  4. js-controller 3.3 jetzt im Beta
    6.0k
791 Beiträge 75 Kommentatoren 286.0k Aufrufe 56 Beobachtet
  • ChaotC Chaot
    @thomas-braun Oh, da kommen am Ende jede Menge Errors
    | | | `-- tslib@1.11.1 deduped
    | | +-- @sentry/tracing@6.9.0
    | | | +-- @sentry/hub@6.9.0 deduped
    | | | +-- @sentry/minimal@6.9.0 deduped
    | | | +-- @sentry/types@6.9.0 deduped
    | | | +-- @sentry/utils@6.9.0 deduped
    | | +-- cookie@0.4.1
    | | +-- https-proxy-agent@5.0.0 deduped
    | | +-- lru_map@0.3.3 deduped
    | +-- extend@3.0.2
    | +-- finalhandler@1.1.2
    | | +-- debug@2.6.9 deduped
    | | +-- encodeurl@1.0.2 deduped
    | | +-- escape-html@1.0.3 deduped
    | | +-- on-finished@2.3.0 deduped
    | | +-- parseurl@1.3.3 deduped
    | | +-- statuses@1.5.0 deduped
    | | `-- unpipe@1.0.0
    | +-- http-mitm-proxy@0.9.0
    | | +-- async@3.2.0
    | | +-- debug@4.3.2
    | | | `-- ms@2.1.2
    | | +-- mkdirp@0.5.5
    | | | `-- minimist@1.2.5 deduped
    | | +-- node-forge@0.10.0 deduped
    | | +-- semaphore@1.1.0
    | | +-- ws@3.3.3
    | | | +-- async-limiter@1.0.1 deduped
    | | | +-- safe-buffer@5.1.2
    | | | `-- ultron@1.1.1 deduped
    | | `-- yargs@16.2.0
    | |   +-- cliui@7.0.4
    | |   | +-- string-width@4.2.2 deduped
    | |   | +-- strip-ansi@6.0.0
    | |   | | `-- ansi-regex@5.0.0
    | |   | `-- wrap-ansi@7.0.0 deduped
    | |   +-- escalade@3.1.1 deduped
    | |   +-- get-caller-file@2.0.5 deduped
    | |   +-- require-directory@2.1.1 deduped
    | |   | +-- emoji-regex@8.0.0 deduped
    | |   | +-- is-fullwidth-code-point@3.0.0
    | |   | `-- strip-ansi@6.0.0 deduped
    | |   +-- y18n@5.0.5 deduped
    | |   `-- yargs-parser@20.2.4 deduped
    | +-- qrcode@1.4.4
    | | +-- buffer@5.6.0
    | | | +-- base64-js@1.3.1 deduped
    | | | `-- ieee754@1.1.13
    | | +-- buffer-alloc@1.2.0
    | | | +-- buffer-alloc-unsafe@1.1.0
    | | | `-- buffer-fill@1.0.0
    | | +-- buffer-from@1.1.1 deduped
    | | +-- dijkstrajs@1.0.2
    | | +-- isarray@2.0.5
    | | +-- pngjs@3.4.0
    | | `-- yargs@13.3.2
    | |   +-- cliui@5.0.0
    | |   | +-- string-width@3.1.0 deduped
    | |   | +-- strip-ansi@5.2.0
    | |   | | `-- ansi-regex@4.1.0
    | |   | `-- wrap-ansi@5.1.0
    | |   |   +-- ansi-styles@3.2.1
    | |   |   | `-- color-convert@1.9.3 deduped
    | |   |   `-- strip-ansi@5.2.0 deduped
    | |   +-- find-up@3.0.0
    | |   | `-- locate-path@3.0.0
    | |   |   +-- p-locate@3.0.0
    | |   |   | `-- p-limit@2.3.0
    | |   |   |   `-- p-try@2.2.0
    | |   |   `-- path-exists@3.0.0
    | |   +-- require-main-filename@2.0.0
    | |   +-- set-blocking@2.0.0 deduped
    | |   | +-- emoji-regex@7.0.3
    | |   | +-- is-fullwidth-code-point@2.0.0
    | |   +-- which-module@2.0.0
    | |   +-- y18n@4.0.3
    | |   `-- yargs-parser@13.1.2
    | |     +-- camelcase@5.3.1
    | |     `-- decamelize@1.2.0 deduped
    | +-- request@2.88.2 deduped
    | +-- serve-static@1.14.1
    | | `-- send@0.17.1 deduped
    | +-- source-map-support@0.5.19 deduped
    | `-- tuyapi@7.2.0
    |   +-- debug@4.1.1
    |   | `-- ms@2.1.2 deduped
    |   +-- p-queue@6.6.1
    |   | +-- eventemitter3@4.0.7
    |   | `-- p-timeout@3.2.0 deduped
    |   +-- p-retry@4.2.0
    |   | +-- @types/retry@0.12.1
    |   | `-- retry@0.12.0
    |   `-- p-timeout@3.2.0
    |     `-- p-finally@1.0.0
    +-- iobroker.tvprogram@1.1.0
    | +-- @iobroker/adapter-core@2.4.0
    | | `-- @types/iobroker@3.2.9
    | |   `-- @types/node@13.11.1 deduped
    | +-- @sentry/browser@6.3.5
    | | +-- @sentry/core@6.3.5
    | | | +-- @sentry/hub@6.3.5
    | | | | +-- @sentry/types@6.3.5 deduped
    | | | | +-- @sentry/utils@6.3.5 deduped
    | | | +-- @sentry/minimal@6.3.5
    | | | | +-- @sentry/hub@6.3.5 deduped
    | `-- parcel-plugin-build-hooks@1.1.0
    |   `-- comment-json@1.1.3
    |     `-- json-parser@1.1.5
    |       `-- esprima@2.7.3
    +-- iobroker.tvspielfilm@2.0.4
    | +-- @iobroker/adapter-core@2.2.1 deduped
    | `-- xml2js@0.4.23 deduped
    +-- iobroker.ubuntu@0.1.0 extraneous
    +-- iobroker.unifi@0.5.10
    | +-- @iobroker/adapter-core@2.5.0
    | | `-- @types/iobroker@3.3.0
    | +-- axios@0.21.1 deduped
    | +-- dateformat@4.5.1 deduped
    | +-- json-logic-js@2.0.1
    | `-- node-unifi@1.4.3
    |   +-- async@3.2.0
    |   `-- request@2.88.2 deduped
    +-- iobroker.upnp@1.0.19
    | +-- ip@1.1.5
    | +-- node-schedule@2.0.0
    | | +-- cron-parser@3.5.0
    | | | +-- is-nan@1.3.2
    | | | | +-- call-bind@1.0.0 deduped
    | | | | `-- define-properties@1.1.3 deduped
    | | | `-- luxon@1.27.0
    | | +-- long-timeout@0.1.1 deduped
    | | `-- sorted-array-functions@1.3.0
    | +-- node-ssdp@4.0.1 deduped
    | +-- parsexmlresponse@0.0.5
    | +-- portfinder@1.0.28
    | | +-- async@2.6.3
    | | | `-- lodash@4.17.15 deduped
    | | +-- debug@3.2.7
    | | | `-- ms@2.1.3
    | | `-- mkdirp@0.5.5
    | +-- xml2js@0.4.23 deduped
    | `-- xmldom@0.6.0
    +-- iobroker.virtualpowermeter@1.4.2
    | | `-- @types/iobroker@3.2.8
    | +-- @types/node-cron@2.0.3
    | | `-- @types/tz-offset@0.0.0
    | +-- cron@1.8.2 deduped
    | +-- node-cron@2.0.3
    | | +-- opencollective-postinstall@2.0.3
    | | `-- tz-offset@0.0.1
