  4. Samsung 2016 Modelle (KU/KS Serie)
71 Beiträge 13 Kommentatoren 15.5k Aufrufe
  • M
    M
    my-knx-shop
    Bei Bild in Bild öffnet sich auch nur das Menü des PIP und bei Aufnahme scheint er auch nicht mit meinem Key zu funktionieren.
    Ich probiere aber weiter:
    samsung2016.0 2017-01-31 18:18:22.439 info stateChange samsung2016.0.sendKey {"val":"KEY_REC","ack":false,"ts":1485886702429,"q":0,"from":"system.adapter.javascript.0","lc":1485886702429}
    javascript.0 2017-01-31 18:18:22.426 warn Wrong type of samsung2016.0.sendKey: "string". Please fix, while deprecated and will not work in next versions.
    javascript.0 2017-01-31 18:18:22.425 info script.js.Fernseher.Aufnahme_Start_Stop: Switch off Samsung TV
    samsung2016.0 2017-01-31 18:17:59.331 info websocket closed
    samsung2016.0 2017-01-31 18:17:58.340 info successfully sent key
    samsung2016.0 2017-01-31 18:17:58.339 info Sending Key
    samsung2016.0 2017-01-31 18:17:58.328 info websocket connect
    samsung2016.0 2017-01-31 18:17:58.264 info Try to open a websocket connection to 192.168.178.218
    samsung2016.0 2017-01-31 18:17:58.264 info Trying ipAddress 192.168.178.218
    samsung2016.0 2017-01-31 18:17:58.263 info Will now send key KEY_PIP_ONOFF to TV
    samsung2016.0 2017-01-31 18:17:58.262 info stateChange samsung2016.0.sendKey {"val":"KEY_PIP_ONOFF","ack":false,"ts":1485886678255,"q":0,"from":"system.adapter.javascript.0","lc":1485886666290}
    javascript.0 2017-01-31 18:17:58.252 warn Wrong type of samsung2016.0.sendKey: "string". Please fix, while deprecated and will not work in next versions.
    javascript.0 2017-01-31 18:17:58.250 info script.js.Fernseher.PIP_An_Aus: Switch off Samsung TV
    samsung2016.0 2017-01-31 18:17:47.511 info websocket closed
    samsung2016.0 2017-01-31 18:17:46.510 info successfully sent key
    samsung2016.0 2017-01-31 18:17:46.509 info Sending Key
    samsung2016.0 2017-01-31 18:17:46.508 info websocket connect
    samsung2016.0 2017-01-31 18:17:46.303 info Try to open a websocket connection to 192.168.178.218
    samsung2016.0 2017-01-31 18:17:46.303 info Trying ipAddress 192.168.178.218
    samsung2016.0 2017-01-31 18:17:46.301 info Will now send key KEY_PIP_ONOFF to TV
    samsung2016.0 2017-01-31 18:17:46.300 info stateChange samsung2016.0.sendKey {"val":"KEY_PIP_ONOFF","ack":false,"ts":1485886666290,"q":0,"from":"system.adapter.javascript.0","lc":1485886666290}
    javascript.0 2017-01-31 18:17:46.287 warn Wrong type of samsung2016.0.sendKey: "string". Please fix, while deprecated and will not work in next versions.
    • N
      N
      Newmiraculix
      @stefan0875:
      Was für einen AVR hast du?
      Meinen Denon AVR3312 kann ich steuern.
      Den Sky Receiver kenne ich nicht, da kann ich nicht helfen…mal google fragen
      Einen Denon AVR-X1300W
      CCU2 mit noch nicht ganz so vielen Aktoren :D
      RaspberryPi2 für SmartHome mit ioBroker
      RaspberryPi3 für SmartHome Mit iobroker (Multihost)
      Logitech Harmony Hub
      RaspberryPi3 mit openELEC
      Amazon Echo, Echo Dot und Echo…
      • Jey CeeJ
        Jey CeeJ
        Jey Cee
        @stefan ich hab mich wochenlang kreuz und quer durchs web gelesen, inklusive der offiziellen Entwicklerdoku von Samsung. Dort findet sich kein Hinweis auf die verwendete Schnittstelle.
