  4. js-controller 3.3 jetzt im Beta
    6.0k
791 Beiträge 75 Kommentatoren 285.9k Aufrufe 56 Beobachtet
    @thomas-braun sagte in js-controller 3.3 jetzt im Beta:
    which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v12.22.2
    v12.22.2
    6.14.13
    nodejs:
     Installiert:           12.22.2-1nodesource1
     Installationskandidat: 12.22.2-1nodesource1
     Versionstabelle:
    *** 12.22.2-1nodesource1 500
           500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages
        10.24.0~dfsg-1~deb10u1 500
           500 http://deb.debian.org/debian buster/main amd64 Packages
           500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
    @apollon77 da bin ich definitiv der falsche um das zu beantworten zu können
    #602
    @brainbug
    Ja, das sieht gut aus.
      @chaot
      Da kann ich so auch nix herauslesen.
      Schau mal im Installationsverzeichnis, ob da alles 'ordentlich' ist:
      cd /opt/iobroker
      npm list
      ChaotC Offline
      ChaotC Offline
      Chaot
      #603
      @thomas-braun Oh, da kommen am Ende jede Menge Errors
      | | | `-- tslib@1.11.1 deduped
      | | +-- @sentry/tracing@6.9.0
      | | | +-- @sentry/hub@6.9.0 deduped
      | | | +-- @sentry/minimal@6.9.0 deduped
      | | | +-- @sentry/types@6.9.0 deduped
      | | | +-- @sentry/utils@6.9.0 deduped
      | | +-- cookie@0.4.1
      | | +-- https-proxy-agent@5.0.0 deduped
      | | +-- lru_map@0.3.3 deduped
      | +-- extend@3.0.2
      | +-- finalhandler@1.1.2
      | | +-- debug@2.6.9 deduped
      | | +-- encodeurl@1.0.2 deduped
      | | +-- escape-html@1.0.3 deduped
      | | +-- on-finished@2.3.0 deduped
      | | +-- parseurl@1.3.3 deduped
      | | +-- statuses@1.5.0 deduped
      | | `-- unpipe@1.0.0
      | +-- http-mitm-proxy@0.9.0
      | | +-- async@3.2.0
      | | +-- debug@4.3.2
      | | | `-- ms@2.1.2
      | | +-- mkdirp@0.5.5
      | | | `-- minimist@1.2.5 deduped
      | | +-- node-forge@0.10.0 deduped
      | | +-- semaphore@1.1.0
      | | +-- ws@3.3.3
      | | | +-- async-limiter@1.0.1 deduped
      | | | +-- safe-buffer@5.1.2
      | | | `-- ultron@1.1.1 deduped
      | | `-- yargs@16.2.0
      | |   +-- cliui@7.0.4
      | |   | +-- string-width@4.2.2 deduped
      | |   | +-- strip-ansi@6.0.0
      | |   | | `-- ansi-regex@5.0.0
      | |   | `-- wrap-ansi@7.0.0 deduped
      | |   +-- escalade@3.1.1 deduped
      | |   +-- get-caller-file@2.0.5 deduped
      | |   +-- require-directory@2.1.1 deduped
      | |   | +-- emoji-regex@8.0.0 deduped
      | |   | +-- is-fullwidth-code-point@3.0.0
      | |   | `-- strip-ansi@6.0.0 deduped
      | |   +-- y18n@5.0.5 deduped
      | |   `-- yargs-parser@20.2.4 deduped
      | +-- qrcode@1.4.4
      | | +-- buffer@5.6.0
      | | | +-- base64-js@1.3.1 deduped
      | | | `-- ieee754@1.1.13
      | | +-- buffer-alloc@1.2.0
      | | | +-- buffer-alloc-unsafe@1.1.0
      | | | `-- buffer-fill@1.0.0
      | | +-- buffer-from@1.1.1 deduped
      | | +-- dijkstrajs@1.0.2
      | | +-- isarray@2.0.5
      | | +-- pngjs@3.4.0
      | | `-- yargs@13.3.2
      | |   +-- cliui@5.0.0
      | |   | +-- string-width@3.1.0 deduped
      | |   | +-- strip-ansi@5.2.0
      | |   | | `-- ansi-regex@4.1.0
      | |   | `-- wrap-ansi@5.1.0
      | |   |   +-- ansi-styles@3.2.1
      | |   |   | `-- color-convert@1.9.3 deduped
      | |   |   `-- strip-ansi@5.2.0 deduped
      | |   +-- find-up@3.0.0
      | |   | `-- locate-path@3.0.0
      | |   |   +-- p-locate@3.0.0
      | |   |   | `-- p-limit@2.3.0
      | |   |   |   `-- p-try@2.2.0
      | |   |   `-- path-exists@3.0.0
      | |   +-- require-main-filename@2.0.0
      | |   +-- set-blocking@2.0.0 deduped
      | |   | +-- emoji-regex@7.0.3
      | |   | +-- is-fullwidth-code-point@2.0.0
      | |   +-- which-module@2.0.0
      | |   +-- y18n@4.0.3
      | |   `-- yargs-parser@13.1.2
      | |     +-- camelcase@5.3.1
      | |     `-- decamelize@1.2.0 deduped
      | +-- request@2.88.2 deduped
      | +-- serve-static@1.14.1
      | | `-- send@0.17.1 deduped
      | +-- source-map-support@0.5.19 deduped
      | `-- tuyapi@7.2.0
      |   +-- debug@4.1.1
      |   | `-- ms@2.1.2 deduped
      |   +-- p-queue@6.6.1
      |   | +-- eventemitter3@4.0.7
      |   | `-- p-timeout@3.2.0 deduped
      |   +-- p-retry@4.2.0
      |   | +-- @types/retry@0.12.1
      |   | `-- retry@0.12.0
      |   `-- p-timeout@3.2.0
      |     `-- p-finally@1.0.0
      +-- iobroker.tvprogram@1.1.0
      | +-- @iobroker/adapter-core@2.4.0
      | | `-- @types/iobroker@3.2.9
      | |   `-- @types/node@13.11.1 deduped
      | +-- @sentry/browser@6.3.5
      | | +-- @sentry/core@6.3.5
      | | | +-- @sentry/hub@6.3.5
      | | | | +-- @sentry/types@6.3.5 deduped
      | | | | +-- @sentry/utils@6.3.5 deduped
      | | | +-- @sentry/minimal@6.3.5
      | | | | +-- @sentry/hub@6.3.5 deduped
      | `-- parcel-plugin-build-hooks@1.1.0
      |   `-- comment-json@1.1.3
      |     `-- json-parser@1.1.5
      |       `-- esprima@2.7.3
      +-- iobroker.tvspielfilm@2.0.4
      | +-- @iobroker/adapter-core@2.2.1 deduped
      | `-- xml2js@0.4.23 deduped
      +-- iobroker.ubuntu@0.1.0 extraneous
      +-- iobroker.unifi@0.5.10
      | +-- @iobroker/adapter-core@2.5.0
      | | `-- @types/iobroker@3.3.0
      | +-- axios@0.21.1 deduped
      | +-- dateformat@4.5.1 deduped
      | +-- json-logic-js@2.0.1
      | `-- node-unifi@1.4.3
      |   +-- async@3.2.0
      |   `-- request@2.88.2 deduped
      +-- iobroker.upnp@1.0.19
      | +-- ip@1.1.5
      | +-- node-schedule@2.0.0
      | | +-- cron-parser@3.5.0
      | | | +-- is-nan@1.3.2
      | | | | +-- call-bind@1.0.0 deduped
      | | | | `-- define-properties@1.1.3 deduped
      | | | `-- luxon@1.27.0
      | | +-- long-timeout@0.1.1 deduped
      | | `-- sorted-array-functions@1.3.0
      | +-- node-ssdp@4.0.1 deduped
      | +-- parsexmlresponse@0.0.5
      | +-- portfinder@1.0.28
      | | +-- async@2.6.3
      | | | `-- lodash@4.17.15 deduped
      | | +-- debug@3.2.7
      | | | `-- ms@2.1.3
      | | `-- mkdirp@0.5.5
      | +-- xml2js@0.4.23 deduped
      | `-- xmldom@0.6.0
      +-- iobroker.virtualpowermeter@1.4.2
      | | `-- @types/iobroker@3.2.8
      | +-- @types/node-cron@2.0.3
      | | `-- @types/tz-offset@0.0.0
      | +-- cron@1.8.2 deduped
      | +-- node-cron@2.0.3
      | | +-- opencollective-postinstall@2.0.3
