  4. ZigBee neue Version 1.5.x
    6.4k
579 Beiträge 72 Kommentatoren 188.1k Aufrufe 74 Beobachtet
  • D disaster123
    @asgothian seit heute morgen sieht es alle 2 Stunden so aus:
    zigbee.0	2021-05-07 09:13:07.484	error	(6485) Error while opening serialport 'Error: Error: No such device or address, cannot open /dev/ttyACM1'
    zigbee.0	2021-05-07 09:13:07.484	error	at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12
    zigbee.0	2021-05-07 09:13:07.484	error	at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14)
    zigbee.0	2021-05-07 09:13:07.484	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:158:45)
    zigbee.0	2021-05-07 09:13:07.484	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:4:12)
    zigbee.0	2021-05-07 09:13:07.484	error	at new Promise (<anonymous>)
    zigbee.0	2021-05-07 09:13:07.484	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:8:71
    zigbee.0	2021-05-07 09:13:07.484	error	at Generator.next (<anonymous>)
    zigbee.0	2021-05-07 09:13:07.484	error	at Driver.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:160:28)
    zigbee.0	2021-05-07 09:13:07.484	error	(6485) Error: Error while opening serialport 'Error: Error: No such device or address, cannot open /dev/ttyACM1'
    zigbee.0	2021-05-07 09:13:07.484	error	(6485) unhandled promise rejection: Error while opening serialport 'Error: Error: No such device or address, cannot open /dev/ttyACM1'
    zigbee.0	2021-05-07 09:13:07.482	error	(6485) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #127
    @disaster123 da passt etwas mit der Weiterleitung der seriellen Schnittstelle nicht. Die Meldung
    No such device or address...
    Ist da recht eindeutig.
    A.
    • Horst BöttcherH Horst Böttcher
      Hallo der Adapter bleibt bei mir gelb
      und nix geht mehr
      Aus den log
      zigbee.0	2021-05-07 21:55:23.893	error	(6335) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      #128
      @horst-böttcher
      Bitte das komplette log des Start Vorgangs des zigbee Adapters posten, nicht nur eine Zeile.
      A.
      Horst BöttcherH 1 Antwort Letzte Antwort
      • AsgothianA Asgothian
        @horst-böttcher
        A.
        Horst BöttcherH Offline
        Horst Böttcher
        #129
        @asgothian
        habe den USB Port gewechselt jetzt sind die Geräte da lassen sich aber nicht schalten
        Über all steht Disconectet
        ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
          @tom-son sagte in ZigBee neue Version 1.5.x:
          js update
          welches?
          Gibt es da keine bessere Lösung
          nach dem Fehler suchen (log) , oder die shepherd.dp aus dem backup einspielen, dann müssten die Sensoren wieder da sein, ohne neu anzulernen
          Tom SonT Offline
          Tom SonT Offline
          Tom Son
          #130
          @crunchip JS 3.3.8
          Das mit dem shepherd klingt gut, aber wie geht das? Hasz du bitte eine Anleitung?
          TI Board CC2652R1 / latest / js-Controler 3.3.18 / NodeJS 12.22.7
          • L luie
            js update
            Wie gehst du vor?
            Bei mir lief das update auf js-controller 3.3.8 ohne Probleme. Ich musste nur nach dem reboot des raspi den zigbee-Adapter 1x stoppen und dann wieder starten.
            Tom SonT Offline
            Tom SonT Offline
            Tom Son
            #131
            @luie mache das update über die Konsole wie inder Beschreibung und anschließend mach ich immer einen Reboot, aber nach einem restart des Adapter blieb immer noch alles leer...
            • D disaster123
              arteckA Offline
              arteckA Offline
              arteck
              #132
              @disaster123 multihost ?
              • I Offline
                I Offline
                io_laurent
                #133
                ich habe seit einiger Zeit eine Fehlermeldung im Log, mit welcher ich nichts anfangen kann:
                2021-05-08 11:04:04.567 - error: zigbee.0 (5950) Failed to DeviceConfigure.onZigbeeEvent (Error: '404001' has no configure
                at Object.getConfigureKey (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/configureKey.js:20:15)
                at DeviceConfigure.shouldConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:33:38)
                at DeviceConfigure.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:76:22)
                at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:196:42)
                at ZigbeeController.handleMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:14))
                Diese Meldung kommt ca. alle 20-60 Sekunden.
