  4. Test : Wasserenthärtung judo i-soft plus Adapter
    apollon77A
i-softjudowasserenthärtung
216 Beiträge 22 Kommentatoren 58.8k Aufrufe 22 Beobachtet
  • O oranggila
    @arteck Ok, bitteschön
    judoisoft.0	2021-01-09 18:51:46.607	debug	(32424) --> stateID judoisoft.0.WaterStop changed: false (ack = true)
    judoisoft.0	2021-01-09 18:51:46.603	debug	(32424) -> ValveState
    judoisoft.0	2021-01-09 18:51:44.780	debug	(32424) -> StandBy
    judoisoft.0	2021-01-09 18:51:43.057	debug	(32424) -> WaterYearly
    judoisoft.0	2021-01-09 18:51:43.056	debug	(32424) WaterYearly.12 -1 -1
    judoisoft.0	2021-01-09 18:51:43.056	debug	(32424) WaterYearly.11 -1 -1
    judoisoft.0	2021-01-09 18:51:43.055	debug	(32424) WaterYearly.10 -1 -1
    judoisoft.0	2021-01-09 18:51:43.055	debug	(32424) WaterYearly.09 -1 -1
    judoisoft.0	2021-01-09 18:51:43.055	debug	(32424) WaterYearly.08 -1 -1
    judoisoft.0	2021-01-09 18:51:43.054	debug	(32424) WaterYearly.07 -1 -1
    judoisoft.0	2021-01-09 18:51:43.054	debug	(32424) WaterYearly.06 -1 -1
    judoisoft.0	2021-01-09 18:51:43.054	debug	(32424) WaterYearly.05 -1 -1
    judoisoft.0	2021-01-09 18:51:43.053	debug	(32424) WaterYearly.04 -1 -1
    judoisoft.0	2021-01-09 18:51:43.053	debug	(32424) WaterYearly.03 -1 -1
    judoisoft.0	2021-01-09 18:51:43.053	debug	(32424) WaterYearly.02 -1 -1
    judoisoft.0	2021-01-09 18:51:43.052	debug	(32424) WaterYearly.01 1459 1459
    judoisoft.0	2021-01-09 18:51:41.201	debug	(32424) -> WaterTotaal 49247 31698
    judoisoft.0	2021-01-09 18:51:39.575	debug	(32424) -> Quantity
    judoisoft.0	2021-01-09 18:51:37.390	debug	(32424) -> FlowRate
    judoisoft.0	2021-01-09 18:51:35.356	debug	(32424) -> NaturalHardness
    judoisoft.0	2021-01-09 18:51:33.704	debug	(32424) -> WaterAverage
    judoisoft.0	2021-01-09 18:51:32.007	debug	(32424) -> SaltQuantity
    judoisoft.0	2021-01-09 18:51:29.312	debug	(32424) -> SaltRange
    judoisoft.0	2021-01-09 18:51:27.043	debug	(32424) --> stateID judoisoft.0.ResidualHardness changed: 6 (ack = true)
    judoisoft.0	2021-01-09 18:51:27.038	debug	(32424) -> ResidualHardness
    judoisoft.0	2021-01-09 18:51:25.111	debug	(32424) -> WaterCurrent
    judoisoft.0	2021-01-09 18:51:23.054	debug	(32424) get Consumption data
    judoisoft.0	2021-01-09 18:51:23.053	debug	(32424) get Information Static 3 {"command":"service date","data":"1594389063","group":"contract","msgnumber":"1","status":"ok","token":"f455af61e017e22599608dd442088b524843af4317ff1ff24e8ef2efa43d337
    judoisoft.0	2021-01-09 18:51:23.053	debug	(32424) get Information Static 2 {"command":"init date","data":"1594389063","group":"contract","msgnumber":"1","status":"ok","token":"f455af61e017e22599608dd442088b524843af4317ff1ff24e8ef2efa43d3373",
    judoisoft.0	2021-01-09 18:51:23.052	debug	(32424) get Information Static 1 {"command":"hardware version","data":"5.10","group":"version","msgnumber":"1","status":"ok","token":"f455af61e017e22599608dd442088b524843af4317ff1ff24e8ef2efa43d3373",
    judoisoft.0	2021-01-09 18:51:23.052	debug	(32424) get Information Static 0 {"command":"software version","data":"02.09.h","group":"version","msgnumber":"1","status":"ok","token":"f455af61e017e22599608dd442088b524843af4317ff1ff24e8ef2efa43d337
    judoisoft.0	2021-01-09 18:51:15.316	debug	(32424) get Information Static
    judoisoft.0	2021-01-09 18:51:15.316	debug	(32424) connect Result: {"group":"register","command":"connect","msgnumber":"1","token":"f455af61e017e22599608dd442088b524843af4317ff1ff24e8ef2efa43d3373","parameter":"i-soft plus","serial number":"1
