  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.6k
1.2k Beiträge 100 Kommentatoren 504.2k Aufrufe 82 Beobachtet
  • MeistertrM Meistertr
    @frank579 welches modell? bitte einen debug logauszug vom start
    Frank579
    #218
    @meistertr
    Hier noch den Log :)
    2021-06-03 20:28:51.080 - debug: mihome-vacuum.0 (4034) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-06-03 20:28:51.108 - debug: mihome-vacuum.0 (4034) Objects client ready ... initialize now
    2021-06-03 20:28:51.110 - debug: mihome-vacuum.0 (4034) Objects create System PubSub Client
    2021-06-03 20:28:51.118 - debug: mihome-vacuum.0 (4034) Objects create User PubSub Client
    2021-06-03 20:28:51.118 - debug: mihome-vacuum.0 (4034) Objects client initialize lua scripts
    2021-06-03 20:28:51.126 - debug: mihome-vacuum.0 (4034) Objects connected to redis: 127.0.0.1:9001
    2021-06-03 20:28:51.129 - debug: mihome-vacuum.0 (4034) objectDB connected
    2021-06-03 20:28:51.130 - debug: mihome-vacuum.0 (4034) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-06-03 20:28:51.134 - debug: mihome-vacuum.0 (4034) States create System PubSub Client
    2021-06-03 20:28:51.134 - debug: mihome-vacuum.0 (4034) States create User PubSub Client
    2021-06-03 20:28:51.139 - debug: mihome-vacuum.0 (4034) States connected to redis: 127.0.0.1:9000
    2021-06-03 20:28:51.140 - debug: mihome-vacuum.0 (4034) statesDB connected
    2021-06-03 20:28:51.338 - debug: mihome-vacuum.0 (4034) Plugin sentry Initialize Plugin (enabled=true)
    2021-06-03 20:28:51.423 - info: mihome-vacuum.0 (4034) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.22.1, js-controller: 3.2.16
    2021-06-03 20:28:51.529 - info: mihome-vacuum.0 (4034) check user admin pw iobroker: true
    2021-06-03 20:28:51.531 - info: mihome-vacuum.0 (4034) check group user admin group admin: false
    2021-06-03 20:28:51.542 - debug: mihome-vacuum.0 (4034) load Map creator... true
    2021-06-03 20:28:51.545 - debug: mihome-vacuum.0 (4034) Create State for deviceInfomac
    2021-06-03 20:28:51.546 - debug: mihome-vacuum.0 (4034) Create State for deviceInfomodel
    2021-06-03 20:28:51.546 - debug: mihome-vacuum.0 (4034) Create State for deviceInfofw_ver
    2021-06-03 20:28:51.546 - debug: mihome-vacuum.0 (4034) Create State for deviceInfowifi_signal
    2021-06-03 20:28:51.546 - debug: mihome-vacuum.0 (4034) MIIO: Config: ip:192.168.50.41 token: XXXXXXXXX
    2021-06-03 20:28:51.548 - info: mihome-vacuum.0 (4034) IOT disabled, delete state
    2021-06-03 20:28:51.549 - debug: mihome-vacuum.0 (4034) server started on 0.0.0.0:53421
    2021-06-03 20:28:51.557 - debug: mihome-vacuum.0 (4034) Receive <<< Helo <<< 2131002000000000131824dc60b91f63ffffffffffffffffffffffffffffffff
    2021-06-03 20:28:51.557 - debug: mihome-vacuum.0 (4034) MAIN: Connected to device, try to get model..
    2021-06-03 20:28:51.560 - debug: mihome-vacuum.0 (4034) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1622744524482,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1622713779552}
    2021-06-03 20:28:51.560 - debug: mihome-vacuum.0 (4034) Message= {"id":1,"method":"miIO.info"}
    2021-06-03 20:28:51.566 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1410","ap":{"ssid":"SmartHome","bssid":"e2:63:da:6e:c7:8d","rssi":-83},"netif":{"localIp":"192.168.50.41","mask":"255.255.255.0","gw":"192.168.50.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"64:90:C1:02:20:BF","token":"XXXXXXXXXXXXXXX","life":62521}}
    2021-06-03 20:28:51.566 - debug: mihome-vacuum.0 (4034) GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1410","ap":{"ssid":"SmartHome","bssid":"e2:63:da:6e:c7:8d","rssi":-83},"netif":{"localIp":"192.168.50.41","mask":"255.255.255.0","gw":"192.168.50.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"64:90:C1:02:20:BF","token":"XXXXXXXXXXXX","life":62521}}
    2021-06-03 20:28:51.566 - debug: mihome-vacuum.0 (4034) Get Device data..0
    2021-06-03 20:28:51.566 - debug: mihome-vacuum.0 (4034) Get Device data from robot..
    2021-06-03 20:28:51.567 - debug: mihome-vacuum.0 (4034) DeviceModel selected to: roborock.vacuum.s5e
    2021-06-03 20:28:51.567 - info: mihome-vacuum.0 (4034) select standard vacuum protocol....
