  4. js-controller 3.2 jetzt im STABLE!
    apollon77A
275 Beiträge 58 Kommentatoren 112.6k Aufrufe 51 Beobachtet
  • apollon77A apollon77
    @techmo Mehr Log gibts nicht? Bitte mal Admin in debug log starten und posten
    T
    T
    TechMo
    @apollon77
    Ist jetzt ein anderer Fehler:
    2021-02-21 21:21:06.123  - debug: admin.0 (31084) Adding to Greenlock: anstoots.ddns.net with alternative names anstoots.ddns.net
    2021-02-21 21:21:06.380  - info: admin.0 (31084) Challenge server listening on port 80
    2021-02-21 21:21:06.382  - info: admin.0 (31084) If something is not working and your adapter is not reachable anymore you can turn off HTTPS with executing "iobroker admin.0 set --secure false" in your shell.
    2021-02-21 21:21:06.453  - info: admin.0 (31084) https server listening on port 8081
    2021-02-21 21:21:06.454  - info: admin.0 (31084) Use link "https://localhost:8081" to configure.
    2021-02-21 21:21:06.647  - debug: admin.0 (31084) Subscribe OBJECTS: *
    2021-02-21 21:21:16.886  - debug: admin.0 (31084) [LE] certificate_order: {"account":{"key":{"kid":"https://acme-v02.api.letsencrypt.org/acme/acct/113314436"}},"subject":"mydomain.net","altnames":["mydomain.net"],"challengeTypes":["http-01"]}
    2021-02-21 21:21:19.306  - debug: admin.0 (31084) [LE] challenge_select: {"altname":"mydomain.net","type":"http-01","keyAuthorization":"SZxIO3ip2CRhSFFNCsIKhbsJL5rNL-IuuKtQoRzsvCE.x5SIlyfhEmleea795fCKMguyqnZwCQZOs7-BVkyoLeQ"}
    2021-02-21 21:21:25.662  - debug: admin.0 (31084) [LE] challenge_status: {"status":"pending","type":"http-01","altname":"mydomain.net"}
    2021-02-21 21:21:28.068  - debug: admin.0 (31084) [LE] challenge_status: {"status":"valid","type":"http-01","altname":"mydomain.net"}
    2021-02-21 21:21:28.072  - info: admin.0 (31084) Received new certificate for mydomain.net via http-01
    2021-02-21 21:21:30.451  - debug: admin.0 (31084) [LE] certificate_status: {"subject":"mydomain.net","status":"valid"}
    2021-02-21 21:21:31.478  - debug: admin.0 (31084) [LE] cert_issue: {"renewAt":1617822156264,"subject":"mydomain.net","altnames":["mydomain.net"]}
    2021-02-21 21:21:31.479  - info: admin.0 (31084) Certificate for mydomain.net is valid till 2021-04-07T19:02:36.264Z
    2021-02-21 21:21:38.021  - error: admin.0 (31084) [LE] {"errno":"ENOTFOUND","code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"mydomain","context":"cert_issue","subject":"mydomain","altnames":["mydomain"]}
    2021-02-21 21:21:38.025  - error: admin.0 (31084) [LE] {"length":0}
    2021-02-21 21:21:38.026  - error: admin.0 (31084) [LE] {"length":0}
    apollon77A UncleSamU 3 Antworten Letzte Antwort
    • T TechMo
      @apollon77
      apollon77A
      apollon77A
      @techmo sagte in js-controller 3.2 jetzt im STABLE!:
      mydomain.net
      really?? Ist das deine domain? Du scheinst Sie in der Konfig aber eingetragen zu haben ..
        mydomain.net
        T
        T
        TechMo
        @apollon77
        Nein ich habe die Domain im Log ersetzt.
        Wo sie ohne .net steht ist sie auch im Original ohne net.
        Bei den anderen eben mit.
