  4. Test/Support für Adapter rssfeed und vis-2-widgets-rssfeed
adapteratomfeediobroker.rssfeedrdfrssviswidget
705 Beiträge 35 Kommentatoren 241.7k Aufrufe 38 Beobachtet
  • OliverIOO OliverIO
    @dicken sagte in Test Adapter rssfeed v0.0.x:
    @oliverio sagte in Test Adapter rssfeed v0.0.x:
    @dicken
    Bitte einen Export davon machen
    [{"tpl":"i-vis-universal","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"iUniversalWidgetType":"Navigation","iValueType":"boolean","iValueComparison":"equal","iStateResponseTime":"0","iStateResetValueTime":"0","iNavWait":"99","iPopUpBackground":"#666666","iPopUpPreventClickOutside":"","iPopUpShowTitle":"true","iPopUpTitle":"","iPopUpTitleColor":"#ffffff","iPopUpCloseBtnColor":"#dc2e2e","iPopUpWidth":"800px","iPopUpHeight":"500px","iPopUpPosition":"center","iPopUpCornerRadiusUL":"12","iPopUpCornerRadiusUR":"0","iPopUpCornerRadiusLR":"12","iPopUpCornerRadiusLL":"0","iPopUpShadowXOffset":"2","iPopUpShadowYOffset":"2","iPopUpShadowBlur":"2","iPopUpShadowSpread":"1","iPopUpShadowColor":"#111111","iButtonCol":"#537EA6","iButtonActive":"#3e5a74","iButtonColHover":"","iOpacityBack":"1","iCornerRadiusUL":"0","iCornerRadiusUR":"0","iCornerRadiusLR":"0","iCornerRadiusLL":"0","iContentFlexDirection":"vertical","iContentVertAlign":"iSpace-between","iContentOrder":"orderImgText","iOpacityCtn":"1","iTextColor":"#ffffff","iTextSize":"16","iTextAlign":"iCenter","iTextSpaceTop":"0","iTextSpaceBottom":"0","iTextSpaceLeft":"0","iTextSpaceRight":"0","iIconSize":"70","iImgAlign":"iCenter","iImgSpaceTop":"-5","iImgSpaceBottom":"-10","iImgSpaceLeft":"0","iImgSpaceRight":"0","iImgRotation":"0","iImgBlinkFalse":"0","iImgBlinkTrue":"0","iImgColorFalse":"","iImgColorTrue":"","iShadowXOffset":"0","iShadowYOffset":"0","iShadowBlur":"0","iShadowSpread":"0","iShadowColor":"#111111","iShadowColorActive":"#111111","iShadowColorHover":"","iShadowInnerXOffset":"0","iShadowInnerYOffset":"0","iShadowInnerBlur":"0","iShadowInnerSpread":"0","iShadowInnerColor":"#111111","iShadowInnerColorActive":"#111111","iShadowInnerColorHover":"","iBorderSize":"0","iBorderStyle":"none","iBorderColor":"#ffffff","iBorderColorActive":"#ffffff","iBorderColorHover":"","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"nav_view":"002_predb","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","views":["002_predb"],"iImageFalse":"/icons-mfd-svg/scene_scene.svg","iImageTrue":"/icons-mfd-svg/scene_scene.svg","iTextFalse":"RSS","iTextTrue":"RSS","iImgColorInvertFalse":true,"iImgColorInvertTrue":true,"value":"new Date().toTime() ","oid":"0_userdata.0.rss.movieinfos_lastread"},"style":{"left":"152px","top":"684px","width":"110px","height":"87px"},"widgetSet":"vis-inventwo"}]
    Bei Wert muss du so etwas dann eintragen.
    Den Datenpunktnamen noch entsprechend anpassen. Das a: ohne leerzeichen danach muss so bleiben
    allerdings dient dieser nur als Dummy, so das man im 2.Argument den Zeitwert ermitteln kann. Das erfordert leider die Notation von vis.