    judoisoft.0	2021-01-09 18:51:14.994	debug	(32424) getSerialnumber : {"group":"register","command":"show","msgnumber":"2","token":"f455af61e017e22599608dd442088b524843af4317ff1ff24e8ef2efa43d3373","status":"ok","data":[{"wtuType":"i-soft plus
    judoisoft.0	2021-01-09 18:51:14.576	debug	(32424) getToken: {"group":"register","command":"login","msgnumber":"1","name":"login","user":"*","password":"*","role":"customer","status":"ok","token":"f455af61e017e22599608dd442088b524843a
    judoisoft.0	2021-01-09 18:51:13.895	debug	(32424) getURL: https://192.168.0.29:8124/?group=register&command=login&msgnumber=1&name=login&user=*
    judoisoft.0	2021-01-09 18:51:13.890	debug	(32424) create state
    judoisoft.0	2021-01-09 18:51:13.876	info	(32424) starting. Version 0.0.9 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v12.20.1, js-controller: 3.1.6
    judoisoft.0	2021-01-09 18:51:13.449	debug	(32424) statesDB connected
    judoisoft.0	2021-01-09 18:51:13.449	debug	(32424) States connected to redis: 0.0.0.0:9000
    judoisoft.0	2021-01-09 18:51:13.441	debug	(32424) States create System PubSub Client
    judoisoft.0	2021-01-09 18:51:13.440	debug	(32424) States create User PubSub Client
    judoisoft.0	2021-01-09 18:51:13.435	debug	(32424) Redis States: Use Redis connection: 0.0.0.0:9000
    judoisoft.0	2021-01-09 18:51:13.434	debug	(32424) objectDB connected
    judoisoft.0	2021-01-09 18:51:13.432	debug	(32424) Objects connected to redis: 0.0.0.0:9001
    judoisoft.0	2021-01-09 18:51:13.417	debug	(32424) Objects client initialize lua scripts
    judoisoft.0	2021-01-09 18:51:13.416	debug	(32424) Objects create User PubSub Client
    judoisoft.0	2021-01-09 18:51:13.416	debug	(32424) Objects create System PubSub Client
    judoisoft.0	2021-01-09 18:51:13.414	debug	(32424) Objects client ready ... initialize now
    judoisoft.0	2021-01-09 18:51:13.397	debug	(32424) Redis Objects: Use Redis connection: 0.0.0.0:9001
    judoisoft.0	2021-01-09 18:51:15.316	debug	(32424) connect Result: {"group":"register","command":"connect","msgnumber":"1","token":"f455af61e017e22599608dd442088b524843af4317ff1ff24e8ef2efa43d3373","parameter":"i-soft plus","serial number":"19
    arteckA
    arteckA
    arteck
    @oranggila sagte in Test : Wasserenthärtung judo i-soft plus Adapter:
    jo jetzt musst du warten bis hier am ende eine 0 steht.. ich vermute die wird nicht übermittelt.
    • O oranggila
      @arteck 👍 Aktualisierung funktioniert jetzt.
      WaterTotal hat jetzt die letzte Stelle verloren. Kann das sein? Es müssten m.E. nach 49160 l sein. f001e6df-5ee3-4ee3-88ab-d439427ece10-grafik.png
      O
      O
      oranggila
      @oranggila Aktualisierung stoppt täglich nachdem mein DSL-Router durchstartet 4:30 Uhr und läuft nicht mehr neu an. Was macht man da am besten, Neustart des Adapters danach einplanen?
      Intel NUC - ioBroker in Proxmox-VM, Zigbee TCP CC2652P2, MG4 Trophy (e-Auto)
      • O oranggila
        arteckA
        arteckA
        arteck
        @oranggila kommt da was als fehler ?? den wir bewegen uns Lokal.. sollte nicht stören
        O 2 Antworten Letzte Antwort
        • arteckA arteck
          O
          O
          oranggila
          @arteck Muss ich beobachten. Im Log war nichts mehr zu sehen, als ich es bemerkt habe.
          • arteckA arteck
            O
            O
            oranggila
            @arteck In den Logs der vergangenen Tage ist nach 4:30 Uhr DSL-Router Restart kein Eintrag mehr von judoisoft, auch keine Fehlermeldung. Hat noch jemand dieses Verhalten oder eine Erklärung dafür? Ich würde jetzt halt täglich einen Neustart des Adapters nach 4:30 Uhr einplanen als Workaround.
