  4. Mini-HowTo: Cannot find view "system" for search "host"
302 Beiträge 39 Kommentatoren 124.4k Aufrufe 45 Beobachtet
  • P pd_mueller
    @apollon77
    Jetzt funktionierts 😊
    2021-03-25 16:15:07.414  - info: dwd.0 (31004) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-03-25 16:15:07.956  - info: host.phoscon instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-03-25 16:15:15.003  - info: daswetter.0 (31079) Terminated (NO_ERROR): Without reason
    2021-03-25 16:15:15.530  - info: daswetter.0 (31079) cleaned everything up...
    2021-03-25 16:15:15.550  - info: host.phoscon instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-03-25 16:15:32.939  - info: web.0 (1696) ==>Connected system.user.admin from ::ffff:192.168.0.7
    2021-03-25 16:16:12.973  - info: web.0 (1696) ==>Connected system.user.admin from ::ffff:192.168.0.7
    2021-03-25 16:16:17.801  - info: fb-checkpresence.0 (2062) newActive Hannah true
    2021-03-25 16:17:09.435  - info: web.0 (1696) <==Disconnect system.user.admin from ::ffff:192.168.0.7 vis.0
    2021-03-25 16:18:00.449  - info: web.0 (1696) ==>Connected system.user.admin from ::ffff:192.168.0.7
    2021-03-25 16:18:02.998  - info: web.0 (1696) <==Disconnect system.user.admin from ::ffff:192.168.0.7 vis.0
    2021-03-25 16:18:43.023  - info: web.0 (1696) <==Disconnect system.user.admin from ::ffff:192.168.0.7 vis.0
    2021-03-25 16:20:00.072  - info: host.phoscon instance system.adapter.dwd.0 started with pid 2139
    2021-03-25 16:20:02.113  - info: dwd.0 (2139) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.21.0, js-controller: 3.2.16
    2021-03-25 16:20:06.482  - info: dwd.0 (2139) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-03-25 16:20:07.021  - info: host.phoscon instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-03-25 16:22:24.744  - info: web.0 (1696) <==Disconnect system.user.admin from ::ffff:192.168.0.7 vis.0
    \00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\002021-03-25 16:17:09.680  - info: host.phoscon iobroker.js-controller version 3.2.16 js-controller starting
    2021-03-25 16:17:09.686  - info: host.phoscon Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-03-25 16:17:09.687  - info: host.phoscon hostname: phoscon, node: v12.21.0
    2021-03-25 16:17:09.688  - info: host.phoscon ip addresses:
    2021-03-25 16:17:09.727  - error: host.phoscon-Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected end of JSON input. Try last Backup!
    2021-03-25 16:17:09.732  - error: host.phoscon-Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: /opt/iobroker/iobroker-data/objects.json.bak: Unexpected end of JSON input. Continue with empty dataset!
    2021-03-25 16:17:09.813  - error: host.phoscon Cannot read system.config: null (OK when migrating or restoring)
    2021-03-25 16:17:09.850  - error: host.phoscon-Server Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
    2021-03-25 16:17:10.014  - info: host.phoscon connected to Objects and States
    2021-03-25 16:17:10.147  - warn: host.phoscon logger system.adapter.admin.0.logging was deleted
    2021-03-25 16:17:10.148  - warn: host.phoscon logger system.adapter.javascript.0.logging was deleted
    2021-03-25 16:17:10.187  - info: host.phoscon added notifications configuration of host
    2021-03-25 16:17:10.194  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:17:10.196  - error: host.phoscon Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-03-25 16:17:10.258  - info: host.phoscon Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-03-25 16:17:10.266  - error: host.phoscon Cannot find view "system" for search "host"
    2021-03-25 16:17:10.275  - error: host.phoscon Cannot find view "system" for search "state"
    2021-03-25 16:17:10.276  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:17:10.278  - error: host.phoscon Could not collect system.host.phoscon states to check for obsolete states: Error: Cannot find view "system"
    2021-03-25 16:17:10.280  - error: host.phoscon _design/system missing - call node iobroker.js setup
    2021-03-25 16:17:10.499  - info: host.phoscon Created UUID: 7303e95c-cccb-281a-3567-e18baa14bc25
    2021-03-25 16:28:03.304  - info: host.phoscon received SIGTERM
    2021-03-25 16:28:03.395  - info: host.phoscon terminated
    2021-03-25 16:28:14.085  - info: host.phoscon iobroker.js-controller version 3.2.16 js-controller starting
    2021-03-25 16:28:14.091  - info: host.phoscon Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-03-25 16:28:14.092  - info: host.phoscon hostname: phoscon, node: v12.21.0
    2021-03-25 16:28:14.093  - info: host.phoscon ip addresses:
    2021-03-25 16:28:14.217  - error: host.phoscon Cannot read system.config: null (OK when migrating or restoring)
    2021-03-25 16:28:14.441  - info: host.phoscon connected to Objects and States
    2021-03-25 16:28:14.530  - info: host.phoscon added notifications configuration of host
    2021-03-25 16:28:14.573  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:28:14.575  - error: host.phoscon Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-03-25 16:28:14.646  - info: host.phoscon Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-03-25 16:28:14.654  - error: host.phoscon Cannot find view "system" for search "host"
