  4. Test Adapter HeatingControl v3.xx
heating
3.3k Beiträge 239 Kommentatoren 2.6m Aufrufe 201 Beobachtet
  • Rene_HMR Rene_HM
    @michi_pi hast du mal geschaut, ob der log
    checking reduced temp with Profiles.1.Raum.absolute.WindowOpenDecrease
    bei den anderen Räumen bei dir kommt, wenn du dort das Fenster öffnest?
    M
    M
    Michi_Pi
    #2184
    @rene_hm Hab ich jetzt nicht direkt gefunden.
    Das steht hier
    2021-02-19 21:18:57.145 - debug: heatingcontrol.0 (3654) Wohnzimmer ### ChangeStatus Thermostats_Target to {"val":12,"ack":true,"ts":1613765937101,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1613765937101} in auto
    2021-02-19 21:18:57.145 - debug: heatingcontrol.0 (3654) Change Status target temperature in Wohnzimmer to 12 (profile 22) in auto
    2021-02-19 21:18:57.145 - debug: heatingcontrol.0 (3654) CheckManualMode Wohnzimmer
    2021-02-19 21:18:57.146 - debug: heatingcontrol.0 (3654) temperature from thermostat while window is open Wohnzimmer with 12
    2021-02-19 21:18:57.146 - debug: heatingcontrol.0 (3654) HandleActors for Wohnzimmer auto
    2021-02-19 21:18:57.146 - debug: heatingcontrol.0 (3654) UpdateDPs for Wohnzimmer auto
    2021-02-19 21:18:57.215 - debug: heatingcontrol.0 (3654) ### handle state change acked hm-rpc.1.00201A4996D42E.1.ACTUAL_TEMPERATURE {"val":21.6,"ack":true,"ts":1613765937104,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1613760093410}
    2021-02-19 21:18:57.216 - debug: heatingcontrol.0 (3654) HandleStateChangeDevices hm-rpc.1.00201A4996D42E.1.ACTUAL_TEMPERATURE
    2021-02-19 21:18:57.216 - debug: heatingcontrol.0 (3654) CheckStateChangeDevice hm-rpc.1.00201A4996D42E.1.ACTUAL_TEMPERATURE
    2021-02-19 21:18:57.216 - debug: heatingcontrol.0 (3654) ChangeStatus called, while already changing, push to list Wohnzimmer Thermostats_Current {"val":21.6,"ack":true,"ts":1613765937104,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1613760093410} (1)
    2021-02-19 21:18:57.408 - debug: heatingcontrol.0 (3654) ### handle state change !ack heatingcontrol.0.Rooms.Wohnzimmer.CurrentTimePeriod {"val":3,"ack":false,"ts":1613765937399,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1613764740732}
    2021-02-19 21:18:57.408 - debug: heatingcontrol.0 (3654) HandleStateChanges CurrentTimePeriod 3
    2021-02-19 21:18:57.492 - debug: heatingcontrol.0 (3654) ### handle state change !ack heatingcontrol.0.Rooms.Wohnzimmer.StatusLog {"val":" 19.02.2021 21:18:57 auto WindowOpen 12°C
    19.02.2021 20:59:02 auto 21.5°C
    19.02.2021 20:58:53 starting 20.5°C
    19.02.2021 20:58:51 starting
    ","ack":false,"ts":1613765937483,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1613765937483}
    Rene_HMR 1 Antwort Letzte Antwort
    • M Michi_Pi
      Das steht hier
      Rene_HMR
      Rene_HMR
      Rene_HM
      #2185
      @michi_pi sagte in Test Adapter HeatingControl v2.2.x:
      Das sieht mir eher danach aus, als ob das Thermostat selbst die Absenkung macht und nicht der Adapter...
      • Rene_HMR Rene_HM
        M
        M
        Michi_Pi
        #2186
        @rene_hm Jetzt hab ich den Fehler gefunden. Die Sensoren waren irgendwie noch nicht komplett entkoppelt. Bei den Geräten selbst habe ich keine Verknüpfung nicht mehr gesehen. nur bei den direkten Verknüpfungen in der CCU war nach am Sensor selbst ein Verbindung zum Regler, jedoch nicht umgekehrt. Komisch da ich eigentlich alle auf Werksreset damals gesetzt hatte.
