  4. LED Anzeige für VIS - Akku,Pegel,Kreis
    2.2k
    4.1k
79 Beiträge 3 Kommentatoren 5.6k Aufrufe 12 Beobachtet
  • sigi234S sigi234
    @liv-in-sky
    Ok, kannst du mal ein Blockly reinstellen für die Alexa Laustärke?
    Andere Frage:
    Möchte ich den Balken waagrecht soll ich transform rotate nehmen?
    liv-in-skyL Offline
    liv-in-skyL Offline
    @sigi234
    klappt
    • liv-in-skyL liv-in-sky
      @sigi234
      script zur anzeige von; alexa lautstärke
      <block xmlns="https://developers.google.com/blockly/xml" type="on" id="pF#%z?-}$wDG81-s,Sxk" x="-512" y="888">
       <field name="OID">alexa2.0.Echo-Devices.G090NV03742503T0.Player.volume</field>
       <statement name="STATEMENT">
         <block type="debug" id="|L_`rE7V5qN?Fy(SF#KP">
           <value name="TEXT">
             <shadow type="text" id="T#CZT4K^W(cRL2WXbuSu">
             </shadow>
             <block type="math_arithmetic" id="_v,8ZU%g@Msp*nT5IM,+">
               <field name="OP">DIVIDE</field>
               <value name="A">
                 <shadow type="math_number" id="!t/k^jY5VkI+9EHjIoE-">
                   <field name="NUM">1</field>
                 </shadow>
                 <block type="on_source" id="D~$Q_~3v)r!SoPzQLfyx">
                 </block>
               </value>
               <value name="B">
                 <shadow type="math_number" id="+iqSdHCMEN#5+S1_*030">
                   <field name="NUM">10</field>
                 </shadow>
               </value>
             </block>
           </value>
           <next>
             <block type="control" id="v)Q`(L@wtEB1[jpzrbP1">
               <field name="OID">javascript.0.Tabellen@Liv.LED1RingVIS.AnzeigeRegler.Regler</field>
               <value name="VALUE">
                 <block type="math_round" id="|vw_9cPpJW]vekcVi85J">
                   <field name="OP">ROUND</field>
                   <value name="NUM">
                     <shadow type="math_number" id="u-p_?)9H#2;?Hm9?5Ig6">
                       <field name="NUM">3.1</field>
                     </shadow>
                     <block type="convert_tonumber" id="/1Y6*QsV5[n9v6,~I5.Z">
                         <block type="math_arithmetic" id="[#q48F^)k$r:gE@9fkMh">
                           <value name="A">
                             <shadow type="math_number" id="q9Kd0@dpiuo]8Or($j6K">
                             </shadow>
                             <block type="on_source" id="O:Z-Z~o45M!wt|~0Ru6i">
                             </block>
                           </value>
                           <value name="B">
                             <shadow type="math_number" id="i:n~k2xNqtEhE)Q6fICy">
                             </shadow>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </value>
             </block>
           </next>
         </block>
       </statement>
      </block>
      sigi234S Online
      sigi234S Online
      @liv-in-sky sagte in LED Anzeige für VIS - Akku,Pegel,Kreis:
      Danke, ich bin ein Blockly Koffer.....😀
        @sigi234
        beim regler kannst du die anzahl der leds nicht bestimmen - die ist fix - du bestimmst dort, wieviel leds leuchten soll
        wenn du zweispaltig willst, musst du das widget etwas breiter machen
        die abstände zwischen den led's stellst du in PunkteAbstan ein - schrib da mal "5,5" rein
        sigi234S Online
        sigi234S Online
        #66
        Und wie bekomme ich die Led grösser?
        Wenn ich die Lautstärke am Dot ändere werden sie je nach LS von selber grösser?
        • sigi234S sigi234
          liv-in-skyL Offline
          liv-in-skyL Offline
          #67
          @sigi234
          z.b. javascript.0.Tabellen@Liv.LED1RingVIS.AnzeigeRegler.PunkteGroesse
          teste mal 20,20 - eigentlich sind das rechtecke, daher die 2 werte - im script werden die ecken dann abgerundet
          @sigi234 sagte in LED Anzeige für VIS - Akku,Pegel,Kreis:
          das verstehe ich nicht, das bild ergibt auch keinen sinn - ich sehe zuviele punkte - ist das auf zweispaltig gesetzt? dann muss das widget etwas breiter gemacht werden - der wert paßt auch nich
          den ganzen satz verstehe ich nicht - es ändert sich der volume wert und der durchmesser der leds verändert sich ???
            @sigi234
            sigi234S Online
            sigi234S Online
            #68
            • sigi234S sigi234
              liv-in-skyL Offline
              liv-in-skyL Offline
              #69
              @sigi234
              du mußt das html widget breiter machen - bis 2 spalten sichtbar sind
              • sigi234S sigi234
                liv-in-skyL Offline
                liv-in-skyL Offline
                #70
                @sigi234
                oder du schreibst "einspaltig" rein- javascript.0.Tabellen@Liv.LED1RingVIS.AnzeigeRegler.UsageFormat
                  @sigi234
                  sigi234S Online
                  sigi234S Online
                  #71
                  @liv-in-sky
                  Aha gecheckt, da geht`s um Millimeter......
                  • sigi234S sigi234
                    @liv-in-sky
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    #72
                    @sigi234
                    ja - vielleicht fällt mir noch eine bessere lösung ein - aber wenn man erstmal alles eingestellt hat , muss man nix mehr ändern
                      @sigi234
                      sigi234S Online
                      sigi234S Online
                      #73
                      @sigi234
                      Super, jetzt habe ich es begriffen. Theoretisch brauche ich dann für jedes Gerät ein Skript und ein Blockly.
