  4. CC26X2R1 an NUC unter Proxmox nicht grün
Geplant Angeheftet Gesperrt Verschoben Ungelöst ioBroker Allgemein
23 Beiträge 5 Kommentatoren 2.4k Aufrufe 4 Beobachtet
  • schmitzkatzeS schmitzkatze
    hoffe ich habe Dich richtig verstanden und sprenge hier nichts!!
    2021-03-25 16:39:19.154 - info: host.ioBroker "system.adapter.zigbee.0" enabled
    2021-03-25 16:39:19.185 - info: host.ioBroker instance system.adapter.zigbee.0 started with pid 2743
    2021-03-25 16:39:21.010 - info: zigbee.0 (2743) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.21.0, js-controller: 3.2.16
    2021-03-25 16:39:21.045 - info: zigbee.0 (2743) Starting Zigbee npm ...
    2021-03-25 16:39:21.220 - error: zigbee.0 (2743) Failed to start Zigbee
    2021-03-25 16:39:21.221 - error: zigbee.0 (2743) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100KJS-if00'
    at Znp. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
    at Generator.next ()
    at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
    at new Promise ()
    at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
    at SerialPort. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
    at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
    at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
    2021-03-25 16:39:21.407 - info: zigbee.0 (2743) Installed Version: iobroker.zigbee@1.4.4
    2021-03-25 16:39:31.222 - info: zigbee.0 (2743) Try to reconnect. 1 attempts left
    2021-03-25 16:39:31.222 - info: zigbee.0 (2743) Starting Zigbee npm ...
    2021-03-25 16:39:31.225 - error: zigbee.0 (2743) Failed to start Zigbee
    2021-03-25 16:39:31.226 - error: zigbee.0 (2743) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100KJS-if00'
    at new Promise ()
    2021-03-25 16:39:31.229 - info: zigbee.0 (2743) Installed Version: iobroker.zigbee@1.4.4
    2021-03-25 16:40:00.025 - info: host.ioBroker instance system.adapter.dwd.0 started with pid 2781
    2021-03-25 16:40:01.667 - info: dwd.0 (2781) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.21.0, js-controller: 3.2.16
    2021-03-25 16:40:01.972 - info: host.ioBroker "system.adapter.zigbee.0" disabled
    2021-03-25 16:40:01.973 - info: host.ioBroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2021-03-25 16:40:01.979 - info: host.ioBroker stopInstance system.adapter.zigbee.0 send kill signal
    2021-03-25 16:40:01.979 - info: zigbee.0 (2743) Got terminate signal TERMINATE_YOURSELF
    2021-03-25 16:40:01.981 - info: zigbee.0 (2743) cleaned everything up...
    2021-03-25 16:40:01.984 - info: zigbee.0 (2743) Zigbee: disabling joining new devices.
    2021-03-25 16:40:01.986 - warn: zigbee.0 (2743) Failed to stop zigbee during startup
    2021-03-25 16:40:01.986 - info: zigbee.0 (2743) terminating
    2021-03-25 16:40:01.987 - info: zigbee.0 (2743) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-03-25 16:40:01.989 - error: zigbee.0 (2743) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-03-25 16:40:01.989 - error: zigbee.0 (2743) unhandled promise rejection: Cannot read property 'getEntries' of null
    2021-03-25 16:40:01.994 - error: zigbee.0 (2743) TypeError: Cannot read property 'getEntries' of null
    at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
    at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
    at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:289:31)
    at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:206:49)
    at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
    at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:192:42)
    at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:310:20)
    at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:581:41)
    at Zigbee.emit (events.js:314:20)
    at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
    2021-03-25 16:40:01.995 - error: zigbee.0 (2743) Cannot read property 'getEntries' of null
    2021-03-25 16:40:02.555 - info: host.ioBroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-03-25 16:40:05.740 - info: dwd.0 (2781) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-03-25 16:40:06.317 - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @schmitzkatze Die Fehlermeldung besagt eindeutig das der serielle Port nicht (korrekt) an den lxc container weitergegeben ist:
    schmitzkatzeS 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      schmitzkatzeS Offline
      schmitzkatze
      @asgothian ist denn der Weg so ok?
      Ich werde den Eintrag nochmals (habe es schon mehrmals geprüft) prüfen !
      Kann es auch an den Einstellungen in der Instanz liegen?
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @schmitzkatze
        Nein. Die Fehlermeldung ist eindeutig.
        Mit Proxxmoxx und LXC kenn ich mich nicht aus. Aber wenn der Adapter "no such file or directory" meldet dann gibt es da etwas nicht
        A.
          @schmitzkatze
          A.
          schmitzkatze
          schrieb am zuletzt editiert von schmitzkatze
          @asgothian ok dann werde ich mir die Sache nochmal vornehmen und versuch raus zu bekommen wo ich den Fehler habe!
          Eigentlich habe ich es so gemacht wie im Video gezeigt wurde.
          Danke schon mal
            Danke schon mal
            schmitzkatze
            @schmitzkatze
            so nun habe ich mein System etwas umgebaut um den USB Prot einfacher durch zu reichen! Ich habe den ioBroker jetzt als VM laufen und die Instanz zigbee.0 installiert.
            aber ich bekomme ihn immer noch nicht grün.
            Welche Einstellung in der VM wäre denn die richtige?
            Bildschirmfoto 2021-04-01 um 13.20.47.png Bildschirmfoto 2021-04-01 um 13.20.31.png
            ich habe die Geräte alle schon neugestartet aber komme nicht weiter. Beim einstellen der Instanz habe ich den Com Eintrag:
            ist das Immer so? kommt es dadurch das ich noch keine Geräte angelernt habe?
