  4. Test Adapter Gartenbewässerung v0.0.x
    apollon77A
beregnungssteuerungbewässerunggartengartenbewässerungmagnetventilventilventile
567 Beiträge 66 Kommentatoren 220.8k Aufrufe 77 Beobachtet
  • Holger EtzelH
    Holger EtzelH
    Holger Etzel
    #462
    bekomme nach start der Instanz folgende Meldung:
    Was haben diese zu bedeuten?
    host.raspberrypi	2021-04-04 15:18:58.701	error	instance system.adapter.gartenbewaesserung.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    gartenbewaesserung.0	2021-04-04 15:18:58.192	error	(760050) DB closed
    gartenbewaesserung.0	2021-04-04 15:18:58.192	error	at TCP.<anonymous> (net.js:675:12)
    gartenbewaesserung.0	2021-04-04 15:18:58.192	error	at Socket.EventEmitter.emit (domain.js:483:12)
    gartenbewaesserung.0	2021-04-04 15:18:58.192	error	at Socket.emit (events.js:314:20)
    gartenbewaesserung.0	2021-04-04 15:18:58.192	error	at Object.onceWrapper (events.js:421:26)
    gartenbewaesserung.0	2021-04-04 15:18:58.192	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:146:20)
    gartenbewaesserung.0	2021-04-04 15:18:58.192	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:179:25)
    gartenbewaesserung.0	2021-04-04 15:18:58.192	error	(760050) Error: DB closed
    gartenbewaesserung.0	2021-04-04 15:18:58.192	error	(760050) unhandled promise rejection: DB closed
    gartenbewaesserung.0	2021-04-04 15:18:58.191	error	(760050) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    gartenbewaesserung.0	2021-04-04 15:18:58.180	error	(760050) DB closed
    gartenbewaesserung.0	2021-04-04 15:18:58.180	error	at TCP.<anonymous> (net.js:675:12)
    gartenbewaesserung.0	2021-04-04 15:18:58.180	error	at Socket.EventEmitter.emit (domain.js:483:12)
    gartenbewaesserung.0	2021-04-04 15:18:58.180	error	at Socket.emit (events.js:314:20)
    gartenbewaesserung.0	2021-04-04 15:18:58.180	error	at Object.onceWrapper (events.js:421:26)
    gartenbewaesserung.0	2021-04-04 15:18:58.180	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:146:20)
    gartenbewaesserung.0	2021-04-04 15:18:58.180	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:179:25)
    gartenbewaesserung.0	2021-04-04 15:18:58.180	error	(760050) Error: DB closed
    gartenbewaesserung.0	2021-04-04 15:18:58.180	error	(760050) unhandled promise rejection: DB closed
    gartenbewaesserung.0	2021-04-04 15:18:58.174	error	(760050) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    • T tombox
      @atomicix Jap ist das nächste Ding..Saison beginnt ja in 2 Wochen.
      S
      S
      Snapergy
      #463
      @tombox
      hallo tombox, gibt es schon einen neuen stand?
      • S Snapergy
        @tombox
        T
        T
        tombox
        #464
        @snapergy Es gibt mittlerweile ein besseren Adaper für Bewässerung.
        Es fehlen hier zwar noch Gardena und KNX states die angesteuert werden können
        Deswegen macht eine Entwicklung an dem Adapter kein Sinn mehr
        https://github.com/Dirk-Peter-md/ioBroker.sprinklecontrol
        Leider gibt es noch kein Forum eintrag zu dem Adaper aber er ist auch schon im latest.
        Bei Anfragen müsst ihr euch bei Dirk Peter direkt per Mail melden.
        • T tombox
          B
          B
          bob der 1.
          #465
          @tombox sagte in Test Adapter Gartenbewässerung v0.0.x:
          Was ist an dem besser?
          Ok,sehe den Durchfluß eingepflegt was aber sehr wage ist.
          Paar Sachen die der noch hat...aber besser? sehe eher das Wort umfangreicher...
          • B bob der 1.
            sigi234S
            sigi234S
            #466
            @bob-der-1
            Jupp, die Beschreibung ist aber gut gemacht.
            B X 2 Antworten Letzte Antwort
            • sigi234S sigi234
              @bob-der-1
              B
              B
              bob der 1.
              #467
              @sigi234
              Sehr gut sogar.