                      • sigi234S sigi234
                        @sigi234
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #74
                        @sigi234 Ja genau
                        Die Blocklys können aber alle in einem Script sein
                        Jedes Script braucht in der variable dpVisnew einen eigenen Namen
                          ein script für eine led anzeige in der vis - benötigt ein html-standard widget mit binding auf den datenpunkt
                          • die datenpunkte des scriptes sollen durch andere scripte (js,blockly) angesprochen werden - damit wird die anzeige für die vis erzeugt - ähnlich wie bei einem adapter
                          • es ist eine reine anzeige - keine "rücksteuerung vom widget zu einen dp möglich
                          • bei diesem script ist es wichtig, nachdem man die settings in den dp definiert hat, dass die "breite" des widgets richtig definiert wird - das widget ist innen responsive - dh. durch das ändern der breite des html-standard-widgets, wird die liste der leds/punkte neu angeordnet
                          • das script kann für einen pegelanzeige und gleichteitig für eine standard ledanzeige genutzt werden - benötigt man ein zweites widget, muss ein neues script eingerichtet werden und unter der variablen: dpVISnew ein neuer name eingetragen werden
                          die datenpunkte sind unter: javascript.0.Tabellen@Liv.LED1RingVIS
                          das script braucht keine settings - wird alles über dp gesteuert bzw eingestellt
                          möglichkeiten der standard led anzeige
                          Lautstärke Anzeige:
                          beispiel bei pegelanzeige:
                          • einspaltig lautstärke pegel (leise unten grün und laut - oben rot)
                          • zweispaltig lautstärke pegel
                          • akku anzeige (farben gedreht - unten rot oben grün))
                          • die pegelanzeige hat feste farben und schatten - es können werte von 0 bis 10 eingetragen werden - für das volume von zb. alexa, muss ein script auf das volume von dem echo device getriggert sein und der volume-wert durch 10 geteilt werden - dieser wert wird dann in den dp geschrieben
                          einstellbar:
                          • anzahl punkte
                          • durchmesser des hauptkreises
                          • farben der punkte
                          • anzahl "leuchtender" punkte in bestimmter farbe
                          siehe mehr unter:
                          //@liv-in-sky 15.8.2021-15:00
                          let  dpVISnew="LED1RingVIS";                            // Datenpunkte unter javascript.x.Tabellen@Liv.LED1RingVIS
                          let ansichtFormat=1;                                //Datenpunkt einstellung hat höhere priorität - bitte dort bestimmen und script neustarten
        //- 1 ist rund, 2 ist quer, 3 ist hoch form
                          let styleLEDsVER;
                          let styleLEDsnew;
                          let scriptLEDnew;
                          let styleLEDsViele;
                          let DatapointArr=["javascript." + instance + ".Tabellen@Liv."+dpVISnew+".WidgetAnzeigeFormat","javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDStandardFarbeAus",
                          "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".WidgetDurchmesserGesamt","javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDDurchmesser",
                          "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDAnzahl","javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDFormat",
                          "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDSchatten","javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDAbstandZueinander",
                          "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".EinzelneLEDsSteuern-Animation"];
                          async function mainLED(){
                             await needDP().then(  async function () {
                          //ALLE EINSTELLUNGEN IN DEN DATENPUNKTEN
                          let grundfarbe="transparent";                         //Datenpunkt einstellung hat höhere priorität - bitte dort bestimmen
                          let groessePunkteHoehe=15;                           //Datenpunkt einstellung hat höhere priorität - bitte dort bestimmen und script neustarten
                          let groessePunkteWeite=15;                           //Datenpunkt einstellung hat höhere priorität - bitte dort bestimmen und script neustarten
                          let groesseGesamtHoehe=170;                          //Datenpunkt einstellung hat höhere priorität - bitte dort bestimmen und script neustarten
                          let groesseGesamtWeite=170;                          //Datenpunkt einstellung hat höhere priorität - bitte dort bestimmen und script neustarten
                          let rundung="rund";
                          let shadowLED=false;
                          let abstandLEDs=3;
                          let animationLED=false;
                            if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDDurchmesser")) {
                             let PunkteArr=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDDurchmesser").val.split(',')
                             groessePunkteHoehe=Number(PunkteArr[1]);
                             groessePunkteWeite=Number(PunkteArr[0]);
                              await wait(2000);}
                            if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".WidgetDurchmesserGesamt")) {
                             let GeamtArr=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".WidgetDurchmesserGesamt").val.split(',')
                              groesseGesamtHoehe=Number(GeamtArr[0])
                              groesseGesamtWeite=Number(GeamtArr[1])  }
                            if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDStandardFarbeAus")) {
                             let ledAusFarbe=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDStandardFarbeAus").val;
                              grundfarbe=ledAusFarbe; }
                            if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".WidgetAnzeigeFormat")) {
                             let ledAusFarbe=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".WidgetAnzeigeFormat").val;
                              ansichtFormat=ledAusFarbe; }
                            if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDFormat")) {
                             let ledAusFarbe=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDFormat").val;
                              rundung=ledAusFarbe; }
                            if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDSchatten")) {
                             let ledAusFarbe=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDSchatten").val;
                              shadowLED=ledAusFarbe; }
                            if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDAbstandZueinander")) {
                             let ledAusFarbe=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDAbstandZueinander").val;
                              abstandLEDs=ledAusFarbe; }
                            if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".EinzelneLEDsSteuern-Animation")) {
                             let ledAusFarbe=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".EinzelneLEDsSteuern-Animation").val;
                              animationLED=ledAusFarbe; }
                          let ansichtFormatVERHOR="inline-block";
                          let schattenLeds=`width: ${groessePunkteWeite}px;`;
                          if(shadowLED) schattenLeds=`--width: ${groessePunkteWeite}px;
                             width: var(--width);
                             box-shadow: inset 2px 2px  calc(var(--width) * 0.3) #aaa;` ;
                          let rotation="";
