  4. Meldungen seit controller v3.3 zu falschem Datentyp
175 Beiträge 35 Kommentatoren 46.4k Aufrufe 31 Beobachtet
    Snapergy
    #110
    Auch beim Weatherunderground Adapter habe ich die Meldungen: (Liste ist nur ein Ausschnitt)
    weatherunderground.0
    	2021-08-10 09:00:22.461	info	State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
    	2021-08-10 09:00:22.305	info	State value to set for "weatherunderground.0.forecastHourly.34h.precipitation" has to be type "value.precipitation" but received type "number"
    	2021-08-10 09:00:22.185	info	State value to set for "weatherunderground.0.forecastHourly.33h.precipitation" has to be type "value.precipitation" but received type "number"
    	2021-08-10 09:00:22.084	info	State value to set for "weatherunderground.0.forecastHourly.32h.precipitation" has to be type "value.precipitation" but received type "number"
    	2021-08-10 09:00:21.994	info	State value to set for "weatherunderground.0.forecastHourly.31h.precipitation" has to be type "value.precipitation" but received type "number"
    	2021-08-10 09:00:21.901	info	State value to set for "weatherunderground.0.forecastHourly.30h.precipitation" has to be type "value.precipitation" but received type "number"
    	2021-08-10 09:00:21.802	info	State value to set for "weatherunderground.0.forecastHourly.29h.precipitation" has to be type "value.precipitation" but received type "number"
    	2021-08-10 09:00:21.702	info	State value to set for "weatherunderground.0.forecastHourly.28h.precipitation" has to be type "value.precipitation" but received type "number"
    	2021-08-10 09:00:21.607	info	State value to set for "weatherunderground.0.forecastHourly.27h.precipitation" has to be type "value.precipitation" but received type "number"
    	2021-08-10 09:00:21.496	info	State value to set for "weatherunderground.0.forecastHourly.26h.precipitation" has to be type "value.precipitation" but received type "number"
    	2021-08-10 09:00:21.394	info	State value to set for "weatherunderground.0.forecastHourly.25h.precipitation" has to be type "value.precipitation" but received type "number"
    	2021-08-10 09:00:21.289	info	State value to set for "weatherunderground.0.forecastHourly.24h.precipitation" has to be type "value.precipitation" but received type "number"
    	2021-08-10 09:00:21.186	info	State value to set for "weatherunderground.0.forecastHourly.23h.precipitation" has to be type "value.precipitation" but received type "number"
    	2021-08-10 09:00:21.064	info	State value to set for "weatherunderground.0.forecastHourly.22h.precipitation" has to be type "value.precipitation" but received type "number"
    	2021-08-10 09:00:20.937	info	State value to set for "weatherunderground.0.forecastHourly.21h.precipitation" has to be type "value.precipitation" but received type "number"
    • DolomitiD Offline
      DolomitiD Offline
      Dolomiti
      schrieb am zuletzt editiert von Dolomiti
      #111
      Bei WLED auch
      2021-08-10 20:22:07.527  - info: wled.0 (757) State value to set for "wled.0.8caab57a90dc.seg.0.col.2" has to be one of type "string", "number", "boolean" but received type "object"
      2021-08-10 20:22:37.736  - info: wled.0 (757) State value to set for "wled.0.2cf432778428._info.leds.pin" has to be one of type "string", "number", "boolean" but received type "object"
      2021-08-10 20:22:38.023  - info: wled.0 (757) State value to set for "wled.0.2cf432778428._info.mac" has to be type "number" but received type "string"
      2021-08-10 20:22:38.271  - info: wled.0 (757) State value to set for "wled.0.2cf432778428.seg.0.col.0" has to be one of type "string", "number", "boolean" but received type "object"
      2021-08-10 20:22:38.287  - info: wled.0 (757) State value to set for "wled.0.2cf432778428.seg.0.col.1" has to be one of type "string", "number", "boolean" but received type "object"
      2021-08-10 20:22:38.303  - info: wled.0 (757) State value to set for "wled.0.2cf432778428.seg.0.col.2" has to be one of type "string", "number", "boolean" but received type "object"
      2021-08-10 20:22:38.563  - info: wled.0 (757) State value to set for "wled.0.8caab57a90dc._info.leds.pin" has to be one of type "string", "number", "boolean" but received type "object"
      2021-08-10 20:22:38.834  - info: wled.0 (757) State value to set for "wled.0.8caab57a90dc._info.mac" has to be type "number" but received type "string"
      Objekte habe ich mal Alle gelöscht und Instanz neu gestartet. Keine Änderung.
