Test Adapter renault v0.0.x für myRenault und myDacia
@tombox Ich gucke grade alles durch...
- In der App wird der Fuel-Level nicht angezeigt, im Adapter schon
- navigationAssistanceLevel ist leer
Der Fehler kommt trotz Neuinstallation im Abfrageintervall:
2021-09-29 16:44:34.643 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-settings?country=de 2021-09-29 16:44:34.643 - error: renault.0 (19060) Error: Request failed with status code 502 2021-09-29 16:44:34.643 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"} 2021-09-29 16:44:34.653 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/res-state?country=de 2021-09-29 16:44:34.653 - error: renault.0 (19060) Error: Request failed with status code 502 2021-09-29 16:44:34.653 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"} 2021-09-29 16:44:34.672 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charges?country=de 2021-09-29 16:44:34.672 - error: renault.0 (19060) Error: Request failed with status code 400 2021-09-29 16:44:34.673 - error: renault.0 (19060) {"type":"FUNCTIONAL","messages":[{"code":"err.func.400","message":"{\"errors\":[{\"status\":\"Bad Request\",\"code\":\"400\",\"title\":\"Required LocalDate parameter 'start' is not present\",\"detail\":\"start is missing\"}]}"}],"errors":[{"errorCode":"err.func.400","errorMessage":"{\"errors\":[{\"status\":\"Bad Request\",\"code\":\"400\",\"title\":\"Required LocalDate parameter 'start' is not present\",\"detail\":\"start is missing\"}]}"}],"error_reference":"FUNCTIONAL"} 2021-09-29 16:44:34.691 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/battery-inhibition-status?country=de 2021-09-29 16:44:34.692 - error: renault.0 (19060) Error: Request failed with status code 502 2021-09-29 16:44:34.692 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"} 2021-09-29 16:44:34.710 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v2/cars/VF1RJXXXXXXXXXX/battery-status?country=de 2021-09-29 16:44:34.711 - error: renault.0 (19060) Error: Request failed with status code 502 2021-09-29 16:44:34.711 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"} 2021-09-29 16:44:34.761 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-settings?country=de 2021-09-29 16:44:34.761 - error: renault.0 (19060) Error: Request failed with status code 502 2021-09-29 16:44:34.761 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"} 2021-09-29 16:44:34.785 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/hvac-settings?country=de 2021-09-29 16:44:34.786 - error: renault.0 (19060) Error: Request failed with status code 502 2021-09-29 16:44:34.786 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"} 2021-09-29 16:44:34.982 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/hvac-status?country=de 2021-09-29 16:44:34.983 - error: renault.0 (19060) Error: Request failed with status code 502 2021-09-29 16:44:34.983 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"/ vehicledata API: vnext error http_code=403/ GetCurrentScheduledPresoakCommand API: vnext error http_code=403\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"/ vehicledata API: vnext error http_code=403/ GetCurrentScheduledPresoakCommand API: vnext error http_code=403\"}]}"}],"error_reference":"TECHNICAL"} -
@guergen Fuel Level wird nicht in der App angezeigt. Das ist eigenartig.
Bitte nochmal installieren dann sollten die Fehler weg sein -
Also der Adapter gefällt mir schon mal, aber den Objekten fehlen noch die Units und der Datenpunkt charging power.
Die Kilometer Anzeige stimmt auch nicht, da stehen die Kilometer drin von dem Tag als wir den gekauft haben, im ZOE2 ist der richtige Wert drin.Außerdem sind da einige Fehler im Log:
@jey-cee Das heißt du hast ein zoe?
total Mileage ist eigentlich unter cockpit zu finden
Komisch das er so viele Fehler wirft. Wird denn unter location was angezeigt bzw war das im zoe2 so?
Ich glaube es wäre hilfreich wenn ich kurz die zugangsdaten zu einem zoe bekomme -
Ich glaube es wäre hilfreich wenn ich kurz die zugangsdaten zu einem zoe bekomme@tombox die mileage unter general müsste der Kilometerstand sein, der beim Anmelden der App aktuell waren. bei mir passt das: 4313 km am 29.3.21
Obwohl... ich glaube ich habe die App nicht da installiert.... Aber Datum ind Kilometerstand stimmen von dem Tag -
@tombox sagte in Test Adapter renault v0.0.x:
lösche mal dein log weil man da dein VIN sieht
besteht da die Möglichkeit die VIN gar nicht als object zu nehmen, sondern einen Alias, der in der Konfiguration vergeben wird?
