  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.6k
1.2k Beiträge 100 Kommentatoren 504.2k Aufrufe 82 Beobachtet
  • U Offline
    U Offline
    UHT
    #220
    gibt es das vis widget nicht mehr?
    • Ronny GerndtR Offline
      Ronny Gerndt
      #221
      hab seit letzter Wochen einen Roborock S7 und wollte den mit iobroker verbinden.
      Die Verbindung bekomme ich soweit auch hin. Token usw. hat geklappt.
      Ich habe Version 3.20 am laufen und bekomme in endlosschleife diese Log Ausgaben.
      mihome-vacuum.0	2021-06-07 10:11:32.591	debug	(17421) Helo message Timeout
      mihome-vacuum.0	2021-06-07 10:11:20.589	debug	(17421) Time difference between Mihome Vacuum and ioBroker: -1623027974 sec
      mihome-vacuum.0	2021-06-07 10:11:20.588	debug	(17421) Receive <<< Helo <<< 213100200000000018cf43ce000063a2ffffffffffffffffffffffffffffffff
      mihome-vacuum.0	2021-06-07 10:11:19.784	debug	(17421) MIIO RECIVE: {"id":326,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":100}
      mihome-vacuum.0	2021-06-07 10:11:19.576	debug	(17421) Message= {"id":326,"method":"get_carpet_mode"}
      mihome-vacuum.0	2021-06-07 10:11:19.575	debug	(17421) MIIO RECIVE: {"id":325,"result":[90],"exe_time":200}
      mihome-vacuum.0	2021-06-07 10:11:19.285	debug	(17421) Message= {"id":325,"method":"get_sound_volume"}
      mihome-vacuum.0	2021-06-07 10:11:19.274	debug	(17421) MIIO RECIVE: {"id":324,"result":{"ssid":"Familie-Gerndt","ip":"192.168.178.70","mac":"b0:4a:39:15:75:03","bssid":"2c:91:ab:a5:2f:9a","rssi":-47},"exe_time":100}
      mihome-vacuum.0	2021-06-07 10:11:19.085	debug	(17421) Message= {"id":324,"method":"get_network_info"}
      mihome-vacuum.0	2021-06-07 10:11:19.083	debug	(17421) setGetStatus {"msg_ver":2,"msg_seq":609,"state":8,"battery":90,"clean_time":2399,"clean_area":30630000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1
      mihome-vacuum.0	2021-06-07 10:11:19.082	debug	(17421) MIIO RECIVE: {"id":323,"result":[{"msg_ver":2,"msg_seq":609,"state":8,"battery":90,"clean_time":2399,"clean_area":30630000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_f
      mihome-vacuum.0	2021-06-07 10:11:18.814	debug	(17421) Message= {"id":323,"method":"get_status"}
      mihome-vacuum.0	2021-06-07 10:11:18.813	debug	(17421) get params for stock Vacuum
      mihome-vacuum.0	2021-06-07 10:11:10.583	debug	(17421) Time difference between Mihome Vacuum and ioBroker: -1623027974 sec
      mihome-vacuum.0	2021-06-07 10:11:10.582	debug	(17421) Receive <<< Helo <<< 213100200000000018cf43ce00006398ffffffffffffffffffffffffffffffff
      mihome-vacuum.0	2021-06-07 10:11:00.533	debug	(17421) Helo message Timeout
      mihome-vacuum.0	2021-06-07 10:10:58.811	debug	(17421) MIIO Receive Timeout<<<
      mihome-vacuum.0	2021-06-07 10:10:56.809	debug	(17421) Message= {"id":322,"method":"get_carpet_mode"}
      mihome-vacuum.0	2021-06-07 10:10:56.809	debug	(17421) ERROR at setGetSoundVolume: MESSAGE TIMEOUT
      mihome-vacuum.0	2021-06-07 10:10:56.807	debug	(17421) MIIO Receive Timeout<<<
      mihome-vacuum.0	2021-06-07 10:10:54.805	debug	(17421) Message= {"id":321,"method":"get_sound_volume"}
      mihome-vacuum.0	2021-06-07 10:10:54.797	debug	(17421) MIIO RECIVE: {"id":320,"result":{"ssid":"Familie-Gerndt","ip":"192.168.178.70","mac":"b0:4a:39:15:75:03","bssid":"2c:91:ab:a5:2f:9a","rssi":-52},"exe_time":101}