    {a:0_userdata.0.lastread;new Date().getTime()}
    DickenD Offline
    DickenD Offline
    Dicken
    #413
    @oliverio
    Hmm?? Sorry ich versteh es leider nicht :man-facepalming:
    Was trag ich jetzt bei Object-ID im Widget und was bei Wert im Widget ein.
    habe das jetzt bei Wert eingefügt:
    {a:0_userdata.0.rss.movieinfos_lastread;new Date().getTime()}
    Aber das bringt keine Veränderung im Datenpunkt bei klicken. Jetzt schreibt er garnichts neues mehr in den Datenpunkt.
    • OliverIOO Offline
      OliverIOO Offline
      OliverIO
      #414
      @oliverio
      Objectid lässt du wie es war.
      Schau mal in die datenpunkt Einstellungen nach.
      Bei mir erzeugt Iobroker automatisch immer
      Max 100
      Und als Einheit ein %
      Ich finde das dafür ungünstig.
      Lösche beide Einstellungen über den roten Müll Knopf auf der rechten Seite
      Meine Adapter und Widgets
      Links im Profil
      DickenD 1 Antwort Letzte Antwort
        @oliverio
        Max 100
        DickenD Offline
        DickenD Offline
        Dicken
        #415
        @oliverio
        Ok, so jetzt wird eine Zahl in den unread Datenpunkt geschrieben beim Buttonklick, zbsp: "1616625483042"
        Jetzt muss ich vermutlich mal morgen Abwarten ob es bis dahin einen neuen RSS Beitrag gab um es zu testen.
        Viele Dank für deine Ausdauer :D Werde mich dann melden :)
        Es sei denn du sagst jetzt ich muss noch was ändern, weil die Zahl im unread Datenpunkt so garnicht erwünscht ist :D
        • DickenD Dicken
          @oliverio
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          #416
          @oliverio
          Also es steht noch die letzte Zahl der ungelesenen Artikel drin?
          Dann müssen wir im das Skript gleichzeitig triggern das unread auch gleich noch berechnet wird.
          Dazu muss man im Skript beim on noch zusätzlich den lastread datenpunkt eintragen.
          Das schaue ich morgen mal nach wie man da 2 datenpunkte einträgt.
          Wahrscheinlich per Array
          Links im Profil
            @oliverio
            DickenD Offline
            DickenD Offline
            Dicken
            #417
            @oliverio
            Ach sorry bin durcheinander gekommen,
            lastread = 1616625483042" nach klick
            unread = 0
            • DickenD Dicken
              @oliverio
              unread = 0
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              #418
              @oliverio
              unread = 0
              Also passt nun alles?
              Links im Profil
                @oliverio
                unread = 0
                DickenD Offline
                DickenD Offline
                Dicken
                #419
                @oliverio
                Das werde ich wohl erst sehen, wenn ein neuer RSS Beitrag kommt. Denke morgen früh sollte einer da sein. Werde aber dann bescheid geben.
                Sollte alles so laufen wie gewollt, würde ich das Workaround auch nochmal in einem Beitrag zusammen fassen, damit andere es auch verwenden können, ohne sich an den zich Beiträgen hier langhangeln zu müssen.
                Vielen Dank auf jedenfall schonmal/nochmal für deine Geduld und Hilfe :)
                • DickenD Offline
                  DickenD Offline
                  Dicken
                  #420
                  @oliverio
                  So also die Anzeige passt schonmal, auch wenn neue kommen, wird unread hochgezählt.
                  Wenn ich den Button klicke ändert sich auch die zahl in lastread.
                  Das einzige Problem ist jetzt glaub ich noch das script, denn unread wird nicht zurück auf 0 gesetzt wenn lastread sich ändert.
