  4. ZigBee neue Version 1.5.x
    6.5k
579 Beiträge 72 Kommentatoren 188.4k Aufrufe 74 Beobachtet
  • R rewenode
    Ich weis echt nicht mehr weiter.
    Bekomme einfach nicht das Update vom 1.5.5 auf 1.5.6 hin.
    iob im Docker Container mit 4gb auf einem Rock64
    node.js - v12.18.3
    npm - 6.14.6
    zigbee stick CC2538 + CC2592 von dimaiv
    Bisher gab es nie die geringsten zigbee Updateprobleme. Nur die 1.5.6 bekomme ich nicht installiert.
    Hier das Log:
     01:23:20.786 - info: zigbee.0 (3129) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.3, js-controller: 3.2.16
    2021-06-11 01:23:21.151 - info: zigbee.0 (3129) Starting Zigbee npm ...
    2021-06-11 01:23:22.084 - info: zigbee.0 (3129) Installed Version: iobroker.zigbee@1.5.6
    2021-06-11 01:23:23.678 - error: zigbee.0 (3129) Configuration is not consistent with adapter state/backup!
    2021-06-11 01:23:23.681 - error: zigbee.0 (3129) - PAN ID: configured=6754, adapter=65535
    2021-06-11 01:23:23.683 - error: zigbee.0 (3129) - Extended PAN ID: configured=00124b001940c0ba, adapter=0000000000000000
    2021-06-11 01:23:23.685 - error: zigbee.0 (3129) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    2021-06-11 01:23:23.686 - error: zigbee.0 (3129) - Channel List: configured=11, adapter=
    2021-06-11 01:23:23.688 - error: zigbee.0 (3129) Please update configuration to prevent further issues.
    2021-06-11 01:23:23.689 - error: zigbee.0 (3129) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    2021-06-11 01:23:23.691 - error: zigbee.0 (3129) Re-commissioning your network will require re-pairing of all devices!
    2021-06-11 01:23:23.694 - error: zigbee.0 (3129) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    2021-06-11 01:23:23.695 - error: zigbee.0 (3129) Failed to start Zigbee
    2021-06-11 01:23:23.697 - error: zigbee.0 (3129) Error herdsman start
    2021-06-11 01:23:33.700 - info: zigbee.0 (3129) Try to reconnect. 1 attempts left
    2021-06-11 01:23:33.702 - info: zigbee.0 (3129) Starting Zigbee npm ...
    2021-06-11 01:23:33.735 - info: zigbee.0 (3129) Installed Version: iobroker.zigbee@1.5.6
    2021-06-11 01:23:33.980 - error: zigbee.0 (3129) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    2021-06-11 01:23:33.982 - error: zigbee.0 (3129) Failed to start Zigbee
    2021-06-11 01:23:33.984 - error: zigbee.0 (3129) Error herdsman start
    2021-06-11 01:25:09.693 - info: host.iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2021-06-11 01:25:09.717 - info: mqtt.0 (705) send2Server system.adapter.zigbee.0.sigKill[iob/system/adapter/zigbee/0/sigKill]
    2021-06-11 01:25:09.718 - info: zigbee.0 (3129) Got terminate signal TERMINATE_YOURSELF
    2021-06-11 01:25:09.723 - info: zigbee.0 (3129) cleaned everything up...
    2021-06-11 01:25:09.730 - info: zigbee.0 (3129) Zigbee: disabling joining new devices.
    2021-06-11 01:25:09.733 - warn: zigbee.0 (3129) Failed to stop zigbee during startup
    2021-06-11 01:25:09.735 - info: zigbee.0 (3129) terminating
    2021-06-11 01:25:09.737 - info: zigbee.0 (3129) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-06-11 01:25:09.739 - error: zigbee.0 (3129) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-06-11 01:25:09.740 - error: zigbee.0 (3129) unhandled promise rejection: Cannot read property 'getEntries' of null
    2021-06-11 01:25:09.743 - error: zigbee.0 (3129) TypeError: Cannot read property 'getEntries' of null
    at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
    at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
    at Controller.getDevices (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
    at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49)
    at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
    at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42)
    at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
    at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
    Was kann ich noch tun ?
    arteckA Offline
    arteckA Offline
    arteck
    #432
    @rewenode geh auf version 1.4.1 und dann wieder auf die 1.5.6 gehts dann ?