        Als ich die gelöscht habe, hatte es zwar noch nicht funktioniert. Grund war dass ich unter Thermostateinstellungen "Thermostat behandelt Fenster offen" aktiviert habe. Diese Option deaktivert und jetzt geht es in jedem Zimmer. :D
        • Rene_HMR Rene_HM
          @laola
          @pittini sagte in Test Adapter HeatingControl v2.2.x:
          Und zwar dass sich die Offsets addieren, also jede Periode wird neu gerechnet und oben drauf geschlagen. Das würde die hohen Werte erklären. Ob das so sein kann weist Du aber am besten, is nur ne Idee.
          naja, addieren findet zwar statt, aber nur um Mittelwerte zu bilden. und das ist unabhängig von den Perioden. Jeder Wert vom zusätzlichen Sensor führt zu einer weiteren Mittelwert-Berechnung der Differenz zwischen zusätzlichem Sensor und Sensor am Thermostat.
          Ihr könnt euch das im log anschauen (hier als Beispiel)
          calculate temp offset for Arbeitszimmer old value is -3, got value "val":18.1,"ack":true,"ts":1612719101378,"q":0,"from": ...}
          got 21.5 from xyz
          tempdiff: 18.1 - 21.5 = -3.3999999999999986
          TempOffset Arbeitszimmer
          (avg) Ist-Temperatur am Thermostat 21.5
          Ist-Temperatur am zusätzl. Sensor 18.1
          tempDiff -3.3999999999999986
          (avg) TempOffset -3
          new temp offset for Arbeitszimmer is -3
          Damit müsstet ihr auch nachvollziehen können, wie euer Offset zustande kommt. Aus meiner Sicht kommen die Offsets zustande, weil die Differenz zwischen den Sensoren stark schwankt. Könnte ein geöffnetes Fenster dazu führen, dass die Differenz ansteigt?
          Im Moment sehe ich wenig Möglichkeiten, wie ich das Verhalten beeinflussen kann...
          L
          L
          Lanki1302
          #2187
          @rene_hm said in Test Adapter HeatingControl v2.2.x:
          @laola
          got 21.5 from xyz
          (avg) TempOffset -3
          Ich habe auch das Problem, dass eine Heizung permanent auf 25 ° Hochheizen möchte obwohl der sollwert auf 20° steht.
          Das Problem könnte vllt ein ganz anderes sein. Wenn man das mal durchspielt:
          Der Adapter regelt die Heizung von 17 auf 20° (wegen neuer periode) und die ist-temp steht auf 17° bei einem offset von 0
          Dementsprechend erhöht sich jetzt zuerst die Temperatur am thermostat. Nehmen wir mal an auf 20°. Das ventil schließt irgendwann und der offset verändert sich jetzt auf -3: der Adapter regelt das thermostat runter.
          Dann erhöht sich irgendwann die Temperatur am externen sensor. Er klettert von 17° auf 20.5°.
          Die ist temp am Thermostat ist jetzt wieder etwas gefallen auf 19°. Neuer offset: 19 - 20.5 = -1.5
          Das Thermostat wird auf 18.5° (20° soll - 1.5 offset) eingestellt.
          Jetzt aus meiner Sicht das problem: wenn die ist temp am Thermostat über diese 20° vom externen Sensor geht bekommt der offset ein positiven Wert. Dieser wird auf den 20° sollWert hinzuaddiert, so dass der Adapter das Thermostat hochregeln wird.
          Wenn jetzt der ist Wert vom externen Sensor weiter abfällt (weil die Wärme bis zum Sensor etwas braucht)wird der offset noch größer. Irgendwann ist die spanne zwischen ist Wert vom Thermostat und dem externen Sensor so hoch das er den offset nicht mehr runtergeregelt bekommt.
