  4. [gelöst]Influxdb installieren
influxdb
40 Beiträge 5 Kommentatoren 2.9k Aufrufe 5 Beobachtet
    @torsten_mg zeigen
    Torsten_MG
    @crunchip sagte in Influxdb installieren:
    @torsten_mg zeigen
    War das 2. Bild
    • T Torsten_MG
      @crunchipich bin total durch. Habe den ganzen Tag herumexperimentiert.
      laut
      systemctl status influxdb
      läuft ja influxdb nun
      * influxdb.service - InfluxDB is an open-source, distributed, time series database
         Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
         Active: active (running) since Sun 2021-05-30 19:43:08 CEST; 19min ago
           Docs: man:influxd(1)
       Main PID: 184 (influxd)
          Tasks: 8 (limit: 4915)
         Memory: 22.5M
         CGroup: /system.slice/influxdb.service
                 `-184 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
      May 30 19:43:08 influxdb influxd[184]: ts=2021-05-30T17:43:08.898180Z lvl=info msg="Registered diagnostics client" log_id=0URanri
      May 30 19:43:08 influxdb influxd[184]: ts=2021-05-30T17:43:08.899864Z lvl=info msg="Starting precreation service" log_id=0URanril
      May 30 19:43:08 influxdb influxd[184]: ts=2021-05-30T17:43:08.900979Z lvl=info msg="Starting snapshot service" log_id=0URanril000
      May 30 19:43:08 influxdb influxd[184]: ts=2021-05-30T17:43:08.901042Z lvl=info msg="Starting continuous query service" log_id=0UR
      May 30 19:43:08 influxdb influxd[184]: ts=2021-05-30T17:43:08.902296Z lvl=info msg="Starting HTTP service" log_id=0URanril000 ser
      May 30 19:43:08 influxdb influxd[184]: ts=2021-05-30T17:43:08.902357Z lvl=info msg="opened HTTP access log" log_id=0URanril000 se
      May 30 19:43:08 influxdb influxd[184]: ts=2021-05-30T17:43:08.903749Z lvl=info msg="Listening on HTTP" log_id=0URanril000 service
      May 30 19:43:08 influxdb influxd[184]: ts=2021-05-30T17:43:08.903843Z lvl=info msg="Starting retention policy enforcement service
      May 30 19:43:08 influxdb influxd[184]: ts=2021-05-30T17:43:08.904809Z lvl=info msg="Listening for signals" log_id=0URanril000
      May 30 19:43:08 influxdb influxd[184]: ts=2021-05-30T17:43:08.914937Z lvl=info msg="Storing statistics" log_id=0URanril000 servic
      lines 1-20/20 (END)
      wie lege ich eine Datenbank und nutzer an?
      crunchipC Offline
      crunchipC Offline
      @torsten_mg sagte in Influxdb installieren:
      Active: active (running) since Sun 2021-05-30 20:15:47
      Active: active (running) since Mon 2021-05-31 21:26:03
      Hast du da zwischenzeitlich was gemacht?
      • T Torsten_MG
        @torsten_mg zeigen
        War das 2. Bild
        crunchipC Offline
        crunchipC Offline
        @torsten_mg nein vom ersten Bild deine Einstellung für den DP möcht ich sehen
          Torsten_MG
          Ich habe gestern die Datenpunkte zum loggen ausgewählt.
          Und gestern habe ich in dem selben Container noch Grafana installiert
            Torsten_MG
            • T Torsten_MG
              crunchipC Offline
              crunchipC Offline
              @torsten_mg da ist schon mal ein Fehler, wie ich oben schon schrieb...bei speicher als, hast du automatik belassen, das macht hin und wieder Probleme, daher explizit auswählen, was man loggen möchte. In diesem Fall ist dein DP vom Typ Number, daher dann auch so einstellen.
              Problem ist jetzt nur, du hast bereits Daten auf Automatik geloggt, da hilft kein nachträgliches ändern.
              Am besten du löscht die Datenpunkte aus der Datenbank und loggst neu.
              Da du gerade erst begonnen hast, ist es am einfachsten, du löscht die Datenbank und lässt sie neu anlegen. Kannst du auch in der Influx Instanz. Da gibts die Option Datenbank löschen
                Torsten_MG
                @crunchip
                Habe jetzt mal auf "alle Daten in DB löschen" geklickt.
                Was mir gerade auch noch aufgefallen ist:
                Ich wollte mir gerade Grafana genauer anschauen und wollte die Verknüpfung zu influxdb herstellen, aber nach Save&Test kommt folgende Meldung
                • T Torsten_MG
                  @crunchip
                  crunchipC Offline
                  crunchipC Offline
                  @torsten_mg klick mal in Grafana auf deine Datenbank, dort hast du wahrscheinlich bei Auth etwas angewählt, bzw hast du bei users auch keinen admin eingerichtet.
