  4. [neuer Adapter] smartgarden adapter for Gardena smart system
gardena smart systemsmartgarden
1.1k Beiträge 108 Kommentatoren 437.9k Aufrufe 101 Beobachtet
  • FlexerF Offline
    FlexerF Offline
    Flexer
    #597
    Hallo in die Runde, ich habe mir heute den Adapter mal installiert. Ich habe einen Account und auch einen Key. Pi hole war aus. Ich habe das alles auf einem Intel Nuc unter Proxmox LXC laufen.
    Ich bekomme folgende Fehler im Log Level 3
    Hat jemand eine Idee?
    Unterm Strich ist alles besser.
    Ja, voll geil hier!
    • FlexerF Flexer
      #598
      @flexer
      Bitte log text auch als Text (in CodeTags </> eingebettet) posten, keine Screenshots.
      FlexerF 1 Antwort Letzte Antwort
        @flexer
        FlexerF Offline
        FlexerF Offline
        Flexer
        #599
        smartgarden.0	2021-04-01 12:18:59.483	info	(22147) 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0	2021-04-01 12:18:59.482	info	(22147) 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0	2021-04-01 12:18:59.476	info	(22147) 3/ getConnection: trying to connect again in 300 seconds
        smartgarden.0	2021-04-01 12:18:59.476	info	(22147) 3/ getConnection: returned connection error: request returned 403 Forbidden
        smartgarden.0	2021-04-01 12:18:59.476	info	(22147) 3/ sgSetState: info.connection value=false ack=true
        smartgarden.0	2021-04-01 12:18:59.476	error	(22147) Error: request returned 403 Forbidden
        smartgarden.0	2021-04-01 12:18:59.476	info	(22147) 3/ get_locations failure:..return with error
        smartgarden.0	2021-04-01 12:18:59.475	info	(22147) 3/ get_locations failure: response.statusCode/Message=403/Forbidden
        smartgarden.0	2021-04-01 12:18:59.475	info	(22147) 3/ sgSetState: info.connection value=false ack=true
        smartgarden.0	2021-04-01 12:18:59.391	info	(22147) 3/ get_locations ...
        smartgarden.0	2021-04-01 12:18:59.391	info	(22147) 3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        smartgarden.0	2021-04-01 12:18:59.391	info	(22147) 3/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
        smartgarden.0	2021-04-01 12:18:59.390	info	(22147) 3/ Connection: successful: response.statusCode / statusMessage=200 / OK
        smartgarden.0	2021-04-01 12:18:59.190	info	(22147) 3/ ---> State change by device: state smartgarden.0.info.revision changed: Main: 2466 / API: 2466 (ack = true)
        smartgarden.0	2021-04-01 12:18:59.189	info	(22147) 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0	2021-04-01 12:18:59.187	info	(22147) 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0	2021-04-01 12:18:59.181	info	(22147) 3/ sgSetState: info.revision value=Main: 2466 / API: 2466 ack=true
        smartgarden.0	2021-04-01 12:18:59.159	info	(22147) 3/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
        smartgarden.0	2021-04-01 12:18:59.159	info	(22147) 3/ connecting to Gardena Smart System Service ...
        smartgarden.0	2021-04-01 12:18:59.158	info	(22147) 3/ sgSetState: info.connection value=false ack=true
        smartgarden.0	2021-04-01 12:18:59.157	info	(22147) 3/ connectToGardena...
        smartgarden.0	2021-04-01 12:18:59.156	info	(22147) 3/ getConnection...
        smartgarden.0	2021-04-01 12:18:59.131	info	(22147) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v12.19.0, js-controller: 3.2.16
        smartgarden.0	2021-04-01 12:18:55.044	info	(21554) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        smartgarden.0	2021-04-01 12:18:55.044	info	(21554) terminating
        smartgarden.0	2021-04-01 12:18:55.044	info	(21554) 3/ cleaned everything up...
        smartgarden.0	2021-04-01 12:18:55.043	info	(21554) Got terminate signal TERMINATE_YOURSELF
        smartgarden.0	2021-04-01 12:18:36.036	info	(21554) 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0	2021-04-01 12:18:36.034	info	(21554) 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0	2021-04-01 12:18:35.817	info	(21554) 3/ getConnection: trying to connect again in 300 seconds
        smartgarden.0	2021-04-01 12:18:35.817	info	(21554) 3/ getConnection: returned connection error: request returned 403 Forbidden
        smartgarden.0	2021-04-01 12:18:35.817	info	(21554) 3/ sgSetState: info.connection value=false ack=true
        smartgarden.0	2021-04-01 12:18:35.817	error	(21554) Error: request returned 403 Forbidden
        Ja, voll geil hier!