    2021-06-03 20:28:51.569 - debug: mihome-vacuum.0 (4034) Xiaomi Cloud: Logging in
    2021-06-03 20:28:51.603 - debug: mihome-vacuum.0 (4034) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2021-06-03 20:28:52.074 - info: mihome-vacuum.0 (4034) settest next timer: not available
    2021-06-03 20:28:52.658 - debug: mihome-vacuum.0 (4034) Login step1: &&&START&&&{"result":"error","serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","securityStatus":0,"pwd":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","desc":"登录验证失败"}
    2021-06-03 20:28:53.535 - debug: mihome-vacuum.0 (4034) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"o3W5w1oCXFHVd1aHvZNi3Q==","code":0,"passToken":"V1:bVc+HLNQkn0wITZpdR20IOLv1XQtV1PICexQU7S61KGti5bw/7h3oYzN/j+L5+9zp10jf/8sxzW0rGLKEhXYPwpua4SIjFmOm17RxnV1GiPsIZ2z97jAtSepjnTJ1kgGrO79ZZv9s7+eTQ7kxY+oPJGl1ptFHmy9lyPX0rsRwZOtkAoBEsGMaC5XrQPc9eTM8IYKvL1rlKD2u81VRQyA+j7HqPZV/tpXWdCGfSWAcbFXtRRR0CDsEi9YhQAq4O9f8UFazaQhBNJD/PQqxAzo3TUXFgzjQiMu4t7i9UxKPYU=","securityStatus":0,"nonce":4582086323101018112,"userId":6353965320,"cUserId":"2Xh3BEW_HsDJAdUD4fg6WPU8B0A","result":"ok","psecurity":"Kp+ASNrVyl7bjsWoDxRmPw==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=rpadrj&ticket=0&pwd=1&p_ts=1622744933000&fid=0&p_lm=1&auth=at58%2FopYpD2bVeqpJ3C6bhdjUAG6Of72aRZiSaz%2BOXbxfC%2F8H9ffGwzKqaYi6WRY1C1u5RMqcig%2Bl0QUSTZZy5stz%2F%2BoKun12OecRFSi7XdMkbhXZEY1IofUhqLzD3mKOLO6%2BMB3ocXRq%2BLNy4T5c6RNwi1tsI14MUJvKq%2FWJgE%3D&m=1&tsl=0&nonce=9pCgOu31CK4BnK90&_ssign=0pV2Q70xZSwecm1Qdu7eHxtblCk%3D","pwd":1,"desc":"成功"}
    2021-06-03 20:28:53.665 - debug: mihome-vacuum.0 (4034) Login step3: [{"key":"userId","value":"6353965320","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2021-06-03T18:28:53.654Z","lastAccessed":"2021-06-03T18:28:53.665Z"},{"key":"cUserId","value":"2Xh3BEW_HsDJAdUD4fg6WPU8B0A","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2021-06-03T18:28:53.660Z","lastAccessed":"2021-06-03T18:28:53.665Z"},{"key":"serviceToken","value":"u4XTQ/K8NyjIh6l2H9fTFPpzG4cKaMMHxXbqDwMz4GPBGFXvl3E4RB7R2RVOJ5l/vzz1LzxuEWvHxXa7wRGB9UZhqIKm5pZQO2FpjJZMcc4HWHK7nnOzXaXZe8YoB+MN94ZnL85roewPeIZxNDwm8d3Zn/DcSKel5StGAUTUpBM=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2021-06-03T18:28:53.662Z","lastAccessed":"2021-06-03T18:28:53.665Z"}]
    2021-06-03 20:28:53.665 - debug: mihome-vacuum.0 (4034) Xiaomi Cloud: Login successful
    2021-06-03 20:28:53.670 - debug: mihome-vacuum.0 (4034) Create State for deviceInfoundefined
    2021-06-03 20:28:53.671 - debug: mihome-vacuum.0 (4034) Create State for deviceInfoundefined
    2021-06-03 20:28:53.672 - debug: mihome-vacuum.0 (4034) Create State for deviceInfoundefined
    2021-06-03 20:28:53.683 - debug: mihome-vacuum.0 (4034) Create State for stockInfoundefined
    2021-06-03 20:28:53.686 - debug: mihome-vacuum.0 (4034) Create State for stockInfoundefined
    2021-06-03 20:28:53.687 - debug: mihome-vacuum.0 (4034) Create State for stockInfoundefined
    2021-06-03 20:28:53.690 - debug: mihome-vacuum.0 (4034) Create State for stockConsumableundefined
    2021-06-03 20:28:53.691 - debug: mihome-vacuum.0 (4034) Create State for stockConsumableundefined
    2021-06-03 20:28:53.697 - debug: mihome-vacuum.0 (4034) Create State for stockHistoryundefined
    2021-06-03 20:28:53.698 - debug: mihome-vacuum.0 (4034) Create State for stockHistoryundefined
    2021-06-03 20:28:53.702 - debug: mihome-vacuum.0 (4034) Create State for Queue: queue
    2021-06-03 20:28:53.702 - debug: mihome-vacuum.0 (4034) Create State for Queue: clearQueue
    2021-06-03 20:28:53.704 - debug: mihome-vacuum.0 (4034) Create State for enableResumeZoneundefined
    2021-06-03 20:28:53.704 - info: mihome-vacuum.0 (4034) Map selected create states...
    2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State for map: map64
    2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State for map: actualMap
    2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State for map: mapStatus
    2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State for map: mapURL
    2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State for map: loadMap
    2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State done!