    | `-- node-schedule@1.3.2 deduped
    +-- iobroker.vis@1.4.3
    | | `-- @types/iobroker@3.3.1
    | `-- jsonwebtoken@8.5.1 deduped
    +-- iobroker.vis-bars@0.1.4 extraneous
    +-- iobroker.vis-canvas-gauges@0.1.5 extraneous
    +-- iobroker.vis-colorpicker@1.2.0
    | `-- @iobroker/adapter-core@2.2.1 deduped
    +-- iobroker.vis-fancyswitch@1.1.0 extraneous
    +-- iobroker.vis-google-fonts@0.1.0 extraneous
    +-- iobroker.vis-history@1.0.0 extraneous
    +-- iobroker.vis-hqwidgets@1.1.7
    +-- iobroker.vis-inventwo@3.1.2
    | +-- @iobroker/adapter-core@2.5.1
    | | `-- @types/iobroker@3.3.4
    | +-- minimist@1.2.5
    | `-- np@7.5.0
    |   +-- @samverschueren/stream-to-observable@0.3.1
    |   | `-- any-observable@0.3.0
    |   +-- any-observable@0.5.1
    |   +-- async-exit-hook@2.0.1
    |   +-- chalk@4.1.1
    |   | +-- ansi-styles@4.2.1
    |   | | +-- @types/color-name@1.1.1
    |   | | `-- color-convert@2.0.1
    |   | |   `-- color-name@1.1.4
    |   | `-- supports-color@7.2.0
    |   |   `-- has-flag@4.0.0
    |   +-- cosmiconfig@7.0.0
    |   | +-- @types/parse-json@4.0.0
    |   | +-- import-fresh@3.3.0
    |   | | +-- parent-module@1.0.1
    |   | | | `-- callsites@3.1.0 deduped
    |   | | `-- resolve-from@4.0.0
    |   | +-- parse-json@5.2.0
    |   | | +-- @babel/code-frame@7.14.5
    |   | | | `-- @babel/highlight@7.14.5
    |   | | |   +-- @babel/helper-validator-identifier@7.14.8
    |   | | |   +-- chalk@2.4.2
    |   | | |   | +-- escape-string-regexp@1.0.5
    |   | | |   | `-- supports-color@5.5.0
    |   | | |   |   `-- has-flag@3.0.0
    |   | | |   `-- js-tokens@4.0.0
    |   | | +-- error-ex@1.3.2
    |   | | | `-- is-arrayish@0.2.1
    |   | | +-- json-parse-even-better-errors@2.3.1
    |   | | `-- lines-and-columns@1.1.6
    |   | +-- path-type@4.0.0
    |   | `-- yaml@1.10.2
    |   +-- del@6.0.0
    |   | +-- globby@11.0.4
    |   | | +-- array-union@2.1.0
    |   | | +-- dir-glob@3.0.1
    |   | | | `-- path-type@4.0.0
    |   | | +-- fast-glob@3.2.7
    |   | | | +-- @nodelib/fs.stat@2.0.5
    |   | | | +-- @nodelib/fs.walk@1.2.8
    |   | | | | +-- @nodelib/fs.scandir@2.1.5
    |   | | | | | +-- @nodelib/fs.stat@2.0.5 deduped
    |   | | | | | `-- run-parallel@1.2.0
    |   | | | | |   `-- queue-microtask@1.2.3
    |   | | | | `-- fastq@1.11.1
    |   | | | |   `-- reusify@1.0.4
    |   | | | +-- glob-parent@5.1.2
    |   | | | | `-- is-glob@4.0.1 deduped
    |   | | | +-- merge2@1.4.1 deduped
    |   | | | `-- micromatch@4.0.4
    |   | | |   +-- braces@3.0.2
    |   | | |   | `-- fill-range@7.0.1
    |   | | |   |   `-- to-regex-range@5.0.1
    |   | | |   |     `-- is-number@7.0.0
    |   | | |   `-- picomatch@2.3.0
    |   | | +-- ignore@5.1.8
    |   | | +-- merge2@1.4.1
    |   | | `-- slash@3.0.0 deduped
    |   | +-- graceful-fs@4.2.6
    |   | +-- is-glob@4.0.1 deduped
    |   | +-- is-path-cwd@2.2.0
    |   | +-- is-path-inside@3.0.3
    |   | +-- p-map@4.0.0
    |   | | `-- aggregate-error@3.1.0
    |   | |   +-- clean-stack@2.2.0
    |   | |   `-- indent-string@4.0.0 deduped
    |   | +-- rimraf@3.0.2
    |   | | `-- glob@7.1.6 deduped
    |   | `-- slash@3.0.0
    |   +-- escape-goat@3.0.0
    |   +-- escape-string-regexp@4.0.0
    |   +-- execa@5.1.1
    |   | +-- cross-spawn@7.0.3
    |   | | +-- path-key@3.1.1
    |   | | +-- shebang-command@2.0.0
    |   | | | `-- shebang-regex@3.0.0
    |   | | `-- which@2.0.2
    |   | |   `-- isexe@2.0.0 deduped
    |   | +-- get-stream@6.0.1
    |   | +-- human-signals@2.1.0
    |   | +-- is-stream@2.0.0
    |   | +-- merge-stream@2.0.0
    |   | +-- npm-run-path@4.0.1
    |   | | `-- path-key@3.1.1 deduped
    |   | +-- onetime@5.1.2 deduped
    |   | +-- signal-exit@3.0.3
    |   | `-- strip-final-newline@2.0.0
    |   +-- github-url-from-git@1.5.0
    |   +-- has-yarn@2.1.0
    |   +-- hosted-git-info@3.0.8
    |   | `-- lru-cache@6.0.0
    |   |   `-- yallist@4.0.0 deduped
    |   +-- ignore-walk@3.0.3
    |   | `-- minimatch@3.0.4 deduped
    |   +-- import-local@3.0.2
    |   | +-- pkg-dir@4.2.0
    |   | | `-- find-up@4.1.0
    |   | |   +-- locate-path@5.0.0
    |   | |   | `-- p-locate@4.1.0
    |   | |   |   `-- p-limit@2.3.0 deduped
    |   | |   `-- path-exists@4.0.0
    |   | `-- resolve-cwd@3.0.0
    |   |   `-- resolve-from@5.0.0
    |   +-- inquirer@7.3.3
    |   | +-- ansi-escapes@4.3.2
    |   | | `-- type-fest@0.21.3
    |   | +-- chalk@4.1.1 deduped
    |   | +-- cli-cursor@3.1.0
    |   | | `-- restore-cursor@3.1.0
    |   | |   `-- signal-exit@3.0.3 deduped
    |   | +-- cli-width@3.0.0
    |   | +-- external-editor@3.1.0
    |   | | +-- chardet@0.7.0
    |   | | +-- iconv-lite@0.4.24 deduped
    |   | | `-- tmp@0.0.33
    |   | |   `-- os-tmpdir@1.0.2
    |   | +-- figures@3.2.0
    |   | | `-- escape-string-regexp@1.0.5
    |   | +-- lodash@4.17.21
    |   | +-- mute-stream@0.0.8 deduped
    |   | +-- run-async@2.4.1
    |   | +-- rxjs@6.6.7 deduped
    |   | `-- through@2.3.8 deduped
    |   +-- is-installed-globally@0.3.2
    |   | +-- global-dirs@2.1.0
    |   | | `-- ini@1.3.7
    |   | `-- is-path-inside@3.0.3 deduped
    |   +-- is-interactive@1.0.0
    |   +-- is-scoped@2.1.0
    |   | `-- scoped-regex@2.1.0
