zigbee nach update gelb
seit einem update der Letzen tage ist zigbee gelb.
Proxmox:
lsusb Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 005: ID 0451:16c8 Texas Instruments, Inc. Bus 001 Device 002: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter Bus 001 Device 004: ID 8087:0aaa Intel Corp. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ls -la /dev/bus/usb/001/005 crw-rw-r-- 1 root root 189, 4 May 24 17:57 /dev/bus/usb/001/005 ls -la /dev/ttyACM0 crw-rw-rw- 1 root dialout 166, 0 May 24 18:10 /dev/ttyACM0proxmox conf:
lxc.cgroup.devices.allow: c 189:* rwm lxc.mount.entry: /dev/bus/usb/001/005 dev/bus/usb/001/005 none bind,optional,create=file lxc.cgroup.devices.allow: c 166:* rwm lxc.mount.entry: /dev/ttyACM0 dev/ttyACM0 none bind,optional,create=fileiobroker LXC container
lsusb Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 005: ID 0451:16c8 Texas Instruments, Inc. Bus 001 Device 002: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter Bus 001 Device 004: ID 8087:0aaa Intel Corp. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ls -al /dev/bus/usb/001/005 crw-rw-r-- 1 root root 189, 4 May 24 17:57 /dev/bus/usb/001/005 ls -al /dev/ttyACM0 crw-rw-rw- 1 root dialout 166, 0 May 24 18:10 /dev/ttyACM0iobroker log
zigbee.0 2021-05-24 18:19:33.385 error (2787) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/zn zigbee.0 2021-05-24 18:19:33.385 error (2787) Failed to start Zigbee zigbee.0 2021-05-24 18:19:33.280 info (2787) Installed Version: iobroker.zigbee@1.5.5 zigbee.0 2021-05-24 18:19:33.272 info (2787) Starting Zigbee npm ... zigbee.0 2021-05-24 18:19:33.271 info (2787) Try to reconnect. 1 attempts left zigbee.0 2021-05-24 18:19:23.270 error at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:24:58) zigbee.0 2021-05-24 18:19:23.270 error at Generator.next (<anonymous>) zigbee.0 2021-05-24 18:19:23.270 error at ZnpAdapterManager.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:193:41) zigbee.0 2021-05-24 18:19:23.270 error (2787) TypeError: Cannot read property 'error' of undefined zigbee.0 2021-05-24 18:19:23.270 error (2787) Failed to start Zigbee zigbee.0 2021-05-24 18:19:21.681 info (2787) Installed Version: iobroker.zigbee@1.5.5 zigbee.0 2021-05-24 18:19:21.564 info (2787) Starting Zigbee npm ... zigbee.0 2021-05-24 18:19:21.534 info (2787) starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16 host.iobroker 2021-05-24 18:19:20.739 info instance system.adapter.zigbee.0 started with pid 2787 host.iobroker 2021-05-24 18:19:18.254 info instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) knx.0 2021-05-24 18:19:17.755 debug (1054) system.adapter.admin.0: logging true zigbee.0 2021-05-24 18:19:17.727 error (1568) Cannot read property 'getEntries' of null zigbee.0 2021-05-24 18:19:17.727 error at processTicksAndRejections (internal/process/task_queues.js:97:5) zigbee.0 2021-05-24 18:19:17.727 error at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) zigbee.0 2021-05-24 18:19:17.727 error at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:368:20) zigbee.0 2021-05-24 18:19:17.727 error at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:196:42) zigbee.0 2021-05-24 18:19:17.727 error at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) zigbee.0 2021-05-24 18:19:17.727 error at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:210:49) zigbee.0 2021-05-24 18:19:17.727 error at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) zigbee.0 2021-05-24 18:19:17.727 error at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:241:16) zigbee.0 2021-05-24 18:19:17.727 error at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:221:55) zigbee.0 2021-05-24 18:19:17.727 error (1568) TypeError: Cannot read property 'getEntries' of null zigbee.0 2021-05-24 18:19:17.727 error (1568) unhandled promise rejection: Cannot read property 'getEntries' of null zigbee.0 2021-05-24 18:19:17.727 error (1568) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). zigbee.0 2021-05-24 18:19:17.726 info (1568) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason zigbee.0 2021-05-24 18:19:17.726 info (1568) terminating zigbee.0 2021-05-24 18:19:17.726 warn (1568) Failed to stop zigbee during startup zigbee.0 2021-05-24 18:19:17.725 info (1568) Zigbee: disabling joining new devices. zigbee.0 2021-05-24 18:19:17.724 info (1568) cleaned everything up... zigbee.0 2021-05-24 18:19:17.724 info (1568) Got terminate signal TERMINATE_YOURSELF host.iobroker 2021-05-24 18:19:17.724 info stopInstance system.adapter.zigbee.0 send kill signal host.iobroker 2021-05-24 18:19:17.720 info stopInstance system.adapter.zigbee.0 (force=false, process=true) knx.0 2021-05-24 18:19:16.316 debug (1054) system.adapter.admin.0: logging false zigbee.0 2021-05-24 18:19:12.258 error (1568) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefinedwas tut dem Zigbee Adapter weh?