    2021-06-03 20:28:53.709 - debug: mihome-vacuum.0 (4034) get params for stock Vacuum
    2021-06-03 20:28:53.709 - debug: mihome-vacuum.0 (4034) Message= {"id":2,"method":"get_status"}
    2021-06-03 20:28:53.717 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":3367,"state":8,"battery":100,"clean_time":332,"clean_area":5422500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":106,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"water_box_carriage_status":1,"mop_forbidden_enable":1}],"id":2}
    2021-06-03 20:28:53.717 - debug: mihome-vacuum.0 (4034) setGetStatus {"msg_ver":2,"msg_seq":3367,"state":8,"battery":100,"clean_time":332,"clean_area":5422500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":106,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"water_box_carriage_status":1,"mop_forbidden_enable":1,"error_text":"No error"}
    2021-06-03 20:28:53.717 - info: mihome-vacuum.0 (4034) change states from State control.fan_power
    2021-06-03 20:28:53.729 - info: mihome-vacuum.0 (4034) create states for water box
    2021-06-03 20:28:53.730 - info: mihome-vacuum.0 (4034) create states for water box mode
    2021-06-03 20:28:53.731 - info: mihome-vacuum.0 (4034) create states for mop
    2021-06-03 20:28:53.793 - debug: mihome-vacuum.0 (4034) Message= {"id":3,"method":"get_map_v1"}
    2021-06-03 20:28:53.801 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":["retry"],"id":3}
    2021-06-03 20:28:54.101 - debug: mihome-vacuum.0 (4034) Message= {"id":4,"method":"get_map_v1"}
    2021-06-03 20:28:54.108 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":["retry"],"id":4}
    2021-06-03 20:28:54.408 - debug: mihome-vacuum.0 (4034) Message= {"id":5,"method":"get_map_v1"}
    2021-06-03 20:28:54.415 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":["rubyslite%2F320349404%2F7"],"id":5}
    2021-06-03 20:28:54.416 - debug: mihome-vacuum.0 (4034) Mappointer_updated
    2021-06-03 20:28:54.416 - debug: mihome-vacuum.0 (4034) update_Map Mimap enabled
    2021-06-03 20:28:54.416 - debug: mihome-vacuum.0 (4034) update_Map need new mapurl
    2021-06-03 20:28:54.418 - debug: mihome-vacuum.0 (4034) Message= {"id":6,"method":"get_room_mapping"}
    2021-06-03 20:28:54.427 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[],"id":6}
    2021-06-03 20:28:54.427 - debug: mihome-vacuum.0 (4034) Message= {"id":7,"method":"get_consumable"}
    2021-06-03 20:28:54.428 - debug: mihome-vacuum.0 (4034) Message= {"id":8,"method":"get_network_info"}
    2021-06-03 20:28:54.437 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"main_brush_work_time":69237,"side_brush_work_time":69237,"filter_work_time":69237,"filter_element_work_time":59372,"sensor_dirty_time":69219}],"id":7}
    2021-06-03 20:28:54.437 - debug: mihome-vacuum.0 (4034) Message= {"id":9,"method":"get_clean_summary"}
    2021-06-03 20:28:54.454 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":{"ssid":"SmartHome","ip":"192.168.50.41","mac":"64:90:c1:02:20:bf","bssid":"e2:63:da:6e:c7:8d","rssi":-81},"id":8}
    2021-06-03 20:28:54.459 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[69219,1176440000,49,[1622711457,1622709889,1621759219,1621757141,1621754893,1621158710,1620568308,1619975461,1619949343,1618733615,1616845998,1615721681,1615127170,1614445195,1613896540,1612608025,1612000844,1611384765,1610874479,1610280635]],"id":9}
    2021-06-03 20:28:54.460 - debug: mihome-vacuum.0 (4034) Message= {"id":10,"method":"get_clean_record","params":[1622711457]}
    2021-06-03 20:28:54.464 - debug: mihome-vacuum.0 (4034) Message= {"id":11,"method":"get_sound_volume"}
    2021-06-03 20:28:54.472 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1622711457,1622711789,332,5422500,0,1,2,3,56]],"id":10}
    2021-06-03 20:28:54.472 - debug: mihome-vacuum.0 (4034) Message= {"id":12,"method":"get_clean_record","params":[1622709889]}
    2021-06-03 20:28:54.473 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[62],"id":11}
    2021-06-03 20:28:54.473 - debug: mihome-vacuum.0 (4034) Message= {"id":13,"method":"get_multi_maps_list"}
    2021-06-03 20:28:54.482 - debug: mihome-vacuum.0 (4034) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320349404/7?Expires=1622746734000&GalaxyAccessKeyId=5271733786445&Signature=W1R8N53zTY3P7ZdS+Emboe4UQmA=
    2021-06-03 20:28:54.482 - debug: mihome-vacuum.0 (4034) update_Map got new expires:1622746734
    2021-06-03 20:28:54.482 - debug: mihome-vacuum.0 (4034) update_Map got new time:1622744934
    2021-06-03 20:28:54.489 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1622709889,1622710194,305,5252500,0,1,2,3,56]],"id":12}
    2021-06-03 20:28:54.489 - debug: mihome-vacuum.0 (4034) Message= {"id":14,"method":"get_clean_record","params":[1621759219]}
    2021-06-03 20:28:54.490 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"max_multi_map":4,"max_bak_map":0,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1621757005,"length":12,"name":"Obergeschoss","bak_maps":[]}]}],"id":13}
    2021-06-03 20:28:54.490 - debug: mihome-vacuum.0 (4034) States for 1 Map: [{"mapFlag":0,"add_time":1621757005,"length":12,"name":"Obergeschoss","bak_maps":[]}]
    2021-06-03 20:28:54.490 - debug: mihome-vacuum.0 (4034) States for Map: {"0":"Obergeschoss"}
