7.6k Beiträge 296 Kommentatoren 9.0m Aufrufe 201 Beobachtet
  • s.bormannS
    s.bormannS
    s.bormann
    #4855
    1.6.0
    • (sbormann) Changed standard badge-color to red, 20% transparency.
    • (sbormann) Added optional glow-effect for tiles.
    • (sbormann) Fixed edit-dialog of device not opening under some circumstances.
    • (sbormann) Added type icon and type datapoint to widget-url-parameters.
    • (sbormann) Added OVERLAY_INACTIVE_COLOR and OVERLAY_ACTIVE_COLOR.
    • (sbormann) Added option to show badge value without unit.
    • (sbormann) Badge has now a maximum-width and uses marquee-effect.
    • (sbormann) Added toggle by icon for garage door (after optional confirmation).
    • (sbormann) Fixed not to open Dialog if clickOnTileOpensDialog is set to false.
    • (sbormann) Added new device: Info-Text, which can be used to display plain Text on views, therefore some new options were created (stateHeightAdaptsContent, stateFillsDevice, stateBigFont).
    • (sbormann) Text on transparent tiles is now white (can be configured).
    • (sbormann) When converting to bool, "off" is interpreted as false now.
    • (sbormann) Added option to center device name and/or state.
    • (sbormann) Fixed option font-size for sub-header.
    • (sbormann) Moved option, to show toolbar in one single line, into the options-tab.
    • (sbormann) Added option, to invert Error Icon.
    • (sbormann) Rearranged device option for a better overview.
    • (sbormann) Added option noZoomOnHover for Icon (in device-options, section tile-behaviour (general) and, for all devices, in settings, section tile).
    • (sbormann) Added delay to visibility of badge to allow color-change happen before it appears.
    • (sbormann) Fixed min/max/step for number of url-parameters of widgets (which fixed range for FLOT-Chart).
    • (sbormann) Added PANEL_HIDE and the corresponding option Invert PANEL_HIDE to panel.
    • (sbormann) Added manifest.json.
    • (sbormann) Fixed saving values of color-picker.
    • s.bormannS s.bormann
      1.6.0
      dslraserD
      dslraserD
      dslraser
      #4856
      @s-bormann
      unten im Bildschirm ist jetzt nach dem Update auf 1.6.0 wieder kein Abstand mehr da, hast Du daran auch was verändert ? Gibt es eine Einstellung dafür ?
      Ich habe bei mir keine Einstellungen verändert...
      Ich kann nicht ganz runter scrollen, egal auf welcher Seite...?
      Auf meiner Startseite fehlt die ganze untere Reihe mit 0,5 × 0,5 bzw. ist nicht sichtbar/bedienbar.
      Edit: mit gesetzten Haken geht es, aber das war vorher nicht so und der Handybildschrim wird so nicht ganz ausgenutzt (auf der rechten Seite)
      s.bormannS 2 Antworten Letzte Antwort
      • dslraserD dslraser
        @s-bormann
        s.bormannS
        s.bormannS
        s.bormann
        #4857
        @dslraser sagte in Test Adapter iQontrol 1.6.x Vis:
        @s-bormann
        hattest Du die letzten Github-Updates ausprobiert? Welches Endgerät ist betroffen?
        Kann mir höchstens vorstellen, dass es was mit der manifest.json zu tun hat, was ja erst in den letzten Tagen hinzukam. Hier hatte ich aber bislang zumindest keine negativen Rückmeldungen erhalten.
          @s-bormann
          dslraserD
          dslraserD
          dslraser
          #4858
          @s-bormann sagte in Test Adapter iQontrol 1.6.x Vis:
          Nein, hatte ich bisher nicht probiert.
          Samsung Note10+5G
          Edit: mit dem Haken drinn
          (rechts ist nun etwas Platz. Zum scrollen mit dem Daumen gar nicht so schlecht🙃)
          Aber wie gesagt, vorher ging es ohne den Haken.
            Samsung Note10+5G
            s.bormannS
            s.bormannS
            s.bormann
            #4859
            Samsung Note10+5G
            Im Simulator geht es:
            Ich nehme an, Du hast das ganze auf dem Homescreen, oder? Geht es im Browser direkt?
              Samsung Note10+5G
              dslraserD
              dslraserD
              dslraser
              #4860
              @s-bormann
              Ich habe ne Verknüpfung auf dem Homescreen, über diese öffne ich. Direkt im Browser habe ich nicht probiert. Damit öffne ich iQontrol.
                @s-bormann
                s.bormannS
                s.bormannS
                s.bormann
                #4861
                @s-bormann
                Bitte installiere mal diese Version (Unter Adapter auf das Github-(Katzen)-Icon, dann auf beliebig und dann diese URL eingeben: https://github.com/sbormann/ioBroker.iqontrol/tarball/1f4458036d83fafadcffeaeff6350087ba0e33f9
                Das ist die letzte Version, bevor das manifest.json eingefügt wurde.
