  4. Forecast.solar mit dem Systeminfo Adapter
systeminfosolarjson
188 Beiträge 15 Kommentatoren 39.3k Aufrufe 16 Beobachtet
  • GarganoG Gargano
    @jb_sullivan hab gesehen :
    90° ist west , -90° ist ost.
    Also entweder Du drehst
    const legendTest = ["Ost","West"];
    um oder
    Du drehst
    const declination = ['40','40'];
    const azimuth = ['90','-90'];
    const kwp = ['7.26','2.64'];
    in
    const azimuth = ['-90','90'];
    const kwp = ['2.64','7.26'];
    Dann sollte Ost als erstes kommen
    JB_SullivanJ Offline
    JB_Sullivan
    #149
    @gargano
    OK - nun passt alles.
    Hier nochmal der Finale Code zum abgleich
    /* read solar forecasts for 2 different orientations
    Author : gargano
    Display in VIS : use JSON Chart from Scrounger
    Version 1.0.1
    Last Update 16.3.2021
    Change history :
    1.0.1 / 16.3.2021   :   use setStateAsync(myUrl.mySolarJSON.. to avoid time conflicts
                            dp's are now saved in '0_userdata.0.'
                            use variables for setting lat, lon, color..
    const prefix = 'javascript.0.';
    const SolarJSON1            = prefix+"SolarForecast.JSON1";
    const SolarJSON2            = prefix+"SolarForecast.JSON2";
    const SolarJSONAll1         = prefix+"SolarForecast.JSONAll1";
    const SolarJSONAll2         = prefix+"SolarForecast.JSONAll2";
    const SolarJSONGraphAll1    = prefix+"SolarForecast.JSONGraphAll1";
    const SolarJSONGraphAll2    = prefix+"SolarForecast.JSONGraphAll2";
    const SolarJSONTable        = prefix+"SolarForecast.JSONTable";
    const SolarJSONGraph        = prefix+"SolarForecast.JSONGraph";
    const createStateList = [
        {name :SolarJSON1, type:"string", role : "value"},
        {name :SolarJSON2, type:"string", role : "value"},
        {name :SolarJSONAll1, type:"string", role : "value"},
        {name :SolarJSONAll2, type:"string", role : "value"},
        {name :SolarJSONGraphAll1, type:"string", role : "value"},
        {name :SolarJSONGraphAll2, type:"string", role : "value"},
        {name :SolarJSONTable, type:"string", role : "value"},
        {name :SolarJSONGraph, type:"string", role : "value"}
    // create states if not exists
    async function createMyState(item) {
        if (!existsState(item.name)) {
        await createStateAsync(item.name, {
                type: item.type,
                min: 0,
                def: 0,
                role: item.role
    async function makeMyStateList (array) {
        // map array to promises
        const promises = array.map(createMyState);
        await Promise.all(promises);
    var mySchedule = '0,30 * * * *';
    async function main () {
        await makeMyStateList(createStateList);
        schedule(mySchedule, getSolar );
        getSolar();
    main();
    // set logging = true for logging
    const logging = true;
    var request = require('request');
    /* https://api.forecast.solar/estimate/:lat/:lon/:dec/:az/:kwp
    lat - latitude of location, -90 (south) … 90 (north)
    lon - longitude of location, -180 (west) … 180 (east)
    dec - plane declination, 0 (horizontal) … 90 (vertical)
    az - plane azimuth, -180 … 180 (-180 = north, -90 = east, 0 = south, 90 = west, 180 = north)
    kwp - installed modules power in kilo watt
    // set lat and lon for the destination
    const lat = 'xx.yyyy'
    const lon = 'xx.yyy'
    const forcastUrl = 'https://api.forecast.solar';
    // if use the api key remove '//' and insert '//' in front of const api = '';
    //const api = '/xxxxxxxxxxxxxxxx;
    // else
    const api = '/xxxxxxxxxx';
    var options1 = {url: forcastUrl+api+'/estimate/'+lat+'/'+lon+'/'+declination[0]+'/'+azimuth[0]+'/'+kwp[0], method: 'GET', headers: { 'User-Agent': 'request' }};
    var options2 = {url: forcastUrl+api+'/estimate/'+lat+'/'+lon+'/'+declination[1]+'/'+azimuth[1]+'/'+kwp[1], method: 'GET', headers: { 'User-Agent': 'request' }};
    const legendTest = ["West","Ost"];
    const graphColor = ["blue","red"];
    const datalabelColor = ["lightblue","lightblue"];
    const tooltip_AppendText= " Watt";
    var urls = [
      {myUrl:options1,mySolarJSON:SolarJSON1,mySolarJSONAll:SolarJSONAll1,mySolarJSONGraphAll:SolarJSONGraphAll1},
      {myUrl:options2,mySolarJSON:SolarJSON2,mySolarJSONAll:SolarJSONAll2,mySolarJSONGraphAll:SolarJSONGraphAll2}
    // handle the request : convert the result to table and graph
    function myAsyncRequest(myUrl) {
      log('Request '+myUrl.myUrl.url);
      return new Promise((resolve, reject) => {
         request(myUrl.myUrl.url, async function(error, response, body) {