    2021-06-03 20:28:54.491 - debug: mihome-vacuum.0 (4034) Startup: getMultiMapsList Anser: true
    2021-06-03 20:28:54.491 - debug: mihome-vacuum.0 (4034) Startup: Delete getMultiMapsList
    2021-06-03 20:28:54.491 - debug: mihome-vacuum.0 (4034) Message= {"id":15,"method":"get_clean_summary"}
    2021-06-03 20:28:54.497 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1621759219,1621759912,693,6577500,0,1,2,3,56]],"id":14}
    2021-06-03 20:28:54.497 - debug: mihome-vacuum.0 (4034) Message= {"id":16,"method":"get_clean_record","params":[1621757141]}
    2021-06-03 20:28:54.511 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[69219,1176440000,49,[1622711457,1622709889,1621759219,1621757141,1621754893,1621158710,1620568308,1619975461,1619949343,1618733615,1616845998,1615721681,1615127170,1614445195,1613896540,1612608025,1612000844,1611384765,1610874479,1610280635]],"id":15}
    2021-06-03 20:28:54.511 - debug: mihome-vacuum.0 (4034) Startup: setGetCleanSummary Anser: true
    2021-06-03 20:28:54.511 - debug: mihome-vacuum.0 (4034) Startup: Delete setGetCleanSummary
    2021-06-03 20:28:54.511 - debug: mihome-vacuum.0 (4034) Message= {"id":17,"method":"get_consumable"}
    2021-06-03 20:28:54.512 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1621757141,1621757598,457,8490000,0,1,2,3,56]],"id":16}
    2021-06-03 20:28:54.512 - debug: mihome-vacuum.0 (4034) Message= {"id":18,"method":"get_clean_record","params":[1621754893]}
    2021-06-03 20:28:54.522 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"main_brush_work_time":69237,"side_brush_work_time":69237,"filter_work_time":69237,"filter_element_work_time":59372,"sensor_dirty_time":69219}],"id":17}
    2021-06-03 20:28:54.525 - debug: mihome-vacuum.0 (4034) Startup: setGetConsumable Anser: true
    2021-06-03 20:28:54.526 - debug: mihome-vacuum.0 (4034) Startup: Delete setGetConsumable
    2021-06-03 20:28:54.526 - debug: mihome-vacuum.0 (4034) Message= {"id":19,"method":"get_map_v1"}
    2021-06-03 20:28:54.526 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1621754893,1621756979,2086,35620000,0,1,2,1,52]],"id":18}
    2021-06-03 20:28:54.526 - debug: mihome-vacuum.0 (4034) Message= {"id":20,"method":"get_clean_record","params":[1621158710]}
    2021-06-03 20:28:54.534 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":["rubyslite%2F320349404%2F7"],"id":19}
    2021-06-03 20:28:54.535 - debug: mihome-vacuum.0 (4034) Mappointer_updated
    2021-06-03 20:28:54.535 - debug: mihome-vacuum.0 (4034) update_Map Mimap enabled
    2021-06-03 20:28:54.535 - debug: mihome-vacuum.0 (4034) update_Map use old mapurl
    2021-06-03 20:28:54.535 - debug: mihome-vacuum.0 (4034) Message= {"id":21,"method":"get_carpet_mode"}
    2021-06-03 20:28:54.536 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1621158710,1621160901,2191,35707500,0,1,2,1,52]],"id":20}
    2021-06-03 20:28:54.536 - debug: mihome-vacuum.0 (4034) Message= {"id":22,"method":"get_clean_record","params":[1620568308]}
    2021-06-03 20:28:54.551 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":21}
    2021-06-03 20:28:54.551 - info: mihome-vacuum.0 (4034) create state for carpet_mode
    2021-06-03 20:28:54.551 - debug: mihome-vacuum.0 (4034) Message= {"id":23,"method":"get_carpet_mode"}
    2021-06-03 20:28:54.552 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1620568308,1620570593,2285,36180000,0,1,2,1,52]],"id":22}
    2021-06-03 20:28:54.552 - debug: mihome-vacuum.0 (4034) Message= {"id":24,"method":"get_clean_record","params":[1619975461]}
    2021-06-03 20:28:54.565 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":23}
    2021-06-03 20:28:54.566 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1619975461,1619975962,501,6510000,0,1,2,3,56]],"id":24}
    2021-06-03 20:28:54.566 - debug: mihome-vacuum.0 (4034) Message= {"id":25,"method":"get_clean_record","params":[1619949343]}
    2021-06-03 20:28:54.574 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1619949343,1619951478,2135,35587500,0,1,2,1,52]],"id":25}
    2021-06-03 20:28:54.575 - debug: mihome-vacuum.0 (4034) Message= {"id":26,"method":"get_clean_record","params":[1618733615]}
    2021-06-03 20:28:54.582 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1618733615,1618735576,1961,35317500,0,1,2,1,52]],"id":26}
    2021-06-03 20:28:54.584 - debug: mihome-vacuum.0 (4034) Message= {"id":27,"method":"get_clean_record","params":[1616845998]}
    2021-06-03 20:28:54.649 - debug: mihome-vacuum.0 (4034) 25401
    2021-06-03 20:28:54.787 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1616845998,1616848181,2183,36225000,0,1,2,1,52]],"id":27}
    2021-06-03 20:28:54.787 - debug: mihome-vacuum.0 (4034) Message= {"id":28,"method":"get_clean_record","params":[1615721681]}
    2021-06-03 20:28:54.800 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1615721681,1615723823,2142,36732500,0,1,2,1,52]],"id":28}
    2021-06-03 20:28:54.800 - debug: mihome-vacuum.0 (4034) Message= {"id":29,"method":"get_clean_record","params":[1615127170]}
    2021-06-03 20:28:54.810 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1615127170,1615129241,2071,36080000,0,1,2,1,52]],"id":29}
