  4. JavaScript
  5. [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.
474 Beiträge 50 Kommentatoren 141.2k Aufrufe 41 Beobachtet
  • P Pittini
    Hi allerseits,
    wer alles hat die 0.2.24 laufen und KEINE Probleme? Und wer hat Probleme in denen die Meldung "Cannot read property 'rssi' of undefined" vorkommt?
    crunchipC Offline
    crunchipC Offline
    #242
    @pittini hab gerade mal die version drauf gemacht, erhalte jedoch
    14:06:45.546	info	javascript.0 (4954) Stop script script.js.MiHome
    14:06:45.614	info	javascript.0 (4954) Start javascript script.js.MiHome
    14:06:45.619	info	javascript.0 (4954) script.js.MiHome: Starting AllMyMi V.0.2.24
    14:06:45.622	info	javascript.0 (4954) script.js.MiHome: registered 0 subscriptions and 0 schedules
    14:06:45.622	info	javascript.0 (4954) script.js.MiHome: You are already logged in, login canceled
    14:06:45.623	info	javascript.0 (4954) script.js.MiHome: Retrieving your in de registered MiHome Devices
    14:06:45.730	info	javascript.0 (4954) script.js.MiHome: Found 3 MiHome Devices, those are:
    14:06:45.731	info	javascript.0 (4954) script.js.MiHome: Mi Air Purifier 3/3H
    14:06:45.732	error	javascript.0 (4954) script.js.MiHome: ReferenceError: praefix0 is not defined
    14:06:45.734	error	javascript.0 (4954) at PrepareGenericDps (script.js.MiHome:704:33)
    14:06:45.734	error	javascript.0 (4954) at Init (script.js.MiHome:770:15)
    edit selber gefunden:man-facepalming: kommt davon wenn man immer nur halbe sachen hin und her kopiert
    ja die Meldung kommt bei mir
    javascript.0 (4954) script.js.MiHome: TypeError: Cannot read property 'rssi' of undefined
    14:10:06.631	error	javascript.0 (4954) at RefreshGenericDpsTicker (script.js.MiHome:860:37)
    javascript.0
    2021-08-12 14:10:06.632	error	at processTicksAndRejections (internal/process/task_queues.js:95:5)
    javascript.0
    2021-08-12 14:10:06.632	error	at runMicrotasks (<anonymous>)
    javascript.0
    2021-08-12 14:10:06.631	error	at RefreshGenericDpsTicker (script.js.MiHome:860:37)
    javascript.0
    2021-08-12 14:10:06.629	error	script.js.MiHome: TypeError: Cannot read property 'rssi' of undefined
    P 1 Antwort Letzte Antwort
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      Pittini
      #243
      @crunchip Ok, dankeschön. Es gibt bereits nen Fix (ohne neue Version), damit sollte es weg sein, pls mal testen.
      haselchenH crunchipC 3 Antworten Letzte Antwort
      • P Pittini
        haselchenH Offline
        haselchenH Offline
        haselchen
        #244
        @pittini
        Neue Version getestet, läuft bisher.
        Keine Fehler im Log.
        Wirklich klasse wie Du das hier supportest und auf Github!
        Alle Daumen hoch.