                          let borderRadius="50%";
                          ansichtFormat==2 ?  ansichtFormatVERHOR="flex" :  ansichtFormatVERHOR="inline-block"
                          ansichtFormat==2 ? rotation="" : rotation=`transform: rotate(180deg); `
                          if (rundung=="rund") {borderRadius="50%";} else if(rundung=="eckig") {borderRadius="0%";} else if (rundung=="abgerundet") {borderRadius="20%";}
                          let animater=`}`
                          if (animationLED) {animater=`animation: zoom-in-zoom-out 1.5s ;
                                 @keyframes zoom-in-zoom-out { 0% { transform: scale(1, 1);}
                                                              50% { transform: scale(1.3, 1.3); }
                                                             100% { transform: scale(1, 1); }
                          styleLEDsVER=`#outer${dpVISnew}{
                          		display: ${ansichtFormatVERHOR} ;
                                 ${rotation}
                             	.inner${dpVISnew}{
                             	height: ${groessePunkteHoehe}px;
                             	${schattenLeds}
                             	background: ${grundfarbe};
                             	border-radius: ${borderRadius};
                                 align-items: center;
                                 margin-right: ${String(abstandLEDs)}px;
                                 margin-top: 8px;
                                 margin-left: ${String(abstandLEDs)}px;
                           styleLEDsViele=`#outer${dpVISnew}{
                          		display: flex;
                                 flex-flow: row wrap;
                                /* justify-content: space-around;*/
                             	.inner${dpVISnew}{
                                 ${schattenLeds}
                                 /*animation: 7s infinite alternate slidein;*/
                                /* box-shadow: inset 3px 3px 3px #FFF;*/
                                / box-shadow: inset 50% 50% silver;*/
                                 /*blur(4px);*/
                                 /*border: 2px;*/
                                 margin-top: 8px;
                             	${animater}`
                          styleLEDsnew=`#outer${dpVISnew} {
                          		position: absolute;
                             	height: ${groesseGesamtHoehe}px;
                             	width: ${groesseGesamtWeite}px;
                                 transform: rotate(-90deg);
                             	.inner${dpVISnew}{
                             	position: absolute;
                             	${schattenLeds}
                             	display: flex;
                             	justify-content: center;
                          scriptLEDnew=`var outer = document.getElementById('outer${dpVISnew}');
                             	var outerWidth = document.getElementById('outer${dpVISnew}').offsetWidth;
                             	var outerHeight = document.getElementById('outer${dpVISnew}').offsetHeight;
                             	for(var i = 0; i < outer.children.length; i++){
                             	var r = outerWidth / 2 - outer${dpVISnew}.children[i].offsetWidth / 2;
                             	var phi = i / outer${dpVISnew}.children.length;
                             	var x = r * Math.cos(phi * 2 * Math.PI) + r;
                             	var y = r * Math.sin(phi * 2 * Math.PI) + r;
                             	outer${dpVISnew}.children[i].style.left = x+'px';
                             	outer${dpVISnew}.children[i].style.top = y+'px';
                             	console.log(outer${dpVISnew}.children[i].style.left);
                              AlleLedsAus(ansichtFormat);
                             async function needDP(){
                              if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDAnzahl"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".LEDAnzahl", 15,{type: "number", name: "Anzahl LEDs", role: "value", read: true, write: true, } ); }
                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDFormat"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".LEDFormat", "rund",{type: "string", name: "Format Punkte -rund-eckig-abgerundet", role: "value", read: true, write: true, } ); }
                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDAbstandZueinander"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".LEDAbstandZueinander", 3,{type: "number", name: "Seitlicher LED Abstand Zueinander", role: "value", read: true, write: true, } ); }
                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDDurchmesser"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".LEDDurchmesser", "15,15",{type: "string", name: "Durchmesser Punkte", role: "value", read: true, write: true, } ); }
                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".WidgetDurchmesserGesamt"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".WidgetDurchmesserGesamt", "200,200",{type: "string", name: "Durchmesser Gesamt", role: "value", read: true, write: true, } ); }
                              if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AlleLEDs"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".AlleLEDs", "#14f54b",{type: "string", name: "Alle LEDs in einer Farbe", role: "value", read: true, write: true, } ); }
                              if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDStandardFarbeAus"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".LEDStandardFarbeAus", "#3f3f3f",{type: "string", name: "Standard Led Farbe Aus", role: "value", read: true, write: true, } ); }
                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AlleLEDsAUS"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".AlleLEDsAUS", false,{type: "boolean", name: "Alle LEDs AUS", role: "value", read: true, write: true, } ); }
                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDsEINAnzahl"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".LEDsEINAnzahl", "4,red",{type: "string", name: "Anzahl LEDs EIN", role: "value", read: true, write: true, } ); }
                              if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".EinzelneLEDsSteuern"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".EinzelneLEDsSteuern", '[{"number":3,"color":"red"}]',{type: "string", name: "Einzelne LEDs Steuern", role: "value", read: true, write: true, } ); }
                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AlleLEDsBunt"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".AlleLEDsBunt", "bunt",{type: "string", name: "Alle LEDs Bunt", role: "value", read: true, write: true, } ); }
                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDSchatten"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".LEDSchatten", false,{type: "boolean", name: "Alle LEDs mit Schatten", role: "value", read: true, write: true, } ); }
                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".EinzelneLEDsSteuern-Animation"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".EinzelneLEDsSteuern-Animation", false,{type: "boolean", name: "Animation - Einzelne LEDs Steuern", role: "value", read: true, write: true, } ); }
                                if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AlleLEDsRegenbogen"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".AlleLEDsRegenbogen", "regenbogen",{type: "string", name: "Alle LEDs Regenbogen", role: "value", read: true, write: true, } ); }
                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".WidgetAusgabe"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".WidgetAusgabe", "",{type: "string", name: "Widget VIS Datenpunkt", role: "value", read: true, write: true, } ); }
                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".WidgetAnzeigeFormat"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".WidgetAnzeigeFormat", 1,{type: "number", name: "Anzeige Format - rund-quer-hoch-eckig", role: "value", read: true, write: true, } ); }