                Das System läuft ohne irgendwelche Probleme, raspi4, admin 5.0.18, Zigbee 1.5.5, js-controller 3.3.8 (den Fehler gab es aber auch schon vorher, ab 3.3.4 wenn ich richtig erinnere).
                Kann da jemand helfen?
                Vielen Dank!
                  disaster123
                  #134
                  Hat irgendjemand eine Idee wie ich die sensivity beim Aqara Neigungssensor ändern kann? Es gibt zwar mit 1.5 ein drop down aber immer wenn ich Versuche dort etwas einzustellen kommt nach einiger Zeit:
                  (449) Send command to 0x00158d0006896b8d failed with no error code (no response received)
                  Habe schon versucht Knopf kurz drücken am Sensor oder lang drücken nach dem Absetzen - aber hilft alles nichts.
                  • D disaster123
                    crunchipC Offline
                    crunchipC Offline
                    #135
                    @disaster123 hat bei mir bisher auch nicht funktioniert, habe mich damit allerdings nicht weiter beschäftigt
                    • C Offline
                      ChrisXY
                      #136
                      schöne neue Version. Wäre gut wenn man per Button alle Kacheln umdrehen könnte. Sehe sonst keine Firmware Update Icons :D
                      • L Offline
                        luie
                        #137
                        @Asgothian
                        Bei mir führt ein Versuch der Firmwareaktualisierung immer zum Absturz des Adapters. Im git gibt es dazu auch ein issue aber ich möchte mich nicht unbedingt auch noch im git anmelden. Können wir das auch hier behandeln?
                        git zigbee issue #653
                        2021-05-08 17:25:12.660 - info: zigbee.0 (5165) starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.1.0, js-controller: 3.3.8
                        2021-05-08 17:25:12.768 - info: zigbee.0 (5165) Starting Zigbee npm ...
                        2021-05-08 17:25:13.095 - info: zigbee.0 (5165) Installed Version: ioBroker/ioBroker.zigbee#master
                        2021-05-08 17:25:13.266 - info: zigbee.0 (5165) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":105,"maintrel":0,"revision":"0x26690700"}}
                        2021-05-08 17:25:13.315 - info: zigbee.0 (5165) Unable to disable LED, unsupported function.
                        2021-05-08 17:25:13.316 - info: zigbee.0 (5165) --> transmitPower : normal
                        2021-05-08 17:25:13.318 - info: zigbee.0 (5165) Unable to set transmit power, unsupported function.
                        2021-05-08 17:25:13.323 - info: zigbee.0 (5165) Currently 36 devices are joined:
                        2021-05-08 17:25:13.407 - info: zigbee.0 (5165) 0x001788011039c09e (addr 50374): 324131092621 - Philips Hue dimmer switch (EndDevice)
                        2021-05-08 17:25:13.412 - info: zigbee.0 (5165) 0x00178801049bab21 (addr 59296): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                        2021-05-08 17:25:13.413 - info: zigbee.0 (5165) 0x00158d00056e2c1a (addr 45418): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                        2021-05-08 17:25:13.414 - info: zigbee.0 (5165) 0x000d6ffffe164575 (addr 38575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                        2021-05-08 17:25:13.416 - info: zigbee.0 (5165) 0x7cb03eaa0a030c48 (addr 40071): AB3257001NJ - OSRAM Smart+ plug (Router)
                        2021-05-08 17:25:13.417 - info: zigbee.0 (5165) 0x84182600000a19e7 (addr 50161): AB3257001NJ - OSRAM Smart+ plug (Router)
