  4. Mini-HowTo: Cannot find view "system" for search "host"
302 Beiträge 39 Kommentatoren 124.4k Aufrufe 45 Beobachtet
  • P pd_mueller
    @apollon77
    Jetzt funktionierts 😊
    2021-03-25 16:15:07.414  - info: dwd.0 (31004) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-03-25 16:15:07.956  - info: host.phoscon instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-03-25 16:15:15.003  - info: daswetter.0 (31079) Terminated (NO_ERROR): Without reason
    2021-03-25 16:15:15.530  - info: daswetter.0 (31079) cleaned everything up...
    2021-03-25 16:15:15.550  - info: host.phoscon instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-03-25 16:15:32.939  - info: web.0 (1696) ==>Connected system.user.admin from ::ffff:192.168.0.7
    2021-03-25 16:16:12.973  - info: web.0 (1696) ==>Connected system.user.admin from ::ffff:192.168.0.7
    2021-03-25 16:16:17.801  - info: fb-checkpresence.0 (2062) newActive Hannah true
    2021-03-25 16:17:09.435  - info: web.0 (1696) <==Disconnect system.user.admin from ::ffff:192.168.0.7 vis.0
    2021-03-25 16:18:00.449  - info: web.0 (1696) ==>Connected system.user.admin from ::ffff:192.168.0.7
    2021-03-25 16:18:02.998  - info: web.0 (1696) <==Disconnect system.user.admin from ::ffff:192.168.0.7 vis.0
    2021-03-25 16:18:43.023  - info: web.0 (1696) <==Disconnect system.user.admin from ::ffff:192.168.0.7 vis.0
    2021-03-25 16:20:00.072  - info: host.phoscon instance system.adapter.dwd.0 started with pid 2139
    2021-03-25 16:20:02.113  - info: dwd.0 (2139) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.21.0, js-controller: 3.2.16
    2021-03-25 16:20:06.482  - info: dwd.0 (2139) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-03-25 16:20:07.021  - info: host.phoscon instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-03-25 16:22:24.744  - info: web.0 (1696) <==Disconnect system.user.admin from ::ffff:192.168.0.7 vis.0
    \00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\002021-03-25 16:17:09.680  - info: host.phoscon iobroker.js-controller version 3.2.16 js-controller starting
    2021-03-25 16:17:09.686  - info: host.phoscon Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-03-25 16:17:09.687  - info: host.phoscon hostname: phoscon, node: v12.21.0
    2021-03-25 16:17:09.688  - info: host.phoscon ip addresses:
    2021-03-25 16:17:09.727  - error: host.phoscon-Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected end of JSON input. Try last Backup!
    2021-03-25 16:17:09.732  - error: host.phoscon-Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: /opt/iobroker/iobroker-data/objects.json.bak: Unexpected end of JSON input. Continue with empty dataset!
    2021-03-25 16:17:09.813  - error: host.phoscon Cannot read system.config: null (OK when migrating or restoring)
    2021-03-25 16:17:09.850  - error: host.phoscon-Server Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
    2021-03-25 16:17:10.014  - info: host.phoscon connected to Objects and States
    2021-03-25 16:17:10.147  - warn: host.phoscon logger system.adapter.admin.0.logging was deleted
    2021-03-25 16:17:10.148  - warn: host.phoscon logger system.adapter.javascript.0.logging was deleted
    2021-03-25 16:17:10.187  - info: host.phoscon added notifications configuration of host
    2021-03-25 16:17:10.194  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:17:10.196  - error: host.phoscon Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-03-25 16:17:10.258  - info: host.phoscon Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-03-25 16:17:10.266  - error: host.phoscon Cannot find view "system" for search "host"
    2021-03-25 16:17:10.275  - error: host.phoscon Cannot find view "system" for search "state"
    2021-03-25 16:17:10.276  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:17:10.278  - error: host.phoscon Could not collect system.host.phoscon states to check for obsolete states: Error: Cannot find view "system"
    2021-03-25 16:17:10.280  - error: host.phoscon _design/system missing - call node iobroker.js setup
    2021-03-25 16:17:10.499  - info: host.phoscon Created UUID: 7303e95c-cccb-281a-3567-e18baa14bc25
    2021-03-25 16:28:03.304  - info: host.phoscon received SIGTERM
    2021-03-25 16:28:03.395  - info: host.phoscon terminated
    2021-03-25 16:28:14.085  - info: host.phoscon iobroker.js-controller version 3.2.16 js-controller starting
    2021-03-25 16:28:14.091  - info: host.phoscon Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-03-25 16:28:14.092  - info: host.phoscon hostname: phoscon, node: v12.21.0
    2021-03-25 16:28:14.093  - info: host.phoscon ip addresses:
    2021-03-25 16:28:14.217  - error: host.phoscon Cannot read system.config: null (OK when migrating or restoring)
    2021-03-25 16:28:14.441  - info: host.phoscon connected to Objects and States
    2021-03-25 16:28:14.530  - info: host.phoscon added notifications configuration of host
    2021-03-25 16:28:14.573  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:28:14.575  - error: host.phoscon Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-03-25 16:28:14.646  - info: host.phoscon Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-03-25 16:28:14.654  - error: host.phoscon Cannot find view "system" for search "host"