                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.Pegel"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".AnzeigePegel.Pegel", 3,{type: "number", name: "Anzeige Pegel", role: "value", read: true, write: true, } ); }
                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.WidgetPegelAusgabe"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".AnzeigePegel.WidgetPegelAusgabe", "",{type: "string", name: "Widget VIS Datenpunkt Pegel", role: "value", read: true, write: true, } ); }
                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.PegelPunkteFormat"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".AnzeigePegel.PegelPunkteFormat", "rund",{type: "string", name: "Pegel Punkte Format -rund -eckig", role: "value", read: true, write: true, } ); }
                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.PunkteGroesse"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".AnzeigePegel.PunkteGroesse", "19,6",{type: "string", name: "AnzeigePegel Punkte Groesse", role: "value", read: true, write: true, } ); }
                              if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.UsageFormat"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".AnzeigePegel.UsageFormat", "zweispaltig",{type: "string", name: "AnzeigePegel Usage Format ", role: "value", read: true, write: true, } ); }
                             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.PunkteAbstand"))) {
                                 await createStateAsync("Tabellen@Liv."+dpVISnew+".AnzeigePegel.PunkteAbstand", "5,5",{type: "string", name: "AnzeigePegel Punkte Abstand", role: "value", read: true, write: true, } ); }
                              function AlleLedsAus(ansichtFormat) {
                                 let menge= getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDAnzahl").val;
                                 let augabeHilfe=`<div id="outer${dpVISnew}">`;
                                 for (let i=0;i<menge;i++){
                                     augabeHilfe=augabeHilfe+`<div class="inner${dpVISnew}"></div>`
                                 augabeHilfe=augabeHilfe+`</div>`;
                                 let ausgabe;
                                 switch (ansichtFormat) {
                                        case 1:  ausgabe="<style>"+styleLEDsnew+`</style>`+augabeHilfe+"<script>"+scriptLEDnew+`</script>`; break;
                                        case 2:  ausgabe="<style>"+styleLEDsVER+`</style>`+augabeHilfe; break;
                                        case 3:  ausgabe="<style>"+styleLEDsVER+`</style>`+augabeHilfe; break;
                                        case 4:  ausgabe="<style>"+styleLEDsViele+`</style>`+augabeHilfe; break;
                                 setState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".WidgetAusgabe",ausgabe);
                              function alleLedsEIN(ansichtFormat) {
                                 let colorAll= getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AlleLEDs").val;
                                 let newColorStyle=`.inner1${dpVISnew}{  			 background: ${colorAll};}`;
                                    augabeHilfe=augabeHilfe+`<div class="inner${dpVISnew} inner1${dpVISnew} "></div>`
                                let ausgabe;
                                        case 1:  ausgabe="<style>"+styleLEDsnew+newColorStyle+`</style>`+augabeHilfe+"<script>"+scriptLEDnew+`</script>`; break;
                                        case 2:  ausgabe="<style>"+styleLEDsVER+newColorStyle+`</style>`+augabeHilfe; break;
                                        case 3:  ausgabe="<style>"+styleLEDsVER+newColorStyle+`</style>`+augabeHilfe; break;
                                        case 4:  ausgabe="<style>"+styleLEDsViele+newColorStyle+`</style>`+augabeHilfe; break;
                              function LEDsEINAnzahl(ansichtFormat) {
                                 let mengeArr= getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDsEINAnzahl").val.split(',');
                                 let newColorStyle=`.inner1${dpVISnew}{  			 background: ${mengeArr[1]};}`;
                                     if(i<Number(mengeArr[0])) {augabeHilfe=augabeHilfe+`<div class="inner${dpVISnew} inner1${dpVISnew} "></div>`}
                                                           else {  augabeHilfe=augabeHilfe+`<div class="inner${dpVISnew}"></div>`}
                                  let ausgabe;
                              function alleLedsRegenbogen(ansichtFormat) {
                                 let colorAll= `linear-gradient(red 20%, yellow 40%, orange 60%, cyan 80%)`;
                                 let newColorStyle=`.inner1${dpVISnew}{  			 background-image: ${colorAll};}`;
                                    augabeHilfe=augabeHilfe+`<div class="inner${dpVISnew} inner1${dpVISnew} "></div>`;
                                  let ausgabe;
                              function alleLedsBunt(ansichtFormat) {
                                 let newColorStyle=`.inner1${dpVISnew}{  			 background: #0AD0E6;} .inner2${dpVISnew}{  			 background: #F2DD23;}
                                                    .inner3${dpVISnew}{  			 background: #63F285;} .inner4${dpVISnew}{  			 background: #E60A62;}`;
                                     if(i%4==0)  { augabeHilfe=augabeHilfe+`<div class="inner${dpVISnew} inner4${dpVISnew} "></div>`}
                                     else if (i%3==0)  { augabeHilfe=augabeHilfe+`<div class="inner${dpVISnew} inner3${dpVISnew} "></div>`  }
                                     else if (i%2==0)  { augabeHilfe=augabeHilfe+`<div class="inner${dpVISnew} inner2${dpVISnew} "></div>`  }
                                     else if (i%1==0)  { augabeHilfe=augabeHilfe+`<div class="inner${dpVISnew} inner1${dpVISnew} "></div>`  }
                                 let ausgabe;
                             function einzelneLedsSteuern(ansichtFormat) {
                                 let mengeArr= JSON.parse(getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".EinzelneLEDsSteuern").val);
                                 let pictureSizeBreite=(getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDDurchmesser").val.split(','))[0];
                                 let pictureSizeHoehe=(getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDDurchmesser").val.split(','))[1];
                                 let newColorStyle="";
                                 for (let i=0;i<mengeArr.length;i++){
                                 newColorStyle=newColorStyle+`.inner${(i+1)}${dpVISnew}{  			 background: ${mengeArr[i].color};}`
                                 let arrHelper=[];
                                      arrHelper.push(`<div class="inner${dpVISnew} "></div>`)}
                                //  log(JSON.stringify(mengeArr[i]))
                                      if(mengeArr[i].hasOwnProperty("picture")) {/*log(mengeArr[i].picture);*/ arrHelper[(mengeArr[i].number)-1]=   `<div class="inner${dpVISnew} inner${i+1}${dpVISnew} "><img src='${mengeArr[i].picture}' width='${pictureSizeBreite}px' height='${pictureSizeHoehe}px'></div>`}
                                      else {arrHelper[(mengeArr[i].number)-1]=   `<div class="inner${dpVISnew} inner${i+1}${dpVISnew} "></div>`}  }
                                       augabeHilfe=augabeHilfe+arrHelper[i] }
                                 let ausgabe;
                          mainLED();
                          //Pegel(12)
                           on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AlleLEDsAUS", val: true}, function (obj) {
                           if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".WidgetAusgabe"))  AlleLedsAus(ansichtFormat);
                           setState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AlleLEDsAUS",false)
                          on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".LEDsEINAnzahl",  change: "any"}, function (obj) {
