  4. Auf redis umstellen
Auf redis umstellen
100 Beiträge 11 Kommentatoren 20.4k Aufrufe 9 Beobachtet
    Noch ein Versuch - gleiches Ergebnis.
    sudo systemctl restart redis-server
    ergibt:
    Job for redis-server.service failed because the control process exited with error code.
    See "systemctl status redis-server.service" and "journalctl -xe" for details.
    ergibt:
    * redis-server.service - Advanced key-value store
       Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor preset: enabled)
       Active: failed (Result: exit-code) since Thu 2021-01-21 19:08:33 CET; 13s ago
         Docs: http://redis.io/documentation,
               man:redis-server(1)
      Process: 6559 ExecStart=/usr/bin/redis-server /etc/redis/redis.conf (code=exited, status=226/NAMESPA
    Und sudo journalctl -xe
    ergibt:
    -- Defined-By: systemd
    -- Support: https://www.debian.org/support
    -- The process /usr/bin/redis-server could not be executed and failed.
    -- The error number returned by this process is ERRNO.
    Jan 21 19:08:33 iobroker systemd[1]: redis-server.service: Control process exited, code=exited, status
    -- Subject: Unit process exited
    -- An ExecStart= process belonging to unit redis-server.service has exited.
    -- The process' exit code is 'exited' and its exit status is 226.
    Jan 21 19:08:33 iobroker systemd[1]: redis-server.service: Failed with result 'exit-code'.
    -- Subject: Unit failed
    -- The unit redis-server.service has entered the 'failed' state with result 'exit-code'.
    Jan 21 19:08:33 iobroker systemd[1]: Failed to start Advanced key-value store.
    -- Subject: A start job for unit redis-server.service has failed
    -- A start job for unit redis-server.service has finished with a failure.
    -- The job identifier is 674 and the job result is failed.
    Jan 21 19:08:33 iobroker systemd[1]: redis-server.service: Service RestartSec=100ms expired, schedulin
    Jan 21 19:08:33 iobroker systemd[1]: redis-server.service: Scheduled restart job, restart counter is a
    -- Subject: Automatic restarting of a unit has been scheduled
    -- Automatic restarting of the unit redis-server.service has been scheduled, as the result for
    -- the configured Restart= setting for the unit.
    Jan 21 19:08:33 iobroker systemd[1]: Stopped Advanced key-value store.
    -- Subject: A stop job for unit redis-server.service has finished
    -- A stop job for unit redis-server.service has finished.
    -- The job identifier is 715 and the job result is done.
    Jan 21 19:08:33 iobroker systemd[1]: redis-server.service: Start request repeated too quickly.
    -- The job identifier is 715 and the job result is failed.
    Der Ordner \var\log\redis ist leer.
    Jemand noch eine Idee?
    Dr. BakteriusD Offline
    Dr. Bakterius
    #76
    Mit /usr/bin/redis-server /etc/redis/redis.conf kann man ja die Config prüfen. Das ergibt:
    *** FATAL CONFIG FILE ERROR ***
    Reading the configuration file, at line 171
    >>> 'logfile /var/log/redis/redis-server.log'
    Can't open the log file: Permission denied
    Also folgendes gemacht:
    Eine leere redis-server.log erstellt und dann
    sudo chown -R redis:redis /var/log/redis
    sudo chmod -R u+rwX,g+rwX,u+rx /var/log/redis
    sudo chmod +r /etc/redis/redis.conf
    Allerdings ohne Erfolg.
    Thomas BraunT F 2 Antworten Letzte Antwort
      #77
      @dr-bakterius Da würde ich ja auch zunächst Mal schauen wem das Log mit welchen Rechten gehört. Dann kannst du halt da was ändern. Ich vermute ja immer noch eine fehlende Gruppenzugehörigkeit.