    R 1 Antwort Letzte Antwort
    • arteckA arteck
      rewenode
      #433
      @arteck Reicht da ein Downgrade adapter->Bestimmte version installieren -> 1.4.1 ?
      Oder muss erst den Adapter (1.5.5) löschen?
      Und falls löschen, wie kann ich alle meine Geräte behalten ohne alle neu anlernen zu müssen?
      Sry wenn die Fragen etwas naiv sein sollten. Ich sag ja, bisher reichte ein Knopfdruck und alles neu anlernen wäre hier ziemlich mit Arbeit verbunden bei kleinem Zeitfenster.
      Jedenfalls schonmal danke für deine Hilfe.
      G 1 Antwort Letzte Antwort
      • R rewenode
        gosund
        #434
        @arteck @Asgothian
        FYI: Hatte gestern Abend auf die 1.5.5 herunter gegraded. Das Problem besteht immer noch: nach ziemlich genau 24 Stunden hängt sich der Adapter auf. Ich mußte den Pi gerade eben wieder booten.
        Irgend eine Idee, was ich noch machen kann?
        Und nochwas: Seit dem Downgrade bekomme ich ständig folgende Meldung im Log:
        zigbee.0 (1671) Failed to DeviceConfigure.onZigbeeEvent (Error: 'LED1623G12' has no configure
            at Object.getConfigureKey (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/configureKey.js:20:15)
            at DeviceConfigure.shouldConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:33:38)
            at DeviceConfigure.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:76:22)
            at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:196:42)
            at ZigbeeController.handleMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:14))
        Woher kommt LED1623G12? Ich habe alle Devices umbenannt, kann also nicht sagen, welches er meint. Irgend eine Idee?
        • R Offline
          Rushmed
          schrieb am zuletzt editiert von Rushmed
          #435
          ich komme gerade vom Ikea Einkauf und habe zwei kleine Probleme.
          Die Fernbedienung STYRBAR wird vom Adapter als W2094 erkannt. Auf dem Gerät steht aber W2044 und in der Anleitung E2002. Das ist erstmal kein Problem für mich, allerdings funktionieren Druck und langer Druck nur bei den links/rechts Tasten. Die anderen beiden Tasten funktionieren garnicht. f750e091-c6d7-4da2-af97-ba27597956bb-grafik.png
          Wenn ich STYRBAR direkt mit einer Lampe kopple geht alles.
          Wenn ich den Adapter auf debug stelle kommen Tastendrücke an:
          zigbee.0	2021-06-12 19:09:59.315	debug	(18506) Publish {"action":"brightness_stop","action_group":901} to "842e14fffe471ae1"
          zigbee.0	2021-06-12 19:09:59.300	debug	(18506) Type commandStopWithOnOff device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"p
          zigbee.0	2021-06-12 19:09:59.299	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandStopWithOnOff', cluster 'genLevelCtrl', data '{}' from endpoint 1 with groupID 901
          zigbee.0	2021-06-12 19:09:59.297	debug	(18506) handleMessage. {"type":"commandStopWithOnOff","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profi
          zigbee.0	2021-06-12 19:09:58.939	debug	(18506) Publish {"action":"brightness_move_down","action_rate":83,"action_group":901} to "842e14fffe471ae1"
          zigbee.0	2021-06-12 19:09:58.926	debug	(18506) Type commandMove device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID"
          zigbee.0	2021-06-12 19:09:58.926	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandMove', cluster 'genLevelCtrl', data '{"movemode":1,"rate":83}' from endpoint 1 with groupID 901
          zigbee.0	2021-06-12 19:09:58.924	debug	(18506) handleMessage. {"type":"commandMove","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260
          zigbee.0	2021-06-12 19:09:57.127	debug	(18506) Publish {"action":"brightness_stop","action_group":901} to "842e14fffe471ae1"
          zigbee.0	2021-06-12 19:09:57.116	debug	(18506) Type commandStopWithOnOff device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"p
          zigbee.0	2021-06-12 19:09:57.114	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandStopWithOnOff', cluster 'genLevelCtrl', data '{}' from endpoint 1 with groupID 901