        • T TechMo
          @apollon77
          apollon77A
          apollon77A
          @techmo Also es sieht an sich gut aus. Das Zertifikat wurde geholt. starte admin mal neu ( hätte eigentlich gedacht der Startet sich automatisch neu ... aber ok). Und durufst es danach EXAKT MIT DEM Domainnamen auch auf für den Du das Zertifikat geholt hast?
          • T TechMo
            @apollon77
            UncleSamU
            UncleSamU
            UncleSam
            @techmo Für mich scheint es, dass du Admin mit https://mydomain/ aufrufst anstatt mit https://mydomain.net/. Da greenlock den Domainnamen überprüft und damit das Zertifikat auswählt, wird das nicht funktionieren. Du musst die Admin-Seite exakt mit demselben Domainnamen aufrufen. Wenn du das lokal nicht kannst oder willst, dann verwende lokal eine zweite Admin Instanz ohne HTTPS.
            Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
            ♡-lichen Dank an meine Sponsoren
            • UncleSamU UncleSam
              T
              T
              TechMo
              @unclesam
              @apollon77
              Ja das habe ich bei dem Log auch gedacht, aber ich rufe immer genau die Domain auf, die auch als Domain eingetragen ist.
              Deswegen frage ich mich was da los ist.
              Safari auf dem iPhone sagt auch noch:
              Malformed HTTP Header: 'Host:mydomain.net:8081'
              Ging bis zur Umstellung mit dem alten js-Controller immer ohne Probleme.
              • T TechMo
                @unclesam
                @apollon77
                apollon77A
                apollon77A
                @techmo Na da haben wirs schon.
                Das "Neue "Letsencrypt unterstützt aktuell nur "Standard https", also Port 443
                  T
                  T
                  TechMo
                  @apollon77
                  Jap das ist es tatsächlich.
                  Steht das irgendwo?
                  8081 ist ja der StandardPort für Admin.0, deswegen läuft es bei mir dort.
                  Habs jezt geändert und es läuft wieder.
                  Vielen Dank.
                  • M
                    M
                    Michi68
                    schrieb am zuletzt editiert von Michi68
                    ich bekomme seit dem Update auf js-controller 3.2.16 ab und zu folgende Fehlermeldungen
                    2021-02-24 15:30:43.411 - error: host.iobroker-Server Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.json'
                    2021-02-24 16:00:36.149 - error: host.iobroker-Server Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, rename '/opt/iobroker/iobroker-data/objects.json' -> '/opt/iobroker/iobroker-data/objects.json.bak'
                    Backups der Datei werden aber gemacht
                    hatte das Update schon Freitag gemacht und auch diese Fehlermeldungen bekommen, hab es dann Gestern noch mal neu gemacht, ist aber immer noch das selbe mit denn Fehlermeldungen.