    |   +-- issue-regex@3.1.0
    |   +-- listr@0.14.3
    |   | +-- @samverschueren/stream-to-observable@0.3.1 deduped
    |   | +-- is-observable@1.1.0
    |   | | `-- symbol-observable@1.2.0
    |   | +-- is-promise@2.2.2
    |   | +-- is-stream@1.1.0 deduped
    |   | +-- listr-silent-renderer@1.1.1
    |   | +-- listr-update-renderer@0.5.0
    |   | | +-- chalk@1.1.3
    |   | | | +-- ansi-styles@2.2.1
    |   | | | +-- has-ansi@2.0.0
    |   | | | | `-- ansi-regex@2.1.1 deduped
    |   | | | +-- strip-ansi@3.0.1 deduped
    |   | | | `-- supports-color@2.0.0
    |   | | +-- cli-truncate@0.2.1
    |   | | | +-- slice-ansi@0.0.4
    |   | | | `-- string-width@1.0.2 deduped
    |   | | +-- elegant-spinner@1.0.1
    |   | | +-- figures@1.7.0
    |   | | | +-- escape-string-regexp@1.0.5 deduped
    |   | | | `-- object-assign@4.1.1 deduped
    |   | | +-- indent-string@3.2.0
    |   | | +-- log-symbols@1.0.2
    |   | | | `-- chalk@1.1.3 deduped
    |   | | +-- log-update@2.3.0
    |   | | | +-- ansi-escapes@3.2.0
    |   | | | +-- cli-cursor@2.1.0
    |   | | | | `-- restore-cursor@2.0.0
    |   | | | |   +-- onetime@2.0.1
    |   | | | |   | `-- mimic-fn@1.2.0
    |   | | | `-- wrap-ansi@3.0.1
    |   | | |   +-- string-width@2.1.1
    |   | | |   | `-- strip-ansi@4.0.0 deduped
    |   | | |     `-- ansi-regex@3.0.0
    |   | | `-- strip-ansi@3.0.1 deduped
    |   | +-- listr-verbose-renderer@0.5.0
    |   | | +-- chalk@2.4.2
    |   | | |   `-- has-flag@3.0.0
    |   | | |   +-- onetime@2.0.1
    |   | | |   | `-- mimic-fn@1.2.0
    |   | | +-- date-fns@1.30.1
    |   | | `-- figures@2.0.0
    |   | |   `-- escape-string-regexp@1.0.5 deduped
    |   | +-- p-map@2.1.0
    |   | `-- rxjs@6.6.7
    |   +-- listr-input@0.2.1
    |   | +-- inquirer@7.3.3
    |   | | +-- ansi-escapes@4.3.2 deduped
    |   | | +-- cli-cursor@3.1.0 deduped
    |   | | +-- cli-width@3.0.0 deduped
    |   | | | +-- chardet@0.7.0
    |   | | | `-- tmp@0.0.33 deduped
    |   | | +-- figures@3.2.0 deduped
    |   | | +-- lodash@4.17.21
    |   | | +-- run-async@2.4.1 deduped
    |   | +-- inquirer-autosubmit-prompt@0.2.0
    |   | | +-- chalk@2.4.2
    |   | | |   `-- has-flag@3.0.0
    |   | | +-- inquirer@6.5.2
    |   | | | +-- chalk@2.4.2 deduped
    |   | | | |   +-- onetime@2.0.1
    |   | | | |   | `-- mimic-fn@1.2.0
    |   | | | +-- cli-width@2.2.1
    |   | | | | +-- chardet@0.7.0
    |   | | | +-- figures@2.0.0
    |   | | | +-- lodash@4.17.15 deduped
    |   | | | +-- mute-stream@0.0.7
    |   | | `-- rxjs@6.6.7
    |   | +-- rxjs@6.6.7
    |   +-- log-symbols@4.1.0
    |   | `-- is-unicode-supported@0.1.0
    |   +-- meow@8.1.2
    |   | +-- @types/minimist@1.2.2
    |   | +-- camelcase-keys@6.2.2
    |   | | +-- camelcase@5.3.1 deduped
    |   | | +-- map-obj@4.2.1
    |   | | `-- quick-lru@4.0.1
    |   | +-- decamelize-keys@1.1.0
    |   | | +-- decamelize@1.2.0 deduped
    |   | | `-- map-obj@1.0.1
    |   | +-- hard-rejection@2.1.0
    |   | +-- minimist-options@4.1.0
    |   | | +-- arrify@1.0.1
    |   | | +-- is-plain-obj@1.1.0
    |   | | `-- kind-of@6.0.3
    |   | +-- normalize-package-data@3.0.2
    |   | | +-- hosted-git-info@4.0.2
    |   | | | `-- lru-cache@6.0.0
    |   | | +-- resolve@1.20.0
    |   | | | +-- is-core-module@2.5.0
    |   | | | | `-- has@1.0.3 deduped
    |   | | | `-- path-parse@1.0.6 deduped
    |   | | +-- semver@7.3.5
    |   | | | `-- lru-cache@6.0.0 deduped
    |   | | `-- validate-npm-package-license@3.0.4
    |   | |   +-- spdx-correct@3.1.0
    |   | |   | +-- spdx-expression-parse@3.0.0 deduped
    |   | |   | `-- spdx-license-ids@3.0.5
    |   | |   `-- spdx-expression-parse@3.0.0
    |   | |     +-- spdx-exceptions@2.2.0
    |   | |     `-- spdx-license-ids@3.0.5 deduped
    |   | +-- read-pkg-up@7.0.1
    |   | | +-- find-up@4.1.0
    |   | | | | `-- p-locate@4.1.0
    |   | | +-- read-pkg@5.2.0
    |   | | | +-- @types/normalize-package-data@2.4.1 deduped
    |   | | | +-- normalize-package-data@2.5.0
    |   | | | | +-- hosted-git-info@2.8.9
    |   | | | | +-- resolve@1.20.0 deduped
    |   | | | | +-- semver@5.7.1
    |   | | | | `-- validate-npm-package-license@3.0.4 deduped
    |   | | | | +-- @babel/code-frame@7.14.5 deduped
    |   | | | | +-- error-ex@1.3.2 deduped
    |   | | | | +-- json-parse-even-better-errors@2.3.1 deduped
    |   | | | | `-- lines-and-columns@1.1.6 deduped
    |   | | | `-- type-fest@0.6.0
    |   | | `-- type-fest@0.8.1
    |   | +-- redent@3.0.0
    |   | | +-- indent-string@4.0.0
    |   | | `-- strip-indent@3.0.0
    |   | |   `-- min-indent@1.0.1
    |   | +-- trim-newlines@3.0.1
    |   | +-- type-fest@0.18.1
    |   +-- minimatch@3.0.4 deduped
    |   +-- new-github-release-url@1.0.0
    |   | `-- type-fest@0.4.1
    |   +-- npm-name@6.0.1
    |   | +-- got@10.7.0
    |   | | +-- @sindresorhus/is@2.1.1
    |   | | +-- @szmarczak/http-timer@4.0.5 deduped
    |   | | +-- @types/cacheable-request@6.0.1 deduped
    |   | | +-- cacheable-lookup@2.0.1
    |   | | | +-- @types/keyv@3.1.1 deduped
    |   | | | `-- keyv@4.0.3 deduped
    |   | | +-- cacheable-request@7.0.1 deduped
    |   | | +-- decompress-response@5.0.0
    |   | | | `-- mimic-response@2.1.0 deduped