        • FlexerF Flexer
          #600
          @flexer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
          Da sag der gardena-Server: Du kummst hier ned rein...
          Passwort korrekt? Ggf. muss da auch ein neues angelegt werden.
          node: v12.19.0
          Mein Hobby: Halte das System aktuell.
            node: v12.19.0
            FlexerF Offline
            FlexerF Offline
            Flexer
            #601
            @thomas-braun Passwort habe ich auch geändert. Keine Änderung
            Ja, voll geil hier!
            • FlexerF Flexer
              #602
              @flexer
              Auch key zur Hand?
              To use this adapter you need two things:
              an GARDENA smart system account
              an GARDENA application key
              To get both things please go to https://developer.husqvarnagroup.cloud/docs#/docs/getting-started/.
                @flexer
                Auch key zur Hand?
                FlexerF Offline
                FlexerF Offline
                Flexer
                #603
                @thomas-braun Bin nochmal alles in ruhe durchgegangen jetzt hat es geklappt. Muss nur noch rausfinden wie ich das Watercontrol steuer! Super jetzt habe ich wieder einen Adapter mehr der läuft
                Ja, voll geil hier!
                jpgorganizerJ 1 Antwort Letzte Antwort
                • FlexerF Flexer
                  jpgorganizerJ Offline
                  jpgorganizer
                  #604
                  @flexer
                  schön, dass es nun klappt bei dir.
                  kannst du verraten, was die Ursache war, dass es zunächst nicht funktioniert hat? Das würde mir und evtl. anderen Usern helfen.
                  den Water Control musst du als SERVICE_VALVE steuern. Kannst im readme einfach nach Water Control suchen, dann solltest du fündig werden.
                  VG jpgorganizer
                  smartgarden Adapter für GARDENA smart system
                  Plattform: Raspberry Pi OS Linux 12 (bookworm), Node.js: v18.18.2, NPM: 9.8.1
                  • jpgorganizerJ jpgorganizer
                    @flexer
                    VG jpgorganizer
                    FlexerF Offline
                    FlexerF Offline
                    Flexer
                    schrieb am zuletzt editiert von Flexer
                    #605
                    @jpgorganizer Ich hatte nicht auf Connect new Api geklickt. Das hat natürlich dann nicht geklappt.
                    Super dann suche ich das mal in der readme. Aktuell habe ich das zwar über eine alexaroutine noch am laufen aber das baue ich dann um.
                    Vielen dank für die tolle arbeit
                    EDIT: Valve an und aus klappt! Klasse!
                    Ja, voll geil hier!
                      dany198300
                      #606
                      Hi jpgorganizer
                      Leider verbindet sich meine Smartgarden Instanz nicht mit dem API vom Gardena.
                      Application key sowie Benutzername habe ich eingetragen. Wo könnte das Problem noch liegen? Lg Dani
                      Bildschirmfoto 2021-04-06 um 14.46.53.png Bildschirmfoto 2021-04-06 um 14.46.32.png Bildschirmfoto 2021-04-06 um 14.46.02.png
                      Qualle888Q jpgorganizerJ 2 Antworten Letzte Antwort
                      • D dany198300
                        Hi jpgorganizer
                        Qualle888Q Offline
                        Qualle888Q Offline
                        Qualle888
                        #607
                        @dany198300 Ich wollte den Adapter gerade testen und habe das gleiche Problem.
                        • D dany198300
                          Hi jpgorganizer
                          jpgorganizer
                          schrieb am zuletzt editiert von jpgorganizer
                          #608
                          @dany198300 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                          Hi jpgorganizer
                          @dany198300 dir empfehle ich einen neuen Application key zu generieren, den key solltest du geheim halten und möglichst nicht in Foren posten
                          @qualle888 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                          naja, ich vermute es liegt an Application key / Benutzername / Passwort
                          und ohne Log kann man nur vermuten :-)
                          VG jpgorganizer
                            dany198300
                            schrieb am zuletzt editiert von dany198300
                            #609
                            Hallo @jpgorganizer
                            Ja, da hast Du natürlich Recht, sehr fahrlässig von mir. Hab den Key erneuert.
