  4. Test Adapter renault v0.0.x für myRenault und myDacia
387 Beiträge 59 Kommentatoren 96.7k Aufrufe 56 Beobachtet
  • arteckA arteck
    @tombox sieht gut aus ..
    tombox
    @arteck keine Fehler im log? Und die Remote Befehle gehen auch?
    arteckA G 2 Antworten Letzte Antwort
    • T tombox
      arteckA Offline
      arteckA Offline
      arteck
      @tombox ich kann nur abfragen... hab einen Captur 2 in der app .. die Daten kommen alle
      • T tombox
        guergen
        @tombox Hier schneit es mit Fehlern bei einem Renault Captur 2:
        2021-09-29 15:40:41.006 - error: renault.0 (9897) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-history?type=month&country=de
        2021-09-29 15:40:41.006 - error: renault.0 (9897) Error: Request failed with status code 404
        2021-09-29 15:40:41.007 - error: renault.0 (9897) {"type":"FUNCTIONAL","messages":[{"code":"err.func.404","message":"{\"timestamp\":\"2021-09-29T13:40:40.769+0000\",\"status\":404,\"error\":\"Not Found\",\"message\":\"No message available\",\"path\":\"/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-history\"}"}],"errors":[{"errorCode":"err.func.404","errorMessage":"{\"timestamp\":\"2021-09-29T13:40:40.769+0000\",\"status\":404,\"error\":\"Not Found\",\"message\":\"No message available\",\"path\":\"/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-history\"}"}],"error_reference":"FUNCTIONAL"}
        2021-09-29 15:40:41.041 - error: renault.0 (9897) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-settings?country=de
        2021-09-29 15:40:41.041 - error: renault.0 (9897) Error: Request failed with status code 502
        2021-09-29 15:40:41.041 - error: renault.0 (9897) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
        2021-09-29 15:40:41.165 - error: renault.0 (9897) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/hvac-status?country=de
        2021-09-29 15:40:41.165 - error: renault.0 (9897) Error: Request failed with status code 502
        2021-09-29 15:40:41.165 - error: renault.0 (9897) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"/ vehicledata API: vnext error http_code=403/ GetCurrentScheduledPresoakCommand API: vnext error http_code=403\"}]}"}],"errors":[{"errorCode":"err.tech.400","errorMessage":"{\"errors\":[{\"status\":\"400\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"/ vehicledata API: vnext error http_code=403/ GetCurrentScheduledPresoakCommand API: vnext error http_code=403\"}]}"}],"error_reference":"TECHNICAL"}
        Die Remotes sind "null"
        • G guergen
          tombox
          @guergen Eigentlich sollten diese Fehler nur einmal kommen. Kannst du vielleicht neuinstallieren und checken ob sie nur einmal kommen.
          die remotes müssen auf true gesetzt werden damit sie aktiv sind sie haben bisher kein response
          G 1 Antwort Letzte Antwort
          • T tombox
            guergen
            @tombox ok, mache ich.
            Die Fehler kommen im 10-Minutentakt (Abfrageintervall)
            • G guergen
              tombox
              @guergen werden alle Daten aus der App angezeigt oder fehlt etwas
              • T tombox
                guergen
                @tombox Ich gucke grade alles durch...
                • In der App wird der Fuel-Level nicht angezeigt, im Adapter schon
                • navigationAssistanceLevel ist leer
                Der Fehler kommt trotz Neuinstallation im Abfrageintervall:
                2021-09-29 16:44:34.643 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-settings?country=de
                2021-09-29 16:44:34.643 - error: renault.0 (19060) Error: Request failed with status code 502
                2021-09-29 16:44:34.643 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
                2021-09-29 16:44:34.653 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/res-state?country=de
                2021-09-29 16:44:34.653 - error: renault.0 (19060) Error: Request failed with status code 502
                2021-09-29 16:44:34.653 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
                2021-09-29 16:44:34.672 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charges?country=de
                2021-09-29 16:44:34.672 - error: renault.0 (19060) Error: Request failed with status code 400
                2021-09-29 16:44:34.673 - error: renault.0 (19060) {"type":"FUNCTIONAL","messages":[{"code":"err.func.400","message":"{\"errors\":[{\"status\":\"Bad Request\",\"code\":\"400\",\"title\":\"Required LocalDate parameter 'start' is not present\",\"detail\":\"start is missing\"}]}"}],"errors":[{"errorCode":"err.func.400","errorMessage":"{\"errors\":[{\"status\":\"Bad Request\",\"code\":\"400\",\"title\":\"Required LocalDate parameter 'start' is not present\",\"detail\":\"start is missing\"}]}"}],"error_reference":"FUNCTIONAL"}
                2021-09-29 16:44:34.691 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/battery-inhibition-status?country=de
                2021-09-29 16:44:34.692 - error: renault.0 (19060) Error: Request failed with status code 502
                2021-09-29 16:44:34.692 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
                2021-09-29 16:44:34.710 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v2/cars/VF1RJXXXXXXXXXX/battery-status?country=de
                2021-09-29 16:44:34.711 - error: renault.0 (19060) Error: Request failed with status code 502
                2021-09-29 16:44:34.711 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
                2021-09-29 16:44:34.761 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-settings?country=de
                2021-09-29 16:44:34.761 - error: renault.0 (19060) Error: Request failed with status code 502
                2021-09-29 16:44:34.761 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
                2021-09-29 16:44:34.785 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/hvac-settings?country=de
                2021-09-29 16:44:34.786 - error: renault.0 (19060) Error: Request failed with status code 502
                2021-09-29 16:44:34.786 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
                2021-09-29 16:44:34.982 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/hvac-status?country=de
                2021-09-29 16:44:34.983 - error: renault.0 (19060) Error: Request failed with status code 502
                2021-09-29 16:44:34.983 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"/ vehicledata API: vnext error http_code=403/ GetCurrentScheduledPresoakCommand API: vnext error http_code=403\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"/ vehicledata API: vnext error http_code=403/ GetCurrentScheduledPresoakCommand API: vnext error http_code=403\"}]}"}],"error_reference":"TECHNICAL"}
                • G guergen
                  tombox
                  @guergen Fuel Level wird nicht in der App angezeigt. Das ist eigenartig.