      | | `-- tz-offset@0.0.1
      | `-- node-schedule@1.3.2 deduped
      +-- iobroker.vis@1.4.3
      | | `-- @types/iobroker@3.3.1
      | `-- jsonwebtoken@8.5.1 deduped
      +-- iobroker.vis-bars@0.1.4 extraneous
      +-- iobroker.vis-canvas-gauges@0.1.5 extraneous
      +-- iobroker.vis-colorpicker@1.2.0
      | `-- @iobroker/adapter-core@2.2.1 deduped
      +-- iobroker.vis-fancyswitch@1.1.0 extraneous
      +-- iobroker.vis-google-fonts@0.1.0 extraneous
      +-- iobroker.vis-history@1.0.0 extraneous
      +-- iobroker.vis-hqwidgets@1.1.7
      +-- iobroker.vis-inventwo@3.1.2
      | +-- @iobroker/adapter-core@2.5.1
      | | `-- @types/iobroker@3.3.4
      | +-- minimist@1.2.5
      | `-- np@7.5.0
      |   +-- @samverschueren/stream-to-observable@0.3.1
      |   | `-- any-observable@0.3.0
      |   +-- any-observable@0.5.1
      |   +-- async-exit-hook@2.0.1
      |   +-- chalk@4.1.1
      |   | +-- ansi-styles@4.2.1
      |   | | +-- @types/color-name@1.1.1
      |   | | `-- color-convert@2.0.1
      |   | |   `-- color-name@1.1.4
      |   | `-- supports-color@7.2.0
      |   |   `-- has-flag@4.0.0
      |   +-- cosmiconfig@7.0.0
      |   | +-- @types/parse-json@4.0.0
      |   | +-- import-fresh@3.3.0
      |   | | +-- parent-module@1.0.1
      |   | | | `-- callsites@3.1.0 deduped
      |   | | `-- resolve-from@4.0.0
      |   | +-- parse-json@5.2.0
      |   | | +-- @babel/code-frame@7.14.5
      |   | | | `-- @babel/highlight@7.14.5
      |   | | |   +-- @babel/helper-validator-identifier@7.14.8
      |   | | |   +-- chalk@2.4.2
      |   | | |   | +-- escape-string-regexp@1.0.5
      |   | | |   | `-- supports-color@5.5.0
      |   | | |   |   `-- has-flag@3.0.0
      |   | | |   `-- js-tokens@4.0.0
      |   | | +-- error-ex@1.3.2
      |   | | | `-- is-arrayish@0.2.1
      |   | | +-- json-parse-even-better-errors@2.3.1
      |   | | `-- lines-and-columns@1.1.6
      |   | +-- path-type@4.0.0
      |   | `-- yaml@1.10.2
      |   +-- del@6.0.0
      |   | +-- globby@11.0.4
      |   | | +-- array-union@2.1.0
      |   | | +-- dir-glob@3.0.1
      |   | | | `-- path-type@4.0.0
      |   | | +-- fast-glob@3.2.7
      |   | | | +-- @nodelib/fs.stat@2.0.5
      |   | | | +-- @nodelib/fs.walk@1.2.8
      |   | | | | +-- @nodelib/fs.scandir@2.1.5
      |   | | | | | +-- @nodelib/fs.stat@2.0.5 deduped
      |   | | | | | `-- run-parallel@1.2.0
      |   | | | | |   `-- queue-microtask@1.2.3
      |   | | | | `-- fastq@1.11.1
      |   | | | |   `-- reusify@1.0.4
      |   | | | +-- glob-parent@5.1.2
      |   | | | | `-- is-glob@4.0.1 deduped
      |   | | | +-- merge2@1.4.1 deduped
      |   | | | `-- micromatch@4.0.4
      |   | | |   +-- braces@3.0.2
      |   | | |   | `-- fill-range@7.0.1
      |   | | |   |   `-- to-regex-range@5.0.1
      |   | | |   |     `-- is-number@7.0.0
      |   | | |   `-- picomatch@2.3.0
      |   | | +-- ignore@5.1.8
      |   | | +-- merge2@1.4.1
      |   | | `-- slash@3.0.0 deduped
      |   | +-- graceful-fs@4.2.6
      |   | +-- is-glob@4.0.1 deduped
      |   | +-- is-path-cwd@2.2.0
      |   | +-- is-path-inside@3.0.3
      |   | +-- p-map@4.0.0
      |   | | `-- aggregate-error@3.1.0
      |   | |   +-- clean-stack@2.2.0
      |   | |   `-- indent-string@4.0.0 deduped
      |   | +-- rimraf@3.0.2
      |   | | `-- glob@7.1.6 deduped
      |   | `-- slash@3.0.0
      |   +-- escape-goat@3.0.0
      |   +-- escape-string-regexp@4.0.0
      |   +-- execa@5.1.1
      |   | +-- cross-spawn@7.0.3
      |   | | +-- path-key@3.1.1
      |   | | +-- shebang-command@2.0.0
      |   | | | `-- shebang-regex@3.0.0
      |   | | `-- which@2.0.2
      |   | |   `-- isexe@2.0.0 deduped
      |   | +-- get-stream@6.0.1
      |   | +-- human-signals@2.1.0
      |   | +-- is-stream@2.0.0
      |   | +-- merge-stream@2.0.0
      |   | +-- npm-run-path@4.0.1
      |   | | `-- path-key@3.1.1 deduped
      |   | +-- onetime@5.1.2 deduped
      |   | +-- signal-exit@3.0.3
      |   | `-- strip-final-newline@2.0.0
      |   +-- github-url-from-git@1.5.0
      |   +-- has-yarn@2.1.0
      |   +-- hosted-git-info@3.0.8
      |   | `-- lru-cache@6.0.0
      |   |   `-- yallist@4.0.0 deduped
      |   +-- ignore-walk@3.0.3
      |   | `-- minimatch@3.0.4 deduped
      |   +-- import-local@3.0.2
      |   | +-- pkg-dir@4.2.0
      |   | | `-- find-up@4.1.0
      |   | |   +-- locate-path@5.0.0
      |   | |   | `-- p-locate@4.1.0
      |   | |   |   `-- p-limit@2.3.0 deduped
      |   | |   `-- path-exists@4.0.0
      |   | `-- resolve-cwd@3.0.0
      |   |   `-- resolve-from@5.0.0
      |   +-- inquirer@7.3.3
      |   | +-- ansi-escapes@4.3.2
      |   | | `-- type-fest@0.21.3
      |   | +-- chalk@4.1.1 deduped
      |   | +-- cli-cursor@3.1.0
      |   | | `-- restore-cursor@3.1.0
      |   | |   `-- signal-exit@3.0.3 deduped
      |   | +-- cli-width@3.0.0
      |   | +-- external-editor@3.1.0
      |   | | +-- chardet@0.7.0
      |   | | +-- iconv-lite@0.4.24 deduped
      |   | | `-- tmp@0.0.33
      |   | |   `-- os-tmpdir@1.0.2
      |   | +-- figures@3.2.0
      |   | | `-- escape-string-regexp@1.0.5
      |   | +-- lodash@4.17.21
      |   | +-- mute-stream@0.0.8 deduped
      |   | +-- run-async@2.4.1
      |   | +-- rxjs@6.6.7 deduped
      |   | `-- through@2.3.8 deduped
      |   +-- is-installed-globally@0.3.2
      |   | +-- global-dirs@2.1.0
      |   | | `-- ini@1.3.7
      |   | `-- is-path-inside@3.0.3 deduped
      |   +-- is-interactive@1.0.0
      |   +-- is-scoped@2.1.0
      |   | `-- scoped-regex@2.1.0
      |   +-- issue-regex@3.1.0
      |   +-- listr@0.14.3
      |   | +-- @samverschueren/stream-to-observable@0.3.1 deduped
      |   | +-- is-observable@1.1.0
      |   | | `-- symbol-observable@1.2.0
      |   | +-- is-promise@2.2.2
      |   | +-- is-stream@1.1.0 deduped
      |   | +-- listr-silent-renderer@1.1.1
      |   | +-- listr-update-renderer@0.5.0
      |   | | +-- chalk@1.1.3
      |   | | | +-- ansi-styles@2.2.1
      |   | | | +-- has-ansi@2.0.0
      |   | | | | `-- ansi-regex@2.1.1 deduped
      |   | | | +-- strip-ansi@3.0.1 deduped
      |   | | | `-- supports-color@2.0.0
      |   | | +-- cli-truncate@0.2.1
      |   | | | +-- slice-ansi@0.0.4
      |   | | | `-- string-width@1.0.2 deduped
      |   | | +-- elegant-spinner@1.0.1
      |   | | +-- figures@1.7.0
      |   | | | +-- escape-string-regexp@1.0.5 deduped