      mihome-vacuum.0	2021-06-07 10:10:53.045	debug	(17421) Message= {"id":320,"method":"get_network_info"}
      mihome-vacuum.0	2021-06-07 10:10:53.043	debug	(17421) setGetStatus {"msg_ver":2,"msg_seq":607,"state":8,"battery":89,"clean_time":2399,"clean_area":30630000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1
      mihome-vacuum.0	2021-06-07 10:10:53.030	debug	(17421) MIIO RECIVE: {"id":319,"result":[{"msg_ver":2,"msg_seq":607,"state":8,"battery":89,"clean_time":2399,"clean_area":30630000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_f
      mihome-vacuum.0	2021-06-07 10:10:52.839	debug	(17421) Message= {"id":319,"method":"get_status"}
      mihome-vacuum.0	2021-06-07 10:10:52.838	debug	(17421) get params for stock Vacuum
      Es kommt also ständig ein Timeout und das es eine Zeitdifferenz gibt. Kann man da was dagegen tun?
      Danke und Grüße
      Ronny
        tobitobsta
        #222
        hat irgendwer die 3.2.0 Version mit einem S5 am Laufen? Ich habe ihn nicht zum Laufen bekommen hinsichtlich "load rooms" - zurück auf 2.5.5 funktioniert wieder alles einwandfrei.
        Im debug protokoll ist mir aufgefallen, dass er bei 3.2.0 irgendwas mit "unknown device model" sagte...
        und Frage 2: funktioniert beim S5 die Detektion der Wischeinheit? bei mir bleibt der "water_box" Datenpunkt immer auf false - mag aber sein, dass das der S5 das gar nicht kann.
        • Ronny GerndtR Ronny Gerndt
          Danke und Grüße
          Ronny
          #223
          @ronny-gerndt
          Hast du den Sauger mal in einer der Apps mihome oder roborock konfiguriert?
          Ronny GerndtR 1 Antwort Letzte Antwort
            @ronny-gerndt
            Ronny Gerndt
            schrieb am zuletzt editiert von Ronny Gerndt
            #224
            @thomas-braun said in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
            @ronny-gerndt
            Ja klar. Hatte erst die Roborock drauf und bin dann auf MiHome gewechselt. Da funzt auch alles.
            Die Anbindung funktioniert inzwischen auch grundsätzlich. Mir fehlt noch die Raumliste. Die wird immer als leer angezeigt.
            • U UHT
              haselchenH Offline
              haselchenH Offline
              haselchen
              #225
              @Meistertr
              Ich habe über die 2.1.1 die 3.2.0 installiert (update über Admin Oberfläche).
              Bei GetDevices bekomme ich permanent einen Error: LOG IN FAILED.
              Runter auf die 2.1.1 geht wieder alles (bis auf die Karte, deswegen wollte ich updaten)
              Ist ein Robo S5 2.GEN.
              (ich habe noch einen V1 deswegen die 1. Instanz zusätzlich)
              mihome-vacuum.0	2021-06-13 13:50:46.231	info	(8576) create state for carpet_mode
              mihome-vacuum.0	2021-06-13 13:50:45.416	info	(8576) create states for water box
              mihome-vacuum.0	2021-06-13 13:50:45.375	info	(8576) change states from State control.fan_power
              mihome-vacuum.0	2021-06-13 13:50:45.258	info	(8576) Map selected create states...
              mihome-vacuum.1	2021-06-13 13:50:44.889	info	(8582) create state for carpet_mode
              mihome-vacuum.0	2021-06-13 13:50:44.873	warn	(8576) Login failed
              mihome-vacuum.1	2021-06-13 13:50:44.421	info	(8582) Map selected create states...