            if (!error && response.statusCode == 200) {
                if (logging) console.log ('body : '+body);
                let watts = JSON.parse(body).result.watts;
                setState(myUrl.mySolarJSONAll, JSON.stringify(watts), true);
                let table = [];
                for(let time in watts) {
                        let entry = {};
                        entry.Uhrzeit = time;
                        entry.Leistung = watts[time];
                        table.push(entry);
                if (logging) console.log ('JSON: '+myUrl.mySolarJSON);
                await setStateAsync(myUrl.mySolarJSON, JSON.stringify(table), true);
                // make GraphTable
                let graphTimeData = [];
                        let graphEntry ={};
                        graphEntry.t = Date.parse(time);
                        graphEntry.y = watts[time];
                        graphTimeData.push(graphEntry);
                var graph = {};
                var graphData ={};
                var graphAllData = [];
                graphData.data = graphTimeData;
                graphAllData.push(graphData);
                graph.graphs=graphAllData;
                setState(myUrl.mySolarJSONGraphAll, JSON.stringify(graph), true);
                resolve (body);
            } else
                reject(new Error("Could not load " + myUrl.myUrl.url+' Error '+error +'Status '+ response.statusCode));
    // summarize the single watts results to table and graph
    function makeTable () {
        if (logging) console.log ('MakeTable');
        let watts1 = JSON.parse(getState(SolarJSON1).val);
        let watts2 = JSON.parse(getState(SolarJSON2).val);
        if (logging) console.log ('Items: '+watts1.length);
        let table = [];
    	let axisLabels = [];
        // make table
        for(var n=0;n<watts1.length;n++) {
                let entry = {};
                entry.Uhrzeit = watts1[n].Uhrzeit;
                entry.Leistung1 = watts1[n].Leistung;
                entry.Leistung2 = watts2[n].Leistung;
                entry.Summe = watts1[n].Leistung + watts2[n].Leistung;
                table.push(entry);
        // prepare data for graph
    	let graphTimeData1 = [];
        	graphTimeData1.push(watts1[n].Leistung);
            let time = watts1[n].Uhrzeit.substr(11,5);
            axisLabels.push(time);
    	let graphTimeData2 = [];
        for(var n=0;n<watts2.length;n++) {
       		graphTimeData2.push(watts2[n].Leistung);
        // make total graph
        var graph = {};
        var graphData = {"tooltip_AppendText":  tooltip_AppendText,"legendText": legendTest[0],"yAxis_id": 1,"type": "bar","displayOrder": 2,"barIsStacked": true,"color":graphColor[0],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[0],"datalabel_fontSize":10};
        graphData.data = graphTimeData1;
    	graphData = {"tooltip_AppendText": tooltip_AppendText,"legendText": legendTest[1],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[1],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[1],"datalabel_fontSize":10};
        graphData.data = graphTimeData2;
    	graph.axisLabels =  axisLabels;
        setState(SolarJSONTable, JSON.stringify(table), true);
        setState(SolarJSONGraph, JSON.stringify(graph), true);
    // get the requests
    async function getSolar() {
       let promises = urls.map(myAsyncRequest);
        .then(function(bodys) {
            if (logging) console.log("All url loaded");
            makeTable();
        .catch(error => {
            console.log('Error : '+error)
    GarganoG M 2 Antworten Letzte Antwort
    • JB_SullivanJ JB_Sullivan
      @gargano
      Author : gargano
      Version 1.0.1
      Change history :
                  type: item.type,
                  min: 0,
                  def: 0,
                  role: item.role
          getSolar();
      main();
      // else
      var urls = [
                  let table = [];
                          let entry = {};
                          table.push(entry);
                  // make GraphTable
                          let graphEntry ={};
                  var graph = {};
                  var graphData ={};
                  resolve (body);
              } else
          let table = [];
          // make table
                  let entry = {};
                  table.push(entry);
          // make total graph
          var graph = {};
      // get the requests
              makeTable();
          .catch(error => {
      GarganoG Offline
      GarganoG Offline
      Gargano
      #150
      @jb_sullivan Dann wäre Dein Panel West das mit 7,26 kW und Dein Ost mit 2.64 kW.