                        2021-05-08 17:25:13.419 - info: zigbee.0 (5165) 0xec1bbdfffecfa3d9 (addr 22434): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                        2021-05-08 17:25:13.420 - info: zigbee.0 (5165) 0xec1bbdfffeec05dc (addr 13222): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                        2021-05-08 17:25:13.422 - info: zigbee.0 (5165) 0x680ae2fffe11ed0f (addr 34368): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                        2021-05-08 17:25:13.423 - info: zigbee.0 (5165) 0x680ae2fffe3540df (addr 5239): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                        2021-05-08 17:25:13.424 - info: zigbee.0 (5165) 0x680ae2fffe39478e (addr 44077): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                        2021-05-08 17:25:13.426 - info: zigbee.0 (5165) 0x00158d0001dcfc7e (addr 16956): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                        2021-05-08 17:25:13.427 - info: zigbee.0 (5165) 0x84182600000a21ea (addr 17446): AB3257001NJ - OSRAM Smart+ plug (Router)
                        2021-05-08 17:25:13.428 - info: zigbee.0 (5165) 0x00178801029c2ab5 (addr 28900): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                        2021-05-08 17:25:13.430 - info: zigbee.0 (5165) 0x0017880104907516 (addr 24066): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                        2021-05-08 17:25:13.431 - info: zigbee.0 (5165) 0x0017880102130d27 (addr 34504): 9290012607 - Philips Hue motion sensor (EndDevice)
                        2021-05-08 17:25:13.432 - info: zigbee.0 (5165) 0x000d6f000e639ce8 (addr 59115): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
                        2021-05-08 17:25:13.433 - info: zigbee.0 (5165) 0x8418260000101cf6 (addr 45885): AB3257001NJ - OSRAM Smart+ plug (Router)
                        2021-05-08 17:25:13.434 - info: zigbee.0 (5165) 0x90fd9ffffe78e7ca (addr 44873): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                        2021-05-08 17:25:13.435 - info: zigbee.0 (5165) 0x0017880103e5d609 (addr 5539): 324131092621 - Philips Hue dimmer switch (EndDevice)
                        2021-05-08 17:25:13.437 - info: zigbee.0 (5165) 0x00178801011a95ad (addr 51145): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                        2021-05-08 17:25:13.438 - info: zigbee.0 (5165) 0x00178801011d9fce (addr 64403): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                        2021-05-08 17:25:13.440 - info: zigbee.0 (5165) 0x00178801011ad866 (addr 42082): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                        2021-05-08 17:25:13.441 - info: zigbee.0 (5165) 0x0017880102aca26e (addr 18295): 915005106701 - Philips Hue white and color ambiance LightStrip plus (Router)
                        2021-05-08 17:25:13.442 - info: zigbee.0 (5165) 0x000d6f000d5ac2a8 (addr 6178): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
                        2021-05-08 17:25:13.443 - info: zigbee.0 (5165) 0x7cb03eaa00b266c1 (addr 51847): AB3257001NJ - OSRAM Smart+ plug (Router)
                        2021-05-08 17:25:13.445 - info: zigbee.0 (5165) 0x0017880100ce3b70 (addr 18432): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
                        2021-05-08 17:25:13.448 - info: zigbee.0 (5165) 0x0017880100ce3b8c (addr 61494): 7299355PH - Philips Hue white and color ambiance LightStrip (Router)
                        2021-05-08 17:25:13.450 - info: zigbee.0 (5165) 0x001788010801afea (addr 9490): 8718699693985 - Philips Hue smart button (EndDevice)
                        2021-05-08 17:25:13.451 - info: zigbee.0 (5165) 0x7cb03eaa0a066d68 (addr 57807): AB3257001NJ - OSRAM Smart+ plug (Router)
                        2021-05-08 17:25:13.452 - info: zigbee.0 (5165) 0x0017880108e79c10 (addr 9049): 929002240401 - Philips Hue smart plug - EU (Router)
                        2021-05-08 17:25:13.454 - info: zigbee.0 (5165) 0x804b50fffebbef5c (addr 11623): 5120.1100 - Iluminize ZigBee 3.0 Dimm-Aktor mini 1x 230V (Router)
                        2021-05-08 17:25:13.456 - info: zigbee.0 (5165) 0x00158d00057f65f1 (addr 31779): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                        2021-05-08 17:25:13.457 - info: zigbee.0 (5165) 0x00158d0005d0cec2 (addr 27089): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                        2021-05-08 17:25:13.458 - info: zigbee.0 (5165) 0x00158d000484ed05 (addr 61070): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                        2021-05-08 17:25:13.460 - info: zigbee.0 (5165) 0x00158d0006c4ba8e (addr 52637): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                        2021-05-08 17:25:13.461 - info: zigbee.0 (5165) Zigbee started
