  4. ZigBee neue Version 1.5.x
    6.4k
579 Beiträge 72 Kommentatoren 188.1k Aufrufe 74 Beobachtet
  • AsgothianA Asgothian
    @disaster123
    Was für Hardware hast du ?
    disaster123
    #119
    @asgothian conbee 2 usb Stick via qemu / kvm in eine vm und von da in einen docker container mit iobroker
      @disaster123
      disaster123
      #120
      @asgothian seit heute morgen sieht es alle 2 Stunden so aus:
      zigbee.0	2021-05-07 09:13:07.484	error	(6485) Error while opening serialport 'Error: Error: No such device or address, cannot open /dev/ttyACM1'
      zigbee.0	2021-05-07 09:13:07.484	error	at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12
      zigbee.0	2021-05-07 09:13:07.484	error	at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14)
      zigbee.0	2021-05-07 09:13:07.484	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:158:45)
      zigbee.0	2021-05-07 09:13:07.484	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:4:12)
      zigbee.0	2021-05-07 09:13:07.484	error	at new Promise (<anonymous>)
      zigbee.0	2021-05-07 09:13:07.484	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:8:71
      zigbee.0	2021-05-07 09:13:07.484	error	at Generator.next (<anonymous>)
      zigbee.0	2021-05-07 09:13:07.484	error	at Driver.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:160:28)
      zigbee.0	2021-05-07 09:13:07.484	error	(6485) Error: Error while opening serialport 'Error: Error: No such device or address, cannot open /dev/ttyACM1'
      zigbee.0	2021-05-07 09:13:07.484	error	(6485) unhandled promise rejection: Error while opening serialport 'Error: Error: No such device or address, cannot open /dev/ttyACM1'
      zigbee.0	2021-05-07 09:13:07.482	error	(6485) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      AsgothianA arteckA 2 Antworten Letzte Antwort
      -1
      • Tom SonT Offline
        Tom SonT Offline
        Tom Son
        #121
        Langsam frustiert mich das ganze, jetzt mache ich das doofe js update schon zum dritten mal und immer sind alle Geräte in der Zigbee Instanz weg :-( Muss dann alle wieder koppeln.... Gibt es da keine bessere Lösung?
        Ich glaube ich gehe zurück auf stable :-( :-(
        TI Board CC2652R1 / latest / js-Controler 3.3.18 / NodeJS 12.22.7
        crunchipC amg_666A L 3 Antworten Letzte Antwort
        • Tom SonT Tom Son
          crunchipC Offline
          crunchipC Offline
          #122
          @tom-son sagte in ZigBee neue Version 1.5.x:
          js update
          welches?
          nach dem Fehler suchen (log) , oder die shepherd.dp aus dem backup einspielen, dann müssten die Sensoren wieder da sein, ohne neu anzulernen
          Tom SonT 1 Antwort Letzte Antwort
          • Tom SonT Tom Son
            amg_666A Offline
            amg_666A Offline
            amg_666
            #123
            @tom-son Hm, also bei mir läuft das alles stabil,
            Node.js: v14.16.1, NPM: 6.14.12 und iobroker 3.3.8
            admin 5.0.15 und zigbee 1.5.5
            Das ganze läuft als VM unter Debian auf einem intel nuc mit proxmox
            Einzig nerviger Punkt ist, dass der zigbee unter "Netzwerkkarte" alle Geräte als nicht verbunden und rot darstellt, das dauert dann zwischen 5 und vielleicht 20 Sekunden und dann stimmt die Karte auch.
            KEINE "Verluste" von Geräten, KEINE Funktionseinschränkungen
            Horst BöttcherH 1 Antwort Letzte Antwort
            • amg_666A amg_666
              Horst BöttcherH Offline
              Horst Böttcher
              #124
              Hallo der Adapter bleibt bei mir gelb
              und nix geht mehr
              Aus den log
              zigbee.0	2021-05-07 21:55:23.893	error	(6335) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
              ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
              • Tom SonT Tom Son
                luie
                schrieb am zuletzt editiert von luie
                #125
                js update
                Wie gehst du vor?