      |   | | | `-- object-assign@4.1.1 deduped
      |   | | +-- indent-string@3.2.0
      |   | | +-- log-symbols@1.0.2
      |   | | | `-- chalk@1.1.3 deduped
      |   | | +-- log-update@2.3.0
      |   | | | +-- ansi-escapes@3.2.0
      |   | | | +-- cli-cursor@2.1.0
      |   | | | | `-- restore-cursor@2.0.0
      |   | | | |   +-- onetime@2.0.1
      |   | | | |   | `-- mimic-fn@1.2.0
      |   | | | `-- wrap-ansi@3.0.1
      |   | | |   +-- string-width@2.1.1
      |   | | |   | `-- strip-ansi@4.0.0 deduped
      |   | | |     `-- ansi-regex@3.0.0
      |   | | `-- strip-ansi@3.0.1 deduped
      |   | +-- listr-verbose-renderer@0.5.0
      |   | | +-- chalk@2.4.2
      |   | | |   `-- has-flag@3.0.0
      |   | | |   +-- onetime@2.0.1
      |   | | |   | `-- mimic-fn@1.2.0
      |   | | +-- date-fns@1.30.1
      |   | | `-- figures@2.0.0
      |   | |   `-- escape-string-regexp@1.0.5 deduped
      |   | +-- p-map@2.1.0
      |   | `-- rxjs@6.6.7
      |   +-- listr-input@0.2.1
      |   | +-- inquirer@7.3.3
      |   | | +-- ansi-escapes@4.3.2 deduped
      |   | | +-- cli-cursor@3.1.0 deduped
      |   | | +-- cli-width@3.0.0 deduped
      |   | | | +-- chardet@0.7.0
      |   | | | `-- tmp@0.0.33 deduped
      |   | | +-- figures@3.2.0 deduped
      |   | | +-- lodash@4.17.21
      |   | | +-- run-async@2.4.1 deduped
      |   | +-- inquirer-autosubmit-prompt@0.2.0
      |   | | +-- chalk@2.4.2
      |   | | |   `-- has-flag@3.0.0
      |   | | +-- inquirer@6.5.2
      |   | | | +-- chalk@2.4.2 deduped
      |   | | | |   +-- onetime@2.0.1
      |   | | | |   | `-- mimic-fn@1.2.0
      |   | | | +-- cli-width@2.2.1
      |   | | | | +-- chardet@0.7.0
      |   | | | +-- figures@2.0.0
      |   | | | +-- lodash@4.17.15 deduped
      |   | | | +-- mute-stream@0.0.7
      |   | | `-- rxjs@6.6.7
      |   | +-- rxjs@6.6.7
      |   +-- log-symbols@4.1.0
      |   | `-- is-unicode-supported@0.1.0
      |   +-- meow@8.1.2
      |   | +-- @types/minimist@1.2.2
      |   | +-- camelcase-keys@6.2.2
      |   | | +-- camelcase@5.3.1 deduped
      |   | | +-- map-obj@4.2.1
      |   | | `-- quick-lru@4.0.1
      |   | +-- decamelize-keys@1.1.0
      |   | | +-- decamelize@1.2.0 deduped
      |   | | `-- map-obj@1.0.1
      |   | +-- hard-rejection@2.1.0
      |   | +-- minimist-options@4.1.0
      |   | | +-- arrify@1.0.1
      |   | | +-- is-plain-obj@1.1.0
      |   | | `-- kind-of@6.0.3
      |   | +-- normalize-package-data@3.0.2
      |   | | +-- hosted-git-info@4.0.2
      |   | | | `-- lru-cache@6.0.0
      |   | | +-- resolve@1.20.0
      |   | | | +-- is-core-module@2.5.0
      |   | | | | `-- has@1.0.3 deduped
      |   | | | `-- path-parse@1.0.6 deduped
      |   | | +-- semver@7.3.5
      |   | | | `-- lru-cache@6.0.0 deduped
      |   | | `-- validate-npm-package-license@3.0.4
      |   | |   +-- spdx-correct@3.1.0
      |   | |   | +-- spdx-expression-parse@3.0.0 deduped
      |   | |   | `-- spdx-license-ids@3.0.5
      |   | |   `-- spdx-expression-parse@3.0.0
      |   | |     +-- spdx-exceptions@2.2.0
      |   | |     `-- spdx-license-ids@3.0.5 deduped
      |   | +-- read-pkg-up@7.0.1
      |   | | +-- find-up@4.1.0
      |   | | | | `-- p-locate@4.1.0
      |   | | +-- read-pkg@5.2.0
      |   | | | +-- @types/normalize-package-data@2.4.1 deduped
      |   | | | +-- normalize-package-data@2.5.0
      |   | | | | +-- hosted-git-info@2.8.9
      |   | | | | +-- resolve@1.20.0 deduped
      |   | | | | +-- semver@5.7.1
      |   | | | | `-- validate-npm-package-license@3.0.4 deduped
      |   | | | | +-- @babel/code-frame@7.14.5 deduped
      |   | | | | +-- error-ex@1.3.2 deduped
      |   | | | | +-- json-parse-even-better-errors@2.3.1 deduped
      |   | | | | `-- lines-and-columns@1.1.6 deduped
      |   | | | `-- type-fest@0.6.0
      |   | | `-- type-fest@0.8.1
      |   | +-- redent@3.0.0
      |   | | +-- indent-string@4.0.0
      |   | | `-- strip-indent@3.0.0
      |   | |   `-- min-indent@1.0.1
      |   | +-- trim-newlines@3.0.1
      |   | +-- type-fest@0.18.1
      |   +-- minimatch@3.0.4 deduped
      |   +-- new-github-release-url@1.0.0
      |   | `-- type-fest@0.4.1
      |   +-- npm-name@6.0.1
      |   | +-- got@10.7.0
      |   | | +-- @sindresorhus/is@2.1.1
      |   | | +-- @szmarczak/http-timer@4.0.5 deduped
      |   | | +-- @types/cacheable-request@6.0.1 deduped
      |   | | +-- cacheable-lookup@2.0.1
      |   | | | +-- @types/keyv@3.1.1 deduped
      |   | | | `-- keyv@4.0.3 deduped
      |   | | +-- cacheable-request@7.0.1 deduped
      |   | | +-- decompress-response@5.0.0
      |   | | | `-- mimic-response@2.1.0 deduped
      |   | | +-- duplexer3@0.1.4
      |   | | +-- get-stream@5.2.0 deduped
      |   | | +-- lowercase-keys@2.0.0 deduped
      |   | | +-- mimic-response@2.1.0
      |   | | +-- p-cancelable@2.0.0 deduped
      |   | | +-- p-event@4.2.0
      |   | | +-- responselike@2.0.0 deduped
      |   | | +-- to-readable-stream@2.1.0
      |   | | `-- type-fest@0.10.0
      |   | +-- is-scoped@2.1.0 deduped
      |   | +-- is-url-superb@4.0.0
      |   | +-- lodash.zip@4.2.0
      |   | +-- org-regex@1.0.0
      |   | +-- p-map@3.0.0
      |   | | `-- aggregate-error@3.1.0 deduped
      |   | +-- registry-auth-token@4.2.1
      |   | | `-- rc@1.2.8 deduped
      |   | +-- registry-url@5.1.0
      |   | `-- validate-npm-package-name@3.0.0
      |   |   `-- builtins@1.0.3
      |   +-- onetime@5.1.2
      |   | `-- mimic-fn@2.1.0
      |   +-- open@7.4.2
      |   | +-- is-docker@2.2.1
      |   | `-- is-wsl@2.2.0
      |   |   `-- is-docker@2.2.1 deduped
      |   +-- ow@0.21.0
      |   | +-- @sindresorhus/is@4.0.1
      |   | +-- callsites@3.1.0
      |   | +-- dot-prop@6.0.1
      |   | | `-- is-obj@2.0.0
      |   | +-- lodash.isequal@4.5.0
      |   | +-- type-fest@0.20.2
      |   | `-- vali-date@1.0.0
      |   +-- p-memoize@4.0.1
      |   | +-- mem@6.1.1
      |   | | +-- map-age-cleaner@0.1.3
      |   | | | `-- p-defer@1.0.0
      |   | | `-- mimic-fn@3.1.0
      |   | `-- mimic-fn@3.1.0
      |   +-- p-timeout@4.1.0
      |   +-- pkg-dir@5.0.0
      |   | `-- find-up@5.0.0
      |   |   +-- locate-path@6.0.0
      |   |   | `-- p-locate@5.0.0
      |   |   |   `-- p-limit@3.1.0
      |   |   |     `-- yocto-queue@0.1.0
      |   | +-- find-up@4.1.0
      |   | | | `-- p-locate@4.1.0
      |   | +-- read-pkg@5.2.0