      F Dr. BakteriusD 2 Antworten Letzte Antwort
        F Online
        F Online
        fastfoot
        #78
        @dr-bakterius sagte in Auf redis umstellen:
        probiere mal (ohne Gewähr)
        sudo systemctl edit redis-server
        [Service]
        ProtectHome=no
        Save and exit the editor
          F Online
          F Online
          fastfoot
          #79
          @thomas-braun sagte in Auf redis umstellen:
          er ist nicht iobroker, das würde sich erst beim Zugriff bemerkbar machen und ist dann evtl nochmal Thema. für jetzt startet der server erst gar nicht
            Dr. Bakterius
            schrieb am zuletzt editiert von Dr. Bakterius
            #80
            Es wird ja erst gar keine Log-Datei erstellt. Den Ordner habe ich mal als Test '777' zugewiesen - brachte aber auch nichts.
            @fastfoot sagte in Auf redis umstellen:
            Danke, aber leider kein Erfolg.
            F 1 Antwort Letzte Antwort
              F Online
              F Online
              fastfoot
              #81
              das Logfile wird in der redis.conf konfiguriert. Standardmässig ist das der Standard Output, also kein File. Wenn als daemon gestartet gehen die Ausgaben ohne eine Angabe nach /dev/null
              Dr. BakteriusD 1 Antwort Letzte Antwort
              • F fastfoot
                Dr. Bakterius
                #82
                Also wird dieses File, auch wenn in der Config angegeben, nicht erstellt? Warum beschwert er sich dann, dass er darauf keinen Zugriff hat?
                Ich habe das File jetzt noch einmal erstellt und dem User 'redis' gegeben (wie auch der Ordner). Jetzt kommt keine Beschwerde wegen des Zugriffs. Aber funktionieren tut es trotzdem nicht.
                Was bedeutet: Failed to start Advanced key-value store. (wird mir jetzt beim Status ausgegeben)?
                  F Online
                  F Online
                  fastfoot
                  schrieb am zuletzt editiert von fastfoot
                  #83
                  doch, wenn angegeben schon! Stell mal das LOG-level auf warning. Evtl. hat redis keine Berechtigung?
                  Schau mal noch hier, 2te Antwort, da wird Advanced....... als Beschreibung angegeben, wie bei dir. Seine Lösung war die ReadOnlyDirectory auszukommentieren
                  • F fastfoot
                    Dr. Bakterius
                    #84
                    @fastfoot @Thomas-Braun @Homoran
                    Vielen Dank für eure Unterstützung. Das Problem ist erledigt! Die Lösung habe ich hier im Forum an anderer Stelle gefunden. Es lag an einer Proxmox-Einstellung für den LXC von ioBroker. Da muss man unter 'Features' 'Nesting' aktivieren. Ja ich weiß, mit einer VM wäre das nicht passiert... 🙄
                    Thomas BraunT Master67M 2 Antworten Letzte Antwort
                      #85
                      @dr-bakterius
                      Hmmmmmm. Komisch. Gerade gestern hat hier noch irgendwer erzählt, containern könnte jeder und es gäbe da eigentlich nie Probleme, die man nicht bei einer nativen Installation auch hätte.
                      • F Online
                        F Online
                        fastfoot
                        #86
                        @dr-bakterius
                        Ich hatte von Docker geredet, da ich lxc nicht auf dem Schirm hatte, da läuft das sofort. Und speziell meinte ich das buanet image, welches alle für iobroker notwendigen Einstellungen mitbringt. Gilt auch für das redis image :-) Hier wurde die Standard redis distro in einem container installiert. Und ja, meine Aussage war etwas allgemein, sonst bräuchte es ja keine Docker-, lxc- und auch Linuxspezialisten. Fallstricke gibt es immer...
                          @dr-bakterius
                          Dr. Bakterius
                          #87
                          Stimmt ja im Prinzip auch. War in über 18 Monaten das erste Problem mit LXC. USB-Gerät konnte ich durchreichen und sonst immer alles installieren. Natürlich ist eine VM einfacher. Aber die Vorteile von LXC überwiegen deren Nachteile. Wichtig ist, dass man eine Lösung findet und dafür sind Foren wie dieses spitze!
