  4. Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest
    6.4k
sainlogicwetterstationadapterws980wififroggit wh4000sh
326 Beiträge 60 Kommentatoren 102.0k Aufrufe 51 Beobachtet
  • qqolliQ qqolli
    @fogg
    gerade ist meine Sainlogic WS3500 Wetterstation gekommen und ich wollte mir Deinen Adapter installieren. Leider bekomme ich bei der Installation folgenden Fehler (Code: 25) angezeigt:
    $ iobroker add sainlogic --host ioBroker
    NPM version: 6.14.14
    npm install iobroker.sainlogic@0.7.2 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code ETARGET
    npm ERR! notarget No matching version found for iobroker.sainlogic@0.7.2.npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-08-21T09_50_30_041Z-debug.log
    host.ioBroker Cannot install iobroker.sainlogic@0.7.2: 1
    ERROR: Process exited with code 25
    Anbei zur Info der komplette log:
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli   '/usr/bin/node',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'iobroker.sainlogic@0.7.2',
    1 verbose cli   '--loglevel',
    1 verbose cli   'error',
    1 verbose cli   '--prefix',
    1 verbose cli   '/opt/iobroker'
    1 verbose cli ]
    2 info using npm@6.14.14
    3 info using node@v12.22.5
    4 verbose npm-session 9dfae1f10b5b6e6a
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 http fetch GET 200 https://registry.npmjs.org/iobroker.sainlogic 44ms (from cache)
    8 silly registry:manifest no matching version for iobroker.sainlogic@0.7.2 in the cache. Forcing revalidation.
    9 http fetch GET 200 https://registry.npmjs.org/iobroker.sainlogic 938ms
    10 silly fetchPackageMetaData error for iobroker.sainlogic@0.7.2 No matching version found for iobroker.sainlogic@0.7.2.
    11 timing stage:rollbackFailedOptional Completed in 2ms
    12 timing stage:runTopLevelLifecycles Completed in 10193ms
    13 verbose type version
    14 verbose stack iobroker.sainlogic: No matching version found for iobroker.sainlogic@0.7.2.
    14 verbose stack     at pickManifest (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/index.js:122:13)
    14 verbose stack     at /usr/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:43:18
    14 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
    14 verbose stack     at Promise._settlePromiseFromHandler (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:517:31)
    14 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:574:18)
    14 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:619:10)
    14 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:699:18)
    14 verbose stack     at _drainQueueStep (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:138:12)
    14 verbose stack     at _drainQueue (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:131:9)
    14 verbose stack     at Async._drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:147:5)
    14 verbose stack     at Immediate.Async.drainQueues [as _onImmediate] (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
    14 verbose stack     at processImmediate (internal/timers.js:461:21)
    15 verbose cwd /opt/iobroker
    16 verbose Linux 5.10.52-v7l+
    17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.sainlogic@0.7.2" "--loglevel" "error" "--prefix" "/opt/iobroker"
    18 verbose node v12.22.5
    19 verbose npm  v6.14.14
    20 error code ETARGET
    21 error notarget No matching version found for iobroker.sainlogic@0.7.2.
    22 error notarget In most cases you or one of your dependencies are requesting
    22 error notarget a package version that doesn't exist.
    23 verbose exit [ 1, true ]
    #204
    @qqolli
    echad@chet:~ $ iobroker add sainlogic
    NPM version: 7.20.3
    npm install iobroker.sainlogic@0.6.1 --loglevel error --prefix "/opt/iobroker" (System call)
    host.chet install adapter sainlogic
    Da ist wohl sainlogic@0.7.2 falsch eingecheckt worden.
    Im stable ist auch keine Zeit aufgeführt:
    github:	0.7.2
    latest:	0.6.1 for 14 months
    stable:	0.7.2
    Da muss wohl jemand nochmal sauber die richtige Version im Repo einchecken.
    Edit: Da stimmt irgendwie noch mehr nicht. 0.6.1 ist installiert worden, aber:
    Adapter    "sainlogic"     : 0.6.1    , installed 0.6.0 [Updateable]
    https://github.com/phifogg/ioBroker.sainlogic/issues/91
    https://github.com/phifogg/ioBroker.sainlogic/issues/90
    qqolliQ 1 Antwort Letzte Antwort
      @qqolli
      NPM version: 7.20.3
      github:	0.7.2
      stable:	0.7.2
      qqolliQ Offline
      qqolliQ Offline
      qqolli
      #205
      Heißt dass, das ich auf eine korrigierte Version warten muss?