                        2021-05-08 17:25:13.556 - info: zigbee.0 (5165) debug devices set to []
                        2021-05-08 17:28:49.186 - info: zigbee.0 (5165) Start firmware update for 0xec1bbdfffecfa3d9
                        2021-05-08 17:28:49.920 - error: zigbee.0 (5165) Update of '0xec1bbdfffecfa3d9' failed (Image is truncated: not long enough to contain a valid tag)
                        2021-05-08 17:28:49.958 - info: zigbee.0 (5165) Failed to check if update available for '0x001788011039c09e' (Device didn't respond to OTA request)
                        2021-05-08 17:28:49.976 - info: zigbee.0 (5165) Failed to check if update available for '0x000d6ffffe164575' (Device didn't respond to OTA request)
                        2021-05-08 17:28:50.025 - info: zigbee.0 (5165) Failed to check if update available for '0x0017880104907516' (Device didn't respond to OTA request)
                        2021-05-08 17:28:50.036 - info: zigbee.0 (5165) Failed to check if update available for '0x0017880103e5d609' (Device didn't respond to OTA request)
                        2021-05-08 17:28:50.040 - info: zigbee.0 (5165) Failed to check if update available for '0x00178801011d9fce' (Device didn't respond to OTA request)
                        2021-05-08 17:28:50.045 - info: zigbee.0 (5165) Failed to check if update available for '0x0017880102aca26e' (Device didn't respond to OTA request)
                        2021-05-08 17:28:50.048 - info: zigbee.0 (5165) Failed to check if update available for '0x7cb03eaa00b266c1' (Device didn't respond to OTA request)
                        2021-05-08 17:28:50.050 - info: zigbee.0 (5165) Failed to check if update available for '0x0017880100ce3b70' (Device didn't respond to OTA request)
                        2021-05-08 17:28:50.053 - info: zigbee.0 (5165) Failed to check if update available for '0x0017880100ce3b8c' (Device didn't respond to OTA request)
                        2021-05-08 17:28:50.055 - info: zigbee.0 (5165) Failed to check if update available for '0x001788010801afea' (Device didn't respond to OTA request)
                        2021-05-08 17:28:50.058 - info: zigbee.0 (5165) Failed to check if update available for '0x7cb03eaa0a066d68' (Device didn't respond to OTA request)
                        2021-05-08 17:28:50.067 - info: zigbee.0 (5165) Failed to check if update available for '0x7cb03eaa0a030c48' (Device didn't respond to OTA request)
                        2021-05-08 17:28:56.107 - error: zigbee.0 (5165) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2021-05-08 17:28:56.107 - error: zigbee.0 (5165) unhandled promise rejection: undefined
                        2021-05-08 17:28:56.109 - info: zigbee.0 (5165) cleaned everything up...
                        2021-05-08 17:28:56.112 - info: zigbee.0 (5165) Zigbee: disabling joining new devices.
                        2021-05-08 17:28:56.440 - error: zigbee.0 (5165) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2021-05-08 17:28:56.440 - error: zigbee.0 (5165) unhandled promise rejection: undefined
                        2021-05-08 17:28:56.610 - info: zigbee.0 (5165) terminating
                        2021-05-08 17:28:56.612 - warn: zigbee.0 (5165) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2021-05-08 17:28:57.183 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        2021-05-08 17:28:57.188 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
                        2021-05-08 17:28:57.189 - warn: host.raspberrypi Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                        debian13-x64, docker, SONOFF ZigBee 3.0 USB DONGLE PLUS, Admin 7.8.29, Node.js v22.22.2, NPM 10.9.7, js-controller 7.1.2
                          disaster123
                          #138
                          Hat es schonmal jemand geschafft bei einem Batteriesensor die Konfiguration zu ändern?
