  4. Fehlersuche?traeges Verhalten/Zigbee/IKEA/Blockly
20 Beiträge 3 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • AsgothianA Asgothian
    @fred-freund sagte in Fehlersuche?traeges Verhalten/Zigbee/IKEA/Blockly:
    Also : ein Shutdown und POWER OFF loeste das Adapter problem , mal sehen ob er wieder Probleme macht.
    Wenn so etwas passiert musst du im Log nachschauen was für Meldungen vorhanden sind. Das Log meldet im Normalfall recht genau weswegen die Hardware nicht startet.
    A.
    Fred FreundF Offline
    Fred Freund
    schrieb am zuletzt editiert von Fred Freund
    @asgothian
    2021-03-13 16:11:31.035  - info: zigbee.0 (1244) Currently no devices.
    2021-03-13 16:11:31.036  - info: zigbee.0 (1244) Zigbee started
    2021-03-13 16:11:44.136  - info: zigbee.0 (1244) Zigbee: allowing new devices to join.
    2021-03-13 16:12:05.076  - info: zigbee.0 (1244) Starting interview of '0x5c0272fffe997f78'
    2021-03-13 16:12:07.331  - warn: zigbee.0 (1244) Device '0x5c0272fffe997f78' announced itself
    2021-03-13 16:12:45.446  - info: zigbee.0 (1244) Zigbee: stop joining
    2021-03-13 16:12:46.687  - info: zigbee.0 (1244) Successfully interviewed '0x5c0272fffe997f78', device has succesfully been paired
    2021-03-13 16:12:46.688  - info: zigbee.0 (1244) Device '0x5c0272fffe997f78' is supported, identified as: IKEA TRADFRI motion sensor (E1525/E1745)
    2021-03-13 16:12:46.692  - info: zigbee.0 (1244) Configuring 0x5c0272fffe997f78 TRADFRI motion sensor
    2021-03-13 16:12:53.918  - info: zigbee.0 (1244) DeviceConfigure successful 0x5c0272fffe997f78 TRADFRI motion sensor
    2021-03-13 16:14:55.652  - info: zigbee.0 (1244) Zigbee: allowing new devices to join.
    2021-03-13 16:15:21.445  - info: zigbee.0 (1244) Starting interview of '0x60a423fffeeecd67'
    2021-03-13 16:15:24.855  - warn: zigbee.0 (1244) Device '0x60a423fffeeecd67' announced itself
    2021-03-13 16:15:28.299  - error: zigbee.0 (1244) Adapter disconnected, stopping
    2021-03-13 16:15:31.507  - error: zigbee.0 (1244) Failed to interview '0x60a423fffeeecd67', device has not succesfully been paired. undefined
    2021-03-13 16:15:38.301  - info: zigbee.0 (1244) Try to reconnect. 5 attempts left
    2021-03-13 16:15:38.303  - info: zigbee.0 (1244) Starting Zigbee  npm ...
    2021-03-13 16:15:38.312  - error: zigbee.0 (1244) Failed to start Zigbee
    2021-03-13 16:15:38.313  - error: zigbee.0 (1244) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM1'
        at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
        at Generator.next (<anonymous>)
        at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
        at new Promise (<anonymous>)
        at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
        at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
        at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
        at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
    2021-03-13 16:15:38.324  - info: zigbee.0 (1244) Installed Version: ioBroker/ioBroker.zigbee#47e641cb8ec3756b16e5b7ff817fbf93502e295d
    2021-03-13 16:15:48.315  - info: zigbee.0 (1244) Try to reconnect. 4 attempts left
    2021-03-13 16:15:48.317  - info: zigbee.0 (1244) Starting Zigbee  npm ...
    2021-03-13 16:15:48.325  - error: zigbee.0 (1244) Failed to start Zigbee
    2021-03-13 16:15:48.326  - error: zigbee.0 (1244) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM1'
    2021-03-13 16:15:48.331  - info: zigbee.0 (1244) Installed Version: ioBroker/ioBroker.zigbee#47e641cb8ec3756b16e5b7ff817fbf93502e295d
    2021-03-13 16:15:56.906  - info: zigbee.0 (1244) Zigbee: stop joining
    2021-03-13 16:15:56.910  - error: zigbee.0 (1244) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-03-13 16:15:56.911  - error: zigbee.0 (1244) unhandled promise rejection: Cannot request when znp has not been initialized yet
    2021-03-13 16:15:56.913  - error: zigbee.0 (1244) Error: Cannot request when znp has not been initialized yet
        at Znp.request (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:273:19)
        at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:808:28)
        at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:27:71
        at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:23:12)
        at ZStackAdapter.dataRequestExtended (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:804:16)
        at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:453:28)
    2021-03-13 16:15:56.913  - error: zigbee.0 (1244) Cannot request when znp has not been initialized yet
    2021-03-13 16:15:56.963  - info: zigbee.0 (1244) cleaned everything up...
