  4. js-controller 3.2 jetzt im Latest!
    1.0k
575 Beiträge 70 Kommentatoren 189.4k Aufrufe 57 Beobachtet
    @master67
    Lösch mal den npm-cache
    cd /opt/iobroker
    npm cache clear --force
    Die logs liegen übrigens in /opt/iobroker/log
    Master67M Offline
    Master67M Offline
    Master67
    #82
    @thomas-braun sagte in js-controller 3.2 jetzt im Latest!:
    Das Ergebnis sieht so aus:
    npm WARN using --force I sure hope you know what you are doing.
    Der Log sieht so aus:
    2021-01-19 11:19:50.463  - ^[[32minfo^[[39m: host.ioBroker iobroker.js-controller version 3.2.7 js-controller starting
    2021-01-19 11:19:50.465  - ^[[32minfo^[[39m: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-01-19 11:19:50.466  - ^[[32minfo^[[39m: host.ioBroker hostname: ioBroker, node: v12.20.1
    2021-01-19 11:19:50.466  - ^[[32minfo^[[39m: host.ioBroker ip addresses: 192.168.178.XX fe80::8846:72ff:fe3a:8ae1
    2021-01-19 11:19:50.526  - ^[[32minfo^[[39m: host.ioBroker connected to Objects and States
    2021-01-19 11:19:50.550  - ^[[32minfo^[[39m: host.ioBroker added notifications configuration of host
    2021-01-19 11:19:51.229  - ^[[32minfo^[[39m: host.ioBroker 49 instances found
    2021-01-19 11:19:51.255  - ^[[32minfo^[[39m: host.ioBroker starting 36 instances
    2021-01-19 11:19:51.401  - ^[[32minfo^[[39m: host.ioBroker instance system.adapter.admin.0 started with pid 17266
    2021-01-19 11:19:52.053  - ^[[32minfo^[[39m: admin.0 (17266) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.20.1, js-controller: 3.2.7
    2021-01-19 11:19:52.082  - ^[[32minfo^[[39m: admin.0 (17266) requesting all states
    2021-01-19 11:19:52.082  - ^[[32minfo^[[39m: admin.0 (17266) requesting all objects
    2021-01-19 11:19:52.714  - ^[[32minfo^[[39m: admin.0 (17266) received all objects
    2021-01-19 11:19:52.811  - ^[[31merror^[[39m: admin.0 (17266) Cannot create webserver: Error: Please specify the email address and domains to use Let's Encrypt certifica>
    2021-01-19 11:19:52.812  - ^[[32minfo^[[39m: admin.0 (17266) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-01-19 11:19:53.450  - ^[[31merror^[[39m: host.ioBroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, befor>
    2021-01-19 11:19:53.451  - ^[[32minfo^[[39m: host.ioBroker Do not restart adapter system.adapter.admin.0 because desired by instance
    2021-01-19 11:19:55.264  - ^[[32minfo^[[39m: host.ioBroker instance system.adapter.email.0 started with pid 17281
    2021-01-19 11:19:55.774  - ^[[32minfo^[[39m: email.0 (17281) starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.email, node: v12.20.1, js-controller: 3.2.7
    2021-01-19 11:19:59.773  - ^[[32minfo^[[39m: vis.0 (17296) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.vis, node: v12.20.1, js-controller: 3.2.7
    2021-01-19 11:20:00.020  - ^[[32minfo^[[39m: vis.0 (17296) vis license is OK.