                          • D disaster123
                            klassisch
                            #139
                            @disaster123 sagte in ZigBee neue Version 1.5.x:
                            Beispiel?
                            Die meisten Zgbee Geräte scheinen mir äußerst sparsam mit Konfigurationsmöglichkeiten - zumindest im Vergleich mit den klassischen Homematic-Geräten.
                            • K klassisch
                              Beispiel?
                              disaster123
                              #140
                              @klassisch Sensifity bei mir von den Aqara Neigungssensoren
                                klausiob
                                schrieb am zuletzt editiert von klausiob
                                #141
                                Sorry offtopic. Warum ist der Thread "ZigBee neue Version 1.4.4" gesperrt, die Version ist doch die letzte stable?
                                Habe einen Aqara Door & Window contact pairen wollen (neu ausgepackt aber vor 2 Jahren gekauft). Pairen funktionierte auch sofort, hat hier alles angezeigt was unter Geräteinformationen steht. Die Kachel unter den Geräten sieht aber nicht gut aus. Man kann auch den Namen nicht editieren. Funktionieren tut aber der Sensor. Was könnte da los sein?
                                ZigBee-Coordinator ist noch cc2531.
                                20210509 ZigBee Aqara door & Window contact sensor 2.JPG .
                                Anbei noch ein Sensor, der schon seit 2 Jahren dran hängt und aus der gleichen Charge ist. Merkwürdiger Weise mit ein paar weniger Geräteinfos.
                                Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
                                node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
                                • K klausiob
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  #142
                                  @klausiob sagte in ZigBee neue Version 1.5.x:
                                  Der thread ist gesperrt weil die Entwicklung jetzt mit der 1.5.x weiter geht. Probleme mit der 1.4.4 sollten in eigenen Threads diskutiert werden, da sie in den seltensten Fällen alleine mit der Adapter Version zusammen hängen. Und wenn etwas geändert wird dann in der 1.5.x
                                  Nun zu deinen Effekten:
                                  Ohne Log Dateien und mehr Informationen ist es unmöglich da etwas zu zu schreiben.
                                  A.
                                    A.
                                    klausiob
                                    #143
                                    @asgothian Ja, klar. Merke gerade, dass in den downgeloadeten Logs kein zigbee vorkommt, obwohl unter admin ein warning drin steht. Der Zigbee-Adapter läuft auf einen Pi3-Slave. Die Warnings zeigt er zwar bei Auswahl des entsprechenden Hosts an, lassen sich aber nicht herunterladen. Muß ich da mitPutty oder FTP ran? Wollte den log vom Tag des Pairen nehmen.
                                    Bei der Gelegenheit die Warnings, die auch neu sind. Bei allen Aqara Temperatursensoren.
                                    zigbee.0	2021-05-09 08:33:07.007	warn	(1811) State value to set for "zigbee.0.00158d0002c16bed.pressure" has value "986.8" greater than max "100"
                                    zigbee.0	2021-05-09 08:32:48.984	warn	(1811) State value to set for "zigbee.0.00158d0002c1470d.pressure" has value "987.7" greater than max "100"
                                    Ansonsten noch ein Hinweis:
                                    • K klausiob
                                      crunchipC Offline
                                      crunchipC Offline
                                      #144
                                      @klausiob sollte im Raw so aussehen
                                        "type": "state",
                                        "common": {
                                          "name": "HWR Pressure",
                                          "type": "number",
                                          "unit": "hPa",
                                          "read": true,
                                          "write": false,
                                          "role": "value.pressure",
                                          "min": 0,
                                          "max": 10000,
                                          "smartName": false
                                          "type": "state",
                                          "common": {
                                            "type": "number",
                                            "unit": "hPa",
                                            "read": true,
                                            "write": false,
                                            "min": 0,
                                            "max": 10000,
                                            "smartName": false
                                        klausiob
                                        #145
                                        @crunchip @Asgothian ja da steht 100, warum auch. War 2 Jahre kein Problem. Hatte den Wert auch schon hoch gesetzt, aber irgendwann steht wieder 100 drin? ZigBee-Adapter läuft auf Slave Pi3 nach wie vor. Hatte versuchtden js-controller von 3.0.18 auf 3.3.8 upzudaten. Lief auch alles fehlerfrei durch. Dann wollte ich den js-controller des Hosts von 2.2.9 auf 3.3.8 updaten. Da kamen dann Fehler vom Slave
                                         Objects 192.168.178.xx:45020 Error from InMemDB: Error: client NOT SUPPORTED
                                         Objects 192.168.178.xx:45022 Error from InMemDB: Error: client NOT SUPPORTED
                                         Objects 192.168.178.xx:45024 Error from InMemDB: Error: client NOT SUPPORTED
                                         Objects 192.168.178.xx:45030 Error from InMemDB: Error: client NOT SUPPORTED
                                        Da muß ich wohl was zerschossen haben. Habe dann wieder js-controller 2.2.9 installiert.