                Geht es damit wieder normal?
                Ggf. muss man die Verknüpfung auf dem Homescreen neu anlegen.
                Danke Dir.
                  Samsung Note10+5G
                  dslraserD
                  dslraserD
                  dslraser
                  #4862
                  Direkt im Browser funktioniert es.
                  (aber sobald ich über das Verknüpfungsicon starte geht es nicht---Chrome)
                    @s-bormann
                    Danke Dir.
                    dslraserD
                    dslraserD
                    dslraser
                    #4863
                    Habe ich gerade probiert, ging auch mit einer neuen Vernküpfung nicht
                      @s-bormann
                      Danke Dir.
                      dslraserD
                      dslraserD
                      dslraser
                      #4864
                      Das ist dann 1.5.7
                      gleiches Verhalten, daran liegt es also nicht ? 😥
                      Edit: mit Firefox geht es über die Verknüpfung, aber erst wenn ich einmal runter scrolle, dann wieder hoch und dann nach unten. Es ist so, als ob etwas nachgeladen wird (bei Firefox, mit Chrome ging das nicht)
                        Das ist dann 1.5.7
                        s.bormannS
                        s.bormannS
                        s.bormann
                        #4865
                        Das ist dann 1.5.7
                        hmm. Und wenn Du ganz auf die 1.5.7 zurückgehst? Bzw. auf die Version, die Du vorher hattest? (Das über die obige URL hat zwar auch die Versionsnummer 1.5.7, enthält aber einige Github-Entwicklungsschritte mehr).
                          Das ist dann 1.5.7
                          dslraserD
                          dslraserD
                          dslraser
                          #4866
                          @s-bormann
                          ich weiß nicht mehr welche ich davor hatte, ich gehe glich mal Schrittweise zurück
                            Das ist dann 1.5.7
                            dslraserD
                            dslraserD
                            dslraser
                            #4867
                            Damit geht es wieder so wie es immer war...
                            Also irgendwas von den Entwicklungen danach funkt da wohl rein. ?
                              s.bormannS
                              s.bormannS
                              s.bormann
                              #4868
                              Ja, scheint so. Aber auf die Weise können wir uns ran tasten. Bitte versuch mal
                              https://github.com/sbormann/ioBroker.iqontrol/tree/e494f6543974d7e6ca6f823a3d099ea7e88b8d7e
                                dslraserD
                                dslraserD
                                dslraser
                                #4869
                                Installation dauert immer einen Moment....bin dabei
                                  s.bormannS
                                  s.bormannS
                                  s.bormann
                                  #4870
                                  Ich schreib Dich mal im Chat an, sonst werden die Anderen hier noch irre :)
                                    dslraserD
                                    dslraserD
                                    dslraser
                                    #4871
                                    Diese Version läuft nicht
                                      @s-bormann
                                      s.bormannS
                                      s.bormannS
                                      s.bormann
                                      schrieb am zuletzt editiert von s.bormann
                                      #4872
                                      @dslraser @all: Das Problem wurde mit Hilfe von dslraser gelöst. Mit der aktuellen Github-Version sollte es wieder laufen!
                                      EDIT: Habe es gerade auch als Version 1.6.1 hochgeladen.
                                      • s.bormannS
                                        s.bormannS
                                        s.bormann
                                        #4873
                                        Neu in der 1.6.1 zum Testen:
                                        Ein lange gefragtes Feature:
                                        Man kann jetzt mehrere oder alle Geräte-Icons und -Optionen auf einmal ändern:
                                        Bitte testen und gerne Rückmeldungen geben.
                                        Viel Spaß und schönen Sonntag noch!
                                        • S
                                          S
                                          sebi85
                                          #4874
                                          Hallo @s-bormann ,
                                          bei mir funktionieren seit der Version 1.6 die "Popup" Geräte nicht mehr. Beim Klick auf das Icon wird das Popup nicht mehr geöffnet.
                                          Ich habe die "Additional Infos" und "URL" gesetzt und normalerweise (d.h. < 1.6) hat sich dann beim Klick auf das Icon ein Popup mit den entsprechenden Daten geöffnet.
                                          Sofern ich nun "lange" auf das Icon klicke öffnet sich ein kleines Popup wo ich dann "Eigenschaften" auswählen kann. Anschließend öffnet sich das "reguläre" Popup mit den gewünschten Informationen. Mir scheint es so, als würde er durch einen normalen Klick die Geräteeigenschaften nicht mehr öffnen.
                                          Bei anderen Gerätearten (z.B. Thermometer) funktioniert das Klicken um den Dialog zu öffnen immer noch.
                                          Wurde hier in dem Bereich etwas geändert bzw. hat jemand ein ähnliches Problem?
                                          Ich verwende den google Chrome Browser.
                                          Danke und viele Grüße,
                                          Sebastian
                                          33.2k
                                          84.3k
