB Online
                                  BananaJoe
                                  @omnedon 100.115.95.14 wäre ggf. deine öffentliche IP-Adresse.
                                  Kannst du von deinem iobroker-Server ein
                                  wget https://<IP>:2323
                                  machen? er lädt dann eine Datei runter (index.htlm oder so) in welcher du den Inhalt der Login-Seite sehen müsstest
                                  Im Adapter hats du nur die IP, das Passwort und den Port 2323 angegeben?
                                  • BananaJoeB BananaJoe
                                    OmnedonO Offline
                                    OmnedonO Offline
                                    Omnedon
                                    schrieb am zuletzt editiert von Omnedon
                                    @bananajoe
                                    In der Fritzbox sehe ich nur die IP6 Adresse (ich glaube die IP4 werden nicht mehr verwendet) .
                                    Aber das ist nicht meine öffentliche IP Adresse. Ich habe das über die geprüft über https://whatismyipaddress.com/de/meine-ip.
                                    Die öffentliche ist anders: 94.xxx.yyy.zzz
                                    Mit wget auf der lokalen Adresse bekomme ich die index.html zurück mit dem Login zu Fully.
                                    Mit der anderen IP Adresse geht es nicht.
                                    Hier der Screenshot aus Fully:
                                    ostseereiterO BananaJoeB 2 Antworten Letzte Antwort
                                    • OmnedonO Omnedon
                                      @bananajoe
                                      ostseereiterO Offline
                                      ostseereiter
                                      @omnedon Natürlich werden die IP4 Adressen noch vergeben nur halt ungern und erst wenn man sein Provider anruft. das andere sine sogenannte DS lite Zugänge.
                                      Gruß OSR
                                      Plattform
                                      • OmnedonO Omnedon
                                        @bananajoe
                                        BananaJoeB Online
                                        BananaJoeB Online
                                        BananaJoe
                                        @omnedon Wenn du über http://<IP>:2323 dich anmeldest, was steht denn da unter Device-Info bei den Adressen
                                        Und ich hatte so ein komisches Phänomen schon mal mit verschiedenen WLAN Geräten, da wollte einige Geräte partout nicht mehr miteinander reden obwohl beide Geräte von einem 3 erreichbar waren.
                                        Ein FireTV-Stick der erst wieder lief nachdem ich den auf DHCP umgestellt habe (wo er die gleiche Adresse bekam, aber es funktionierte dann) sowie ein anderes Gerät was erst lief nachdem ich die IP geändert hatte.
                                        Mit der FritzBox hatte ich auch einmal das Phänomen das meine FritzBox die IP .200 hatte und ich kein Gerät mit der Adresse .203 zum laufen bekam. Eine Diagnose der ARP-Adressen ergab das sich die Fritzbox auch die IP gekrallt hatte (aber nicht darauf antwortete)
                                        Test doch mal die IP auf DHCP zu setzen, falls dem schon so ist die Zuweisung zu löschen und eine neue Adresse beziehen zu lassen oder eine statische IP einzustellen (ggf. mal mehrere in verschiedenen Bereichen durchprobieren
                                          OmnedonO Offline
                                          OmnedonO Offline
                                          Omnedon
                                          @bananajoe
                                          Beim Anmelden über einen anderen Computer geht es über die lokale IP x.y.z.72. Ich sehe hier alles.
                                          Aber bei den Device-Infos steht die andere IP:
                                          Ich habe bereits eine feste IP zugewiesen, IP geändert - auch aus verschiedenen Bereichen - leider ohne Erfolg.
