  4. Adapter: ebus
    6.7k
Adapter: ebus
ebus adapter
712 Beiträge 73 Kommentatoren 331.5k Aufrufe 60 Beobachtet
  • GlasfaserG Glasfaser
    @pairo sagte in Adapter: ebus:
    --configpath=/etc/ebusd
    Versuche mal Online die Daten zu holen .
    EBUSD_OPTS="-d /dev/ttyUSB0 -p 8888  --latency=10000 --receivetimeout=100000 -l /var/log/ebusd.log --configpath=http://ebusd.eu/config/  --scanconfig=full  --httpport=8889 --htmlpath=/var/ebusd/html"
    PaiRo
    schrieb am zuletzt editiert von PaiRo
    #350
    @glasfaser
    habe es geändert, leider ist es nicht besser geworden:
    pi@raspberrypi:~ $ service ebusd status
    ● ebusd.service - LSB: controls ebusd, the daemon for communication with eBUS heating systems.
       Loaded: loaded (/etc/init.d/ebusd; generated)
       Active: active (running) since Fri 2021-07-02 18:01:03 CEST; 11min ago
         Docs: man:systemd-sysv-generator(8)
      Process: 7643 ExecStart=/etc/init.d/ebusd start (code=exited, status=0/SUCCESS)
        Tasks: 4 (limit: 4915)
       CGroup: /system.slice/ebusd.service
               └─7650 /usr/bin/ebusd --pidfile /var/run/ebusd.pid -d /dev/ttyUSB0 -p 8888 --latency=10000 --receivetimeout=100000 -l /var/log/ebusd.log --configpath=http://ebusd.eu/config/ --s
    Jul 02 18:01:03 raspberrypi systemd[1]: Starting LSB: controls ebusd, the daemon for communication with eBUS heating systems....
    Jul 02 18:01:03 raspberrypi ebusd[7643]: Starting ebusd: ebusd.
    Jul 02 18:01:03 raspberrypi systemd[1]: Started LSB: controls ebusd, the daemon for communication with eBUS heating systems..
    eher schlechter:
    pi@raspberrypi:~ $ ebusctl i
    version: ebusd 21.2.v21.2
    signal: acquired
    symbol rate: 23
    max symbol rate: 130
    min arbitration micros: 629
    max arbitration micros: 3956
    min symbol latency: 4
    max symbol latency: 8
    reconnects: 0
    masters: 3
    conditional: 3
    poll: 0
    update: 10
    address 03: master #11
    address 08: slave #11, scanned "MF=Vaillant;ID=BAI00;SW=0104;HW=7803", loaded "vaillant/bai.308523.inc", "vaillant/08.bai.csv"
    address 10: master #2
    address 15: slave #2
    address 31: master #8, ebusd
    address 36: slave #8, ebusd
    address ed: slave, scanned "MF=Vaillant;ID=VMS02;SW=0108;HW=1703"
    ist es normal, dass ich nach einer config Änderung die Heizung aus und wieder einschalten muss?
    Ich mache immer:
    service ebusd stop
    nano /etc/default/ebusd - anpassen
    service ebbst start
    Danach findet er garnichts mehr. Schalte ich die Heizungsanlage aus und danach wieder ein findet er was - siehe oben ebusctl i
    Was mir noch aufgefallen ist, bei mir steht bei der Abfrage service ebusd status in Zeile 9 --pidfile /var/run/ebusd.pid```
    das habe ich so noch nirgends gesehen, liegt es evtl. daran?
    • P PaiRo
      @glasfaser
      eher schlechter:
      signal: acquired
      symbol rate: 23
      reconnects: 0
      masters: 3
      conditional: 3
      poll: 0
      update: 10
      Ich mache immer:
      service ebusd stop
      service ebbst start
      GlasfaserG Offline
      GlasfaserG Offline
      #351
      @pairo
      Versuche mal damit ,hier war das gleiche :
      https://forum.iobroker.net/topic/29359/ebus-adapter-vaillant/119
      und einmal hier :
      https://forum.iobroker.net/topic/29359/ebus-adapter-vaillant/135
      P 1 Antwort Letzte Antwort
        @pairo
        und einmal hier :
        PaiRo
        #352
        @glasfaser ok schaue ich mir an.
        • Rene_HMR Offline
          Rene_HMR Offline
          Rene_HM
          schrieb am zuletzt editiert von Rene_HM
          #353
          Anscheinend gibt es ein Problem beim Lesen der Daten vom ebusd mit Version 21.2 .
          siehe issue im github
          Seit Version 21.2 vom ebusd werden teilweise Knoten mit eckigen Klammern im Namen gesendet. Das führt zum Absturz des Adapters. Ich arbeite derzeit an einem workaround. Gleichzeitig habe ich aber ein Ticket bei John30 eröffnet, weil ich mir nicht sicher bin, ob das evtl. ein Problem vom ebusd ist.
          Mich würde deshalb interessieren, wer das Problem noch hat und wie sich das auswirkt.
