    6.5k
7.6k Beiträge 296 Kommentatoren 7.8m Aufrufe 201 Beobachtet
  • dslraserD dslraser
    @dirk1962
    Boost Restlaufzeit---eigener Datenpunkt. Kannst ja mal probieren. iQontrol Boost Restlaufzeit auf den eigenen Datenpunkt verlinken. Die Restlaufzeit zählt im Sekundentakt runter.
     <variables>
       <variable id="=yzQW{xe](*q)[.G4RO(">Boost_Zeit</variable>
       <variable type="interval" id="Intervall">Intervall</variable>
     </variables>
     <block type="create" id="HHlmtV`-A_7.m9zR85D$" x="-263" y="13">
       <field name="NAME">0_userdata.0.Heizungen.Wohnzimmer_Boost_Restlaufzeit</field>
       <value name="VALUE">
         <block type="math_number" id="}#?sOH5I|R{/z+j~@guP">
           <field name="NUM">0</field>
         </block>
       </value>
       <value name="COMMON">
         <block type="text" id="s,QEs/JoRn:|wD~*,1/-">
           <field name="TEXT">{ "role" : "number" , "type" : "number" , "min": 0 , "max": 300 , "name" : "Wohnzimmer_Boost_Restlaufzeit" }</field>
         </block>
       </value>
       <next>
         <block type="variables_set" id="`j.%R9KyW}54;1d3AST9">
           <field name="VAR" id="=yzQW{xe](*q)[.G4RO(">Boost_Zeit</field>
             <block type="math_number" id="H[XRzP+,jlePabqg,^.2">
               <field name="NUM">300</field>
             </block>
           </value>
           <next>
             <block type="on_ext" id="t+ye_(`.~#-QgBEBQy:)">
               <value name="OID0">
                 <shadow type="field_oid" id="Ls;!NT[E]n%1.S?d()el">
                   <field name="oid">hm-rpc.2.INT0000008.1.BOOST_MODE</field>
                 </shadow>
               </value>
               <statement name="STATEMENT">
                 <block type="controls_if" id="/jnA1P-V^!NGNw9wT!W6">
                   <value name="IF0">
                     <block type="on_source" id="uYkiY6~nOZaR!N6#kr/4">
                     </block>
                   </value>
                   <statement name="DO0">
                     <block type="timeouts_setinterval" id=";g-vwXu*fxnIQDP,?Fxo">
                       <field name="NAME">Intervall</field>
                       <field name="INTERVAL">1000</field>
                       <field name="UNIT">ms</field>
                         <block type="math_change" id="_jvI1n#z(%|+xb#0@~|#">
                           <value name="DELTA">
                             <shadow type="math_number" id="#Z/o*-RGnE^a*8nt.^c6">
                               <field name="NUM">1</field>
                             </shadow>
                             <block type="math_number" id="~:$7cg{rAHv)4.)r690.">
                               <field name="NUM">-1</field>
                             </block>
                           </value>
                           <next>
                             <block type="control_ex" id="=rMO5FVMV?b/_XS5kFg6">
                               <field name="TYPE">true</field>
                               <value name="OID">
                                 <shadow type="field_oid" id="SKL}a1FVhzk@,oP}(6!-">
                                   <field name="oid">0_userdata.0.Heizungen.Wohnzimmer_Boost_Restlaufzeit</field>
                                 </shadow>
                               </value>
                                 <shadow type="logic_boolean" id="@|F?+NhxL$V*]ca-9E*P">
                                 </shadow>
                                 <block type="variables_get" id="H6M#DI4DV!qp#15zW`a8">
                                 </block>
                               </value>
                               <value name="DELAY_MS">
                                 <shadow type="math_number" id="@{RP7TE^(gh?baCSZXnw">
                                 </shadow>
                               </value>
                             </block>
                           </next>
                         </block>
                       </statement>
                     </block>
                   </statement>
                   <statement name="ELSE">
                     <block type="timeouts_clearinterval" id="D,*Qa(,Ii/sUC:X@64au">
                       <next>
                         <block type="variables_set" id="8yv})T/z2vwHVz[ZX{+Q">
                             <block type="math_number" id="6IuBKArg@oQ:ItlHYu3o">
                             </block>
                           </value>
                           <next>
                             <block type="control_ex" id="(jJX`QK=vd%1#AWC5D$f">
                               <value name="OID">
                                 <shadow type="field_oid" id=":Pqf]rOtun/K3t^!YRSD">
                                 </shadow>
                               </value>
                                 <shadow type="logic_boolean" id="3QcamcLkHl-|Nb4~s7S0">
                                 </shadow>
                                 <block type="math_number" id="%w-|9rM}a/IF$eSdDfNs">
                                 </block>
                               </value>
                                 <shadow type="math_number" id="J*r/h74]MyX#W:;b)]65">
                                 </shadow>
                               </value>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </statement>
                 </block>
               </statement>
             </block>
           </next>
         </block>
       </next>
     </block>
    </xml>
    EDIT: Blockly geändert....