              mihome-vacuum.1	2021-06-13 13:50:44.191	warn	(8582) Login failed
              mihome-vacuum.0	2021-06-13 13:50:43.462	info	(8576) settest next timer: not available
              mihome-vacuum.0	2021-06-13 13:50:42.897	info	(8576) select standard vacuum protocol....
              mihome-vacuum.0	2021-06-13 13:50:42.853	info	(8576) IOT disabled, delete state
              mihome-vacuum.1	2021-06-13 13:50:42.777	info	(8582) settest next timer: not available
              mihome-vacuum.0	2021-06-13 13:50:42.683	info	(8576) check group user admin group admin: false
              mihome-vacuum.0	2021-06-13 13:50:42.626	info	(8576) check user admin pw iobroker: true
              mihome-vacuum.0	2021-06-13 13:50:42.166	info	(8576) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.22.1, js-controller: 3.2.16
              mihome-vacuum.1	2021-06-13 13:50:42.152	info	(8582) select standard vacuum protocol....
              mihome-vacuum.1	2021-06-13 13:50:42.124	info	(8582) IOT disabled, delete state
              mihome-vacuum.0	2021-06-13 13:50:42.012	info	(8576) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              mihome-vacuum.1	2021-06-13 13:50:41.881	info	(8582) check group user admin group admin: false
              mihome-vacuum.1	2021-06-13 13:50:41.765	info	(8582) check user admin pw iobroker: true
              mihome-vacuum.1	2021-06-13 13:50:41.285	info	(8582) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.22.1, js-controller: 3.2.16
              mihome-vacuum.1	2021-06-13 13:50:41.174	info	(8582) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              MeistertrM 1 Antwort Letzte Antwort
              • haselchenH haselchen
                @Meistertr
                MeistertrM Offline
                MeistertrM Offline
                Meistertr
                schrieb am zuletzt editiert von Meistertr
                #226
                @haselchen du musst das passwort neu eingeben. Steht auch im changelog
                haselchenH F 3 Antworten Letzte Antwort
                • MeistertrM Meistertr
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  #227
                  @meistertr
                  Als wenn ich das nicht nach so einer Meldung machen würde ;)
                  Ergebnis blieb und bleibt das Gleiche.
                  Warum bekomme ich mit der 2.1.1 eigentlich die Map nicht mehr angezeigt bzw. ausgelesen?
                    Frank579
                    #228
                    @meistertr konntest du dir meinen log schon ansehen ? Sind noch immer keine Räume da 😔
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      #229
                      @meistertr
                      Habe alles nochmal neu aufgesetzt in der Mihome App.
                      Dann nochmal über die 2.1.1 die 3.2.0 installiert.
                      Hab noch nicht alles getestet, aber Verbindung ist da und die Datenpunkte werden aktualisiert.
                      Auch von mir ein Danke, dass Du Deine Freizeit diesem Projekt widmest!
                        @meistertr
                        tobitobsta
                        #230
                        @haselchen bei map hat sich der Datenpunkt geändert - dennoch hab ich es noch nicht bis ins VIS geschafft - aber die URL konnte ich bereits laden und die Map auch sehen.
                        das Thema Problem mit den Räumen habe ich auch (siehe ein paar Posts weiter oben). Habe auch den S5 - kann es daran tatsächlich liegen?
                        • haselchenH Offline
                          haselchenH Offline
                          haselchen
                          #231
                          @tobitobsta
                          Soweit läuft alles wieder bei mir.
                          Durch das drüber installieren sind die alten Einstellungen geblieben.
                          Map hat er geladen und erscheint auch in der VIS.
                            saeft_2003
                            schrieb am zuletzt editiert von saeft_2003
                            #232
                            @Meistertr
                            Ich habe jetzt das regelmäßig der Adapter (version 3.2.0) crasht. Weißt du an was das liegen könnte?