    2021-03-13 16:15:56.966  - info: zigbee.0 (1244) Zigbee: disabling joining new devices.
    2021-03-13 16:15:56.976  - error: zigbee.0 (1244) Failed to stop zigbee (Error: Cannot request when znp has not been initialized yet
        at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:27:71)
    2021-03-13 16:15:56.978  - info: zigbee.0 (1244) terminating
    2021-03-13 16:15:56.980  - warn: zigbee.0 (1244) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2021-03-13 16:15:57.572  - error: host.broker1 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2021-03-13 16:15:57.577  - info: host.broker1 Restart adapter system.adapter.zigbee.0 because enabled
    2021-03-13 16:16:27.624  - info: host.broker1 instance system.adapter.zigbee.0 started with pid 1320
    2021-03-13 16:16:29.882  - info: zigbee.0 (1320) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.21.0, js-controller: 3.2.16
    2021-03-13 16:16:29.974  - info: zigbee.0 (1320) Starting Zigbee  npm ...
    2021-03-13 16:16:30.193  - error: zigbee.0 (1320) Failed to start Zigbee
    2021-03-13 16:16:30.194  - error: zigbee.0 (1320) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM1'
    2021-03-13 16:16:30.255  - info: zigbee.0 (1320) Installed Version: ioBroker/ioBroker.zigbee#47e641cb8ec3756b16e5b7ff817fbf93502e295d
    2021-03-13 16:16:40.195  - info: zigbee.0 (1320) Try to reconnect. 1 attempts left
    2021-03-13 16:16:40.196  - info: zigbee.0 (1320) Starting Zigbee  npm ...
    2021-03-13 16:16:40.201  - error: zigbee.0 (1320) Failed to start Zigbee
    2021-03-13 16:16:40.202  - error: zigbee.0 (1320) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM1'
    2021-03-13 16:16:40.205  - info: zigbee.0 (1320) Installed Version: ioBroker/ioBroker.zigbee#47e641cb8ec3756b16e5b7ff817fbf93502e295d
    Das passiert beim anlernen der Gunnarp Lampe ...
    Motion Sensor hat kein Problem gemacht..
    many Thx for your support,
    Vielen Dank!
    • Fred FreundF Fred Freund
      @asgothian
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @fred-freund Dir ist die serielle Schnittstelle abgestürzt.
      Das ist ein Hinweis darauf das er die Kommunikation zum Zigbee-Stick verloren hat.
      Diese Meldung besagt das der link zum seriellen Port nicht existiert.
      Da gibt es also ein problem mit dem Rechner an dem das steckt oder der Firmware / Hardware auf dem Koordinator.
      A.
      Fred FreundF 1 Antwort Letzte Antwort
        A.
        Fred Freund
        @asgothian
        Interpretiere ich den Scan richtig dort wo nichts ist waere der beste Kanal?
        Also software reset habe ich keinen gefunden, aber aus einstecken des cc2531 funktioniert auch...
        ttyACM1 ist dann wieder da
        Vielen Dank!
          @asgothian
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @fred-freund Ja, das sind die "leeren" Kanäle. Allerdings musst du mit den nicht ZLL Kanälen (ZLL Kanäle sind 11,15,20,26) Vorsichtig sein, nicht alle Geräte laufen darauf
            Fred Freund
            @asgothian
            Habe jetzt mal den 26er Kanal genommen...die Switches und Bewegungsmelder Tradfir werden identifiziert und funktionieren.
            Die Lampen geben diesen Error und dann steigt der CC2531 aus.
            Nach dem reboot ist nur
            zu sehen.
            Beim Speicher bekomme ich immer diese Meldung:
            Hoffe Dienstag ist es besser mit cc26xr21
            Also default war 11 eingestellt das hat recht gut funktioniert , momentan geht garnichts :-) und Schalte und BM ohne Lampen machen keinen Sinn :-)
            Vielen Dank!
