  4. Update Zigbee funktioniert nicht
zigbee
40 Beiträge 10 Kommentatoren 5.7k Aufrufe 5 Beobachtet
  • OberjembkerO Oberjembker
    SO?
    pi@raspi04:~ $ iobroker repo list
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest): http://download.iobroker.net/sources-dist-latest.json
    Live (testtest): http://iobroker.live/repo/sources-dist.json
    Active repo: Live (testtest)
    Leider gleiches Verhalten:
    $ ./iobroker upgrade zigbee
    Update zigbee from @1.3.1 to @1.4.3
    host.raspi04 Adapter "system.adapter.zigbee.0" is stopped.
    NPM version: 6.14.8
    npm install iobroker.zigbee@1.4.3 --loglevel error --prefix "/opt/iobroker" (System call)
    npm
     ERR! code ETARGET
    npm
    ERR! notarget No matching version found for iobroker.zigbee@1.4.3.npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-02-18T22_21_19_907Z-debug.log
    upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_rb280.png img/tuya_rb280.png image/png
    upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
    Adapter "zigbee" updated
    host.raspi04 Adapter "system.adapter.zigbee.0" is started
    process exited with code 0
    EXIT mit 0, aber nicht updated...
    Hier vorsichtshalber noch das LOG:
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli   '/usr/bin/node',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'iobroker.zigbee@1.4.3',
    1 verbose cli   '--loglevel',
    1 verbose cli   'error',
    1 verbose cli   '--prefix',
    1 verbose cli   '/opt/iobroker'
    1 verbose cli ]
    2 info using npm@6.14.8
    3 info using node@v12.19.0
    4 verbose npm-session adf20965151176c8
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 http fetch GET 304 https://registry.npmjs.org/iobroker.zigbee 350ms (from cache)
    8 silly registry:manifest no matching version for iobroker.zigbee@1.4.3 in the cache. Forcing revalidation.
    9 http fetch GET 200 https://registry.npmjs.org/iobroker.zigbee 114ms
    10 silly fetchPackageMetaData error for iobroker.zigbee@1.4.3 No matching version found for iobroker.zigbee@1.4.3.
    11 timing stage:rollbackFailedOptional Completed in 2ms
    12 timing stage:runTopLevelLifecycles Completed in 9078ms
    13 verbose type version
    14 verbose stack iobroker.zigbee: No matching version found for iobroker.zigbee@1.4.3.
    14 verbose stack     at pickManifest (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/index.js:122:13)
    14 verbose stack     at /usr/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:43:18
    14 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
    14 verbose stack     at Promise._settlePromiseFromHandler (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:517:31)
    14 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:574:18)
    14 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:619:10)
    14 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:699:18)
    14 verbose stack     at _drainQueueStep (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:138:12)
    14 verbose stack     at _drainQueue (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:131:9)
    14 verbose stack     at Async._drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:147:5)
    14 verbose stack     at Immediate.Async.drainQueues [as _onImmediate] (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
    14 verbose stack     at processImmediate (internal/timers.js:461:21)
    15 verbose cwd /opt/iobroker
    16 verbose Linux 5.4.51-v7l+
    17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.zigbee@1.4.3" "--loglevel" "error" "--prefix" "/opt/iobroker"
    18 verbose node v12.19.0
    19 verbose npm  v6.14.8
    20 error code ETARGET
    21 error notarget No matching version found for iobroker.zigbee@1.4.3.
    22 error notarget In most cases you or one of your dependencies are requesting
    22 error notarget a package version that doesn't exist.
    23 verbose exit [ 1, true ]
    @Oberjembker
    Vorher
    iobroker update
    ausgeführt?
    OberjembkerO 1 Antwort Letzte Antwort
      @Oberjembker
      Vorher
      iobroker update
      ausgeführt?
      OberjembkerO Offline
      Oberjembker
      K.A.
      Habe nicht über Kommandozeile sondern über GUI aktualisiert.
      Dachte, der update wird eh über die GUI gemacht.
      Ich check das mal...
        SO?
        NPM version: 6.14.8
        npm
         ERR! code ETARGET
        npm
        1 verbose cli [
        1 verbose cli ]
        @oberjembker
        Da ist aber grundsätzlich mal eine Aktualisierung erforderlich.
        sudo apt update
        sudo apt dist-upgrade
        sudo reboot
          K.A.
          @oberjembker Vergiss die GUI, Kommandozeile ist viel besser geeignet.
            Oberjembker
            schrieb am zuletzt editiert von Oberjembker
            Das gilt nicht! :-)
            Die meisten Nutzer können das nicht und (mein Verständnis) sollen es auch gar nicht, oder?
            Aber: ich habe meine Updates tatsächlich vernachlässigt :-(
            Der Update läuft gerade...
              Das gilt nicht! :-)
              @oberjembker Warum gilt das nicht? Ist einfach das am besten geeignete Werkzeug dafür.
              OberjembkerO 2 Antworten Letzte Antwort
                Oberjembker
                @thomas-braun Natürlich ist es das.