                           if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".WidgetAusgabe"))  LEDsEINAnzahl(ansichtFormat);
                          on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AlleLEDs",  change: "any"}, function (obj) {
                           if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".WidgetAusgabe"))  alleLedsEIN(ansichtFormat);
                          on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AlleLEDsBunt",  change: "any"}, function (obj) {
                          if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".WidgetAusgabe"))   alleLedsBunt(ansichtFormat);
                          on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AlleLEDsRegenbogen",  change: "any"}, function (obj) {
                           if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".WidgetAusgabe"))  alleLedsRegenbogen(ansichtFormat);
                          on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".EinzelneLEDsSteuern",  change: "any"}, function (obj) {
                           if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".WidgetAusgabe"))  einzelneLedsSteuern(ansichtFormat);
                           on({id: DatapointArr,  change: "any"}, function (obj) {
                           mainLED();
                           on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.Pegel",  change: "any"}, function (obj) {
                            var value = obj.state.val;
                             Pegel(value);
                          on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.PegelPunkteFormat",  change: "any"}, function (obj) {
                          // if(value=="rund" || value=="eckig") {
                           Pegel(getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.Pegel").val);
                          on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.PunkteGroesse",  change: "any"}, function (obj) {
                           on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.PunkteAbstand",  change: "any"}, function (obj) {
                            on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.UsageFormat",  change: "any"}, function (obj) {
                          async function Pegel(myStufe){
                                if (!existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.PunkteAbstand")) {
                                await wait(4000);}
                               let punkteGroesseBreite=(getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.PunkteGroesse").val.split(','))[0];
                               let punkteGroesseHoehe=(getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.PunkteGroesse").val.split(','))[1];
                               let punkteAbstandHorizontal=(getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.PunkteAbstand").val.split(','))[0];
                               let punkteAbstandVertikal=(getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.PunkteAbstand").val.split(','))[1];
                               let PegelPunkteFormat=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.PegelPunkteFormat").val;
                               let borderRadiosPunkte ;
                               if (PegelPunkteFormat=="eckig") {borderRadiosPunkte = ""} else {borderRadiosPunkte = `border-radius: 50%; `;}
                               if (PegelPunkteFormat=="rund") borderRadiosPunkte = `border-radius: 50%; `;
                               let usage=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.UsageFormat").val;
                           let arrMitColor=[  `<li class="flex-item${dpVISnew} more-color-red${dpVISnew}"></li>`,
                           `<li class="flex-item${dpVISnew} more-color-yellow${dpVISnew}"></li>`,
                             `<li class="flex-item${dpVISnew} more-color-green${dpVISnew}"></li>`,
                            `<li class="flex-item${dpVISnew} more-color-green${dpVISnew}"></li>`]
                           let arrOhneColor=[`<li class="flex-item${dpVISnew}"></li>`,
                            `<li class="flex-item${dpVISnew}"></li>`]
                          let stylePegel=`<style>
                          .flex-container${dpVISnew} {
                           display: flex;
                           padding: 2px;
                           margin: 3px;
                           list-style: none;
                          .flex-item${dpVISnew} {
                           ${borderRadiosPunkte}
                           background: #3f3f3f;
                          /* padding: 15px; */
                           width: ${punkteGroesseBreite}px;
                           height: ${punkteGroesseHoehe}px;
                           margin-top: ${punkteAbstandVertikal}px; /*5*/
                           margin-left: ${punkteAbstandHorizontal}px; /*15*/
                           margin-right: ${punkteAbstandHorizontal}px; /*15*/
                           margin-bottom: ${punkteAbstandVertikal}px; /*8*/
                           line-height: 15px;
                           color: white;
                           font-weight: bold;
                           font-size: 3em;
                           text-align: center;
                          .more-color-red${dpVISnew}{
                          background: linear-gradient(11deg, rgba(179,75,62,1) 0%, rgba(157,66,50,1) 26%, rgba(239,215,218,1) 75%, rgba(228,21,89,1) 100%);
                            box-shadow: 1px 1px 2px 2px red;
                          .more-color-yellow${dpVISnew}{
                          background: linear-gradient(11deg, rgba(249,249,152,0.947835799358806) 0%, rgba(249,243,84,1) 26%, rgba(238,239,215,1) 75%, rgba(238,242,53,1) 100%);
                            box-shadow: 1px 1px 2px 2px #b8ba48;
                          .more-color-green${dpVISnew}{
                          background: linear-gradient(11deg, rgba(117,190,147,1) 0%, rgba(108,198,121,1) 26%, rgba(215,239,215,1) 75%, rgba(59,183,44,1) 100%);
                            box-shadow: 1px 1px 3px 3px green;
                          </style><ul class="flex-container${dpVISnew}">`;
                          //myStufe=myStufe/2;
                          let myHTMLText="";
                          if(usage=="zweispaltig") {
                            let arrMitColorReverse=arrMitColor.reverse();
                            for(let i=arrOhneColor.length-1;i>=0;i-=2){
                           //  log(i.toString())
                            if(i-(myStufe*2) >= 0 ) { myHTMLText=myHTMLText+arrOhneColor[i]+arrOhneColor[i-1];}
                            else {  myHTMLText=myHTMLText+arrMitColorReverse[i]+arrMitColorReverse[i-1];} }
                          } else if(usage=="einspaltig"){
                            myHTMLText="";
                            //log(i.toString() + "  "+ arrMitColorReverse[i])
                            if(i-(myStufe*2) >= 0 ) { myHTMLText=myHTMLText+arrOhneColor[i];}
                            else {  myHTMLText=myHTMLText+arrMitColorReverse[i];} }
                          } else if (usage=="akku"){
                            myHTMLText="";
                            log("akku")
                             // log(i.toString() + "  "+ arrMitColor[i] )
                            else {  myHTMLText=myHTMLText+arrMitColor[i];} }
                          let ausgabe=stylePegel+myHTMLText+`</ul>`;
                          // log(ausgabe)
                          setState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigePegel.WidgetPegelAusgabe",ausgabe);
                          beispiel view von @sigi234
                          weitere beispiele:
                          beispiel als uhrzeit mit bildern (zahlen 0-9)
                          neues script für LED's mit Zahlen und zum Schalten von Datenpunkten:
                          siehe https://forum.iobroker.net/post/749984
                          sigi234S Online
                          sigi234S Online
                          #75
                          @liv-in-sky
                          Es wird schon!