            • O oranggila
              M
              M
              mpenno
              @oranggila Bei mir läuft der Adapter ohne Probleme.
              Ich hatte letztens das erste Mal ein Problem, was einen fehlerhaften Neustart des gesamten Docker-Containers mit sich zog. Die eigentliche Ursache konnte ich aber nicht ausmachen.
              Ich hatte kürzlich einige Adapter aktualisiert, jetzt auch noch mal. In den Änderungshistorien habe ich was von "fix crash case" bei den Adaptern "Information tab" und "javascript" gelesen.
              Soweit alles in Ordnung :-)
              Viele Grüße
              O 1 Antwort Letzte Antwort
              • M mpenno
                Viele Grüße
                O
                O
                oranggila
                @mpenno Bei mir läuft er jetzt auch stabil. Ich starte den Adapter täglich 5:30 Uhr neu und habe Aktualisierung alle 2 min eingestellt. VIS ist auch schon ganz brauchbar:
                Nur die Wasserhärte einstellen im Adapter fehlt noch, damit die Szenen funktionieren.
                M S 2 Antworten Letzte Antwort
                • O oranggila
                  M
                  M
                  mpenno
                  @oranggila Schöne Visu!
                  Bei mir aktualisieren sich jetzt auch keine Werte mehr. Alle Daten sind vom 21.01. ca. 3:00 Uhr morgens, auch der Zetistempel vom "Connection Status = OK".
                  Das Log ist unauffällig.
                  Soll ich was bestimmtes Prüfen, was der Sache dienlich sein kein, bevor ich den Adapter neu starte?
                  Viele Grüße
                  Michael
                  • M mpenno
                    Viele Grüße
                    Michael
                    M
                    M
                    mpenno
                    Habe dann gestern aufgrund vom Aktualisieren einiger Pakete, darunter auch den js-controller, neugestartet. Das war gestern gegen 16:30 Uhr.
                    Heute aktualisieren sich wieder keine Daten. Stehen geblieben ist er gestern um 21:24 Uhr.
                    Wieder mit Connection-Status = OK.
                    Er denkt scheinbar immer noch, er sei verbunden. Adapterspezifische Log-Meldungen gibt es nicht.
                    Zur Info: Mein Judo iSoft ist mit einem Netzwerkkabel angebunden, nicht per WLAN.
                    Viele Grüße
                    Michael
                    • M mpenno
                      Viele Grüße
                      Michael
                      arteckA
                      arteckA
                      arteck
                      @mpenno hmm..
                      aktualisiere nochmal vom GIT und stell den adapter mal auf silly und beobachte die logs.. wo der aussteigt
                      • arteckA arteck
                        @mpenno hmm..
                        M
                        M
                        mpenno
                        @arteck Ja OK, mache ich.
                        Ich habe mal kurz das Netzwerkkabel vom Judo iSoft für 10 Minuten abgezogen. Das scheint dem Adapter nicht zu interessieren (Abfrageintervall war Standard=300s). Er scheint wirklich fest zu "hängen".
                        Ich melde mich später.
                        Danke übrigens für Deinen Support!
                        Habt Ihr eine PayPal-Kasse?
                        • arteckA
                          arteckA
                          arteck
                          jetzt auch mit cloud Login
                          leider musste ich die Einstellung wieder ausbauen da die Cloud nicht die funktionalität hergibt
                          • arteckA arteck
                            M
                            M
                            mpenno
                            @arteck Kleiner Zwischenstand: mit der 1.0.1 läuft es schon seit über 24h.
                            • M mpenno
                              M
                              M
                              mpenno
                              Neuer Zwischenstand: Ich musste den Test abbrechen, da meine Docker-Instanz instabil lief. Mein RAM wurde knapp, so dass ich erst einen neuen Speicherriegel für meine Synology bestellen musste. Ich hoffe, er wird am Samstag geliefert :-)
                              • O
                                O
                                oranggila
                                schrieb am zuletzt editiert von oranggila
                                gelöscht
                                • arteckA arteck
                                  @oranggila ok klingt plausibel.. ich bau es ein
                                  check 0.0.6
                                  O
                                  O
                                  oranggila
                                  @arteck said in Test : Wasserenthärtung judo i-soft plus Adapter:
                                  check 0.0.6
                                  @arteck Ist das Einstellen der Wasserhärte schon eingebaut in der 1.0.1?