                    Aufgefallen ist mir das sich die Datei Attribute geändert haben von
                    objects.json.bak, objects.json, states.json.bak, states.json
                    unter js-controller 3.1.6 wahren die noch
                    Datei Attribute 674
                    -rw-rwxr--
                    und unter js-controller 3.2.16 sind die
                    Datei Attribute 664
                    -rw-rw-r--
                    habe dann nochmal iobroker fix ausgefürt, Datei Attribute wurden auch geändert
                    Datei Attribute 674
                    -rw-rwxr--
                    nach dem Start von iobroker haben sich die Datei Attribute aber wieder geändert
                    Datei Attribute 664
                    -rw-rw-r--
                    das hab ich dann auch mal getestet
                    pi@iobroker:~ $ cd /opt/iobroker/iobroker-data
                    pi@iobroker:/opt/iobroker/iobroker-data $ sudo chmod -v 674 objects.json
                    der Modus von 'objects.json' wurde von 0664 (rw-rw-r--) in 0674 (rw-rwxr--) geändert
                    pi@iobroker:/opt/iobroker/iobroker-data $ sudo chmod -v 674 objects.json.bak
                    der Modus von 'objects.json.bak' wurde von 0664 (rw-rw-r--) in 0674 (rw-rwxr--) geändert
                    pi@iobroker:/opt/iobroker/iobroker-data $ sudo chmod -v 674 states.json
                    der Modus von 'states.json' wurde von 0664 (rw-rw-r--) in 0674 (rw-rwxr--) geändert
                    pi@iobroker:/opt/iobroker/iobroker-data $ sudo chmod -v 674 states.json.bak
                    der Modus von 'states.json.bak' wurde von 0664 (rw-rw-r--) in 0674 (rw-rwxr--) geändert
                    nur ändern sich die Datei Attribute wieder wenn die Dateien sich ändern
                    und unter /opt/iobroker/iobroker-data/backup-objects haben sich die Datei Attribute auch geändert
                    Raspbeery 4
                    nodejs 12.20.2
                    node 12.20.2
                    npm 6.14.11
                    admin 4.2.1
                    javascript 4.8.4
                    Update habe ich wie folgt gemacht
                    cd /opt/iobroker
                    iobroker stop
                    ps auxww|grep io
                    iobroker update
                    iobroker upgrade self
                    iobroker fix
                    iobroker start
                    alles ohne Fehler
                    und nu hab ich keine idee mehr
                    Gruß Michael
                    Edit: log angehangen
                    log0.txt
                    • M Michi68
                      Datei Attribute 674
                      -rw-rwxr--
                      Datei Attribute 664
                      -rw-rw-r--
                      Datei Attribute 674
                      -rw-rwxr--
                      Datei Attribute 664
                      -rw-rw-r--
                      Raspbeery 4
                      nodejs 12.20.2
                      node 12.20.2
                      npm 6.14.11
                      admin 4.2.1
                      javascript 4.8.4
                      cd /opt/iobroker
                      iobroker stop
                      ps auxww|grep io
                      iobroker update
                      iobroker fix
                      iobroker start
                      alles ohne Fehler
                      Gruß Michael
                      log0.txt
                      Thomas BraunT
                      Thomas BraunT
                      @michi68 sagte in js-controller 3.2 jetzt im STABLE!:
                      .json
                      sind keine ausführbaren Dateien. Darüber hinaus sind die Dateien per ACL angelegt, dir fehlen also Informationen über die Attribute.
                      Jag da mal wieder den Fixer drüber.
                      iobroker fix
                        .json
                        iobroker fix
                        M
                        M
                        Michi68
                        iobroker fix gemacht
                        nach dem start dann wieder
                        2021-02-24 22:44:49.947 - error: host.iobroker-Server Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.json'
                        Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                        • M Michi68
                          Thomas BraunT
                          Thomas BraunT
                          @michi68
                          pi@raspberrypi:~ $ getfacl /opt/iobroker/iobroker-data/iobroker.json
                          getfacl: Entferne führende '/' von absoluten Pfadnamen
                          # file: opt/iobroker/iobroker-data/iobroker.json
                          # owner: iobroker
                          # group: iobroker
                          user::rw-
                          group::r--
                          group:iobroker:rwx
                          mask::rwx
                          other::r--
                          Gut, bei der Gruppe iobroker ruder ich zurück, iobroker hat das x-bit.
                          • M Michi68
                            apollon77A
                            apollon77A
                            @michi68 Ist das auf ner synology? Da gabs ja weiter oben ähnliche berichte ... ich weiss aber nicht was das issue sein soll ...
                            Das interessante ist auch das beim "nach dem Start"-Screenshot die objects.bak fehlt.
                            EDIT: Ok ich habs gefunden ... Der Fehler bedeutet (meeh unglücklich formuliert) erstmal nur das kein objects.json existiert und daher dieses auch nicht in "objects.json.bak" umbenannt werden kann. Es wird danach trotzdem das objects.json neu geschrieben . Beim nächsten Speichern sollte an sich dann wieder alles klappen und der Fehler nicht nochmals vorkommen.