            Wäre über Tipps dankbar.
            K crunchipC 3 Antworten Letzte Antwort
              @schmitzkatze
              klassisch
              @schmitzkatze sagte in CC26X2R1 an NUC unter Proxmox nicht grün:
              ist das Immer so?
              oft, das sehe ich auch häufig, ohne daß es anschließend Probs gäbe.
              eher nicht. Das scheint wohl ein OS-Problem zu sein. Da ich ioBroker unter Win laufen habe, hatte ich auch keine Probs mit uSB-Erkennung. Habs aber dennoch auf Ethernet umgestellt, um in der Wahl des Funkstandorts frei zu sein.
                @schmitzkatze
                crunchipC Offline
                crunchipC Offline
                Die erste von beiden
                VM muss danach aber neu gestartet werden
                Und darauf achten das usb 3.0 nicht angehakt ist
                  @schmitzkatze
                  crunchipC Offline
                  crunchipC Offline
                  Sollte so aussehen, auf dem blauen Pfeil, kommt ein Auswahlmenü
                  schmitzkatzeS 2 Antworten Letzte Antwort
                    schmitzkatze
                    @crunchip ok bei mir kommt keine Auswahl, ich klicke auf den blauen Pfeil und nicht öffnet sich!
                      schmitzkatze
                      @crunchip said in CC26X2R1 an NUC unter Proxmox nicht grün:
                      bei dem COM Port habe ich es so gemacht wie im Video https://www.youtube.com/watch?v=UKn5hBwCxoQ&t=4s
                      haus-automatisierung.com ist das nicht richtig?
                        FredFF Online
                        FredFF Online
                        FredF
                        Most Active Forum Testing
                        @schmitzkatze
                        Das stimmt schon beim CC26X2R1... Nutze ihn aber nicht über Proxmox...
                        Zeig doch mal die Konsolenausgabe der ioBroker VM wenn du ls -la /dev/serial/by-id eingibst
                        • FredFF FredF
                          @schmitzkatze
                          schmitzkatze
                          @fredf said in CC26X2R1 an NUC unter Proxmox nicht grün:
                          @schmitzkatze
                          schmitzkatzeS FredFF 2 Antworten Letzte Antwort
                            @schmitzkatze
                            schmitzkatze
                            @schmitzkatze said in CC26X2R1 an NUC unter Proxmox nicht grün:
                            @schmitzkatze
                            permitted by applicable law.
                            Last login: Thu Apr 1 18:41:49 2021 from 192.168.178.171
                            michael@debianIObroker:~$ ls -la /dev/serial/by-id
                            insgesamt 0
                            drwxr-xr-x 2 root root 80 Apr 1 19:36 .
                            drwxr-xr-x 4 root root 80 Apr 1 19:36 ..
                            lrwxrwxrwx 1 root root 13 Apr 1 19:36 usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100KJS-if00 -> ../../ttyACM0
                            lrwxrwxrwx 1 root root 13 Apr 1 19:36 usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100KJS-if03 -> ../../ttyACM1
                              @schmitzkatze
                              insgesamt 0
                              FredFF Online
                              FredFF Online
                              FredF
                              @schmitzkatze
                              Dann das per copy und paste beim Zigbee Adapter eintragen:
                              /dev/serial/by-id/usb-Texas_Instruments_usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100KJS-if00
                              Dann muss es klappen, anschließend kann (normalerweise) gespeichert werden
                                @schmitzkatze
                                FredFF Online
                                FredFF Online
                                FredF
                                @schmitzkatze Das ist aber nicht die ioBroker VM sondern die PVE
                                • FredFF FredF
                                  schmitzkatze
                                  @fredf ja habe ich auch gemerkt, aber das was ich als Text eingefügt habe ist das von der VM
                                  Und das habe ich auch kopiert und eingetragen, es läuft aber nicht? 🤷‍♂️
                                    schmitzkatze
                                    Bildschirmfoto 2021-04-01 um 18.56.03.png Bildschirmfoto 2021-04-01 um 13.28.53.png
                                      schmitzkatze
                                        schmitzkatze
                                        @schmitzkatze
                                        Gelöst 👍 warum 🤷‍♂️
                                        habe ich heute morgen den Adapter nochmal gelöscht und das TI abgezogen VM neugestartet dann den ZigBee Adapter wieder installiert im ioBroker das TI Modul an einem anderen USB Port angesteckt (in den USB Einstellungen in der VM nur geschaut ob er das TI noch drin hat) die VM neugestartet und in den Einstellungen des Adapters den COM Port eingegeben und siehe da "GRÜN" warum auch immer 🤷‍♂️ gibt es eine Erklärung dafür?
                                          klassisch
                                          schrieb am zuletzt editiert von klassisch
                                          Herzlichen Glückwunsch, daß es jetzt funktioniert.
                                          Da ich kein Linux/Proxmox Experte bin, habe ich keine Erklärung.
                                          Ich denke, daß Löschen und Neuinstallieren des Zigbee Adapters eher unnötig sind. Eher VM neustarten und dann vielleicht noch Adapter neu starten, damit er prüft, welche COM Ports da sind.
                                          Was ich aber empfehlen würde: Bevor Du groß Geräte anlernst, schaue bitte, ob das Ganze auch rebootfest ist und resilient gegen die anderen Proxmox Features, die man mit Proxmox so treibt. Bei Linux-SBCs habe ich da schon unangenehme Überraschungen erlebt. Ausgewachsene Linuxsysteme verhalten sich da hoffentlich besser.
                                          Aber erst mal testen schadet nicht.