      |   | | +-- normalize-package-data@2.5.0 deduped
      |   | | `-- type-fest@0.6.0
      |   | `-- type-fest@0.8.1
      |   +-- rxjs@6.6.7
      |   +-- semver@7.3.5
      |   +-- split@1.0.1 deduped
      |   +-- symbol-observable@3.0.0
      |   +-- terminal-link@2.1.1
      |   | `-- supports-hyperlinks@2.2.0
      |   |   +-- has-flag@4.0.0 deduped
      |   |   `-- supports-color@7.2.0 deduped
      |   `-- update-notifier@5.1.0
      |     +-- boxen@5.0.1
      |     | +-- ansi-align@3.0.0
      |     | | `-- string-width@3.1.0
      |     | +-- camelcase@6.2.0
      |     | +-- cli-boxes@2.2.1
      |     | +-- widest-line@3.1.0
      |     | | `-- string-width@4.2.2
      |     +-- configstore@5.0.1
      |     | +-- dot-prop@5.3.0
      |     | | `-- is-obj@2.0.0 deduped
      |     | +-- graceful-fs@4.2.3 deduped
      |     | +-- make-dir@3.1.0 deduped
      |     | +-- unique-string@2.0.0
      |     | | `-- crypto-random-string@2.0.0
      |     | +-- write-file-atomic@3.0.3
      |     | | +-- imurmurhash@0.1.4
      |     | | +-- is-typedarray@1.0.0 deduped
      |     | | +-- signal-exit@3.0.3 deduped
      |     | | `-- typedarray-to-buffer@3.1.5 deduped
      |     | `-- xdg-basedir@4.0.0 deduped
      |     +-- has-yarn@2.1.0 deduped
      |     +-- import-lazy@2.1.0
      |     +-- is-ci@2.0.0
      |     | `-- ci-info@2.0.0
      |     +-- is-installed-globally@0.4.0
      |     | +-- global-dirs@3.0.0
      |     | | `-- ini@2.0.0
      |     +-- is-npm@5.0.0
      |     +-- is-yarn-global@0.3.0
      |     +-- latest-version@5.1.0
      |     | `-- package-json@6.5.0
      |     |   +-- got@9.6.0
      |     |   | +-- @sindresorhus/is@0.14.0
      |     |   | +-- @szmarczak/http-timer@1.1.2
      |     |   | | `-- defer-to-connect@1.1.3
      |     |   | +-- cacheable-request@6.1.0
      |     |   | | +-- clone-response@1.0.2 deduped
      |     |   | | | `-- pump@3.0.0 deduped
      |     |   | | +-- http-cache-semantics@4.1.0 deduped
      |     |   | | +-- keyv@3.1.0
      |     |   | | | `-- json-buffer@3.0.0
      |     |   | | +-- normalize-url@4.5.0 deduped
      |     |   | | `-- responselike@1.0.2
      |     |   | |   `-- lowercase-keys@1.0.1 deduped
      |     |   | +-- decompress-response@3.3.0
      |     |   | | `-- mimic-response@1.0.1 deduped
      |     |   | +-- duplexer3@0.1.4 deduped
      |     |   | +-- get-stream@4.1.0
      |     |   | +-- lowercase-keys@1.0.1
      |     |   | +-- mimic-response@1.0.1
      |     |   | +-- p-cancelable@1.1.0
      |     |   | +-- to-readable-stream@1.0.0
      |     |   | `-- url-parse-lax@3.0.0
      |     |   |   `-- prepend-http@2.0.0
      |     |   +-- registry-auth-token@4.2.1 deduped
      |     |   +-- registry-url@5.1.0 deduped
      |     |   `-- semver@6.3.0
      |     +-- pupa@2.1.1
      |     | `-- escape-goat@2.1.1
      |     +-- semver@7.3.5
      |     | `-- lru-cache@6.0.0
      |     +-- semver-diff@3.1.1
      |     | `-- semver@6.3.0
      +-- iobroker.vis-jqui-mfd@1.0.12 extraneous
      +-- iobroker.vis-justgage@1.0.2 extraneous
      +-- iobroker.vis-lcars@1.0.4 extraneous
      +-- iobroker.vis-map@1.0.4
      +-- iobroker.vis-metro@1.1.2 extraneous
      +-- iobroker.vis-players@0.1.6
      | `-- @iobroker/adapter-core@1.0.3
      |   `-- @types/iobroker@1.4.13
      +-- iobroker.vis-plumb@1.0.2 extraneous
      +-- iobroker.vis-rgraph@0.0.2 extraneous
      +-- iobroker.vis-timeandweather@1.1.7 extraneous
      +-- iobroker.vis-weather@2.5.3
      +-- iobroker.vodafone-speedtest@0.0.7
      | +-- node-libcurl@2.3.3
      | | +-- env-paths@2.2.0
      | | +-- nan@2.14.1
      | | +-- node-gyp@7.1.0
      | | | +-- env-paths@2.2.0 deduped
      | | | +-- glob@7.1.6
      | | | | +-- fs.realpath@1.0.0
      | | | | +-- inflight@1.0.6
      | | | | | +-- once@1.4.0 deduped
      | | | | | `-- wrappy@1.0.2 deduped
      | | | | +-- inherits@2.0.4 deduped
      | | | | `-- path-is-absolute@1.0.1
      | | | +-- nopt@4.0.3
      | | | | +-- abbrev@1.1.1
      | | | | `-- osenv@0.1.5
      | | | |   +-- os-homedir@1.0.2
      | | | |   `-- os-tmpdir@1.0.2 deduped
      | | | +-- npmlog@4.1.2 deduped
      | | | +-- rimraf@2.7.1 deduped
      | | | +-- semver@7.3.5
      | | | | `-- lru-cache@6.0.0
      | | | +-- tar@6.0.2 deduped
      | | | `-- which@2.0.2
      | | +-- node-pre-gyp@0.15.0
      | | | +-- detect-libc@1.0.3 deduped
      | | | +-- mkdirp@0.5.5
      | | | +-- needle@2.6.0
      | | | | +-- debug@3.2.7
      | | | | | `-- ms@2.1.3
      | | | | `-- sax@1.2.4 deduped
      | | | +-- nopt@4.0.3 deduped
      | | | +-- npm-packlist@1.4.8
      | | | | +-- ignore-walk@3.0.3 deduped
      | | | | +-- npm-bundled@1.1.2
      | | | | | `-- npm-normalize-package-bin@1.0.1 deduped
      | | | +-- rc@1.2.8 deduped
      | | | +-- rimraf@2.7.1
      | | | +-- semver@5.7.0 deduped
      | | | `-- tar@4.4.13
      | | |   +-- chownr@1.1.4 deduped
      | | |   +-- fs-minipass@1.2.7
      | | |   | `-- minipass@2.9.0 deduped
      | | |   +-- minipass@2.9.0
      | | |   | +-- safe-buffer@5.2.0 deduped
      | | |   | `-- yallist@3.1.1 deduped
      | | |   +-- minizlib@1.3.3
      | | |   +-- mkdirp@0.5.5 deduped
      | | |   `-- yallist@3.1.1
      | | +-- rimraf@3.0.2
      | | `-- tslib@2.0.1
      | +-- ping@0.4.1
      | | +-- q@1.5.1 deduped
      | | `-- underscore@1.13.1
      | `-- querystring@0.2.1
      +-- iobroker.wallpanel@0.1.6-0 (github:xXBJXx/ioBroker.wallpanel#30b00ce75531116146f928304b1cfe839c77bbcb)
      | `-- axios@0.21.1 deduped
      +-- iobroker.weatherunderground@3.3.1
      +-- iobroker.web@3.4.5
      | +-- body-parser@1.19.0 deduped
      | +-- connect-flash@0.1.1 deduped
      | +-- cookie-parser@1.4.5 deduped
      | +-- express@4.17.1 deduped
      | +-- express-session@1.17.2
      | | +-- cookie@0.4.1
      | | +-- cookie-signature@1.0.6 deduped
      | | +-- depd@2.0.0
      | | +-- on-headers@1.0.2 deduped
      | | +-- safe-buffer@5.2.1
      | | `-- uid-safe@2.1.5 deduped
      | +-- iobroker.simple-api@2.6.1 deduped
      | +-- iobroker.socketio@3.1.4 deduped
      | +-- mime-types@2.1.31
      | | `-- mime-db@1.48.0
      | +-- passport@0.4.1 deduped
      | +-- passport-local@1.0.0 deduped
      | +-- passport.socketio@3.7.0 deduped
      | +-- socket.io-client@2.3.0
      | | +-- backo2@1.0.2 deduped
      | | +-- base64-arraybuffer@0.1.5