    dirk1962D Offline
    dirk1962D Offline
    dirk1962
    #5435
    @dslraser
    Habe alles nach Deiner Anleitung umgebaut und es ist alles perfekt 👏 👏 .
    Vielen Dank für Deine Hilfe!!
    NUC8i5 mit Proxmox; Raspberrymatic in VM, iobroker, Motioneye, infuxDB und Grafana in CT.
    • dirk1962D dirk1962
      @dslraser
      dslraserD Offline
      dslraserD Offline
      dslraser
      #5436
      @dirk1962 sagte in Test Adapter iQontrol 1.8.x Vis:
      @dslraser
      Hallo Dirk,
      ich habe bei den Anzeigen (Ventilöffnung/Boost-Restlaufzeit) jetzt noch einen Schreibschutz drauf gemacht, damit man das nicht versehentlich verstellt....
      Sieht dann so aus...
      • E Einstein2002
        @dslraser Das mit der 1 hatten wir vorhin auch, wurde eigentlich beseitigt. Ich wollte nur kurz sagen, gehe jetzt schlafen.
        Machen wir morgen weiter. Grüße
        s.bormannS Offline
        s.bormannS Offline
        s.bormann
        #5437
        @einstein2002 sagte in Test Adapter iQontrol 1.8.x Vis:
        Hi, ja, sorry, bei mir wurde es gestern auch etwas später :)
        Habe eben noch mal eine neue Version auf Github geladen.
        Vielleicht klappt damit Autocreate. Und das Zurückschalten von Boost könnte auch gehen.
        Bitte mal testen. Falls es nicht klappt, verabreden wir uns noch mal via Anydesk, wie gestern.
        • s.bormannS s.bormann
          dslraserD Offline
          dslraserD Offline
          dslraser
          #5438
          @s-bormann sagte in Test Adapter iQontrol 1.8.x Vis:
          leider beides nicht...(unverändert)
          EDIT: ich habe nochmal einen Upload gemacht. Das Umschalten von Boost funktioniert mal und mal nicht...
            Kueppert
            #5439
            jurze Frage in die Runde hier: hat schon mal jmd versucht, Grafana-Panels oder -Dashboard in iQontrol anzeigen zu lassen? Hab InfluxDB und Grafana neu und spiele gerade damit rum. WIrd ggf nen flot/eChart-Ersatz. Hab jetzt viel rumprobiert mit Try-Error und nur Error erhalten bisher ^^
              Beowolf
              #5440
              Jepp, ich habe einige eingefügt. Allerding per Aufruf durch die Web-Adresse die Grafana erzeugt.
                Kueppert
                #5441
                @beowolf jo, ich habs...auch in einem anderen Thread hier im Forum über die Google-Suche gefunden. Man muss die ini noch bearbeiten:
                nano /etc/grafana/grafana.ini
                [security]
                allow_embedding = true
                [auth.anonymous]
                enabled = true
                org_name = Main Org.
                org_role = Viewer
                [users]
                allow_sign_up = false
                  Beowolf
                  #5442
                  Jepp, da sind ein paar kleine Änderungen notwendig. Schaue Dir auch das "Einloggen" an. Sonst wirst Du immer gebeten die anzumelden wenn Du ein Chart aufrufst.