        • P Pittini
          crunchipC Offline
          crunchipC Offline
          #245
          @pittini kam gerade erst dazu, super, läuft 👍
            Kueppert
            schrieb am zuletzt editiert von Kueppert
            #246
            bei mir auch. Hab den 3C und die js-Datei selbst in den entsprechenden Ordner kopiert ( zhimi.airpurifier.mb4 ). Die hatte gefehlt. Mal schauen ob ich weiterhin Fehlermessages erhalte. Wenn ja, poste ich die hier mal :)
            Danke für das tolle Skript 👍
            • P Pittini
              crunchipC Offline
              crunchipC Offline
              #247
              @pittini weiss nicht ob das schon mal gefragt/gemeldet wurde, bzw ob das nur hin und wieder vorkommt
              javascript.0
              2021-08-13 10:24:13.351	error	FetchError: request to https://de.api.io.mi.com/app/home/device_list failed, reason: getaddrinfo ENOTFOUND de.api.io.mi.com at ClientRequest.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-fetch/lib/index.js:1461:11) at ClientRequest.emit (events.js:412:35) at ClientRequest.emit (domain.js:470:12) at TLSSocket.socketErrorListener (_http_client.js:475:9) at TLSSocket.emit (events.js:400:28) at TLSSocket.emit (domain.js:470:12) at emitErrorNT (internal/streams/destroy.js:106:8) at emitErrorCloseNT (internal/streams/destroy.js:74:3) at processTicksAndRejections (internal/process/task_queues.js:82:21)
              javascript.0
              2021-08-13 10:24:13.350	error	Error: request to https://de.api.io.mi.com/app/home/device_list failed, reason: getaddrinfo ENOTFOUND de.api.io.mi.com
              javascript.0
              2021-08-13 10:24:13.348	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
              K P 2 Antworten Letzte Antwort
                javascript.0
                javascript.0
                javascript.0
                Kueppert
                #248
                @crunchip diese Fehlermeldung meinte ich ^^
                  javascript.0
                  javascript.0
                  javascript.0
                  Pittini
                  #249
                  @crunchip sagte in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
                  javascript.0
                  javascript.0
                  javascript.0
                  Sollte nur gelegentlich vorkommen, die devicelist wurde in den alten Versionen nur bei Skriptstart abgefragt, dadurch fiel das nich auf, wird jetzt aber alle 10 Sekunden abgefragt um rssi und isOnline aktuell zu halten und deswegen kann das eher mal auftreten. Mal beobachten, wenn da zu viele Fehler kommen muß ich mir was einfallen lassen.
                  • P Pittini
                    javascript.0
                    javascript.0
                    javascript.0
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    #250
                    @pittini
                    Jetzt habe ich leider doch wieder nen Problem.
                    Diesmal ist es der Smart Standing Fan Pro (dmaker.fan.p15)
                    Der Datenpunkt on ändert sich zwar in true/false, wenn man im IOT AN/AUS für Alexa eingibt, aber es passiert nichts.
                    Schalte ich den Ventilator per App aus, dann geht er auch aus, aber der Datenpunkt ändert sich nicht.
                    True obwohl er aus ist.
                    Mit dem 0.2.23 Script geht es.
                    • haselchenH haselchen
                      @pittini
                      Pittini
                      schrieb am zuletzt editiert von Pittini
                      #251
                      @haselchen sagte in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
                      Das is aber seltsam, denn daran wurde absolut nix geändert. Der einzige Unterschied von der .23 zur .24 is eine Funktion die rssi und IsOnline refresht. Kannst ja mal guggen obs geht wenn Du die in Zeile 841 auskommentierst, dann wird die Funktion nimmer aufgerufen und Du hast faktisch die .23
                      • P Pittini
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        #252
                        @pittini
                        Dann kann ich ja auch die 23er behalten :)
                        Ich hab ja immer 2 Skripte.
                        Eines Produktiv (23er) und eines als Test (24er).
                        Ich probier einfach mit der 24er Version mal rum.
                          @pittini
                          Pittini
                          #253
                          Ja klar, aber wir würden dann wissen ob die neue Funktion der .24 das Problem auslöst.
                          • P Pittini
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            #254
                            @pittini
                            Habs hin und herprobiert. Auskommentiert und normal. Mit der 24er kann ich den Fan nicht mehr steuern.
                            Über Alexa nicht und manuell über den Datenpunkt nicht.
                              @pittini
                              Pittini
                              #255
                              @pittini
                              Das is ja noch seltsamer, wenn die .24 auch mit der auskommentierten Funktion den Fan nich mehr steuert (denn dann ist quasi die .23), vorallem weil ich den auch hab und alles läuft wie es soll. Hast schon mal das logging aktiviert und geguggt ob das was kommt?
                              • P Pittini
                                @pittini
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                #256
                                @pittini
                                Ich dreh nochmal alles links.
                                Das Smart Home nimmt langsam Überhand :) :) :)
                                  @pittini
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  #257
                                  @pittini
                                  Vermelde Erfolg auf ganzer Linie.
                                  Habe hier und da am System bisschen optimiert.
                                  Am Ende Iobroker neu gestartet und zack, ich kann per Stimme wieder den Ventilator steuern.
                                  Die 24er Version kann ich hiermit offiziell abnicken :)
                                  • F fd
                                    @pittini Danke sehr für die schnelle Anwort.
                                    Ich bin jetzt einen großen Schritt weiter: nachdem ich die Ländereinstellung in der Xiaomi App und im Skript von Deutschland auf Singapur geändert habe (China hat für mich nicht funktioniert, da ich den Ventilator über die App nicht finden konnte) und den Ventilator neu angelernt, klappt der Log-in nun ohne weiteres.