                                        Fehler bleiben aber, als ob der Master nicht auf die Daten zugreifen kann. Habe mal ein Restart des ZigBee-Adapters gemacht und folgendes Log gezogen:
                                        zigbee.0	2021-05-10 09:23:35.046	warn	(10855) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "true"
                                        zigbee.0	2021-05-10 09:23:35.033	error	(10855) Cannot check object existence of "zigbee.0.00158d00024904ee": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.033	error	(10855) Cannot check object existence of "zigbee.0.00158d000444cbe1": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.032	error	(10855) Cannot check object existence of "zigbee.0.00158d0004072701": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.032	error	(10855) Cannot check object existence of "zigbee.0.00158d000237c603": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.031	error	(10855) Cannot check object existence of "zigbee.0.00158d0004445afb": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.031	error	(10855) Cannot check object existence of "zigbee.0.00158d00025e6e78": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.030	error	(10855) Cannot check object existence of "zigbee.0.00158d0004186ac9": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.030	error	(10855) Cannot check object existence of "zigbee.0.00158d0002c16bed": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.029	error	(10855) Cannot check object existence of "zigbee.0.0017880102a11057": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.029	error	(10855) Cannot check object existence of "zigbee.0.00158d0002bfbf83": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.028	error	(10855) Cannot check object existence of "zigbee.0.00158d0002bfdc6e": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.028	error	(10855) Cannot check object existence of "zigbee.0.00158d0002c1470d": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.027	error	(10855) Cannot check object existence of "zigbee.0.00158d0002bfa1c9": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.027	error	(10855) Cannot check object existence of "zigbee.0.00158d00023232ff": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.026	error	(10855) Cannot check object existence of "zigbee.0.00158d00025e501c": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.026	error	(10855) Cannot check object existence of "zigbee.0.00158d0002ffa046": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.025	error	(10855) Cannot check object existence of "zigbee.0.00158d0002bfa18d": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.025	error	(10855) Cannot check object existence of "zigbee.0.00158d0002bfa26e": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.024	error	(10855) Cannot check object existence of "zigbee.0.00158d0002701fb9": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.023	error	(10855) Cannot check object existence of "zigbee.0.00158d0002c9067a": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.023	error	(10855) Cannot check object existence of "zigbee.0.00158d000248b509": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.022	error	(10855) Cannot check object existence of "zigbee.0.00158d0002c147e9": Error exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:35.020	error	(10855) Cannot check object existence of "zigbee.0.00158d000291e392": Error exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.998	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.997	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.996	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.995	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.984	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.983	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.982	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.981	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.980	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.979	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.978	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.977	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.976	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.975	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.974	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.973	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:34.972	warn	Objects IP-Slave:59920 Error from InMemDB: Error: exists NOT SUPPORTED
                                        zigbee.0	2021-05-10 09:23:34.929	info	(10855) Zigbee started
