<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[BackItUp - Restore Backup - Error]]></title><description><![CDATA[<p dir="auto">Jetzt bin ich mit ioBroker schon über drei Jahre aktiv. Leider stoße ich gerade jetzt meine Grenzen. Nach einem Restore sind all meine Daten weg. Ich bekomme folgende Logs:</p>
<pre><code>======================
Log Backitup Restore:
[DEBUG] [iobroker] Start ioBroker Restore ...
[DEBUG] [iobroker] iobroker controller daemon is not running
[DEBUG] [iobroker] host.ioBroker OK.
[DEBUG] [iobroker] host.ioBroker Clear all objects and states...
[DEBUG] [iobroker] clean 103 objects...
[DEBUG] [iobroker] Server Objects 127.0.0.1:45304 Error from InMemDB: Error: Object is marked as non deletable
[ERROR] [iobroker] [Not critical] Cannot delete object 0_userdata.0: {"command":{"name":"del","args":["cfg.o.0_userdata.0"]}}
[ERROR] [iobroker] [Not critical] Cannot delete object alias.0: {"command":{"name":"del","args":["cfg.o.alias.0"]}}
[ERROR] [iobroker] [Not critical] Cannot delete object enum.functions: {"command":{"name":"del","args":["cfg.o.enum.functions"]}}
[ERROR] [iobroker] [Not critical] Cannot delete object enum.rooms: {"command":{"name":"del","args":["cfg.o.enum.rooms"]}}
[ERROR] [iobroker] [Not critical] Cannot delete object system.config: {"command":{"name":"del","args":["cfg.o.system.config"]}}
[ERROR] [iobroker] [Not critical] Cannot delete object system.repositories: {"command":{"name":"del","args":["cfg.o.system.repositories"]}}
[DEBUG] [iobroker] clean 222 states...
[DEBUG] [iobroker] host.ioBroker done.
[DEBUG] [iobroker] host.ioBroker Processed 0/8318 states
[ERROR] [iobroker] Uncaught Rejection: Error: invalid id ""
[ERROR] [iobroker] at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2252:17)
[ERROR] [iobroker] at StatesInMemoryServerClass.setRawState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:589:26)
[ERROR] [iobroker] at BackupRestore._setStateHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:411:31)
[ERROR] [iobroker] at runMicrotasks ()
[ERROR] [iobroker] at processTicksAndRejections (internal/process/task_queues.js:97:5)
[DEBUG] [iobroker] ioBroker Restore completed successfully
[EXIT] 6 **** Restore was canceled!! ****
The log can be closed ...
</code></pre>
<p dir="auto">Wie komme ich wieder zu meinem heiß geliebten ioBroker Backup?</p>
<p dir="auto">Vielen Dank</p>
]]></description><link>https://forum.iobroker.net/topic/41748/backitup-restore-backup-error</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 00:27:31 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/41748.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Feb 2021 21:26:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Wed, 03 Feb 2021 17:04:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morpheus-0" aria-label="Profile: morpheus-0">@<bdi>morpheus-0</bdi></a><br />
Gerne ... schön das ich helfen konnte und weiterhin viel Spaß mit iobroker 😉</p>
]]></description><link>https://forum.iobroker.net/post/573457</link><guid isPermaLink="true">https://forum.iobroker.net/post/573457</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Wed, 03 Feb 2021 17:04:07 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Wed, 03 Feb 2021 16:57:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a></p>
<p dir="auto">Danke Danke Danke :-). Es hat funktioniert. Alles wieder da :-)</p>
]]></description><link>https://forum.iobroker.net/post/573453</link><guid isPermaLink="true">https://forum.iobroker.net/post/573453</guid><dc:creator><![CDATA[morpheus 0]]></dc:creator><pubDate>Wed, 03 Feb 2021 16:57:57 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Wed, 03 Feb 2021 07:05:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morpheus-0" aria-label="Profile: morpheus-0">@<bdi>morpheus-0</bdi></a><br />