    2021-03-25 16:28:14.667  - error: host.phoscon Cannot find view "system" for search "state"
    2021-03-25 16:28:14.668  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:28:14.669  - error: host.phoscon Could not collect system.host.phoscon states to check for obsolete states: Error: Cannot find view "system"
    2021-03-25 16:28:14.670  - error: host.phoscon _design/system missing - call node iobroker.js setup
    2021-03-25 16:33:33.046  - info: host.phoscon received SIGTERM
    2021-03-25 16:33:33.154  - info: host.phoscon terminated
    2021-03-25 16:33:44.034  - info: host.phoscon iobroker.js-controller version 3.2.16 js-controller starting
    2021-03-25 16:33:44.041  - info: host.phoscon Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-03-25 16:33:44.042  - info: host.phoscon hostname: phoscon, node: v12.21.0
    2021-03-25 16:33:44.042  - info: host.phoscon ip addresses:
    2021-03-25 16:33:44.195  - error: host.phoscon Cannot read system.config: null (OK when migrating or restoring)
    2021-03-25 16:33:44.370  - info: host.phoscon connected to Objects and States
    2021-03-25 16:33:44.456  - info: host.phoscon added notifications configuration of host
    2021-03-25 16:33:44.495  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:33:44.497  - error: host.phoscon Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-03-25 16:33:44.518  - info: host.phoscon Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-03-25 16:33:44.575  - error: host.phoscon Cannot find view "system" for search "host"
    2021-03-25 16:33:44.586  - error: host.phoscon Cannot find view "system" for search "state"
    2021-03-25 16:33:44.587  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:33:44.589  - error: host.phoscon Could not collect system.host.phoscon states to check for obsolete states: Error: Cannot find view "system"
    2021-03-25 16:33:44.590  - error: host.phoscon _design/system missing - call node iobroker.js setup
    2021-03-25 16:41:19.733  - info: host.phoscon received SIGTERM
    2021-03-25 16:41:19.763  - info: host.phoscon terminated
    2021-03-25 16:41:27.523  - info: host.phoscon iobroker.js-controller version 3.2.16 js-controller starting
    2021-03-25 16:41:27.529  - info: host.phoscon Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-03-25 16:41:27.530  - info: host.phoscon hostname: phoscon, node: v12.21.0
    2021-03-25 16:41:27.530  - info: host.phoscon ip addresses: 192.168.0.68 fe80::f5f4:844a:60c5:8c7d
    2021-03-25 16:41:27.627  - error: host.phoscon Cannot read system.config: null (OK when migrating or restoring)
    2021-03-25 16:41:27.796  - info: host.phoscon connected to Objects and States
    2021-03-25 16:41:27.882  - info: host.phoscon added notifications configuration of host
    2021-03-25 16:41:27.921  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:41:27.922  - error: host.phoscon Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-03-25 16:41:27.943  - info: host.phoscon Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-03-25 16:41:27.951  - error: host.phoscon Cannot find view "system" for search "host"
    2021-03-25 16:41:27.962  - error: host.phoscon Cannot find view "system" for search "state"
    2021-03-25 16:41:27.963  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:41:27.964  - error: host.phoscon Could not collect system.host.phoscon states to check for obsolete states: Error: Cannot find view "system"
    2021-03-25 16:41:27.965  - error: host.phoscon _design/system missing - call node iobroker.js setup
    2021-03-25 16:43:38.691  - info: host.phoscon received SIGTERM
    2021-03-25 16:43:38.793  - info: host.phoscon terminated
    2021-03-25 16:43:49.687  - info: host.phoscon iobroker.js-controller version 3.2.16 js-controller starting
    2021-03-25 16:43:49.693  - info: host.phoscon Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-03-25 16:43:49.694  - info: host.phoscon hostname: phoscon, node: v12.21.0
    2021-03-25 16:43:49.695  - info: host.phoscon ip addresses:
    2021-03-25 16:43:49.832  - error: host.phoscon Cannot read system.config: null (OK when migrating or restoring)
    2021-03-25 16:43:50.018  - info: host.phoscon connected to Objects and States
    2021-03-25 16:43:50.110  - info: host.phoscon added notifications configuration of host
    2021-03-25 16:43:50.153  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:43:50.154  - error: host.phoscon Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-03-25 16:43:50.225  - info: host.phoscon Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-03-25 16:43:50.233  - error: host.phoscon Cannot find view "system" for search "host"
    2021-03-25 16:43:50.246  - error: host.phoscon Cannot find view "system" for search "state"
    2021-03-25 16:43:50.247  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:43:50.249  - error: host.phoscon Could not collect system.host.phoscon states to check for obsolete states: Error: Cannot find view "system"
    2021-03-25 16:43:50.250  - error: host.phoscon _design/system missing - call node iobroker.js setup
    @pd_mueller Interessant. Ich kann mir echt wenig vorstellen was bak UND echte json beide zerstören kann. An sich ist wenigsrens die bak noch ok auch wenn die andere kaputt ist. mega strange.