    2021-03-25 16:28:14.667  - error: host.phoscon Cannot find view "system" for search "state"
    2021-03-25 16:28:14.668  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:28:14.669  - error: host.phoscon Could not collect system.host.phoscon states to check for obsolete states: Error: Cannot find view "system"
    2021-03-25 16:28:14.670  - error: host.phoscon _design/system missing - call node iobroker.js setup
    2021-03-25 16:33:33.046  - info: host.phoscon received SIGTERM
    2021-03-25 16:33:33.154  - info: host.phoscon terminated
    2021-03-25 16:33:44.034  - info: host.phoscon iobroker.js-controller version 3.2.16 js-controller starting
    2021-03-25 16:33:44.041  - info: host.phoscon Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-03-25 16:33:44.042  - info: host.phoscon hostname: phoscon, node: v12.21.0
    2021-03-25 16:33:44.042  - info: host.phoscon ip addresses:
    2021-03-25 16:33:44.195  - error: host.phoscon Cannot read system.config: null (OK when migrating or restoring)
    2021-03-25 16:33:44.370  - info: host.phoscon connected to Objects and States
    2021-03-25 16:33:44.456  - info: host.phoscon added notifications configuration of host
    2021-03-25 16:33:44.495  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:33:44.497  - error: host.phoscon Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-03-25 16:33:44.518  - info: host.phoscon Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-03-25 16:33:44.575  - error: host.phoscon Cannot find view "system" for search "host"
    2021-03-25 16:33:44.586  - error: host.phoscon Cannot find view "system" for search "state"
    2021-03-25 16:33:44.587  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:33:44.589  - error: host.phoscon Could not collect system.host.phoscon states to check for obsolete states: Error: Cannot find view "system"
    2021-03-25 16:33:44.590  - error: host.phoscon _design/system missing - call node iobroker.js setup
    2021-03-25 16:41:19.733  - info: host.phoscon received SIGTERM
    2021-03-25 16:41:19.763  - info: host.phoscon terminated
    2021-03-25 16:41:27.523  - info: host.phoscon iobroker.js-controller version 3.2.16 js-controller starting
    2021-03-25 16:41:27.529  - info: host.phoscon Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-03-25 16:41:27.530  - info: host.phoscon hostname: phoscon, node: v12.21.0
    2021-03-25 16:41:27.530  - info: host.phoscon ip addresses: 192.168.0.68 fe80::f5f4:844a:60c5:8c7d
    2021-03-25 16:41:27.627  - error: host.phoscon Cannot read system.config: null (OK when migrating or restoring)
    2021-03-25 16:41:27.796  - info: host.phoscon connected to Objects and States
    2021-03-25 16:41:27.882  - info: host.phoscon added notifications configuration of host
    2021-03-25 16:41:27.921  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:41:27.922  - error: host.phoscon Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-03-25 16:41:27.943  - info: host.phoscon Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-03-25 16:41:27.951  - error: host.phoscon Cannot find view "system" for search "host"
    2021-03-25 16:41:27.962  - error: host.phoscon Cannot find view "system" for search "state"
    2021-03-25 16:41:27.963  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:41:27.964  - error: host.phoscon Could not collect system.host.phoscon states to check for obsolete states: Error: Cannot find view "system"
    2021-03-25 16:41:27.965  - error: host.phoscon _design/system missing - call node iobroker.js setup
    2021-03-25 16:43:38.691  - info: host.phoscon received SIGTERM
    2021-03-25 16:43:38.793  - info: host.phoscon terminated
    2021-03-25 16:43:49.687  - info: host.phoscon iobroker.js-controller version 3.2.16 js-controller starting
    2021-03-25 16:43:49.693  - info: host.phoscon Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-03-25 16:43:49.694  - info: host.phoscon hostname: phoscon, node: v12.21.0
    2021-03-25 16:43:49.695  - info: host.phoscon ip addresses:
    2021-03-25 16:43:49.832  - error: host.phoscon Cannot read system.config: null (OK when migrating or restoring)
    2021-03-25 16:43:50.018  - info: host.phoscon connected to Objects and States
    2021-03-25 16:43:50.110  - info: host.phoscon added notifications configuration of host
    2021-03-25 16:43:50.153  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:43:50.154  - error: host.phoscon Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-03-25 16:43:50.225  - info: host.phoscon Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-03-25 16:43:50.233  - error: host.phoscon Cannot find view "system" for search "host"
    2021-03-25 16:43:50.246  - error: host.phoscon Cannot find view "system" for search "state"
    2021-03-25 16:43:50.247  - error: host.phoscon Cannot find view "system" for search "instance"
    2021-03-25 16:43:50.249  - error: host.phoscon Could not collect system.host.phoscon states to check for obsolete states: Error: Cannot find view "system"
    2021-03-25 16:43:50.250  - error: host.phoscon _design/system missing - call node iobroker.js setup
    @pd_mueller sagte in Mini-HowTo: Cannot find view "system" for search "host":
    Du hast da auch diese komischen Zeitsprünge drin.