    |   | | +-- duplexer3@0.1.4
    |   | | +-- get-stream@5.2.0 deduped
    |   | | +-- lowercase-keys@2.0.0 deduped
    |   | | +-- mimic-response@2.1.0
    |   | | +-- p-cancelable@2.0.0 deduped
    |   | | +-- p-event@4.2.0
    |   | | +-- responselike@2.0.0 deduped
    |   | | +-- to-readable-stream@2.1.0
    |   | | `-- type-fest@0.10.0
    |   | +-- is-scoped@2.1.0 deduped
    |   | +-- is-url-superb@4.0.0
    |   | +-- lodash.zip@4.2.0
    |   | +-- org-regex@1.0.0
    |   | +-- p-map@3.0.0
    |   | | `-- aggregate-error@3.1.0 deduped
    |   | +-- registry-auth-token@4.2.1
    |   | | `-- rc@1.2.8 deduped
    |   | +-- registry-url@5.1.0
    |   | `-- validate-npm-package-name@3.0.0
    |   |   `-- builtins@1.0.3
    |   +-- onetime@5.1.2
    |   | `-- mimic-fn@2.1.0
    |   +-- open@7.4.2
    |   | +-- is-docker@2.2.1
    |   | `-- is-wsl@2.2.0
    |   |   `-- is-docker@2.2.1 deduped
    |   +-- ow@0.21.0
    |   | +-- @sindresorhus/is@4.0.1
    |   | +-- callsites@3.1.0
    |   | +-- dot-prop@6.0.1
    |   | | `-- is-obj@2.0.0
    |   | +-- lodash.isequal@4.5.0
    |   | +-- type-fest@0.20.2
    |   | `-- vali-date@1.0.0
    |   +-- p-memoize@4.0.1
    |   | +-- mem@6.1.1
    |   | | +-- map-age-cleaner@0.1.3
    |   | | | `-- p-defer@1.0.0
    |   | | `-- mimic-fn@3.1.0
    |   | `-- mimic-fn@3.1.0
    |   +-- p-timeout@4.1.0
    |   +-- pkg-dir@5.0.0
    |   | `-- find-up@5.0.0
    |   |   +-- locate-path@6.0.0
    |   |   | `-- p-locate@5.0.0
    |   |   |   `-- p-limit@3.1.0
    |   |   |     `-- yocto-queue@0.1.0
    |   | +-- find-up@4.1.0
    |   | | | `-- p-locate@4.1.0
    |   | +-- read-pkg@5.2.0
    |   | | +-- normalize-package-data@2.5.0 deduped
    |   | | `-- type-fest@0.6.0
    |   | `-- type-fest@0.8.1
    |   +-- rxjs@6.6.7
    |   +-- semver@7.3.5
    |   +-- split@1.0.1 deduped
    |   +-- symbol-observable@3.0.0
    |   +-- terminal-link@2.1.1
    |   | `-- supports-hyperlinks@2.2.0
    |   |   +-- has-flag@4.0.0 deduped
    |   |   `-- supports-color@7.2.0 deduped
    |   `-- update-notifier@5.1.0
    |     +-- boxen@5.0.1
    |     | +-- ansi-align@3.0.0
    |     | | `-- string-width@3.1.0
    |     | +-- camelcase@6.2.0
    |     | +-- cli-boxes@2.2.1
    |     | +-- widest-line@3.1.0
    |     | | `-- string-width@4.2.2
    |     +-- configstore@5.0.1
    |     | +-- dot-prop@5.3.0
    |     | | `-- is-obj@2.0.0 deduped
    |     | +-- graceful-fs@4.2.3 deduped
    |     | +-- make-dir@3.1.0 deduped
    |     | +-- unique-string@2.0.0
    |     | | `-- crypto-random-string@2.0.0
    |     | +-- write-file-atomic@3.0.3
    |     | | +-- imurmurhash@0.1.4
    |     | | +-- is-typedarray@1.0.0 deduped
    |     | | +-- signal-exit@3.0.3 deduped
    |     | | `-- typedarray-to-buffer@3.1.5 deduped
    |     | `-- xdg-basedir@4.0.0 deduped
    |     +-- has-yarn@2.1.0 deduped
    |     +-- import-lazy@2.1.0
    |     +-- is-ci@2.0.0
    |     | `-- ci-info@2.0.0
    |     +-- is-installed-globally@0.4.0
    |     | +-- global-dirs@3.0.0
    |     | | `-- ini@2.0.0
    |     +-- is-npm@5.0.0
    |     +-- is-yarn-global@0.3.0
    |     +-- latest-version@5.1.0
    |     | `-- package-json@6.5.0
    |     |   +-- got@9.6.0
    |     |   | +-- @sindresorhus/is@0.14.0
    |     |   | +-- @szmarczak/http-timer@1.1.2
    |     |   | | `-- defer-to-connect@1.1.3
    |     |   | +-- cacheable-request@6.1.0
    |     |   | | +-- clone-response@1.0.2 deduped
    |     |   | | | `-- pump@3.0.0 deduped
    |     |   | | +-- http-cache-semantics@4.1.0 deduped
    |     |   | | +-- keyv@3.1.0
    |     |   | | | `-- json-buffer@3.0.0
    |     |   | | +-- normalize-url@4.5.0 deduped
    |     |   | | `-- responselike@1.0.2
    |     |   | |   `-- lowercase-keys@1.0.1 deduped
    |     |   | +-- decompress-response@3.3.0
    |     |   | | `-- mimic-response@1.0.1 deduped
    |     |   | +-- duplexer3@0.1.4 deduped
    |     |   | +-- get-stream@4.1.0
    |     |   | +-- lowercase-keys@1.0.1
    |     |   | +-- mimic-response@1.0.1
    |     |   | +-- p-cancelable@1.1.0
    |     |   | +-- to-readable-stream@1.0.0
    |     |   | `-- url-parse-lax@3.0.0
    |     |   |   `-- prepend-http@2.0.0
    |     |   +-- registry-auth-token@4.2.1 deduped
    |     |   +-- registry-url@5.1.0 deduped
    |     |   `-- semver@6.3.0
    |     +-- pupa@2.1.1
    |     | `-- escape-goat@2.1.1
    |     +-- semver@7.3.5
    |     | `-- lru-cache@6.0.0
    |     +-- semver-diff@3.1.1
    |     | `-- semver@6.3.0
    +-- iobroker.vis-jqui-mfd@1.0.12 extraneous
    +-- iobroker.vis-justgage@1.0.2 extraneous
    +-- iobroker.vis-lcars@1.0.4 extraneous
    +-- iobroker.vis-map@1.0.4
    +-- iobroker.vis-metro@1.1.2 extraneous
    +-- iobroker.vis-players@0.1.6
    | `-- @iobroker/adapter-core@1.0.3
    |   `-- @types/iobroker@1.4.13
    +-- iobroker.vis-plumb@1.0.2 extraneous
    +-- iobroker.vis-rgraph@0.0.2 extraneous
    +-- iobroker.vis-timeandweather@1.1.7 extraneous
    +-- iobroker.vis-weather@2.5.3
    +-- iobroker.vodafone-speedtest@0.0.7
    | +-- node-libcurl@2.3.3
    | | +-- env-paths@2.2.0
    | | +-- nan@2.14.1
    | | +-- node-gyp@7.1.0
    | | | +-- env-paths@2.2.0 deduped
    | | | +-- glob@7.1.6
    | | | | +-- fs.realpath@1.0.0
