  4. Test ViessmannAPI v2.0.0
827 Beiträge 129 Kommentatoren 400.7k Aufrufe 125 Beobachtet
  • I ioAli
    @keepon sagte in Test ViessmannAPI v2.0.0:
    Hi, danke für deine Arbeit. Ich habe den alten Adapter deinstalliert und diesen hier installiert. Allerdings bekomme ich beim Installieren diese Fehlermeldung:
    $ iobroker url https://github.com/TA2k/ioBroker.viessmannapi --host iobroker --debug
    install TA2k/ioBroker.viessmannapi#b13be1884571d93ddbecb8cdf5b50c9a8e7e9c56
    NPM version: 6.14.13
    npm install TA2k/ioBroker.viessmannapi#b13be1884571d93ddbecb8cdf5b50c9a8e7e9c56 --prefix "/opt/iobroker" (System call)
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@^2.2.1 (node_modules/node-dtls-client/node_modules/node-aead-crypto):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported engine for node-aead-crypto@2.2.1: wanted: {"node":">4 <10"} (current: {"node":"14.17.2","npm":"6.14.13"})npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Not compatible with your version of node/npm: node-aead-crypto@2.2.1
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/node-aead-crypto/package.json'
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    + iobroker.viessmannapi@2.0.0updated 1 package in 15.941s
    66 packages are looking for funding run `npm fund` for details
    upload [4] viessmannapi.admin /opt/iobroker/node_modules/iobroker.viessmannapi/admin/words.js words.js application/javascript
    upload [3] viessmannapi.admin /opt/iobroker/node_modules/iobroker.viessmannapi/admin/viessmannapi.png viessmannapi.png image/png
    upload [2] viessmannapi.admin /opt/iobroker/node_modules/iobroker.viessmannapi/admin/style.css style.css text/css
    upload [1] viessmannapi.admin /opt/iobroker/node_modules/iobroker.viessmannapi/admin/index_m.html index_m.html text/html
    upload [0] viessmannapi.admin /opt/iobroker/node_modules/iobroker.viessmannapi/admin/admin.d.ts admin.d.ts video/mp2t
    Process exited with code 0
    Weis jemand wie und was ich hier nachinstallieren muss?
    Vielen Dank!
    Hallo zusammen
    ich freue mich das es nun diesen neuen Adapter gibt.
    Ich habe bei der Installation des Adapter ähnliche Warnungen erhalten wie hier von KeePon beschrieben:
    $ iobroker url https://github.com/TA2k/ioBroker.viessmannapi --host ioBroker1RPI4 --debug
    install TA2k/ioBroker.viessmannapi#4fd277ca095a9dc55ec99062b1e19000973b6ec9
    NPM version: 6.14.12npm install TA2k/ioBroker.viessmannapi#4fd277ca095a9dc55ec99062b1e19000973b6ec9 --prefix "/opt/iobroker" (System call)
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/aws-sdk/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/escodegen/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/jsdom/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/nconf/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/pg/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/sharp/package.json'
    npm WARN pg-pool@3.3.0 requires a peer of pg@>=8.0 but none is installed. You must install peer dependencies yourself.
    + iobroker.viessmannapi@2.0.1updated 1 package in 31.287s
    58 packages are looking for funding run `npm fund` for details
    Es sind zwar "nur" Warnungen, im Anschluss ist unter ioBroker kein neuer Viessmann-Adapter erschienen.
    Ich habe vor der Installation die alte Viessmann-Instanz und die dazugehörigen Datenpunkte gelöscht.
    @KeePon: Konntest du die Installation erfolgreich durchführen? Wenn ja, wie hast du es hinbekommen?
    Ich bin dankbar für jeden Tip.
    Gruß ioAli
    tombox
    #157
    @ioali normales verhalten kann ignoriert werden
    I 1 Antwort Letzte Antwort
    • T tombox
      I Offline
      I Offline
      ioAli
      #158
      @tombox
      Hallo tombox
      danke für die zügige Rückmeldung.
      Das Problem ist jedoch das nach der Installation des Adapter (über die URL https://github.com/TA2k/ioBroker.viessmannapi ) mit den obigen Warnungen keine Instanz namens Viessmann oder ähnlich angelegt wurde. Unter den Datenpunkte ist jedoch der Eintrag Viessmann und darunter admin zu finden. Es feht also die Instanz um darin die Optionen einzustellen.