              @asgothian
              zu sehen.
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @fred-freund
              Wie schon oben beschrieben.. Interessant ist was im log steht.
              A.
                @fred-freund
                A.
                Fred Freund
                @asgothian
                das nicht vollstaendige Geraet laesst sich auch nicht loeschen...
                Also adapter gloescht neu , usb
                /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CD48243-if00
                2021-03-13 22:05:28.885  - error: zigbee.0 (1280) Serial port not selected! Go to settings page.
                2021-03-13 22:05:28.942  - info: zigbee.0 (1280) Starting Zigbee  npm ...
                2021-03-13 22:05:29.239  - info: zigbee.0 (1280) Installed Version: ioBroker/ioBroker.zigbee#47e641cb8ec3756b16e5b7ff817fbf93502e295d
                2021-03-13 22:05:31.251  - info: zigbee.0 (1280) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}
                2021-03-13 22:05:31.263  - info: zigbee.0 (1280)   --> transmitPower : normal
                2021-03-13 22:05:31.272  - info: zigbee.0 (1280) Currently no devices.
                2021-03-13 22:05:31.274  - info: zigbee.0 (1280) Zigbee started
                2021-03-13 22:08:06.054  - info: host.broker1 stopInstance system.adapter.zigbee.0 (force=false, process=true)
                2021-03-13 22:08:06.065  - info: zigbee.0 (1280) Got terminate signal TERMINATE_YOURSELF
                2021-03-13 22:08:06.067  - info: host.broker1 stopInstance system.adapter.zigbee.0 send kill signal
                2021-03-13 22:08:06.069  - info: zigbee.0 (1280) cleaned everything up...
                2021-03-13 22:08:06.074  - info: zigbee.0 (1280) Zigbee: disabling joining new devices.
                2021-03-13 22:08:06.331  - info: zigbee.0 (1280) terminating
                2021-03-13 22:08:06.333  - info: zigbee.0 (1280) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2021-03-13 22:08:06.973  - info: host.broker1 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2021-03-13 22:08:09.116  - info: host.broker1 instance system.adapter.zigbee.0 started with pid 1327
                2021-03-13 22:08:11.470  - info: zigbee.0 (1327) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.21.0, js-controller: 3.2.16
                2021-03-13 22:08:11.564  - info: zigbee.0 (1327) Starting Zigbee  npm ...
                2021-03-13 22:08:11.892  - info: zigbee.0 (1327) Installed Version: ioBroker/ioBroker.zigbee#47e641cb8ec3756b16e5b7ff817fbf93502e295d
                2021-03-13 22:08:19.630  - info: zigbee.0 (1327) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}
                2021-03-13 22:08:19.644  - info: zigbee.0 (1327)   --> transmitPower : normal
                2021-03-13 22:08:19.653  - info: zigbee.0 (1327) Currently no devices.
                2021-03-13 22:08:19.655  - info: zigbee.0 (1327) Zigbee started
                2021-03-13 22:08:56.483  - info: host.broker1 stopInstance system.adapter.zigbee.0 (force=false, process=true)
                2021-03-13 22:08:56.524  - info: zigbee.0 (1327) Got terminate signal TERMINATE_YOURSELF
                2021-03-13 22:08:56.525  - info: host.broker1 stopInstance system.adapter.zigbee.0 send kill signal
                2021-03-13 22:08:56.526  - info: zigbee.0 (1327) cleaned everything up...
                2021-03-13 22:08:56.528  - info: zigbee.0 (1327) Zigbee: disabling joining new devices.
                2021-03-13 22:08:56.774  - info: zigbee.0 (1327) terminating
                2021-03-13 22:08:56.776  - info: zigbee.0 (1327) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2021-03-13 22:08:57.444  - info: host.broker1 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2021-03-13 22:08:59.587  - info: host.broker1 instance system.adapter.zigbee.0 started with pid 1357
                2021-03-13 22:09:01.965  - info: zigbee.0 (1357) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.21.0, js-controller: 3.2.16
                2021-03-13 22:09:02.068  - info: zigbee.0 (1357) Starting Zigbee  npm ...
