  4. [ESPHome] Beta release
591 Beiträge 48 Kommentatoren 238.9k Aufrufe 39 Beobachtet
  • K klassisch
    Habe mittlerweile auf node 12 upgegraded.
    Der Adapter ist installiert, schon mal ein Fortschritt
    Allerdings kommt das Dashboard nicht und läßt sich auch nicht ansprechen.
    Ist da bei der Installation etwas schief gelaufen?
    install Drozmotix/ioBroker.esphome#1646702ba7f20c2a8563b42f2c06f20a7620d91e
    NPM version: 6.14.14
    npm install Drozmotix/ioBroker.esphome#1646702ba7f20c2a8563b42f2c06f20a7620d91e --loglevel error (System call)
    node-aead-crypto not needed on this system, since all ciphers are natively supported
    C:\Program Files\Python39\lib\site-packages\setuptools\distutils_patch.py:25: UserWarning: Distutils was imported before Setuptools. This usage is discouraged and may exhibit undesirable behaviors or errors. Please use Setuptools' objects directly or at least import Setuptools first.
      warnings.warn(
    Cache entry deserialization failed, entry ignored
    upload [5] esphome.admin C:/Program Files/iobroker/ioBrMain026/node_modules/iobroker.esphome/admin/words.js words.js application/javascript
    upload [4] esphome.admin C:/Program Files/iobroker/ioBrMain026/node_modules/iobroker.esphome/admin/style.css style.css text/css
    upload [3] esphome.admin C:/Program Files/iobroker/ioBrMain026/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html
    upload [2] esphome.admin C:/Program Files/iobroker/ioBrMain026/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png
    upload [1] esphome.admin C:/Program Files/iobroker/ioBrMain026/node_modules/iobroker.esphome/admin/esphome.png esphome.png image/png
    upload [0] esphome.admin C:/Program Files/iobroker/ioBrMain026/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t
    process exited with code 0
    DutchmanD Offline
    DutchmanD Offline
    Dutchman
    #220
    @klassisch sagte in [ESPHome] Beta release:
    Ip in den Settings eingetragen ?
      klassisch
      #221
      Vielen Dank!
      @dutchman sagte in [ESPHome] Beta release:
      ich denke, ja. Oder ich habe alles falsch verstanden.
      Hatte die Anleitung so interpretiert, daß ein ESPHome dashbord auf dem ioBroker Rechner mit installiert wird.
      Allerdings konnte ich dieses nicht starten. Weder über localhost noch über die IP-Adresse des ioBroker Rechners.
      So, Jetzt habe ich mal bei ESPHome direkt geschaut und gesehen
      It was primarily designed for the Home Assistant add-on, but also works with a simple command on *nix machines (sorry, no windows).
      Also die unterstützen kein Windows. Dann wird das bei mir auch nicht laufen....
      Hatte aber mal hier auf einem Windows Rechner eine laufende ESPHome Infrasruktur. Damit konnte ich ESP32 mit ESPHome flashen. Der ESP32 läuft auch noch.
      Aber die ESPHome Plattform leider nicht mehr. Jeder Kompilierungsversuch wird mit
      Warning! You are not connected to the Internet.
      quittiert und abgebrochen.
      Und natürlich hat mein Lapto eine funktionierende Internetverbindung.
      Ok, auch das gelöst durch update
      Dann nächtse Fehlermeldung
      Error: Detected unknown package 'espressif32'
      Das hat doch schon mal übersetzt. Und espressif32 habe ich nirgendwo spezifiziert, lediglich ESP32
      So, jetzt ist die Mittagspause auch vorbei
      • K klassisch
        Vielen Dank!
        DutchmanD Offline
        DutchmanD Offline
        Dutchman
        #222
        nope, den ESPHome hat ne rissige backend mit libs usw ich kan im Adapter nur das Resultat unterstützen :)
        Due könntest eventueel ESPHome in einer Docker Umgebung laugen lassen, nicht das Dashboard im Adapter. sondern das externe verwenden als alternatieve.
        • DutchmanD Dutchman
          klassisch
          #223
          @dutchman auf das Dashboard könnte ich notfalls auch verzichten .
          Das hatte ich früher ja auch nicht.
          Habe da ja auch alles auf meinem PC gemacht.
          Leider übersetzen meine bisherigen Yaml nicht mehr. Kennen den ESP32 nicht mehr so richtig.
          • K klassisch
            DutchmanD Offline
            DutchmanD Offline
            Dutchman
            #224
            wo genau gehts schief ?
              klassisch
              #225
              @dutchman Danke, es entgleist beim Übersetzen des yaml
              d:\USER\JS\SONSTIGE\ESPHome> esphome d:\USER\JS\SONSTIGE\ESPHome\CO2Sensor_ESP32\CO2Sensor.yaml run
              ←[33mWARNING You're using ESPHome with python 2. Support for python 2 is deprecated and will be removed in 1.15.0. Please reinstall ESPHome with python 3.6 or higher.←[0m
              ←[32mINFO Reading configuration d:\USER\JS\SONSTIGE\ESPHome\CO2Sensor_ESP32\CO2Sensor.yaml...←[0m
              ←[32mINFO Generating C++ source...←[0m
              ←[32mINFO Compiling app...←[0m
              ←[32mINFO Running:  platformio run -d 'd:\USER\JS\SONSTIGE\ESPHome\CO2Sensor_ESP32\co2sensor01'←[0m
              Processing co2sensor01 (board: wemos_d1_mini32; framework: arduino; platform: espressif32@1.12.1)
              PlatformManager: Installing espressif32 @ 1.12.1
              unknown package espressif32
              im yaml
              esphome:
                platform: ESP32
              Hat schon mal erfolgreich übersetzt. Jetzt leider nicht mehr.