                          • sigi234S sigi234
                            @liv-in-sky
                            Es wird schon!
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            #76
                            @sigi234
                            schaut gur aus - ich kopiere mal dein bild in meinen erten post :-)
                            • liv-in-skyL Offline
                              liv-in-skyL Offline
                              #77
                              habe ein update im ersten post
                              das alte script kann natürlich noch genutzt werden - um das neue zu testen ein weiteres script dazufügen und dann die variable dpVISnew im script mit einem neuen namen beschreiben/deklarieren
                              ein neues format ist dazugekommen - wir im dp javascript.0.Tabellen@Liv.LED1RingVIS.WidgetAnzeigeFormat angegeben ( 1=rund, 2=quer, 3=hoch oder die neue einstellung 4=eckig)
                              durch anpassen der widgetgröße im vis-editor können die leds angeordnet werden
                              noch dazugekommen: ein schatten für die leds unter dem datenpunkt: javascript.0.Tabellen@Liv.LED1RingVIS.LEDSchatten
                              sieht dann so aus:
                              z.b ein zähler (für erinnerungen an einen monatl termin (tagezähler),...)
                              oder:
                                liv-in-skyL Offline
                                #78
                                im neuen script können auch bilder geladen werden - dies funktioniert nur, wenn man die einzel LEDs steuert. dies funktioniert über ein json. wenn man ein bild an einer stelle haben will, muss man im json den bild-pfad eingeben - ist kein "key" picture im json, wird eine led angezeigt.
                                das format eines images wird unter "javascript.0.Tabellen@Liv.LED1RingVIS.LEDDurchmesser" bestimmt (breite/höhe)
                                    "number": 1,
                                    "color": "tranparent",
                                    "picture": "/vis.0/armin/img/zahl/1-green.png"
                                    "number": 2,
                                    "picture": "/vis.0/armin/img/zahl/0-green.png"
                                    "number": 3,
                                    "picture": "/vis.0/armin/img/zahl/dp-green.png"
                                    "number": 4,
                                    "picture": "/vis.0/armin/img/zahl/2-green.png"
                                    "number": 5,
                                    "picture": "/vis.0/armin/img/zahl/7-green.png"
                                ein beispiel als uhrzeitanzeige - die "leds" sind in diesen fall bilder
                                mit temperatur:
                                • die animation kann abgeschalten werden
                                  liv-in-skyL Offline
                                  #79
                                  dies ist ein eigenes script - für jedes widget, braucht man ein eigenes script - damit kann man andere datenpunkte schalten (bidirektional) und anzeigen lassen. es können dp vom typ number - ganzzahlig - sein
                                  z. b
                                  • uhrzeit
                                  • minuten
                                  • themostate-soll werte
                                  • thermometer - gerundete gradzahlen)
                                    usw ...
                                  einstellungen vor script start:
                                  • rot: kannst du so belassen - wenn du ein zweites script davon installierst, muss hier wieder etwas einzigartiges stehen
                                  • grün: anfang der zahlen
                                  • schwarz: die id eines datenpunktes deiner wahl - typ number, ganze zahlen, keine komma-zahlen
                                  • blau: farbe der zahlen
                                  einstellungen nach script start:
                                  • rot: anzahl der zu zeigenden "bubbles"
                                  • blau: hintergrund nicht selktierter "bubbles"
                                  • schwarz: ist für das widget - binding zu diesem dp
                                  • gelb: bei 1 im kreis - bei 2 im block (werden angezeigt in abhängigkeit von widget größe)
                                  • grün: rundung der bubbles - 50 ist rund, 0 ist eckig
                                  • lila: hintergrund selktierter "bubble"
                                  • grau: größe der "bubbles"
                                  • orange: interne größe des widgets - muss abgeglichen sein mit der größe des widgets
                                  script import:
                                  //@liv-in-sky 27.01.2022-16:19
                                  let  dpVISnew="LED1RingNumbers1";                            // Datenpunkte unter javascript.x.Tabellen@Liv.LED1RingVIS
                                  let ansichtFormat=2;                                //Datenpunkt einstellung hat höhere priorität - bitte dort bestimmen und script neustarten
                                  let styleLEDsVER;
                                  let styleLEDsnew;
                                  let scriptLEDnew;
                                  let scriptLEDnew2;
                                  let styleLEDSpan;
                                  let namerStart=6;               //start der zählung
                                  let colorSchrift="white"         // schriftfarbe
                                  let colorSchriftSelected="white"
                                  let dpToConnect="javascript." + instance + ".Tabellen@Liv."+dpVISnew+".ValueSelected";
                                  let DatapointArr=["javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeFormat","javascript." + instance + ".Tabellen@Liv."+dpVISnew+".StandardLedFarbeAus",
                                  "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".DurchmesserGesamt","javascript." + instance + ".Tabellen@Liv."+dpVISnew+".DurchmesserPunkte",
                                  "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".Anzahl","javascript." + instance + ".Tabellen@Liv."+dpVISnew+".EckenRundung"];
                                  let namer=namerStart;
                                     await needDP().then(  function () {
                                  let borderRadius=25
                                    if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".DurchmesserPunkte")) {
                                     let PunkteArr=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".DurchmesserPunkte").val.split(',')
                                     groessePunkteHoehe=Number(PunkteArr[0])
                                     groessePunkteWeite=Number(PunkteArr[1]) }
                                    if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".DurchmesserGesamt")) {
                                     let GeamtArr=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".DurchmesserGesamt").val.split(',')
                                    if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".StandardLedFarbeAus")) {
                                     let ledAusFarbe=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".StandardLedFarbeAus").val;
                                    if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeFormat")) {
                                     let ledAusFarbe=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeFormat").val;
                                     if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".EckenRundung")) {
                                     borderRadius=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".EckenRundung").val;
                                  let rotation="";
                                  // log(ansichtFormat)
                                  //ansichtFormat==2 ?  ansichtFormatVERHOR="flex" :  ansichtFormatVERHOR="inline-block" //inline-block
                                  //ansichtFormat==2 ? rotation="" : rotation=`transform: rotate(180deg); `
                                  //  ansichtFormat==3 ? rotation="" : rotation=`transform: rotate(180deg); `
                                  //log(rotation)
                                         ${rotation}
                                     	.inner${dpVISnew}{
                                     	border-radius: ${borderRadius}%;