    • wendy2702W Online
      wendy2702W Online
      @Thomas-Braun @pd_mueller
      Darf ich das Phoscon zeug hier raustrennen? Passt ja nicht wirklich zum eigentlichen Thema der Anleitung.
      • D Online
        D Online
        darkiop
        Heute hatte es mich auch erwischt :)
        Nach einem geplanten reboot meines Proxmox Hosts. Die Fehlerbehebung ist ja kein Problem und in wenigen Sekunden erledigt, aber weis man was die Ursache ist? Hat sich das mit dem JS Controller 3.2 eingeschlichen?
        Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
        Thomas BraunT apollon77A 2 Antworten Letzte Antwort
        • D darkiop
          @darkiop
          Ich würde vor einem reboot auch den iobroker stoppen.
          D apollon77A 2 Antworten Letzte Antwort
            @darkiop
            D Online
            D Online
            darkiop
            @thomas-braun sagte in Mini-HowTo: Cannot find view "system" for search "host":
            Guten Morgen Thomas,
            der Gedanke kam mir als ich meine Zeilen heute Morgen tippte ... was macht Proxmox eigentlich mit laufenden Containern/VMs - versuchen vorm System-reboot die Prozesse sauber zu beenden oder nimmt er die Brechstange? :D Das wollte ich im laufe des Tages mal testen.
            apollon77A Thomas BraunT 2 Antworten Letzte Antwort
            • D darkiop
              @darkiop Logs bitte?? vom reboot zeitounkt und kurz davor/danach ... iobroker und syslog
                @darkiop
                @thomas-braun Das sollte systemd komplett alleine erledigen ... daher sollte das unnötig sein
                • D darkiop
                  @darkiop An sich beendet proxymox alles sauber ...siehst Du an sich auch in der Proxmox Task liste ... da siehst DU auch wenn er die brechstange genommen hat
                  • D darkiop
                    @darkiop Ich weiß es nicht genau, ich vermute aber, dass da die 'Brechstange' genommen wird, wäre gleich bedeutend mit 'Stromausfall'.
                    Die Prozessverwaltung wird ja nicht vom Wirt gemacht, sondern läuft innerhalb des Containers ab. Von daher wird das kein besonders sanfter reboot sein, wenn da da plötzlich von extern neugestartet wird.
                    Das Verhalten deines Systems spricht ja auch dafür. Datei offen und wurde nicht sauber zurückgeschrieben.
                    [Edit:] Offenbar Quatsch geschrieben. :-)
                    • D Online
                      D Online
                      darkiop
                      Im Log sieht man schön wie die einzelnen VMs + LXCs beendet werden.
                      Allerdings ist mein Beispiel wohl ein schlechtes, denn heute Morgen um 08:02 hat irgendwas meinen js-controller abgeschossen (08:02 bis 08:33 war der offline). Erklären kann ich mir das gerade nicht, denn normalerweise hab ich ein sehr stabiles System. Aber heute Morgen habe ich diverse Updates gefahren - vielleicht hat da irgendwas scharf geschossen ...
                      Hab den pve01 heute zum Test auch noch 2x neu gestartet - alles ohne Probleme.