Gehe mal wie <a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a> gesagt hat auf eine Stable Version des js-controllers und führe im Anschluss den Restore erneut aus.</p>
<pre><code>cd /opt/iobroker
iobroker stop
npm install iobroker.js-controller@3.1.6
iobroker fix
iobroker start
</code></pre>
<p dir="auto">Im Anschluss führe den Restore aus</p>
]]></description><link>https://forum.iobroker.net/post/573051</link><guid isPermaLink="true">https://forum.iobroker.net/post/573051</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Wed, 03 Feb 2021 07:05:09 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Wed, 03 Feb 2021 00:35:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morpheus-0" aria-label="Profile: morpheus-0">@<bdi>morpheus-0</bdi></a> Können wir in der 3.2.14 abfangen. Danke</p>
]]></description><link>https://forum.iobroker.net/post/573007</link><guid isPermaLink="true">https://forum.iobroker.net/post/573007</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Wed, 03 Feb 2021 00:35:58 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Tue, 02 Feb 2021 23:31:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morpheus-0" aria-label="Profile: morpheus-0">@<bdi>morpheus-0</bdi></a> Hast du mal den js-controller wieder auf die stabile Version gesetzt?</p>
]]></description><link>https://forum.iobroker.net/post/572999</link><guid isPermaLink="true">https://forum.iobroker.net/post/572999</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 02 Feb 2021 23:31:51 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Tue, 02 Feb 2021 23:27:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">jetzt konnte ich doch noch Backup Dateien der letzten 30 Tage finden. Leider funktionieren die auch nicht :-(.</p>
[ERROR] [iobroker] host.ioBroker Cannot extract from file "/opt/iobroker/backups/iobroker_2021_01_25-02_00_10_ioBroker_backupiobroker.tar.gz"
[EXIT] 9 **** Restore was canceled!! ****
</code></pre>
]]></description><link>https://forum.iobroker.net/post/572996</link><guid isPermaLink="true">https://forum.iobroker.net/post/572996</guid><dc:creator><![CDATA[morpheus 0]]></dc:creator><pubDate>Tue, 02 Feb 2021 23:27:31 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Tue, 02 Feb 2021 23:01:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Leider habe ich nur Backups der letzten fünf Tage. Habe alle fünf getestet. Dann habe ich noch ein paar sehr alte von 2019. Den Fehler mach ich nicht mehr. In Zukunft gibt es jeden Monat und Jede Woche ein Backup.</p>
]]></description><link>https://forum.iobroker.net/post/572994</link><guid isPermaLink="true">https://forum.iobroker.net/post/572994</guid><dc:creator><![CDATA[morpheus 0]]></dc:creator><pubDate>Tue, 02 Feb 2021 23:01:02 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Tue, 02 Feb 2021 22:55:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morpheus-0" aria-label="Profile: morpheus-0">@<bdi>morpheus-0</bdi></a> Und wenn du das Back-up davor hernimmst?</p>
]]></description><link>https://forum.iobroker.net/post/572993</link><guid isPermaLink="true">https://forum.iobroker.net/post/572993</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 02 Feb 2021 22:55:56 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Tue, 02 Feb 2021 22:48:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a><br />
auch das habe ich schon gemacht.  Dann bekomme ich folgenden Fehler:</p>
<pre><code>iobroker controller daemon is not running
host.ioBroker OK.
clean 583 objects...
Server Objects 127.0.0.1:45684 Error from InMemDB: Error: Object is marked as non deletable
clean 641 states...
host.ioBroker done.