                                    Der Ventilator wird auch in ioBroker unter Objekte / Javascript angelegt und unter Info finde ich viele Daten zu IP Adresse usw. Leider bleiben jedoch die Fan-Einstellungen leer und Eingaben meinerseits über die Dropdowns werden nicht angenommen.
                                    Das Skipt crasht sofort nach dem Start mit dem folgenden Log (ich habe einige spezifische Daten durch XXX ersetzt, sie scheinen aber korrekt zu sein.
                                    10:37:05.651	info	javascript.0 (2053) Stop script script.js.AllMyMi
                                    10:37:06.971	info	javascript.0 (2053) Start javascript script.js.AllMyMi
                                    10:37:07.027	info	javascript.0 (2053) script.js.AllMyMi: Starting AllMyMi V.0.2.23
                                    10:37:07.036	info	javascript.0 (2053) script.js.AllMyMi: registered 0 subscriptions and 0 schedules
                                    10:37:07.037	info	javascript.0 (2053) script.js.AllMyMi: You are already logged in, login canceled
                                    10:37:07.038	info	javascript.0 (2053) script.js.AllMyMi: Retrieving your in sg registered MiHome Devices
                                    10:37:07.846	info	javascript.0 (2053) script.js.AllMyMi: Found 1 MiHome Devices, those are:
                                    10:37:07.847	info	javascript.0 (2053) script.js.AllMyMi: Mi Smart Standing Fan 2
                                    10:37:07.848	info	javascript.0 (2053) script.js.AllMyMi: Now searching for supported Devices...
                                    10:37:07.849	info	javascript.0 (2053) script.js.AllMyMi: Device Mi Smart Standing Fan 2 is supported, creating DataPoints
                                    10:37:07.870	info	javascript.0 (2053) script.js.AllMyMi: Now creating device for dmaker.fan.p18 / XXXXXXXXXXXXXX / XXXXXXXXX / XXXXXXXXXXXXX / 10000
                                    10:37:07.872	info	javascript.0 (2053) script.js.AllMyMi: Created device {"_events":{},"_eventsCount":0,"_maxListeners":100,"id":"XXXXX","address":"XXXX","token":"XXXXX","protocol":"local","refresh":10000,"_properties":{},"_propertiesToMonitor":["fan:on","fan:mode","fan:fan-level","fan:horizontal-swing","fan:horizontal-angle","fan:status","alarm:alarm","motor-controller:motor-control","physical-controls-locked:physical-controls-locked","off-delay-time:off-delay-time"],"_miotSpec":null,"_miotSpecType":"urn:miot-spec-v2:device:fan:0000A005:dmaker-p18:1","model":"dmaker.fan.p18","setter":{},"definition":{"info":[{"id":"localip","initial":"","forceCreation":false,"common":{"read":true,"write":true,"name":"Ip Adress","type":"string","role":"value","def":""}},{"id":"token","initial":"","forceCreation":false,"common":{"read":true,"write":true,"name":"Token","type":"string","role":"value","def":""}},{"id":"did","initial":"","forceCreation":false,"common":{"read":true,"write":true,"name":"Device Id","type":"string","role":"value","def":""}},{"id":"model","initial":"","forceCreation":false,"common":{"read":true,"write":true,"name":"Model","type":"string","role":"value","def":""}},{"id":"rssi","initial":0,"forceCreation":false,"common":{"read":true,"write":false,"name":"rssi","type":"number","role":"value.rssi","def":0}},{"id":"name","initial":"","forceCreation":false,"common":{"read":true,"write":true,"name":"Name","type":"string","role":"value","def":""}},{"id":"isOnline","initial":false,"forceCreation":false,"common":{"read":true,"write":true,"name":"Is online","type":"boolean","role":"value","def":false}}],"model":"dmaker.fan.p18","description":"Mi Smart Standing Fan 2","setter":{},"common":[{"name":"fan.on","type":"boolean","role":"switch","read":true,"write":true},{"name":"fan.mode","type":"number","role":"switch","read":true,"write":true,"min":0,"max":1,"states":{"0":"Straight Wind","1":"Natural Wind"}},{"name":"fan.fan-level","type":"number","role":"switch","read":true,"write":true,"min":1,"max":4,"states":{"1":"Slow","2":"Middle","3":"High","4":"Turbo"}},{"name":"fan.horizontal-swing","type":"boolean","role":"switch","read":true,"write":true},{"name":"fan.horizontal-angle","type":"number","role":"switch","read":true,"write":true,"min":30,"max":140,"unit":"°","states":{"30":"30°","60":"60°","90":"90°","120":"120°","140":"140°"}},{"name":"fan.status","type":"number","role":"indicator","read":true,"write":false,"min":1,"max":100},{"name":"alarm.alarm","type":"boolean","role":"switch","read":true,"write":true},{"name":"motor-controller.motor-control","type":"number","role":"switch","read":false,"write":true,"min":0,"max":2,"states":{"0":"None","1":"Left","2":"Right"}},{"name":"physical-controls-locked.physical-controls-locked","type":"boolean","role":"switch","read":true,"write":true,"min":false,"max":true},{"name":"off-delay-time.off-delay-time","type":"number","role":"switch","read":true,"write":true,"min":0,"max":480,"unit":"m"}]},"firstrun":true} now fetching data