    2021-06-03 20:28:54.811 - debug: mihome-vacuum.0 (4034) Message= {"id":30,"method":"get_clean_record","params":[1614445195]}
    2021-06-03 20:28:54.816 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1614445195,1614447210,2015,35935000,0,1,2,1,52]],"id":30}
    2021-06-03 20:28:54.817 - debug: mihome-vacuum.0 (4034) Message= {"id":31,"method":"get_clean_record","params":[1613896540]}
    2021-06-03 20:28:54.825 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1613896540,1613898735,2195,36522500,0,1,2,1,52]],"id":31}
    2021-06-03 20:28:54.825 - debug: mihome-vacuum.0 (4034) Message= {"id":32,"method":"get_clean_record","params":[1612608025]}
    2021-06-03 20:28:54.891 - debug: mihome-vacuum.0 (4034) 25401
    2021-06-03 20:28:55.030 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1612608025,1612610154,2129,36230000,0,1,2,1,52]],"id":32}
    2021-06-03 20:28:55.030 - debug: mihome-vacuum.0 (4034) Message= {"id":33,"method":"get_clean_record","params":[1612000844]}
    2021-06-03 20:28:55.051 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1612000844,1612002933,2089,36487500,0,1,2,1,52]],"id":33}
    2021-06-03 20:28:55.051 - debug: mihome-vacuum.0 (4034) Message= {"id":34,"method":"get_clean_record","params":[1611384765]}
    2021-06-03 20:28:55.057 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1611384765,1611386844,2079,36262500,0,1,2,1,52]],"id":34}
    2021-06-03 20:28:55.057 - debug: mihome-vacuum.0 (4034) Message= {"id":35,"method":"get_clean_record","params":[1610874479]}
    2021-06-03 20:28:55.066 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1610874479,1610877149,2670,35790000,0,1,2,1,52]],"id":35}
    2021-06-03 20:28:55.066 - debug: mihome-vacuum.0 (4034) Message= {"id":36,"method":"get_clean_record","params":[1610280635]}
    2021-06-03 20:28:55.072 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1610280635,1610280980,345,6717500,0,1,2,3,56]],"id":36}
    2021-06-03 20:28:55.073 - debug: mihome-vacuum.0 (4034) finish logs all [{"Datum":"3.6","Start":"11:10","Saugzeit":"6 min","Fläche":"5.42 m²","Error":0,"Ende":true},{"Datum":"3.6","Start":"10:44","Saugzeit":"5 min","Fläche":"5.25 m²","Error":0,"Ende":true},{"Datum":"23.5","Start":"10:40","Saugzeit":"12 min","Fläche":"6.58 m²","Error":0,"Ende":true},{"Datum":"23.5","Start":"10:05","Saugzeit":"8 min","Fläche":"8.49 m²","Error":0,"Ende":true},{"Datum":"23.5","Start":"09:28","Saugzeit":"35 min","Fläche":"35.62 m²","Error":0,"Ende":true},{"Datum":"16.5","Start":"11:51","Saugzeit":"37 min","Fläche":"35.71 m²","Error":0,"Ende":true},{"Datum":"9.5","Start":"15:51","Saugzeit":"38 min","Fläche":"36.18 m²","Error":0,"Ende":true},{"Datum":"2.5","Start":"19:11","Saugzeit":"8 min","Fläche":"6.51 m²","Error":0,"Ende":true},{"Datum":"2.5","Start":"11:55","Saugzeit":"36 min","Fläche":"35.59 m²","Error":0,"Ende":true},{"Datum":"18.4","Start":"10:13","Saugzeit":"33 min","Fläche":"35.32 m²","Error":0,"Ende":true},{"Datum":"27.3","Start":"12:53","Saugzeit":"36 min","Fläche":"36.23 m²","Error":0,"Ende":true},{"Datum":"14.3","Start":"12:34","Saugzeit":"36 min","Fläche":"36.73 m²","Error":0,"Ende":true},{"Datum":"7.3","Start":"15:26","Saugzeit":"35 min","Fläche":"36.08 m²","Error":0,"Ende":true},{"Datum":"27.2","Start":"17:59","Saugzeit":"34 min","Fläche":"35.94 m²","Error":0,"Ende":true},{"Datum":"21.2","Start":"09:35","Saugzeit":"37 min","Fläche":"36.52 m²","Error":0,"Ende":true},{"Datum":"6.2","Start":"11:40","Saugzeit":"35 min","Fläche":"36.23 m²","Error":0,"Ende":true},{"Datum":"30.1","Start":"11:00","Saugzeit":"35 min","Fläche":"36.49 m²","Error":0,"Ende":true},{"Datum":"23.1","Start":"07:52","Saugzeit":"35 min","Fläche":"36.26 m²","Error":0,"Ende":true},{"Datum":"17.1","Start":"10:07","Saugzeit":"45 min","Fläche":"35.79 m²","Error":0,"Ende":true},{"Datum":"10.1","Start":"13:10","Saugzeit":"6 min","Fläche":"6.72 m²","Error":0,"Ende":true}]
    2021-06-03 20:29:01.561 - debug: mihome-vacuum.0 (4034) Receive <<< Helo <<< 2131002000000000131824dc60b91f6dffffffffffffffffffffffffffffffff
    2021-06-03 20:29:11.567 - debug: mihome-vacuum.0 (4034) Receive <<< Helo <<< 2131002000000000131824dc60b91f77ffffffffffffffffffffffffffffffff
    2021-06-03 20:29:12.816 - info: mihome-vacuum.0 (4034) Got terminate signal TERMINATE_YOURSELF
    2021-06-03 20:29:12.816 - info: mihome-vacuum.0 (4034) terminating
    2021-06-03 20:29:12.816 - debug: mihome-vacuum.0 (4034) Plugin sentry destroyed
    2021-06-03 20:29:12.817 - info: mihome-vacuum.0 (4034) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      @saeft_2003 ich kann nur immer wieder betonen, dass die liste lang ist die ich umsetzten will,. also kann es in ein paar Wochen oder Monaten kommen
      saeft_2003
      #219
      @meistertr sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
      Alles klar das verstehe ich natürlich. Falls ich bei irgendwelchen simplen Sachen helfen kann was dazu hilft den Zyklus zu integrieren, dann sag Bescheid.
      • U Offline
        U Offline
        UHT
        #220
        gibt es das vis widget nicht mehr?
        • Ronny GerndtR Offline
          Ronny Gerndt
          #221
          hab seit letzter Wochen einen Roborock S7 und wollte den mit iobroker verbinden.