    • P Offline
      pd_mueller
      Weil @Thomas-Braun im anderen Thread danach gefragt hat, hier jetzt auch der Ausschnitt von
      cat /var/log/apt/term.log
      Log started: 2021-03-25  16:22:31
      (Lese Datenbank ... 161018 Dateien und Verzeichnisse sind derzeit installiert.)
      Vorbereitung zum Entpacken von .../deconz_2.10.04-raspbian-buster-stable_armhf.deb ...
      Entpacken von deconz (2.10.04-raspbian-buster-stable) über (2.09.03-raspbian-buster-stable) ...
      deconz (2.10.04-raspbian-buster-stable) wird eingerichtet ...
      Trigger für mime-support (3.62) werden verarbeitet ...
      Trigger für gnome-menus (3.31.4-3) werden verarbeitet ...
      Trigger für desktop-file-utils (0.23-4) werden verarbeitet ...
      Log ended: 2021-03-25  16:22:40
      Log started: 2021-03-25  16:39:06
      Vormals nicht ausgewähltes Paket uuid-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../00-uuid-dev_2.33.1-0.1_armhf.deb ...
      Entpacken von uuid-dev:armhf (2.33.1-0.1) ...
      Vormals nicht ausgewähltes Paket libblkid-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../01-libblkid-dev_2.33.1-0.1_armhf.deb ...
      Entpacken von libblkid-dev:armhf (2.33.1-0.1) ...
      Vormals nicht ausgewähltes Paket liblzo2-2:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../02-liblzo2-2_2.10-0.1_armhf.deb ...
      Entpacken von liblzo2-2:armhf (2.10-0.1) ...
      Vormals nicht ausgewähltes Paket libcairo-script-interpreter2:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../03-libcairo-script-interpreter2_1.16.0-4+rpt1_armhf.deb ...
      Entpacken von libcairo-script-interpreter2:armhf (1.16.0-4+rpt1) ...
      Vormals nicht ausgewähltes Paket libfontconfig1-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../04-libfontconfig1-dev_2.13.1-2_armhf.deb ...
      Entpacken von libfontconfig1-dev:armhf (2.13.1-2) ...
      Vormals nicht ausgewähltes Paket xorg-sgml-doctools wird gewählt.
      Vorbereitung zum Entpacken von .../05-xorg-sgml-doctools_1%3a1.11-1_all.deb ...
      Entpacken von xorg-sgml-doctools (1:1.11-1) ...
      Vormals nicht ausgewähltes Paket x11proto-dev wird gewählt.
      Vorbereitung zum Entpacken von .../06-x11proto-dev_2018.4-4_all.deb ...
      Entpacken von x11proto-dev (2018.4-4) ...
      Vormals nicht ausgewähltes Paket x11proto-core-dev wird gewählt.
      Vorbereitung zum Entpacken von .../07-x11proto-core-dev_2018.4-4_all.deb ...
      Entpacken von x11proto-core-dev (2018.4-4) ...
      Vormals nicht ausgewähltes Paket libxau-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../08-libxau-dev_1%3a1.0.8-1+b2_armhf.deb ...
      Entpacken von libxau-dev:armhf (1:1.0.8-1+b2) ...
      Vormals nicht ausgewähltes Paket libxdmcp-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../09-libxdmcp-dev_1%3a1.1.2-3_armhf.deb ...
      Entpacken von libxdmcp-dev:armhf (1:1.1.2-3) ...
      Vormals nicht ausgewähltes Paket xtrans-dev wird gewählt.
      Vorbereitung zum Entpacken von .../10-xtrans-dev_1.3.5-1_all.deb ...
      Entpacken von xtrans-dev (1.3.5-1) ...