                2021-03-13 22:09:02.365  - info: zigbee.0 (1357) Installed Version: ioBroker/ioBroker.zigbee#47e641cb8ec3756b16e5b7ff817fbf93502e295d
                2021-03-13 22:09:09.651  - info: zigbee.0 (1357) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}
                2021-03-13 22:09:09.664  - info: zigbee.0 (1357)   --> transmitPower : normal
                2021-03-13 22:09:09.673  - info: zigbee.0 (1357) Currently no devices.
                2021-03-13 22:09:09.675  - info: zigbee.0 (1357) Zigbee started
                2021-03-13 22:09:21.759  - info: zigbee.0 (1357) Zigbee: allowing new devices to join.
                2021-03-13 22:09:47.509  - info: zigbee.0 (1357) Starting interview of '0x60a423fffeeecd67'
                2021-03-13 22:09:50.919  - warn: zigbee.0 (1357) Device '0x60a423fffeeecd67' announced itself
                2021-03-13 22:10:23.059  - info: zigbee.0 (1357) Zigbee: stop joining
                2021-03-13 22:10:33.542  - error: zigbee.0 (1357) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2021-03-13 22:10:33.544  - error: zigbee.0 (1357) unhandled promise rejection: SRSP - AF - dataRequestExt after 6000ms
                2021-03-13 22:10:33.546  - error: zigbee.0 (1357) Error: SRSP - AF - dataRequestExt after 6000ms
                    at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:67:35)
                    at listOnTimeout (internal/timers.js:554:17)
                    at processTimers (internal/timers.js:497:7)
                2021-03-13 22:10:33.547  - error: zigbee.0 (1357) SRSP - AF - dataRequestExt after 6000ms
                2021-03-13 22:10:33.578  - info: zigbee.0 (1357) cleaned everything up...
                2021-03-13 22:10:33.582  - info: zigbee.0 (1357) Zigbee: disabling joining new devices.
                2021-03-13 22:10:34.082  - info: zigbee.0 (1357) terminating
                2021-03-13 22:10:34.085  - warn: zigbee.0 (1357) Terminated (UNCAUGHT_EXCEPTION): Without reason
                Dann ist der Adapter wieder gelb und ist weg. Ich geb mal vorerst auf!
                Vielen Dank!
                  @asgothian
                  Fred Freund
                  wollte euch nur sagen habe mit meine Raspi und mit Hilfe der Anleitung
                  CC2531Flash ohne CCdebugger
                  Neu geflashed und jetzt findet er die Lampe aus einer super Entfernung! wo ich vorher auf 10cm hingehen musste und einen Error bekam.
                  2021-03-15 00:09:03.793  - info: host.broker1 stopInstance system.adapter.zigbee.0 (force=false, process=true)
                  2021-03-15 00:09:03.850  - info: zigbee.0 (1178) Got terminate signal TERMINATE_YOURSELF
                  2021-03-15 00:09:03.851  - info: host.broker1 stopInstance system.adapter.zigbee.0 send kill signal
                  2021-03-15 00:09:03.852  - info: zigbee.0 (1178) cleaned everything up...
                  2021-03-15 00:09:03.857  - warn: zigbee.0 (1178) Failed to stop zigbee during startup
                  2021-03-15 00:09:03.858  - info: zigbee.0 (1178) terminating
                  2021-03-15 00:09:03.859  - info: zigbee.0 (1178) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2021-03-15 00:09:04.405  - info: host.broker1 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2021-03-15 00:09:06.902  - info: host.broker1 instance system.adapter.zigbee.0 started with pid 1699
                  2021-03-15 00:09:09.099  - info: zigbee.0 (1699) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.21.0, js-controller: 3.2.16
                  2021-03-15 00:09:09.142  - info: zigbee.0 (1699) Starting Zigbee  npm ...
                  2021-03-15 00:09:09.438  - info: zigbee.0 (1699) Installed Version: ioBroker/ioBroker.zigbee#cd902e1bafcb9ff16c582741d4f027b639a644c1
                  2021-03-15 00:09:14.864  - info: zigbee.0 (1699) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20201128}}
                  2021-03-15 00:09:14.877  - info: zigbee.0 (1699)   --> transmitPower : normal
                  2021-03-15 00:09:14.885  - info: zigbee.0 (1699) Currently no devices.
