  4. js-controller 3.3 jetzt im STABLE!
344 Beiträge 61 Kommentatoren 138.0k Aufrufe 46 Beobachtet
  • apollon77A apollon77
    @oliverio Exakt. Ein Read only state kann per definition nicht kontrolliert werden weil er nur einen Wert bereitstellt :-) Daher die Meldung.
    Michael SchmittM
    Michael SchmittM
    Michael Schmitt
    was bedeutet diese Meldung im Log ???
    State value to set for "tr-064.0.callmonitor.lastCall.callee" has to be type "number" but received type "string"
    Michael SchmittM mickymM apollon77A 3 Antworten Letzte Antwort
    • Michael SchmittM Michael Schmitt
      Michael SchmittM
      Michael SchmittM
      Michael Schmitt
      bzw
      fritzdect.0	2021-08-05 13:17:21.675	info	(2739) State value to set for "fritzdect.0.DECT_099950270252.endperiod" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.674	info	(2739) State value to set for "fritzdect.0.DECT_099950270252.boostactiveendtime" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.673	info	(2739) State value to set for "fritzdect.0.DECT_099950270252.windowopenactiveendtime" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.579	info	(2739) State value to set for "fritzdect.0.DECT_099950276783.endperiod" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.574	info	(2739) State value to set for "fritzdect.0.DECT_099950276783.boostactiveendtime" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.573	info	(2739) State value to set for "fritzdect.0.DECT_099950276783.windowopenactiveendtime" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.470	info	(2739) State value to set for "fritzdect.0.DECT_099950696353.endperiod" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.468	info	(2739) State value to set for "fritzdect.0.DECT_099950696353.boostactiveendtime" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.467	info	(2739) State value to set for "fritzdect.0.DECT_099950696353.windowopenactiveendtime" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.393	info	(2739) State value to set for "fritzdect.0.DECT_133560170728.endperiod" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.391	info	(2739) State value to set for "fritzdect.0.DECT_133560170728.boostactiveendtime" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.390	info	(2739) State value to set for "fritzdect.0.DECT_133560170728.windowopenactiveendtime" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.300	info	(2739) State value to set for "fritzdect.0.DECT_133560175984.endperiod" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.298	info	(2739) State value to set for "fritzdect.0.DECT_133560175984.boostactiveendtime" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.281	info	(2739) State value to set for "fritzdect.0.DECT_133560175984.windowopenactiveendtime" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.135	info	(2739) State value to set for "fritzdect.0.DECT_133560155800.endperiod" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.126	info	(2739) State value to set for "fritzdect.0.DECT_133560155800.boostactiveendtime" has to be type "number" but received type "string"
      fritzdect.0	2021-08-05 13:17:21.124	info	(2739) State value to set for "fritzdect.0.DECT_133560155800.windowopenactiveendtime" has to be type "number" but received type "string"
        mickymM
        mickymM
        mickym
        @michael-schmitt Ja das hatte ich auch. Ist aber wie in der Anleitung beschrieben.
        Ich habe die Datenpunkte alle gelöscht (des Callmonitors) und dann den Adapter neu gestartet und der Adapter hat die Objekte dann mit dem korrekten Typ angelegt.
        Also zum Beispiel den Callmonitor.
        Es geht Dir halt die Historie verloren. - Vielleicht auch nicht, aber ich habe nicht jeden Datenpunkt geprüft. ;) Also vielleicht hätte es auch getan, wenn ich nur den monierten Punkt gelöscht hätte.
        apollon77A Michael SchmittM 2 Antworten Letzte Antwort
        • mickymM mickym
          apollon77A
          apollon77A
          @mickym sagte in js-controller 3.3 jetzt im STABLE!:
          Nur die Settings für History ... man kann es danach wieder aktivieren. Ja das ist leider blöd, aber aktuell leider so.
          Die Alternative ist per Admin im Export-Modus das Objekt zu editierne und den Datentyp dort anzulassen. Für die mit History-Settings vllt schneller
            @fabian1 Ich kann dich verstehen, aber in meinen/unseren Augen ist es nicht zu früh. Wir haben jetzt ca. 3 Monate an den Adaptern gearbeitet und dabei über 80 Adapter aktualisiert welche Meldungen geworfen haben. Irgendwann ist auch mal ok und es muss weiter gehen.
            Daher gab es auch eine Info-Adapter-Meldung dazu und so weiter.
            Daher, falls noch noch einzelne Adapter übrig sind, bitte melden und Loglevel hochsetzen auf "warn". Das Logging der Meldungen erfolgt nur auf "info". Sollte sich also mit deinem "warn/error per pushover senden" nicht kollidieren.
            EDIT: Für Wled sollte richtung Wochenende ein Update kommen (ml mindestens im Latest)
            Wie gesagt, den normalen User interessiert es ja nicht ob irgend ein Wert mit dem falschenb Datentyp geschrieben wird, sondern nur die Entwickler!