                                    10:37:08.240	error	javascript.0 (2053) script.js.AllMyMi: TypeError: Cannot read property 'forEach' of undefined
                                    10:37:08.242	error	javascript.0 (2053) at CreateDevices (script.js.AllMyMi:845:17)
                                    10:37:08.243	error	javascript.0 (2053) at main (script.js.AllMyMi:765:5)
                                    Der Raspi wurde ein Paar mal neu gestartet um dies als Fehlerquelle auszuschließen. Irgendeine Idee?
                                    fd
                                    schrieb am zuletzt editiert von fd
                                    #258
                                    @fd said in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
                                    Sorry dass ich hier nochmals nachfrage aber hat sonst noch jemand probleme mit 'forEach' of undefined? Ich kenne mich leider mit Javascript nicht gut genug aus, um das selbst zu troubleshooten. Danke.
                                    PS: Ich habe auch Version 0.2.24 probiert, leider gleiches Problem...
                                    • F fd
                                      Pittini
                                      #259
                                      @fd Du hast aber schon die dmaker.fan.p18.js in Dein node-mihome Devices Verzeichnis kopiert? Und die is da auch noch? Wenn das Skript an der Stelle abkackt, kanns das Device nicht initialisieren, was eigentlich (zumindest bisher) nur bei nicht vorhandener Definitionsdatei passiert.
                                      F 1 Antwort Letzte Antwort
                                      • P Pittini
                                        fd
                                        #260
                                        @pittini Danke, ja, habe ich installiert und ist auch noch vorhanden und scheint unbeschädigt (gecheckt via sudo nano auf dem Raspi). Ich habe gerade testweise auch mal die Zugriffsrechte via chmod 777 voll freigegeben, keine Änderung.
                                        Das Device wird auch angelegt im JavaScript Folder und ich erhalte infos zu Token, IP Adresse usw.. Die Datenpunkte fuer die Funktionen werden auch angelegt nur bleiben sie leer.
                                        Wenn ich die Datei dmaker.fan.p18.js übrigens mal testweise wieder rauslösche und den Javascript Adapter neu starte, erhalte ich folgende (abweichende) Fehlermeldung:
                                        12:32:05.768	info	javascript.0 (5206) Stop script script.js.AllMyMi
                                        12:32:05.839	info	javascript.0 (5206) script.js.AllMyMi: Retrieving your in sg registered MiHome Devices
                                        12:32:06.597	info	javascript.0 (5206) script.js.AllMyMi: Found 1 MiHome Devices, those are:
                                        12:32:06.597	info	javascript.0 (5206) script.js.AllMyMi: Mi Smart Standing Fan 2
                                        12:32:06.598	info	javascript.0 (5206) script.js.AllMyMi: Now searching for supported Devices...
                                        12:32:06.598	info	javascript.0 (5206) script.js.AllMyMi: Device Mi Smart Standing Fan 2 is supported, creating DataPoints
                                        12:32:06.610	info	javascript.0 (5206) script.js.AllMyMi: Now creating device for dmaker.fan.p18 / xxx / xxx / xxx / 10000
                                        12:32:06.613	error	javascript.0 (5206) script.js.AllMyMi: Error: Model dmaker.fan.p18 is not supported
                                        12:32:06.614	error	javascript.0 (5206) at CreateDevices (script.js.AllMyMi:801:36)
                                        12:32:06.614	error	javascript.0 (5206) at main (script.js.AllMyMi:733:11)
                                        Wenn ich die Datei dmaker.fan.p18.js wieder zurueckkopiere, kommt wieder die gleiche Fehlermeldung wie urspruenglich.