                Bei mir lief das update auf js-controller 3.3.8 ohne Probleme. Ich musste nur nach dem reboot des raspi den zigbee-Adapter 1x stoppen und dann wieder starten.
                debian13-x64, docker, SONOFF ZigBee 3.0 USB DONGLE PLUS, Admin 7.8.29, Node.js v22.22.2, NPM 10.9.7, js-controller 7.1.2
                Horst BöttcherH Tom SonT 2 Antworten Letzte Antwort
                • L luie
                  js update
                  Wie gehst du vor?
                  Horst Böttcher
                  schrieb am zuletzt editiert von Horst Böttcher
                  #126
                  für leicht ist was falsch gelaufen
                  JS update nach anleitung
                  • D disaster123
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    #127
                    @disaster123 da passt etwas mit der Weiterleitung der seriellen Schnittstelle nicht. Die Meldung
                    No such device or address...
                    Ist da recht eindeutig.
                    A.
                    • Horst BöttcherH Horst Böttcher
                      und nix geht mehr
                      Aus den log
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #128
                      @horst-böttcher
                      Bitte das komplette log des Start Vorgangs des zigbee Adapters posten, nicht nur eine Zeile.
                      A.
                        @horst-böttcher
                        A.
                        Horst Böttcher
                        #129
                        @asgothian
                        habe den USB Port gewechselt jetzt sind die Geräte da lassen sich aber nicht schalten
                        Über all steht Disconectet
                          js update
                          welches?
                          Tom SonT Offline
                          Tom SonT Offline
                          Tom Son
                          #130
                          @crunchip JS 3.3.8
                          Das mit dem shepherd klingt gut, aber wie geht das? Hasz du bitte eine Anleitung?
                          • L luie
                            js update
                            Wie gehst du vor?
                            Tom SonT Offline
                            Tom SonT Offline
                            Tom Son
                            #131
                            @luie mache das update über die Konsole wie inder Beschreibung und anschließend mach ich immer einen Reboot, aber nach einem restart des Adapter blieb immer noch alles leer...
                            • D disaster123
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #132
                              @disaster123 multihost ?
                              • I Offline
                                I Offline
                                io_laurent
                                #133
                                ich habe seit einiger Zeit eine Fehlermeldung im Log, mit welcher ich nichts anfangen kann:
                                2021-05-08 11:04:04.567 - error: zigbee.0 (5950) Failed to DeviceConfigure.onZigbeeEvent (Error: '404001' has no configure
                                at Object.getConfigureKey (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/configureKey.js:20:15)
                                at DeviceConfigure.shouldConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:33:38)
                                at DeviceConfigure.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:76:22)
                                at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:196:42)
                                at ZigbeeController.handleMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:14))
                                Diese Meldung kommt ca. alle 20-60 Sekunden.
                                Das System läuft ohne irgendwelche Probleme, raspi4, admin 5.0.18, Zigbee 1.5.5, js-controller 3.3.8 (den Fehler gab es aber auch schon vorher, ab 3.3.4 wenn ich richtig erinnere).
                                Kann da jemand helfen?
                                Vielen Dank!
                                  disaster123
                                  #134
                                  Hat irgendjemand eine Idee wie ich die sensivity beim Aqara Neigungssensor ändern kann? Es gibt zwar mit 1.5 ein drop down aber immer wenn ich Versuche dort etwas einzustellen kommt nach einiger Zeit:
                                  (449) Send command to 0x00158d0006896b8d failed with no error code (no response received)
                                  Habe schon versucht Knopf kurz drücken am Sensor oder lang drücken nach dem Absetzen - aber hilft alles nichts.
                                  • D disaster123
                                    crunchipC Offline
                                    crunchipC Offline
                                    #135
                                    @disaster123 hat bei mir bisher auch nicht funktioniert, habe mich damit allerdings nicht weiter beschäftigt
                                    • C Offline
                                      ChrisXY
                                      #136
                                      schöne neue Version. Wäre gut wenn man per Button alle Kacheln umdrehen könnte. Sehe sonst keine Firmware Update Icons :D
                                      • L Offline
                                        luie
                                        #137
                                        @Asgothian
                                        Bei mir führt ein Versuch der Firmwareaktualisierung immer zum Absturz des Adapters. Im git gibt es dazu auch ein issue aber ich möchte mich nicht unbedingt auch noch im git anmelden. Können wir das auch hier behandeln?