      | | +-- component-bind@1.0.0 deduped
      | | +-- component-emitter@1.2.1
      | | +-- debug@4.1.1
      | | | `-- ms@2.1.2
      | | +-- engine.io-client@3.4.0
      | | | +-- component-emitter@1.2.1 deduped
      | | | +-- component-inherit@0.0.3 deduped
      | | | +-- debug@4.1.1
      | | | | `-- ms@2.1.2
      | | | +-- engine.io-parser@2.2.0 deduped
      | | | +-- has-cors@1.1.0 deduped
      | | | +-- indexof@0.0.1 deduped
      | | | +-- parseqs@0.0.5 deduped
      | | | +-- parseuri@0.0.5 deduped
      | | | +-- ws@6.1.4
      | | | | `-- async-limiter@1.0.1 deduped
      | | | +-- xmlhttprequest-ssl@1.5.5
      | | | `-- yeast@0.1.2 deduped
      | | +-- has-binary2@1.0.3 deduped
      | | +-- has-cors@1.1.0
      | | +-- object-component@0.0.3 deduped
      | | +-- parseqs@0.0.5
      | | | `-- better-assert@1.0.2 deduped
      | | +-- socket.io-parser@3.3.0
      | | | +-- debug@3.1.0
      | | | | `-- ms@2.0.0
      | | | `-- isarray@2.0.1
      | | `-- to-array@0.1.4 deduped
      | `-- xtend@4.0.2
      +-- iobroker.web-speedy@0.2.0
      | `-- speedtest-net@1.6.2
      |   +-- chalk@2.4.2
      |   |   `-- has-flag@3.0.0
      |   +-- draftlog@1.0.12
      |   +-- http-proxy-agent@2.1.0
      |   | +-- agent-base@4.3.0
      |   | | `-- es6-promisify@5.0.0 deduped
      |   | `-- debug@3.1.0
      |   |   `-- ms@2.0.0 deduped
      |   +-- https-proxy-agent@3.0.1
      |   | `-- debug@3.2.6
      |   |   `-- ms@2.1.2
      +-- iobroker.wifilight@1.1.0 extraneous
      +-- iobroker.wifilight-community@0.2.1 extraneous
      +-- iobroker.wled@0.5.6
      | | `-- @types/iobroker@3.2.7
      | +-- axios@0.21.1
      | | `-- follow-redirects@1.11.0 deduped
      | +-- bonjour@3.5.0
      | | +-- array-flatten@2.1.2
      | | +-- deep-equal@1.1.1
      | | | +-- is-arguments@1.1.0
      | | | | `-- call-bind@1.0.0 deduped
      | | | +-- is-date-object@1.0.2
      | | | +-- is-regex@1.0.5
      | | | +-- object-is@1.1.4
      | | | +-- object-keys@1.1.1
      | | | `-- regexp.prototype.flags@1.3.0
      | | |   +-- define-properties@1.1.3 deduped
      | | |   `-- es-abstract@1.17.5 deduped
      | | +-- dns-equal@1.0.0
      | | +-- dns-txt@2.0.2
      | | | `-- buffer-indexof@1.1.1
      | | +-- multicast-dns@6.2.3
      | | | +-- dns-packet@1.3.1 deduped
      | | | `-- thunky@1.1.0
      | | `-- multicast-dns-service-types@1.1.0
      | +-- hex-rgb@4.2.0
      | `-- rgb-hex@3.0.0
      +-- jsonata@1.8.4 extraneous
      +-- node-inspect@2.0.0 extraneous
      +-- node-red@0.20.7 extraneous
      +-- node-red-dashboard@2.15.5 extraneous
      +-- node-telegram-bot-api@0.30.0 extraneous
      +-- open-fin-ts-js-client@2.0.4 extraneous
      +-- portfinder@1.0.20 extraneous
      +-- pushover-notifications@1.2.0 extraneous
      +-- qrcode@1.3.3 extraneous
      +-- semver@5.7.0
      +-- systeminformation@4.14.4 extraneous
      +-- tuyapi@5.1.1 extraneous
      +-- typescript@3.5.3 extraneous
      +-- virtual-device-sdk@1.5.16 extraneous
      +-- virtual-tsc@0.5.0 extraneous
      +-- vm2@3.8.2 extraneous
      +-- wake_on_lan@1.0.0 extraneous
      +-- xmldom@0.1.27 extraneous
      `-- yargs@7.1.0
       +-- camelcase@3.0.0
       +-- cliui@3.2.0
       | +-- string-width@1.0.2 deduped
       | `-- wrap-ansi@2.1.0
       +-- get-caller-file@1.0.3
       +-- os-locale@1.4.0
       | `-- lcid@1.0.0
       |   `-- invert-kv@1.0.0
       +-- read-pkg-up@1.0.1
       | +-- find-up@1.1.2
       | | +-- path-exists@2.1.0
       | | | `-- pinkie-promise@2.0.1 deduped
       | `-- read-pkg@1.1.0
       |   +-- load-json-file@1.1.0
       |   | +-- parse-json@2.2.0
       |   | | `-- error-ex@1.3.2 deduped
       |   | +-- pify@2.3.0
       |   | +-- pinkie-promise@2.0.1 deduped
       |   | `-- strip-bom@2.0.0 deduped
       |   | +-- hosted-git-info@2.8.8
       |   | +-- resolve@1.15.1 deduped
       |   `-- path-type@1.1.0
       |     +-- pify@2.3.0 deduped
       +-- require-main-filename@1.0.1
       | +-- code-point-at@1.1.0
       | +-- is-fullwidth-code-point@1.0.0
       | | `-- number-is-nan@1.0.1
       +-- which-module@1.0.0
       +-- y18n@3.2.1
       `-- yargs-parser@5.0.0
         `-- camelcase@3.0.0 deduped
      npm ERR! extraneous: @apollon/frankjoke-myadapter@1.2.5 /opt/iobroker/node_modules/@apollon/frankjoke-myadapter
      npm ERR! extraneous: @types/request@2.48.2 /opt/iobroker/node_modules/@types/request
      npm ERR! extraneous: fsevents /opt/iobroker/node_modules/fsevents
      npm ERR! error in /opt/iobroker/node_modules/fsevents: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/fsevents/package.json'
      npm ERR! extraneous: alexa-remote2@2.3.7 /opt/iobroker/node_modules/alexa-remote2
      npm ERR! extraneous: anyproxy@4.1.0 /opt/iobroker/node_modules/anyproxy
      npm ERR! extraneous: coffee-compiler@0.3.2 /opt/iobroker/node_modules/coffee-compiler
      npm ERR! extraneous: coffee-script@1.12.7 /opt/iobroker/node_modules/coffee-script
      npm ERR! extraneous: express-fileupload@0.4.1 /opt/iobroker/node_modules/express-fileupload
      npm ERR! extraneous: http-mitm-proxy@0.8.1 /opt/iobroker/node_modules/http-mitm-proxy
      npm ERR! extraneous: iobroker@1.3.1 /opt/iobroker/node_modules/iobroker
      npm ERR! extraneous: iobroker.amazon-dash@1.1.0 /opt/iobroker/node_modules/iobroker.amazon-dash
      npm ERR! extraneous: iobroker.fontui@0.1.0 /opt/iobroker/node_modules/iobroker.fontui
      npm ERR! extraneous: iobroker.fullcalendar@1.1.0 /opt/iobroker/node_modules/iobroker.fullcalendar
      npm ERR! extraneous: iobroker.icons-addictive-flavour-png@0.1.0 /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png
      npm ERR! extraneous: iobroker.icons-fatcow-hosting@0.1.0 /opt/iobroker/node_modules/iobroker.icons-fatcow-hosting
      npm ERR! extraneous: iobroker.icons-icons8@0.0.1 /opt/iobroker/node_modules/iobroker.icons-icons8
      npm ERR! extraneous: iobroker.icons-material-png@0.1.0 /opt/iobroker/node_modules/iobroker.icons-material-png
      npm ERR! extraneous: iobroker.icons-material-svg@0.1.0 /opt/iobroker/node_modules/iobroker.icons-material-svg
      npm ERR! extraneous: iobroker.icons-mfd-png@1.0.2 /opt/iobroker/node_modules/iobroker.icons-mfd-png
      npm ERR! extraneous: iobroker.icons-mfd-svg@1.0.2 /opt/iobroker/node_modules/iobroker.icons-mfd-svg
      npm ERR! extraneous: iobroker.icons-open-icon-library-png@0.1.3 /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png