                  • DickenD Dicken
                    @oliverio
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    #421
                    @oliverio
                    hier nochmal eine kleine skriptänderung.
                    habe es gerade mit tagesschau getestet. da kommen öfters neue nachrichten.
                    dieses skript triggert nun bei Änderung des rss datenpunkts,
                    als auch bei Änderung von lastread. daher
                    1. wenn rss daten geändert, wird die anzahl der artikel gerechnet seit dem letzten lesen
                    2. wenn lastread durch knopf gesetzt wird, dann wird ebenfalls die artikel nochmal durchgerechnet, was demzufolge meist 0 ergeben müsste.
                    var rssFeedDP = "rssfeed.0.tagesschau";
                    var lastreadDP ="0_userdata.0.rssfeed.lastread";
                    var unreadDP ="0_userdata.0.rssfeed.unread";
                    var articles,maxdate,unread,rss;
                    on([rssFeedDP,lastreadDP], function (obj) {
                        unread=0;
                        rss = getState(rssFeedDP).val;
                        maxdate = getState(lastreadDP).val;
                        try {
                            var rssObj = JSON.parse(rss);
                            articles = rssObj.articles;
                        } catch {
                            return;
                        articles.forEach(function(item){
                            if (maxdate<new Date(item.pubdate).getTime()) unread=unread+1;
                        setState(unreadDP,unread);
                    Links im Profil
                      @oliverio
                          unread=0;
                          try {
                          } catch {
                              return;
                      DickenD Offline
                      DickenD Offline
                      Dicken
                      #422
                      Dankeschön :) Habs eingebaut und berichte wenn ich es durchgetestet hab :)
                      • DickenD Offline
                        DickenD Offline
                        Dicken
                        #423
                        Jawoll 💪 💪 💪 Es läuft :) Vielen vielen Dank.
                        Wenn ich jetzt auch noch nen zweiten oder dritten RSS Feed auf der View hab, kriegt man die vermutlich nich so einfach auch noch in dem Script unter oder? Das quasi die Beiträge von allen RSS Feeds auf der View in den selben unread Datenpunkt wandern.
                        • DickenD Dicken
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          #424
                          klar geht alles.
                          aber um es auch für dich einfach, skalierbar und für dich wartbar zu machen, würde ich für jedes rss ein eigenes skript machen und separate datenpunkte anlegen.
                          dann zum schluss noch ein separates skript, das auf Änderungen aller unread-datenpunkte reagiert, alle zusammenzählt und in eine neuen gesamt unread datenpunkt schreibt.
                          das ist dann der datenpunkt, den du dir anzeigen lassen kannst.
                          Links im Profil
                          • DickenD Offline
                            DickenD Offline
                            Dicken
                            #425
                            klar geht alles.
                            Stimmt, soweit hab ich garnich gedacht :) Das sollte ich sogar ohne Hilfe hinbekommen jetzt :) Danke, werd ich die Tage mal testen.
                              klaus88
                              schrieb am zuletzt editiert von klaus88
                              #426
                              Frage zu den Bildern in einem RSS Feed - vielleicht hat einer von euch einen Tipp für mich:
                              Ich wollte den Rss Feed des ORF einlesen: ORF-RSS
                              Dort sind jedoch die Bilder in den Enclosure eingebaut:
                              Bsp.:
                              <enclosure url="https://oekastatic.orf.at/mims/2021/42/08/crops/w=1280/1112139_opener_395208_unbenannt-3.jpg?s=d023243310648f6020297d5911934a4760082a2a" type="image/jpeg"/>
                              Habt ihr eine Ahnung, wie ich den Bild URL hier rausbekomme? Schlimm ist leider, dass dieser Enclosure nicht bei jedem item angefügt wurde sondern nur bei ein paar.
                              Was hab ich probiert:
                              var stpicture = item.enclosure;
                              var test=JSON.parse(stpicture);
                              Das gibt mir einen Fehler, dass ein unexpected token u in JSON at position 0 auftritt
                              was ich noch probiert habe:
                              let regex = /url="(.*?)"/;
                              let src = regex.exec(stpicture)[1];
                              aber auch hier gibt er mir einen Fehler aus
                              Habt ihr einen Tipp für mich?
                              Klaus
                              • K klaus88
                                Bsp.:
                                Klaus
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                #427
                                @klaus88
                                ok fehlalarm, ich hatte noch einen datenpunkt mit alten daten. daher hab ich text was zuvor hier drin stand überschrieben;
                                probier es mit dem folgenden template.