                                        git zigbee issue #653
                                        2021-05-08 17:25:12.660 - info: zigbee.0 (5165) starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.1.0, js-controller: 3.3.8
                                        2021-05-08 17:25:12.768 - info: zigbee.0 (5165) Starting Zigbee npm ...
                                        2021-05-08 17:25:13.095 - info: zigbee.0 (5165) Installed Version: ioBroker/ioBroker.zigbee#master
                                        2021-05-08 17:25:13.266 - info: zigbee.0 (5165) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
                                        2021-05-08 17:25:13.315 - info: zigbee.0 (5165) Unable to disable LED, unsupported function.
                                        2021-05-08 17:25:13.316 - info: zigbee.0 (5165) --> transmitPower : normal
                                        2021-05-08 17:25:13.318 - info: zigbee.0 (5165) Unable to set transmit power, unsupported function.
                                        2021-05-08 17:25:13.323 - info: zigbee.0 (5165) Currently 36 devices are joined:
                                        2021-05-08 17:25:13.407 - info: zigbee.0 (5165) 0x001788011039c09e (addr 50374): 324131092621 - Philips Hue dimmer switch (EndDevice)
                                        2021-05-08 17:25:13.412 - info: zigbee.0 (5165) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                                        2021-05-08 17:25:13.413 - info: zigbee.0 (5165) 0x00158d00056e2c1a (addr 45418): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                        2021-05-08 17:25:13.414 - info: zigbee.0 (5165) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                        2021-05-08 17:25:13.416 - info: zigbee.0 (5165) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
                                        2021-05-08 17:25:13.417 - info: zigbee.0 (5165) 0x84182600000a19e7 (addr 50161): AB3257001NJ - OSRAM Smart+ plug (Router)
                                        2021-05-08 17:25:13.419 - info: zigbee.0 (5165) 0xec1bbdfffecfa3d9 (addr 22434): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                                        2021-05-08 17:25:13.420 - info: zigbee.0 (5165) 0xec1bbdfffeec05dc (addr 13222): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                                        2021-05-08 17:25:13.422 - info: zigbee.0 (5165) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                                        2021-05-08 17:25:13.423 - info: zigbee.0 (5165) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                                        2021-05-08 17:25:13.424 - info: zigbee.0 (5165) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                                        2021-05-08 17:25:13.426 - info: zigbee.0 (5165) 0x00158d0001dcfc7e (addr 16956): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                        2021-05-08 17:25:13.427 - info: zigbee.0 (5165) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
                                        2021-05-08 17:25:13.428 - info: zigbee.0 (5165) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                                        2021-05-08 17:25:13.430 - info: zigbee.0 (5165) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                                        2021-05-08 17:25:13.431 - info: zigbee.0 (5165) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
                                        2021-05-08 17:25:13.432 - info: zigbee.0 (5165) 0x000d6f000e639ce8 (addr 59115): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
                                        2021-05-08 17:25:13.433 - info: zigbee.0 (5165) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
                                        2021-05-08 17:25:13.434 - info: zigbee.0 (5165) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                                        2021-05-08 17:25:13.435 - info: zigbee.0 (5165) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
                                        2021-05-08 17:25:13.437 - info: zigbee.0 (5165) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                                        2021-05-08 17:25:13.438 - info: zigbee.0 (5165) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                                        2021-05-08 17:25:13.440 - info: zigbee.0 (5165) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                                        2021-05-08 17:25:13.441 - info: zigbee.0 (5165) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                                        2021-05-08 17:25:13.442 - info: zigbee.0 (5165) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
                                        2021-05-08 17:25:13.443 - info: zigbee.0 (5165) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
                                        2021-05-08 17:25:13.445 - info: zigbee.0 (5165) 0x0017880100ce3b70 (addr 18432): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
                                        2021-05-08 17:25:13.448 - info: zigbee.0 (5165) 0x0017880100ce3b8c (addr 61494): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
                                        2021-05-08 17:25:13.450 - info: zigbee.0 (5165) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