                            Falls doch ist die Frage was da bei Dir passiert das das File verschwindet
                              M
                              M
                              Michi68
                              @apollon77
                              jo fehlt hatte ich auch noch nicht bemerkt, 😁 ist aber wieder da
                              ist Raspbian buster
                              • M
                                M
                                Michi68
                                ich hatte auch mal die objects.json, states.json gelöscht und aus denn .gz wiederhergestellt, geht.
                                Also Backups werden gemacht nur ab und zu meckert er das er die objects.json.bak nicht findet
                                dann kann ich die aber schon mal verstehen
                                  @marty56 Naja vor heute hast du den ioBroker ja die Tage auch neu gestartet. Und irgendwann danach ging das los. Frage ist wann das war und was da so im log Stand.
                                  M
                                  M
                                  Marty56
                                  @apollon77 Nach Neustart bisher nicht mehr aufgetreten
                                  HW:NUC (16 GB Ram)
                                  OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                                  • M Michi68
                                    apollon77A
                                    apollon77A
                                    #66
                                    @michi68 nee das ist es ja. Er meckert das keine objects.json da ist. Heißt davor hätte er die wegkopiert aber nicht neu geschrieben. Dann müsste von davor noch eine zweite/andere logzeile gewesen sein wo er sagt das er die objects.Jain nicht hat schreiben können. Sonst kann der Fall an sich nicht auftreten
                                      M
                                      M
                                      Michi68
                                      #67
                                      @apollon77
                                      sorry das ich jetzt erst antworte, war Heute etwas im Stress.
                                      Ja aber beim Start meckert er doch erst mal das die objects.json.bak nicht da ist und kopiert die objects.json die er dann in objects.json.bak umbennent oder sehe ich das falsch?
                                      und dann im Betrieb fehlt ab und zu die objects.json die er nicht zur objects.json.bak kopieren kann, ich bin verwirrt
                                      host.iobroker-Server	2021-02-25 22:00:59.000	error	Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.json'
                                      aber davon abgesehen hat er die Macke immer noch 🤔 😁
                                      • M Michi68
                                        @apollon77
                                        apollon77A
                                        apollon77A
                                        #68
                                        @michi68 Ne am Ende sind beide Fälle ein" ich finde objects.json nicht" ... ich blicks net
                                          Hallo ioBroker-Community,
                                          mit etwas zeitlicher Verspätung, dafür aber um so besser, kommt heute der neue js-controller 3.2 (Releasename "Grace") ins Stable Repository (sollte im laufe des Abends bei allen auftauchen). Ein großer Dank geht an alle User die in der letzten Zeit diese Version bereits im Beta- und Latest-Test getestet und Probleme und Fehler zur Behebung gemeldet haben!
                                          Node.js Versions-Anforderungen
                                          Die unterstützten Node.js Versionen bleiben in diesem Update gleich: 10.x, 12.x und auch 14.x werden offiziell unterstützt. Aufgrund der übergreifenden Adapter-Kompatibilität bleibt die empfohlene Node.js Version für ioBroker aktuell weiterhin auf 12.x. Falls jemand wirklich mit Node.js 15.x experimentieren will, dann bitte AUSSCHLIESSLICH mit npm 6 !! (die npm Leute haben in npm 7 wieder Dinge geändert, die wir noch untersuchen)
                                          Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/post/266625
                                          Informationen zur Version
                                          Neben einigen Features haben wir unter der Haube weiter aufgeräumt und sehr viel modernisiert und vereinheitlicht.
                                          Auch daran den Wildwuchs in der Umsetzung einiger Adapter etwas einzugrenzen wurde weiter gearbeitet, was ggf. zu neuen Log-Meldungen für bestimmte Fälle führt. Bitte unterstützt hier wieder und legt bei den relevanten Adaptern im GitHub Issues an, damit diese Dinge gefixt werden können.