          Bei mir stellt sich das Problem im browser so dar:
          • Rene_HMR Offline
            Rene_HMR Offline
            Rene_HM
            #354
            Im github und NPM liegt die 2.3.2 zum Testen bereit.
            siehe auch github
            Es gibt folgende Änderungen:
            • ebusd in der Version 21.2 wird nun unterstützt
            • Datenpunkte, welche als Wert on / off liefern, können nun optional als Boolean interpretiert werden (muss im admin aktiviert werden). Der Datenpunkt im ioBroker ist dann vom Type boolean und liefert true /false. Original war es ein string und lieferte on / off
            Feedback ist wie immer willkommen...
            • Rene_HMR Rene_HM
              siehe auch github
              Kanumouse
              #355
              @rene_hm
              Kann das sein, dass es in dieser Version ei Problem mit dem Schreiben auf dem ebus gibt?
              Bisher hatte das bei mir problemlos funktioniert, seit dem update auf die neue Version nicht mehr.
              Rene_HMR 1 Antwort Letzte Antwort
              • K Kanumouse
                @rene_hm
                Rene_HMR Offline
                Rene_HMR Offline
                Rene_HM
                #356
                @kanumouse Was funktioniert denn konkret nicht? Gibt es Fehlermeldungen? Was sagt das log?
                Auf meinem System (live und test) habe ich keine Probleme...
                • Rene_HMR Rene_HM
                  Kanumouse
                  #357
                  @rene_hm
                  Im Log habe ich keine Fehlermeldung gefunden. Das Kommando wird richtigerweise durch mein Script in „cmd“ der ebus-Objekte geschrieben. Wenn die zyklische Abfrage des ebus erfolgt, verschwindet das Kommando auch von dort. Mit telnet kann ich auf port 8888 auch auf den ebusd zugreifen. Alle lesenden Abfragen des ebusd funktionieren auch fehlerfrei. Ich kann momentan das Problem leider nicht weiter eingrenzen.
                  Was mit noch einfällt und mich gewundert hat: bei der ebus-Objekten ist auch unter „cmd result“ die Beschreibung des write-Befehls zu finden. Ist das richtig?
                  • K Kanumouse
                    @rene_hm
                    Rene_HMR Offline
                    Rene_HMR Offline
                    Rene_HM
                    #358
                    @kanumouse erstelle mal bitte ein issue in github. Ich schaue mir das nochmal an...
                    Bei mir sieht das so aus:
                    und wie erkennst du, dass das Schreiben nicht funktioniert?
                    • Rene_HMR Rene_HM
                      Kanumouse
                      #359
                      @rene_hm
                      Bei mir steht unter „cmdResult“-Wert das:
                      usage: write [-s QQ] [-d ZZ] -c CIRCUIT NAME [VALUE[;VALUE]]
                      or: write [-s QQ] [-d ZZ] -def DEFINITION [VALUE[;VALUE]
                      ] (only if enabled)
                      or: write [-s QQ] [-c CIRCUIT] -h ZZPBSBNN[DD]*
                      Write value(s) or hex message.
                      -s QQ override source address QQ
                      -d ZZ override destination address ZZ
                      -c CIRCUIT CIRCUIT of the message to send
                      NAME NAME of the message to send
                      VALUE a single field VALUE
                      -def write with explicit message definition (only if enabled):
                      DEFINITION message definition to use instead of known definition
                      -h send hex write message:
                      ZZ destination address
                      PB SB primary/secondary command byte
                      NN number of following data bytes
                      DD data byte(s) to send
                      Das nichts geschrieben wird sehe ich an den unveränderten Werten, die ich beim Lesen im Log mitlesen kann. Außerdem habe ich sicherheitshalber auch noch direkt an der Heizung kontrolliert. Vorher hat alles problemlos funktioniert, ich konnte z.B. Solltemperatungen, Heizprogramme, Wartungstermine, ect. schreiben.
                      • K Kanumouse
                        @rene_hm
                        ] (only if enabled)
                        Rene_HMR Offline
                        Rene_HMR Offline
                        Rene_HM
                        #360
                        @kanumouse welche Version vom ebusd nutzt du? Hast du den auch aktualisiert? Funktioniert dein write-Befehl in Telnet noch?
                        • Rene_HMR Rene_HM
                          Kanumouse
                          #361
                          @rene_hm
                          Ich benutze ebusd- Version 21.2.
                          direkt mit telnetfunktioniert das Schreiben noch.
                          • K Kanumouse
                            @rene_hm
                            Rene_HMR Offline
                            Rene_HMR Offline
                            Rene_HM
                            #362
                            @kanumouse und du nutzt in telnet den gleichen Schreibbefehl wie aus deinem script?
                            Das was als Resultat in cmdResult steht, ist das, was ich vom ebusd als Ergebnis auf die Ausführung des Kommandos erhalte. Wenn der ebusd mit
                            usage: write  ...