          zigbee.0	2021-06-12 19:09:57.113	debug	(18506) handleMessage. {"type":"commandStopWithOnOff","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profi
          zigbee.0	2021-06-12 19:09:56.660	debug	(18506) Publish {"action":"brightness_move_up","action_rate":83,"action_group":901} to "842e14fffe471ae1"
          zigbee.0	2021-06-12 19:09:56.644	debug	(18506) Type commandMoveWithOnOff device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"p
          zigbee.0	2021-06-12 19:09:56.643	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandMoveWithOnOff', cluster 'genLevelCtrl', data '{"movemode":0,"rate":83}' from endpoint 1 with groupID 901
          zigbee.0	2021-06-12 19:09:56.640	debug	(18506) handleMessage. {"type":"commandMoveWithOnOff","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profi
          zigbee.0	2021-06-12 19:09:54.926	debug	(18506) Publish {"action":"on","action_group":901} to "842e14fffe471ae1"
          zigbee.0	2021-06-12 19:09:54.917	debug	(18506) Type commandOn device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":2
          zigbee.0	2021-06-12 19:09:54.916	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandOn', cluster 'genOnOff', data '{}' from endpoint 1 with groupID 901
          zigbee.0	2021-06-12 19:09:54.915	debug	(18506) handleMessage. {"type":"commandOn","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"
          zigbee.0	2021-06-12 19:09:53.737	debug	(18506) Publish {"action":"arrow_right_click"} to "842e14fffe471ae1"
          zigbee.0	2021-06-12 19:09:53.720	debug	(18506) Type commandTradfriArrowSingle device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID"
          zigbee.0	2021-06-12 19:09:53.719	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandTradfriArrowSingle', cluster 'genScenes', data '{"value":256,"value2":13}' from endpoint 1 with groupID 901
          zigbee.0	2021-06-12 19:09:53.715	debug	(18506) handleMessage. {"type":"commandTradfriArrowSingle","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"
          zigbee.0	2021-06-12 19:09:52.576	debug	(18506) Publish {"action":"off","action_group":901} to "842e14fffe471ae1"
          zigbee.0	2021-06-12 19:09:52.563	debug	(18506) Type commandOff device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":
          zigbee.0	2021-06-12 19:09:52.561	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandOff', cluster 'genOnOff', data '{}' from endpoint 1 with groupID 901
          zigbee.0	2021-06-12 19:09:52.558	debug	(18506) handleMessage. {"type":"commandOff","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,
          zigbee.0	2021-06-12 19:09:51.208	debug	(18506) Publish {"action":"arrow_left_click"} to "842e14fffe471ae1"
          zigbee.0	2021-06-12 19:09:51.199	debug	(18506) Type commandTradfriArrowSingle device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID"
          zigbee.0	2021-06-12 19:09:51.196	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandTradfriArrowSingle', cluster 'genScenes', data '{"value":257,"value2":13}' from endpoint 1 with groupID 901
          zigbee.0	2021-06-12 19:09:51.194	debug	(18506) handleMessage. {"type":"commandTradfriArrowSingle","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"
          Der Timeout für die Erkennung des langen Drucks ist mit ca. 3 s auch sehr lang, kann man das irgendwo verstellen? Das ist zum Beispiel bei E1743 nur ca. 1 s, was viel besser passt.
          Dann habe ich noch eine LED1924G9, die funktioniert soweit, außer die Effekte. Da tut sich garnichts.
          Hat da jemand einen Tipp für mich?
          L arteckA 2 Antworten Letzte Antwort
          • R Rushmed
            locito09
            #436
            @rushmed
            hast du probiert das Gerät auszuschliessen?
            • L locito09
              @rushmed
              Rushmed
              #437
              @locito09 Wie ausschließen? Im Adapter? Nein.
              Edit: Habs probiert, geht nicht.