                Wer mit der CMD umgehen kann sollte es tun.
                Aber ich bin bequem geworden und die 2 Klicks in der GUI haben bisher immer prima funktioniert.
                Kein putty, kein "wie hieß der Befehl doch noch gleich?" usw. :-)
                  Oberjembker
                  Soll ich jetzt eigentlich auf dem live-repo bleiben?
                  Ist das das empfohlene?
                  Ich dachte immer, das ist so eine Art BETA
                    @oberjembker Ja, bleib mal auf dem live-Repo. Aber auch auf default/stable bleiben. Das ist nur eine andere URL für die gleichen Versionen, ist aber manchmal besser zu erreichen.
                      Oberjembker
                      @thomas-braun OK.
                      So. Jetzt ist meine Statistik kaputt. :-(
                      Erster reboot seit 64 Tagen.
                        @thomas-braun OK.
                        @oberjembker Dafür aber auch einen Kernel 5.10.
                          Oberjembker
                          @thomas-braun Jo.
                          Normalerweise baue ich mir den Raspi immer komplett neu.
                          Hab da Skripte, die mir das komplett mit all meinen "Eigenheiten" (security hauptsächlich) automatisch bauen.
                          SD rein, Putty, Skript starten, warten, mehrfacher autoreboot, warten, fertig.
                          Hab aber lange nicht gebaut, da der Raspi problemlos rennt.
                          Melde mich gleich wg Updateversuch
                          • OberjembkerO Offline
                            Oberjembker
                            Hmm:
                            pi@raspi04:~ $ iobroker stop
                            pi@raspi04:~ $ iobroker update
                            Used repository: Live (testtest)
                            hash unchanged, use cached sources
                            update done
                            Wie gehabt:
                            NPM version: 6.14.11
                            npm
                            ERR! code ETARGET
                            npm ERR! notarget No matching version found for iobroker.zigbee@1.4.3.npm ERR! notarget ....
                            Nicht sehr wahrscheinlich, aber hängt es vielleicht auch mit dem neuen "JS controller" zusammen?
                            Da ist ein anderer Thread, sinngemäß: "Update JS controller und Problem mit Zigbee"?
                              Hmm:
                              update done
                              Wie gehabt:
                              npm
                              ERR! code ETARGET
                              @oberjembker Schau es morgen nochmal an. Ich vermute da sind Dateien nicht konsistent.
                                Oberjembker
                                OK.
                                Gute Nacht.
                                Das war der Thread:
                                https://forum.iobroker.net/topic/42385/js-controller-3-2-jetzt-im-stable
                                  OK.
                                  Gute Nacht.
                                  Das war der Thread:
                                  @oberjembker
                                  npm view iobroker.zigbee
                                    Oberjembker
                                    @thomas-braun sagte in Update Zigbee funktioniert nicht:
                                    pi@raspi04:~ $ npm view iobroker.zigbee
                                    iobroker.zigbee@1.4.4 | MIT | deps: 5 | versions: 43
                                    Zigbee devices
                                    https://github.com/ioBroker/ioBroker.zigbee
                                    keywords: ioBroker, zigbee, cc2531, cc2530, cc2538, cc2652, deconz, conbee, raspbee
                                    dist
                                    .tarball: https://registry.npmjs.org/iobroker.zigbee/-/iobroker.zigbee-1.4.4.tgz
                                    .shasum: 45564e3e5dafec8e0ea9ec8795e8f4da6508f838
                                    .integrity: sha512-NjDrmZ+fTxQnSUkJQBq9UVYmcM7A9sgNOj7jbDxZZ1jE/hIchHcLXtnuMEkrBzB2zdL+oKO3GrZ8QsU0EJHmzw==
                                    .unpackedSize: 9.6 MB
                                    dependencies:
                                    @iobroker/adapter-core: ^2.4.0       tar: ^6.0.5                          typescript: ^4.0.5                   zigbee-herdsman-converters: ^14.0.57 zigbee-herdsman: ^0.13.70
                                    maintainers:
                                    - bluefox <dogafox@gmail.com>
                                    - kirovilya <kirovilya@gmail.com>
                                    dist-tags:
                                    latest: 1.4.4
                                    published 5 days ago by kirovilya <kirovilya@gmail.com>
                                    1.4.4? Nur Tippfehler?
                                      Zigbee devices
                                      dist
                                      dependencies:
                                      maintainers:
                                      dist-tags:
                                      latest: 1.4.4
                                      @oberjembker Ist die Version in latest/beta.
                                      github:	1.4.4
                                      latest:	1.4.4 for 4 days
                                      stable:	1.3.1 for 3 months
                                        github:	1.4.4
                                        kwittig
                                        @thomas-braun Anscheinend gibt es keine Version 1.4.3?
                                        • K kwittig
                                          @kwittig Das ist ja des Pudels Kern.
                                          Die Update-Datei referenziert 1.4.3, die gibt es aber nicht bei npm.
                                          Das muss sich noch einrenken.