Proxmox:
@mpl1338 installiere bitte JETZT von GIT nicht das du eine buggy Version erwischt hast
zigbee.0 2021-05-24 19:17:59.412 error at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12 zigbee.0 2021-05-24 19:17:59.412 error at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14) zigbee.0 2021-05-24 19:17:59.412 error at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49) zigbee.0 2021-05-24 19:17:59.412 error at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12) zigbee.0 2021-05-24 19:17:59.412 error at new Promise (<anonymous>) zigbee.0 2021-05-24 19:17:59.412 error at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71 zigbee.0 2021-05-24 19:17:59.412 error at Generator.next (<anonymous>) zigbee.0 2021-05-24 19:17:59.412 error at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32) zigbee.0 2021-05-24 19:17:59.412 error (4592) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' zigbee.0 2021-05-24 19:17:59.411 error (4592) Failed to start Zigbee zigbee.0 2021-05-24 19:17:59.312 info (4592) Installed Version: ioBroker/ioBroker.zigbee#931800aecb03758f9cf7d92a751609de574b1b37 zigbee.0 2021-05-24 19:17:59.306 info (4592) Starting Zigbee npm ... zigbee.0 2021-05-24 19:17:59.305 info (4592) Try to reconnect. 1 attempts left zigbee.0 2021-05-24 19:17:49.304 error at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:24:58) zigbee.0 2021-05-24 19:17:49.304 error at Generator.next (<anonymous>) zigbee.0 2021-05-24 19:17:49.304 error at ZnpAdapterManager.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:201:35) zigbee.0 2021-05-24 19:17:49.304 error (4592) Error: startup failed - configuration-adapter mismatch - see logs above for more information zigbee.0 2021-05-24 19:17:49.303 error (4592) Failed to start Zigbee zigbee.0 2021-05-24 19:17:49.303 error (4592) Re-commissioning your network will require re-pairing of all devices! zigbee.0 2021-05-24 19:17:49.303 error (4592) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json. zigbee.0 2021-05-24 19:17:49.303 error (4592) Please update configuration to prevent further issues. zigbee.0 2021-05-24 19:17:49.303 error (4592) - Channel List: configured=11, adapter=11 zigbee.0 2021-05-24 19:17:49.303 error (4592) - Network Key: configured=blabla, adapter=blabla zigbee.0 2021-05-24 19:17:49.303 error (4592) - Extended PAN ID: configured=blabla, adapter=00124b00062d6098 zigbee.0 2021-05-24 19:17:49.303 error (4592) - PAN ID: configured=6754, adapter=6754 zigbee.0 2021-05-24 19:17:49.302 error (4592) Configuration is not consistent with adapter state/backup! zigbee.0 2021-05-24 19:17:47.677 info (4592) Installed Version: ioBroker/ioBroker.zigbee#931800aecb03758f9cf7d92a751609de574b1b37 zigbee.0 2021-05-24 19:17:47.576 info (4592) Starting Zigbee npm ... zigbee.0 2021-05-24 19:17:47.528 info (4592) starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16immernoch
@mpl1338 du fährst mit npm 7.x ??
@mpl1338
npm@7 ist auch nicht die empfohlene Version zu deinem node12. -
update auf 7 erfolgte erst eben.
zurück zu 6:
which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs /usr/bin/nodejs /usr/bin/node /usr/bin/npm v12.22.1 v12.22.1 6.14.13 nodejs: Installed: 12.22.1-1nodesource1 Candidate: 12.22.1-1nodesource1 Version table: *** 12.22.1-1nodesource1 500 500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u1 500 500 http://ftp.debian.org/debian buster/main amd64 Packages 500 http://security.debian.org buster/updates/main amd64 Packageszigbee.0 2021-05-24 19:41:43.508 error at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12 zigbee.0 2021-05-24 19:41:43.508 error at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14) zigbee.0 2021-05-24 19:41:43.508 error at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49) zigbee.0 2021-05-24 19:41:43.508 error at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12) zigbee.0 2021-05-24 19:41:43.508 error at new Promise (<anonymous>) zigbee.0 2021-05-24 19:41:43.508 error at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71 zigbee.0 2021-05-24 19:41:43.508 error at Generator.next (<anonymous>) zigbee.0 2021-05-24 19:41:43.508 error at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32) zigbee.0 2021-05-24 19:41:43.508 error (5962) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' zigbee.0 2021-05-24 19:41:43.508 error (5962) Failed to start Zigbeeiobroker Platform linux Betriebssystem linux Architektur x64 CPUs 2 Geschwindigkeit 3600 MHz Modell Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz RAM 4 GB System Betriebszeit 4 T. 23:16:12 Node.js v12.22.1 Festplatte Größe 12 GB Festplatte frei 7.81 GB Anzahl der Adapter 411 NPM v6.14.13 Betriebszeit 00:02:58 Aktive Instanzen 25 Hostname iobrokerund problem immernoch da
zurück zu 6:
@mpl1338 Was liegt denn da drauf?
sudo lsof /dev/ttyACM0 -
sudo lsof /dev/ttyACM0@thomas-braun said in zigbee nach update gelb:
sudo lsof /dev/ttyACM0sudo lsof /dev/ttyACM0 COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME node 1305 iobroker 27uW CHR 166,0 0t0 361 /dev/ttyACM0 -
zurück zu 6:
@mpl1338 proxmox selbst mal neu gestartet, bzw stick mal abgesteckt?
@mpl1338 seltsam
iobroker stopDamn nochmal schauen ob das File noch offen ist, process ggf. killen,
iobroker start -
iobroker startbin jetzt auf 1.4.1 runter - da läufts wieder
Habe auch gerade Update gemacht und der Adapter bleibt rot. Folgende Fehler habe ich:
Hat einer eine Idee?