      Vormals nicht ausgewähltes Paket libpthread-stubs0-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../11-libpthread-stubs0-dev_0.4-1_armhf.deb ...
      Entpacken von libpthread-stubs0-dev:armhf (0.4-1) ...
      Vormals nicht ausgewähltes Paket libxcb1-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../12-libxcb1-dev_1.13.1-2_armhf.deb ...
      Entpacken von libxcb1-dev:armhf (1.13.1-2) ...
      Vormals nicht ausgewähltes Paket libx11-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../13-libx11-dev_2%3a1.6.7-1+deb10u1_armhf.deb ...
      Entpacken von libx11-dev:armhf (2:1.6.7-1+deb10u1) ...
      Vormals nicht ausgewähltes Paket libxrender-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../14-libxrender-dev_1%3a0.9.10-1_armhf.deb ...
      Entpacken von libxrender-dev:armhf (1:0.9.10-1) ...
      Vormals nicht ausgewähltes Paket x11proto-xext-dev wird gewählt.
      Vorbereitung zum Entpacken von .../15-x11proto-xext-dev_2018.4-4_all.deb ...
      Entpacken von x11proto-xext-dev (2018.4-4) ...
      Vormals nicht ausgewähltes Paket libxext-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../16-libxext-dev_2%3a1.3.3-1+b2_armhf.deb ...
      Entpacken von libxext-dev:armhf (2:1.3.3-1+b2) ...
      Vormals nicht ausgewähltes Paket libice-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../17-libice-dev_2%3a1.0.9-2_armhf.deb ...
      Entpacken von libice-dev:armhf (2:1.0.9-2) ...
      Vormals nicht ausgewähltes Paket libsm-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../18-libsm-dev_2%3a1.2.3-1_armhf.deb ...
      Entpacken von libsm-dev:armhf (2:1.2.3-1) ...
      Vormals nicht ausgewähltes Paket libpixman-1-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../19-libpixman-1-dev_0.36.0-1+rpt1_armhf.deb ...
      Entpacken von libpixman-1-dev:armhf (0.36.0-1+rpt1) ...
      Vormals nicht ausgewähltes Paket libxcb-render0-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../20-libxcb-render0-dev_1.13.1-2_armhf.deb ...
      Entpacken von libxcb-render0-dev:armhf (1.13.1-2) ...
      Vormals nicht ausgewähltes Paket libxcb-shm0-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../21-libxcb-shm0-dev_1.13.1-2_armhf.deb ...
      Entpacken von libxcb-shm0-dev:armhf (1.13.1-2) ...
      Vormals nicht ausgewähltes Paket libffi-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../22-libffi-dev_3.2.1-9_armhf.deb ...
      Entpacken von libffi-dev:armhf (3.2.1-9) ...
      Vormals nicht ausgewähltes Paket libglib2.0-dev-bin wird gewählt.
      Vorbereitung zum Entpacken von .../23-libglib2.0-dev-bin_2.58.3-2+deb10u2_armhf.deb ...
      Entpacken von libglib2.0-dev-bin (2.58.3-2+deb10u2) ...
      Vormals nicht ausgewähltes Paket libmount-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../24-libmount-dev_2.33.1-0.1_armhf.deb ...
      Entpacken von libmount-dev:armhf (2.33.1-0.1) ...
      Vormals nicht ausgewähltes Paket libpcre16-3:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../25-libpcre16-3_2%3a8.39-12_armhf.deb ...
      Entpacken von libpcre16-3:armhf (2:8.39-12) ...
      Vormals nicht ausgewähltes Paket libpcre32-3:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../26-libpcre32-3_2%3a8.39-12_armhf.deb ...
      Entpacken von libpcre32-3:armhf (2:8.39-12) ...
      Vormals nicht ausgewähltes Paket libpcrecpp0v5:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../27-libpcrecpp0v5_2%3a8.39-12_armhf.deb ...
      Entpacken von libpcrecpp0v5:armhf (2:8.39-12) ...
      Vormals nicht ausgewähltes Paket libpcre3-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../28-libpcre3-dev_2%3a8.39-12_armhf.deb ...
      Entpacken von libpcre3-dev:armhf (2:8.39-12) ...
      Vormals nicht ausgewähltes Paket libsepol1-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../29-libsepol1-dev_2.8-1_armhf.deb ...
      Entpacken von libsepol1-dev:armhf (2.8-1) ...
      Vormals nicht ausgewähltes Paket libselinux1-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../30-libselinux1-dev_2.8-1+b1_armhf.deb ...
      Entpacken von libselinux1-dev:armhf (2.8-1+b1) ...