              Ist ein Klasse Adapter nur leider die Bennenung der einzelnen Daten-Punkte nict für jeden trivial.
              • sigi234S sigi234
                @bob-der-1
                X
                X
                xbow42
                schrieb am zuletzt editiert von xbow42
                #468
                @sigi234 "spezifische Konfiguration des jeweiligen Rollladens" scheint einiges vom shuttercontrol-Adapter übernommen zu sein, oder kann man damit auch seinen Rasen abdunkeln ;)
                  #469
                  @xbow42 hehe, wenn du ihn lange genug bewässerst, dann wird der Rasen auch dunkel... wie n Moor.. ;-)
                    JB_SullivanJ
                    JB_SullivanJ
                    JB_Sullivan
                    #470
                    Leider liest sich die Aussage von @tombox so, als wenn der jetzige Adapter in diesem Status bleiben wird.
                    Heißt also im Umkehrschluss, sich vom Adapter Gartenbewässerung verabschieden, oder den Status Quo akzeptieren. Auch wenn ich sehr mit dem Adapter von TomBox zufrieden war/bin, werde ich den "neuen" Adapter auch mal ausprobieren und im Sommer einem Praxis Test unterziehen.
                    Aber im Grunde bedarf es ja nicht unbedingt immer und immer wieder etwas neuem. TomBox sein Adapter hat im letzten Jahr für MICH gut funktioniert. Also dafür nochmal herzlichen Dank.
                    Aber wie gesagt - ich werde trotzdem mal einen Blick über den Tellerrand werfen, auch wenn es nur dazu da ist um zu alt bekanntem zurück zu kehren ;)
                    T sigi234S 2 Antworten Letzte Antwort
                    • JB_SullivanJ JB_Sullivan
                      T
                      T
                      tombox
                      #471
                      @jb_sullivan also ich werde meinen nicht weiter entwickeln dazu ist der andere zu gut außer. Ich werde aber den anderen verbessern falls es wünsche gibt
                      M S 2 Antworten Letzte Antwort
                      • T tombox
                        M
                        M
                        MartyBr
                        #472
                        @tombox Hallo tombox, ich habe mir den anderen Adapter auch angeschaut. Er hat für mich zwei Nachteile gegenüber deinem:
                        1. Pumpe und Verbrauch: Brauche ich nicht, das hängt bei mir an dem Gartenwasserhahn. Das sollte zukünftig konfigurierbar, also abschaltbar sein.
                        2. Gravierend ist das Fehlen eines Bodenfeuchtesensors. Das ist ein RIESEN Vorteil deines Adapters.
                        Ich habe für mich beschlossen, dass ich deinen Adapter weiter benutze.
                        Herzlichen Dank an dieser Stelle für den Adapter und den Support!!!
                        Gruß und Dank
                        Martin
                        Martin
                        Homematic und Homematic IP
                          sigi234S
                          sigi234S
                          #473
                          @jb_sullivan
                          @tombox
                          @Dirk-Peter-md
                          @Kuddel
                          Wunsch:
                          Ich würde beide kombinieren und einen Community Adapter machen. Auch Kuddel mit ins Boot nehmen.
                          • M MartyBr
                            Gruß und Dank
                            Martin
                            T
                            T
                            tombox
                            #474
                            @martybr so wie ich Dirk verstanden habe ist feuchte Sensor das nächste was er einbaut er würde das gleich mit Temperatur Sensoren verbinden sich
                            • sigi234S sigi234
                              @jb_sullivan
                              @tombox
                              @Dirk-Peter-md
                              @Kuddel
                              Wunsch:
                              T
                              T
                              tombox
                              #475
                              @sigi234 j habe ich auch schon geäußert aber will erstmal ein Grundlage entwickelt aber du kannst ihm ja ne Mail schreiben
                              • T tombox
                                M
                                M
                                MartyBr
                                #476
                                @tombox Ich werde das verfolgen, danke für die Info.
                                Martin
                                Martin
                                • T tombox
                                  sigi234S
                                  sigi234S
                                  #477
                                  Jupp, schade das er nicht im Forum ist?