      Oder kann ich den, indem ich mich mittels SSH auf den ioB einlogge die aktuelle Version so installieren:
      npm install https://github.com/phifogg/ioBroker.sainlogic --prefix "/opt/iobroker"
      Stand jedenfalls so auf der Githubseite. Oder gibt es eine einfachere Möglichkeit?
      • qqolliQ qqolli
        #206
        @qqolli
        Oder du stellt kurz auf das Beta-Repo und ziehst diesen Adapter dann da heraus.
        Dann wieder auf stable setzen.
        qqolliQ 2 Antworten Letzte Antwort
          @qqolli
          qqolliQ Offline
          qqolliQ Offline
          qqolli
          #207
          Prima, hat super geklappt.
          Kommen leider z. Zt. keine Werte rein; alles auf Null und orange und nur sainlogic.0.weather.current.solarradiation ist schwarz. Vielleicht dauert es auch einfach etwas, bis die ersten Werte kommen.
          NegaleinN Thomas BraunT 2 Antworten Letzte Antwort
            @qqolli
            qqolliQ Offline
            qqolliQ Offline
            qqolli
            #208
            Na ja, in der Instanz zeigt er mir v0.6.0 an, im Adapter als installiert ebenfalls die 0.6.0.
            Aber:
            zeigt folgendes an:
            $ iobroker upgrade sainlogic@0.7.2
            Update sainlogic from @0.6.0 to @0.7.2
            npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-08-21T10_44_13_595Z-debug.log
            upload [4] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/words.js words.js application/javascript
            upload [3] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/style.css style.css text/css
            upload [2] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/sainlogic.png sainlogic.png image/png
            upload [1] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/index_m.html index_m.html text/html
            upload [0] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/admin.d.ts admin.d.ts video/mp2t
            Adapter "sainlogic" updated
            Process exited with code 0
            • qqolliQ qqolli
              Aber:
              zeigt folgendes an:
              #209
              @qqolli
              Ja, das muss in den Repos geradegezogen werden. Steht ja auch in den Issues drin.
              • qqolliQ qqolli
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                #210
                @qqolli sagte in Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest:
                hast du dir mal das Script von Sborg angeschaut?
                https://forum.iobroker.net/topic/28384/linux-shell-skript-wlan-wetterstation/2839
                Ich hab auch mal den Sainlogic-Adapter versucht. Habs aber ganz schnell wieder deinstalliert und verwende seit Ewigkeiten das Script.
                ° Fixer ---> iob fix
                • NegaleinN Negalein
                  qqolliQ Offline
                  qqolliQ Offline
                  qqolli
                  #211
                  @negalein
                  Wow, das sieht aber auch richtig gut aus.
                  Schau ich mir nachher mal an. Geh jetzt erstmal den Rasen mähen :-)
                  • qqolliQ qqolli
                    #212
                    Ich hab mir heute auch so'n Ding aufs Dach gesetzt.
                    Mit dem wunderground-Protokoll war da nix zu wollen, ich hab einfach auf Ecowitt umgestellt, jetzt läuft es.
                      qqolliQ Offline
                      qqolliQ Offline
                      qqolli
                      #213
                      meinen setzt ich heute aufs Dach, musste erst auf die Montagestange warten.
                      D. h., die WU-Seite benutzt Du gar nicht, sondern nur die Ecowitseite?
                      Habe bei beiden einen Account angelegt, aber noch nicht "scharf" gestellt, da noch nicht auf dem Dach.
                      Das Skript von Sborg, welches @Negalein erwähnt hat sieht eigentlich auch recht gut aus. Hast Du das schon mal benutzt?
                      Thomas BraunT NegaleinN 2 Antworten Letzte Antwort
                      • qqolliQ qqolli
                        #214
                        Weder noch. Die Station sendet an das Display und das sendet dann weiter an den iobroker-Server. Geht über die 'Customized'-Seite in der WS View-App.