                                        • F fd
                                          fd
                                          #261
                                          @fd Für alle, die ein ähnliches Problem haben, dass sie das Skript leider nicht zum Laufen bekommen: Ich habe das ganze jetzt über den ham adapter gelöst.
                                          Folgendermaßen bin ich vorgegangen:
                                          1. Via SSH "homebridge" und "homebridge xiaomi fan" installieren (siehe z.B. https://github.com/merdok/homebridge-xiaomi-fan für weitere Anmerkungen)
                                          2. ham Adapter für den iobroker installieren
                                          3. Im ham Adapter unter "Main Settings" "Local Mode (...)" wählen
                                          4. Unter "Main Settings" "Additional NPM modules" "homebridge-xiaomi-fan" hinzufügen
                                          5. Im ham Adapter unter "Configuration File" die in https://github.com/merdok/homebridge-xiaomi-fan beschriebenen Eintragungen vornehmen. Bei mir sieht das zB so aus (mit einigen Dummies und ohne Sonos):
                                            "bridge": {
                                              "name": "TEST",
                                              "username": "00:11:22:33:44:55",
                                              "port": 51826,
                                              "pin": "000-00-001"
                                            "platforms": [
                                                "name": "Config",
                                                "port": 8090,
                                                "auth": "form",
                                                "theme": "dark-mode",
                                                "tempUnits": "c",
                                                "lang": "auto",
                                                "sudo": false,
                                                "log": {
                                                  "method": "file",
                                                  "path": "/var/log/homebridge_ioB.log"
                                                "platform": "config"
                                                "devices": [
                                                    "name": "Mi Smart Standing Fan 2",
                                                    "ip": "192.xxx.xxx.xxx",
                                                    "token": "xxxxx",
                                                    "model": "dmaker.fan.p18",
                                                    "pollingInterval": 10,
                                                    "buzzerControl": true,
                                                    "ledControl": true,
                                                    "naturalModeControl": true,
                                                    "sleepModeControl": true,
                                                    "moveControl": true,
                                                    "shutdownTimer": true,
                                                    "angleButtons": [
                                                      30,
                                                      60,
                                                      90,
                                                      120,
                                                      140
                                                    "ioniserControl": false
                                                "platform": "xiaomifan"
                                            "accessories": []
                                          Diese Config-Datei kann mit anderen Einträgen (bei mir zB für Sonos) kombiniert werden. Den Token, das Modell und die IP Adresse des Ventilators kann einfach über die hier hinterlegte App ausgelesen werden: https://github.com/Maxmudjon/Get_MiHome_devices_token/releases
                                          6. den ham Adapter neu starten (passiert eigentlich automatisch)
                                          7. Unter Objects in ioBroker werden dann unter ham.0 die Ventilatorsettings und Steuermöglichkeiten angezeigt
                                          Wenn der Ventilator in der Xiaomi App auftaucht, sollte er dann auch in ioBroker verfügbar sein.
                                          Weitere Hinweise:
                                          • Ich hatte den Ventilator testweise im Fritzbox-Gästenetz, dann funktioniert es aber leider nicht, er muss scheinbar lokal im Netz gut erreichbar sein
                                          • Für mein Ventilatormodell sind alle Einstellungen in ioBroker vornehmbar, bis auf die exakte Fan Speed als Prozentangabe. Es gibt aber 4 Stufen, die gewählt werden können
                                          • Der Ventilator erscheint auch ohne weiteres in der Apple Home App und kann dort auch gesteuert werden, dort kann sogar die Fan Speed in Prozent geändert werden. Hierzu muss der ham Adapter mit Apple Home verbunden werden, das müsstet Ihr nochmals googlen (bei mir liefs wegen des Sonos bereits), ist aber recht einfach.
                                          • Wer der China-Cloud nicht vertraut, kann nach der Installtion des Ventilators in der Fritzbox den Internetzugang des Fans kappen. Er erscheint dann in der Xiaomi Home App als "offline"
                                          @Pittini nochmals vielen herzlichen Dank für das Trouble-Shooting mit Deinem Skript, leider musste ich doch den anderen Weg gehen, da die Fehlermeldung nicht wegzubekommen war. Insbesondere die Tatsache, dass der Ventilator über ham ohne China Cloud lauffähig ist, ist m.E. ein Vorteil.
                                          haselchenH Damrak2022D 2 Antworten Letzte Antwort
