  4. Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest
    6.4k
sainlogicwetterstationadapterws980wififroggit wh4000sh
326 Beiträge 60 Kommentatoren 102.0k Aufrufe 51 Beobachtet
    df0101
    #198
    ich versuche gerade die Version 0.66 unter Iobroker im Stable zu installieren, funktioniert aber leider nicht:
    Hier das Logfile:
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli   '/usr/bin/node',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'iobroker.sainlogic@0.6.6',
    1 verbose cli   '--loglevel',
    1 verbose cli   'error',
    1 verbose cli   '--prefix',
    1 verbose cli   '/opt/iobroker'
    1 verbose cli ]
    2 info using npm@6.14.13
    3 info using node@v12.22.2
    4 verbose npm-session da54c664d4a5514e
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 http fetch GET 304 https://registry.npmjs.org/iobroker.sainlogic 1373ms (from cache)
    8 silly registry:manifest no matching version for iobroker.sainlogic@0.6.6 in the cache. Forcing revalidation.
    9 http fetch GET 200 https://registry.npmjs.org/iobroker.sainlogic 876ms
    10 silly fetchPackageMetaData error for iobroker.sainlogic@0.6.6 No matching version found for iobroker.sainlogic@0.6.6.
    11 timing stage:rollbackFailedOptional Completed in 1ms
    12 timing stage:runTopLevelLifecycles Completed in 9809ms
    13 verbose type version
    14 verbose stack iobroker.sainlogic: No matching version found for iobroker.sainlogic@0.6.6.
    14 verbose stack     at pickManifest (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/index.js:122:13)
    14 verbose stack     at /usr/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:43:18
    14 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
    14 verbose stack     at Promise._settlePromiseFromHandler (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:517:31)
    14 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:574:18)
    14 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:619:10)
    14 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:699:18)
    14 verbose stack     at _drainQueueStep (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:138:12)
    14 verbose stack     at _drainQueue (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:131:9)
    14 verbose stack     at Async._drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:147:5)
    14 verbose stack     at Immediate.Async.drainQueues [as _onImmediate] (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
    14 verbose stack     at processImmediate (internal/timers.js:461:21)
    15 verbose cwd /opt/iobroker
    16 verbose Linux 5.10.17-v7l+
    17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.sainlogic@0.6.6" "--loglevel" "error" "--prefix" "/opt/iobroker"
    18 verbose node v12.22.2
    19 verbose npm  v6.14.13
    20 error code ETARGET
    21 error notarget No matching version found for iobroker.sainlogic@0.6.6.
    22 error notarget In most cases you or one of your dependencies are requesting
    22 error notarget a package version that doesn't exist.
    23 verbose exit [ 1, true ]
    Ich hoffe mir kann jemand helfen,
    Danke und viele Grüße,
    df0101
      df0101
      schrieb am zuletzt editiert von df0101
      #199
      keiner ne Idee ?
      Ich habe auch versucht auf Beta umzustellen, geht aber auch nicht, allerdings verwendet er da die Version 0.6.0 ???
      Ich hatte eigentlich noch nie ein Problem, einen Adapter installiert zu bekommen...
      • D df0101
        keiner ne Idee ?
        GlasfaserG Offline
        GlasfaserG Offline
        #200
        @df0101
        Du kannst die Github Version 0.7.2 über beleibige URL installieren .
        URL:
        https://github.com/phifogg/ioBroker.sainlogic
        Stable ist 0.6.6 , latest 0.6.1 , da ist was durcheinander bei Ihm
          df0101
          #201
          @Glasfaser
          so hat es funktioniert. Danke dir :)
          • E Offline
            e-i-k-e
            #202
            Könntest du vielleicht diese Kleinigkeit integrieren?
            Einfach eine Variable die bei Regen auf true oder false steht.
            Würde mich drüber freuen! :)
            • FoggF Fogg
              Aktuelle Test Version 0.6.0
              Veröffentlichungsdatum 21.05.2020
              Github Link https://github.com/phifogg/ioBroker.sainlogic
              Hier Adapter Beschreibung, Changelog etc.
              Neu:
              • Umrechnung in andere Einheiten möglich -> neues Tab in den Einstellungen ähnlich zu Ecowitt
              • Listener kann auch Ecowitt Protokoll zum Empfangen von Daten
              • Einiges überarbeitet, Datenpunkte umbenannt zum vereinheitlichen
              Bekannte Probleme / Unfertig:
              Testen auf eigenes Risiko bis jetzt - nicht für den produktiven Einsatz geeignet.