      Wie passt dann die Ausrichtung -90 und 90 Azimuth zu West und Ost ?
      • GarganoG Gargano
        JB_Sullivan
        schrieb am zuletzt editiert von JB_Sullivan
        #151
        @gargano
        Genau die Modulleistungen sind so wie du sagst, aber was meinst du mit den Himmelsrichtungen?
        Passt doch / -90 =Ost - 90=West
        Also Passt im Sinne das Diagramm ist richtig. Ostseite weniger Ertrag als die Westseite
        GarganoG 1 Antwort Letzte Antwort
          @gargano
          GarganoG Offline
          GarganoG Offline
          Gargano
          schrieb am zuletzt editiert von Gargano
          #152
          @jb_sullivan In der LegendText
          kommt als erstes "West" dann "Ost"
          in Azimuth kommt als erstes
          -90 ,also Ost
          Dann müsste umgekehrt sein
          Vom Ertrag her gleich aber logisch jetzt richtig.
          Der 1. Response ist Ost (-90), dann West (90)
          • GarganoG Gargano
            -90 ,also Ost
            JB_Sullivan
            #153
            @gargano
            UPS - jetzt sehe ich es auch
            OST Richtig
            OST Falsch
            Auch der Ertrag ist auf addiert unterschiedlich. Kleines Zeichen große Wirkung.
            • P Offline
              PatrickWalther
              #154
              bin gerade dran einen Adapter zu schreiben. Denke die Grundfunktione sind drin, allerdings keine Anlagen addition oder Grafiken.
              @gargano Hast du schon Adapter programmiert?
              • P PatrickWalther
                GarganoG Offline
                GarganoG Offline
                Gargano
                #155
                @patrickwalther sagte in Forecast.solar mit dem Systeminfo Adapter:
                Nicht von Anfang an, hab beim Resol Adapter mitgemacht.
                Hast Du den Adapter auf GIT ?
                P 1 Antwort Letzte Antwort
                • GarganoG Gargano
                  PatrickWalther
                  #156
                  @gargano habe leider noch Problem den umzubenennen und auf Github zu bringen.
                  Für den Befehl "gulp rename ... " fehlt mir eine Datei. Habe das ganze nach dem Youtube Video Luftdaten aufgestetzt der Adapter funktioniert bisher nur auf meinem PI.
                  Verusch das ganze später nochmal nach der Anleitung:
                  https://forum.iobroker.net/assets/uploads/files/282_entwickler_howto_v0.2.pdf
                  Vielleicht hast du ne Idee.
                  • P PatrickWalther
                    GarganoG Offline
                    GarganoG Offline
                    Gargano
                    #157
                    @patrickwalther ich mach es immer so (unter Windows):
                    Leeres, neues Repo in Github erzeugen.
                    Clonen. Files in Directories kopieren.