          Ich hoffe ich habe es für alle verständlich rübergebracht und jeder kann es nachvollziehen.
          Vielleicht irre ich mich ja auch....
          Gruß Lanki1302
          • E Elluminatus
            @Rene_HM Nach einiger Recherche habe ich leider herausgefunden, dass der FAL230 eine spezielle Anbindung an ein Homematic Thermostat benötigt. Somit kann der FAL230 NICHT aber den state angesprochen werden, bedeutet wenn Ihr vor habt diesen Adapter einzusetzen, nehmt einfach normale Relais und spart noch einiges an Geld!
            Update: Es gibt zwei DIY Lösungen:
            Es gibt für thermische Ventile eine DIY Lösung auf Tasmota Basis: 10ch thermisches Ventil Stellboard für FBH mit Tasmota
            und sogar eine Lösung für motorische Ventile: DIY Lösung für motorische Stellantriebe bei der FBH
            koelleforniaK
            koelleforniaK
            koellefornia
            #2188
            @elluminatus said in Test Adapter HeatingControl v2.2.x:
            @Rene_HM Nach einiger Recherche habe ich leider herausgefunden, dass der FAL230 eine spezielle Anbindung an ein Homematic Thermostat benötigt. Somit kann der FAL230 NICHT aber den state angesprochen werden, bedeutet wenn Ihr vor habt diesen Adapter einzusetzen, nehmt einfach normale Relais und spart noch einiges an Geld! Rene, macht es vllt Sinn solche Erkenntnisse auch mit in Github in die Beschreibung zu schreiben?
            Hallo, gibt's da keine Lösung? Wollte den Fal230-6 über die Aqara Thermometer steuern.
            Gruß K
            Rene_HMR E 2 Antworten Letzte Antwort
            • koelleforniaK koellefornia
              Gruß K
              Rene_HMR
              Rene_HMR
              Rene_HM
              #2189
              @koellefornia sagte in Test Adapter HeatingControl v2.2.x:
              Aus meiner Sicht ist das eher eine Frage an den hm-rpc-Adapter, oder alternativ ein Adapterrequest, um die Teile einzubinden..
              • L Lanki1302
                @laola
                got 21.5 from xyz
                (avg) TempOffset -3
                Gruß Lanki1302
                Rene_HMR
                Rene_HMR
                Rene_HM
                #2190
                @Pittini @laola @Denkra @lanki1302 ja, das ist soweit richtig, was die Berechnung des Offset betrifft.
                ABER: der Offset wird nur bei Periodenwechsel auf die Soll-Temperatur addiert. In deinem Fall (offset =0 bei erster Periode) würde sich der offset im Laufe der ersten Periode einschwingen und erst am Ende der Periode auf die nächste Periode auswirken. Damit sollte die große Differenz am Anfang keinen großen Anteil am Mittelwert der Differenz über die Zeit haben...
                Villeicht kann ja einer, der das Feature nutzt, mal eine Aufzeichnung mit history und eine Dartsellung mit flot charts machen, so dass wir den Verlauf von
                • Ist-Temperatur am Thermostat
                • Ist-Temperatur am zusätzlichen Sensor
                • Offset
                • Soll-Temperatur
                sehen.
                Ich kann das hier nur simulieren, da ich hier nur Wandthermostate verbaut habe...
                • Rene_HMR Rene_HM
                  • Offset
                  • Soll-Temperatur
                  sehen.
                  A
                  A
                  And-Sh_Sa
                  #2191
                  Hallo, ich habe mal, wo es so kalt war, die Differenz zwischen Thermostat Sensor und dem Raumsensor aufgezeichnet.
                  Ich habe Aquara Raumsensoren und comet Dect Thermostate. Beim Aufheizen ist der unterschied sehr hoch. Habe schon in der fritzbox einen offset von 1,0 °C eingetragen. Habe es früher, bevor ich HeatingControl nutzte, es per script alle 10 min. ausgeglichen. Die comet sendet und empfängt alle 5-10 min neue Werte.