    2021-01-19 11:20:00.961  - ^[[32minfo^[[39m: vis.0 (17296) Terminated (NO_ERROR): Without reason
    2021-01-19 11:20:01.586  - ^[[32minfo^[[39m: host.ioBroker instance system.adapter.vis.0 terminated while should be started once
    2021-01-19 11:20:03.263  - ^[[32minfo^[[39m: host.ioBroker instance system.adapter.terminal.0 started with pid 17311
    2021-01-19 11:20:03.756  - ^[[32minfo^[[39m: terminal.0 (17311) starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.terminal, node: v12.20.1, js-controller: 3>
    2021-01-19 11:20:03.788  - ^[[32minfo^[[39m: terminal.0 (17311) http server listening on port 8090
    2021-01-19 11:20:07.387  - ^[[32minfo^[[39m: host.ioBroker instance system.adapter.web.0 started with pid 17326
    2021-01-19 11:20:07.934  - ^[[32minfo^[[39m: web.0 (17326) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.web, node: v12.20.1, js-controller: 3.2.7
    2021-01-19 11:20:08.368  - ^[[32minfo^[[39m: web.0 (17326) socket.io server listening on port 8082
    2021-01-19 11:20:08.369  - ^[[32minfo^[[39m: web.0 (17326) http server listening on port 8082
    2021-01-19 11:20:11.403  - ^[[32minfo^[[39m: host.ioBroker instance system.adapter.text2command.0 started with pid 17341
    2021-01-19 11:20:11.879  - ^[[32minfo^[[39m: text2command.0 (17341) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.text2command, node: v12.20.1, js-contr>
    2021-01-19 11:20:13.648  - ^[[32minfo^[[39m: web.0 (17326) ==>Connected system.user.admin from ::ffff:192.168.178.43
    2021-01-19 11:20:15.397  - ^[[32minfo^[[39m: host.ioBroker instance system.adapter.trashschedule.0 started with pid 17358
    2021-01-19 11:20:15.899  - ^[[32minfo^[[39m: trashschedule.0 (17358) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v12.20.1, js-con>
    2021-01-19 11:20:16.042  - ^[[32minfo^[[39m: web.0 (17326) ==>Connected system.user.admin from ::ffff:192.168.178.43
    Gruß Master67
    S apollon77A 2 Antworten Letzte Antwort
    • Master67M Master67
      Stoni
      #83
      Moin,
      meine ioB Installation läuft auf dem Pi4 seit langem sehr gut. Heute hatte ich mal etwas Zeit und habe die meisten, aus meiner Sicht wichtigen, Adapter auf den aktuellen Stand geupdatet.
      Jetzt habe ich noch den JS-Controller 2.1.1. laufen und dachte, den könnte ich ja auch mal auf updaten. Ich erinnere mich aber noch an das letzte Mal, als ich mir das gesamte System zerschossen habe und alle von Grund auf neu installieren musste.
      Ein Backup habe ich mit backitup erstellt. Kann ich gefahrlos updaten? Ist das update überhaupt erforderlich und muss ich es aus der Konsole machen oder geht das auch irgendwie in der ioB Oberfläche?
      VG Stoni
      UncleSamU 1 Antwort Letzte Antwort
      • S Stoni
        Moin,
        VG Stoni
        UncleSamU Offline
        UncleSamU Offline
        UncleSam
        #84
        @stoni sagte in js-controller 3.2 jetzt im Latest!:
        Auf die Stable (3.1) ja, auf die Latest (3.2) nein! Mach das nicht mit einem Produktivsystem, wenn du ioBroker nicht 100% unter Kontrolle hast.
        Geht nur mit der Konsole. Aber wie gesagt: wenn du diese Frage stellen musst, dann bitte nur auf eine Stable Version!
        Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
        ♡-lichen Dank an meine Sponsoren
        • apollon77A apollon77
          Hallo ioBroker-Community,
          mit etwas zeitlicher Verspätung, dafür aber um so besser, kommt heute der neue js-controller 3.2 (Releasename "Grace") ins Latest Repository (sollte im laufe des Abends bei allen auftauchen). Ein großer Dank geht an alle User die bereits in den Letzten Tagen diese Version im Beta test getestet und Probleme und Fehler zur Behebung gemeldet haben!
          Node.js Versions-Anforderungen
          Die unterstützten Node.js Versionen bleiben in diesem Update gleich: 10.x, 12.x und auch 14.x werden offiziell unterstützt. Aufgrund der übergreifenden Adapter-Kompatibilität bleibt die empfohlene Node.js Version für ioBroker aktuell weiterhin auf 12.x. Falls jemand wirklich mit Node.js 15.x experimentieren will, dann bitte AUSSCHLIESSLICH mit npm 6 !! (die npm Leute haben in npm 7 wieder Dinge geändert, die wir noch untersuchen)
          Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/post/266625
          Informationen zur Version
          Neben einigen Features haben wir unter der Haube weiter aufgeräumt und sehr viel modernisiert und vereinheitlicht.
          Auch daran den Wildwuchs in der Umsetzung einiger Adapter etwas einzugrenzen wurde weiter gearbeitet, was ggf. zu neuen Log-meldungen für bestimmte Fälle führt. Bitte unterstützt hier wieder und legt bei den relevanten Adaptern im GitHub Issues an, damit diese Dinge gefixt werden können.
          Besonders zu erwähnen ist die Grundlage für das neue Benachrichtigungssystem (kommt dann in einem Admin-Update) und die Reaktivierung von Let's Encrypt zur automatischen Zertifikatsaktualisierung.
          Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog. Ich hoffe auch diesmal auf Eure tatkräftige Unterstützung, sodass der Latest-Release dann genau so reibungslos verläuft wie bei den letzten Versionen.