              Mich interessiert ob das Umrechnen soweit stimmt und brauchbare Werte ergibt. Am Besten zum hin- und herrechnen Listener und Scheduler deaktivieren.
              qqolliQ Offline
              qqolliQ Offline
              qqolli
              schrieb am zuletzt editiert von qqolli
              #203
              @fogg
              gerade ist meine Sainlogic WS3500 Wetterstation gekommen und ich wollte mir Deinen Adapter installieren. Leider bekomme ich bei der Installation folgenden Fehler (Code: 25) angezeigt:
              $ iobroker add sainlogic --host ioBroker
              NPM version: 6.14.14
              npm install iobroker.sainlogic@0.7.2 --loglevel error --prefix "/opt/iobroker" (System call)
              npm ERR! code ETARGET
              npm ERR! notarget No matching version found for iobroker.sainlogic@0.7.2.npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
              npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-08-21T09_50_30_041Z-debug.log
              host.ioBroker Cannot install iobroker.sainlogic@0.7.2: 1
              ERROR: Process exited with code 25
              Anbei zur Info der komplette log:
              1 verbose cli [
              1 verbose cli   'iobroker.sainlogic@0.7.2',
              1 verbose cli ]
              2 info using npm@6.14.14
              3 info using node@v12.22.5
              4 verbose npm-session 9dfae1f10b5b6e6a
              7 http fetch GET 200 https://registry.npmjs.org/iobroker.sainlogic 44ms (from cache)
              8 silly registry:manifest no matching version for iobroker.sainlogic@0.7.2 in the cache. Forcing revalidation.
              9 http fetch GET 200 https://registry.npmjs.org/iobroker.sainlogic 938ms
              10 silly fetchPackageMetaData error for iobroker.sainlogic@0.7.2 No matching version found for iobroker.sainlogic@0.7.2.
              11 timing stage:rollbackFailedOptional Completed in 2ms
              12 timing stage:runTopLevelLifecycles Completed in 10193ms
              14 verbose stack iobroker.sainlogic: No matching version found for iobroker.sainlogic@0.7.2.
              16 verbose Linux 5.10.52-v7l+
              17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.sainlogic@0.7.2" "--loglevel" "error" "--prefix" "/opt/iobroker"
              18 verbose node v12.22.5
              19 verbose npm  v6.14.14
              21 error notarget No matching version found for iobroker.sainlogic@0.7.2.
              • qqolliQ qqolli
                @fogg
                1 verbose cli [
                1 verbose cli ]
                #204
                @qqolli
                echad@chet:~ $ iobroker add sainlogic
                NPM version: 7.20.3
                npm install iobroker.sainlogic@0.6.1 --loglevel error --prefix "/opt/iobroker" (System call)
                host.chet install adapter sainlogic
                Da ist wohl sainlogic@0.7.2 falsch eingecheckt worden.
                Im stable ist auch keine Zeit aufgeführt:
                github:	0.7.2
                latest:	0.6.1 for 14 months
                stable:	0.7.2
                Da muss wohl jemand nochmal sauber die richtige Version im Repo einchecken.
                Edit: Da stimmt irgendwie noch mehr nicht. 0.6.1 ist installiert worden, aber:
                Adapter    "sainlogic"     : 0.6.1    , installed 0.6.0 [Updateable]
                https://github.com/phifogg/ioBroker.sainlogic/issues/91
                https://github.com/phifogg/ioBroker.sainlogic/issues/90
                qqolliQ 1 Antwort Letzte Antwort
                  @qqolli
                  NPM version: 7.20.3
                  github:	0.7.2
                  stable:	0.7.2
                  qqolliQ Offline
                  qqolliQ Offline
                  qqolli
                  #205
                  Heißt dass, das ich auf eine korrigierte Version warten muss?
                  Oder kann ich den, indem ich mich mittels SSH auf den ioB einlogge die aktuelle Version so installieren:
                  npm install https://github.com/phifogg/ioBroker.sainlogic --prefix "/opt/iobroker"
                  Stand jedenfalls so auf der Githubseite. Oder gibt es eine einfachere Möglichkeit?
                  • qqolliQ qqolli
                    #206
                    @qqolli
                    Oder du stellt kurz auf das Beta-Repo und ziehst diesen Adapter dann da heraus.
                    Dann wieder auf stable setzen.
                    qqolliQ 2 Antworten Letzte Antwort
                      @qqolli
                      qqolliQ Offline
                      qqolliQ Offline
                      qqolli
                      #207
                      Prima, hat super geklappt.
