  4. Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest
    6.4k
sainlogicwetterstationadapterws980wififroggit wh4000sh
326 Beiträge 60 Kommentatoren 102.0k Aufrufe 51 Beobachtet
  • S Sender
    @thomas-braun SO! läuft alles wieder...
    node-red-contrib-smartmeter hat sich heftig gegen einen rebuild gewehrt, die node.js Version hatte sich ja geändert.
    #190
    @sender Sollte eigentlich automatisch im Hintergrund passieren.
    Manchmal muss halt noch von Hand rebuildet werden.
    Steht aber dann im Log drin.
    • E Offline
      e-i-k-e
      schrieb am zuletzt editiert von e-i-k-e
      #191
      @Fogg
      Nach Update des js-Controllers auf Version 3.3x wird nachfolgendes im Log angezeigt.
      sainlogic.0	2021-04-30 21:20:28.098	warn	(6166) State value to set for "sainlogic.0.weather.current.uvi" has wrong type "string" but has to be "number"
      sainlogic.0	2021-04-30 21:20:28.097	warn	(6166) State value to set for "sainlogic.0.weather.current.winddir" has wrong type "string" but has to be "number"
      sainlogic.0	2021-04-30 21:20:28.097	warn	(6166) State value to set for "sainlogic.0.weather.current.outdoorhumidity" has wrong type "string" but has to be "number"
      sainlogic.0	2021-04-30 21:20:28.096	warn	(6166) State value to set for "sainlogic.0.weather.current.indoorhumidity" has wrong type "string" but has to be "number"
      sainlogic.0	2021-04-30 21:20:28.092	warn	(6166) State "sainlogic.0.info.last_listener_update" has no existing object, this might lead to an error in future versions
      sainlogic.0	2021-04-30 19:19:27.095	warn	(6166) State value to set for "sainlogic.0.weather.current.uvi" has wrong type "string" but has to be "number"
      sainlogic.0	2021-04-30 19:19:27.095	warn	(6166) State value to set for "sainlogic.0.weather.current.winddir" has wrong type "string" but has to be "number"
      sainlogic.0	2021-04-30 19:19:27.095	warn	(6166) State value to set for "sainlogic.0.weather.current.outdoorhumidity" has wrong type "string" but has to be "number"
      sainlogic.0	2021-04-30 19:19:27.094	warn	(6166) State value to set for "sainlogic.0.weather.current.indoorhumidity" has wrong type "string" but has to be "number"
      sainlogic.0	2021-04-30 19:19:27.091	warn	(6166) State "sainlogic.0.info.last_listener_update" has no existing object, this might lead to an error in future versions
      sainlogic.0	2021-04-30 19:18:26.098	warn	(6166) State value to set for "sainlogic.0.weather.current.uvi" has wrong type "string" but has to be "number"
      sainlogic.0	2021-04-30 19:18:26.097	warn	(6166) State value to set for "sainlogic.0.weather.current.winddir" has wrong type "string" but has to be "number"
      sainlogic.0	2021-04-30 19:18:26.097	warn	(6166) State value to set for "sainlogic.0.weather.current.outdoorhumidity" has wrong type "string" but has to be "number"
      sainlogic.0	2021-04-30 19:18:26.095	warn	(6166) State value to set for "sainlogic.0.weather.current.indoorhumidity" has wrong type "string" but has to be "number"
      sainlogic.0	2021-04-30 19:18:26.092	warn	(6166) State "sainlogic.0.info.last_listener_update" has no existing object, this might lead to an error in future versions
      sainlogic.0	2021-04-30 19:17:25.098	warn	(6166) State value to set for "sainlogic.0.weather.current.uvi" has wrong type "string" but has to be "number"
      sainlogic.0	2021-04-30 19:17:25.098	warn	(6166) State value to set for "sainlogic.0.weather.current.winddir" has wrong type "string" but has to be "number"
      sainlogic.0	2021-04-30 19:17:25.097	warn	(6166) State value to set for "sainlogic.0.weather.current.outdoorhumidity" has wrong type "string" but has to be "number"
      sainlogic.0	2021-04-30 19:17:25.097	warn	(6166) State value to set for "sainlogic.0.weather.current.indoorhumidity" has wrong type "string" but has to be "number"
      sainlogic.0	2021-04-30 19:17:25.094	warn	(6166) State "sainlogic.0.info.last_listener_update" has no existing object, this might lead to an error in future versions
      https://forum.iobroker.net/topic/44624/js-controller-3-3-jetzt-im-latest/68
      • E e-i-k-e
        @Fogg
        #192
        @e-i-k-e
        Mach am besten ein Issue dazu auf, falls noch nicht geschehen:
        https://github.com/phifogg/ioBroker.sainlogic/issues
        E 1 Antwort Letzte Antwort
          @e-i-k-e
          e-i-k-e
          #193
          erledigt
          https://github.com/phifogg/ioBroker.sainlogic/issues/74
          FoggF 1 Antwort Letzte Antwort
          • E e-i-k-e
            erledigt
            FoggF Offline
            FoggF Offline
            Fogg
            #194
            @e-i-k-e
            Ich kriege gerade die neue jsController version bei mir nicht installiert.. das muss ich erst noch rausknobeln wie ..