          Die Verbindung bekomme ich soweit auch hin. Token usw. hat geklappt.
          Ich habe Version 3.20 am laufen und bekomme in endlosschleife diese Log Ausgaben.
          mihome-vacuum.0	2021-06-07 10:11:32.591	debug	(17421) Helo message Timeout
          mihome-vacuum.0	2021-06-07 10:11:20.589	debug	(17421) Time difference between Mihome Vacuum and ioBroker: -1623027974 sec
          mihome-vacuum.0	2021-06-07 10:11:20.588	debug	(17421) Receive <<< Helo <<< 213100200000000018cf43ce000063a2ffffffffffffffffffffffffffffffff
          mihome-vacuum.0	2021-06-07 10:11:19.784	debug	(17421) MIIO RECIVE: {"id":326,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":100}
          mihome-vacuum.0	2021-06-07 10:11:19.576	debug	(17421) Message= {"id":326,"method":"get_carpet_mode"}
          mihome-vacuum.0	2021-06-07 10:11:19.575	debug	(17421) MIIO RECIVE: {"id":325,"result":[90],"exe_time":200}
          mihome-vacuum.0	2021-06-07 10:11:19.285	debug	(17421) Message= {"id":325,"method":"get_sound_volume"}
          mihome-vacuum.0	2021-06-07 10:11:19.274	debug	(17421) MIIO RECIVE: {"id":324,"result":{"ssid":"Familie-Gerndt","ip":"192.168.178.70","mac":"b0:4a:39:15:75:03","bssid":"2c:91:ab:a5:2f:9a","rssi":-47},"exe_time":100}
          mihome-vacuum.0	2021-06-07 10:11:19.085	debug	(17421) Message= {"id":324,"method":"get_network_info"}
          mihome-vacuum.0	2021-06-07 10:11:19.083	debug	(17421) setGetStatus {"msg_ver":2,"msg_seq":609,"state":8,"battery":90,"clean_time":2399,"clean_area":30630000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1
          mihome-vacuum.0	2021-06-07 10:11:19.082	debug	(17421) MIIO RECIVE: {"id":323,"result":[{"msg_ver":2,"msg_seq":609,"state":8,"battery":90,"clean_time":2399,"clean_area":30630000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_f
          mihome-vacuum.0	2021-06-07 10:11:18.814	debug	(17421) Message= {"id":323,"method":"get_status"}
          mihome-vacuum.0	2021-06-07 10:11:18.813	debug	(17421) get params for stock Vacuum
          mihome-vacuum.0	2021-06-07 10:11:10.583	debug	(17421) Time difference between Mihome Vacuum and ioBroker: -1623027974 sec
          mihome-vacuum.0	2021-06-07 10:11:10.582	debug	(17421) Receive <<< Helo <<< 213100200000000018cf43ce00006398ffffffffffffffffffffffffffffffff
          mihome-vacuum.0	2021-06-07 10:11:00.533	debug	(17421) Helo message Timeout
          mihome-vacuum.0	2021-06-07 10:10:58.811	debug	(17421) MIIO Receive Timeout<<<
          mihome-vacuum.0	2021-06-07 10:10:56.809	debug	(17421) Message= {"id":322,"method":"get_carpet_mode"}
          mihome-vacuum.0	2021-06-07 10:10:56.809	debug	(17421) ERROR at setGetSoundVolume: MESSAGE TIMEOUT
          mihome-vacuum.0	2021-06-07 10:10:56.807	debug	(17421) MIIO Receive Timeout<<<
          mihome-vacuum.0	2021-06-07 10:10:54.805	debug	(17421) Message= {"id":321,"method":"get_sound_volume"}
          mihome-vacuum.0	2021-06-07 10:10:54.797	debug	(17421) MIIO RECIVE: {"id":320,"result":{"ssid":"Familie-Gerndt","ip":"192.168.178.70","mac":"b0:4a:39:15:75:03","bssid":"2c:91:ab:a5:2f:9a","rssi":-52},"exe_time":101}
          mihome-vacuum.0	2021-06-07 10:10:53.045	debug	(17421) Message= {"id":320,"method":"get_network_info"}
          mihome-vacuum.0	2021-06-07 10:10:53.043	debug	(17421) setGetStatus {"msg_ver":2,"msg_seq":607,"state":8,"battery":89,"clean_time":2399,"clean_area":30630000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1
          mihome-vacuum.0	2021-06-07 10:10:53.030	debug	(17421) MIIO RECIVE: {"id":319,"result":[{"msg_ver":2,"msg_seq":607,"state":8,"battery":89,"clean_time":2399,"clean_area":30630000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_f
          mihome-vacuum.0	2021-06-07 10:10:52.839	debug	(17421) Message= {"id":319,"method":"get_status"}
          mihome-vacuum.0	2021-06-07 10:10:52.838	debug	(17421) get params for stock Vacuum
          Es kommt also ständig ein Timeout und das es eine Zeitdifferenz gibt. Kann man da was dagegen tun?
          Danke und Grüße
          Ronny
            tobitobsta
            #222
            hat irgendwer die 3.2.0 Version mit einem S5 am Laufen? Ich habe ihn nicht zum Laufen bekommen hinsichtlich "load rooms" - zurück auf 2.5.5 funktioniert wieder alles einwandfrei.
            Im debug protokoll ist mir aufgefallen, dass er bei 3.2.0 irgendwas mit "unknown device model" sagte...
            und Frage 2: funktioniert beim S5 die Detektion der Wischeinheit? bei mir bleibt der "water_box" Datenpunkt immer auf false - mag aber sein, dass das der S5 das gar nicht kann.