        Und so ziemlich alles versucht, bis auf eine eigene APP für den TV zu schreiben um über den cloud service zu kommunizieren.
        Wake on LAN klappt auch nicht, laut Samsung geht das ebenfalls erst ab 2016.
        Es gibt keine offiziellen aussagen von Samsung zum Thema. Mein Gefühl ist aber das sie versucht haben alles auf cloud um zu stellen oder einfach nur externe Entwickler aus zu sperren.
        Gesendet von meinem m8 mit Tapatalk
        Persönlicher Support
        Spenden -> paypal.me/J3YC33
        • S
          S
          stefan0875
          Hi
          weiß hier jemand, was genau die Warnung
          bedeutet?
          OK, ich sende einen String und das ist der falsche Typ.
          Aber was muss ich stattdessen senden?
          Vielleicht kann mir Bluefox was dazu sagen?
          • Jey CeeJ
            Jey CeeJ
            Jey Cee
            Wie wird das Objekt sendkey angelegt? Ist der type des Objekts auch string?
            • S
              S
              stefan0875
              @Jey Cee:
              Wie wird das Objekt sendkey angelegt? Ist der type des Objekts auch string? `
              Danke, jetzt lege ich es mit
              adapter.setObject('sendKey', {
                      type: 'state',
                      common: {
                          type: 'string',
                          role: 'button'
                      native: {}
              an.
              Vorher war es
              type: 'val'
              Warning ist jetzt natürlich weg
              • S
                S
                stefan0875
                @my-knx-shop:
                Ich probiere aber weiter: `
                Zur Aufnahme kann ich nix sagen, der Befehl ist scheinbar sauber gesendet worden.
                Zum PIP, sende doch einfach mehrere Kommandos hintereinander.
                Auf der Fernbedienung musst du ja scheinbar auch mehrere Tasten Tasten hintereinander drücken
                • S
                  S
                  stefan0875
                  Noch eine Frage meinerseits:
                  Unter Instanzen habe ich für meinen Adapter kein Icon, nur einen Platzhalter.
                  Bei einem anderen Adapter von mir funktioniert es aber.
                  Das png File wird in der Adapterkonfiguration aber angezeigt. Es hat eine Auflösung von 256x256 Pixel.
                  Jemand eine Idee, warum es nicht in klein bei den Instanzen angezeigt wird?
                  • Jey CeeJ
                    Jey CeeJ
                    Jey Cee
                    Der Pfad zum png muss in der io-package.json hinterlegt sein.
                    • M
                      M
                      my-knx-shop
                      @stefan0875:
                      @my-knx-shop:
                      Auf der Fernbedienung musst du ja scheinbar auch mehrere Tasten Tasten hintereinander drücken `
                      Wie könnte das dann aussehen. Kann man das auch mit einem Aufruf machen und wie wäre dazu der Code für das Script ?
                      • M
                        M
                        my-knx-shop
                        Ich habe nun einiges ausprobiert und Mute, Sender, Aufnahme starten, Ein aus funktionieren wunderbar.
                        Leider musste ich feststellen, dass man an dem TV kein PIP mit dem HDMI 1 oder 2 anzeigen lassen kann. Auch kann man keine vordefinierte Browserseite aufrufen. Das zerstört mir gerade meinen Plan vom Videobild im TV wenn es klingelt. Grrr.
                        Jetzt will ich nur noch eines realisiert bekommen, wozu ich auch schon einen Adapter gefunden habe, der aber bei mir noch nicht geht. Es geht um das einblenden von Information wie Texten. Und idealer weise Texte die aus einem dynamischen 14 Byte aus einem Datenpunkt und normalen Text zusammen gesetzt werden kann.
                        Ziel ist es, die Rufnummer oder den Namen anzeigen zu lassen, von demjenigen, der gerade anruft.
                        Jemand eine Idee ?
                        • S
                          S
                          stefan0875
                          @my-knx-shop:
                          Jemand eine Idee ? `
                          Was ist das für ein Adapter?