            Wenn Du aber testen magst habe ich im DEV Branch versucht die Warn-Meldungen zu umgehen.
            https://github.com/phifogg/ioBroker.sainlogic/tree/dev
            Das mit den Versionen im Repo ist durchaus etwas wo ich leicht auf kriegsfuss stehe. Zurückgezogen habe ich nichts...
            Ich versuche in Kürze die 0.7.1 ins repo zu schieben, die ist auch schon stabil.
            RaspiUserR 1 Antwort Letzte Antwort
              tim77777
              #195
              Hallo ....
              ich habe mir gerade sainlogic instaliert mit einer WPS1500.
              Ich kriege folgende Fehlermeldung. Kann mir einer helfen ?
              • trinoT Offline
                trinoT Offline
                trino
                schrieb am zuletzt editiert von trino
                #196
                Hallo
                kann das sein das man den Adapter nicht richtig installieren kann auf iobroker v5.1.9
                Ich kann keine instanz hinzufügen...
                vielen Dank
                oh man.. fehler gefunden....
                • FoggF Fogg
                  @e-i-k-e
                  RaspiUserR Online
                  RaspiUserR Online
                  RaspiUser
                  #197
                  @fogg said in Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest:
                  Ist es bald soweit ? Ich sage schonmal: Vielen Dank !!
                    df0101
                    #198
                    ich versuche gerade die Version 0.66 unter Iobroker im Stable zu installieren, funktioniert aber leider nicht:
                    Hier das Logfile:
                    0 info it worked if it ends with ok
                    1 verbose cli [
                    1 verbose cli   '/usr/bin/node',
                    1 verbose cli   '/usr/bin/npm',
                    1 verbose cli   'install',
                    1 verbose cli   'iobroker.sainlogic@0.6.6',
                    1 verbose cli   '--loglevel',
                    1 verbose cli   'error',
                    1 verbose cli   '--prefix',
                    1 verbose cli   '/opt/iobroker'
                    1 verbose cli ]
                    2 info using npm@6.14.13
                    3 info using node@v12.22.2
                    4 verbose npm-session da54c664d4a5514e
                    5 silly install loadCurrentTree
                    6 silly install readLocalPackageData
                    7 http fetch GET 304 https://registry.npmjs.org/iobroker.sainlogic 1373ms (from cache)
                    8 silly registry:manifest no matching version for iobroker.sainlogic@0.6.6 in the cache. Forcing revalidation.
                    9 http fetch GET 200 https://registry.npmjs.org/iobroker.sainlogic 876ms
                    10 silly fetchPackageMetaData error for iobroker.sainlogic@0.6.6 No matching version found for iobroker.sainlogic@0.6.6.
                    11 timing stage:rollbackFailedOptional Completed in 1ms
                    12 timing stage:runTopLevelLifecycles Completed in 9809ms
                    13 verbose type version
                    14 verbose stack iobroker.sainlogic: No matching version found for iobroker.sainlogic@0.6.6.
                    14 verbose stack     at pickManifest (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/index.js:122:13)
                    14 verbose stack     at /usr/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:43:18
                    14 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
                    14 verbose stack     at Promise._settlePromiseFromHandler (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:517:31)
                    14 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:574:18)
                    14 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:619:10)
                    14 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:699:18)
                    14 verbose stack     at _drainQueueStep (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:138:12)
                    14 verbose stack     at _drainQueue (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:131:9)
                    14 verbose stack     at Async._drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:147:5)
                    14 verbose stack     at Immediate.Async.drainQueues [as _onImmediate] (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
                    14 verbose stack     at processImmediate (internal/timers.js:461:21)
                    15 verbose cwd /opt/iobroker
                    16 verbose Linux 5.10.17-v7l+
                    17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.sainlogic@0.6.6" "--loglevel" "error" "--prefix" "/opt/iobroker"
                    18 verbose node v12.22.2
                    19 verbose npm  v6.14.13
                    20 error code ETARGET
                    21 error notarget No matching version found for iobroker.sainlogic@0.6.6.