                  • B Beowolf
                    Kueppert
                    #5443
                    @beowolf hab ich mit auth.anonymous, enable = true schon gemacht ;)
                    Wo hast du die Links im iQontrol eingegeben? Eben gings bei mir noch, jetzt nicht mehr O.o Hab Widget und den Link bei Background-html rein...sieht dann aber so aus:
                    • K Kueppert
                      Beowolf
                      #5444
                      @kueppert
                      Ansicht auswählen
                      Gerät hinzufügen
                      dann auf den blauen Kreis klicken
                      zweite Zeile im Feld Datenpnkt
                      nennt sich URL -> dort den Link eingeben.
                      fettich 😀
                      • B Beowolf
                        @kueppert
                        Ansicht auswählen
                        Gerät hinzufügen
                        fettich 😀
                        Kueppert
                        #5445
                        @beowolf AAaahhh, bei URL nicht HTML. Danke dir :) Hab nen Widget genommen und den Link bei Background-URL rein 👍
                        dslraserD B 2 Antworten Letzte Antwort
                        • K Kueppert
                          da_WoodyD Offline
                          da_WoodyD Offline
                          #5446
                          @kueppert ist keine raketen wissenschaft! ;)
                          sogar die komplette wetterstation
                          • da_WoodyD da_Woody
                            Kueppert
                            schrieb am zuletzt editiert von Kueppert
                            #5447
                            @da_woody uiuiui, mein Grafana+InfluxDB läuft auf nem Nuc => LXC mit 1 Kern und 1 GB RAM. Da fällt das Proxmox-Dashboard schon mal raus (so wie ich das gelesen hab...ddafür musst dem Teil mehr Power geben?)
                            da_WoodyD dslraserD 2 Antworten Letzte Antwort
                            • K Kueppert
                              dslraserD Offline
                              dslraserD Offline
                              dslraser
                              #5448
                              @kueppert
                              Ich habe auch son par Proben drinn in iQontrol, seit gestern sogar Testweise Kameras...
                              da_WoodyD K 2 Antworten Letzte Antwort
                              • K Kueppert
                                da_WoodyD Offline
                                da_WoodyD Offline
                                #5449
                                @kueppert häh? das ist selbstgeschnitzt aus den objekten vom proxmox adapter...
                                • K Kueppert
                                  Beowolf
                                  #5450
                                  @kueppert sagte in Test Adapter iQontrol 1.8.x Vis:
                                  Kaum macht man es richtig - funktioniert es. 👍 👍 👍 👍
                                    Kueppert
                                    #5451
                                    @da_woody ah, okay, das werd ich auch machen...nach und nach. Bei dem Dashboard bei Grafana wird Grafana auch direkt vom Proxmox gefüttert irgendwie. Hab nicht weiter gelesen ;)
                                      @kueppert
                                      da_WoodyD Offline
                                      da_WoodyD Offline
                                      #5452
                                      @dslraser wobei das mit den kameras... die daten da 3x durchs netzwerk jagen?🙄
                                      da nehm ich lieber gleich die motioneye links...
                                        @kueppert
                                        Kueppert
                                        #5453
                                        @dslraser wie hast du denn die Panels inkl. den beiden Buttons oben in iQontrol bekommen, ohne dass er dir auch das Menü aus Grafana links anzeigt? Ich hab an dem Link ein "&kiosk" angehangen, dann wird aber das Menü links sowie auch die beiden Filter oberhalb der Daten ausgeblendet...
                                          Kueppert
                                          #5454
                                          @da_woody sagte in Test Adapter iQontrol 1.8.x Vis:
                                          oder die Synology-Links ;) Wenn man die Surveillance-Station betreibt ^^