              • G gosund
                @arteck @Asgothian
                arteckA Offline
                arteckA Offline
                arteck
                #438
                @gosund da sist der Technische name .. nicht dein umbenanntess.das kannst du in der Kachel sehen ..wenn du die umdrehst
                F 1 Antwort Letzte Antwort
                • arteckA arteck
                  Frank579
                  #439
                  @Asgothian
                  Habe gerade mein bastelsystem hochgezogen auf Admin5.
                  Er spuckt mir jetzt für einige Geräte
                  zigbee.0
                  2021-06-13 09:52:06.290	warn	State value to set for "zigbee.0.0017880108279caf.link_quality" has value "255" greater than max "254"
                  ins Log.
                  Ist das schon bekannt?
                  • F Frank579
                    @Asgothian
                    zigbee.0
                    ins Log.
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #440
                    @frank579 ohh Danke..habs korrigiert
                    • R Rushmed
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #441
                      @rushmed zeigma die Kachel
                      • arteckA arteck
                        Rushmed
                        #442
                        @arteck Prego!
                        arteckA R D 3 Antworten Letzte Antwort
                        • R Rushmed
                          @arteck Prego!
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #443
                          @rushmed der Button meldet sich als W2049. ist so
                          https://github.com/Koenkk/zigbee2mqtt/issues/7655
                          • arteckA arteck
                            Rushmed
                            #444
                            @arteck Ja ok, stört mich auch nicht. Mein Problem ist dass nur die Hälfte der Tasten (als Objekte) gehen aber im debug LOG doch auch die anderen irgendwie ankommen wie in meinem Post geschrieben.
                            Im verlinkten Issue ist das Pairing das Problem, nicht dass die Tasten nur teilweise funktionieren.
                            • R Rushmed
                              @arteck Prego!
                              Rushmed
                              #445
                              @rushmed sagte in ZigBee neue Version 1.5.x:
                              Hat hierzu keiner weiter eine Idee. Hab ich vll. an der falschen Stelle gepostet?
                              • R Rushmed
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #446
                                @rushmed Nein, hast du nicht. im Issue steht auch bereits das daran gearbeitet wird, aber das es noch dauern wird da es aktuell eine deutlich grössere Baustelle gibt.
                                Wenn Du magst kannst Du dich da aber auch selber heran wagen. Das Problem ist das die Definition der states über die exposes nicht zu den Nachrichten des Herdsman passt.
                                A.
                                • AsgothianA Asgothian
                                  A.
                                  Rushmed
                                  #447
                                  @asgothian Klingt interessant, was kann ich tun?
                                  • R Rushmed
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    #448
                                    @rushmed
                                    • Fork vom Zigbee-Adpater auf Github erstellen
                                    • Prüfen wie durch die Funktion(en) unter lib/exposes.js die Datenpunkte der Fernbedienung angelegt werden, und auf welche Nachrichten diese reagieren
                                    • Code anpassen
                                    • zum test bei Dir installieren, testen
                                    • rinse- repeat bis das Zielergebnis erreicht ist.
                                    • Wenn es läuft: PR gegen den Hauptadapter stellen
                                    • Wenn es nicht läuft / nicht zum laufen zu bekommen ist - im Issue auf Github posten was du versucht hast und an welcher Stelle du hängst.
                                    A.
                                    Note: Programmierwissen in JS ist notwendig. Du wirst dich auch in die Arbeitsweise des codes einarbeiten müssen. Das ist nicht in einer Stunde erledigt.
                                      @rushmed
                                      • Code anpassen
                                      A.
                                      Rushmed
                                      #449
                                      @asgothian Puuh, da bin ich raus.
                                      • R Rushmed
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        #450
                                        Das hatte ich schon befürchtet. Jetzt ist hoffentlich auch klar warum das nicht 'mal eben' gemacht ist.
                                        A.
                                          A.
                                          Rushmed
                                          #451
                                          @asgothian Mir ist schon klar was ihr hier alle leistet!
                                          Falls ich irgendwie behilflich sein kann, zum Testen oder hier und da mal ne Zeile in einer Datei ändern stehe ich bereit. 👷