      Mein Log ist dadurch auf 15MB angewachsen und zwingt den ioBroker in die Knie wenn ich mir den anzeigen lassen will.
      Admin 5.1.23
      JS-Controller 3.3.15
      Intel N100 (32GB,256GB SSD), Proxmox -> Debian 13 in VM (Master) + Debian 13 in CT (Test) + Debmatic, HM-Aktoren, Wago 750-880, Shelly, Zigbee
      • S Snapergy
        crunchipC Abwesend
        crunchipC Abwesend
        #112
        @snapergy instanz stoppen, Datenpunkte löschen( wenn mehr den ganzen Objektbaum löschen), instanz wieder starten
        • DolomitiD Dolomiti
          Bei WLED auch
          Admin 5.1.23
          crunchipC Abwesend
          crunchipC Abwesend
          #113
          @dolomiti mit der neuen Version 0.5.7? vor dem löschen Instanz stoppen
          DolomitiD 1 Antwort Letzte Antwort
            DolomitiD Offline
            DolomitiD Offline
            Dolomiti
            #114
            @crunchip
            Habe die Instanz gelöscht,Datenpunkte gelöscht. Dann auf Beta umgestellt, da mir 0.5.7 nicht im stable (0.5.6) angezeigt wurde. Dann musste ich noch ein
            iobroker update
            machen, damit er das Repository aktualisiert. Dann 0.5.7 installiert wobei 0.5.9 verfügbar wäre. Seit dem ist Ruhe.
              meikelg
              #115
              km200 (Buderus) auch:
              2021-08-11 17:37:16.339 - info: km200.0 (22247) State value to set for "km200.0.heatSources.info" has to be type "string" but received type "object"
              2021-08-11 17:37:16.347 - info: km200.0 (22247) State value to set for "km200.0.heatSources.info" has to be type "string" but received type "object"
              2021-08-11 17:37:19.553 - info: km200.0 (22247) State value to set for "km200.0.heatingCircuits.hc1.currentOpModeInfo" has to be type "string" but received type "object"
              2021-08-11 17:37:19.556 - info: km200.0 (22247) State value to set for "km200.0.heatingCircuits.hc1.currentOpModeInfo" has to be type "string" but received type "object"
              2021-08-11 17:37:32.461 - info: km200.0 (22247) State value to set for "km200.0.recordings.heatSources.actualPower._Months" has to be type "string" but received type "object"
              2021-08-11 17:37:32.463 - info: km200.0 (22247) State value to set for "km200.0.recordings.heatSources.actualPower._Months" has to be type "string" but received type "object"
              Kommentiert unter https://github.com/frankjoke/ioBroker.km200/issues/59#issuecomment-896948783
              Gab allerdings schon länger keine Updates mehr für diesen Adapter ...
              iobroker auf Synology 718+ und RasPi 3B
              Homematic CCU3 etc.
              • M meikelg
                Ahnungsbefreit
                schrieb am zuletzt editiert von Ahnungsbefreit
                #116
                LaMetric auch noch offen (und dadurch funktionslos):
                lametric.0
                2021-08-11 18:14:42.290	info	State value to set for "lametric.0.mydatadiy.obj" has to be type "string" but received type "object"
                Github Issue:
                https://github.com/klein0r/ioBroker.lametric/issues/45
                • apollon77A Offline
                  #117
                  @frankjoke hat auf GitHub mak eine 2.0.3 von Radar gebaut ... Kann mal jemand bitte checken wie die so ist und Rückmeldung geben?
                  https://github.com/frankjoke/ioBroker.radar2
                  • apollon77A apollon77
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #118
                    @apollon77 gerade gesehen, moment, ich teste mal
                    installation verlief fehlerfrei, Problem Konfig Seite immer noch undefined
                    wenn ich mir die config.json runter lade, sieht die so aus, mehr steht da nicht drin
                      "_adapter_info_": {
                        "time": "2021-08-11T22:54:39.635Z",
                        "instance": "radar2.0&newReact=true&0"
                    wenn ichs jetzt richtig gelesen habe, wurde "ack-flag" behoben
                        "_adapter_info_": {
                      #119
                      @crunchip Aulo wenn das was nicht geht nur die Anzeige der versionsnummer ist dann ist das ja verkraftbar :-) Oder?
                      crunchipC F 2 Antworten Letzte Antwort
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #120
                        @apollon77 verstehe gerade deine Aussage nicht, der Radar lief vor und nach dem Update, ohne Probleme, ausser das es bei mir zu Fehlern kam beim stoppen des Adapters (issue hatte ich erstellt im Mai)
                        was nun bereinigt ist, sind die (set state...ack, true), dennoch fehlt die Konfig, siehe Screen,
                        man könnte zwar nun wieder etwas reinschreiben, weiß aber nicht, wie es sich verhält, da die Konfig ja irgendwo noch hinterlegt ist.