                                          Besonders zu erwähnen ist die Grundlage für das neue Benachrichtigungssystem (kommt dann in einem Admin-Update) und die Reaktivierung von Let's Encrypt zur automatischen Zertifikatsaktualisierung.
                                          Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog. Ich hoffe auch diesmal auf Eure tatkräftige Unterstützung, sodass der Latest-Release dann genau so reibungslos verläuft wie bei den letzten Versionen.
                                          In Summe sind in diese Version über 750 commits eingeflossen. Dafür bedanke mich diesmal besonders bei foxriver76, AlCalzone und natürlich Bluefox und auch ein paar weiteren Entwicklern für die aktive Mitarbeit an dieser Version!
                                          Der js-controller 3.2 ist generell kompatibel mit allen bestehenden ioBroker-Systemen. Was es bei Multihost Systemen zu beachten gibt findet Ihr etwas weiter unten! Ein Update von der 2.0/2.1/2.2 ist problemlos möglich. Nur die Node.js Version muss jetzt mindestens 10.x sein, wie oben bereits ausgeführt. Wer überlegt die Node.js Version anzuheben bitte weiter unten im Abschnitt "Was ist zu testen" lesen 🙂
                                          Es gibt aktuell keine inkompatiblem Adapter, aber einige Empfehlungen weiter unten.
                                          Installation
                                          VOR der Installation
                                          Wie bei jedem Test dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt. Die alte Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version installiert werden und sollte alles wieder herstellen.
                                          Nötige Adapter-Aktualisierungen
                                          Aktuell sind keine Inkompatibilitäten bekannt, damit allerdings Let's encrypt wieder funktioniert benötigt es einige Adapter in "Latest" Versionen von mindestens:
                                          • ioBroker.lovelace 1.4.1 oder höher
                                          • ioBroker.simple-api 2.5.2 oder höher
                                          • ioBroker.socketio 3.1.3 oder höher
                                          • ioBroker.telegram 1.7.0 oder höher
                                          • ioBroker.web 3.2.2 oder höher
                                          • ioBroker.admin 4.2.1 oder höher
                                          Es werden aber, wie oben ausgeführt, einige Adapter ggf Warnungen ins Log schreiben. Falls das Problematisch ist ist aktuell die einzige Option das Loglevel der Instanz auf "Error" zu setzen.
                                          Achtung: Multihost-Systeme Reihenfolgen beachten!
                                          Bei einem Multi-Host-System, welches auf js-controller 2.2 oder 3.1 läuft ist es beim Update auf Version 3.2 nötig, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
                                          Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher auf die 3.2 müssen zwingend zuerst die Slaves und der Master als letztes aktualisiert werden. Beim Slave Update muss der alte master aber noch laufen. Die Slaves bleiben nach dem Update offline und können sich nicht zum Master verbinden und werden erst wieder funktionieren wenn auch der Master auf die 3.2 aktualisiert wurde!
                                          Windows
                                          Auf Systemen, die mit dem neuen Windows Installer eingerichtet wurden weiss ich gerade nicht wie der aktuelle Prozess ist, da der Windows Installer nicht ganz aktuell ist. Bitte hier berichten dann kann ich ergänzen.
                                          Für alle "alten manuellen" Installationen gilt
                                          • ioBroker muss gestoppt sein.
                                          • Vor dem Update bitte prüfen das keine Prozesse mehr laufen
                                          • iobroker update
                                          • iobroker upgrade self
                                          • ioBroker starten
                                          Linux
                                          • ioBroker stoppen (iobroker stop)
                                          • prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup ). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
                                          • iobroker update
                                          • Wie üblich wird das Update dann per iobroker upgrade self ausgeführt.