                                  • T tombox
                                    S
                                    S
                                    Snapergy
                                    #478
                                    @tombox said in Test Adapter Gartenbewässerung v0.0.x:
                                    Leider kann man SprinklerControl nicht ohne die Wetterdaten nutzen, d.h. scheinbar auch nicht einfach so starten... Was mir bei deinem lediglich gefehlt hat, ist die Möglichkeit mehr als 6 Kreise anzusteuern :(
                                    Was ich beim Neuen auch noch nicht herausgefunden habe: Wird nach jeder Beregnung eines Kreises die Bodenfeuchte automatisch auf 100% gesetzt (egal wie lange ich bewässere), oder wird es auch ungefähr berechnet?
                                    • S
                                      S
                                      Saschag
                                      #479
                                      @tombox
                                      Schade das der Adapter nicht weiterentwickelt wird.
                                      Ich war auch sehr zufrieden mit deinem Adapter! Werde vermutlich auch diesem bleiben.
                                      Mir z.B. hätte nur eine "Sperr-DP" gefehlt. (z.B. Mähroboter aktuelle am Mähen, Gartenparty etc.)
                                      Auch von mir Herzlichen Dank an dieser Stelle für den Adapter und den Support!!!
                                      • S Saschag
                                        @tombox
                                        T
                                        T
                                        Tschaeens
                                        #480
                                        @saschag Hallo vllt könnt Ihr mir helfen!
                                        Ich finde den Adapter super und der hat letztes Jahr auch super seine Arbeit verrichtet. Jetzt habe ich meine Gartenbewässerung weitergebaut und einen Homematic Funk Schaltaktor 4-fach verbaut (HM-LC-Sw4). Leider wirft mir das Log ständig Fehlermeldungen:
                                        2021-05-09 20:44:49.893 - error: hm-rpc.1 (24871) xmlrpc -> setValue ["REQ1499186:2","STATE",false] BOOL
                                        2021-05-09 20:44:49.893 - error: hm-rpc.1 (24871) Cannot call setValue: XML-RPC fault: Failure
                                        oder noch schlimmer der Duty Cicle geht hoch und dann geht nichts mehr. Ich nutze raspberrymatic unter proxmox mit Funkantenne? Steuere ich den Eingang über die ccu oberfläche funzt es ohne Probleme.
                                        Danke für eure Hilfe.
                                        Lieben Gruß
                                        • JB_SullivanJ
                                          JB_SullivanJ
                                          JB_Sullivan
                                          #481
                                          @tombox
                                          Auch wenn du den Adapter nicht weiter entwickelst, kannst du bitte die Fehlermeldung die der Adapter im Zusammenhang mit Admin 5.x.x ausgibt, ggf noch heilen?
                                          gartenbewaesserung.0	2021-05-10 06:55:28.555	info	(4324) State value to set for "gartenbewaesserung.0.status.fortschritt" has to be type "number" but received type "string"
                                          gartenbewaesserung.0	2021-05-10 06:55:28.554	warn	(4324) Read-only state "gartenbewaesserung.0.status.fortschritt" has been written without ack-flag with value "100"
                                          gartenbewaesserung.0	2021-05-10 06:55:28.554	info	(4324) State value to set for "gartenbewaesserung.0.status.restzeit_sek" has to be type "number" but received type "string"
                                          gartenbewaesserung.0	2021-05-10 06:55:28.554	warn	(4324) Read-only state "gartenbewaesserung.0.status.restzeit_sek" has been written without ack-flag with value "10"
                                          gartenbewaesserung.0	2021-05-10 06:55:28.554	info	(4324) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                                          gartenbewaesserung.0	2021-05-10 06:55:28.554	warn	(4324) Read-only state "gartenbewaesserung.0.status.restzeit" has been written without ack-flag with value "00:10"
                                          gartenbewaesserung.0	2021-05-10 06:55:28.554	info	(4324) State value to set for "gartenbewaesserung.0.status.ventil4.fortschritt" has to be type "number" but received type "string"
                                          gartenbewaesserung.0	2021-05-10 06:55:28.553	warn	(4324) Read-only state "gartenbewaesserung.0.status.ventil4.fortschritt" has been written without ack-flag with value "99"
                                          gartenbewaesserung.0	2021-05-10 06:55:28.553	info	(4324) State value to set for "gartenbewaesserung.0.status.ventil4.restzeit_sek" has to be type "number" but received type "string"
                                          gartenbewaesserung.0	2021-05-10 06:55:28.553	warn	(4324) Read-only state "gartenbewaesserung.0.status.ventil4.restzeit_sek" has been written without ack-flag with value "10"
                                          84.0k