      Vormals nicht ausgewähltes Paket libglib2.0-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../31-libglib2.0-dev_2.58.3-2+deb10u2_armhf.deb ...
      Entpacken von libglib2.0-dev:armhf (2.58.3-2+deb10u2) ...
      Vormals nicht ausgewähltes Paket libcairo2-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../32-libcairo2-dev_1.16.0-4+rpt1_armhf.deb ...
      Entpacken von libcairo2-dev:armhf (1.16.0-4+rpt1) ...
      libpcrecpp0v5:armhf (2:8.39-12) wird eingerichtet ...
      libglib2.0-dev-bin (2.58.3-2+deb10u2) wird eingerichtet ...
      libpixman-1-dev:armhf (0.36.0-1+rpt1) wird eingerichtet ...
      libpcre16-3:armhf (2:8.39-12) wird eingerichtet ...
      libsepol1-dev:armhf (2.8-1) wird eingerichtet ...
      liblzo2-2:armhf (2.10-0.1) wird eingerichtet ...
      libffi-dev:armhf (3.2.1-9) wird eingerichtet ...
      libpthread-stubs0-dev:armhf (0.4-1) wird eingerichtet ...
      xtrans-dev (1.3.5-1) wird eingerichtet ...
      uuid-dev:armhf (2.33.1-0.1) wird eingerichtet ...
      libpcre32-3:armhf (2:8.39-12) wird eingerichtet ...
      xorg-sgml-doctools (1:1.11-1) wird eingerichtet ...
      libcairo-script-interpreter2:armhf (1.16.0-4+rpt1) wird eingerichtet ...
      libblkid-dev:armhf (2.33.1-0.1) wird eingerichtet ...
      libfontconfig1-dev:armhf (2.13.1-2) wird eingerichtet ...
      libpcre3-dev:armhf (2:8.39-12) wird eingerichtet ...
      libmount-dev:armhf (2.33.1-0.1) wird eingerichtet ...
      libselinux1-dev:armhf (2.8-1+b1) wird eingerichtet ...
      libglib2.0-dev:armhf (2.58.3-2+deb10u2) wird eingerichtet ...
      Trigger für sgml-base (1.29) werden verarbeitet ...
      Trigger für install-info (6.5.0.dfsg.1-4+b1) werden verarbeitet ...
      x11proto-dev (2018.4-4) wird eingerichtet ...
      libxau-dev:armhf (1:1.0.8-1+b2) wird eingerichtet ...
      libice-dev:armhf (2:1.0.9-2) wird eingerichtet ...
      libsm-dev:armhf (2:1.2.3-1) wird eingerichtet ...
      Trigger für libglib2.0-0:armhf (2.58.3-2+deb10u2) werden verarbeitet ...
      Trigger für libc-bin (2.28-10+rpi1) werden verarbeitet ...
      Trigger für man-db (2.8.5-2) werden verarbeitet ...
      libxdmcp-dev:armhf (1:1.1.2-3) wird eingerichtet ...
      x11proto-core-dev (2018.4-4) wird eingerichtet ...
      x11proto-xext-dev (2018.4-4) wird eingerichtet ...
      libxcb1-dev:armhf (1.13.1-2) wird eingerichtet ...
      libx11-dev:armhf (2:1.6.7-1+deb10u1) wird eingerichtet ...
      libxcb-shm0-dev:armhf (1.13.1-2) wird eingerichtet ...
      libxcb-render0-dev:armhf (1.13.1-2) wird eingerichtet ...
      libxext-dev:armhf (2:1.3.3-1+b2) wird eingerichtet ...
      libxrender-dev:armhf (1:0.9.10-1) wird eingerichtet ...
      libcairo2-dev:armhf (1.16.0-4+rpt1) wird eingerichtet ...
      Log ended: 2021-03-25  16:39:26
      Log started: 2021-03-25  16:39:32
      Vormals nicht ausgewähltes Paket libharfbuzz-gobject0:armhf wird gewählt.
      (Lese Datenbank ... 162796 Dateien und Verzeichnisse sind derzeit installiert.)
      Vorbereitung zum Entpacken von .../0-libharfbuzz-gobject0_2.3.1-1_armhf.deb ...
      Entpacken von libharfbuzz-gobject0:armhf (2.3.1-1) ...
      Vormals nicht ausgewähltes Paket gir1.2-harfbuzz-0.0:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../1-gir1.2-harfbuzz-0.0_2.3.1-1_armhf.deb ...
      Entpacken von gir1.2-harfbuzz-0.0:armhf (2.3.1-1) ...
      Vormals nicht ausgewähltes Paket icu-devtools wird gewählt.
