  4. BackItUp - Restore Backup - Error
Geplant Angeheftet Gesperrt Verschoben Ungelöst ioBroker Allgemein
backitupbackuprestore
20 Beiträge 4 Kommentatoren 2.8k Aufrufe 4 Beobachtet
    @morpheus-0
    iobroker -v
    morpheus 0
    js-controller: 3.2.12
    • M morpheus 0
      simatecS Online
      simatecS Online
      simatec
      @morpheus-0
      Hatte einen vergleichbaren Error im Test Thread zum neuen js-controller gesehen.
      Eventuell kann hier @apollon77 etwas zu sagen.
      Ansonsten kannst du den Restore auch noch einmal über Konsole anschieben
      iobroker restore <backupname>
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • simatecS simatec
        @morpheus-0
        morpheus 0
        @simatec
        auch das habe ich schon gemacht. Dann bekomme ich folgenden Fehler:
        iobroker controller daemon is not running
        host.ioBroker OK.
        host.ioBroker Clear all objects and states...
        clean 583 objects...
        Server Objects 127.0.0.1:45684 Error from InMemDB: Error: Object is marked as non deletable
        [Not critical] Cannot delete object 0_userdata.0: {"command":{"name":"del","args":["cfg.o.0_userdata.0"]}}
        [Not critical] Cannot delete object alias.0: {"command":{"name":"del","args":["cfg.o.alias.0"]}}
        [Not critical] Cannot delete object enum.functions: {"command":{"name":"del","args":["cfg.o.enum.functions"]}}
        [Not critical] Cannot delete object enum.rooms: {"command":{"name":"del","args":["cfg.o.enum.rooms"]}}
        [Not critical] Cannot delete object system.config: {"command":{"name":"del","args":["cfg.o.system.config"]}}
        [Not critical] Cannot delete object system.repositories: {"command":{"name":"del","args":["cfg.o.system.repositories"]}}
        clean 641 states...
        host.ioBroker done.
        host.ioBroker Processed 0/8366 states
        Uncaught Rejection: Error: invalid id ""
            at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2252:17)
            at StatesInMemoryServerClass.setRawState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:589:26)
            at BackupRestore._setStateHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:411:31)
            at runMicrotasks (<anonymous>)
            at processTicksAndRejections (internal/process/task_queues.js:97:5)
        Ich bin echt am Verzweifeln. Drei Jahre Arbeit weg : -(.
        Thomas BraunT apollon77A simatecS 3 Antworten Letzte Antwort
        • M morpheus 0
          @simatec
          host.ioBroker OK.
          clean 641 states...
          host.ioBroker done.
          @morpheus-0 Und wenn du das Back-up davor hernimmst?
          M 2 Antworten Letzte Antwort
            morpheus 0
            Leider habe ich nur Backups der letzten fünf Tage. Habe alle fünf getestet. Dann habe ich noch ein paar sehr alte von 2019. Den Fehler mach ich nicht mehr. In Zukunft gibt es jeden Monat und Jede Woche ein Backup.
              morpheus 0
              jetzt konnte ich doch noch Backup Dateien der letzten 30 Tage finden. Leider funktionieren die auch nicht :-(.
              Log Backitup Restore:
              [DEBUG] [iobroker] Start ioBroker Restore ...
              [ERROR] [iobroker] host.ioBroker Cannot extract from file "/opt/iobroker/backups/iobroker_2021_01_25-02_00_10_ioBroker_backupiobroker.tar.gz"
              [DEBUG] [iobroker] ioBroker Restore completed successfully
              [EXIT] 9 **** Restore was canceled!! ****
              The log can be closed ...
              • M morpheus 0
                @morpheus-0 Hast du mal den js-controller wieder auf die stabile Version gesetzt?
                • M morpheus 0
                  @simatec
                  host.ioBroker OK.
                  clean 641 states...
                  host.ioBroker done.
                  @morpheus-0 Können wir in der 3.2.14 abfangen. Danke
                  • M morpheus 0
                    @simatec
                    host.ioBroker OK.
                    clean 641 states...
                    host.ioBroker done.
                    simatecS Online
                    simatecS Online
                    simatec
                    @morpheus-0
                    Gehe mal wie @Thomas-Braun gesagt hat auf eine Stable Version des js-controllers und führe im Anschluss den Restore erneut aus.
                    cd /opt/iobroker
                    iobroker stop
                    npm install iobroker.js-controller@3.1.6
                    iobroker fix
                    iobroker start
                    Im Anschluss führe den Restore aus
                    • simatecS simatec
                      @morpheus-0
                      cd /opt/iobroker
                      iobroker stop
                      iobroker fix
                      iobroker start
                      morpheus 0
                      @simatec
                      Danke Danke Danke :-). Es hat funktioniert. Alles wieder da :-)
                      • M morpheus 0
                        @simatec
                        simatecS Online
                        simatecS Online
                        simatec
                        @morpheus-0
                        Gerne ... schön das ich helfen konnte und weiterhin viel Spaß mit iobroker 😉