      Gruß ioAli
      • I ioAli
        @tombox
        Hallo tombox
        Gruß ioAli
        tombox
        #159
        @ioali Installiere einfach wie in Beitrag 1 beschrieben dann müsste es gehen
        • T tombox
          I Offline
          I Offline
          ioAli
          #160
          @tombox
          Hallo tombox
          es funktioniert jetzt, vielen Dank. 👍 😀
          Mein Denkfehler:
          Ich hatte erwartet das es nach der Installation in der Adapterliste einen "neuen" Adapter gibt.
          Für mich sah es so aus als handelte es sich bei dem Adapter "viessmannapi" um den bisher schon dagewesenen Adapter.
          Bestätigt wurde diese Annahme noch dadurch, das beim öffnen von Liesmich (das Fragezeichen) scheinbar die Infos zum alten Viesmann-Adapter angezeigt wurden.
          Freue mich das ich wieder auf die Daten meine Heizung zugreifen kann, tolle Arbeit
          Gruß ioAli
          P 1 Antwort Letzte Antwort
          • I ioAli
            @tombox
            Hallo tombox
            Mein Denkfehler:
            Gruß ioAli
            photographix
            schrieb am zuletzt editiert von photographix
            #161
            Gab es irgendeine Änderung? Seit dem 01.09. habe ich nur Probleme mit dem Adapter. Er ist zwar an liefert aber keine Daten mehr. Nach einer Neuinstallation geht dies nur kurz :-/
            Im Log habe ich zumindest nichts auffälliges gefunden. Ich weiss aber auch nicht nach was ich konkret suchen muss. Vielleicht hat ja jemand eine Idee. Polling ist default 5min im Adapter - nix geändert.
            EDIT: hat sich nach 3maligem neu installieren selber gefixt. Kann leider nicht sagen woran es lag. Es geht zumindest nun wieder.
            ioBroker in Docker auf Raspberry PI 4 / 4GB
            CCU2 mit Strommessung, JeeLink v3c für TX29DHT-ITs, Maxtox's RF-Link 868 Mhz Arduino, Tradfri Lampen, Shellys
            • C Offline
              ceram
              #162
              erstmal vielen Dank @tombox für die Entwicklung des Adapters.
              Das Auslesen der Werte klappt schonmal einwandfrei bei mir. Leider ist das Setzen von Werten über die *.setValue-Datenpunkte reine Glückssache. Grundsätzlich gehen die Setter zwar. Aber von Zeit zu Zeit, in letzter Zeit sogar meistens, hat das keinen Effekt. Im Log taucht dann ein Timeoutfehler auf:
              viessmannapi.0
              2021-09-02 16:53:38.750	error	{"viErrorId":"req-HierStehtEineHexID","statusCode":502,"errorType":"DEVICE_COMMUNICATION_ERROR","message":"DEVICE_COMMUNICATION_ERROR","extendedPayload":{"code":"unknown","httpStatusCode":"0","message":"The request timed-out."}}
              viessmannapi.0
              2021-09-02 16:53:38.738	error	Error: Request failed with status code 502
              Gibt es dafür einen Fix?
              Viele Grüße
              ceram
              • C ceram
                viessmannapi.0
                viessmannapi.0
                Viele Grüße
                ceram
                tombox
                #163
                @ceram sowas im viessmann Developer Forum melden
                C 1 Antwort Letzte Antwort
                • T tombox
                  ceram
                  #164
                  @tombox Danke, habe das auch dort platziert.
                  Da das ja offenbar eine größere Sache ist und ggf. auch an einer schlechten Verbindung zur Vitoconnect liegen könnte, was schwer zu beheben wäre, Frage in die Runde: Gibt es eine Möglichkeit, per Javascript auf das Auftreten dieses Time-Out-Fehlers zu subscriben, sodass dann versucht werden kann, die Werte erneut reinzuschreiben?
                  • C ceram
                    tombox
                    #165
                    @ceram der Adapter updated die Werte 10sek nach dem setzen. Man könnte also 15sek später schauen ob der Wert sich geändert hat und wenn nicht nochmal setzen.
                      aueland
                      #166
                      Moin, erstmal Dankeschön für den Adapter, läuft soweit undliefert auch einige Werte. Allerdings wird bei mir zum burner nicht alles angezeit, was laut API-Doku da sein sollte, insbesondere
                      heating.burners.N.statistics
                      fehlt gänzlich. Liegt das an meinem System oder ist in dem Adapter etwas nicht ganz passend?