BTW: steht die VIN nicht auch in der Windschutzscheibe öffentlich sichbar?
Ja die VIN ist eigentlich nichts geheimes oder lassen sich private Informationen ableiten.
Eigentlich müssten die totalMileage unter cockpit sein aber ich weiß nicht warum sie leer sind vielleicht muss das Fahrzeug erst bewegt werden.
Falls es länger leer bleibt werde ich auch die information unter general regelmässig updaten müssenIch habe die Fehler am Anfang als Info geändert und werden jetz alle ignoriert
nein.. die steht für jeden offen ensehbar.. am Auto
@tombox Der Fuelstand ist nicht in der App; wahrscheinlich liegt es am Bi-Fuel.
0b der Fuelstand (ich gehe vom Benzin aus) sich ändert kann ich erst sagen, wenn ich mal wieder tanke oder längere Zeit mit Benzin fahre, was ich ja normal vermeiden will! -
@tombox renault.0.FIN.cockpit.fuelQuantity
Da steht bei mir aktuell eine "19" drin
Und hier habe ich nochmal einen DP mit einer "019":
renault.0.FIN.general.vehicleDetails.energy.group
Im renault.0.FIN.general.vehicleDetails.energy.label steht PETROL drin, daher geh ich von "019" als Inhalt aus... obwohl, das macht als group keinen Sinn.Die
renault.0.FIN.location.lastUpdateTime stimmt leider auch nicht, da ich grade "gelandet" binund die Zeit von gestern drin steht, obwohl Lat & Long stimmt -
renault.0.FIN.location.lastUpdateTime stimmt leider auch nicht, da ich grade "gelandet" binund die Zeit von gestern drin steht, obwohl Lat & Long stimmt@guergen Jetzt ist es 15 Uhr und in den DP stehen noch die Werte von heute Morgen 7:40h drin, Kilometer ebenso.
In der App sind die Kilometer aktuell, der Standort auch.
Aktualisierung steht auf 10 Minuten
Nach Neustart des Adapters stimmt zumindest jetzt die Kilometerangabe; mein Auto steht aber immernoch ca. 30 kilometer weit weg laut DP -
Nach Neustart des Adapters stimmt zumindest jetzt die Kilometerangabe; mein Auto steht aber immernoch ca. 30 kilometer weit weg laut DPBei meinem ZOE (1. Generation) kommt gar nichts. Für mich sieht es so aus, als ob zu mit dem falschen AccountID bei den Kamereon Apis nachfragen gehts. Du müsstest doch über /commerce/v1/persons/ dir den KameronAccount holen. Den vermisse ich bei dir im Log.
Laut log sieht es so aus, als ob du dir mit der kameronpersonid (von /accounts.getAccountInfo?login_token ) direkt die Fahrzeugliste holen willst.
Hi ich habe ein neuen Adapter für Renault/Dacia Fahrzeug die mit der my Renault oder myDacia App gesteuert werden können
geschrieben.Datenpunkt zum Lade Status werden erst beim ersten Laden angezeigt
Steuerung über renault.0.id.remote
Zum Installieren:
https://github.com/TA2k/ioBroker.renaultFür die aktuelle Version
bitte das latest Repo auswählen:
Loginablauf:
Die myRenault/myDacia App Mail und Passwort eingeben.@tombox Bei meinem ZOE (1. Generation) kommt gar nichts. Für mich sieht es so aus, als ob zu mit dem falschen AccountID bei den Kamereon Apis nachfragen gehts. Du müsstest doch über /commerce/v1/persons/ dir den KameronAccount holen. Den vermisse ich bei dir im Log.
@fungus75 Ich nutze den ersten Account der neuen API.
Mir war nicht klar wann es passieren kann wenn ein Nutzer mehrere Accounts auf seinem Login haben kann
https://github.com/TA2k/ioBroker.renault/blob/de4ebbcd7053cefde0b0e785b25d39b53a52d8d0/main.js#L143Wenn du den Adapter von logLevel Info auf Debug setzt siehst du auch genau was zurück kommt. Dein Account geht auch in der MyRenault App?
