  4. zigbee nach update gelb
    6.1k
50 Beiträge 12 Kommentatoren 6.9k Aufrufe 12 Beobachtet
    @mpl1338 du fährst mit npm 7.x ??
    arteckA Offline
    arteckA Offline
    arteck
    wie @crunchip gerade schreibt.... da haben wir das Problem
      mpl1338
      update auf 7 erfolgte erst eben.
      zurück zu 6:
      which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v12.22.1
      v12.22.1
      6.14.13
      nodejs:
        Installed: 12.22.1-1nodesource1
        Candidate: 12.22.1-1nodesource1
        Version table:
       *** 12.22.1-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages
           10.24.0~dfsg-1~deb10u1 500
              500 http://ftp.debian.org/debian buster/main amd64 Packages
              500 http://security.debian.org buster/updates/main amd64 Packages
      zigbee.0	2021-05-24 19:41:43.508	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
      zigbee.0	2021-05-24 19:41:43.508	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
      zigbee.0	2021-05-24 19:41:43.508	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
      zigbee.0	2021-05-24 19:41:43.508	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
      zigbee.0	2021-05-24 19:41:43.508	error	at new Promise (<anonymous>)
      zigbee.0	2021-05-24 19:41:43.508	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
      zigbee.0	2021-05-24 19:41:43.508	error	at Generator.next (<anonymous>)
      zigbee.0	2021-05-24 19:41:43.508	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
      zigbee.0	2021-05-24 19:41:43.508	error	(5962) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
      zigbee.0	2021-05-24 19:41:43.508	error	(5962) Failed to start Zigbee
      iobroker
      Platform
      linux
      Betriebssystem
      linux
      Architektur
      x64
      CPUs
      Geschwindigkeit
      3600 MHz
      Modell
      Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz
      RAM
      4 GB
      System Betriebszeit
      4 T. 23:16:12
      Node.js
      v12.22.1
      Festplatte Größe
      12 GB
      Festplatte frei
      7.81 GB
      Anzahl der Adapter
      411
      NPM
      v6.14.13
      Betriebszeit
      00:02:58
      Aktive Instanzen
      25
      Hostname
      iobroker
      und problem immernoch da
      • M mpl1338
        zurück zu 6:
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v12.22.1
        v12.22.1
        6.14.13
        nodejs:
          Version table:
        iobroker
        Platform
        linux
        Betriebssystem
        linux
        Architektur
        x64
        CPUs
        Geschwindigkeit
        3600 MHz
        Modell
        RAM
        4 GB
        System Betriebszeit
        4 T. 23:16:12
        Node.js
        v12.22.1
        Festplatte Größe
        12 GB
        Festplatte frei
        7.81 GB
        Anzahl der Adapter
        411
        NPM
        v6.14.13
        Betriebszeit
        00:02:58
        Aktive Instanzen
        25
        Hostname
        iobroker
        @mpl1338 Was liegt denn da drauf?
        sudo lsof /dev/ttyACM0
          mpl1338
          @thomas-braun said in zigbee nach update gelb:
          COMMAND  PID     USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
          node    1305 iobroker   27uW  CHR  166,0      0t0  361 /dev/ttyACM0
          • M mpl1338
            @mpl1338
            Stop den Adapter,
            sudo -u iobroker kill 1305
            Adapter starten.
            • M mpl1338
              zurück zu 6:
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v12.22.1
              v12.22.1
              6.14.13
              nodejs:
                Version table:
              iobroker
              Platform
              linux
              Betriebssystem
              linux
              Architektur
              x64
              CPUs
              Geschwindigkeit
              3600 MHz
              Modell
              RAM
              4 GB
              System Betriebszeit
              4 T. 23:16:12
              Node.js
              v12.22.1
              Festplatte Größe
              12 GB
              Festplatte frei
              7.81 GB
              Anzahl der Adapter
              411
              NPM
              v6.14.13
              Betriebszeit
              00:02:58
              Aktive Instanzen
              25
              Hostname
              iobroker
              crunchipC Abwesend
              crunchipC Abwesend
              @mpl1338 proxmox selbst mal neu gestartet, bzw stick mal abgesteckt?
                mpl1338
                @crunchip
                mehrmals
                @Thomas-Braun
                keine besserung
                M Thomas BraunT 2 Antworten Letzte Antwort
                • M mpl1338
                  @crunchip
                  mehrmals
                  @Thomas-Braun
                  keine besserung
                  mpl1338
                  downgrade auf 1.4.1 und es geht wieder....