                                          • ioBroker starten (iobroker start)
                                          Bei Fehlern:
                                          Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x oder höher hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
                                          Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
                                          NACH der Installation
                                          Nach der Installation den ioBroker wieder starten (z.B. mittels iobroker start).
                                          Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
                                          Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
                                          Mit iobroker help wird eine Liste der möglichen Kommandozeilen-Kommandos angezeigt, die mit Version 2.0 um einige Befehle länger geworden ist. Es geht jetzt auch Kommandospezifisch Hilfe zu erhalten (iobroker upgrade --help)
                                          Was hat sich geändert, was besonders ansehen/beachten?
                                          Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
                                          • generell siehe Changelog, speziell auch für Features
                                          • Let's Encrypt sollte wieder tun. Minimum Adapterversionen dazu siehe weiter oben!
                                          • Einige Adapter werden Warnungen ausgeben wenn State-Werte gesetzt werden VOR dem Anlegen von Objekten. Bitte bei den Adapter-Repos melden
                                          Speziell die Entwickler sollten bitte die genannten Deprecations anschauen und beachten
                                          Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
                                          BREAKING CHANGES
                                          • None, Supported are nodejs 10.x, 12.x and 14.x (Node.js 15.x is also working WHEN USED WITH npm 6!! in the automated tests, but formally not supported)
                                          • If you have enabled Multihost Discovery please disable and enable it again if you really need it persistent running. By re-enabling it you update the used passphrase with a better encryption mechanism.
                                          • (Foxriver76) Harmonize username handling between admin and js-controller by transforming the object id to lowercase. With this user names will be treated case insensitive from now on!
                                          Features
                                          • (raintonr) Update Let's encrypt implementation; all relevent adapters (web and such) need updates to use it! NEEDS NODE.JS 12.x+! (see DOCS LINK TODO)
                                          • (bluefox) Restart adapters that use Let's encrypt after certificates were updated
                                          • (bluefox) Provide min/max for convert alias functions
                                          • (foxriver76) handling major adapter upgrades more carefully (CLI on upgrade will show if it's a major upgrade and major upgrades will be skipped on upgrade all when executed by admin
                                          • (AlCalzone) detect and allow short github URL format when (auto-)installing adapters (iobroker url User/repo#branchorcommit)
                                          • (AlCalzone) Support more Github URL formats for iobroker url command
                                          • (AlCalzone) support github branch names with slashes on adapter install
                                          • (foxriber76) Add notification system (see DOCS LINK TODO)
                                          • (foxriver76) enhance setup (and setup first) with redis to all port configuration
                                          • (foxriver76) set connectionName for redis connections and simulator support
                                          • (bluefox) Added "http" and "stream" options for logs
                                          • (Apollon77) add seq logging support to js-controller
                                          • (foxriver76) Fix wrong logger pattern that caused issues on windows
                                          • (Apollon77) fix potential crash when restoring backup
                                          • (Apollon77) restore old logfile deletion logic because rotator library do not work as expected
                                          • (Apollon77) Optimize File DBs to lower write i/o by 50% (backup file is now renamed instead of rewritten)
                                          • (AlCalzone/Apollon77) Restructure DB code to allow easier new DB types
                                          • (Apollon77) enhance letsencrypt to also allow to specify alternative names for certs
                                          Optimizations and Fixes
                                          • (foxriver76) Detect adapter restart loops and stop restarting after 3 crashes (an adapter is considered "working" when no crash by an exception happens within 10 minutes)
                                          • (foxriver76) Fix failed logins if username is uppercase, be reworking user logic and caching
                                          • (bluefox) Set for def states the quality: QUALITY_SUBS_INITIAL
                                          • (AlCalzone) fix npm uninstall loglevel argument
                                          • (foxriver76) delete pids.txt when iobroker was stopped
                                          • (bluefox) Add missing attributes by multihost if Redis is used for objects/states, Remove unused settings from iobroker-dist.json, Remove pass and user from connection settings. Use options.auth_pass
                                          • (AlCalzone) Package-Manager: log which packages were (already) installed
                                          • (foxriver76) replace redis "KEYS" command by "SCAN" to optimize redis access performance
                                          • (foxriver76) optimize redis library usage to prevent errors on redis outages
                                          • (bluefox) Catch errors when plugins initialize. At least log will work and could be checked for errors.