                                          margin-right: 5px;
                                         margin-top: 4px;
                                         margin-bottom: 4px;
                                         margin-left: 5px;
                                         color: ${colorSchrift};
                                           display: inline-block;
                                         top: 50%;
                                          vertical-align: middle;
                                          text-align: center;
                                     	}`  //justify-content: center;
                                         // vertical-align: middle;
                                  styleLEDSpan=`.span${dpVISnew} {
        display: block;
        text-align:center;
        margin-top: ${Math.round(groessePunkteHoehe)/5}px;
                                  }`;       /* display: inline-block;
                                         line-height: normal;
                                         text-align: center;
                                         justify-content: center;*/
                                  		position: absolute;
                                     	.inner${dpVISnew}{
                                             z-index:4;
                                     	position: absolute;
                                     	display: flex;
                                         transform: rotate(90deg)
                                     	}`  // in outer:  transform: rotate(-90deg);
                                  scriptLEDnew=`function myKreis${dpVISnew}() {var outer = document.getElementById('outer${dpVISnew}');
                                     	/*console.log(outer${dpVISnew}.children[i].style.left);*/
                                         myKreis${dpVISnew}();
                                          $(".inner${dpVISnew}").click(function() {
                                                      var matches2 = $(this).text();
                                                      console.log(matches2);
                                                      matches2=matches2-${namer};
                                                      vis.setValue('${dpToConnect}',matches2+${namer});
                                                      vis.setValue('javascript.${instance}.Tabellen@Liv.${dpVISnew}.Refresh',true);  });
                                                       console.log("refresh ${dpVISnew}");
                                          $( document ).ready(function() {
                                                    console.log( "dokument ready! von: ${dpVISnew}" );setTimeout( () => {
                                                     myKreis${dpVISnew}();   }, 2000);
                                  scriptLEDnew2=` $(".inner${dpVISnew}").click(function() {
                                                      console.log(matches2-20);
                                     // alleLedsAus(ansichtFormat);
                                      if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".Anzahl"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".Anzahl", 15,{type: "number", name: "Anzahl LEDs", role: "value", read: true, write: true, } ); }
                                     if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".DurchmesserPunkte"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".DurchmesserPunkte", "35,35",{type: "string", name: "Durchmesser Punkte", role: "value", read: true, write: true, } ); }
                                     if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".DurchmesserGesamt"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".DurchmesserGesamt", "200,200",{type: "string", name: "Durchmesser Gesamt", role: "value", read: true, write: true, } ); }
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".AlleLEDs", "#14f54b",{type: "string", name: "Alle LEDs", role: "value", read: true, write: true, } ); }
                                      if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".StandardLedFarbeAus"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".StandardLedFarbeAus", "linear-gradient(90deg, rgba(127,210,79,1) 0%, rgba(119,237,42,1) 35%, rgba(99,177,63,1) 100%)",{type: "string", name: "Standard Led Farbe Aus", role: "value", read: true, write: true, } ); }
                                     if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".alleLEDsAUS"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".alleLEDsAUS", false,{type: "boolean", name: "Alle LEDs AUS", role: "value", read: true, write: true, } ); }
                                     if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzahlLEDsEIN"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".AnzahlLEDsEIN", "4,red",{type: "string", name: "Anzahl LEDs EIN", role: "value", read: true, write: true, } ); }
                                     if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeFormat"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".AnzeigeFormat", 2,{type: "number", name: "Anzeige Format - rund-quer-hoch", role: "value", read: true, write: true, } ); }
                                     if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.Regler"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".AnzeigeRegler.Regler", 3,{type: "number", name: "Anzeige Regler", role: "value", read: true, write: true, } ); }
                                     if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.WidgetReglerAusgabe"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".AnzeigeRegler.WidgetReglerAusgabe", "",{type: "string", name: "Widget VIS Datenpunkt Regler", role: "value", read: true, write: true, } ); }
                                     if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.ReglerPunkteFormat"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".AnzeigeRegler.ReglerPunkteFormat", "rund",{type: "string", name: "Regler Punkte Format -rund -eckig", role: "value", read: true, write: true, } ); }
                                     if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.PunkteGroesse"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".AnzeigeRegler.PunkteGroesse", "19,6",{type: "string", name: "AnzeigeRegler Punkte Groesse", role: "value", read: true, write: true, } ); }
                                      if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.UsageFormat"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".AnzeigeRegler.UsageFormat", "zweispaltig",{type: "string", name: "AnzeigeRegler Usage Format ", role: "value", read: true, write: true, } ); }
                                     if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.PunkteAbstand"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".AnzeigeRegler.PunkteAbstand", "15,15",{type: "string", name: "AnzeigeRegler Punkte Abstand", role: "value", read: true, write: true, } ); }
                                     if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".ValueSelected"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".ValueSelected", 0,{type: "number", name: "ValueSelected", role: "value", read: true, write: true, } ); }
                                     if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".Refresh"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".Refresh", false,{type: "boolean", name: "Refresh", role: "value", read: true, write: true, } ); }
                                     if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".ValueSelectedColor"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".ValueSelectedColor", "linear-gradient(90deg, rgba(96,86,227,1) 0%, rgba(47,128,212,1) 35%, rgba(0,212,255,1) 100%)",{type: "string", name: "ValueSelectedColor", role: "value", read: true, write: true, } ); }
                                      if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".EckenRundung"))) {
                                         await createStateAsync("Tabellen@Liv."+dpVISnew+".EckenRundung", 40,{type: "number", name: "EckenRundung (%)", role: "value", read: true, write: true, } );
                                         allSubs() } else {allSubs()}
                                      function alleLedsAus(ansichtFormat) {
                                         let menge= getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".Anzahl").val;
                                         let ausgabe;
                                                case 1:  ausgabe="<style>"+styleLEDsnew+styleLEDSpan+`</style>`+augabeHilfe+"<script>"+scriptLEDnew+`</script>`; break;