                          • apollon77A Offline
                            #88
                            So,jetzt mal gaaaanz langsam!!
                            Nicht gleich redis kaputt konfigurieren!
                            erstmal: Welche redis version ists überhaupt? Wie installiert? Istes ein Debian oder Ubuntu? AM besten Redis NICHT aus dem Standard Repo nehmen bei Ubuntu sondern aus dem chris-lea PPA
                              Master67M Offline
                              Master67M Offline
                              Master67
                              #89
                              Das habe ich nun schon ein paar mal gelesen, ist bei mir aber nicht Aktiv und ich nutze auch "redis"... komisch ;-)
                              Gruß Master67
                              Dr. BakteriusD W 2 Antworten Letzte Antwort
                              • Master67M Master67
                                Dr. Bakterius
                                #90
                                @master67 VM, LXC oder Docker?
                                Master67M 1 Antwort Letzte Antwort
                                  Master67M Offline
                                  Master67M Offline
                                  Master67
                                  #91
                                  @dr-bakterius LXC natürlich... siehe hier mal https://forum.iobroker.net/topic/39253/iobroker-auf-proxmox-installiert/61?_=1611244014875 wie das bei mir war :-)
                                  Gruß Master67
                                    Dr. Bakterius
                                    #92
                                    @master67 apt install software-properties-common hatte ich auch probiert um das Repository lt. Anleitung hinzufügen zu können. Hat bei mir aber auch nichts gebracht (außer noch mehr Fehlermeldungen).
                                      Master67M Offline
                                      Master67M Offline
                                      Master67
                                      schrieb am zuletzt editiert von Master67
                                      #93
                                      @dr-bakterius Okay... nutzt du Ubuntu o. Debian? Wenn Debian dann liegt ggf. darin der Unterschied
                                      127.0.0.1:XXXX> info
                                      # Server
                                      redis_version:6.0.6
                                      redis_git_sha1:00000000
                                      redis_git_dirty:0
                                      redis_build_id:d463d609620685c0
                                      redis_mode:standalone
                                      os:Linux 5.4.78-2-pve x86_64
                                      arch_bits:64
                                      multiplexing_api:epoll
                                      atomicvar_api:atomic-builtin
                                      gcc_version:9.3.0
                                      process_id:167
                                      run_id:62a07ff782195008fecc1a3f64cf6xxxxxxxxxxxxx
                                      tcp_port:6379
                                      uptime_in_seconds:202082
                                      uptime_in_days:2
                                      hz:10
                                      configured_hz:10
                                      lru_clock:684751
                                      executable:/usr/bin/redis-server
                                      config_file:/etc/redis/redis.conf
                                      Gruß Master67
                                        W Offline
                                        W Offline
                                        Wildbill
                                        schrieb am zuletzt editiert von Wildbill
                                        #94
                                        @master67 Ich meine, nesting muss nur bei unpriviligierten lxc aktiviert werden wenn man Zugriff auf bestimmte, ansonsten abgeschottete Funktionen des Host/Kernel braucht, z. B. für redis. Läuft iobroker eh schon in einem priviligierten ct, dann kann man nesting eh nicht aktivieren.
                                        Gruß, Jürgen
                                        • W Wildbill
                                          Gruß, Jürgen
                                          Master67M Offline
                                          Master67M Offline
                                          Master67
                                          #95
                                          @wildbill.... könnte so sein, mein ioBroker liefe ja schon lange als unpriviligierter LXC, das "nachträgliche" Installieren von redis war woll so kein Problem für meine Einrichtung des ioBrokers.
                                          Edit: Stopp meintest du nun schon "priviligierten" o. "unpriviligierten"... mein ioBroker lief und läuft "unpriviligiert"
                                          Gruß Master67
                                          W 1 Antwort Letzte Antwort