      npm ERR! extraneous: iobroker.icons-ultimate-png@1.0.1 /opt/iobroker/node_modules/iobroker.icons-ultimate-png
      npm ERR! extraneous: iobroker.js2fs@0.1.5 /opt/iobroker/node_modules/iobroker.js2fs
      npm ERR! extraneous: iobroker.opentherm@0.1.9 /opt/iobroker/node_modules/iobroker.opentherm
      npm ERR! extraneous: iobroker.openuv@0.0.5 /opt/iobroker/node_modules/iobroker.openuv
      npm ERR! extraneous: iobroker.paw@0.3.2 /opt/iobroker/node_modules/iobroker.paw
      npm ERR! extraneous: iobroker.rickshaw@1.0.0 /opt/iobroker/node_modules/iobroker.rickshaw
      npm ERR! extraneous: iobroker.samsung@0.2.9 /opt/iobroker/node_modules/iobroker.samsung
      npm ERR! extraneous: iobroker.ubuntu@0.1.0 /opt/iobroker/node_modules/iobroker.ubuntu
      npm ERR! extraneous: iobroker.vis-bars@0.1.4 /opt/iobroker/node_modules/iobroker.vis-bars
      npm ERR! extraneous: iobroker.vis-canvas-gauges@0.1.5 /opt/iobroker/node_modules/iobroker.vis-canvas-gauges
      npm ERR! extraneous: iobroker.vis-fancyswitch@1.1.0 /opt/iobroker/node_modules/iobroker.vis-fancyswitch
      npm ERR! extraneous: iobroker.vis-google-fonts@0.1.0 /opt/iobroker/node_modules/iobroker.vis-google-fonts
      npm ERR! extraneous: iobroker.vis-history@1.0.0 /opt/iobroker/node_modules/iobroker.vis-history
      npm ERR! extraneous: iobroker.vis-jqui-mfd@1.0.12 /opt/iobroker/node_modules/iobroker.vis-jqui-mfd
      npm ERR! extraneous: iobroker.vis-justgage@1.0.2 /opt/iobroker/node_modules/iobroker.vis-justgage
      npm ERR! extraneous: iobroker.vis-lcars@1.0.4 /opt/iobroker/node_modules/iobroker.vis-lcars
      npm ERR! extraneous: iobroker.vis-metro@1.1.2 /opt/iobroker/node_modules/iobroker.vis-metro
      npm ERR! extraneous: iobroker.vis-plumb@1.0.2 /opt/iobroker/node_modules/iobroker.vis-plumb
      npm ERR! extraneous: iobroker.vis-rgraph@0.0.2 /opt/iobroker/node_modules/iobroker.vis-rgraph
      npm ERR! extraneous: iobroker.vis-timeandweather@1.1.7 /opt/iobroker/node_modules/iobroker.vis-timeandweather
      npm ERR! extraneous: iobroker.wifilight@1.1.0 /opt/iobroker/node_modules/iobroker.wifilight
      npm ERR! extraneous: iobroker.wifilight-community@0.2.1 /opt/iobroker/node_modules/iobroker.wifilight-community
      npm ERR! extraneous: jsonata@1.8.4 /opt/iobroker/node_modules/jsonata
      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
      npm ERR! extraneous: node-red@0.20.7 /opt/iobroker/node_modules/node-red
      npm ERR! extraneous: node-red-dashboard@2.15.5 /opt/iobroker/node_modules/node-red-dashboard
      npm ERR! extraneous: node-telegram-bot-api@0.30.0 /opt/iobroker/node_modules/node-telegram-bot-api
      npm ERR! extraneous: open-fin-ts-js-client@2.0.4 /opt/iobroker/node_modules/open-fin-ts-js-client
      npm ERR! extraneous: portfinder@1.0.20 /opt/iobroker/node_modules/portfinder
      npm ERR! extraneous: pushover-notifications@1.2.0 /opt/iobroker/node_modules/pushover-notifications
      npm ERR! extraneous: qrcode@1.3.3 /opt/iobroker/node_modules/qrcode
      npm ERR! extraneous: systeminformation@4.14.4 /opt/iobroker/node_modules/systeminformation
      npm ERR! extraneous: tuyapi@5.1.1 /opt/iobroker/node_modules/tuyapi
      npm ERR! extraneous: typescript@3.5.3 /opt/iobroker/node_modules/typescript
      npm ERR! extraneous: virtual-device-sdk@1.5.16 /opt/iobroker/node_modules/virtual-device-sdk
      npm ERR! extraneous: virtual-tsc@0.5.0 /opt/iobroker/node_modules/virtual-tsc
      npm ERR! extraneous: vm2@3.8.2 /opt/iobroker/node_modules/vm2
      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
      npm ERR! extraneous: xmldom@0.1.27 /opt/iobroker/node_modules/xmldom
      npm ERR! extraneous: @alcalzone/release-script@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
      npm ERR! extraneous: chai@4.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
      npm ERR! extraneous: del@6.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/del
      npm ERR! extraneous: eslint@7.31.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
      npm ERR! extraneous: gulp@4.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp
      npm ERR! extraneous: gulp-rename@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-rename
      npm ERR! extraneous: gulp-replace@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace
      npm ERR! extraneous: mocha@9.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha
      npm ERR! extraneous: timekeeper@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/timekeeper
      Kann / Muss man das lösen?
      • ChaotC Chaot
        | | +-- cookie@0.4.1
        | +-- extend@3.0.2
        | | `-- unpipe@1.0.0
        | | +-- async@3.2.0
        | | +-- debug@4.3.2
        | | | `-- ms@2.1.2
        | | +-- mkdirp@0.5.5
        | | +-- semaphore@1.1.0
        | | +-- ws@3.3.3
        | | `-- yargs@16.2.0
        | |   +-- cliui@7.0.4
        | +-- qrcode@1.4.4
        | | +-- buffer@5.6.0
        | | | `-- ieee754@1.1.13
        | | +-- isarray@2.0.5
        | | +-- pngjs@3.4.0
        | | `-- yargs@13.3.2
        | |   +-- cliui@5.0.0
        | |   | `-- wrap-ansi@5.1.0
        | |   +-- find-up@3.0.0
        | |   |   +-- p-locate@3.0.0
        | |   |   | `-- p-limit@2.3.0
        | |   |   |   `-- p-try@2.2.0
        | |   +-- y18n@4.0.3
        | |     +-- camelcase@5.3.1
        | `-- tuyapi@7.2.0
        |   +-- debug@4.1.1
        |   +-- p-queue@6.6.1
        |   +-- p-retry@4.2.0
        |   | `-- retry@0.12.0
        |   `-- p-timeout@3.2.0
        |     `-- p-finally@1.0.0
        |       `-- esprima@2.7.3
        |   +-- async@3.2.0
        | +-- ip@1.1.5
        | | | +-- is-nan@1.3.2
        | | | `-- luxon@1.27.0
        | | +-- async@2.6.3
        | | +-- debug@3.2.7
        | | | `-- ms@2.1.3
        | | `-- mkdirp@0.5.5
        | `-- xmldom@0.6.0
        | +-- node-cron@2.0.3
        | | `-- tz-offset@0.0.1
        | +-- minimist@1.2.5
        | `-- np@7.5.0
        |   +-- chalk@4.1.1
        |   |   `-- has-flag@4.0.0
        |   | | |   +-- chalk@2.4.2
        |   | | |   |   `-- has-flag@3.0.0
        |   | | |   `-- js-tokens@4.0.0
        |   | | +-- error-ex@1.3.2
        |   | +-- path-type@4.0.0
        |   | `-- yaml@1.10.2
        |   +-- del@6.0.0
        |   | +-- globby@11.0.4
        |   | | +-- dir-glob@3.0.1
        |   | | | `-- path-type@4.0.0
