  4. Auf redis umstellen
Auf redis umstellen
100 Beiträge 11 Kommentatoren 20.4k Aufrufe 9 Beobachtet
  • R Offline
    Renegade 0
    #67
    Also hab jetzt mal migrieren wollen:
    pi@TestPI:~ $ iobroker stop
    pi@TestPI:~ $ iobroker setup custom
    Current configuration:
    - Objects database:
      - Type: file
      - Host/Unix Socket: 127.0.0.1
      - Port: 9001
    - States database:
      - Type: file
      - Port: 9000
    - Data Directory: ../../iobroker-data/
    Type of objects DB [(f)ile, (r)edis, ...], default [file]: r
    When Objects and Files are stored in a Redis database please consider the following:
    1. All data will be stored in RAM, make sure to have enough free RAM available!
    2. Make sure to check Redis persistence options to make sure a Redis problem will not cause data loss!
    3. The Redis persistence files can get big, make sure not to use an SD card to store them.
    Host / Unix Socket of objects DB(redis), default[127.0.0.1]: r
    Port of objects DB(redis), default[6379]:
    Type of states DB [(f)file, (r)edis, ...], default [redis]:
    Host / Unix Socket of states DB (redis), default[r]:
    Port of states DB (redis), default[6379]:
    Host name of this machine [TestPI]:
    Please choose if this is a Master/single host (enter "m") or a Slave host (enter "S") you are about to edit. For Slave hosts the data migration will be skipped. [S/m]: m
    Important: Using redis for the Objects database is only supported
    with js-controller 2.0 or higher!
    When your system consists of multiple hosts please make sure to have
    js-controller 2.0 or higher installed on ALL hosts *before* continuing!
    Important #2: If you already did the migration on an other host
    please *do not* migrate again! This can destroy your system!
    Important #3: The process will migrate all files that were officially
    uploaded into the ioBroker system. If you have manually copied files into
    iobroker-data/files/... into own directories then these files will NOT be
    migrated! Make sure all files are in adapter directories inside the files
    directory!
    Do you want to migrate objects and states from "file/file" to "redis/redis" [y/N]: y
    Migrating the objects database will overwrite all objects! Are you sure that this is not a slave host and you want to migrate the data? [y/N]: y
    Connecting to previous DB "file"...
    Creating backup ...
    This can take some time ... please be patient!
    host.TestPI 609 states saved
    host.TestPI 747 objects saved
    Backup created: /opt/iobroker/backups/2021_01_21-18_36_16_backupiobroker-migration.tar.gz
    updating conf/iobroker.json
    Connecting to new DB "redis" (can take up to 20s) ...
    No connection to objects r:6379[redis]
    New Database could not be connected. Please check your settings. No settings have been changed.
    restoring conf/iobroker.json
    No connection to states r:6379[redis]
    pi@TestPI:~ $ redis-cli ping
    PONG
    pi@TestPI:~ $
    F HomoranH 2 Antworten Letzte Antwort
    • R Renegade 0
      - Objects database:
        - Type: file
        - Port: 9001
      - States database:
        - Type: file
        - Port: 9000
      directory!
      Creating backup ...
      PONG
      pi@TestPI:~ $
      F Online
      F Online
      fastfoot
      #68
      @renegade-0 sagte in Auf redis umstellen:
      du hast die IP mit r überschrieben :-)
      R 1 Antwort Letzte Antwort
      • F fastfoot
        Renegade 0
        #69
        @fastfoot uups.^^
        ok nochmal von vorn :)
        • R Renegade 0
          - Objects database:
            - Type: file
            - Port: 9001
          - States database:
            - Type: file
            - Port: 9000
          directory!
          Creating backup ...
          PONG
          pi@TestPI:~ $
          HomoranH Offline
          HomoranH Offline
          #70
          was macht das r da?
          EDIT: @fastfoot war schneller
            was macht das r da?
            Renegade 0
            #71
            jaja schon gefixt. :)
            @apollon77 So alles nochmal nach Vorschrift gemacht. Läuft wie eine 1.
            nur mein DoorIO macht immer noch mucken, aber das geht in den passenden Thread.
            Danke dir vielmals :)
            HomoranH F 2 Antworten Letzte Antwort
            • R Renegade 0
              HomoranH Offline
              HomoranH Offline
              #72
              Auch für die anderen Threads bitte nochmal Zusammenfassen:
              Du hast jetzt controller 3.2.x und redis?
