  4. Beta Test js-controller 3.2.x auf GitHub
js-controller
287 Beiträge 25 Kommentatoren 120.5k Aufrufe 29 Beobachtet
  • GarganoG Gargano
    @apollon77
    Installieren aus eigener URL geht nicht mehr mit 3.2.7 und 3.2.8 (mit 3.1.6 geht es)
    node 12.20.1 npm 6.14.10
    npm ERR! premature close
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-01-23T10_41_58_613Z-debug.log
    ERROR: host.raspberrypi Cannot install Grizzelbee/ioBroker.resol#02688d5f04b27921be060f533d2fd02cbfd9892d: 1
    Inhalt vom Error log :
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli '/usr/bin/node',
    1 verbose cli '/usr/bin/npm',
    1 verbose cli 'install',
    1 verbose cli 'Grizzelbee/ioBroker.resol#02688d5f04b27921be060f533d2fd02cbfd9892d',
    1 verbose cli '--loglevel',
    1 verbose cli 'error',
    1 verbose cli '--prefix',
    1 verbose cli '/opt/iobroker'
    1 verbose cli ]
    2 info using npm@6.14.10
    3 info using node@v12.20.1
    4 verbose npm-session 3649abc973e44642
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 verbose prepareGitDep github:Grizzelbee/ioBroker.resol#02688d5f04b27921be060f533d2fd02cbfd9892d: installing devDeps and running prepare script.
    8 silly fetchPackageMetaData error for github:Grizzelbee/ioBroker.resol#02688d5f04b27921be060f533d2fd02cbfd9892d premature close
    9 timing stage:rollbackFailedOptional Completed in 2ms
    10 timing stage:runTopLevelLifecycles Completed in 13533ms
    11 verbose stack Error: premature close
    11 verbose stack at PassThrough.onclose (/usr/lib/node_modules/npm/node_modules/end-of-stream/index.js:47:67)
    11 verbose stack at PassThrough.emit (events.js:326:22)
    11 verbose stack at emitCloseNT (internal/streams/destroy.js:69:8)
    11 verbose stack at processTicksAndRejections (internal/process/task_queues.js:83:21)
    12 verbose cwd /opt/iobroker
    13 verbose Linux 5.4.83-v7l+
    14 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "Grizzelbee/ioBroker.resol#02688d5f04b27921be060f533d2fd02cbfd9892d" "--loglevel" "error" "--prefix" "/opt/iobroker"
    15 verbose node v12.20.1
    16 verbose npm v6.14.10
    17 error premature close
    18 verbose exit [ 1, true ]
    apollon77A
    apollon77A
    #268
    @gargano sagte in Beta Test js-controller 3.2.x auf GitHub:
    Also "iobroker url Grizzelbee/ioBroker.resol#02688d5f04b27921be060f533d2fd02cbfd9892d" geht bei mit mit der 3.2.10
    EIn "npm Fehler mit "premature CLose" heisst an sich das es Netzwerkprobleme gibt
    GarganoG 1 Antwort Letzte Antwort
    • apollon77A apollon77
      GarganoG
      GarganoG
      Gargano
      #269
      @apollon77 Danke, dann werde ich das mal mit der 3.2.10 probieren. Ist ja grad mal eine Stunde alt👍
      • GarganoG Gargano
        apollon77A
        apollon77A
        #270
        @gargano naja an dem Teil hat sich zuletzt was in 3.2.8 geändert gehabt glaube ich ;-)
          GarganoG
          GarganoG
          Gargano
          #271
          @apollon77 da schein noch irgendwas nicht zu funktionieren
          pi@raspberrypi:/opt/iobroker $ sudo npm install ioBroker/ioBroker.js-controller
          npm ERR! code 128
          npm ERR! Command failed: git clone --mirror -q git://github.com/ioBroker/ioBroker.js-controller.git /root/.npm/_cacache/tmp/git-clone-82ee4f0a/.git
          npm ERR! fatal: could not create leading directories of '/root/.npm/_cacache/tmp/git-clone-82ee4f0a/.git'
          npm ERR!
          npm ERR!     /root/.npm/_logs/2021-01-24T11_07_09_234Z-debug.log
          • GarganoG Gargano
            npm ERR! code 128
            npm ERR!
            #272
            @gargano 10,-€ in die Kaffeekasse bei @apollon77 für's aufrufen mit "sudo" und nicht beachten der Anleitung im ersten Post...
              GarganoG
              GarganoG
              Gargano
              schrieb am zuletzt editiert von Gargano
              #273
              @ilovegym hatte ich auch ohne sudo probiert ,
              das ist ohne sudo :
               npm install ioBroker/ioBroker.js-controller      Illegal option --
              sudo: Usage:: command not found
              • GarganoG Gargano
                das ist ohne sudo :
                #274
                @gargano was macht denn ein "iobroker fix" bei dir ?