                                                case 2:  ausgabe="<style>"+styleLEDsVER+styleLEDSpan+`</style>`+augabeHilfe; break;
                                                case 3:  ausgabe="<style>"+styleLEDsVER+styleLEDSpan+`</style>`+augabeHilfe; break;
                                        let ausgabe;
                                      function anzahlLEDsEIN(ansichtFormat) {
                                         let mengeArr= getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzahlLEDsEIN").val.split(',');
                                          let ausgabe;
                                          let ausgabe;
                                         let ausgabe;
                                       let menge;
                                         if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".Anzahl")) {
                                          menge=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".Anzahl").val} else {menge=5}
                                       //  let mengeArr= JSON.parse(getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".EinzelneLEDsSteuern").val);
                                         let theNumberSelected=8;
                                         if (existsState(dpToConnect)) {
                                          theNumberSelected=getState(dpToConnect).val}
                                         let newSelected=Number(theNumberSelected)-Number(namer)+1; //log(theNumberSelected+' '+namer+' ' +  newSelected)
                                         namer=namerStart;
                                         namer--;
                                      //   if(theNumberSelected> && theNumberSelected< ) {}
                                       /*  for (let i=0;i<mengeArr.length;i++){
                                         let backigroundi;
                                         if (existsState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".ValueSelectedColor")) {
                                         backigroundi=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".ValueSelectedColor").val;} else {backigroundi="red"}
                                         newColorStyle=newColorStyle+`.inner${(newSelected)}${dpVISnew}{  		color:${colorSchriftSelected};	 background: ${backigroundi}}`
                                         let arrHelper=[];
                                         // namer=20;
                                         let namer2=namer;
                                              namer++
                                              arrHelper.push(`<div class="helpingClass${dpVISnew}${namer} inner${dpVISnew}"><span class="span${dpVISnew}">${namer}</span></div>`)}
                                          //for (let i=0;i<mengeArr.length;i++){
                                             // namer++
                                           //   arrHelper[(mengeArr[i].number)-1]=   `<div class="helpingClass${dpVISnew}${namer} inner${dpVISnew} inner${i+1}${dpVISnew}">${namer2+(mengeArr[i].number)}</div>`}
                                            //   arrHelper[(theNumberSelected)-namer2-1]=   `<div class="helpingClass${dpVISnew}${namer} inner${dpVISnew} inner${i+1}${dpVISnew}">${theNumberSelected}</div>` }
                                           arrHelper[(theNumberSelected)-namer2-1]=   `<div class="helpingClass${dpVISnew}${namer} inner${dpVISnew} inner${newSelected}${dpVISnew}"><span class="span${dpVISnew}">${theNumberSelected}</span></div>`
                                         //  log(styleLEDSpan)
                                         let ausgabe;
                                                case 2:  ausgabe="<style>"+styleLEDsVER+newColorStyle+styleLEDSpan+`</style>`+augabeHilfe+"<script>"+scriptLEDnew2+`</script>`; break;
                                                case 3:  ausgabe="<style>"+styleLEDsVER+newColorStyle+styleLEDSpan+`</style>`+augabeHilfe+"<script>"+scriptLEDnew2+`</script>`; break;
                                  mainLED();
                                  //regler(12)
                                  //einzelneLedsSteuern(ansichtFormat);
                                  function allSubs() {
                                   on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".alleLEDsAUS", val: true}, function (obj) {
                                   setState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".alleLEDsAUS",false)
                                  on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzahlLEDsEIN",  change: "any"}, function (obj) {
                                   anzahlLEDsEIN(ansichtFormat);
                                   mainLED();
                                   on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.Regler",  change: "any"}, function (obj) {
                                   regler(value);
                                    on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".Refresh",  val: true}, function (obj) {
                                     on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".EckenRundung",  change:"ne"}, function (obj) {
                                     on({id: dpToConnect,  change:"ne"}, function (obj) {
                                  on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.ReglerPunkteFormat",  change: "any"}, function (obj) {
                                   regler(getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.Regler").val);
                                  on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.PunkteGroesse",  change: "any"}, function (obj) {
                                   on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.PunkteAbstand",  change: "any"}, function (obj) {
                                    on({id: "javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.UsageFormat",  change: "any"}, function (obj) {
                                   function regler(myStufe){
                                       let punkteGroesseBreite=(getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.PunkteGroesse").val.split(','))[0];
                                       let punkteGroesseHoehe=(getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.PunkteGroesse").val.split(','))[1];
                                       let punkteAbstandHorizontal=(getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.PunkteAbstand").val.split(','))[0];
                                       let punkteAbstandVertikal=(getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.PunkteAbstand").val.split(','))[1];
                                       let reglerPunkteFormat=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.ReglerPunkteFormat").val;
                                       if (reglerPunkteFormat=="eckig") {borderRadiosPunkte = ""} else {borderRadiosPunkte = `border-radius: 50%; `;}
                                       if (reglerPunkteFormat=="rund") borderRadiosPunkte = `border-radius: 50%; `;
                                       let usage=getState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.UsageFormat").val;
                                  let styleRegler=`<style>
                                   display: flex;
                                   padding: 2px;
                                   margin: 2px;
                                   list-style: none;
                                   background: #9B9794;
                                   line-height: 15px;
                                   color: white;
                                   font-weight: bold;
                                   font-size: 3em;
                                   text-align: center;
                                  let myHTMLText="";
                                    myHTMLText="";
                                    myHTMLText="";
                                    //log("akku")
                                  let ausgabe=styleRegler+myHTMLText+`</ul>`;
                                  // log(ausgabe)
                                  setState("javascript." + instance + ".Tabellen@Liv."+dpVISnew+".AnzeigeRegler.WidgetReglerAusgabe",ausgabe);
                                  widget import:
                                  [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"{javascript.0.Tabellen@Liv.LED1RingNumbers1.WidgetAusgabe}"},"style":{"left":"358px","top":"276px","width":"288px","height":"419px","font-size":"16px"},"widgetSet":"basic"}]
