  4. Test Coronavirus Statistics for ioBroker
    apollon77A
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 572.8k Aufrufe 94 Beobachtet
  • DutchmanD Dutchman
    @sigi234 sagte in Test Coronavirus Statistics for ioBroker:
    @dutchman sagte in Test Coronavirus Statistics for ioBroker:
    starting. Version 0.8.2 in
    ziehe bitte mal auf neuste version und probieren nochmal :)
    Leider nein
    glaube jetzt sind sie da wurden um 13.44 aktualisiert ?
    sigi234S
    sigi234S
    #993
    Leider nein
    Nur BRD
      Aktuelle Test Version 0.6.9
      Veröffentlichungsdatum 22-03-2021
      Github Link https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/blob/master/README.md
      NPM npm i ioBroker.coronavirus-statistics@latest
      Adapter to show Global Corona Virus information and current reports
      Coronavirus Live Statistics adapter for ioBroker
      There is no configuration required, after installation it will :
      • Receive global information world-wide and write it to "global_totals"
      • Create a folder for each country with all relevant information regarding COVID-19
      • Update the information every 15 minutes
      The following information is available :
      Datapoint Details
      active Amount of current infected people
      cases Amount of totally known cases
      casesPerOneMillion Amount of totally known cases per million citizen
      critical Amount of critical situation (Hospitalized)
      deaths Amount of current registered deaths
      deathsPerOneMillion Amount of current registered deaths per million citizen
      recovered Amount of totally known recovered cases
      todayCases New Cases by Today
      todayDeaths Amount of totally known people died today
      test Total number of covid-19 tests taken globally
      tests per one million counties Total number of covid-19 tests taken globally per one million
      Please be aware this adapter uses as much as possible up-to-date information but there can be an delay of several hours depending on the country's report.
      German Federal States : https://npgeo-corona-npgeo-de.hub.arcgis.com/ s
      Generic Source : https://coronavirus-19-api.herokuapp.com
      Advanced settings
      Option Description
      All Countries Get data for all countries World-Wide (Default: false)
      Continents Group total amounts by continent in seperate state (Default: false)
      Delete unused States Delete data when countries are deselected (Default: false)
      German counties Get counties data for Germany (Selected only, Default false)
      German federal states Get federal state data for Germany (Selected only, Default false)
      Get all German federal states Get federal state data for Germany (Default false)
      Get all German counties Get all counties data for Germany (Default false)
      For Germany only
      It's possible to get data for federal states (Bundesländer) and counties (Landeskreise).
      You can choose to recieve all data or just select specific regions in advanced settings.
      Please note : After activation the the adapter must run 1 time to get all federal states and counties before table loads !
      Add missing countries
      It may happen that countries are not recognized correctly because the API delivers some country names not ISO conform. In such a case you will get a warning message in the log, which looks like this
      coronavirus-statistics.0	2020-03-21 09:05:31.328	warn	(22937) Timor-Leste not found in lib! Must be added to the country name translator.
      Using the datapoint coronavirus-statistics.0.countryTranslator you can assign a country yourself. Look for the name of the corresponding country here:
      List with country names
      With the selected country name you have to create a JSON string and enter it in the datapoint coronavirus-statistics.0.countryTranslator.
      The JSON string then looks like this, for example:
      	"Cabo_Verde": "Cape Verde",
      	"Timor-Leste": "East Timor"
      As first value the name from the warning message must be taken from the log. The name of the country from the List with country names is then assigned to this.
      Changelog
      sigi234S
      sigi234S
      #994
      @dutchman
      habe den Adapter neu installiert und die Objekte gelöscht. Die Daten kommen bei Today wieder nicht.
      Auch die Impfungen DP sind vom 17/18.08.21 ( werden wahrscheinlich nur 1 mal die Woche aktualisiert? )
      • sigi234S sigi234
        @dutchman
        J
        J
        jlssmt
        schrieb am zuletzt editiert von jlssmt
        #995
        @sigi234
        Die todayCases sind auch bei mir 0. Das kommt so von der API. Ich aktualisiere den Adapter aber auch täglich um 5. Da ist vllt noch nichts gemeldet. Die tatsächlich neuen Fälle für heute berechne ich aus dem state "cases" minus "cases gestern". "cases gestern" ist bei mir ein User state, eben von cases gestern, die ich täglich aktualisiere.
        Today cases ist quatsch, da das rki heute Fälle meldet, die vor 2 Wochen waren...
        Die Impfungen werden täglich aktualisiert (zumindest für Deutschland), aber es kann schon sein, dass es sie mal ein paar Tage nicht aktualisiert werden. Wenn gestern drin steht sind sie aktuell. Deutschland hat bei mir 18.08., Niederlande 15.08.
        • J jlssmt
          @sigi234
          J
          J
          jlssmt
          #996
          @sigi234
          Das mit den Impfungen siehst du übrigens auch bei Google. Wir verwenden die selbe Datenquelle.