                                          • (foxriver76) allow migration of instances to already existing host
                                          • (foxriver76) also allow <adapter>.<instance-nr> for install/add cli command
                                          • (AlCalzone) buffer streams that are piped to stdout to fix weird Windows logging cases
                                          • (foxriver76/AlCalzone) Optimize upgrade/downgrade logic for adapters, ask for a downgrade only if lower version is to be installed
                                          • (foxriver76) allow redis redis migration when changing host of redis - fix bug where process crashes when controller is running when migrating
                                          • (bluefox) Catch errors for subscribe on alias without target
                                          • (foxriver76) only perform auto scaling on alias if not null
                                          • (foxriver76) if repository request fails also use cached sources on updating repository
                                          • (foxriver76) prevent host deletion from same host - otherwise it will remove the system.host states but instances will still be on the removed host, because transfer happens to itself
                                          • (foxriver76) use instanceObjects from system.adapter.* object instead from io-package.json
                                          • (foxriver76) notify of errors on readFileCertificates to show permission problems etc.
                                          • (foxriver76) multihost discovery now logs ignored messages on debug and also logs the senders address
                                          • (foxriver76) sync up created objects on instance start and instance creation by using helper function in tools.js, e.g. .loglevel was missing on instance creation
                                          • (bluefox) Package-Manager: Filter empty packets out to suppress error message
                                          • (foxriver76) rename repository names for new installations and on updates to beta/stable
                                          • (foxriver76) rewrite collectDiagInfo to Promises and fix minor issue with it
                                          • (foxriver76) only scale aliases if target or source is represented by unit %
                                          • (foxriver76) create meta.user on file sync cli, if not existing
                                          • (Apollon77) also create meta.user on setup first if not existing
                                          • (foxriver76) fix enumInstances used by CLI commands
                                          • (foxriver76) when missing rights to access log dir do not crash hard anymore, instead fallback to default directory
                                          • (bluefox) Fix error if type of native data changed in the new version from basic type e.g. 'string' to 'object'.
                                          • (AlCalzone) Remove hardcoded references to GitHub master branch because newer repositories use "main"
                                          • (Apollon77) update _design objects also on js-controller upgrade/setup first
                                          • (Apollon77) optimize deletion of files in ioBroker file storage
                                          • (foxriver76) do not return an error if object does not exist on del*Object
                                          • (Apollon77) optimize logs when instance is restarted
                                          • (foxriver76) Preserve name field on instance object creation/update
                                          • (foxriver76) optimize parameters and flags on CLI
                                          • (foxriver76) Use yargs helper instead of building our own string output to allow showing --help for a specific command instead of the whole output and allow support for auto completion (iobroker _createCompletion >> ~/.bashrc)
                                          • (foxriver76, Apollon77) also accept pre-release version in some semver checks for dependencies
                                          • (foxriver76) replace outdated encryption mechanism of multihost
                                          • (Apollon77) prevent an endless loop when lua script initialization was not possible
                                          • (Apollon77) catch semver errors in upgrade commands
                                          • (foxriver76) ensure setAdapterInstanceEnabled can not hang
                                          • (Apollon77, foxriver, bluefox, AlCalzone) Several fixes and refactorings to prevent potential crash cases reported by Sentry and other sources
                                          Developer relevant DEPRECATIONS/WARNINGS
                                          • (foxriver76) we warn if object not exists when setting a state via adapter.setState. Adjust your code that a state value is NOT set before the object is successfully created. If this deep check is NOT wanted for performance reasons the adapter needs to be initialized with strictObjectChecks = false!! (see DOCS LINK TODO)
                                          • (foxriver76) readFile should not validate meta object, we now throw on writeFile if id is no valid meta object
                                          • (AlCalzone) update Forbidden ID Characters: use Unicode properties to define which characters are allowed instead of blacklisting. For ASCII the allowed characters are the same as before - for other languages mainly character class of Unicode are allowed! (see DOCS LINK TODO)
                                          • (foxriver76) Throw on invalid setState objects; was logged as deprecated before
                                          • (foxriver76) remove getMessage shim, no adapter uses it anymore; was logged as deprecated before
                                          Developer relevant new Features
                                          • (foxriver76) use aes-192-cbc as encryption - backward compatible with current encryption, nothing to do for adapter-developers (see DOCS LINK TODO)
                                          • (bluefox) Add system view to filter for "folder" objects
                                          • (bluefox) add set/clearTimeout and set/clearInterval to adapter methods and check on unload that they were all cleared and clear if needed with logging, so developers are reminded to clean up!