host.ioBroker Processed 0/8366 states
    at runMicrotasks (&lt;anonymous&gt;)
</code></pre>
<p dir="auto">Ich bin echt am Verzweifeln. Drei Jahre Arbeit weg : -(.</p>
]]></description><link>https://forum.iobroker.net/post/572991</link><guid isPermaLink="true">https://forum.iobroker.net/post/572991</guid><dc:creator><![CDATA[morpheus 0]]></dc:creator><pubDate>Tue, 02 Feb 2021 22:48:28 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Tue, 02 Feb 2021 22:40:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morpheus-0" aria-label="Profile: morpheus-0">@<bdi>morpheus-0</bdi></a><br />
Hatte einen vergleichbaren Error im Test Thread zum neuen js-controller gesehen.</p>
<p dir="auto">Eventuell kann hier <a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a> etwas zu sagen.</p>
<p dir="auto">Ansonsten kannst du den Restore auch noch einmal über Konsole anschieben</p>
<pre><code>iobroker restore &lt;backupname&gt;
</code></pre>
]]></description><link>https://forum.iobroker.net/post/572989</link><guid isPermaLink="true">https://forum.iobroker.net/post/572989</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Tue, 02 Feb 2021 22:40:08 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Tue, 02 Feb 2021 22:36:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Danke :-)</p>
<p dir="auto">js-controller: 3.2.12</p>
]]></description><link>https://forum.iobroker.net/post/572987</link><guid isPermaLink="true">https://forum.iobroker.net/post/572987</guid><dc:creator><![CDATA[morpheus 0]]></dc:creator><pubDate>Tue, 02 Feb 2021 22:36:36 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Tue, 02 Feb 2021 22:30:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morpheus-0" aria-label="Profile: morpheus-0">@<bdi>morpheus-0</bdi></a></p>
<pre><code>iobroker -v
</code></pre>
]]></description><link>https://forum.iobroker.net/post/572984</link><guid isPermaLink="true">https://forum.iobroker.net/post/572984</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 02 Feb 2021 22:30:27 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Tue, 02 Feb 2021 22:30:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a><br />
Gute Frage... Ich bekomme es nicht raus.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morpheus-0" aria-label="Profile: morpheus-0">@<bdi>morpheus-0</bdi></a> sagte in <a href="/post/572982">BackItUp - Restore Backup - Error</a>:</p>
<blockquote>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/572983</link><guid isPermaLink="true">https://forum.iobroker.net/post/572983</guid><dc:creator><![CDATA[morpheus 0]]></dc:creator><pubDate>Tue, 02 Feb 2021 22:30:18 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Tue, 02 Feb 2021 22:29:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a><br />
]]></description><link>https://forum.iobroker.net/post/572982</link><guid isPermaLink="true">https://forum.iobroker.net/post/572982</guid><dc:creator><![CDATA[morpheus 0]]></dc:creator><pubDate>Tue, 02 Feb 2021 22:29:15 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Tue, 02 Feb 2021 22:16:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morpheus-0" aria-label="Profile: morpheus-0">@<bdi>morpheus-0</bdi></a><br />
Welche Version hat der js-controller?</p>
]]></description><link>https://forum.iobroker.net/post/572974</link><guid isPermaLink="true">https://forum.iobroker.net/post/572974</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Tue, 02 Feb 2021 22:16:30 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Tue, 02 Feb 2021 22:12:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morpheus-0" aria-label="Profile: morpheus-0">@<bdi>morpheus-0</bdi></a> sagte in <a href="/post/572969">BackItUp - Restore Backup - Error</a>:</p>
<blockquote>
<p dir="auto">Hallo <a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a> ,<br />
Das Backup war erst fünf Tage alt. Node, nodejs, npm und js-controller, alles auf dem neuesten Stand.</p>
</blockquote>
<p dir="auto">Node: v12.20.1<br />
Nodejs: v12.20.1<br />
npm: 6.14.10</p>
]]></description><link>https://forum.iobroker.net/post/572972</link><guid isPermaLink="true">https://forum.iobroker.net/post/572972</guid><dc:creator><![CDATA[morpheus 0]]></dc:creator><pubDate>Tue, 02 Feb 2021 22:12:41 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Tue, 02 Feb 2021 22:08:18 GMT]]></title><description><![CDATA[<p dir="auto">Hallo <a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a> ,<br />
]]></description><link>https://forum.iobroker.net/post/572969</link><guid isPermaLink="true">https://forum.iobroker.net/post/572969</guid><dc:creator><![CDATA[morpheus 0]]></dc:creator><pubDate>Tue, 02 Feb 2021 22:08:18 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Tue, 02 Feb 2021 22:07:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a><br />
]]></description><link>https://forum.iobroker.net/post/572968</link><guid isPermaLink="true">https://forum.iobroker.net/post/572968</guid><dc:creator><![CDATA[morpheus 0]]></dc:creator><pubDate>Tue, 02 Feb 2021 22:07:52 GMT</pubDate></item><item><title><![CDATA[Reply to BackItUp - Restore Backup - Error on Tue, 02 Feb 2021 22:02:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/morpheus-0" aria-label="Profile: morpheus-0">@<bdi>morpheus-0</bdi></a><br />
Bitte gib mal mehr Infos?<br />
Wie alt ist das Backup?<br />
node, nodejs, npm und js-controller Version?</p>
]]></description><link>https://forum.iobroker.net/post/572966</link><guid isPermaLink="true">https://forum.iobroker.net/post/572966</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Tue, 02 Feb 2021 22:02:11 GMT</pubDate></item></channel></rss>