          • J jlssmt
            @sigi234
            sigi234S
            sigi234S
            #997
            @jlssmt
            Ok, Danke.
            • WinniW
              WinniW
              Winni
              #998
              Unabhängig vom Adapter finde ich diese Seite ganz gut um sich einen Überblick zum Stand der Impfungen zu verschaffen:
              https://www.zeit.de/wissen/gesundheit/corona-impfungen-deutschland-impffortschritt-aktuelle-zahlen-karte
              ChrisNettC 1 Antwort Letzte Antwort
              • WinniW Winni
                ChrisNettC
                ChrisNettC
                ChrisNett
                #999
                Moin,
                noch einer das Problem das die daten nicht Aktuell sind ? er holt immer wieder die gleichen daten ab? sind die gleichen zahlen für die LK wie gestern (Das bei drei unterschiedlichen)
                Christian
                v522533V 1 Antwort Letzte Antwort
                • ChrisNettC ChrisNett
                  Moin,
                  Christian
                  v522533V
                  v522533V
                  v522533
                  #1000
                  @christian-sandkaulen
                  das rki hat auch noch nichts veröffentlicht. liegt glaube ich nicht am adapter
                  Gruß Chris
                  • v522533V v522533
                    ChrisNettC
                    ChrisNettC
                    ChrisNett
                    #1001
                    @v522533
                    oh ja wenn das so ist dann funktioniert er ja :-)
                    Hospitalisierungsrate wäre noch hilfreich je LK.
                    DutchmanD J 2 Antworten Letzte Antwort
                      @v522533
                      DutchmanD
                      DutchmanD
                      Dutchman
                      #1002
                      @christian-sandkaulen sagte in Test Coronavirus Statistics for ioBroker:
                      habe noch keine source dafuer
                        ChrisNettC
                        ChrisNettC
                        ChrisNett
                        #1003
                        source
                        So sind wir eben... führen neue Zahlen ein aber wo und wie man die bekommt ist nicht zu sagen...
                        Danke!
                          @v522533
                          J
                          J
                          jlssmt
                          #1004
                          Krankenhausdaten pro Landkreis wären ggf. mit der schon implementierten DIVI API machbar. Weiß ich aber grad nicht 100%
                          Habe aber persönlich noch keinen Sinn darin gesehen, da zumindest in Bayern die Daten für ganz Bayern gelten und nicht pro Landkreis. Ist das Krankenhaus voll, wirst du ja auch zum nächsten gefahren.
                          ChrisNettC O 2 Antworten Letzte Antwort
                          • J jlssmt
                            ChrisNettC
                            ChrisNettC
                            ChrisNett
                            #1005
                            @jlssmt sagte in Test Coronavirus Statistics for ioBroker:
                            Das stimmt wohl aber die Maßnahmen werden wohl zumindest an den Zahlen der Länder gekoppelt die waren hilfreich.
                            • J jlssmt
                              O
                              O
                              obakuhl
                              #1006
                              @jlssmt Wenn ich es aber richtig gesehen habe, hast du schon die Hospitalisierungsrate für die jeweiligen Bundeslänger in einem der letzten commits implementiert oder?
                              • O obakuhl
                                DutchmanD
                                DutchmanD
                                Dutchman
                                #1007
                                @obakuhl sagte in Test Coronavirus Statistics for ioBroker:
                                ist in der git version drin ich muss noch ne release machen (am WE)
                                O 1 Antwort Letzte Antwort
                                  J
                                  J
                                  jlssmt
                                  #1008
                                  Die Bundesländer und Daten für Gesamt Deutschland sind schon drin.
                                  Uns fehlt aktuell noch eine Datenquelle um "Gelb" bei der Corona Ampel von Bayern abzubilden. Die bezieht sich auf die neuen Krankenhauseinlieferungen der letzten sieben Tage und wir wollen das nicht selbst über eine Historie berechnen. Einerseits ist das aufwändig, andererseits weiß ich nicht ob das 100% passt wenn dann irgendwelche Einlieferungen nachgemeldet werden oder so.
                                    Datapoint Details
                                    Advanced settings
                                    Option Description
                                    For Germany only
                                    Changelog
                                    sigi234S
                                    sigi234S
                                    #1009
                                    @dutchman
                                    Kann man die Hospitalisierungsrate auch für Österreich einbinden?
                                    • sigi234S sigi234
                                      @dutchman
                                      DutchmanD
                                      DutchmanD
                                      Dutchman
                                      #1010
                                      @dutchman
                                      Wen es ne api source gibt…
                                        @dutchman
                                        sigi234S
                                        sigi234S
                                        #1011
                                        @dutchman
                                        Habe nur das gefunden:
                                        https://www.data.gv.at/katalog/dataset/covid-19-daten-zur-auslastung-in-spitalern-und-testergebnissen
                                          O
                                          O
                                          obakuhl
                                          #1012
                                          @dutchman said in Test Coronavirus Statistics for ioBroker:
                                          Spricht noch was dagegen ein Release zu erstellen?
                                          83.9k