                      Anbei ein Screenshot der Datenpunkte die zum Brenner reinkommen bei mir:
                      T J 2 Antworten Letzte Antwort
                      • A aueland
                        tombox
                        #167
                        @aueland der Adapter reicht die Daten ungefiltert weiter also eher eine Anfrage für das viessmann forum
                        • A aueland
                          J Online
                          J Online
                          jrudolph
                          #168
                          @aueland Der Pfad zu den Brennern (und damit auch zu den Statistics) ist laut API-Doku heating/burners/0/statistics/...
                          • T tombox
                            August 2021
                            Updates zu neuen und geänderten Device Features
                            Folgende Features sind nun über die API zugänglich. Zum Teil ersetzen sie frühere (veraltete) Features:
                            heating.gas.consumption.total
                            heating.power.consumption.total >> ersetzt heating.power.consumption
                            heating.power.consumption.heating
                            heating.power.consumption.dhw
                            heating.dhw.temperature.main >> ersetzt heating.dhw.temperature
                            heating.dhw.temperature.hygiene
                            heating.dhw.temperature.temp2
                            heating.compressors.N >> ersetzt heating.compressor
                            heating.compressors.N.statistics >> ersetzt heating.compressor.statistics
                            SentiQ
                            #169
                            @tombox said in Test ViessmannAPI v2.0.0:
                            August 2021
                            Diese Punkte erscheinen bei mir nicht, kann jemand sagen warum?
                            • S SentiQ
                              August 2021
                              tombox
                              #170
                              @sentiq Das kann nur viessmann sagen
                              • Bjoern77B Bjoern77
                                @tombox
                                tombox schrieb:
                                Wie gesagt wegen fehlenden Datenpunkte direkt bei Viessmann fragen
                                https://www.viessmann-community.com/t5/The-Viessmann-API/bd-p/dev-viessmann-api
                                Wenn viessmann sie hinzufügt tauchen sie sofort auch im adapter auf.
                                Moin
                                Ich habe dort mal einen Post aufgemacht. Allerdings, wenn man sich die anderen Beiträge dort anschaut,
                                macht das wenig Hoffnung. Naja, mal abwarten.
                                Hoffentlich versaut sich Viessmann das nicht selber.
                                Schlieslich sammeln und verarbeiten sie ja unsere Daten für Umsonst. Und das ist bestimmt mehr Wert als die Bereitstellung eines Servers.
                                Björn
                                SentiQ
                                #171
                                @bjoern77 schon Antwort erhalten? Habe ähnliches Problem.
                                Bjoern77B 1 Antwort Letzte Antwort
                                • J jrudolph
                                  aueland
                                  #172
                                  @jrudolph said in Test ViessmannAPI v2.0.0:
                                  Ja, eben, und der Ordner "burners" fehlt mir komplett... Muss ich wohl doch mal bei Viessmann fragen.
                                  • T tombox
                                    manrum1
                                    #173
                                    @tombox Hallo, auch von meiner Seite vielen Dank für den neuen Viessmann Adapter.
                                    Leider habe ich immer noch das Problem, dass der Adapter plötzlich keinen Daten mehr liefert. Das Status-Objekte zeigen an, dass der Adapter läuft:
                                    viessmannapi.0.info.connection = true
                                    viessmannapi.0.xx.0.general.status = online
                                    Temperaturen bleiben auf alten Werten, genauso alle anderen Werte. Im Log findet man keine Einträge. Nach Restart läuft wieder alles.
                                    Frage: Wie kann man erkennen, dass der Adapter eigentlich offline ist oder vielleicht abgestürtzt ist?
                                    • M manrum1
                                      tombox
                                      #174
                                      @manrum1 Das sollte nicht passieren du kannst den Adapter in debug setzen dann müsstest du die regelmässigen rückmeldung der api sehen
                                      • T tombox
                                        manrum1
                                        #175
                                        @tombox Danke für die schnelle Antwort. Das Problem ist, dass das sporadisch auftrittund ich kann ja schlecht dauernd auf das Log schauen. Ich hatte schon die Idee die timestamps von Objekten abzufragen, aber die ändern sich erst, wenn der Wert sich geändert hat.
                                        Gibt es nicht eine Art watchdog, mit der sich der Adpater selber testet ob er noch online ist?
                                        Oder gibt es seitens des iobrokers eine Möglichkeit den Adapter zu testen ob er noch lebt?
                                        • M manrum1
                                          tombox
                                          #176
                                          @manrum1 Der Log dient dazu die Ursache zu finden. Denn es ist unwahrscheinlich das der Adapter keine Daten liefer sondern die API. Der Log dient dazu festzustellen was die API genau liefert.
                                          M 2 Antworten Letzte Antwort