    | | | | +-- inflight@1.0.6
    | | | | | +-- once@1.4.0 deduped
    | | | | | `-- wrappy@1.0.2 deduped
    | | | | +-- inherits@2.0.4 deduped
    | | | | `-- path-is-absolute@1.0.1
    | | | +-- nopt@4.0.3
    | | | | +-- abbrev@1.1.1
    | | | | `-- osenv@0.1.5
    | | | |   +-- os-homedir@1.0.2
    | | | |   `-- os-tmpdir@1.0.2 deduped
    | | | +-- npmlog@4.1.2 deduped
    | | | +-- rimraf@2.7.1 deduped
    | | | +-- semver@7.3.5
    | | | | `-- lru-cache@6.0.0
    | | | +-- tar@6.0.2 deduped
    | | | `-- which@2.0.2
    | | +-- node-pre-gyp@0.15.0
    | | | +-- detect-libc@1.0.3 deduped
    | | | +-- mkdirp@0.5.5
    | | | +-- needle@2.6.0
    | | | | +-- debug@3.2.7
    | | | | | `-- ms@2.1.3
    | | | | `-- sax@1.2.4 deduped
    | | | +-- nopt@4.0.3 deduped
    | | | +-- npm-packlist@1.4.8
    | | | | +-- ignore-walk@3.0.3 deduped
    | | | | +-- npm-bundled@1.1.2
    | | | | | `-- npm-normalize-package-bin@1.0.1 deduped
    | | | +-- rc@1.2.8 deduped
    | | | +-- rimraf@2.7.1
    | | | +-- semver@5.7.0 deduped
    | | | `-- tar@4.4.13
    | | |   +-- chownr@1.1.4 deduped
    | | |   +-- fs-minipass@1.2.7
    | | |   | `-- minipass@2.9.0 deduped
    | | |   +-- minipass@2.9.0
    | | |   | +-- safe-buffer@5.2.0 deduped
    | | |   | `-- yallist@3.1.1 deduped
    | | |   +-- minizlib@1.3.3
    | | |   +-- mkdirp@0.5.5 deduped
    | | |   `-- yallist@3.1.1
    | | +-- rimraf@3.0.2
    | | `-- tslib@2.0.1
    | +-- ping@0.4.1
    | | +-- q@1.5.1 deduped
    | | `-- underscore@1.13.1
    | `-- querystring@0.2.1
    +-- iobroker.wallpanel@0.1.6-0 (github:xXBJXx/ioBroker.wallpanel#30b00ce75531116146f928304b1cfe839c77bbcb)
    | `-- axios@0.21.1 deduped
    +-- iobroker.weatherunderground@3.3.1
    +-- iobroker.web@3.4.5
    | +-- body-parser@1.19.0 deduped
    | +-- connect-flash@0.1.1 deduped
    | +-- cookie-parser@1.4.5 deduped
    | +-- express@4.17.1 deduped
    | +-- express-session@1.17.2
    | | +-- cookie@0.4.1
    | | +-- cookie-signature@1.0.6 deduped
    | | +-- depd@2.0.0
    | | +-- on-headers@1.0.2 deduped
    | | +-- safe-buffer@5.2.1
    | | `-- uid-safe@2.1.5 deduped
    | +-- iobroker.simple-api@2.6.1 deduped
    | +-- iobroker.socketio@3.1.4 deduped
    | +-- mime-types@2.1.31
    | | `-- mime-db@1.48.0
    | +-- passport@0.4.1 deduped
    | +-- passport-local@1.0.0 deduped
    | +-- passport.socketio@3.7.0 deduped
    | +-- socket.io-client@2.3.0
    | | +-- backo2@1.0.2 deduped
    | | +-- base64-arraybuffer@0.1.5
    | | +-- component-bind@1.0.0 deduped
    | | +-- component-emitter@1.2.1
    | | +-- debug@4.1.1
    | | | `-- ms@2.1.2
    | | +-- engine.io-client@3.4.0
    | | | +-- component-emitter@1.2.1 deduped
    | | | +-- component-inherit@0.0.3 deduped
    | | | +-- debug@4.1.1
    | | | | `-- ms@2.1.2
    | | | +-- engine.io-parser@2.2.0 deduped
    | | | +-- has-cors@1.1.0 deduped
    | | | +-- indexof@0.0.1 deduped
    | | | +-- parseqs@0.0.5 deduped
    | | | +-- parseuri@0.0.5 deduped
    | | | +-- ws@6.1.4
    | | | | `-- async-limiter@1.0.1 deduped
    | | | +-- xmlhttprequest-ssl@1.5.5
    | | | `-- yeast@0.1.2 deduped
    | | +-- has-binary2@1.0.3 deduped
    | | +-- has-cors@1.1.0
    | | +-- object-component@0.0.3 deduped
    | | +-- parseqs@0.0.5
    | | | `-- better-assert@1.0.2 deduped
    | | +-- socket.io-parser@3.3.0
    | | | +-- debug@3.1.0
    | | | | `-- ms@2.0.0
    | | | `-- isarray@2.0.1
    | | `-- to-array@0.1.4 deduped
    | `-- xtend@4.0.2
    +-- iobroker.web-speedy@0.2.0
    | `-- speedtest-net@1.6.2
    |   +-- chalk@2.4.2
    |   |   `-- has-flag@3.0.0
    |   +-- draftlog@1.0.12
    |   +-- http-proxy-agent@2.1.0
    |   | +-- agent-base@4.3.0
    |   | | `-- es6-promisify@5.0.0 deduped
    |   | `-- debug@3.1.0
    |   |   `-- ms@2.0.0 deduped
    |   +-- https-proxy-agent@3.0.1
    |   | `-- debug@3.2.6
    |   |   `-- ms@2.1.2
    +-- iobroker.wifilight@1.1.0 extraneous
    +-- iobroker.wifilight-community@0.2.1 extraneous
    +-- iobroker.wled@0.5.6
    | | `-- @types/iobroker@3.2.7
    | +-- axios@0.21.1
    | | `-- follow-redirects@1.11.0 deduped
    | +-- bonjour@3.5.0
    | | +-- array-flatten@2.1.2
    | | +-- deep-equal@1.1.1
    | | | +-- is-arguments@1.1.0
    | | | | `-- call-bind@1.0.0 deduped
    | | | +-- is-date-object@1.0.2
    | | | +-- is-regex@1.0.5
    | | | +-- object-is@1.1.4
    | | | +-- object-keys@1.1.1
    | | | `-- regexp.prototype.flags@1.3.0
    | | |   +-- define-properties@1.1.3 deduped
    | | |   `-- es-abstract@1.17.5 deduped
    | | +-- dns-equal@1.0.0
    | | +-- dns-txt@2.0.2
    | | | `-- buffer-indexof@1.1.1
    | | +-- multicast-dns@6.2.3
    | | | +-- dns-packet@1.3.1 deduped
    | | | `-- thunky@1.1.0
    | | `-- multicast-dns-service-types@1.1.0
    | +-- hex-rgb@4.2.0
    | `-- rgb-hex@3.0.0
    +-- jsonata@1.8.4 extraneous
    +-- node-inspect@2.0.0 extraneous
    +-- node-red@0.20.7 extraneous
    +-- node-red-dashboard@2.15.5 extraneous
    +-- node-telegram-bot-api@0.30.0 extraneous
    +-- open-fin-ts-js-client@2.0.4 extraneous
    +-- portfinder@1.0.20 extraneous
    +-- pushover-notifications@1.2.0 extraneous
    +-- qrcode@1.3.3 extraneous
    +-- semver@5.7.0
    +-- systeminformation@4.14.4 extraneous