      Vorbereitung zum Entpacken von .../2-icu-devtools_63.1-6+deb10u1_armhf.deb ...
      Entpacken von icu-devtools (63.1-6+deb10u1) ...
      Vormals nicht ausgewähltes Paket libfribidi-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../3-libfribidi-dev_1.0.5-3.1+deb10u1_armhf.deb ...
      Entpacken von libfribidi-dev:armhf (1.0.5-3.1+deb10u1) ...
      Vormals nicht ausgewähltes Paket libgraphite2-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../4-libgraphite2-dev_1.3.13-7_armhf.deb ...
      Entpacken von libgraphite2-dev:armhf (1.3.13-7) ...
      Vormals nicht ausgewähltes Paket libicu-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../5-libicu-dev_63.1-6+deb10u1_armhf.deb ...
      Entpacken von libicu-dev:armhf (63.1-6+deb10u1) ...
      Vormals nicht ausgewähltes Paket libharfbuzz-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../6-libharfbuzz-dev_2.3.1-1_armhf.deb ...
      Entpacken von libharfbuzz-dev:armhf (2.3.1-1) ...
      Vormals nicht ausgewähltes Paket libxft-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../7-libxft-dev_2.3.2-2_armhf.deb ...
      Entpacken von libxft-dev:armhf (2.3.2-2) ...
      Vormals nicht ausgewähltes Paket pango1.0-tools wird gewählt.
      Vorbereitung zum Entpacken von .../8-pango1.0-tools_1.42.4-8~deb10u1_armhf.deb ...
      Entpacken von pango1.0-tools (1.42.4-8~deb10u1) ...
      Vormals nicht ausgewähltes Paket libpango1.0-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../9-libpango1.0-dev_1.42.4-8~deb10u1_armhf.deb ...
      Entpacken von libpango1.0-dev:armhf (1.42.4-8~deb10u1) ...
      libfribidi-dev:armhf (1.0.5-3.1+deb10u1) wird eingerichtet ...
      pango1.0-tools (1.42.4-8~deb10u1) wird eingerichtet ...
      libharfbuzz-gobject0:armhf (2.3.1-1) wird eingerichtet ...
      gir1.2-harfbuzz-0.0:armhf (2.3.1-1) wird eingerichtet ...
      libgraphite2-dev:armhf (1.3.13-7) wird eingerichtet ...
      icu-devtools (63.1-6+deb10u1) wird eingerichtet ...
      libicu-dev:armhf (63.1-6+deb10u1) wird eingerichtet ...
      libxft-dev:armhf (2.3.2-2) wird eingerichtet ...
      libharfbuzz-dev:armhf (2.3.1-1) wird eingerichtet ...
      libpango1.0-dev:armhf (1.42.4-8~deb10u1) wird eingerichtet ...
      Log ended: 2021-03-25  16:39:44
      Log started: 2021-03-25  16:39:48
      Vormals nicht ausgewähltes Paket libjpeg62-turbo-dev:armhf wird gewählt.
      (Lese Datenbank ... 163245 Dateien und Verzeichnisse sind derzeit installiert.)
      Vorbereitung zum Entpacken von .../libjpeg62-turbo-dev_1%3a1.5.2-2+deb10u1_armhf.deb ...
      Entpacken von libjpeg62-turbo-dev:armhf (1:1.5.2-2+deb10u1) ...
      Vormals nicht ausgewähltes Paket libjpeg-dev wird gewählt.
      Vorbereitung zum Entpacken von .../libjpeg-dev_1%3a1.5.2-2+deb10u1_all.deb ...
      Entpacken von libjpeg-dev (1:1.5.2-2+deb10u1) ...
      libjpeg62-turbo-dev:armhf (1:1.5.2-2+deb10u1) wird eingerichtet ...
      libjpeg-dev (1:1.5.2-2+deb10u1) wird eingerichtet ...
      Log ended: 2021-03-25  16:39:49
      Log started: 2021-03-25  16:39:55
      Vormals nicht ausgewähltes Paket libgif-dev wird gewählt.
      (Lese Datenbank ... 163265 Dateien und Verzeichnisse sind derzeit installiert.)
      Vorbereitung zum Entpacken von .../libgif-dev_5.1.4-3_armhf.deb ...
      Entpacken von libgif-dev (5.1.4-3) ...
      libgif-dev (5.1.4-3) wird eingerichtet ...
      Log ended: 2021-03-25  16:39:57
      Log started: 2021-03-25  16:40:02
      Vormals nicht ausgewähltes Paket gir1.2-rsvg-2.0:armhf wird gewählt.
      (Lese Datenbank ... 163275 Dateien und Verzeichnisse sind derzeit installiert.)