        |   | | +-- fast-glob@3.2.7
        |   | | | | `-- fastq@1.11.1
        |   | | | |   `-- reusify@1.0.4
        |   | | |   +-- braces@3.0.2
        |   | | |   |     `-- is-number@7.0.0
        |   | | |   `-- picomatch@2.3.0
        |   | | +-- ignore@5.1.8
        |   | | +-- merge2@1.4.1
        |   | +-- p-map@4.0.0
        |   | +-- rimraf@3.0.2
        |   | `-- slash@3.0.0
        |   +-- execa@5.1.1
        |   | | +-- path-key@3.1.1
        |   | | `-- which@2.0.2
        |   | +-- is-stream@2.0.0
        |   +-- has-yarn@2.1.0
        |   | `-- lru-cache@6.0.0
        |   | +-- pkg-dir@4.2.0
        |   | | `-- find-up@4.1.0
        |   | |   | `-- p-locate@4.1.0
        |   +-- inquirer@7.3.3
        |   | +-- cli-width@3.0.0
        |   | | +-- chardet@0.7.0
        |   | | `-- tmp@0.0.33
        |   | |   `-- os-tmpdir@1.0.2
        |   | +-- figures@3.2.0
        |   | +-- lodash@4.17.21
        |   | +-- run-async@2.4.1
        |   | | `-- ini@1.3.7
        |   +-- is-scoped@2.1.0
        |   +-- listr@0.14.3
        |   | | +-- chalk@1.1.3
        |   | | | +-- has-ansi@2.0.0
        |   | | +-- figures@1.7.0
        |   | | | |   +-- onetime@2.0.1
        |   | | | |   | `-- mimic-fn@1.2.0
        |   | | | `-- wrap-ansi@3.0.1
        |   | | +-- chalk@2.4.2
        |   | | |   `-- has-flag@3.0.0
        |   | | |   +-- onetime@2.0.1
        |   | | |   | `-- mimic-fn@1.2.0
        |   | | +-- date-fns@1.30.1
        |   | | `-- figures@2.0.0
        |   | +-- p-map@2.1.0
        |   | `-- rxjs@6.6.7
        |   | +-- inquirer@7.3.3
        |   | | | +-- chardet@0.7.0
        |   | | +-- lodash@4.17.21
        |   | | +-- chalk@2.4.2
        |   | | |   `-- has-flag@3.0.0
        |   | | +-- inquirer@6.5.2
        |   | | | |   +-- onetime@2.0.1
        |   | | | |   | `-- mimic-fn@1.2.0
        |   | | | +-- cli-width@2.2.1
        |   | | | | +-- chardet@0.7.0
        |   | | | +-- figures@2.0.0
        |   | | `-- rxjs@6.6.7
        |   | +-- rxjs@6.6.7
        |   +-- meow@8.1.2
        |   | | +-- map-obj@4.2.1
        |   | | `-- quick-lru@4.0.1
        |   | | `-- map-obj@1.0.1
        |   | | +-- arrify@1.0.1
        |   | | `-- kind-of@6.0.3
        |   | | | `-- lru-cache@6.0.0
        |   | | +-- resolve@1.20.0
        |   | | +-- semver@7.3.5
        |   | | +-- find-up@4.1.0
        |   | | | | `-- p-locate@4.1.0
        |   | | +-- read-pkg@5.2.0
        |   | | | | +-- semver@5.7.1
        |   | | | `-- type-fest@0.6.0
        |   | | `-- type-fest@0.8.1
        |   | +-- redent@3.0.0
        |   | `-- type-fest@0.4.1
        |   +-- npm-name@6.0.1
        |   | +-- got@10.7.0
        |   | | +-- duplexer3@0.1.4
        |   | | +-- p-event@4.2.0
        |   | +-- org-regex@1.0.0
        |   | +-- p-map@3.0.0
        |   |   `-- builtins@1.0.3
        |   +-- onetime@5.1.2
        |   | `-- mimic-fn@2.1.0
        |   +-- open@7.4.2
        |   | +-- is-docker@2.2.1
        |   | `-- is-wsl@2.2.0
        |   +-- ow@0.21.0
        |   | +-- callsites@3.1.0
        |   | +-- dot-prop@6.0.1
        |   | | `-- is-obj@2.0.0
        |   | `-- vali-date@1.0.0
        |   +-- p-memoize@4.0.1
        |   | +-- mem@6.1.1
        |   | | | `-- p-defer@1.0.0
        |   | | `-- mimic-fn@3.1.0
        |   | `-- mimic-fn@3.1.0
        |   +-- p-timeout@4.1.0
        |   +-- pkg-dir@5.0.0
        |   | `-- find-up@5.0.0
        |   |   | `-- p-locate@5.0.0
        |   |   |   `-- p-limit@3.1.0
        |   | +-- find-up@4.1.0
        |   | | | `-- p-locate@4.1.0
        |   | +-- read-pkg@5.2.0
        |   | | `-- type-fest@0.6.0
        |   | `-- type-fest@0.8.1
        |   +-- rxjs@6.6.7
        |   +-- semver@7.3.5
        |     +-- boxen@5.0.1
        |     | +-- camelcase@6.2.0
        |     | +-- cli-boxes@2.2.1
        |     | +-- dot-prop@5.3.0
        |     +-- is-ci@2.0.0
        |     | `-- ci-info@2.0.0
        |     | | `-- ini@2.0.0
        |     +-- is-npm@5.0.0
        |     |   +-- got@9.6.0
        |     |   | | +-- keyv@3.1.0
        |     |   `-- semver@6.3.0
        |     +-- pupa@2.1.1
        |     +-- semver@7.3.5
        |     | `-- lru-cache@6.0.0
        |     | `-- semver@6.3.0
        | | +-- env-paths@2.2.0
        | | +-- nan@2.14.1
        | | +-- node-gyp@7.1.0
        | | | +-- glob@7.1.6
        | | | | +-- inflight@1.0.6
        | | | +-- nopt@4.0.3
        | | | | +-- abbrev@1.1.1
        | | | | `-- osenv@0.1.5
        | | | +-- semver@7.3.5
        | | | | `-- lru-cache@6.0.0
        | | | `-- which@2.0.2
        | | | +-- mkdirp@0.5.5
        | | | +-- needle@2.6.0
        | | | | +-- debug@3.2.7
        | | | | | `-- ms@2.1.3
        | | | +-- rimraf@2.7.1
        | | | `-- tar@4.4.13
        | | |   +-- minipass@2.9.0
        | | |   +-- minizlib@1.3.3
        | | |   `-- yallist@3.1.1
        | | +-- rimraf@3.0.2
        | | `-- tslib@2.0.1
        | +-- ping@0.4.1
        | | +-- q@1.5.1 deduped
        | | +-- cookie@0.4.1
        | | +-- depd@2.0.0
        | | `-- mime-db@1.48.0
        | | +-- debug@4.1.1
        | | | `-- ms@2.1.2
        | | | +-- debug@4.1.1
        | | | | `-- ms@2.1.2
        | | | +-- ws@6.1.4
        | | +-- has-cors@1.1.0
        | | +-- parseqs@0.0.5
        | | | +-- debug@3.1.0
        | | | | `-- ms@2.0.0
        | | | `-- isarray@2.0.1
        | `-- xtend@4.0.2
        |   +-- chalk@2.4.2
        |   |   `-- has-flag@3.0.0
        |   +-- draftlog@1.0.12
        |   | `-- debug@3.1.0
        |   | `-- debug@3.2.6
        |   |   `-- ms@2.1.2
        | +-- axios@0.21.1
        | +-- bonjour@3.5.0
        | | | +-- is-regex@1.0.5
        | | | +-- object-is@1.1.4
        | | +-- dns-equal@1.0.0
        | | +-- dns-txt@2.0.2
        | | | `-- thunky@1.1.0
        | +-- hex-rgb@4.2.0
        | `-- rgb-hex@3.0.0
        +-- semver@5.7.0
        `-- yargs@7.1.0
         +-- camelcase@3.0.0
         +-- cliui@3.2.0
         | `-- wrap-ansi@2.1.0
         +-- os-locale@1.4.0
         | `-- lcid@1.0.0
         |   `-- invert-kv@1.0.0
         | +-- find-up@1.1.2
         | `-- read-pkg@1.1.0
         |   | +-- pify@2.3.0
         |   `-- path-type@1.1.0
         +-- y18n@3.2.1
        #604
        @chaot
        Einen Teil der Meldungen dürfte man per
        cd /opt/iobroker
        npm prune
        aus der Welt bekommen. Was dann noch übrigbleibt muss man sich nochmal anschauen.