                  Habe deine Offset getestet und die Werte gehen dabei über den ganzen Zeitraum (bei mir) auf 25° wegen den anfänglichen hohen unterschied von teilweise(ohne Fritzbox offset) von 3° bis 4°.
                  • A And-Sh_Sa
                    Rene_HMR
                    Rene_HMR
                    Rene_HM
                    #2192
                    @and-sh_sa ich schaue mal, ob ich die Mittelwert-Berechnung optimieren kann. Eine einzelne große Abweichung sollte eigentlich keinen so großen Einfluß auf den Mittelwert der Differenz (und damit den Offset) haben...
                    • Rene_HMR Rene_HM
                      inspiriert vom Heizungsthermostat-Script und weil meine homeputer-Lizenz abgelaufen ist, und ich meine Heizungssteuerung von dort nach iobroker portieren wollte, ist der Adapter HeatingControl entstanden.
                      Features:
                      • setzen der Zieltemperatur in verschiedenen Thermostaten
                      • beliebige Anzahl von täglichen Zeitabschnitten mit unterschiedlichen Zieltemperaturen
                      • Zeit und Zieltemperatur per Visualisierung konfigurierbar
                      • automatische Suche nach vorhandenen Thermostaten im System (über Gewerk) und Zuordnung zu Räumen
                      • Für den Fall, dass der Thermostat nur als Thermometer verwendet wird, behandelt der Adapter auch digitale Outputs zum Schalten der Ventile. Im Moment ist dafür nur eine einfache Ein/Aus-Regelung implementiert (die für meine Zwecke ausreichend ist). Weitere Regelungen sind aber als Idee bereits vorhanden und können implementiert werden. Es gibt nun auch einen linearen on/off mit Hysterese
                      • es werden bis zu zwei Outputs für Ventile unterstützt
                      • Outputs werden auch automatisch den Räumen zugeordnet. Dafür müssen diese dem gleichen Gewerk wie Thermostate zugeordnet sein.
                      • im Admin des Adapters können Räume deaktiviert werden
                      • Absenkung bei Abwesenheit
                      • Ventile ein oder aus außerhalb der Heizperiode
                      • Verbindung zu ical
                      • Verbindung zu Feiertags-Adapter
                      • Senden von Nachrichten per email, Signal, Telegram, discord, ...
                      • Kamin-Modus
                      • Wartungsmodus
                      • mehrere Profile
                      • Tages-Programme für
                        - Montag - Sonntag
                        - Montag - Freitag + Samstag - Samstag
                        - jeden Tag separat
                      Versionen:
                      • 3.0.0
                        Status: beta seit 29.12.2025
                        NPM: ja
                        github: ja
                        weitere Informationen: github
                      • 2.12.19
                        Status: stable seit 26.10.2025
                        NPM: ja
                        github: ja
                      CKMartensC
                      CKMartensC
                      CKMartens
                      #2193
                      @Rene_HM
                      Ich hatte einen Vorschlag für eine Erweiterung in der Funktion des Temperatur Override. Wäre es möglich eine Funktion einzubauen, das der Temperatur Override nicht nur zeitgesteuert werden kann, sondern auch bis zur nächsten planmäßigen Änderung, die im Profil eingestellt ist?
                      Ein Enhancement-Issue dazu habe ich auf Github dazu mal erstellt.
                      • J Ja.rod
                        @dominik-f Warum ist dann der "State" im "Kinderzimmer 1" auf "manuel"? Wobei mir eigentlich wichtiger ist wie ich ihn wieder auf "Auto" bekomme. Heatingcontrol nutze ich schon länger, habe es nur neu aufgesetzt und nachdem im Wohnzimmer alles geklappt hat, habe ich die anderen Räume nicht kontrolliert.
                        kBrausewK
                        kBrausewK
                        kBrausew
                        #2194
                        @ja-rod
                        Habe hier auch immer Status manual...
                        Bin mir aber absolut sicher das niemand am Thermostat rumdreht...
