  4. BackItUp - Restore Backup - Error
Geplant Angeheftet Gesperrt Verschoben Ungelöst ioBroker Allgemein
backitupbackuprestore
20 Beiträge 4 Kommentatoren 2.8k Aufrufe 4 Beobachtet
    morpheus 0
    schrieb am zuletzt editiert von morpheus 0
    Jetzt bin ich mit ioBroker schon über drei Jahre aktiv. Leider stoße ich gerade jetzt meine Grenzen. Nach einem Restore sind all meine Daten weg. Ich bekomme folgende Logs:
    Log Backitup Restore:
    [DEBUG] [iobroker] Start ioBroker Restore ...
    [DEBUG] [iobroker] iobroker controller daemon is not running
    [DEBUG] [iobroker] host.ioBroker OK.
    [DEBUG] [iobroker] host.ioBroker Clear all objects and states...
    [DEBUG] [iobroker] clean 103 objects...
    [DEBUG] [iobroker] Server Objects 127.0.0.1:45304 Error from InMemDB: Error: Object is marked as non deletable
    [ERROR] [iobroker] [Not critical] Cannot delete object 0_userdata.0: {"command":{"name":"del","args":["cfg.o.0_userdata.0"]}}
    [ERROR] [iobroker] [Not critical] Cannot delete object alias.0: {"command":{"name":"del","args":["cfg.o.alias.0"]}}
    [ERROR] [iobroker] [Not critical] Cannot delete object enum.functions: {"command":{"name":"del","args":["cfg.o.enum.functions"]}}
    [ERROR] [iobroker] [Not critical] Cannot delete object enum.rooms: {"command":{"name":"del","args":["cfg.o.enum.rooms"]}}
    [ERROR] [iobroker] [Not critical] Cannot delete object system.config: {"command":{"name":"del","args":["cfg.o.system.config"]}}
    [ERROR] [iobroker] [Not critical] Cannot delete object system.repositories: {"command":{"name":"del","args":["cfg.o.system.repositories"]}}
    [DEBUG] [iobroker] clean 222 states...
    [DEBUG] [iobroker] host.ioBroker done.
    [DEBUG] [iobroker] host.ioBroker Processed 0/8318 states
    [ERROR] [iobroker] Uncaught Rejection: Error: invalid id ""
    [ERROR] [iobroker] at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2252:17)
    [ERROR] [iobroker] at StatesInMemoryServerClass.setRawState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:589:26)
    [ERROR] [iobroker] at BackupRestore._setStateHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:411:31)
    [ERROR] [iobroker] at runMicrotasks ()
    [ERROR] [iobroker] at processTicksAndRejections (internal/process/task_queues.js:97:5)
    [DEBUG] [iobroker] ioBroker Restore completed successfully
    [EXIT] 6 **** Restore was canceled!! ****
    The log can be closed ...
    Wie komme ich wieder zu meinem heiß geliebten ioBroker Backup?
    Vielen Dank
    • M morpheus 0
      Vielen Dank
      simatecS Online
      simatecS Online
      simatec
      @morpheus-0
      Bitte gib mal mehr Infos?
      Wie alt ist das Backup?
      node, nodejs, npm und js-controller Version?
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      M 2 Antworten Letzte Antwort
      • simatecS simatec
        @morpheus-0
        morpheus 0
        @simatec
        Das Backup war erst fünf Tage alt. Node, nodejs, npm und js-controller, alles auf dem neuesten Stand.
        • simatecS simatec
          @morpheus-0
          morpheus 0
          Hallo @simatec ,
            morpheus 0
            @morpheus-0 sagte in BackItUp - Restore Backup - Error:
            Hallo @simatec ,
            Node: v12.20.1
            Nodejs: v12.20.1
            npm: 6.14.10
            • M morpheus 0
              Hallo @simatec ,
              Node: v12.20.1
              Nodejs: v12.20.1
              npm: 6.14.10
              simatecS Online
              simatecS Online
              simatec
              @morpheus-0
              Welche Version hat der js-controller?