                            Danke für den Hinweis :-)
                            Mit löschen des Adapters und neu installieren hat es geklappt :-)
                            • D dany198300
                              Hallo @jpgorganizer
                              jpgorganizer
                              #610
                              @dany198300
                              gut dass es nun geht, aber ich bin immer etwas erstaunt, was eine Neuinstallation wohl so anderes macht wie die erste Installation. Es werden nur Files kopiert.
                              Falls du sagen kannst woran es lag, dann her damit. Dann haben alle was davon :-)
                              lt. dem Screenshot, den du vorhin noch geposted hattest, kam ein 403 Forbidden. Klares Zeichen für Fehler bei der Authentifizierung, also war mind. ein Element aus Api-Key, Username, Passwort falsch.
                              @all: wenn ihr Log's posted, dann bitte als Text als
                              Code
                              posten (in CodeTags </> eingebettet) . Und seid nicht zu geizig mit dem Log. Es sollte auch sichtbar sein, was vor dem Fehler passierte. Eine Fehlermeldung kommt erst, wenn der Fehler passiert ist. Die Ursache lag i.d.R. davor.
                              Wie wenn Ihr vom Fahrrad stürzt. Ein Bild dass Ihr auf dem Boden liegt, bringt nichts mehr um die Ursache zu finden. Ein Bild von den 10 m zugefrorener Straße davor, kann das aber erklären.
                              VG jpgorganizer
                                @dany198300
                                Code
                                VG jpgorganizer
                                FlexerF Offline
                                FlexerF Offline
                                Flexer
                                #611
                                @jpgorganizer Kurze Zwischenfrage. Hat jemand das Smart irrigation Modul mit dem Adapter am laufen?
                                Ja, voll geil hier!
                                dslraserD jpgorganizerJ 2 Antworten Letzte Antwort
                                • FlexerF Flexer
                                  dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  #612
                                  Ich habe das Irrigation Control, das lief die ganze letzte Saison mit diesem Adapter. Dieses Jahr ist es noch nicht angeschlossen.
                                  Warum fragst Du ?
                                  Edit: bedient habe ich es damit
                                  https://forum.iobroker.net/post/408094
                                  • dslraserD dslraser
                                    Warum fragst Du ?
                                    FlexerF Offline
                                    FlexerF Offline
                                    Flexer
                                    #613
                                    @dslraser Ich überlege dieses Jahr eine Bewässerung einzubauen. Ich habe im Trockenaufbau mal eine Steuerung mit einen Sonoff 4 Pro aufgebaut, jedoch kommt jetzt ein Kreislauf mehr dazu und bin bei 5 Ventilen. Deshalb überlege ich das Smart Irrigation zu holen.
                                    Ja, voll geil hier!
                                    • FlexerF Flexer
                                      jpgorganizer
                                      #614
                                      ja, ich, das war der initiale Grund, dass ich den Adapter entwickelt habe :-)
                                      ich hab 6 Ventile dran
                                        FlexerF Offline
                                        FlexerF Offline
                                        Flexer
                                        #615
                                        @jpgorganizer Hallo und schönen Abend. Bin von deinem Adapter echt begeistert. Vielen Dank.
                                        Ich habe aber festgestellt dass dieser Sensor wohl keine Korrekten Werte zur Batterie hergibt. Hast du eine Idee? Habe mehrfach die Batterien gewechselt aber er zeigt immer einen Wert von 37% an.
                                        GARDENA smart Sensor: https://www.amazon.de/dp/B08LNQGB99/ref=cm_sw_r_cp_api_glc_i_16E128SH87WV8YGZ4ZNS
                                        Ps habe heute meine Visualisierung angepasst und die Bewässerung eingebaut. Hier ein paar Bilder.
                                        IMG_8102.MP4 E2D07A70-135D-4D7B-8E65-792FD88747E7.jpeg ABAFE23B-E6E8-46EB-9777-FDD1748508CA.jpeg DBDA31A8-81F9-4DA1-8987-035FE87FD29A.jpeg
                                        Ja, voll geil hier!
                                        jpgorganizerJ dslraserD 2 Antworten Letzte Antwort
                                        • FlexerF Flexer
                                          jpgorganizer
                                          #616
                                          ich würde schon erwarten, dass verschiedene Werte kommen.
                                          Ich habe keinen Sensor, somit kann ich im Detail dazu aber nichts sagen. Aber es gibt hier einige Leute, die einen Sensor betreiben. Vielleicht sagt einer was dazu
                                          JohGreJ 1 Antwort Letzte Antwort