                    22 error notarget In most cases you or one of your dependencies are requesting
                    22 error notarget a package version that doesn't exist.
                    23 verbose exit [ 1, true ]
                    Ich hoffe mir kann jemand helfen,
                    Danke und viele Grüße,
                    df0101
                      df0101
                      schrieb am zuletzt editiert von df0101
                      #199
                      keiner ne Idee ?
                      Ich habe auch versucht auf Beta umzustellen, geht aber auch nicht, allerdings verwendet er da die Version 0.6.0 ???
                      Ich hatte eigentlich noch nie ein Problem, einen Adapter installiert zu bekommen...
                      • D df0101
                        keiner ne Idee ?
                        GlasfaserG Offline
                        GlasfaserG Offline
                        #200
                        @df0101
                        Du kannst die Github Version 0.7.2 über beleibige URL installieren .
                        URL:
                        Stable ist 0.6.6 , latest 0.6.1 , da ist was durcheinander bei Ihm
                          df0101
                          #201
                          @Glasfaser
                          so hat es funktioniert. Danke dir :)
                          • E Offline
                            e-i-k-e
                            #202
                            Könntest du vielleicht diese Kleinigkeit integrieren?
                            Einfach eine Variable die bei Regen auf true oder false steht.
                            Würde mich drüber freuen! :)
                            • FoggF Fogg
                              Aktuelle Test Version 0.6.0
                              Veröffentlichungsdatum 21.05.2020
                              Github Link https://github.com/phifogg/ioBroker.sainlogic
                              Hier Adapter Beschreibung, Changelog etc.
                              Neu:
                              • Umrechnung in andere Einheiten möglich -> neues Tab in den Einstellungen ähnlich zu Ecowitt
                              • Listener kann auch Ecowitt Protokoll zum Empfangen von Daten
                              • Einiges überarbeitet, Datenpunkte umbenannt zum vereinheitlichen
                              Bekannte Probleme / Unfertig:
                              Testen auf eigenes Risiko bis jetzt - nicht für den produktiven Einsatz geeignet.
                              Mich interessiert ob das Umrechnen soweit stimmt und brauchbare Werte ergibt. Am Besten zum hin- und herrechnen Listener und Scheduler deaktivieren.
                              qqolliQ Offline
                              qqolliQ Offline
                              qqolli
                              schrieb am zuletzt editiert von qqolli
                              #203
                              @fogg
                              gerade ist meine Sainlogic WS3500 Wetterstation gekommen und ich wollte mir Deinen Adapter installieren. Leider bekomme ich bei der Installation folgenden Fehler (Code: 25) angezeigt:
                              $ iobroker add sainlogic --host ioBroker
                              NPM version: 6.14.14
                              npm install iobroker.sainlogic@0.7.2 --loglevel error --prefix "/opt/iobroker" (System call)
                              npm ERR! code ETARGET
                              npm ERR! notarget No matching version found for iobroker.sainlogic@0.7.2.npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
                              npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-08-21T09_50_30_041Z-debug.log
                              host.ioBroker Cannot install iobroker.sainlogic@0.7.2: 1
                              ERROR: Process exited with code 25
                              Anbei zur Info der komplette log:
                              1 verbose cli [
                              1 verbose cli   'iobroker.sainlogic@0.7.2',
                              1 verbose cli ]
                              2 info using npm@6.14.14
                              3 info using node@v12.22.5
                              4 verbose npm-session 9dfae1f10b5b6e6a
                              7 http fetch GET 200 https://registry.npmjs.org/iobroker.sainlogic 44ms (from cache)
                              8 silly registry:manifest no matching version for iobroker.sainlogic@0.7.2 in the cache. Forcing revalidation.
                              9 http fetch GET 200 https://registry.npmjs.org/iobroker.sainlogic 938ms
                              10 silly fetchPackageMetaData error for iobroker.sainlogic@0.7.2 No matching version found for iobroker.sainlogic@0.7.2.