                          • M
                            M
                            my-knx-shop
                            Gib mal unter suche Popup LG ein dann findest du den !
                            • M
                              M
                              my-knx-shop
                              Jetzt habe ich ihn wieder gefunden … heißt lgtv
                              • M
                                M
                                my-knx-shop
                                Ich möchte noch einmal das Thema PIP aufgreifen, da ich mir denke, dass es bestimmt lösbar ist.
                                Also, per :
                                on({id: '<hier den/datenpunkt/von/deinem/knx/adapter/eintragen="">'}, function (obj) {
                                console.log("Switch off Samsung TV");
                                setState ('samsung2016.0.sendKey', 'KEY_PIP_ONOFF');
                                wird das Auswahl Menue aufgerufen, ob ich das PIP Ein oder AUS schalten will.
                                Um dieses aber nicht manuell per Fernbedienung zu tätigen, gibt es doch bestimmt auch eine Code oder eine Script Funktion, die dieses für mich über nimmt und dann die Ein oder Aus Funktion schaltet …. oder ist das nicht möglich.
                                Vielleicht ist es dann aber möglich wie folgt vorzugehen:
                                KEY_PIP_ONOFF aufrufen dann 0,03 sek später
                                KEY für Taste runter auswählen dann 0,03 sek später
                                KEY für Taste ok auswählen
                                Wie kann ich dieses mit einem Script realisieren ? Weiss da jemand Rat ?</hier>
                                • S
                                  S
                                  stefan0875
                                  @my-knx-shop:
                                  Wie kann ich dieses mit einem Script realisieren ? Weiss da jemand Rat ? `
                                  Klar…recht einfach:
                                      console.log("Turning on PIP");
                                     // Nach 500ms KEY_DOWN senden
                                      setTimeout (function() {
                                           setState ('samsung2016.0.sendKey', 'KEY_DOWN');
                                      }, 500);
                                   // Und nochmal 500ms später, also 1000ms später dann KEY_OK senden
                                           setState ('samsung2016.0.sendKey', 'KEY_OK');
                                      }, 1000);
                                  });</hier>
                                  • M
                                    M
                                    my-knx-shop
                                    Das klingt super.
                                    Ich habe habe mir die Vorgehensweise nun mal detailierter angesehen und würde folgendes realisieren. Allerdings fehlt mir dazu der KEY für Exit
                                    PIP Menü auf rufen
                                    ok Taste
                                    runter taste
                                    ok Taste
                                    Menü verlassen mit exit
                                    20 sekunden später
                                    PIP Menü aufrufen
                                    ok Taste
                                    rauf Taste
                                    ok Taste
                                    Menü verlassen mit Exit
                                    Vielleicht kennt ja jemand den richtigen Befehl für Exit.
                                    ob KEY_OK für die OK Taste stimmt, teste ich gleich mal.
                                    Ich würde dass dann so deuten, habe aber noch einen Fehler in der vorletzen Reihe.
                                    on({id: 'knx.0.Multimedia.WHZ_Samsung.Browse'},  function (obj) {
                                        console.log("Turning on / off PIP");
                                        }, 1000);
                                        }, 1500);
                                        }, 2000);
                                             setState ('samsung2016.0.sendKey', 'KEY_EXIT');
                                        }, 3000);
                                        }, 23000);
                                        }, 24000);
                                             setState ('samsung2016.0.sendKey', 'KEY_UP');
                                        }, 24500);
                                        }, 25000);
                                        }, 26000);
                                    • S
                                      S
                                      stefan0875
                                      OK ist KEY_ENTER
                                      EXIT ist…<trommelwirbel>...KEY_EXIT</trommelwirbel>
                                      • M
                                        M
                                        my-knx-shop
                                        Sehr gut, dass passe ich gleich noch an.
                                        Siehst du den Fehler in meinem Code.
                                        Es wird mir ein Ausrufezeichen in der vorletzten Zeile angezeigt.
                                        • S
                                          S
                                          stefan0875
                                          In Zeile 16 fehlt der 'setTimeout' Aufruf
                                          84.2k