                      Kommen leider z. Zt. keine Werte rein; alles auf Null und orange und nur sainlogic.0.weather.current.solarradiation ist schwarz. Vielleicht dauert es auch einfach etwas, bis die ersten Werte kommen.
                      NegaleinN Thomas BraunT 2 Antworten Letzte Antwort
                        @qqolli
                        qqolliQ Offline
                        qqolliQ Offline
                        qqolli
                        #208
                        Na ja, in der Instanz zeigt er mir v0.6.0 an, im Adapter als installiert ebenfalls die 0.6.0.
                        Aber:
                        zeigt folgendes an:
                        $ iobroker upgrade sainlogic@0.7.2
                        Update sainlogic from @0.6.0 to @0.7.2
                        npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-08-21T10_44_13_595Z-debug.log
                        upload [4] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/words.js words.js application/javascript
                        upload [3] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/style.css style.css text/css
                        upload [2] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/sainlogic.png sainlogic.png image/png
                        upload [1] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/index_m.html index_m.html text/html
                        upload [0] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/admin.d.ts admin.d.ts video/mp2t
                        Adapter "sainlogic" updated
                        Process exited with code 0
                        • qqolliQ qqolli
                          Aber:
                          zeigt folgendes an:
                          #209
                          @qqolli
                          Ja, das muss in den Repos geradegezogen werden. Steht ja auch in den Issues drin.
                          • qqolliQ qqolli
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            #210
                            @qqolli sagte in Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest:
                            hast du dir mal das Script von Sborg angeschaut?
                            https://forum.iobroker.net/topic/28384/linux-shell-skript-wlan-wetterstation/2839
                            Ich hab auch mal den Sainlogic-Adapter versucht. Habs aber ganz schnell wieder deinstalliert und verwende seit Ewigkeiten das Script.
                            ° Fixer ---> iob fix
                            • NegaleinN Negalein
                              qqolliQ Offline
                              qqolliQ Offline
                              qqolli
                              #211
                              @negalein
                              Wow, das sieht aber auch richtig gut aus.
                              Schau ich mir nachher mal an. Geh jetzt erstmal den Rasen mähen :-)
                              • qqolliQ qqolli
                                #212
                                Ich hab mir heute auch so'n Ding aufs Dach gesetzt.
                                Mit dem wunderground-Protokoll war da nix zu wollen, ich hab einfach auf Ecowitt umgestellt, jetzt läuft es.
                                  qqolliQ Offline
                                  qqolliQ Offline
                                  qqolli
                                  #213
                                  meinen setzt ich heute aufs Dach, musste erst auf die Montagestange warten.
                                  D. h., die WU-Seite benutzt Du gar nicht, sondern nur die Ecowitseite?
                                  Habe bei beiden einen Account angelegt, aber noch nicht "scharf" gestellt, da noch nicht auf dem Dach.
                                  Das Skript von Sborg, welches @Negalein erwähnt hat sieht eigentlich auch recht gut aus. Hast Du das schon mal benutzt?
                                  Thomas BraunT NegaleinN 2 Antworten Letzte Antwort
                                  • qqolliQ qqolli
                                    #214
                                    Weder noch. Die Station sendet an das Display und das sendet dann weiter an den iobroker-Server. Geht über die 'Customized'-Seite in der WS View-App.
                                    Nein, ich hab aber auch lieber Adapter, die kann ich besser administrieren. Bei skripten musst du ja selber immer schauen, ob es da ein Update gab.
                                    • qqolliQ qqolli
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      #215
                                      Vorallem kannst du mit dem Script deine Wetterstation zB in "Wunderground, Weathercloud, Windy, Open Sense Map und wetter(.)com" veröffentlichen.
                                      Von den ganzen Statistiken mal abgesehn. :)
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        #216
                                        @thomas-braun sagte in Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest:
                                        Da gibts bei Sborg 0 Probleme.
                                        Updates kommuniziert er immer sofort im Thema.
                                          qqolliQ Offline
                                          qqolliQ Offline
                                          qqolli
                                          #217
                                          @negalein
                                          versuche gerade das Skript von Sborg zu installieren. Habe aber ein kleines Problem, wenn dich die drei Dateien mittels WinSCP in das Raspi /home/iobroker-Verzeichnis kopieren will, sagt er das ich keine Rechte habe.
                                          Wie kann man z. B. in WinSCP die Dateien als root kopieren?