                    Adden und Push mit Tortoise GIT
                    • G Offline
                      glitzi
                      schrieb am zuletzt editiert von glitzi
                      #158
                      @paul53 log (info.result)
                      {'watts':{'2020-12-15 07:49:00':0,'2020-12-15 08:25:00':80,'2020-12-15 09:00:00':590,'2020-12-15 10:00:00':1230,'2020-12-15 11:00:00':1810,'2020-12-15 12:00:00':2040,'2020-12-15 13:00:00':1560,'2020-12-15 14:00:00':1120,'2020-12-15 15:00:00':570,'2020-12-15 15:41:00':80,'2020-12-15 16:22:00':0,'2020-12-16 07:50:00':0,'2020-12-16 08:25:00':60,'2020-12-16 09:00:00':380,'2020-12-16 10:00:00':770,'2020-12-16 11:00:00':1140,'2020-12-16 12:00:00':1400,'2020-12-16 13:00:00':1360,'2020-12-16 14:00:00':1080,'2020-12-16 15:00:00':560,'2020-12-16 15:41:00':80,'2020-12-16 16:22:00':0},'watt_hours':{'2020-12-15 07:49:00':0,'2020-12-15 08:25:00':50,'2020-12-15 09:00:00':390,'2020-12-15 10:00:00':1620,'2020-12-15 11:00:00':3430,'2020-12-15 12:00:00':5470,'2020-12-15 13:00:00':7030,'2020-12-15 14:00:00':8150,'2020-12-15 15:00:00':8720,'2020-12-15 15:41:00':8780,'2020-12-15 16:22:00':8780,'2020-12-16 07:50:00':0,'2020-12-16 08:25:00':40,'2020-12-16 09:00:00':260,'2020-12-16 10:00:00':1030,'2020-12-16 11:00:00':2170,'2020-12-16 12:00:00':3570,'2020-12-16 13:00:00':4930,'2020-12-16 14:00:00':6010,'2020-12-16 15:00:00':6570,'2020-12-16 15:41:00':6620,'2020-12-16 16:22:00':6620},'watt_hours_day':{'2020-12-15':8780,'2020-12-16':6620}}
                      const options = {url: 'https://api.forecast.solar/estimate/Dein-Lat/Dein-Lon/45/45/10', method: 'GET', headers: { 'User-Agent': 'request' }};
                      request(options, function(error, response, body) {
                            let res = JSON.parse(body).result.watts;  // res ist ein Objekt
                            log(res);
                      kann mir jemand sagen wie ich die obigen Daten des aktuellen Tages morgens um 1 Uhr mit folgendem Code in die InfluxDB bekomme? Ziel ist es in grafana eine Prognose für den Tag zu erstellen.
                      Die Tabelle kann von der Anzahl und den Zeitstempeln variieren.
                      Ich denke man muss eine Schleife programmieren die die Daten nacheinander in die DB schreibt.
                      sendTo('influxdb.0', 'storeState', {id: 'PV_Forecast', state: {ts: ZEIT AUS LISTE, val: WERT AUS LISTE, ack: true, from: "javascript.0", q: 0}});
                      • G glitzi
                              log(res);
                        #159
                        @glitzi sagte: Schleife programmieren die die Daten nacheinander in die DB schreibt.
                        Ja:
                        for(let key in res) {
                            let ts = new Date(key).getTime(); // ms
                            let watt = res[key];
                            // in DB schreiben
                          Ja:
                              // in DB schreiben
                          glitzi
                          #160
                          leider bin ich ein absoluter Anfänger was die Programmierung angeht, kannst Du mir bitte den Code etwas zusammen stellen?
                          Die zuletzt geschrieben Code-Schnipsel habe ich mir nur zusammengesucht, aber verstehen tue ich da noch lange nichts ;-)
                          Gerade der Teil wo ich die unterschiedlichen Zeit Stempel zerlegen muss, diese können täglich variieren.
                          MfG
                          • G glitzi
                            MfG
                            #161
                            @glitzi sagte: Gerade der Teil wo ich die unterschiedlichen Zeit Stempel zerlegen muss, diese können täglich variieren.
                            Von Datenbanken habe ich keine Ahnung, weshalb ich das Schreiben in die DB nur als Kommentar angegeben habe. Wie muss der Zeitstempel in der InfluxDB vorliegen? In meinem Vorschlag - der direkt nach
                            ausgeführt werden muss - werden die Zeiten im Objekt res in ms umgerechnet und stehen in der Variablen ts zur Verfügung.
                              glitzi
                              #162
                              So hier mein versuch, leider ist noch ein Fehler im Skript vermutlich unten bei den Klammern...
                              Nochmal ergänzend, ich möchte jetzt dann folgendes tun...
                              Die Zeit und den zugehörigen Wert aus dem Result '2021-05-27 12:00:00' :1234, für alle Werte aus dem Result in die InfluxDB schreiben.
                              Geliefert werden immer zwei Tage, hiervon möchte ich jedoch immer nur den aktuellen Tag.