                  Die Grafana ini.conf hast du angepasst?
                  Steht in der Beschreibung
                  Siehe Link
                    Siehe Link
                    Torsten_MG
                    @crunchip
                    Da die Influx-Instanz gestern abend auch auf Gelb ging habe ich kurzerhand alles gelöscht. Wenn es Bereitschaft & RL es zulassen werde ich die Tage das noch mal neu machen.
                    Was soll ich für den Container besser nehmen Ubuntu oder Debian?
                    Oder soll ich den selben Container nehmen für Influx und Grafana wo auch schon der IOBroker läuft?
                    Bin jetzt auf der Arbeit, daher kann ich nicht nachschauen welche Version genau zur verfügung steht.
                    Seltsam ist nur, dass alle Datenpunkte, die ich geloggt habe nicht mehr da waren, da waren auch welche bei, die ich als Nummer ausgewählt hatte.
                    da_WoodyD crunchipC 2 Antworten Letzte Antwort
                    • T Torsten_MG
                      @crunchip
                      da_WoodyD Offline
                      da_WoodyD Offline
                      @torsten_mg selbes linux verwenden. warum mischen?
                      • T Torsten_MG
                        @crunchip
                        crunchipC Offline
                        crunchipC Offline
                        Hast ja die Datenbank geleert.
                        Debian ist schlank und du verwendest eh schon debian, dann bleib am bestenn dabei.
                        Ich persönlich habe alles getrennt laufen, dadurch kann ich, falls mal was schief gehen sollte, einzeln eingreifen.
                        Hättest du nicht müssen.
                        Man kann auch Datenbanken anlegen/ löschen, direkt in der Konsole.
                        Habe z.b. 3 Influx instanzen. In jeder instanz logge ich bestimmte Sachen, eine davon ist nur zum "Spielen", wenn ich die geloggten Daten nicht mehr brauche, lösche ich einfach die Datenbank und leg eine neue an, anstatt alle Messungen einzeln zu löschen.
                          @torsten_mg einfach nach der offizellen Anleitung☺
                          oder guck mal hier
                          erstelle einen Debian LXC und dann Influx drauf
                          ungefähr so
                          gegebenenfalls einen Benutzer anlegen
                          der dpkg Befehl ist grundsätzlich zu machen bei einem LXC, sowie curl und sudo nachinstalliert werden müssen
                          apt install curl sudo
                          apt update && apt upgrade
                          dpkg-reconfigure tzdata
                          dann nach Anleitung
                          Torsten_MG
                          dann nach Anleitung
                          So, habe jetzt versucht es so zu machen, aber leider komme ich nicht weiter.
                          Zuerst die 3 Punkte oben, dann nach den Angaben von Installing InfluxDB OSS:
                          curl -s https://repos.influxdata.com/influxdb.key | gpg --dearmor > /etc/apt/trusted.gpg.d/influxdb.gpg
                          Danach
                          export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
                          Hier kommt dann die Meldung
                          root@influxdb:~# export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
                          -bash: lsb_release: command not found
                          root@influxdb:~#
                          Da bin ich jetzt raus! Was mach ich falsch?
                          Ich nehme folgendes Debian: Debian-10-standart10.7.1_amd64.tar.gz
                          • T Torsten_MG
                            dann nach Anleitung
                            Danach
                            root@influxdb:~#
                            lsb_release
                            Ist auch das Paket 'lsb-release' installiert?
                            apt policy lsb-release
                            Und root@debian ist auch 'falsch'.
                              lsb_release
                              Torsten_MG
                              @thomas-braun sagte in Influxdb installieren:
                              lsb_release
                              Jetzt ja :)
                              Ok weitergekommen.
                              gestartet, läuft!
                              Muss ich die influxdb.conf anpassen? Hatte das irgendwo gelesen.
                              • T Torsten_MG
                                lsb_release
                                Jetzt ja :)
                                Ok weitergekommen.
                                gestartet, läuft!
                                crunchipC Offline
                                crunchipC Offline
                                @torsten_mg statt local muss sie ip eingetragen werden, glaub ich, bin aber nicht sicher.
                                Kann auch sein das ich es gerade mit grafana verwechsle
                                Bei http musst du entsprechende Dinge auskommentieren
                                  Torsten_MG
                                  @crunchip
                                  Habe jetzt erstmal nichts geändert.
                                  Habe ein paar Werte zum loggen ausgewählt und die scheinen auch geloggt zu werden.
                                  Muss jetzt erstmal weg Bereitschaftsdienst ruft
                                    Torsten_MG
                                    InfluxDB läuft, Grafana zeigt auch schöne Grafiken, nur bei einem klappt das leider nicht
                                    Siehe => Link Text