                                          • (AlCalzone) Add ...Async version for getChannels - make sure to check before using or use correct js-controller version dependency!
                                          • (Apollon77) modularize databases into own npm packages and basically support adding new types of databases; add deprecation infos and logging to "old legacy" files in lib/states and lib/objects to not be used anymore; requires mostly updates in testing (see DOCS LINK TODO)
                                          • (foxriver76) allow to specify the instance for debug starts (iobroker debug adaptername.1)
                                          • (foxriver76) Enhance extendObject to allow to preserve specified fields (e.g. common.name)
                                          • (foxriver76) add adapter method getUserId
                                          Developer relevant Optimizations and Fixes
                                          • (foxriver76) implement maybeCallback and maybeCallbackWithError and use it in adapter.js
                                          • (AlCalzone) use fs-extra instead of mkdirp
                                          • (AlCalzone) read JSON files using fs-extra's readJSONSync
                                          • (AlCalzone) fix callback definitions in adapter.js, We have signatures for (almost) everything in @types/iobroker and we should use them
                                          • (AlCalzone) move from Promises to async/await in some places, use a single readyPromise instead of an array
                                          • (foxriver76) migrated ci tests to github actions
                                          • (foxriver76) resolve adapter main file as tools.js method
                                          • (foxriver76) optimize extendObject with def value
                                          • (AlCalzone) Handle existing, but undefined properties in validateSetStateObjectArgument
                                          • (foxriver76) also escape + char on regex, it's not forbidden
                                          • (bluefox) Set default state only for objects of type "state"
                                          • (AlCalzone) include folders in the result of getAdapterObjects
                                          • (Apollon77) Make sure to not trigger subscribes or messages when unload is called
                                          • (Apollon77) deleting a not existing object is handled as success instead of Not-Exists error
                                          • general dependency updates
                                          • code style optimizations
                                          Generell ist zu prüfen, ob alles noch so funktioniert wie vorher auch. Das ist das wichtigste!
                                          Wie Fehler melden?
                                          Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
                                          Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
                                          Wir wünschen allen viel Spaß beim Testen und vielen Dank für Eure Unterstützung!
                                          Ingo
                                          K
                                          K
                                          klassisch
                                          #69
                                          @apollon77 sagte in js-controller 3.2 jetzt im STABLE!:
                                          Windows
                                          • iobroker update
                                          • ioBroker starten
                                          @sigi234 hat mich ermutigt es genau so wie oben beschrieben zu tun und auch bei mir hat es so funktioniert. Mein Win-System wurde mit dem Installer von @Stabilostick aufgesetzt und mit dem Workaround von @AlCalzone upgedatet.
                                          Bin jetzt auf js-controller 3.2.16, node-js v10.17.0, npm v6.11.3 und soweit scheint alles zu funktionieren.
                                          Q 1 Antwort Letzte Antwort
                                          83.9k