    +-- tuyapi@5.1.1 extraneous
    +-- typescript@3.5.3 extraneous
    +-- virtual-device-sdk@1.5.16 extraneous
    +-- virtual-tsc@0.5.0 extraneous
    +-- vm2@3.8.2 extraneous
    +-- wake_on_lan@1.0.0 extraneous
    +-- xmldom@0.1.27 extraneous
    `-- yargs@7.1.0
     +-- camelcase@3.0.0
     +-- cliui@3.2.0
     | +-- string-width@1.0.2 deduped
     | `-- wrap-ansi@2.1.0
     +-- get-caller-file@1.0.3
     +-- os-locale@1.4.0
     | `-- lcid@1.0.0
     |   `-- invert-kv@1.0.0
     +-- read-pkg-up@1.0.1
     | +-- find-up@1.1.2
     | | +-- path-exists@2.1.0
     | | | `-- pinkie-promise@2.0.1 deduped
     | `-- read-pkg@1.1.0
     |   +-- load-json-file@1.1.0
     |   | +-- parse-json@2.2.0
     |   | | `-- error-ex@1.3.2 deduped
     |   | +-- pify@2.3.0
     |   | +-- pinkie-promise@2.0.1 deduped
     |   | `-- strip-bom@2.0.0 deduped
     |   | +-- hosted-git-info@2.8.8
     |   | +-- resolve@1.15.1 deduped
     |   `-- path-type@1.1.0
     |     +-- pify@2.3.0 deduped
     +-- require-main-filename@1.0.1
     | +-- code-point-at@1.1.0
     | +-- is-fullwidth-code-point@1.0.0
     | | `-- number-is-nan@1.0.1
     +-- which-module@1.0.0
     +-- y18n@3.2.1
     `-- yargs-parser@5.0.0
       `-- camelcase@3.0.0 deduped
    npm ERR! extraneous: @apollon/frankjoke-myadapter@1.2.5 /opt/iobroker/node_modules/@apollon/frankjoke-myadapter
    npm ERR! extraneous: @types/request@2.48.2 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: fsevents /opt/iobroker/node_modules/fsevents
    npm ERR! error in /opt/iobroker/node_modules/fsevents: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/fsevents/package.json'
    npm ERR! extraneous: alexa-remote2@2.3.7 /opt/iobroker/node_modules/alexa-remote2
    npm ERR! extraneous: anyproxy@4.1.0 /opt/iobroker/node_modules/anyproxy
    npm ERR! extraneous: coffee-compiler@0.3.2 /opt/iobroker/node_modules/coffee-compiler
    npm ERR! extraneous: coffee-script@1.12.7 /opt/iobroker/node_modules/coffee-script
    npm ERR! extraneous: express-fileupload@0.4.1 /opt/iobroker/node_modules/express-fileupload
    npm ERR! extraneous: http-mitm-proxy@0.8.1 /opt/iobroker/node_modules/http-mitm-proxy
    npm ERR! extraneous: iobroker@1.3.1 /opt/iobroker/node_modules/iobroker
    npm ERR! extraneous: iobroker.amazon-dash@1.1.0 /opt/iobroker/node_modules/iobroker.amazon-dash
    npm ERR! extraneous: iobroker.fontui@0.1.0 /opt/iobroker/node_modules/iobroker.fontui
    npm ERR! extraneous: iobroker.fullcalendar@1.1.0 /opt/iobroker/node_modules/iobroker.fullcalendar
    npm ERR! extraneous: iobroker.icons-addictive-flavour-png@0.1.0 /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png
    npm ERR! extraneous: iobroker.icons-fatcow-hosting@0.1.0 /opt/iobroker/node_modules/iobroker.icons-fatcow-hosting
    npm ERR! extraneous: iobroker.icons-icons8@0.0.1 /opt/iobroker/node_modules/iobroker.icons-icons8
    npm ERR! extraneous: iobroker.icons-material-png@0.1.0 /opt/iobroker/node_modules/iobroker.icons-material-png
    npm ERR! extraneous: iobroker.icons-material-svg@0.1.0 /opt/iobroker/node_modules/iobroker.icons-material-svg
    npm ERR! extraneous: iobroker.icons-mfd-png@1.0.2 /opt/iobroker/node_modules/iobroker.icons-mfd-png
    npm ERR! extraneous: iobroker.icons-mfd-svg@1.0.2 /opt/iobroker/node_modules/iobroker.icons-mfd-svg
    npm ERR! extraneous: iobroker.icons-open-icon-library-png@0.1.3 /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png
    npm ERR! extraneous: iobroker.icons-ultimate-png@1.0.1 /opt/iobroker/node_modules/iobroker.icons-ultimate-png
    npm ERR! extraneous: iobroker.js2fs@0.1.5 /opt/iobroker/node_modules/iobroker.js2fs
    npm ERR! extraneous: iobroker.opentherm@0.1.9 /opt/iobroker/node_modules/iobroker.opentherm
    npm ERR! extraneous: iobroker.openuv@0.0.5 /opt/iobroker/node_modules/iobroker.openuv
    npm ERR! extraneous: iobroker.paw@0.3.2 /opt/iobroker/node_modules/iobroker.paw
    npm ERR! extraneous: iobroker.rickshaw@1.0.0 /opt/iobroker/node_modules/iobroker.rickshaw
    npm ERR! extraneous: iobroker.samsung@0.2.9 /opt/iobroker/node_modules/iobroker.samsung
    npm ERR! extraneous: iobroker.ubuntu@0.1.0 /opt/iobroker/node_modules/iobroker.ubuntu
    npm ERR! extraneous: iobroker.vis-bars@0.1.4 /opt/iobroker/node_modules/iobroker.vis-bars
    npm ERR! extraneous: iobroker.vis-canvas-gauges@0.1.5 /opt/iobroker/node_modules/iobroker.vis-canvas-gauges
    npm ERR! extraneous: iobroker.vis-fancyswitch@1.1.0 /opt/iobroker/node_modules/iobroker.vis-fancyswitch
    npm ERR! extraneous: iobroker.vis-google-fonts@0.1.0 /opt/iobroker/node_modules/iobroker.vis-google-fonts
    npm ERR! extraneous: iobroker.vis-history@1.0.0 /opt/iobroker/node_modules/iobroker.vis-history
    npm ERR! extraneous: iobroker.vis-jqui-mfd@1.0.12 /opt/iobroker/node_modules/iobroker.vis-jqui-mfd
    npm ERR! extraneous: iobroker.vis-justgage@1.0.2 /opt/iobroker/node_modules/iobroker.vis-justgage
    npm ERR! extraneous: iobroker.vis-lcars@1.0.4 /opt/iobroker/node_modules/iobroker.vis-lcars
    npm ERR! extraneous: iobroker.vis-metro@1.1.2 /opt/iobroker/node_modules/iobroker.vis-metro
    npm ERR! extraneous: iobroker.vis-plumb@1.0.2 /opt/iobroker/node_modules/iobroker.vis-plumb