                            Heute:
                            host.iobroker	2021-06-25 15:13:59.568	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at UDP.onMessage (dgram.js:921:8)
                            host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
                            host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at Socket.emit (events.js:326:22)
                            host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at Socket.checkAnswer (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:146:62)
                            host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at _Packet.getPlainData (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:310:19)
                            host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at Decipheriv.final (internal/crypto/cipher.js:172:29)
                            host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at Object.final (<anonymous>)
                            host.iobroker	2021-06-25 15:13:59.565	error	Caught by controller[0]: Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                            mihome-vacuum.0	2021-06-25 15:13:59.281	error	(15936) Exception-Code: ERR_OSSL_EVP_BAD_DECRYPT: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                            mihome-vacuum.0	2021-06-25 15:13:59.281	error	at UDP.onMessage (dgram.js:921:8)
                            mihome-vacuum.0	2021-06-25 15:13:59.281	error	at Socket.EventEmitter.emit (domain.js:483:12)
                            mihome-vacuum.0	2021-06-25 15:13:59.281	error	at Socket.emit (events.js:326:22)
                            mihome-vacuum.0	2021-06-25 15:13:59.281	error	at Socket.checkAnswer (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:146:62)
                            mihome-vacuum.0	2021-06-25 15:13:59.281	error	at _Packet.getPlainData (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:310:19)
                            mihome-vacuum.0	2021-06-25 15:13:59.281	error	at Decipheriv.final (internal/crypto/cipher.js:172:29)
                            mihome-vacuum.0	2021-06-25 15:13:59.281	error	at Object.final (<anonymous>)
                            mihome-vacuum.0	2021-06-25 15:13:59.281	error	(15936) Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                            mihome-vacuum.0	2021-06-25 15:13:59.277	error	(15936) uncaught exception: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                            Gestern:
                            2021-06-24 16:30:54.310 - error: mihome-vacuum.0 (10285) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2021-06-24 16:30:54.319 - error: mihome-vacuum.0 (10285) unhandled promise rejection: undefined
                            2021-06-24 16:30:54.319 - error: mihome-vacuum.0 (10285) undefined
                            2021-06-24 16:30:54.937 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                            2021-06-24 16:30:54.938 - error: host.iobroker Caught by controller[1]: MESSAGE TIMEOUT
                            2021-06-24 16:30:54.939 - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            @ all
                            Habt ihr crashs?
                            • S saeft_2003
                              @Meistertr
                              Heute:
                              Gestern:
                              @ all
                              Habt ihr crashs?
                              #233
                              @saeft_2003 Hier crasht nix.
                              Wann passiert es denn bei dir? Wenn der Roboter aktiv ist?
                              S 2 Antworten Letzte Antwort
                                saeft_2003
                                #234
                                Ja nur wenn er aktiv ist sonst nicht.
                                  saeft_2003
                                  #235
                                  @thomas-braun @Meistertr
                                  Gerade war er aktiv und es gab wieder einen crash. Ich kann mir nicht erklären an was das liegt?