            • Ronny GerndtR Ronny Gerndt
              Danke und Grüße
              Ronny
              #223
              @ronny-gerndt
              Hast du den Sauger mal in einer der Apps mihome oder roborock konfiguriert?
              Ronny GerndtR 1 Antwort Letzte Antwort
                @ronny-gerndt
                Ronny Gerndt
                schrieb am zuletzt editiert von Ronny Gerndt
                #224
                @thomas-braun said in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                @ronny-gerndt
                Ja klar. Hatte erst die Roborock drauf und bin dann auf MiHome gewechselt. Da funzt auch alles.
                Die Anbindung funktioniert inzwischen auch grundsätzlich. Mir fehlt noch die Raumliste. Die wird immer als leer angezeigt.
                • U UHT
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  #225
                  @Meistertr
                  Ich habe über die 2.1.1 die 3.2.0 installiert (update über Admin Oberfläche).
                  Bei GetDevices bekomme ich permanent einen Error: LOG IN FAILED.
                  Runter auf die 2.1.1 geht wieder alles (bis auf die Karte, deswegen wollte ich updaten)
                  Ist ein Robo S5 2.GEN.
                  (ich habe noch einen V1 deswegen die 1. Instanz zusätzlich)
                  mihome-vacuum.0	2021-06-13 13:50:46.231	info	(8576) create state for carpet_mode
                  mihome-vacuum.0	2021-06-13 13:50:45.416	info	(8576) create states for water box
                  mihome-vacuum.0	2021-06-13 13:50:45.375	info	(8576) change states from State control.fan_power
                  mihome-vacuum.0	2021-06-13 13:50:45.258	info	(8576) Map selected create states...
                  mihome-vacuum.1	2021-06-13 13:50:44.889	info	(8582) create state for carpet_mode
                  mihome-vacuum.0	2021-06-13 13:50:44.873	warn	(8576) Login failed
                  mihome-vacuum.1	2021-06-13 13:50:44.421	info	(8582) Map selected create states...
                  mihome-vacuum.1	2021-06-13 13:50:44.191	warn	(8582) Login failed
                  mihome-vacuum.0	2021-06-13 13:50:43.462	info	(8576) settest next timer: not available
                  mihome-vacuum.0	2021-06-13 13:50:42.897	info	(8576) select standard vacuum protocol....
                  mihome-vacuum.0	2021-06-13 13:50:42.853	info	(8576) IOT disabled, delete state
                  mihome-vacuum.1	2021-06-13 13:50:42.777	info	(8582) settest next timer: not available
                  mihome-vacuum.0	2021-06-13 13:50:42.683	info	(8576) check group user admin group admin: false
                  mihome-vacuum.0	2021-06-13 13:50:42.626	info	(8576) check user admin pw iobroker: true
                  mihome-vacuum.0	2021-06-13 13:50:42.166	info	(8576) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.22.1, js-controller: 3.2.16
                  mihome-vacuum.1	2021-06-13 13:50:42.152	info	(8582) select standard vacuum protocol....
                  mihome-vacuum.1	2021-06-13 13:50:42.124	info	(8582) IOT disabled, delete state
                  mihome-vacuum.0	2021-06-13 13:50:42.012	info	(8576) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                  mihome-vacuum.1	2021-06-13 13:50:41.881	info	(8582) check group user admin group admin: false
                  mihome-vacuum.1	2021-06-13 13:50:41.765	info	(8582) check user admin pw iobroker: true
                  mihome-vacuum.1	2021-06-13 13:50:41.285	info	(8582) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.22.1, js-controller: 3.2.16
                  mihome-vacuum.1	2021-06-13 13:50:41.174	info	(8582) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                  MeistertrM 1 Antwort Letzte Antwort
                  • haselchenH haselchen
                    @Meistertr
                    MeistertrM Offline
                    MeistertrM Offline
                    Meistertr
                    schrieb am zuletzt editiert von Meistertr
                    #226
                    @haselchen du musst das passwort neu eingeben. Steht auch im changelog
                    haselchenH F 3 Antworten Letzte Antwort
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      #227
                      @meistertr
                      Als wenn ich das nicht nach so einer Meldung machen würde ;)
                      Ergebnis blieb und bleibt das Gleiche.
                      Warum bekomme ich mit der 2.1.1 eigentlich die Map nicht mehr angezeigt bzw. ausgelesen?
                        Frank579
                        #228
                        @meistertr konntest du dir meinen log schon ansehen ? Sind noch immer keine Räume da 😔
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          #229
                          @meistertr
                          Habe alles nochmal neu aufgesetzt in der Mihome App.
                          Dann nochmal über die 2.1.1 die 3.2.0 installiert.
                          Hab noch nicht alles getestet, aber Verbindung ist da und die Datenpunkte werden aktualisiert.
                          Auch von mir ein Danke, dass Du Deine Freizeit diesem Projekt widmest!
                            @meistertr
                            tobitobsta
                            #230
                            @haselchen bei map hat sich der Datenpunkt geändert - dennoch hab ich es noch nicht bis ins VIS geschafft - aber die URL konnte ich bereits laden und die Map auch sehen.
                            das Thema Problem mit den Räumen habe ich auch (siehe ein paar Posts weiter oben). Habe auch den S5 - kann es daran tatsächlich liegen?
                            • haselchenH Offline
                              haselchenH Offline
                              haselchen
                              #231
                              @tobitobsta
                              Soweit läuft alles wieder bei mir.
                              Durch das drüber installieren sind die alten Einstellungen geblieben.
                              Map hat er geladen und erscheint auch in der VIS.
                                saeft_2003
                                schrieb am zuletzt editiert von saeft_2003
                                #232
                                @Meistertr
                                Ich habe jetzt das regelmäßig der Adapter (version 3.2.0) crasht. Weißt du an was das liegen könnte?