                        Nein, ich hab aber auch lieber Adapter, die kann ich besser administrieren. Bei skripten musst du ja selber immer schauen, ob es da ein Update gab.
                        • qqolliQ qqolli
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          #215
                          Vorallem kannst du mit dem Script deine Wetterstation zB in "Wunderground, Weathercloud, Windy, Open Sense Map und wetter(.)com" veröffentlichen.
                          Von den ganzen Statistiken mal abgesehn. :)
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            #216
                            @thomas-braun sagte in Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest:
                            Da gibts bei Sborg 0 Probleme.
                            Updates kommuniziert er immer sofort im Thema.
                              qqolliQ Offline
                              qqolliQ Offline
                              qqolli
                              #217
                              @negalein
                              versuche gerade das Skript von Sborg zu installieren. Habe aber ein kleines Problem, wenn dich die drei Dateien mittels WinSCP in das Raspi /home/iobroker-Verzeichnis kopieren will, sagt er das ich keine Rechte habe.
                              Wie kann man z. B. in WinSCP die Dateien als root kopieren?
                              • qqolliQ qqolli
                                @negalein
                                #218
                                @qqolli
                                Am besten gar nicht.
                                In das Zielverzeichnis wechseln, per
                                sudo -u iobroker wget /pfad/zum/skript
                                fertig.
                                • qqolliQ qqolli
                                  @negalein
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  #219
                                  Hi
                                  @Thomas-Braun hat dir bereits weitergeholfen.
                                  Bitte Fragen zum Projekt von Sborg in seinem Thread stellen.
                                  Hier in diesem geht es um den Sainlogic-Adapter.
                                    @qqolli
                                    fertig.
                                    qqolliQ Offline
                                    qqolliQ Offline
                                    qqolli
                                    #220
                                    Wenn ich auf dem ioB
                                    sudo -u iobroker wget /home/iobroker/
                                    ausführe (meine 3 Skripte liegen in diesem Verzeichnis) bekomme ich
                                    /home/iobroker/: Schema fehlt.
                                    zurück.
                                    • qqolliQ qqolli
                                      zurück.
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      #221
                                      BITTE hier weitermachen!
                                      • FoggF Fogg
                                        Aktuelle Test Version 0.6.0
                                        Veröffentlichungsdatum 21.05.2020
                                        Github Link https://github.com/phifogg/ioBroker.sainlogic
                                        Hier Adapter Beschreibung, Changelog etc.
                                        Neu:
                                        • Umrechnung in andere Einheiten möglich -> neues Tab in den Einstellungen ähnlich zu Ecowitt
                                        • Listener kann auch Ecowitt Protokoll zum Empfangen von Daten
                                        • Einiges überarbeitet, Datenpunkte umbenannt zum vereinheitlichen
                                        Bekannte Probleme / Unfertig:
                                        Testen auf eigenes Risiko bis jetzt - nicht für den produktiven Einsatz geeignet.
                                        Mich interessiert ob das Umrechnen soweit stimmt und brauchbare Werte ergibt. Am Besten zum hin- und herrechnen Listener und Scheduler deaktivieren.
                                        S Nicht stören
                                        S Nicht stören
                                        stenmic
                                        #222
                                        @fogg hi,
                                        ich nutze die V0.7.2
                                        Meine Wetterstation besteht aus einem Froggit Set DP1500 & WH3000SE.
                                        Soweit funktioniert auch alles, habe aber 2 Fragen.
                                        1. Ist es möglich den Batteriestatus vom WH3000SE auszulesen.
                                          In der App wird ja was angezeigt.
                                          (Meine Batterien halten 2-3 Wochen... bin schon mit Froggit im Kontakt,
                                          hat hier jemand ähnliche Erfahrung?)
                                        2. Im Adapter bleiben die max- und minvalues leer.
                                          Ist das normal bei dem Set?
                                        • S stenmic
                                          @fogg hi,
                                          Jupp84
                                          #223
                                          sainlogic.0 2021-09-22 13:57:25.739 error Connection error on 192.168.1.52:45000: Error: connect EISCONN 192.168.1.52:45000 - Local (192.168.1.2:42674)
                                          Die aktuellen Wetterdarten kommen jedoch rein und werden angezeigt Min. Max werte sind nicht da