      Vorbereitung zum Entpacken von .../gir1.2-rsvg-2.0_2.44.10-2.1+rpi1_armhf.deb ...
      Entpacken von gir1.2-rsvg-2.0:armhf (2.44.10-2.1+rpi1) ...
      Vormals nicht ausgewähltes Paket libgdk-pixbuf2.0-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../libgdk-pixbuf2.0-dev_2.38.1+dfsg-1_armhf.deb ...
      Entpacken von libgdk-pixbuf2.0-dev:armhf (2.38.1+dfsg-1) ...
      Vormals nicht ausgewähltes Paket librsvg2-dev:armhf wird gewählt.
      Vorbereitung zum Entpacken von .../librsvg2-dev_2.44.10-2.1+rpi1_armhf.deb ...
      Entpacken von librsvg2-dev:armhf (2.44.10-2.1+rpi1) ...
      libgdk-pixbuf2.0-dev:armhf (2.38.1+dfsg-1) wird eingerichtet ...
      gir1.2-rsvg-2.0:armhf (2.44.10-2.1+rpi1) wird eingerichtet ...
      librsvg2-dev:armhf (2.44.10-2.1+rpi1) wird eingerichtet ...
      Log ended: 2021-03-25  16:40:03
      Log started: 2021-03-26  09:09:31
      (Lese Datenbank ... 163325 Dateien und Verzeichnisse sind derzeit installiert.)
      Vorbereitung zum Entpacken von .../libssl1.1_1.1.1d-0+deb10u6+rpt1_armhf.deb ...
      Entpacken von libssl1.1:armhf (1.1.1d-0+deb10u6+rpt1) über (1.1.1d-0+deb10u5+rpt2) ...
      Vorbereitung zum Entpacken von .../openssl_1.1.1d-0+deb10u6+rpt1_armhf.deb ...
      Entpacken von openssl (1.1.1d-0+deb10u6+rpt1) über (1.1.1d-0+deb10u5+rpt2) ...
      libssl1.1:armhf (1.1.1d-0+deb10u6+rpt1) wird eingerichtet ...
      openssl (1.1.1d-0+deb10u6+rpt1) wird eingerichtet ...
      Log ended: 2021-03-26  09:09:37
      • P pd_mueller
        @pd_mueller
        Warum läuft da ein Desktop mit?
        P 1 Antwort Letzte Antwort
        • P pd_mueller
          @apollon77
          @pd_mueller Interessant. Ich kann mir echt wenig vorstellen was bak UND echte json beide zerstören kann. An sich ist wenigsrens die bak noch ok auch wenn die andere kaputt ist. mega strange.
          • wendy2702W Online
            wendy2702W Online
            @Thomas-Braun @pd_mueller
            Darf ich das Phoscon zeug hier raustrennen? Passt ja nicht wirklich zum eigentlichen Thema der Anleitung.
            • D Online
              D Online
              darkiop
              Heute hatte es mich auch erwischt :)
              Nach einem geplanten reboot meines Proxmox Hosts. Die Fehlerbehebung ist ja kein Problem und in wenigen Sekunden erledigt, aber weis man was die Ursache ist? Hat sich das mit dem JS Controller 3.2 eingeschlichen?
              Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
              Thomas BraunT apollon77A 2 Antworten Letzte Antwort
              • D darkiop
                @darkiop
                Ich würde vor einem reboot auch den iobroker stoppen.
                D apollon77A 2 Antworten Letzte Antwort
                  @darkiop
                  D Online
                  D Online
                  darkiop
                  @thomas-braun sagte in Mini-HowTo: Cannot find view "system" for search "host":
                  Guten Morgen Thomas,
                  der Gedanke kam mir als ich meine Zeilen heute Morgen tippte ... was macht Proxmox eigentlich mit laufenden Containern/VMs - versuchen vorm System-reboot die Prozesse sauber zu beenden oder nimmt er die Brechstange? :D Das wollte ich im laufe des Tages mal testen.
                  apollon77A Thomas BraunT 2 Antworten Letzte Antwort
                  • D darkiop
                    @darkiop Logs bitte?? vom reboot zeitounkt und kurz davor/danach ... iobroker und syslog
                      @darkiop
                      @thomas-braun Das sollte systemd komplett alleine erledigen ... daher sollte das unnötig sein
                      • D darkiop
                        @darkiop An sich beendet proxymox alles sauber ...siehst Du an sich auch in der Proxmox Task liste ... da siehst DU auch wenn er die brechstange genommen hat
                        • D darkiop
                          @darkiop Ich weiß es nicht genau, ich vermute aber, dass da die 'Brechstange' genommen wird, wäre gleich bedeutend mit 'Stromausfall'.