                                  host.iobroker	2021-06-29 08:44:16.591	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  host.iobroker	2021-06-29 08:44:16.591	error	Caught by controller[0]: at UDP.onMessage (dgram.js:921:8)
                                  host.iobroker	2021-06-29 08:44:16.591	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
                                  host.iobroker	2021-06-29 08:44:16.591	error	Caught by controller[0]: at Socket.emit (events.js:326:22)
                                  host.iobroker	2021-06-29 08:44:16.590	error	Caught by controller[0]: at Socket.checkAnswer (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:146:62)
                                  host.iobroker	2021-06-29 08:44:16.590	error	Caught by controller[0]: at _Packet.getPlainData (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:310:19)
                                  host.iobroker	2021-06-29 08:44:16.590	error	Caught by controller[0]: at Decipheriv.final (internal/crypto/cipher.js:172:29)
                                  host.iobroker	2021-06-29 08:44:16.590	error	Caught by controller[0]: at Object.final (<anonymous>)
                                  host.iobroker	2021-06-29 08:44:16.588	error	Caught by controller[0]: Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                  mihome-vacuum.0	2021-06-29 08:44:16.287	error	(27481) Exception-Code: ERR_OSSL_EVP_BAD_DECRYPT: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                  mihome-vacuum.0	2021-06-29 08:44:16.287	error	at UDP.onMessage (dgram.js:921:8)
                                  mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Socket.EventEmitter.emit (domain.js:483:12)
                                  mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Socket.emit (events.js:326:22)
                                  mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Socket.checkAnswer (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:146:62)
                                  mihome-vacuum.0	2021-06-29 08:44:16.287	error	at _Packet.getPlainData (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:310:19)
                                  mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Decipheriv.final (internal/crypto/cipher.js:172:29)
                                  mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Object.final (<anonymous>)
                                  mihome-vacuum.0	2021-06-29 08:44:16.287	error	(27481) Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                  mihome-vacuum.0	2021-06-29 08:44:16.284	error	(27481) uncaught exception: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                  Thomas BraunT MeistertrM apollon77A 3 Antworten Letzte Antwort
                                  • S saeft_2003
                                    #236
                                    @saeft_2003 sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                                    Da gibt es wohl Probleme mit der Entschlüsselung eines Passwortes.
                                    Hast du da 'Sonderzeichen' drin oder ist das besonders lang?
                                    Änder das mal zum testen auf was simpleres.
                                      saeft_2003
                                      #237
                                      Danke für die Info. Das Passwort sollte eigentlich recht simpel sein. Besteht aus 8 Zeichen und das sind nur normale Buchstaben und Zahlen.
                                      Würde es testweise Sinn machen den Adapter mal auf einem anderen Host laufen zu lassen?
                                      • S saeft_2003
                                        #238
                                        normale Buchstaben
                                        Mit Umlauten wie öäü?
                                        Wie sieht deine node-Installation aus?
                                        which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                                          normale Buchstaben
                                          saeft_2003
                                          #239
                                          @thomas-braun sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                                          Nein keine Umlaute. Hier die Ausgabe.
                                          patrick@iobroker:~$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          v12.21.0
                                          v12.21.0
                                          6.14.11
                                          [sudo] Passwort für patrick:
                                          Holen:1 http://security.debian.org/debian-security stretch/updates InRelease [53,0 kB]
                                          Ign:2 http://ftp.de.debian.org/debian stretch InRelease
                                          Holen:3 http://ftp.de.debian.org/debian stretch-updates InRelease [93,6 kB]
                                          Holen:4 https://deb.nodesource.com/node_12.x stretch InRelease [4.585 B]
                                          OK:5 http://ftp.de.debian.org/debian stretch Release
                                          Holen:6 http://security.debian.org/debian-security stretch/updates/main Sources [359 kB]
                                          Holen:7 http://security.debian.org/debian-security stretch/updates/main amd64 Packages [697 kB]
                                          Holen:8 http://security.debian.org/debian-security stretch/updates/main Translation-en [320 kB]
                                          Holen:9 https://deb.nodesource.com/node_12.x stretch/main amd64 Packages [766 B]
                                          Es wurden 1.528 kB in 0 s geholt (2.122 kB/s).
                                          Aktualisierung für 49 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                          OK:1 http://security.debian.org/debian-security stretch/updates InRelease
                                          OK:3 https://deb.nodesource.com/node_12.x stretch InRelease
                                          OK:4 http://ftp.de.debian.org/debian stretch-updates InRelease
                                          nodejs:
                                            Installiert:           12.21.0-1nodesource1
                                            Installationskandidat: 12.22.1-1nodesource1
                                            Versionstabelle:
                                               12.22.1-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_12.x stretch/main amd64 Packages
                                           *** 12.21.0-1nodesource1 100
                                               4.8.2~dfsg-1 500
                                                  500 http://ftp.de.debian.org/debian stretch/main amd64 Packages
                                          patrick@iobroker:~$