                                item.enclosures ist ein array con objekten. das objekt enthält die eigenschaft url.
                                das folgende template listet der reihe nach alle elemente von enclousures (wahrscheinlich immer nur eins) auf und füllt den wert aus url in das image tag.
                                <%= meta.title %>
                                <% articles.forEach(function(item){ %>
                                <p><small><%- vis.formatDate(item.pubdate, "TT.MM.JJJJ SS:mm") %></small></p>
                                <h3><%- item.title %></h3>
                                <p><%- item.description %></p>
                                <% item.enclosures.forEach(function(enc){ %>
                                <img src="<%- enc.url %>">
                                <div style="clear:both;" />
                                als zweite alternative, wenn du weißt, das es immer nur ein bild ist, kannst du auch direkt darauf zugreifen.
                                Zeile 8+9 prüft ob es das Objekt überhaupt gibt und speichert alternativ null ab
                                Zeile 12 prüft ob es ein Link gibt und gibt nur dann das image aus.
                                <%= meta.title %>
                                var url = null;
                                if (item.enclosures.length>0) url=item.enclosures[0].url||null;
                                if (url) {
                                <img src="<%- url %>">
                                Als Tip:
                                Wenn ihr wissen wollt, was ihr da übergeben bekommt, gibt es die beiden Hilfs-Widgets
                                Meta Helper und Article Helper
                                Da werden euch die DAten der einzelnen Artikel angezeigt, so das ihr sie im Template verwenden könnt.
                                Links im Profil
                                  @klaus88
                                  <%= meta.title %>
                                  <%= meta.title %>
                                  var url = null;
                                  if (url) {
                                  Als Tip:
                                  klaus88
                                  #428
                                  <%= meta.title %> <% articles.forEach(function(item){ %> <p><small><%- vis.formatDate(item.pubdate, "TT.MM.JJJJ SS:mm") %></small></p> <h3><%- item.title %></h3> <p><%- item.description %></p> <% var url = null; if (item.enclosures.length>0) url=item.enclosures[0].url||null; %> <% if (url) { %> <img src="<%- url %>"> <% } %> <div style="clear:both;" /> <% }); %>
                                  DANKE DANKE DANKE - so ein Mist - ich habe es nur falsch angesprochen. Das Geheimnis lag im item.enclosures[0].url --> also im [0].
                                  Danke vielmals für deine rasche perfekte Hilfe. Schaut nun super aus !!
                                  Schönen Abend noch!
                                  lg
                                  Klaus
                                    skokarl
                                    schrieb am zuletzt editiert von skokarl
                                    #429
                                    Hallo, OliverIO
                                    Version : 0.9.0
                                    Den lezten eingetragenen Feed ( Mallorca ) kann ich nicht sehen oder bearbeiten weil die
                                    "Schließen" Leiste diesen überdeckt. Scrollen geht auch nicht.
                                    Als Browser habe ich Firefox. Ist das ein Bug ? Danke und Gruß
                                    Weiterhin wird bei der Aktualisierung oben 15 angeboten, unten aber bis min 60 angemeckert.
                                    • S skokarl
                                      Hallo, OliverIO
                                      Version : 0.9.0
                                      OliverIOO Offline
                                      OliverIOO Offline
                                      OliverIO
                                      #430
                                      @skokarl
                                      ja stimmt.
                                      in chrome und edge scrollt das
                                      in firefox nicht.
                                      muss mal schauen.
                                      müsst aber eher ein bug der admin oberfläche sein.
                                      hast du mal noch deine versionsnummer des admins oder js-controllers?
                                      Links im Profil
                                        @skokarl
                                        ja stimmt.
                                        in firefox nicht.
                                        muss mal schauen.
                                        skokarl
                                        #431
                                        @oliverio
                                        Admin 5.1.25
                                        JS Controller weiß ich gerade nicht wo ich das finde, aber im Prinzip alles aktuell.
                                        • S skokarl
                                          @oliverio
                                          Admin 5.1.25
                                          #432
                                          @skokarl sagte in Test Adapter rssfeed v0.0.x:
                                          iobroker version