                          Die Prozessverwaltung wird ja nicht vom Wirt gemacht, sondern läuft innerhalb des Containers ab. Von daher wird das kein besonders sanfter reboot sein, wenn da da plötzlich von extern neugestartet wird.
                          Das Verhalten deines Systems spricht ja auch dafür. Datei offen und wurde nicht sauber zurückgeschrieben.
                          [Edit:] Offenbar Quatsch geschrieben. :-)
                          • D Online
                            D Online
                            darkiop
                            Im Log sieht man schön wie die einzelnen VMs + LXCs beendet werden.
                            Allerdings ist mein Beispiel wohl ein schlechtes, denn heute Morgen um 08:02 hat irgendwas meinen js-controller abgeschossen (08:02 bis 08:33 war der offline). Erklären kann ich mir das gerade nicht, denn normalerweise hab ich ein sehr stabiles System. Aber heute Morgen habe ich diverse Updates gefahren - vielleicht hat da irgendwas scharf geschossen ...
                            Hab den pve01 heute zum Test auch noch 2x neu gestartet - alles ohne Probleme.
                            Von daher, für mich erledigt, kann mich nicht erinnern was genau um 8:02 heute Morgen war :D
                            iobroker.2021-03-31.txt
                            syslog.2021-03-31.txt
                            • D darkiop
                              @darkiop
                              2021-03-31 08:33:47.924  - info: host.pve-vm-iobroker starting 51 instances
                              Ich weiß zwar nicht wie potent deine Hardware ist, aber 51 laufende Instanzen sind jetzt nicht gerade wenig. Dürfte alleine schon deutlich über 2 GB RAM verbrauchen.
                                @darkiop
                                D Online
                                D Online
                                darkiop
                                Ist ein Nuc i5 mit 32GB, die CPU langweilt sich - der RAM könnte aber durchaus heut Morgen um 8 knapp gewesen sein - ich spendiere der VM mal noch ein wenig Reserve. Hab die Woche Rasenmäher und Co wieder in Betrieb genommen und es kamen mqtt und robonect zu den laufenden Instanzen dazu. Vermutlich bringen die das Fass im Grenzbereich zum Überlaufen :)
                                • D darkiop
                                  @darkiop Also das Log an sich sieht wie ein "sauberes" beenden vom controller aus. Und auch danach ist alles wieder sauber hochgefahren. Von daher wäre das Log vom problem-zeitbereich interessant. Und das Syslog wäre vn der VM interessant nicht vom proxmox hosts (und da auch um 8 bzw dann zu dem anderen Zeitpunkt)
                                  EDIT: zu proxmox: bzw ... wa sist den im proxmox log das
                                  Mar 31 08:29:02 pve01 pvestatd[11476]: storage 'odin-pve01' is not online
                                  Ist das der storage wo dide images der Container/VMs liegen? Warum war der offline?
                                    @rdzipzap
                                    Linux version 5.4.83-v7l+
                                    Bring dein System auf Stand. Da dürfte mittlerweile ein Kernel 5.10 angeboten werden.
                                    RDZipZap
                                    schrieb am zuletzt editiert von RDZipZap
                                    @thomas-braun said in Mini-HowTo: Cannot find view "system" for search "host":
                                    Kurzes Update von meiner Seite: Seit meinem Update auf 5.10 (das allerdings nur mit rpi-update möglich war) bin ich komplett befreit von meinen Problemen mit zufälligen Neustarts.
                                    Vielen Dank nochmal für die Unterstützung.
                                    • R RDZipZap
                                      @rdzipzap Von rpi-update würde ich die Finger lassen!
                                      Was hat denn da beim üblichen Upgrade geklemmt?
                                      sudo apt-get update
                                      sudo apt install --reinstall libraspberrypi0 libraspberrypi-{bin,dev,doc} raspberrypi-bootloader raspberrypi-kernel
                                      R 1 Antwort Letzte Antwort
                                        sudo apt-get update
                                        RDZipZap
                                        @thomas-braun Nun ja - ich habs hiermit probiert: Updating and upgrading Raspberry Pi OS
                                        Und da blieb ich immer bei 5.4 hängen. Mein System wäre bereits auf neustem Stand.
                                        Z.z. lebe ich ganz gut mit der pre-release Version. Würdest du mir trotzdem empfehlen, mit deiner geposteten Methode "downzugraden"? Ist das denn möglich?
                                        • R RDZipZap
                                          @rdzipzap auf jeden Fall!
                                          Beta-Zeug will man nicht auf dem System haben, wenn man nicht aktiv testet.
                                          Ist aber was für einen eigenen Thread.