                                  • O oranggila
                                    check 0.0.6
                                    arteckA
                                    arteckA
                                    arteck
                                    @oranggila ja
                                    • arteckA arteck
                                      @oranggila ja
                                      O
                                      O
                                      oranggila
                                      @oranggila ja
                                      Härtegrad einstellen erfolgreich getestet. Vielen Dank dafür! 👍
                                      • M mpenno
                                        M
                                        M
                                        mpenno
                                        seit Sonntag läuft der Adapter ohne Neustart. Im auf "silly" gestelltem Log gibt es immer diesen Block an Einträgen, passend zum eingestelltem Polling-Intervall:
                                        2021-02-03 04:13:32 judoisoft.0 (1228) get Consumption data
                                        2021-02-03 04:13:35 judoisoft.0 (1228) -> WaterCurrent
                                        2021-02-03 04:13:37 judoisoft.0 (1228) -> ResidualHardness
                                        2021-02-03 04:13:37 judoisoft.0 (1228) States user redis pmessage judoisoft.0.ResidualHard
                                        ness/judoisoft.0.ResidualHardness:{"val":"8","ack":true,"ts":1612322017779,"q":0,"from":"system.adapter.judoisoft.0"," user":"system.user.admin","lc":1610288716907}
                                        2021-02-03 04:13:37 judoisoft.0 (1228) --> stateID judoisoft.0.ResidualHardness changed: 8 (ack = true)
                                        2021-02-03 04:13:39 judoisoft.0 (1228) -> SaltRange
                                        2021-02-03 04:13:41 judoisoft.0 (1228) -> SaltQuantity
                                        2021-02-03 04:13:43 judoisoft.0 (1228) -> WaterAverage
                                        2021-02-03 04:13:45 judoisoft.0 (1228) -> NaturalHardness
                                        2021-02-03 04:13:47 judoisoft.0 (1228) -> FlowRate
                                        2021-02-03 04:13:49 judoisoft.0 (1228) -> Quantity
                                        2021-02-03 04:13:51 judoisoft.0 (1228) -> WaterTotaal  265410 170582
                                        2021-02-03 04:13:53 judoisoft.0 (1228) WaterYearly.01 10953 10953
                                        2021-02-03 04:13:53 judoisoft.0 (1228) WaterYearly.02 536 536
                                        2021-02-03 04:13:53 judoisoft.0 (1228) WaterYearly.03 -1 -1
                                        2021-02-03 04:13:53 judoisoft.0 (1228) WaterYearly.04 -1 -1
                                        2021-02-03 04:13:53 judoisoft.0 (1228) WaterYearly.05 -1 -1
                                        2021-02-03 04:13:53 judoisoft.0 (1228) WaterYearly.06 -1 -1
                                        2021-02-03 04:13:53 judoisoft.0 (1228) WaterYearly.07 -1 -1
                                        2021-02-03 04:13:53 judoisoft.0 (1228) WaterYearly.08 -1 -1
                                        2021-02-03 04:13:53 judoisoft.0 (1228) WaterYearly.09 -1 -1
                                        2021-02-03 04:13:53 judoisoft.0 (1228) WaterYearly.10 -1 -1
                                        2021-02-03 04:13:53 judoisoft.0 (1228) WaterYearly.11 -1 -1
                                        2021-02-03 04:13:53 judoisoft.0 (1228) WaterYearly.12 -1 -1
                                        2021-02-03 04:13:53 judoisoft.0 (1228) -> WaterYearly
                                        2021-02-03 04:13:56 judoisoft.0 (1228) -> StandBy
                                        2021-02-03 04:13:58 judoisoft.0 (1228) -> ValveState
                                        2021-02-03 04:13:58 judoisoft.0 (1228) States user redis pmessage judoisoft.0.WaterStop/judoisoft.0.WaterStop:{"val":false,"ack":true,"ts":1612322038845,"q":0,"from":"system.adapter.judoisoft.0","user":"system.user.admin","lc":1610288703551}
                                        2021-02-03 04:13:58 judoisoft.0 (1228) --> stateID judoisoft.0.WaterStop changed: false (ack = true)
                                        Diese beiden Einträge fallen etwas auf ...
                                        und
                                        Was sie bedeuten weiß ich nicht. Oder ist alles normal?
                                        Viele Grüße
                                        Michael
                                        • M mpenno
                                          und
                                          Viele Grüße
                                          Michael
                                          arteckA
                                          arteckA
                                          arteck
                                          @mpenno alles gut
                                          84.0k
