  4. SONOS Instanz stellt Betrieb ein
sonos
25 Beiträge 8 Kommentatoren 2.8k Aufrufe 5 Beobachtet
  • H Offline
    hmanfred
    Nachdem ich die SONOS Instanz gelöscht und komplett neu angelegt habe, bleibt das Problem bestehen.
    Der Start des Adapters mündet irgendwann (nachdem er einige Stunden lang lief) immer in:
    2021-03-10 23:41:29.518  - info: sonos.0 (31885) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.sonos, node: v12.20.1, js-controller: 3.2.16
    2021-03-10 23:41:29.825  - error: sonos.0 (31885) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-03-10 23:41:29.826  - error: sonos.0 (31885) unhandled promise rejection: Cannot read property 'baseUrl' of undefined
    2021-03-10 23:41:29.826  - error: sonos.0 (31885) TypeError: Cannot read property 'baseUrl' of undefined
       at NotificationListener.topologyChange (/opt/iobroker/node_modules/sonos-discovery/lib/SonosSystem.js:109:30)
       at NotificationListener.emit (events.js:314:20)
       at /opt/iobroker/node_modules/sonos-discovery/lib/NotificationListener.js:117:17
       at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2021-03-10 23:41:29.827  - error: sonos.0 (31885) Cannot read property 'baseUrl' of undefined
    2021-03-10 23:41:29.840  - info: sonos.0 (31885) terminating
    2021-03-10 23:41:29.842  - info: sonos.0 (31885) terminating
    2021-03-10 23:41:29.843  - warn: sonos.0 (31885) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2021-03-10 23:41:30.455  - error: host.ioBroker instance system.adapter.sonos.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    ...und nach mehreren Startversuchen mit obigem Log-Eintrag:
    2021-03-10 23:41:30.456  - info: host.ioBroker Restart adapter system.adapter.sonos.0 because enabled
    2021-03-10 23:41:30.456  - warn: host.ioBroker Do not restart adapter system.adapter.sonos.0 because restart loop detected
    Ich bin mit meiner beschränkten Weisheit am Ende.
    cashC E 2 Antworten Letzte Antwort
    • H hmanfred
      cashC Offline
      cashC Offline
      cash
      @hmanfred Ich kann zwar nicht helfen aber bei mir läuft der Adapter ohne Probleme. Mehrmals am Tag speilt er entweder Playlisten oder Radio auf verschiedenen Geräten. Dazu gruppiert er oder löst Gruppen bei Bedarf auf. Alles unauffällig bei mir.
      H 1 Antwort Letzte Antwort
      • H hmanfred
        ente34
        @hmanfred
        Hier berichtet ein User von dem Fehler, nachdem er ein Stereo-Paar physikalisch getrennt hat und das Pärchen im Sonos-System nicht getrennt hat.
        Alternativ könnt ihr testweise Zeile 109 ändern:
            const anyPlayer = _this.getAnyPlayer();
            soap.invoke(`${anyPlayer.baseUrl}/MusicServices/Control`, soap.TYPE.ListAvailableServices)
            anyPlayer && anyPlayer.baseUrl && soap.invoke(`${anyPlayer.baseUrl}/MusicServices/Control`, soap.TYPE.ListAvailableServices)
        • cashC cash
          hmanfred
          @cash sagte in SONOS Instanz stellt Betrieb ein:
          Tja, das war es bis... ja, bis zu welchem Ereignis?... bei mir auch.
          • E ente34
            @hmanfred
            hmanfred
            @ente34
            Danke für den Tipp. Aber bevor ich anfange interne Konfigfiles zu ändern, lote oich erst mal alle anderen Optionen aus.
            • H Offline
              hmanfred
              schrieb am zuletzt editiert von hmanfred
              Es gibt neue Erkenntnisse:
              Ich schalte schon seit eh und je nachts den TV und die Playbar über eine Schaltsteckdose aus. Grund ist der hohe Standby-Verbrauch der SONOS Komponenten. Und: nein, ich habe keinen OLED-TV, der sinnvollerweise nicht vom Strom getrennt werden sollte.
              Nun habe ich das mal gestern abend nicht gemacht - und siehe da, die Instanz läuft noch.
              Ein Rätsel sind mir dabei aber folgende Aspekte:
              • Die Abschaltung der Playbar geschieht schon seit Jahren. Die Probleme sind erst jetzt aufgetreten.
              • Auch zwei Play 1 im Wintergarten sind derzeit dauerhaft vom Strom getrennt. Ohne Auswirkung auf die Stabilität der Instanz.
              FredFF HomoranH 2 Antworten Letzte Antwort
              • H hmanfred
                FredFF Offline
                FredFF Offline
                FredF
                Most Active Forum Testing
                Ist mir auch ein Rätsel das es nun geholfen hat die Playbar nicht auszuschalten und ich habe auch keine Erklärung dafür.
                @hmanfred sagte in SONOS Instanz stellt Betrieb ein:
                Das mache ich auch und schon immer ohne Probleme.
                Habe auch mind. 2 Geräte die im Adapter eingerichtet sind aber häufig aus sind.
                Wirklich merkwürdig...
                • H hmanfred
                  Ich habe gerade mal aufgrund dieser Aussage gemessen.
                  Meine Play:1 zieht irgendwas zwischen 2.5 und 3.5W.
                  Das wäre für mich kein Grund diese abzuschalten
                  Bei mir ist allerdings das WLAN aus
                    hmanfred
                    Meine SONOS-Komponenten (Playbar, SUB und 4 x Play:1) ziehen zusammen ca. > 20 W im Standby. Für mich schon ein Grund zum Abschalten.
                    @All
                    Leider war die Abschaltung der Playbar wohl doch nicht die Ursache. Die Instanz ist dann doch irgendwann wieder abgek***t.😠
                    Wenn ich hier keine Lösung oder einen Workaround finde, wird die SONOS wohl vom ioBroker verabschiedet. Inzwischen steuere ich sie ohnehin fast ausschließlich über den Google Assistant. Einzig wegen der dort fehlenden Unterstützung der Gruppenbildung war/ist ioBroker noch nötig. Mal sehen, vielleicht kann IFTT das ja inzwischen...
                    Wäre nur absolut unbefriedigend, wenn eine so schöne und leistungsfähige Middleware aus Gründen unerklärlicher Fehlfunktionen abgespeckt werden müsste.😞
                    • H hmanfred
                      @All
                      das passt dann ja auch.
                      6 Komponenten, davon ein SUB x 2.5 = 15