                      Von daher, für mich erledigt, kann mich nicht erinnern was genau um 8:02 heute Morgen war :D
                      iobroker.2021-03-31.txt
                      syslog.2021-03-31.txt
                      • D darkiop
                        @darkiop
                        2021-03-31 08:33:47.924  - info: host.pve-vm-iobroker starting 51 instances
                        Ich weiß zwar nicht wie potent deine Hardware ist, aber 51 laufende Instanzen sind jetzt nicht gerade wenig. Dürfte alleine schon deutlich über 2 GB RAM verbrauchen.
                          @darkiop
                          D Online
                          D Online
                          darkiop
                          Ist ein Nuc i5 mit 32GB, die CPU langweilt sich - der RAM könnte aber durchaus heut Morgen um 8 knapp gewesen sein - ich spendiere der VM mal noch ein wenig Reserve. Hab die Woche Rasenmäher und Co wieder in Betrieb genommen und es kamen mqtt und robonect zu den laufenden Instanzen dazu. Vermutlich bringen die das Fass im Grenzbereich zum Überlaufen :)
                          • D darkiop
                            @darkiop Also das Log an sich sieht wie ein "sauberes" beenden vom controller aus. Und auch danach ist alles wieder sauber hochgefahren. Von daher wäre das Log vom problem-zeitbereich interessant. Und das Syslog wäre vn der VM interessant nicht vom proxmox hosts (und da auch um 8 bzw dann zu dem anderen Zeitpunkt)
                            EDIT: zu proxmox: bzw ... wa sist den im proxmox log das
                            Mar 31 08:29:02 pve01 pvestatd[11476]: storage 'odin-pve01' is not online
                            Ist das der storage wo dide images der Container/VMs liegen? Warum war der offline?
                              @rdzipzap
                              Linux version 5.4.83-v7l+
                              Bring dein System auf Stand. Da dürfte mittlerweile ein Kernel 5.10 angeboten werden.
                              RDZipZap
                              schrieb am zuletzt editiert von RDZipZap
                              @thomas-braun said in Mini-HowTo: Cannot find view "system" for search "host":
                              Kurzes Update von meiner Seite: Seit meinem Update auf 5.10 (das allerdings nur mit rpi-update möglich war) bin ich komplett befreit von meinen Problemen mit zufälligen Neustarts.
                              Vielen Dank nochmal für die Unterstützung.
                              • R RDZipZap
                                @rdzipzap Von rpi-update würde ich die Finger lassen!
                                Was hat denn da beim üblichen Upgrade geklemmt?
                                sudo apt-get update
                                sudo apt install --reinstall libraspberrypi0 libraspberrypi-{bin,dev,doc} raspberrypi-bootloader raspberrypi-kernel
                                R 1 Antwort Letzte Antwort
                                  sudo apt-get update
                                  RDZipZap
                                  @thomas-braun Nun ja - ich habs hiermit probiert: Updating and upgrading Raspberry Pi OS
                                  Und da blieb ich immer bei 5.4 hängen. Mein System wäre bereits auf neustem Stand.
                                  Z.z. lebe ich ganz gut mit der pre-release Version. Würdest du mir trotzdem empfehlen, mit deiner geposteten Methode "downzugraden"? Ist das denn möglich?
                                  • R RDZipZap
                                    @rdzipzap auf jeden Fall!
                                    Beta-Zeug will man nicht auf dem System haben, wenn man nicht aktiv testet.
                                    Ist aber was für einen eigenen Thread.
                                    • R Offline
                                      RDZipZap
                                      Alles klar - habs direkt mal gemacht. IOBroker läuft wieder, jetzt auf 5.10.17 (zuvor 5.10.23).
                                      Werde es weiter beobachten.
                                      Nochmals vielen Dank für die Hilfe!
                                      (Jetzt muss ich nur noch meinen Modbus zum Laufen bringen ;-) - aber das ist ein anderes Thema)
                                      • R RDZipZap
                                        @rdzipzap
                                        Zeig mal die Ausgabe von
                                        sudo apt update
                                        • Crazy32C Offline
                                          Crazy32C Offline
                                          Crazy32
                                          Super, vielen dank für die Anleitung. Mir hat es in den letzten Wochen mehrmals eine Sicherung rausgehauen und jedes Mal funktionierte danach ioBroker nicht mehr.
                                          Also, da ich hier die Frage aufkam wodurch das ausgelöst wird, bei mir war es immer Stromausfall. Kann es sein, dass das Problem neu ist? Ist ja nicht der erste Stromausfall, bisher hatte ich solche Probleme aber nicht. Lesezeichen ist auch bei mir gesetzt ;-)