                            antwortet, will er uns damit sagen, dass die Syntax des Befehls nicht passt. Da ich den Befehl aus dem Datenpunkt "cmd" direkt durchreiche, vermute ich ein Problem mit dem Kommando selbst.
                            Stelle den Adapter mal auf debug und poste das log.
                            • Rene_HMR Rene_HM
                              usage: write  ...
                              Kanumouse
                              #363
                              @rene_hm
                              Also ich habe das jetzt noch einmal vo meinem anderen PC direkt mit telnet getestet. Ich kann alle Elemente fehlerfrei lesen, habe jetzt aber doch festgestellt, dass ich nicht schreiben kann. Dann kommt immer ERR: Element not found.
                              Kann z.B. PhoneNumber mit „read -f PhoneNumber“ lesen, aber nicht mit dem Kommando „write -c 470 PhoneNumber xxxxxxx“ schreiben.
                              • K Kanumouse
                                @rene_hm
                                Kanumouse
                                #364
                                @kanumouse
                                Hat jemand eine Idee, warum ich auf den ebus plötzlich mit telnet nicht mehr schreiben kann?
                                Das Lesen der Datenpunkte funktioniert einwandfrei.
                                • K Kanumouse
                                  @kanumouse
                                  Kanumouse
                                  #365
                                  @kanumouse
                                  Ok, ich habe das Problem gefunden und kann jetzt auch schreiben.
                                  Die ebusd-config habe ich um den Eintrag "accesslevel=*" ergänzt. War also ein Berechtigungsproblem. Warum das vorher funktioniert hat kann ich nicht nachvollziehen. Der Fahler ist also rein zufäälig mit dem Update des ebus-Adapter zu Tage getreten.
                                  Der Adapter funktioniert also ordnungsgemäß.
                                  Danke rene_hm für die Unterstützung!
                                  • TimmerxT Offline
                                    TimmerxT Offline
                                    Timmerx
                                    #366
                                    HAllo LEute,
                                    ich habe seit gestren das Problem, das ich keine Daten mehr von meine Ebus empfange.
                                    Das Problem scheint der Port zusein
                                    pi@raspberrypi:~ $ sudo ebusctl stop
                                    error connecting to localhost:8888
                                    pi@raspberrypi:~ $ sudo ebusctl start
                                    pi@raspberrypi:~ $ sudo nano /etc/default/ebusd
                                    pi@raspberrypi:~ $ ebusctl --server=192.168.178.48 i
                                    error connecting to 192.168.178.48:8888
                                    pi@raspberrypi:~ $ sudo ebusctl info
                                    Egal was ich eingebe ich bekomme immer diese Antwort.
                                    Was ist da los?
                                    Hat sich da die Portfreigabe in der Fritzbox geändert/gelöscht?
                                    Oder ??? ....
                                    C 1 Antwort Letzte Antwort
                                    • TimmerxT Timmerx
                                      HAllo LEute,
                                      Was ist da los?
                                      Oder ??? ....
                                      cactus-online
                                      #367
                                      @timmerx Läuft Dein eBusD ? Was sagen ?
                                      systemctl status ebusd
                                      ps aux | grep -i ebusd
                                      • C Offline
                                        Cino
                                        #368
                                        Ich hab dies neuerdings im Log stehen. Was hat das zu bedeuten?
                                        ebus.0
                                        2021-10-03 09:52:08.245	info	Terminated (NO_ERROR): Without reason
                                        ebus.0
                                        2021-10-03 09:52:08.243	info	all http done
                                        ebus.0
                                        2021-10-03 09:52:08.162	info	found ebusd version 21.2
                                        ebus.0
                                        2021-10-03 09:52:06.724	warn	updateObject: not updated bai.messages.SetMode.fields.hwcflowtempdesired.value value: null
                                        ebus.0
                                        2021-10-03 09:52:06.721	warn	Key : bai.messages.SetMode.fields.hwcflowtempdesired.value, Value : null name SetMode
                                        ebus.0
                                        2021-10-03 09:52:06.712	warn	updateObject: not updated bai.messages.SetMode.fields.hwctempdesired.value value: null
                                        ebus.0
                                        2021-10-03 09:52:06.708	warn	Key : bai.messages.SetMode.fields.hwctempdesired.value, Value : null name SetMode
                                        ebus.0
                                        2021-10-03 09:52:02.740	info	starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.ebus, node: v12.22.6, js-controller: 3.3.18
                                        IOB@RPI4
                                        Shelly, Zigbee, ebus
                                        • C Cino
                                          ebus.0
                                          ebus.0
                                          ebus.0
                                          ebus.0
                                          ebus.0
                                          ebus.0
                                          ebus.0
                                          ebus.0
                                          Rene_HMR Offline
                                          Rene_HMR Offline
                                          Rene_HM
                                          #369
                                          @cino ebusd stellt den Datenpunkt zwar zur Verfügung, liefert aber keinen Wert dazu. Ich habe das erst mal als Warnung eingebaut, ist aber nur kritisch, wenn man genau den Datenpunkt benötigt...