                              11 timing stage:rollbackFailedOptional Completed in 2ms
                              12 timing stage:runTopLevelLifecycles Completed in 10193ms
                              14 verbose stack iobroker.sainlogic: No matching version found for iobroker.sainlogic@0.7.2.
                              16 verbose Linux 5.10.52-v7l+
                              17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.sainlogic@0.7.2" "--loglevel" "error" "--prefix" "/opt/iobroker"
                              18 verbose node v12.22.5
                              19 verbose npm  v6.14.14
                              21 error notarget No matching version found for iobroker.sainlogic@0.7.2.
                              • qqolliQ qqolli
                                @fogg
                                1 verbose cli [
                                1 verbose cli ]
                                #204
                                @qqolli
                                echad@chet:~ $ iobroker add sainlogic
                                NPM version: 7.20.3
                                npm install iobroker.sainlogic@0.6.1 --loglevel error --prefix "/opt/iobroker" (System call)
                                host.chet install adapter sainlogic
                                Da ist wohl sainlogic@0.7.2 falsch eingecheckt worden.
                                Im stable ist auch keine Zeit aufgeführt:
                                github:	0.7.2
                                latest:	0.6.1 for 14 months
                                stable:	0.7.2
                                Da muss wohl jemand nochmal sauber die richtige Version im Repo einchecken.
                                Edit: Da stimmt irgendwie noch mehr nicht. 0.6.1 ist installiert worden, aber:
                                Adapter    "sainlogic"     : 0.6.1    , installed 0.6.0 [Updateable]
                                https://github.com/phifogg/ioBroker.sainlogic/issues/91
                                https://github.com/phifogg/ioBroker.sainlogic/issues/90
                                qqolliQ 1 Antwort Letzte Antwort
                                  @qqolli
                                  NPM version: 7.20.3
                                  github:	0.7.2
                                  stable:	0.7.2
                                  qqolliQ Offline
                                  qqolliQ Offline
                                  qqolli
                                  #205
                                  Heißt dass, das ich auf eine korrigierte Version warten muss?
                                  Oder kann ich den, indem ich mich mittels SSH auf den ioB einlogge die aktuelle Version so installieren:
                                  npm install https://github.com/phifogg/ioBroker.sainlogic --prefix "/opt/iobroker"
                                  Stand jedenfalls so auf der Githubseite. Oder gibt es eine einfachere Möglichkeit?
                                  • qqolliQ qqolli
                                    #206
                                    @qqolli
                                    Oder du stellt kurz auf das Beta-Repo und ziehst diesen Adapter dann da heraus.
                                    Dann wieder auf stable setzen.
                                    qqolliQ 2 Antworten Letzte Antwort
                                      @qqolli
                                      qqolliQ Offline
                                      qqolliQ Offline
                                      qqolli
                                      #207
                                      Prima, hat super geklappt.
                                      Kommen leider z. Zt. keine Werte rein; alles auf Null und orange und nur sainlogic.0.weather.current.solarradiation ist schwarz. Vielleicht dauert es auch einfach etwas, bis die ersten Werte kommen.
                                      NegaleinN Thomas BraunT 2 Antworten Letzte Antwort
                                        @qqolli
                                        qqolliQ Offline
                                        qqolliQ Offline
                                        qqolli
                                        #208
                                        Na ja, in der Instanz zeigt er mir v0.6.0 an, im Adapter als installiert ebenfalls die 0.6.0.
                                        Aber:
                                        zeigt folgendes an:
                                        $ iobroker upgrade sainlogic@0.7.2
                                        Update sainlogic from @0.6.0 to @0.7.2
                                        npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-08-21T10_44_13_595Z-debug.log
                                        upload [4] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/words.js words.js application/javascript
                                        upload [3] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/style.css style.css text/css
                                        upload [2] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/sainlogic.png sainlogic.png image/png
                                        upload [1] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/index_m.html index_m.html text/html
                                        upload [0] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/admin.d.ts admin.d.ts video/mp2t
                                        Adapter "sainlogic" updated
                                        Process exited with code 0
                                        • qqolliQ qqolli
                                          Aber:
                                          zeigt folgendes an:
                                          #209
                                          @qqolli
                                          Ja, das muss in den Repos geradegezogen werden. Steht ja auch in den Issues drin.