          @chaot
          cd /opt/iobroker
          npm prune
          #605
          @thomas-braun ja npm prune oder auch npm dedupe alles schön. Gefahr ist das danach was nicht geht. Von daher ……… man kann das aufräumen … muss man … … …. Das muss jeder selbst entscheiden …
          ChaotC E 2 Antworten Letzte Antwort
          • apollon77A apollon77
            ChaotC Offline
            ChaotC Offline
            Chaot
            #606
            @apollon77 Danke - also lass ich da mal lieber vorerst die Finger weg solange alles geht.
            @Thomas-Braun Danke für die Info. Wie gesagt werde ich das vorerst lassen, aber mir das dann mal im Hinterkopf behalten wenn ich ein frisches Backup und vieeeel Zeit habe.
            • ChaotC Chaot
              #607
              @chaot
              So schaut das übrigens in meinem System aus:
              echad@chet:/opt/iobroker $ npm list
              iobroker.inst@3.0.0 /opt/iobroker
              ├── iobroker.admin@5.1.15
              ├── iobroker.alexa2@3.9.3
              ├── iobroker.backitup@2.1.13
              ├── iobroker.ble@0.12.0
              ├── iobroker.cloud@4.1.0
              ├── iobroker.devices@1.0.9
              ├── iobroker.echarts@1.0.3
              ├── iobroker.firetv@1.0.0
              ├── iobroker.history@1.9.13
              ├── iobroker.info@1.9.6
              ├── iobroker.iot@1.8.22
              ├── iobroker.javascript@5.2.8
              ├── iobroker.js-controller@3.3.15
              ├── iobroker.mihome-vacuum@3.2.2
              ├── iobroker.mihome@1.3.7
              ├── iobroker.miio@0.0.13
              ├── iobroker.nuki-extended@2.3.1
              ├── iobroker.samsung-community@ (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.samsung-community.git#ea8f9f373f38d733e3d1a848e5aecf44e66bf34d)
              ├── iobroker.simple-api@2.6.1
              ├── iobroker.tado@0.3.4
              ├── iobroker.tr-064@4.2.14
              ├── iobroker.tradfri@3.0.1
              ├── iobroker.vofo-speedtest@0.0.8
              ├── iobroker.web@3.4.5
              ├── iobroker.whatsapp-cmb@0.1.6
              └── iobroker.zigbee@1.5.6
              Wesentlich aufgeräumter. Gut, das ist auch mit npm@7, das ist im Grund-Layout schon etwas übersichtlicher. Aber keine Errormeldungen oder extranous Pakete. Und mein System schnurrt. Hab halt ungern Fehlermeldungen irgendwo stehen. Macht die Suche nach 'richtigen' Fehlern nämlich auch nicht übersichtlicher.
                e-s
                #608
                @apollon77
                Kannst du oder irgendwer anders mal nach dem bose soundtouch Adapter schauen?
                Da sind auch noch Fehler vorhanden, welche aber schon gefixt sind.
                Leider ist die 0.9.4 nicht auf npm zu finden, sondern nur die 0.9.3.
                apollon77A 3 Antworten Letzte Antwort
                • E e-s
                  @apollon77
                  #609
                  @e-s Checke ich
                  • E e-s
                    @apollon77
                    #610
                    @e-s Naja und in der 0.9.4 ist nichts von den relevanten DIngen gefixt. denke habe morgen was zum testen. Bitte bei Issue https://github.com/iobroker-community-adapters/ioBroker.bosesoundtouch/issues/51 subscriben. poste dort updates wegen testsupport
                    • E e-s
                      @apollon77
                      #611
                      @e-s GitHub version zum testen da ...
                      E 1 Antwort Letzte Antwort
                        e-s
                        #612
                        @apollon77
                        Dankeschön, habe ich auf github schon gesehen. Komme aber erst morgen zum testen, war heute den ganzen Tag unterwegs.
                        Mal was anderes, bei vielen Adaptern sind die fehler schon beseitigt, häufig müssen aber die dp manuell gelöscht und neu angelegt werden.
                        Ich bezweifle das alle stable User das wirklich hinbekommen, besonders weil dadurch auch gerne alias, Funktionen und Räume verloren gehen könnten.
                        Dadurch werden einige User nicht gerade erfreut sein.
                        Wenn der js Controller doch einen Fehler findet, könnte er ihn dann nicht beseitigen. Mir ist bewusst das dies noch viel schlimmere Fehler hervorbringen könnte, aber wenn dieser wirklich nur mal number zu string oder anders herum ändert, dann sollte doch nicht so viel passieren.
                        Ich habe mir auch schon überlegt das es manchmal manuell mit anpassen leichter wäre als neu erstellen lassen.
                        Diese Anpassungen selbst in jeden Adapter selbst zu packen, ist auch schwer bis jetzt kaum möglich.
                        Da fällt mit gerade ein, der undock frontier Silicon Adapter von @hallo-amt ist auch noch nicht fertig.
                        Glaube pr sind sogar schon vorhanden, aber er hat auch scheinbar keine Zeit zum übernehmen.
                        Also anders gesagt, alles fertig bekommen bei dieser riesigen Anzahl von Adaptern wird verdammt schwer.
                        • E e-s
                          @apollon77
                          #613
                          @e-s Ja ist sehr blöd diesmal aber das müssen wir alle jetzt einmal durch ... Leider. Im Notfall müssen User halt Loglevel hochsetzen ...
                          • Jey CeeJ Offline
                            Jey CeeJ Offline
                            Jey Cee
                            #614
                            @apollon77 @e-s am ende sind das doch bei allen Objekten nur ein begrenzte Anzahl an Problemen.
                            Wenn wir die Sammeln und damit so eine Art fix Script Bauen das die Fehler in den Objekten behebt?
                            Eine sehr einfach Variante wäre das der User die ID des Objekts angibt in Verbindung mit der Fehlermeldung.
                            Wäre immer noch ne Menge Arbeit, aber die User hätten einen Weg der nicht gleich das ganze System durcheinander bringt.
                            Persönlicher Support
                            Spenden -> paypal.me/J3YC33
                            • Jey CeeJ Jey Cee
                              #615
                              @jey-cee interessante Idee. Müsste eher generisch sein und dann mit regex arbeiten.
                              Vllt am besten sogar vllt relevante logzeilen als Input dann parsen der Meldung und Objekte fixen. Die Fehlermeldungen die relevant sind sollten überschaubar sein.
                              Damit kriegt man auf jeden Fall die einfachen Datentypenthemen hin. Object/stringify Themen und ggf Objekte die der dev am Ende aus Mixed deklariert hat muss man dann doch löschen und neu anlegen lassen. Sind dann aber weniger.
                              Wer mag sich der Idee mal annehmen?
                              • L Offline
                                LoxDUS
                                #616
                                Hallo Zusammen,
                                Mein Log (oder jetzt Protokoll) listet alle 2 Minuten folgende Warnung auf:
                                State "info.0.sysinfo.cpu.currentSpeed.coresSpeed" has no existing object, this might lead to an error in future versions
                                State "info.0.sysinfo.cpu.currentLoad.currentLoad_hist" has no existing object, this might lead to an error in future versions
                                Kann es sein das da eine "groß-Kleinschreibung verwechselt wurde in "coresSpeed" und "currentLoad"? Kann ich das irgendwie selber fixen?
                                • L LoxDUS
                                  Hallo Zusammen,
                                  #617
                                  @loxdus Bitte die gemedleten Objekte im Admin löschen, Info Adater neu starten. sollte dann weg sein ... bzw info Adapter sicherstellen das letzte Version installiert ist!
                                  L 1 Antwort Letzte Antwort
                                    LoxDUS
                                    #618
                                    @apollon77 Das Problem ist doch das es die nicht gibt. Oder ist das nicht "Case" sensitive? Es gibt nur mit kleinen Buchstaben:
                                    Habe die letzte Version installiert:
                                    • L LoxDUS
                                      #619
                                      @loxdus GutHub Issue bei info Bitte
                                      L LatziL 2 Antworten Letzte Antwort
                                        LoxDUS
                                        #620
                                        @apollon77 Done #336
                                          LatziL Online
                                          LatziL Online
                                          Latzi
                                          #621
                                          @apollon77
                                          issue #336 wurde geschlossen, jedoch in 1.9.9 besteht die Meldung immer noch:
                                          info.0	2021-09-03 18:12:15.028	warn	(2318) State "info.0.sysinfo.cpu.currentSpeed.coresspeed" has no existing object, this might lead to an error in future versions
                                          info.0	2021-09-03 18:12:14.917	warn	(2318) State "info.0.sysinfo.cpu.currentLoad.currentload_hist" has no existing object, this might lead to an error in future versions