                  2021-03-15 00:09:14.887  - info: zigbee.0 (1699) Zigbee started
                  2021-03-15 00:09:14.948  - info: host.broker1 stopInstance system.adapter.zigbee.0 (force=false, process=true)
                  2021-03-15 00:09:14.953  - info: zigbee.0 (1699) Got terminate signal TERMINATE_YOURSELF
                  2021-03-15 00:09:14.954  - info: host.broker1 stopInstance system.adapter.zigbee.0 send kill signal
                  2021-03-15 00:09:14.955  - info: zigbee.0 (1699) cleaned everything up...
                  2021-03-15 00:09:14.958  - info: zigbee.0 (1699) Zigbee: disabling joining new devices.
                  2021-03-15 00:09:15.198  - info: zigbee.0 (1699) terminating
                  2021-03-15 00:09:15.199  - info: zigbee.0 (1699) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2021-03-15 00:09:15.789  - info: host.broker1 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2021-03-15 00:09:17.990  - info: host.broker1 instance system.adapter.zigbee.0 started with pid 1715
                  2021-03-15 00:09:20.103  - info: zigbee.0 (1715) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.21.0, js-controller: 3.2.16
                  2021-03-15 00:09:20.233  - info: zigbee.0 (1715) Starting Zigbee  npm ...
                  2021-03-15 00:09:20.533  - info: zigbee.0 (1715) Installed Version: ioBroker/ioBroker.zigbee#cd902e1bafcb9ff16c582741d4f027b639a644c1
                  2021-03-15 00:09:22.516  - info: zigbee.0 (1715) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20201128}}
                  2021-03-15 00:09:22.528  - info: zigbee.0 (1715)   --> transmitPower : normal
                  2021-03-15 00:09:22.536  - info: zigbee.0 (1715) Currently no devices.
                  2021-03-15 00:09:22.538  - info: zigbee.0 (1715) Zigbee started
                  2021-03-15 00:09:43.873  - info: zigbee.0 (1715) Zigbee: allowing new devices to join.
                  2021-03-15 00:10:00.812  - info: zigbee.0 (1715) Starting interview of '0x60a423fffeebdcf4'
                  2021-03-15 00:10:03.214  - warn: zigbee.0 (1715) Device '0x60a423fffeebdcf4' announced itself
                  2021-03-15 00:10:45.165  - info: zigbee.0 (1715) Zigbee: stop joining
                  2021-03-15 00:10:48.491  - info: zigbee.0 (1715) Successfully interviewed '0x60a423fffeebdcf4', device has succesfully been paired
                  2021-03-15 00:10:48.492  - info: zigbee.0 (1715) Device '0x60a423fffeebdcf4' is supported, identified as: IKEA TRADFRI remote control (E1524/E1810)
                  2021-03-15 00:10:48.496  - info: zigbee.0 (1715) Configuring 0x60a423fffeebdcf4 TRADFRI remote control
                  2021-03-15 00:10:57.741  - info: zigbee.0 (1715) DeviceConfigure successful 0x60a423fffeebdcf4 TRADFRI remote control
                  2021-03-15 00:11:59.436  - info: zigbee.0 (1715) Zigbee: allowing new devices to join.
                  2021-03-15 00:12:27.266  - info: zigbee.0 (1715) Starting interview of '0x60a423fffeeecd67'
                  2021-03-15 00:12:31.127  - warn: zigbee.0 (1715) Device '0x60a423fffeeecd67' announced itself
                  2021-03-15 00:12:41.393  - info: zigbee.0 (1715) Successfully interviewed '0x60a423fffeeecd67', device has succesfully been paired
                  2021-03-15 00:12:41.394  - info: zigbee.0 (1715) Device '0x60a423fffeeecd67' is supported, identified as: IKEA GUNNARP panel round (T1828)
                  2021-03-15 00:12:41.397  - info: zigbee.0 (1715) Configuring 0x60a423fffeeecd67 GUNNARP panel round
                  2021-03-15 00:12:41.576  - info: zigbee.0 (1715) DeviceConfigure successful 0x60a423fffeeecd67 GUNNARP panel round
                  2021-03-15 00:13:00.706  - info: zigbee.0 (1715) Zigbee: stop joining
                  Vielen Dank!
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @fred-freund na ich hoffe du hast nicht die firmware genommen die da im beitrag stand vom April die ist nämlich fehlerhaft
                    • arteckA arteck
                      Fred Freund
                      @arteck Nein Nein , aber Danke.
                      Also das Hex zu finden war fuer mich nicht leicht.
                      HIER fuer den cc2531
                      Genau in diesem ZIP
                      Vielen Dank!