                        (mit zweiten Admin hab ich nicht getestet)
                        F 1 Antwort Letzte Antwort
                          Fabian1
                          #121
                          @crunchip said in Meldungen seit controller v3.3 zu falschem Datentyp:
                          Jepp, das war aber auch schon bei der Version vorher so. An der config wurde in dieser Version nichts geändert. Ich mach mal ein Issue dazu auf.
                            Fabian1
                            schrieb am zuletzt editiert von Fabian1
                            #122
                            @apollon77 said in Meldungen seit controller v3.3 zu falschem Datentyp:
                            Ich habe das jetzt nochmal gechecked. @crunchip hat recht. Konfigurationsmässig geht beim Radar2 garnichts mehr. In der Konfig funktioniert nicht mal mehr der speichern und schliessen Button und man kann keine neuen Geräte hinzufügen.
                            Das ist mir garnicht aufgefallen, weil er trotzdem IRGENDWO her die alten Daten ausliest. Das ganze muss schon vor ein paar Versionen passiert sein.
                            Hier die Konfig, komplett leer:
                            Die Daten kommen aber trotzdem:
                            Kommen die aus der objects.json?
                            Ich bin gerade mal WEIT zurück auf die 1.2.5 gegangen und siehe da, die Objekte sind da:
                            Issue ist erstellt:
                            https://github.com/frankjoke/ioBroker.radar2/issues/101
                            • F Fabian1
                              Issue ist erstellt:
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #123
                              @fabian1 sagte in Meldungen seit controller v3.3 zu falschem Datentyp:
                              das hab ich so nicht probiert, ob ne "uralt" Version mit admin5 klar kommt, bekannt ist jedenfalls das seit admin5 die Konfigseite nicht mehr funktioniert, nur mit alter Oberfläche scheinbar(jedoch noch nicht getestet).
                              nach dem gestrigen Aufruf einer neuen Version hatte ich auch nicht vorher kontrolliert, was geändert wurde, sondern nur installiert, in der Hoffnung dass das Konfigproblem damit behoben sei.
                                Fabian1
                                #124
                                In der neuen Github Version funktioniert die Konfig jetzt wieder! :)
                                • Siggi0904S Siggi0904
                                  @paul53 sieht man die Änderung im git schon?
                                  Irgendwie sehe ich die da nicht.
                                  Denn wenn es der PR https://github.com/iobroker-community-adapters/ioBroker.deconz/pull/261 ist, dann ist der ja mit Fehler (Integrationstest) abgelehnt worden und ist schon 2 Tage alt.
                                  Dann kommt ja noch die große Hürde, dass es auch als stable released werden muss.
                                  #125
                                  Hallo
                                  bei mir läuft der IObroker jetzt ca seit einer Woche auf js3.3 und mit admin5. Bisher sehr reibungslos doch heute werde ich auf einmal durch einen übervollen Log überrascht der durch den mqtt Adapter einen Datenpunkttyp meldet:
                                  2021-08-18 06:07:46.587  - info: mqtt.0 (843) State value to set for "mqtt.0.HeizKellerTank2.Lux.Helligkeit" has to be type "number" but received type "string"
                                  Wenn ich es richtig sehe steht auf Github, dass mit Version 2.4.0 vom 9.5.2021 für js3.3 diese datentypfehler berücksichtigt wurden.
                                  Was läuft falsch und kann ich tun?
                                  Besten Dank.
                                  crunchipC apollon77A 2 Antworten Letzte Antwort
                                    Hallo
                                    Besten Dank.
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #126
                                    @pete0815 Instanz stoppen, DP löschen, Instanz starten, wenn weg ok, wenn nicht issue
                                      #127
                                      @crunchip Danke! Fahre gleich einen Test. VG
                                        Hallo
                                        Besten Dank.
                                        #128
                                        @pete0815 naja die andere frage ist warum eine Helligkeit als String ankommt. Sendet da ggf jemand anders Müll?
                                          #129
                                          @apollon77 sagte in Meldungen seit controller v3.3 zu falschem Datentyp:
                                          ich denke MQTT sendet (bisher??) immer STRING
                                          ? 2 Antworten Letzte Antwort