            Jain ... gibt auch genügend Fälle in Visus oder JavaScript wo User-Skripte komische und falsche Dinge tun.
            mickymM
            mickymM
            mickym
            @apollon77 sagte in js-controller 3.3 jetzt im STABLE!:
            Jo so habe ich heute festgestellt, dass mein NodeRed Flow Strings in ein Zahlenobjekt geschrieben hat. Ich finde diese Meldungen auch als "Nicht-Adapter" Entwickler durchaus nützlich. :)
            F 1 Antwort Letzte Antwort
              apollon77A
              apollon77A
              @michael-schmitt Die Meldung bedeutet das das Objekt definiert hat das es eine Nummer/Zahl ist, aber der Adapter hat eine Zeichenkette reingeschrieben ... Das kann ein Fehler sein weil das Objekt falsch ist oder nur ein Fall von -- Adapter schreibt "22" anstelle 22 -- rein
              • mickymM mickym
                Michael SchmittM
                Michael SchmittM
                Michael Schmitt
                sind davon dann meine Blockly script betroffen ?
                  apollon77A
                  apollon77A
                  @michael-schmitt sagte in js-controller 3.3 jetzt im STABLE!:
                  Wenn Sie die richtigen Datentypen in die States schreiben nein ... falls die was falsch machen wirst Du auch Meldungen bekommen.
                    mickymM
                    mickymM
                    mickym
                    Ja ich schrieb ja dass ich zu faul war, jetzt zu warten welche Datenpunkte alle moniert werden, da das ja auch nicht immer gleich funktioniert. Am Besten müsste das ja der Adapterentwickler wissen, aber keine Ahnung ob man als Adapterentwickler auch den Typ eines Objektes nachträglich ändern kann. Ich geh mal davon aus, dass das geht, aber ist halt zusätzliche Arbeit für die Entwickler.
                    • mickymM mickym
                      OliverIOO
                      OliverIOO
                      OliverIO
                      @mickym
                      schön wäre eine musterlösung für eine migration.
                      dann könnte man die genau so in den adapter einbauen
                      und es müsste sich nicht jeder eine eigene Funktion ausdenken.
                      idee für eine Funktionssignatur wäre:
                      function migrateStateType(id,fromType,toType)
                      oder müsste es eigentlich Object heißen?
                      Meine Adapter und Widgets
                      Links im Profil
                      • OliverIOO OliverIO
                        @mickym
                        mickymM
                        mickymM
                        mickym
                        @oliverio So weit ich das System durchschaue - aber da bist Du schlauer, muss man den Typ glaub in dem Objekt ändern.
                        • mickymM mickym
                          paul53P
                          paul53P
                          @mickym sagte: muss man den Typ glaub in dem Objekt ändern.
                          Ja, common.type im Objekt vom Typ "state".
                            mickymM
                            mickymM
                            mickym
                            @paul53 Das Objekt ist doch das, was unter "raw" steht, das war mein Verständnis:
                            EDIT: Ach so ich verstehe was Du meinst vom Typ state (letzte Zeile). ;)
                            • mickymM mickym
                              paul53P
                              paul53P
                              @mickym
                              Genau dort erfolgt die Korrektur.
                              • mickymM
                                mickymM
                                mickym
                                So noch ein Info - zum Info Adapter ;) - da gibt es auch wenn man sonst keine Systemdaten monitoren will noch 5 Objekte, die man auch löscht, damit der Adapter die korrekten Typen wieder anlegt:
                                info.0	2021-08-05 13:29:38.945	info	(5272) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                                info.0	2021-08-05 13:29:38.941	info	(5272) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
                                info.0	2021-08-05 13:29:38.936	info	(5272) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
                                info.0	2021-08-05 13:29:38.886	info	(5272) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
                                info.0	2021-08-05 13:29:38.849	info	(5272) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                                Es langt aber wirklich nur diese 5 Punkte zu löschen!!!
                                Selbst als ich dann das Laden der Systemdaten mal kurzzeitig aktiviert habe, wurden keine weiteren Inkonsistenzen festgestellt.
                                • mickymM mickym
                                  apollon77A
                                  apollon77A
                                  @mickym Bei info hängt es davon ab welche Statistiken man alles so aktiviert hat, können auch mehr sein.
                                    @mickym
                                    apollon77A
                                    apollon77A
                                    @paul53 Vollkommen korrekt
                                      paul53P
                                      paul53P
                                      @apollon77
                                      Wer merged eigentlich meinen PR im Deconz-Adapter?
                                        @apollon77
                                        apollon77A
                                        apollon77A
                                        @paul53 Den kannte ich bisher nicht ... Kläre
                                          mickymM
                                          mickymM
                                          mickym
                                          @apollon77 Noch ein blöde Frage:
                                          Wenn ich selbsterstellte Datenpunkte mit dem Typ: gemischt anlege:
                                          unterbleibt dann die Typprüfung?
                                          Ich könnte es zwar selbst ausprobieren, aber vielleicht wäre das einfach für alle eine wichtige Info.
                                          83.8k