              • K klassisch
                im yaml
                esphome:
                  platform: ESP32
                DutchmanD Offline
                DutchmanD Offline
                Dutchman
                #226
                welche Python haste du drauf ? denke mal liegt daran ?
                  klassisch
                  schrieb am zuletzt editiert von klassisch
                  #227
                  Danke nochmals!
                  @dutchman gefühlt viele, weil mit verschiedenen Programmpaketen verschiedene Python versionen kamen. Wenn ich in der Dosbox python aufrufe kommt Python 2.7.13 raus.
                  Wenn ich mich recht erinnere, war das u.a. für die ESP-Flasherei wichtig.
                  Mit Libreoffice kam noch python 3.7 und ich habe irgendwo noch python 3.8.
                  Das kann ich auch öffnen.
                  Python 3.8.1 (tags/v3.8.1:1b293b6, Dec 18 2019, 22:39:24) [MSC v.1916 32 bit (Intel)] on win32
                  Type "help", "copyright", "credits" or "license" for more information.
                  Aber das scheint nicht mit dem ESPHome verbunden zu sein.
                  • K klassisch
                    Danke nochmals!
                    DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    #228
                    diese Meldung sagt was anderes :)
                      klassisch
                      #229
                      @dutchman Ja, ich bezog das auch auf die gezeigte 3.8. Die kann ich aufrufen. Aber ESPHOme hält sich an die 2.7
                      • K klassisch
                        DutchmanD Offline
                        DutchmanD Offline
                        Dutchman
                        schrieb am zuletzt editiert von Dutchman
                        #230
                        und genau da geht es schief er braucht naemlich 3.7 :)
                        In der package mache ich keine links fuer python 2.x
                          "python": {
                            "execPath": [
                              "python3.8",
                              "python3.7",
                              "python3",
                              "python"
                            "python": {
                              "execPath": [
                                "python3.8",
                                "python3.7",
                                "python3",
                                "python"
                          klassisch
                          #231
                          @dutchman ok, und wie bekomme ich das hin, so daß 2.7 und 3.3 nutzbar sein können?
                          • K klassisch
                            DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            #232
                            gute frage :/ wie lauten deine Pfade fuer python ?
                              "python"
                            eventuell kommt er durch diesen Eintrag die 2.7
                                "python"
                              klassisch
                              #233
                              @dutchman
                              directories sehr strange: c:\Users\JS\AppData\Local\Programs\Python\Python38-32\
                              und c:\Python27\
                              Und wenn ich in der Konsole "path" eingeben, dann ist dort
                              C:\Python27;C:\Python27\Scripts;C:\Windows\system32;
                              enthalten.
                              Also man Path austauschen?
                              • K klassisch
                                @dutchman
                                und c:\Python27\
                                enthalten.
                                DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                #234
                                also nimmt er standard die 2.7, schau dir das hier mal an um das auf die 3.7 um zu leiten
                                https://stackoverflow.com/questions/5087831/how-should-i-set-default-python-version-in-windows
                                  klassisch
                                  #235
                                  @dutchman herzlichen Dank für Deine Geduld und Deine Tipps.
                                  Habe jetzt alles neu auf Basis python 3.8 aufgebaut, upgedatet - auch platformio. Habe gelernt, daß mein ESP Flashtool nicht mehr funktioniert, die neue espHome-Plattform das jetzt aber auch kann.
                                  Und daß man seine degub-Änderungen auch wieder rückgängig machen sollte
                                  Jetzt ist das Gerätchen wieder online und liefert neben den MQTT-Daten auch noch die API-Daten direkt in Deinen Adapter.
                                  Flashen ota scheint auch zu funktionieren - zumindest von esphome aus.
                                  Hinterlegen der credentials, incl. api credentials in einem zentralen file für alle Sensoren auch.
                                  Klasse!
                                  • K klassisch
                                    Klasse!
                                    DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    #236
                                    sind die Geräte per mdns erreichbar, also im selben Subnetz ?
                                    wie meinst ?
                                    K 2 Antworten Letzte Antwort
                                      wie meinst ?
                                      klassisch
                                      #237
                                      die sind alle im selben Netz. Bin Netzwerklaie und verwende eine Fritte. Und halte es einfach - so lange es geht.
                                      wie meinst ?
                                      So ein file, in dem ich die ganzen IP Adressen, Passwörter, SSID und das was alle meine Sensoren gemeinsam haben, zusammenfasse und welches dann im yaml mit
                                      <<: !include includes.yaml
                                      referenziert wird.
                                        klassisch
                                        #238
                                        vielleicht noch eine Frage: Wie viel Ressourcen braucht ein solches Dashboard? Habe noch einen NUT-Server auf einem OPI plus 2e und armbian laufen. Allerdings nur 1GB RAM,. Passt das da noch drauf? Das Teil idled sonst nur rum.
                                        • K klassisch
                                          DutchmanD Offline
                                          DutchmanD Offline
                                          Dutchman
                                          #239
                                          Nicht so viel sollte passen