    npm ERR! extraneous: iobroker.vis-rgraph@0.0.2 /opt/iobroker/node_modules/iobroker.vis-rgraph
    npm ERR! extraneous: iobroker.vis-timeandweather@1.1.7 /opt/iobroker/node_modules/iobroker.vis-timeandweather
    npm ERR! extraneous: iobroker.wifilight@1.1.0 /opt/iobroker/node_modules/iobroker.wifilight
    npm ERR! extraneous: iobroker.wifilight-community@0.2.1 /opt/iobroker/node_modules/iobroker.wifilight-community
    npm ERR! extraneous: jsonata@1.8.4 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: node-red@0.20.7 /opt/iobroker/node_modules/node-red
    npm ERR! extraneous: node-red-dashboard@2.15.5 /opt/iobroker/node_modules/node-red-dashboard
    npm ERR! extraneous: node-telegram-bot-api@0.30.0 /opt/iobroker/node_modules/node-telegram-bot-api
    npm ERR! extraneous: open-fin-ts-js-client@2.0.4 /opt/iobroker/node_modules/open-fin-ts-js-client
    npm ERR! extraneous: portfinder@1.0.20 /opt/iobroker/node_modules/portfinder
    npm ERR! extraneous: pushover-notifications@1.2.0 /opt/iobroker/node_modules/pushover-notifications
    npm ERR! extraneous: qrcode@1.3.3 /opt/iobroker/node_modules/qrcode
    npm ERR! extraneous: systeminformation@4.14.4 /opt/iobroker/node_modules/systeminformation
    npm ERR! extraneous: tuyapi@5.1.1 /opt/iobroker/node_modules/tuyapi
    npm ERR! extraneous: typescript@3.5.3 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: virtual-device-sdk@1.5.16 /opt/iobroker/node_modules/virtual-device-sdk
    npm ERR! extraneous: virtual-tsc@0.5.0 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: vm2@3.8.2 /opt/iobroker/node_modules/vm2
    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    npm ERR! extraneous: xmldom@0.1.27 /opt/iobroker/node_modules/xmldom
    npm ERR! extraneous: @alcalzone/release-script@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
    npm ERR! extraneous: chai@4.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
    npm ERR! extraneous: del@6.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/del
    npm ERR! extraneous: eslint@7.31.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
    npm ERR! extraneous: gulp@4.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp
    npm ERR! extraneous: gulp-rename@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-rename
    npm ERR! extraneous: gulp-replace@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace
    npm ERR! extraneous: mocha@9.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha
    npm ERR! extraneous: timekeeper@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/timekeeper
    Kann / Muss man das lösen?
    #604
    @chaot
    Einen Teil der Meldungen dürfte man per
    cd /opt/iobroker
    npm prune
    aus der Welt bekommen. Was dann noch übrigbleibt muss man sich nochmal anschauen.
      @chaot
      cd /opt/iobroker
      npm prune
      #605
      @thomas-braun ja npm prune oder auch npm dedupe alles schön. Gefahr ist das danach was nicht geht. Von daher ……… man kann das aufräumen … muss man … … …. Das muss jeder selbst entscheiden …
      ChaotC E 2 Antworten Letzte Antwort
      • apollon77A apollon77
        ChaotC Offline
        ChaotC Offline
        Chaot
        #606
        @apollon77 Danke - also lass ich da mal lieber vorerst die Finger weg solange alles geht.
        @Thomas-Braun Danke für die Info. Wie gesagt werde ich das vorerst lassen, aber mir das dann mal im Hinterkopf behalten wenn ich ein frisches Backup und vieeeel Zeit habe.
        • ChaotC Chaot
          #607
          @chaot
          So schaut das übrigens in meinem System aus:
          echad@chet:/opt/iobroker $ npm list
          iobroker.inst@3.0.0 /opt/iobroker
          ├── iobroker.admin@5.1.15
          ├── iobroker.alexa2@3.9.3
          ├── iobroker.backitup@2.1.13
          ├── iobroker.ble@0.12.0
          ├── iobroker.cloud@4.1.0
          ├── iobroker.devices@1.0.9
          ├── iobroker.echarts@1.0.3
          ├── iobroker.firetv@1.0.0
          ├── iobroker.history@1.9.13
          ├── iobroker.info@1.9.6
          ├── iobroker.iot@1.8.22
          ├── iobroker.javascript@5.2.8
          ├── iobroker.js-controller@3.3.15
          ├── iobroker.mihome-vacuum@3.2.2
          ├── iobroker.mihome@1.3.7
          ├── iobroker.miio@0.0.13
          ├── iobroker.nuki-extended@2.3.1
          ├── iobroker.samsung-community@ (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.samsung-community.git#ea8f9f373f38d733e3d1a848e5aecf44e66bf34d)
          ├── iobroker.simple-api@2.6.1
          ├── iobroker.tado@0.3.4
          ├── iobroker.tr-064@4.2.14
          ├── iobroker.tradfri@3.0.1
          ├── iobroker.vofo-speedtest@0.0.8
          ├── iobroker.web@3.4.5
          ├── iobroker.whatsapp-cmb@0.1.6
          └── iobroker.zigbee@1.5.6
          Wesentlich aufgeräumter. Gut, das ist auch mit npm@7, das ist im Grund-Layout schon etwas übersichtlicher. Aber keine Errormeldungen oder extranous Pakete. Und mein System schnurrt. Hab halt ungern Fehlermeldungen irgendwo stehen. Macht die Suche nach 'richtigen' Fehlern nämlich auch nicht übersichtlicher.
            e-s
            #608
            @apollon77
            Kannst du oder irgendwer anders mal nach dem bose soundtouch Adapter schauen?