              Und auch die Objekte in redis, wenn ich das richtig gesehen habe?
              EDIT: im anderen Thread habe ich gerade gefunden:
              So nun mein ganzes System auf die Latest gezogen, redis draufgepackt und migriert. Alle Adapter aktualisiert.
              Hab das gar nicht mitbekommen, hast du jetzt wirklich ALLE Adapter auf latest?
                Renegade 0
                #73
                OK wird gemacht
                • R Renegade 0
                  F Online
                  F Online
                  fastfoot
                  #74
                  Sorgfalt zahlt sich aus :-)
                    @fastfoot sagte in Auf redis umstellen:
                    ich vermute dass der redis server nicht läuft
                    Ein sudo systemctl restart redis-server hat auf jeden Fall nicht geholfen.
                    Dr. BakteriusD Offline
                    Dr. Bakterius
                    #75
                    Noch ein Versuch - gleiches Ergebnis.
                    ergibt:
                    Job for redis-server.service failed because the control process exited with error code.
                    See "systemctl status redis-server.service" and "journalctl -xe" for details.
                    ergibt:
                    * redis-server.service - Advanced key-value store
                       Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor preset: enabled)
                       Active: failed (Result: exit-code) since Thu 2021-01-21 19:08:33 CET; 13s ago
                         Docs: http://redis.io/documentation,
                               man:redis-server(1)
                      Process: 6559 ExecStart=/usr/bin/redis-server /etc/redis/redis.conf (code=exited, status=226/NAMESPA
                    Und sudo journalctl -xe
                    ergibt:
                    -- Defined-By: systemd
                    -- Support: https://www.debian.org/support
                    -- The process /usr/bin/redis-server could not be executed and failed.
                    -- The error number returned by this process is ERRNO.
                    Jan 21 19:08:33 iobroker systemd[1]: redis-server.service: Control process exited, code=exited, status
                    -- Subject: Unit process exited
                    -- An ExecStart= process belonging to unit redis-server.service has exited.
                    -- The process' exit code is 'exited' and its exit status is 226.
                    Jan 21 19:08:33 iobroker systemd[1]: redis-server.service: Failed with result 'exit-code'.
                    -- Subject: Unit failed
                    -- The unit redis-server.service has entered the 'failed' state with result 'exit-code'.
                    Jan 21 19:08:33 iobroker systemd[1]: Failed to start Advanced key-value store.
                    -- Subject: A start job for unit redis-server.service has failed
                    -- A start job for unit redis-server.service has finished with a failure.
                    -- The job identifier is 674 and the job result is failed.
                    Jan 21 19:08:33 iobroker systemd[1]: redis-server.service: Service RestartSec=100ms expired, schedulin
                    Jan 21 19:08:33 iobroker systemd[1]: redis-server.service: Scheduled restart job, restart counter is a
                    -- Subject: Automatic restarting of a unit has been scheduled
                    -- Automatic restarting of the unit redis-server.service has been scheduled, as the result for
                    -- the configured Restart= setting for the unit.
                    Jan 21 19:08:33 iobroker systemd[1]: Stopped Advanced key-value store.
                    -- Subject: A stop job for unit redis-server.service has finished
                    -- A stop job for unit redis-server.service has finished.
                    -- The job identifier is 715 and the job result is done.
                    Jan 21 19:08:33 iobroker systemd[1]: redis-server.service: Start request repeated too quickly.
                    -- The job identifier is 715 and the job result is failed.
                    Der Ordner \var\log\redis ist leer.
                    Jemand noch eine Idee?
                    Dr. BakteriusD 1 Antwort Letzte Antwort
                      ergibt:
                      ergibt:
                                 man:redis-server(1)
                      ergibt:
                      Dr. Bakterius
                      #76
                      Mit /usr/bin/redis-server /etc/redis/redis.conf kann man ja die Config prüfen. Das ergibt:
                      *** FATAL CONFIG FILE ERROR ***
                      Reading the configuration file, at line 171
                      >>> 'logfile /var/log/redis/redis-server.log'
                      Can't open the log file: Permission denied
                      Also folgendes gemacht:
                      Eine leere redis-server.log erstellt und dann
                      sudo chown -R redis:redis /var/log/redis
                      sudo chmod -R u+rwX,g+rwX,u+rx /var/log/redis
                      sudo chmod +r /etc/redis/redis.conf
                      Allerdings ohne Erfolg.