                        Und zwar habe ich regelmäßig bei einer Absenkung auf 15C bleibt er auf 17C manuell
                        Gibt es noch einen anderen Grund für "manual"
                        Pi 4/8GB + SSD + Docker \ DebMatic HM-IP + HM-RF \ ioBroker
                        HikVision InterCom \ tedee SmartLook
                        Wiegand - TCP/IP Door Access Controller \ MF-549 Fingerprint/Code/RFID \ FP100 Fingerprint/Code
                        Fritz 7590 (ohne SmartHome)
                        • kBrausewK kBrausew
                          @ja-rod
                          Rene_HMR
                          Rene_HMR
                          Rene_HM
                          #2195
                          @kbrausew was hast du für Thermostate? kümmern sich deine Thermostate selbst um die Absenkung, wenn ein Fenster offen ist?
                          kBrausewK 1 Antwort Letzte Antwort
                          • Rene_HMR Rene_HM
                            kBrausewK
                            kBrausewK
                            kBrausew
                            schrieb am zuletzt editiert von kBrausew
                            #2196
                            @rene_hm
                            Ich habe den HMIP eTRV (glaube sogar eTRV2, wenn's sowas überhaupt gibt)
                            Ich habe mal im HeatingControler angegeben das der Thermostat Fenster-auf nicht selber handelt,
                            hierzu habe ich zwei separate TFK an Tür und Fenster, diese sind im HC-Adapter im Raum auch hinterlegt.
                            In der CCU gibt es keine Programme und auch keine Direkt-vk's
                              @rene_hm
                              Dominik F.D
                              Dominik F.D
                              Dominik F.
                              #2197
                              @kbrausew
                              Hast du eventuell die Thermostate noch auf Auto stehen von HM? Dann greift der auf die Profile in der CCU zu, was bedeutet das er sich selber verstellt und HC erkennt das als manuel
                              • Dominik F.D Dominik F.
                                @kbrausew
                                kBrausewK
                                kBrausewK
                                kBrausew
                                #2198
                                @dominik-f
                                Jap; war noch auf AUTO
                                Hab's mal umgestellt und Teste...
                                DANKE
                                BTW: Hab mal die restlichen Einstellungen attached
                                  @dominik-f
                                  DANKE
                                  Rene_HMR
                                  Rene_HMR
                                  Rene_HM
                                  #2199
                                  @kbrausew und stelle sicher, dass dein Thermostat wirklich nicht selbständig auf "Fenster offen" reagiert. Das kannst du ja austesten, indem du den Adapter stoppst und das Fenster öffnest. Dabei darf das Thermostat die Temperatur nicht absenken. Wenn das Thermostat die Temperatur doch absenkt, musst du die Option "Thermostat behandelt Fenster offen selbst" aktivieren, um zu verhindern, dass die Absenkung als manueller Eingriff gewertet wird...
                                  Alternativ: schalte das Verhalten bzgl. Übernahme der Temperatur vom Thermostat komplett aus, wenn du das nicht brauchst...
                                  Z 1 Antwort Letzte Antwort
                                  • T
                                    T
                                    thec64
                                    #2200
                                    Hallo, besteht die möglichkeit, einzelnen Räumen/Wohnungen verschiedene Profile zuzuweisen? 1. Raum Profil 1 - 2 Raum Profil 3 - 3 Raum Profil 1 usw.?
                                    Ich möchte mit dem Apartmer 2-3 Wohnungen mit mehreren Zimmern steuern und diese dann per Profiländerung verschiedene Temperaturen zuzuweisen.
                                    • T thec64
                                      Rene_HMR
                                      Rene_HMR
                                      Rene_HM
                                      #2201
                                      @thec64 nein, das geht nur über mehrere Instanzen des Adapters...
                                      • moppel2810M
                                        moppel2810M
                                        moppel2810
                                        #2202
                                        Hallo, kann mir jemand sagen wo ich den Raumstatus herbekomm? Den zeigt es bei mir nicht an.
                                        • moppel2810M moppel2810
                                          Rene_HMR
                                          Rene_HMR
                                          Rene_HM
                                          #2203
                                          moppel2810M 2 Antworten Letzte Antwort