                  GarganoG
                  GarganoG
                  Gargano
                  #275
                  @ilovegym Ist schon gelaufen
                  • GarganoG Gargano
                    #276
                    @gargano
                    zeig mal wie Node installiert ist:
                     which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                      @gargano
                      GarganoG
                      GarganoG
                      Gargano
                      #277
                      @ilovegym mit npm stimmt was nicht :
                      pi@raspberrypi:/opt/iobroker $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                      /usr/bin/nodejs
                      v12.20.1
                      /usr/bin/node
                      v12.20.1
                      /usr/bin/npm
                      Illegal option --
                      • GarganoG Gargano
                        /usr/bin/nodejs
                        v12.20.1
                        /usr/bin/node
                        v12.20.1
                        /usr/bin/npm
                        Illegal option --
                        #278
                        @gargano Ei, das sieht dringend danach aus, dass du das hier mal durchgehen solltest, da stimmt was NPM nicht und überhaupt...
                          GarganoG
                          GarganoG
                          Gargano
                          #279
                          @ilovegym sagte in Beta Test js-controller 3.2.x auf GitHub:
                          und überhaupt...
                          warum ich vom github installiere und nicht vom latest ?
                          Die Antwort ist in einem Post weiter oben. Ich habe auf js-controller 3.2.8 upgedatet und da ging das Installieren eines Adapters via Github nicht mehr, mit 3.1.6 geht es. Apollon77 sagte dann , daß bei ihm mit 3.2.10 geht. 3.2.10 ist aber noch nicht im latest, deshalb von github installieren. Wie wir nun wissen geht das nicht wegen npm Problem.
                          Dann werde ich mich mal ans Reparieren machen.
                          • GarganoG Gargano
                            und überhaupt...
                            apollon77A
                            apollon77A
                            #280
                            @gargano 3.2.10 sollte seit gestern Nahchmittag schon im Latest sein. Vllt iobroker update machen?
                            • GarganoG
                              GarganoG
                              Gargano
                              #281
                              @ilovegym Das einzige was geholfen hat npm wieder zum Laufen zu bringen war
                              sudo apt-get remove npm
                              sudo apt-get install npm
                              Danach war auch npm wieder da
                              /usr/bin/nodejs
                              v12.20.1
                              /usr/bin/node
                              v12.20.1
                              /usr/bin/npm
                              6.14.10
                              nodejs:
                                Installed: 12.20.1-1nodesource1
                                Candidate: 12.20.1-1nodesource1
                                Version table:
                               *** 12.20.1-1nodesource1 500
                                      500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                                   10.23.1~dfsg-1~deb10u1 500
                              • GarganoG Gargano
                                /usr/bin/nodejs
                                v12.20.1
                                /usr/bin/node
                                v12.20.1
                                /usr/bin/npm
                                6.14.10
                                nodejs:
                                  Version table:
                                #282
                                @gargano super, jetzt passts :-)
                                  So, liebe Freunde der gepflegten Controler Tests :-)
                                  Github ist nun mit der 3.2.4 ausgestattet die alles bisher berichtete behandelt.
                                  • die "Not exists" Fehler in einigen Adaptern wenn diese nicht existente Objekte gelöscht haben sollten weg sein
                                  • Lets encrypt wurde nochmal ein bissl getuned (hat das schonmal jemand gecheckt? ;-))
                                  • der Adapter löschen File Fehler von @Homoran sollte auch weg sein
                                  Have fun
                                  Ingo
                                  peterbaumertP
                                  peterbaumertP
                                  peterbaumert
                                  #283
                                  @apollon77 Hey, ich habe den fehler mit dem neuesten js-controller Installed: 3.2.11 immernoch manchmal. Kommt 2 oder 3 mal dann startet der Adapter. Kann das noch an was anderem liegen?
                                  unifi-protect.0	2021-01-27 19:05:33.090	error	(992) Not exists
                                  unifi-protect.0	2021-01-27 19:05:33.090	error	(992) Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2252:17) at ObjectsInRedisClient._delObject (/opt/iobroker/node_modules
                                  • peterbaumertP peterbaumert
                                    apollon77A
                                    apollon77A
                                    #284
                                    @peterbaumert Wir behandeln das löschen eines "Nicht existenten Objects" als "erfolg" in der 3.1.12 die bald kommt :-)
                                      SBorgS
                                      SBorgS
                                      SBorg
                                      #285
                                      @apollon77 sagte in Beta Test js-controller 3.2.x auf GitHub:
                                      Test bestanden oder Rückschritt? [Klugschei*modus \ON] sollte wohl 3.2.12 heißen 😇
                                      LG SBorg ( SBorg auf GitHub)
                                      • SBorgS SBorg
                                        apollon77A
                                        apollon77A
                                        #286
                                        @sborg hihi ... hast ja recht ;-) 3.23.12 ... mist tastatur oder zu dicke Finger ... 3.2.12
                                        • apollon77A
                                          apollon77A
                                          #287
                                          So, da alles Stabil aussieht mit der 3.2.16 und die wenn alles klappt in einer Woche Richtung stable geht mache ich hier zu.
                                          WICHTIG: Github version ist damit wieder "unstable" und wird die Tabe für den 3.3.0 Entwicklungsstart vorbereitet!
                                          33.2k
                                          84.3k