                      Thomas BraunT F 2 Antworten Letzte Antwort
                        #77
                        @dr-bakterius Da würde ich ja auch zunächst Mal schauen wem das Log mit welchen Rechten gehört. Dann kannst du halt da was ändern. Ich vermute ja immer noch eine fehlende Gruppenzugehörigkeit.
                        F Dr. BakteriusD 2 Antworten Letzte Antwort
                          F Online
                          F Online
                          fastfoot
                          #78
                          @dr-bakterius sagte in Auf redis umstellen:
                          probiere mal (ohne Gewähr)
                          sudo systemctl edit redis-server
                          [Service]
                          ProtectHome=no
                          Save and exit the editor
                            F Online
                            F Online
                            fastfoot
                            #79
                            @thomas-braun sagte in Auf redis umstellen:
                            er ist nicht iobroker, das würde sich erst beim Zugriff bemerkbar machen und ist dann evtl nochmal Thema. für jetzt startet der server erst gar nicht
                              Dr. Bakterius
                              schrieb am zuletzt editiert von Dr. Bakterius
                              #80
                              Es wird ja erst gar keine Log-Datei erstellt. Den Ordner habe ich mal als Test '777' zugewiesen - brachte aber auch nichts.
                              Danke, aber leider kein Erfolg.
                              F 1 Antwort Letzte Antwort
                                F Online
                                F Online
                                fastfoot
                                #81
                                das Logfile wird in der redis.conf konfiguriert. Standardmässig ist das der Standard Output, also kein File. Wenn als daemon gestartet gehen die Ausgaben ohne eine Angabe nach /dev/null
                                • F fastfoot
                                  Dr. Bakterius
                                  #82
                                  Also wird dieses File, auch wenn in der Config angegeben, nicht erstellt? Warum beschwert er sich dann, dass er darauf keinen Zugriff hat?
                                  Ich habe das File jetzt noch einmal erstellt und dem User 'redis' gegeben (wie auch der Ordner). Jetzt kommt keine Beschwerde wegen des Zugriffs. Aber funktionieren tut es trotzdem nicht.
                                  Was bedeutet: Failed to start Advanced key-value store. (wird mir jetzt beim Status ausgegeben)?
                                    F Online
                                    F Online
                                    fastfoot
                                    schrieb am zuletzt editiert von fastfoot
                                    #83
                                    doch, wenn angegeben schon! Stell mal das LOG-level auf warning. Evtl. hat redis keine Berechtigung?
                                    Schau mal noch hier, 2te Antwort, da wird Advanced....... als Beschreibung angegeben, wie bei dir. Seine Lösung war die ReadOnlyDirectory auszukommentieren
                                    • F fastfoot
                                      Dr. Bakterius
                                      #84
                                      @fastfoot @Thomas-Braun @Homoran
                                      Vielen Dank für eure Unterstützung. Das Problem ist erledigt! Die Lösung habe ich hier im Forum an anderer Stelle gefunden. Es lag an einer Proxmox-Einstellung für den LXC von ioBroker. Da muss man unter 'Features' 'Nesting' aktivieren. Ja ich weiß, mit einer VM wäre das nicht passiert... 🙄
                                      Thomas BraunT Master67M 2 Antworten Letzte Antwort
                                        #85
                                        @dr-bakterius
                                        Hmmmmmm. Komisch. Gerade gestern hat hier noch irgendwer erzählt, containern könnte jeder und es gäbe da eigentlich nie Probleme, die man nicht bei einer nativen Installation auch hätte.
                                        • F Online
                                          F Online
                                          fastfoot
                                          #86
                                          @dr-bakterius
                                          Ich hatte von Docker geredet, da ich lxc nicht auf dem Schirm hatte, da läuft das sofort. Und speziell meinte ich das buanet image, welches alle für iobroker notwendigen Einstellungen mitbringt. Gilt auch für das redis image :-) Hier wurde die Standard redis distro in einem container installiert. Und ja, meine Aussage war etwas allgemein, sonst bräuchte es ja keine Docker-, lxc- und auch Linuxspezialisten. Fallstricke gibt es immer...