            Da sind auch noch Fehler vorhanden, welche aber schon gefixt sind.
            Leider ist die 0.9.4 nicht auf npm zu finden, sondern nur die 0.9.3.
            apollon77A 3 Antworten Letzte Antwort
            • E e-s
              @apollon77
              #609
              @e-s Checke ich
              • E e-s
                @apollon77
                #610
                @e-s Naja und in der 0.9.4 ist nichts von den relevanten DIngen gefixt. denke habe morgen was zum testen. Bitte bei Issue https://github.com/iobroker-community-adapters/ioBroker.bosesoundtouch/issues/51 subscriben. poste dort updates wegen testsupport
                • E e-s
                  @apollon77
                  #611
                  @e-s GitHub version zum testen da ...
                  E 1 Antwort Letzte Antwort
                    e-s
                    #612
                    @apollon77
                    Dankeschön, habe ich auf github schon gesehen. Komme aber erst morgen zum testen, war heute den ganzen Tag unterwegs.
                    Mal was anderes, bei vielen Adaptern sind die fehler schon beseitigt, häufig müssen aber die dp manuell gelöscht und neu angelegt werden.
                    Ich bezweifle das alle stable User das wirklich hinbekommen, besonders weil dadurch auch gerne alias, Funktionen und Räume verloren gehen könnten.
                    Dadurch werden einige User nicht gerade erfreut sein.
                    Wenn der js Controller doch einen Fehler findet, könnte er ihn dann nicht beseitigen. Mir ist bewusst das dies noch viel schlimmere Fehler hervorbringen könnte, aber wenn dieser wirklich nur mal number zu string oder anders herum ändert, dann sollte doch nicht so viel passieren.
                    Ich habe mir auch schon überlegt das es manchmal manuell mit anpassen leichter wäre als neu erstellen lassen.
                    Diese Anpassungen selbst in jeden Adapter selbst zu packen, ist auch schwer bis jetzt kaum möglich.
                    Da fällt mit gerade ein, der undock frontier Silicon Adapter von @hallo-amt ist auch noch nicht fertig.
                    Glaube pr sind sogar schon vorhanden, aber er hat auch scheinbar keine Zeit zum übernehmen.
                    Also anders gesagt, alles fertig bekommen bei dieser riesigen Anzahl von Adaptern wird verdammt schwer.
                    • E e-s
                      @apollon77
                      #613
                      @e-s Ja ist sehr blöd diesmal aber das müssen wir alle jetzt einmal durch ... Leider. Im Notfall müssen User halt Loglevel hochsetzen ...
                      • Jey CeeJ Online
                        Jey CeeJ Online
                        Jey Cee
                        #614
                        @apollon77 @e-s am ende sind das doch bei allen Objekten nur ein begrenzte Anzahl an Problemen.
                        Wenn wir die Sammeln und damit so eine Art fix Script Bauen das die Fehler in den Objekten behebt?
                        Eine sehr einfach Variante wäre das der User die ID des Objekts angibt in Verbindung mit der Fehlermeldung.
                        Wäre immer noch ne Menge Arbeit, aber die User hätten einen Weg der nicht gleich das ganze System durcheinander bringt.
                        Persönlicher Support
                        Spenden -> paypal.me/J3YC33
                        • Jey CeeJ Jey Cee
                          #615
                          @jey-cee interessante Idee. Müsste eher generisch sein und dann mit regex arbeiten.
                          Vllt am besten sogar vllt relevante logzeilen als Input dann parsen der Meldung und Objekte fixen. Die Fehlermeldungen die relevant sind sollten überschaubar sein.
                          Damit kriegt man auf jeden Fall die einfachen Datentypenthemen hin. Object/stringify Themen und ggf Objekte die der dev am Ende aus Mixed deklariert hat muss man dann doch löschen und neu anlegen lassen. Sind dann aber weniger.
                          Wer mag sich der Idee mal annehmen?
                          • L Offline
                            LoxDUS
                            #616
                            Hallo Zusammen,
                            Mein Log (oder jetzt Protokoll) listet alle 2 Minuten folgende Warnung auf:
                            State "info.0.sysinfo.cpu.currentSpeed.coresSpeed" has no existing object, this might lead to an error in future versions
                            State "info.0.sysinfo.cpu.currentLoad.currentLoad_hist" has no existing object, this might lead to an error in future versions
                            Kann es sein das da eine "groß-Kleinschreibung verwechselt wurde in "coresSpeed" und "currentLoad"? Kann ich das irgendwie selber fixen?
                            • L LoxDUS
                              Hallo Zusammen,
                              #617
                              @loxdus Bitte die gemedleten Objekte im Admin löschen, Info Adater neu starten. sollte dann weg sein ... bzw info Adapter sicherstellen das letzte Version installiert ist!
                              L 1 Antwort Letzte Antwort
                                LoxDUS
                                #618
                                @apollon77 Das Problem ist doch das es die nicht gibt. Oder ist das nicht "Case" sensitive? Es gibt nur mit kleinen Buchstaben:
                                Habe die letzte Version installiert:
                                • L LoxDUS
                                  #619
                                  @loxdus GutHub Issue bei info Bitte
                                  L LatziL 2 Antworten Letzte Antwort
                                    LoxDUS
                                    #620
                                    @apollon77 Done #336
                                      LatziL Online
                                      LatziL Online
                                      Latzi
                                      #621
                                      @apollon77
                                      issue #336 wurde geschlossen, jedoch in 1.9.9 besteht die Meldung immer noch:
                                      info.0	2021-09-03 18:12:15.028	warn	(2318) State "info.0.sysinfo.cpu.currentSpeed.coresspeed" has no existing object, this might lead to an error in future versions
                                      info.0	2021-09-03 18:12:14.917	warn	(2318) State "info.0.sysinfo.cpu.currentLoad.currentload_hist" has no existing object, this might lead to an error in future versions
                                      • LatziL Latzi
                                        @apollon77
                                        #622
                                        @latzi N dann kommentiere dort oder mach ein neues issue auf. Objekte mal gelöscht?
                                        LatziL 1 Antwort Letzte Antwort
                                          LatziL Online
                                          LatziL Online
                                          Latzi
                                          #623
                                          @apollon77
                                          Ja, Instanz gestoppt, Objekte gelöscht und Instanz wieder gestartet. Da der Fehler bestehen blieb, Reboot versucht - leider ohne Erfolg