                  Bitte nochmal installieren dann sollten die Fehler weg sein
                  • T tombox
                    guergen
                    @tombox Ich habe ein LPG-Captur, vielleicht liegt es daran.
                    Wird grade neu installiert...
                    • Jey CeeJ Online
                      Jey CeeJ Online
                      Jey Cee
                      schrieb am zuletzt editiert von Jey Cee
                      Also der Adapter gefällt mir schon mal, aber den Objekten fehlen noch die Units und der Datenpunkt charging power.
                      Die Kilometer Anzeige stimmt auch nicht, da stehen die Kilometer drin von dem Tag als wir den gekauft haben, im ZOE2 ist der richtige Wert drin.
                      Außerdem sind da einige Fehler im Log:
                      Persönlicher Support
                      Spenden -> paypal.me/J3YC33
                      • T tombox
                        guergen
                        @tombox Die Fehler kommen jetzt nur noch beim Start des Adapters.
                        Wegen der Tankanzeige gucke ich gleich nach und schreibe morgen das Ergebnis ;-)
                        • Jey CeeJ Jey Cee
                          tombox
                          @jey-cee Das heißt du hast ein zoe?
                          total Mileage ist eigentlich unter cockpit zu finden
                          Komisch das er so viele Fehler wirft. Wird denn unter location was angezeigt bzw war das im zoe2 so?
                          Ich glaube es wäre hilfreich wenn ich kurz die zugangsdaten zu einem zoe bekomme
                          Jey CeeJ G 2 Antworten Letzte Antwort
                          • T tombox
                            Jey CeeJ Online
                            Jey CeeJ Online
                            Jey Cee
                            @tombox ja hab ne ZOE, ist eine der ersten. Da kann die App so gut wie gar nix Außer Akkustand anzeigen und wenn sie lädt, den Ladevorgang abbrechen.
                            Wegen Zugangsdaten schreib ich dir nacher direkt.
                            • T tombox
                              guergen
                              @tombox die mileage unter general müsste der Kilometerstand sein, der beim Anmelden der App aktuell waren. bei mir passt das: 4313 km am 29.3.21
                              Obwohl... ich glaube ich habe die App nicht da installiert.... Aber Datum ind Kilometerstand stimmen von dem Tag
                              • G guergen
                                tombox
                                @guergen General wird nicht aktualisiert nur beim start des adapters geschrieben. Die Daten unter Cockpit werden aktualisiert
                                @Jey-Cee lösche mal dein log weil man da dein VIN sieht
                                • T tombox
                                  HomoranH Offline
                                  HomoranH Offline
                                  @tombox sagte in Test Adapter renault v0.0.x:
                                  besteht da die Möglichkeit die VIN gar nicht als object zu nehmen, sondern einen Alias, der in der Konfiguration vergeben wird?
                                  BTW: steht die VIN nicht auch in der Windschutzscheibe öffentlich sichbar?
                                    tombox
                                    Ja die VIN ist eigentlich nichts geheimes oder lassen sich private Informationen ableiten.
                                    Eigentlich müssten die totalMileage unter cockpit sein aber ich weiß nicht warum sie leer sind vielleicht muss das Fahrzeug erst bewegt werden.
                                    Falls es länger leer bleibt werde ich auch die information unter general regelmässig updaten müssen
                                    Ich habe die Fehler am Anfang als Info geändert und werden jetz alle ignoriert
                                    • T tombox
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      nein.. die steht für jeden offen ensehbar.. am Auto
                                      • T tombox
                                        guergen
                                        @tombox Der Fuelstand ist nicht in der App; wahrscheinlich liegt es am Bi-Fuel.
                                        0b der Fuelstand (ich gehe vom Benzin aus) sich ändert kann ich erst sagen, wenn ich mal wieder tanke oder längere Zeit mit Benzin fahre, was ich ja normal vermeiden will!
                                        • G guergen
                                          tombox
                                          @guergen Kannst du kurz sagen unter welchem Ordner der Datenpunkt sichtbar ist