                              var options = {url: 'https://api.forecast.solar/estimate/*STANDORT*/-2/12.73', method: 'GET', headers: { 'User-Agent': 'request' }};
                              schedule({hour: 00, minute: 30}, GetSolar );
                              function GetSolar() {
                                      let res = JSON.parse(body).result.watts;  // info ist ein Objekt
                                      log(res);
                                          log(ts);
                                          log(watt);
                                      // in DB schreiben
                              Bezüglich der Zeit, der Ursprungscode zum schreiben in die DB war folgender
                              sendTo('influxdb.0', 'storeState', {id: 'Temperaturen.Außen.Tagesdurchschnitt2', state: {ts: (new Date().getTime()) - 86400000, val: getState("javascript.0.Aussentemperaturen.Tagesdurchschnitt.Durchschnitt").val, ack: true, from: "javascript.0", q: 0}});
                              • G glitzi
                                        log(res);
                                            log(ts);
                                            log(watt);
                                        // in DB schreiben
                                #163
                                @glitzi sagte: leider ist noch ein Fehler im Skript vermutlich unten bei den Klammern...
                                Ja, verwende Einrückungen konsequent, um solche Fehler zu erkennen.
                                            log(res);
                                                let ts = new Date(key).getTime() - 172800000; // 2 Tage zurück in ms
                                                log(ts + ': ' + watt);
                                                sendTo('influxdb.0', 'storeState', {id: 'PV_Forecast', state: {ts: ts, val: watt, ack: true, from: "javascript.0", q: 0}});
                                schedule('30 0 * * *', GetSolar);
                                              log(res);
                                  glitzi
                                  #164
                                  Super, das sieht erstmal sehr gut aus. DANKE!
                                  ich glaube bei dem Abschnitt haben wir uns falsch verstanden :-)
                                  Folgende Daten Kommen aus der abfragte, davon möchte ich immer nur den aktuellen Tag in die Datenbank schreiben.
                                  Es könnte sein das auch je Tag mehr oder weniger Einträge übermittelt werden.
                                  • G glitzi
                                    #165
                                    @glitzi sagte: davon möchte ich immer nur den aktuellen Tag in die Datenbank schreiben.
                                    Dann muss das Datum geprüft werden:
                                                    if(key.substr(0, 10) == formatDate(new Date(), 'YYYY-MM-DD')) {
                                                        let ts = new Date(key).getTime() - 86400000; //  1 Tag zurück in ms
                                      glitzi
                                      #166
                                      DANKE!
                                      Ohne das - 86400000 ist es das was ich brauche.
                                      Somit das Fertige Script für den PV Forcast über die Webseite Forecast.Solar und die Speicherung in der InfluxDB.
                                      var options = {url: 'https://api.forecast.solar/estimate/MEINE Koordinaten/Meine Koordinaten/35/-2/12.73', method: 'GET', headers: { 'User-Agent': 'request' }};
                                                          let ts = new Date(key).getTime(); //  1 Tag zurück in ms
                                      • Chris 5C Offline
                                        Chris 5C Offline
                                        Chris 5
                                        schrieb am zuletzt editiert von Chris 5
                                        #167
                                        Die Grafiken sehen alle aus wie Glockenkurven, die aus dem Wechselrichter sind aber extrem gezackt (ist ja auch klar wegen der Bewölkung).
                                        Kann man denn die Prognose für das Schalten von Verbrauchen überhaupt gebrauchen? Es gibt auch Seiten die den Bewölkungsgrad des Himmes im Stundenryhtmus angeben: brightsky.dev auch kostenlos. Fährt man da nicht besser mit? oder evt sogar beide Daten miteinander verknüpfen?
                                        Ich glaube zumindest nicht das Mittags immer die Wattzahl am größten ist.
                                        • Chris 5C Chris 5
                                          glitzi
                                          #168
                                          @chris-5
                                          Ja das Stimmt, ist ja wie beim Wetterbericht ;-)
                                          Ich vermute die nutzen für die Prognose auch die Bewölkung und ein paar andere Werte als Grundlage.
                                          Anbei mal ein Bild von heute aus der Nähe von Kassel
                                          grün= hochgerechnet aus einem Messwert der Globalstrahlung
                                          gelb= Prognosewerte
                                          in 3 Wochen bekomme ich meine PV, dann sehe ich was wirklich passiert
                                          wenn man es ordentlich glättet, kommt es etwas besser hin, aber 2-3 km weiter kann es schon ganz anders aussehen.
                                          JB_SullivanJ P 2 Antworten Letzte Antwort