                  • M mpl1338
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @mpl1338 seltsam
                    • M mpl1338
                      @crunchip
                      mehrmals
                      @Thomas-Braun
                      keine besserung
                      @mpl1338
                      iobroker stop
                      Damn nochmal schauen ob das File noch offen ist, process ggf. killen,
                      iobroker start
                        @mpl1338
                        iobroker stop
                        iobroker start
                        mpl1338
                        bin jetzt auf 1.4.1 runter - da läufts wieder
                        • P Offline
                          Peter213
                          Habe auch gerade Update gemacht und der Adapter bleibt rot. Folgende Fehler habe ich:
                          Hat einer eine Idee?
                          • P Peter213
                            arteckA Offline
                            arteckA Offline
                            arteck
                            @peter213 multihost ?
                            P 1 Antwort Letzte Antwort
                            • arteckA arteck
                              Peter213
                              @arteck nein. Nuc mit Proxmox als VM mit Conbee II Stick. Mit 1.4.1 läuft es wieder wie bei den anderen. Bin vor kurzem umgezogen von PI auf NUC. Bis jetzt lief auch alles. Erst gestern mit dem Update auf 1.5.5 kam das Problem. mit 1.5.4 war es auch noch in Ordnung. Waren allerdings gestern noch ein paar andere Updates dabei.
                                Allodo
                                schrieb am zuletzt editiert von Allodo
                                EDIT:
                                Bin auch zurück auf 1.4.1 und der Adapter ist wieder grün!
                                Ich habe auch das Problem, dass mein Zigbee-Adapter seit gestern gelb bleibt :(
                                Gestern gab es, glaube ich, ein Update auf die jetzige Version 1.5.6.
                                Der Zigbee-Stick (CC2538+CC2592) wird von iobroker nicht mehr erkannt.
                                Von mir wurde keinen Änderungen an den Einstellungen vorgenommen.
                                root@raspberrypi:~# sudo lsof /dev/ttyACM0
                                node    4119 iobroker   27uW  CHR  166,0      0t0  489 /dev/ttyACM0
                                Und hier der Log-File:
                                zigbee.0	2021-06-01 17:33:17.898	error	(4119) Error herdsman start
                                zigbee.0	2021-06-01 17:33:17.898	error	(4119) Failed to start Zigbee
                                zigbee.0	2021-06-01 17:33:17.897	error	(4119) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                                zigbee.0	2021-06-01 17:33:17.897	error	(4119) Re-commissioning your network will require re-pairing of all devices!
                                zigbee.0	2021-06-01 17:33:17.896	error	(4119) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                                zigbee.0	2021-06-01 17:33:17.896	error	(4119) Please update configuration to prevent further issues.
                                zigbee.0	2021-06-01 17:33:17.895	error	(4119) - Channel List: configured=11, adapter=
                                zigbee.0	2021-06-01 17:33:17.895	error	(4119) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                                zigbee.0	2021-06-01 17:33:17.894	error	(4119) - Extended PAN ID: configured=00124b001940c090, adapter=0000000000000000
                                zigbee.0	2021-06-01 17:33:17.894	error	(4119) - PAN ID: configured=6754, adapter=65535
                                zigbee.0	2021-06-01 17:33:17.893	error	(4119) Configuration is not consistent with adapter state/backup!
                                Ein Reboot der RPi4 brachte keinen Erfolg. Was kann ich jetzt tun, möglichst ohne alle Geräte wieder mühselig anlernen zu müssen?
                                joggeJ Thomas BraunT 2 Antworten Letzte Antwort
                                • A Allodo
                                  EDIT:
                                  joggeJ Offline
                                  joggeJ Offline
                                  jogge
                                  schrieb am zuletzt editiert von jogge
                                  @allodo hatte eben das gleich Problem. Selbe Fehlermeldungen wie Peter 213.
                                  Hab ein Backup eingespielt weil ein downgraden auf die alte Version auch nicht mehr funktioniert hat.
                                  Hoffe du hast Backups...
                                  • A Allodo
                                    EDIT:
                                    @allodo sagte in zigbee nach update gelb:
                                    Sagt mir auch schon wieder alles. :-/
                                      Allodo
                                      Was genau möchtest Du denn haben?
                                      Wie gesagt, nach Rückspielung auf 1.4.1 funktionierte es auf Anhieb wieder.
                                      • A Allodo
                                        @allodo
                                        Nix. Ich wäre schon zufrieden, wenn da kein root-login zu sehen wäre.
                                        Zusammen mit dem (dann) unnötigen sudo zeigt mir das nur, dass da wieder komplett ahnungslos mit vollen root-Rechten durch das System gepflügt wird.
                                          @allodo
                                          Allodo
                                          Sorry, der Befehl war einfach auf die Schnelle Copy & Paste, deshalb das sudo davor, und hat mit dem eigentlichen Problem wenig zu tun.
                                          Mit der aktuellen Version 1.5.6 gibt's Probleme, mit der 1.4.1 nicht. Ob nun Root oder Nicht Root in an dieser Stelle völlig irrelevant!
                                          Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