              • simatecS simatec
                @morpheus-0
                morpheus 0
                @simatec
                Gute Frage... Ich bekomme es nicht raus.
                  morpheus 0
                  @simatec
                  @simatec
                  js-controller: 3.2.12
                  • M morpheus 0
                    @simatec
                    @morpheus-0
                    iobroker -v
                      @morpheus-0
                      iobroker -v
                      morpheus 0
                      • M morpheus 0
                        simatecS Online
                        simatecS Online
                        simatec
                        @morpheus-0
                        Hatte einen vergleichbaren Error im Test Thread zum neuen js-controller gesehen.
                        Eventuell kann hier @apollon77 etwas zu sagen.
                        Ansonsten kannst du den Restore auch noch einmal über Konsole anschieben
                        iobroker restore <backupname>
                        • simatecS simatec
                          @morpheus-0
                          morpheus 0
                          @simatec
                          auch das habe ich schon gemacht. Dann bekomme ich folgenden Fehler:
                          host.ioBroker OK.
                          clean 583 objects...
                          Server Objects 127.0.0.1:45684 Error from InMemDB: Error: Object is marked as non deletable
                          clean 641 states...
                          host.ioBroker done.
                          host.ioBroker Processed 0/8366 states
                              at runMicrotasks (<anonymous>)
                          Ich bin echt am Verzweifeln. Drei Jahre Arbeit weg : -(.
                          Thomas BraunT apollon77A simatecS 3 Antworten Letzte Antwort
                          • M morpheus 0
                            @simatec
                            host.ioBroker OK.
                            clean 641 states...
                            host.ioBroker done.
                            @morpheus-0 Und wenn du das Back-up davor hernimmst?
                              morpheus 0
                              Leider habe ich nur Backups der letzten fünf Tage. Habe alle fünf getestet. Dann habe ich noch ein paar sehr alte von 2019. Den Fehler mach ich nicht mehr. In Zukunft gibt es jeden Monat und Jede Woche ein Backup.
                                morpheus 0
                                jetzt konnte ich doch noch Backup Dateien der letzten 30 Tage finden. Leider funktionieren die auch nicht :-(.
                                [ERROR] [iobroker] host.ioBroker Cannot extract from file "/opt/iobroker/backups/iobroker_2021_01_25-02_00_10_ioBroker_backupiobroker.tar.gz"
                                [EXIT] 9 **** Restore was canceled!! ****
                                • M morpheus 0
                                  @morpheus-0 Hast du mal den js-controller wieder auf die stabile Version gesetzt?
                                  • M morpheus 0
                                    @simatec
                                    host.ioBroker OK.
                                    clean 641 states...
                                    host.ioBroker done.
                                    @morpheus-0 Können wir in der 3.2.14 abfangen. Danke
                                    • M morpheus 0
                                      @simatec
                                      host.ioBroker OK.
                                      clean 641 states...
                                      host.ioBroker done.
                                      simatecS Online
                                      simatecS Online
                                      simatec
                                      @morpheus-0
                                      Gehe mal wie @Thomas-Braun gesagt hat auf eine Stable Version des js-controllers und führe im Anschluss den Restore erneut aus.
                                      cd /opt/iobroker
                                      iobroker stop
                                      npm install iobroker.js-controller@3.1.6
                                      iobroker fix
                                      iobroker start
                                      Im Anschluss führe den Restore aus
                                      • simatecS simatec
                                        @morpheus-0
                                        cd /opt/iobroker
                                        iobroker stop
                                        iobroker fix
                                        iobroker start
                                        morpheus 0
                                        @simatec
                                        Danke Danke Danke :-). Es hat funktioniert. Alles wieder da :-)
                                        • M morpheus 0
                                          @simatec
                                          simatecS Online
                                          simatecS Online
                                          simatec
                                          @morpheus-0
                                          Gerne ... schön das ich helfen konnte und weiterhin viel Spaß mit iobroker 😉