                                        zigbee.0	2021-05-10 09:23:34.928	info	(10855) 0x00158d00024904ee (addr 44702): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.926	info	(10855) 0x00158d000444cbe1 (addr 51238): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.925	info	(10855) 0x00158d0004072701 (addr 52924): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.923	info	(10855) 0x00158d000237c603 (addr 42565): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.922	info	(10855) 0x00158d0004445afb (addr 50998): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.921	info	(10855) 0x00158d00025e6e78 (addr 26010): HGZB-20A - Nue / 3A Power plug (Router)
                                        zigbee.0	2021-05-10 09:23:34.919	info	(10855) 0x00158d0004186ac9 (addr 38869): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.918	info	(10855) 0x00158d0002c16bed (addr 7525): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.916	info	(10855) 0x0017880102a11057 (addr 12794): 8718696449691 - Philips Hue White Single bulb B22 (Router)
                                        zigbee.0	2021-05-10 09:23:34.914	info	(10855) 0x00158d0002bfbf83 (addr 23457): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.913	info	(10855) 0x00158d0002bfdc6e (addr 48241): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.911	info	(10855) 0x00158d0002c1470d (addr 45524): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.910	info	(10855) 0x00158d0002bfa1c9 (addr 36020): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.909	info	(10855) 0x00158d00023232ff (addr 38182): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.907	info	(10855) 0x00158d00025e501c (addr 45151): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.906	info	(10855) 0x00158d0002ffa046 (addr 8607): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                                        zigbee.0	2021-05-10 09:23:34.903	info	(10855) 0x00158d0002bfa18d (addr 26396): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.902	info	(10855) 0x00158d0002bfa26e (addr 2880): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.901	info	(10855) 0x00158d0002701fb9 (addr 45956): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.899	info	(10855) 0x00158d0002c9067a (addr 3893): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.898	info	(10855) 0x00158d000248b509 (addr 31219): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.896	info	(10855) 0x00158d0002c147e9 (addr 22844): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                        zigbee.0	2021-05-10 09:23:34.894	info	(10855) 0x00158d000291e392 (addr 16809): HGZB-20-DE - Smart Home Pty Power plug (Router)
                                        zigbee.0	2021-05-10 09:23:34.881	info	(10855) Currently 23 devices are joined:
                                        zigbee.0	2021-05-10 09:23:34.859	info	(10855) --> transmitPower : normal
                                        zigbee.0	2021-05-10 09:23:34.849	info	(10855) Disable LED
                                        zigbee.0	2021-05-10 09:23:34.838	info	(10855) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20180507}}
                                        zigbee.0	2021-05-10 09:23:33.189	warn	(10855) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
                                        zigbee.0	2021-05-10 09:23:32.983	info	(10855) Starting Zigbee...
                                        zigbee.0	2021-05-10 09:23:32.898	info	(10855) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.20.1, js-controller: 3.3.8
                                        host.Master	2021-05-10 09:23:32.394	warn	States IP-Slave:41868 Error from InMemDB: Error: client NOT SUPPORTED
                                        host.Master	2021-05-10 09:23:32.390	warn	States IP-Slave:41866 Error from InMemDB: Error: client NOT SUPPORTED
                                        host.Slave	2021-05-10 09:23:29.610	info	instance system.adapter.zigbee.0 started with pid 10855
                                        host.Slave	2021-05-10 09:23:27.704	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        zigbee.0	2021-05-10 09:23:26.964	info	(10473) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        zigbee.0	2021-05-10 09:23:26.962	info	(10473) terminating
                                        zigbee.0	2021-05-10 09:23:26.536	info	(10473) Zigbee: disabling joining new devices.
                                        zigbee.0	2021-05-10 09:23:26.529	info	(10473) cleaned everything up...
                                        host.Slave	2021-05-10 09:23:26.572	info	stopInstance system.adapter.zigbee.0 send kill signal
                                        zigbee.0	2021-05-10 09:23:26.525	info	(10473) Got terminate signal TERMINATE_YOURSELF
                                        host.Slave	2021-05-10 09:23:26.509	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                        • K klausiob
                                          #146
                                          2.2.9 auf 3.3.8
                                          Sprünge von alten stable Versionen auf eine aktuelle Beta-Version sind u. U. zu groß. Zieh das System innerhalb vom Stable auf den letzten dortigen Stand.