                                        2021-05-08 17:25:13.451 - info: zigbee.0 (5165) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
                                        2021-05-08 17:25:13.452 - info: zigbee.0 (5165) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
                                        2021-05-08 17:25:13.454 - info: zigbee.0 (5165) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
                                        2021-05-08 17:25:13.456 - info: zigbee.0 (5165) 0x00158d00057f65f1 (addr 31779): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                                        2021-05-08 17:25:13.457 - info: zigbee.0 (5165) 0x00158d0005d0cec2 (addr 27089): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                        2021-05-08 17:25:13.458 - info: zigbee.0 (5165) 0x00158d000484ed05 (addr 61070): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                        2021-05-08 17:25:13.460 - info: zigbee.0 (5165) 0x00158d0006c4ba8e (addr 52637): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                        2021-05-08 17:25:13.461 - info: zigbee.0 (5165) Zigbee started
                                        2021-05-08 17:25:13.556 - info: zigbee.0 (5165) debug devices set to []
                                        2021-05-08 17:28:49.186 - info: zigbee.0 (5165) Start firmware update for 0xec1bbdfffecfa3d9
                                        2021-05-08 17:28:49.920 - error: zigbee.0 (5165) Update of '0xec1bbdfffecfa3d9' failed (Image is truncated: not long enough to contain a valid tag)
                                        2021-05-08 17:28:49.958 - info: zigbee.0 (5165) Failed to check if update available for '0x001788011039c09e' (Device didn't respond to OTA request)
                                        2021-05-08 17:28:49.976 - info: zigbee.0 (5165) Failed to check if update available for '0x000d6ffffe164575' (Device didn't respond to OTA request)
                                        2021-05-08 17:28:50.025 - info: zigbee.0 (5165) Failed to check if update available for '0x0017880104907516' (Device didn't respond to OTA request)
                                        2021-05-08 17:28:50.036 - info: zigbee.0 (5165) Failed to check if update available for '0x0017880103e5d609' (Device didn't respond to OTA request)
                                        2021-05-08 17:28:50.040 - info: zigbee.0 (5165) Failed to check if update available for '0x00178801011d9fce' (Device didn't respond to OTA request)
                                        2021-05-08 17:28:50.045 - info: zigbee.0 (5165) Failed to check if update available for '0x0017880102aca26e' (Device didn't respond to OTA request)
                                        2021-05-08 17:28:50.048 - info: zigbee.0 (5165) Failed to check if update available for '0x7cb03eaa00b266c1' (Device didn't respond to OTA request)
                                        2021-05-08 17:28:50.050 - info: zigbee.0 (5165) Failed to check if update available for '0x0017880100ce3b70' (Device didn't respond to OTA request)
                                        2021-05-08 17:28:50.053 - info: zigbee.0 (5165) Failed to check if update available for '0x0017880100ce3b8c' (Device didn't respond to OTA request)
                                        2021-05-08 17:28:50.055 - info: zigbee.0 (5165) Failed to check if update available for '0x001788010801afea' (Device didn't respond to OTA request)
                                        2021-05-08 17:28:50.058 - info: zigbee.0 (5165) Failed to check if update available for '0x7cb03eaa0a066d68' (Device didn't respond to OTA request)
                                        2021-05-08 17:28:50.067 - info: zigbee.0 (5165) Failed to check if update available for '0x7cb03eaa0a030c48' (Device didn't respond to OTA request)
                                        2021-05-08 17:28:56.107 - error: zigbee.0 (5165) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2021-05-08 17:28:56.107 - error: zigbee.0 (5165) unhandled promise rejection: undefined
                                        2021-05-08 17:28:56.109 - info: zigbee.0 (5165) cleaned everything up...
                                        2021-05-08 17:28:56.112 - info: zigbee.0 (5165) Zigbee: disabling joining new devices.
                                        2021-05-08 17:28:56.440 - error: zigbee.0 (5165) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2021-05-08 17:28:56.440 - error: zigbee.0 (5165) unhandled promise rejection: undefined
                                        2021-05-08 17:28:56.610 - info: zigbee.0 (5165) terminating
                                        2021-05-08 17:28:56.612 - warn: zigbee.0 (5165) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        2021-05-08 17:28:57.183 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                        2021-05-08 17:28:57.188 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
                                        2021-05-08 17:28:57.189 - warn: host.raspberrypi Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                                          disaster123
                                          #138
                                          Hat es schonmal jemand geschafft bei einem Batteriesensor die Konfiguration zu ändern?