                                Heute:
                                host.iobroker	2021-06-25 15:13:59.568	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at UDP.onMessage (dgram.js:921:8)
                                host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
                                host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at Socket.emit (events.js:326:22)
                                host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at Socket.checkAnswer (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:146:62)
                                host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at _Packet.getPlainData (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:310:19)
                                host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at Decipheriv.final (internal/crypto/cipher.js:172:29)
                                host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at Object.final (<anonymous>)
                                host.iobroker	2021-06-25 15:13:59.565	error	Caught by controller[0]: Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                mihome-vacuum.0	2021-06-25 15:13:59.281	error	(15936) Exception-Code: ERR_OSSL_EVP_BAD_DECRYPT: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                mihome-vacuum.0	2021-06-25 15:13:59.281	error	at UDP.onMessage (dgram.js:921:8)
                                mihome-vacuum.0	2021-06-25 15:13:59.281	error	at Socket.EventEmitter.emit (domain.js:483:12)
                                mihome-vacuum.0	2021-06-25 15:13:59.281	error	at Socket.emit (events.js:326:22)
                                mihome-vacuum.0	2021-06-25 15:13:59.281	error	at Socket.checkAnswer (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:146:62)
                                mihome-vacuum.0	2021-06-25 15:13:59.281	error	at _Packet.getPlainData (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:310:19)
                                mihome-vacuum.0	2021-06-25 15:13:59.281	error	at Decipheriv.final (internal/crypto/cipher.js:172:29)
                                mihome-vacuum.0	2021-06-25 15:13:59.281	error	at Object.final (<anonymous>)
                                mihome-vacuum.0	2021-06-25 15:13:59.281	error	(15936) Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                mihome-vacuum.0	2021-06-25 15:13:59.277	error	(15936) uncaught exception: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                Gestern:
                                2021-06-24 16:30:54.310 - error: mihome-vacuum.0 (10285) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2021-06-24 16:30:54.319 - error: mihome-vacuum.0 (10285) unhandled promise rejection: undefined
                                2021-06-24 16:30:54.319 - error: mihome-vacuum.0 (10285) undefined
                                2021-06-24 16:30:54.937 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2021-06-24 16:30:54.938 - error: host.iobroker Caught by controller[1]: MESSAGE TIMEOUT
                                2021-06-24 16:30:54.939 - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                @ all
                                Habt ihr crashs?
                                • S saeft_2003
                                  @Meistertr
                                  Heute:
                                  Gestern:
                                  @ all
                                  Habt ihr crashs?
                                  #233
                                  @saeft_2003 Hier crasht nix.
                                  Wann passiert es denn bei dir? Wenn der Roboter aktiv ist?
                                  S 2 Antworten Letzte Antwort
                                    saeft_2003
                                    #234
                                    Ja nur wenn er aktiv ist sonst nicht.
                                      saeft_2003
                                      #235
                                      @thomas-braun @Meistertr
                                      Gerade war er aktiv und es gab wieder einen crash. Ich kann mir nicht erklären an was das liegt?
                                      host.iobroker	2021-06-29 08:44:16.591	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.iobroker	2021-06-29 08:44:16.591	error	Caught by controller[0]: at UDP.onMessage (dgram.js:921:8)
                                      host.iobroker	2021-06-29 08:44:16.591	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
                                      host.iobroker	2021-06-29 08:44:16.591	error	Caught by controller[0]: at Socket.emit (events.js:326:22)
                                      host.iobroker	2021-06-29 08:44:16.590	error	Caught by controller[0]: at Socket.checkAnswer (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:146:62)
                                      host.iobroker	2021-06-29 08:44:16.590	error	Caught by controller[0]: at _Packet.getPlainData (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:310:19)
                                      host.iobroker	2021-06-29 08:44:16.590	error	Caught by controller[0]: at Decipheriv.final (internal/crypto/cipher.js:172:29)
                                      host.iobroker	2021-06-29 08:44:16.590	error	Caught by controller[0]: at Object.final (<anonymous>)
                                      host.iobroker	2021-06-29 08:44:16.588	error	Caught by controller[0]: Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                      mihome-vacuum.0	2021-06-29 08:44:16.287	error	(27481) Exception-Code: ERR_OSSL_EVP_BAD_DECRYPT: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                      mihome-vacuum.0	2021-06-29 08:44:16.287	error	at UDP.onMessage (dgram.js:921:8)
                                      mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Socket.EventEmitter.emit (domain.js:483:12)
                                      mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Socket.emit (events.js:326:22)
                                      mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Socket.checkAnswer (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:146:62)
                                      mihome-vacuum.0	2021-06-29 08:44:16.287	error	at _Packet.getPlainData (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:310:19)
                                      mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Decipheriv.final (internal/crypto/cipher.js:172:29)
                                      mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Object.final (<anonymous>)
                                      mihome-vacuum.0	2021-06-29 08:44:16.287	error	(27481) Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                      mihome-vacuum.0	2021-06-29 08:44:16.284	error	(27481) uncaught exception: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                      Thomas BraunT MeistertrM apollon77A 3 Antworten Letzte Antwort
                                      • S saeft_2003
                                        #236
                                        @saeft_2003 sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                                        Da gibt es wohl Probleme mit der Entschlüsselung eines Passwortes.
                                        Hast du da 'Sonderzeichen' drin oder ist das besonders lang?
                                        Änder das mal zum testen auf was simpleres.
                                          saeft_2003
                                          #237
                                          Danke für die Info. Das Passwort sollte eigentlich recht simpel sein. Besteht aus 8 Zeichen und das sind nur normale Buchstaben und Zahlen.
                                          Würde es testweise Sinn machen den Adapter mal auf einem anderen Host laufen zu lassen?