          In Summe sind in diese Version über 650 commits eingeflossen. Dafür bedenke mich diesmal besonders bei foxriver76, AlCalzone und natürlich Bluefox und auch ein paar weiteren Entwicklern für die aktive Mitarbeit an dieser Version!
          Der js-controller 3.2 ist generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2 ist problemlos möglich. Nur die Node.js Version muss jetzt mindestens 10.x sein, wie oben bereits ausgeführt. Wer überlegt die Node.js Version anzuheben bitte weiter unten im Abschnitt "Was ist zu testen" lesen 🙂
          Es gibt aktuell keine inkompatiblem Adapter, aber einige Empfehlungen weiter unten.
          Installation
          VOR der Installation
          Wie bei jedem Test dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt. Die alte Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version installiert werden und sollte alles wieder herstellen.
          Nötige Adapter-Aktualisierungen
          Aktuell sind keine Inkompatibilitäten bekannt, damit allerdings Let's encrypt wieder funktioniert benötigt es einige Adapter in "Latest" Versionen von mindestens:
          • ioBroker.lovelace 1.4.1 oder höher
          • ioBroker.simple-api 2.5.2 oder höher
          • ioBroker.socketio 3.1.3 oder höher
          • ioBroker.telegram 1.7.0 oder höher
          • ioBroker.web 3.2.2 oder höher
          • ioBroker.admin 4.2.1 oder höher
          Es werden aber, wie oben ausgeführt, einige Adapter ggf Warnungen ins Log schreiben. Falls das Problematisch ist ist aktuell die einzige Option das Loglevel der Instanz auf "Error" zu setzen.
          Achtung: MASTER-Systeme Reihenfolgen beachten!
          Bei einem Multi-Host-System, welches auf js-controller 2.2 oder 3.1 läuft ist es beim Update auf Version 3.2 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
          Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher auf die 3.2 müssen zwingend zuerst die Slaves und der Master als letztes aktualisiert werden. Beim Slave Updat emuss der alte master aber noch laufen. Die Slaves bleiben nach dem Update offline und können sich nicht zum Master verbinden und werden erst wieder funktionieren wenn auch der Master auf die 3.2 aktualisiert wurde!
          Windows
          Auf Systemen, die mit dem neuen Windows Installer eingerichtet wurden weiss ich gerade nicht wie der aktuelle Prozess ist, da der Windows installer nicht ganz aktuell ist. Bitte hier berichten dann kann ich ergänzen.
          Für alle "alten manuellen" Installationen gilt
          • ioBroker muss gestoppt sein.
          • Vor dem Update bitte prüfen das keine Prozesse mehr laufen
          • iobroker update
          • iobroker upgrade self
          • ioBroker starten
          Linux
          • ioBroker stoppen (iobroker stop)
          • prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup ). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
          • iobroker update
          • Wie üblich wird das Update dann per iobroker upgrade self ausgeführt.
          • ioBroker starten (iobroker start)
          Bei Fehlern:
          Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x oder höher hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
          Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
          NACH der Installation
          Nach der Installation den ioBroker wieder starten (z.B. mittels iobroker start).
          Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
          Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
          Mit iobroker help wird eine Liste der möglichen Kommandozeilen-Kommandos angezeigt, die mit Version 2.0 um einige Befehle länger geworden ist. Es geht jetzt auch Kommandospezifisch Hilfe zu erhalten (iobroker upgrade --help)
          Was hat sich geändert, was besonders ansehen/beachten?
          Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
          • generell siehe Changelog, speziell auch für Features
          • Let's Encrypt sollte wieder tun. Minimum Adapterversionen dazu siehe weiter oben!
          • Einige Adapter werden Warnungen ausgeben wenn State-Werte gesetzt werden VOR dem Anlegen von Objekten. Bitte bei den Adapter-Repos melden
          Speziell die Entwickler sollten bitte die genannten Deprecations anschauen und beachten
          Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
          BREAKING CHANGES
          • None, Supported are nodejs 10.x, 12.x and 14.x (Node.js 15.x is also working WHEN USED WITH npm 6!! in the automated tests, but formally not supported)
          • If you have enabled Multihost Discovery please disable and enable it again if you really need it persistant running. By re-enabling it you update the used passphrase with a better encryption mechanism.
          Features
          • (raintonr) Update Let's encrypt implementation; all relevent adapters (web and such) need updates to use it! NEEDS NODE.JS 12.x+! (see DOCS LINK TODO)
          • (bluefox) Restart adapters that use Let's encrypt after certificates were updated
          • (bluefox) Provide min/max for convert alias functions
          • (foxriver76) handling major adapter upgrades more carefully (CLI on upgrade will show if it's a major upgrade and major upgrades will be skipped on upgrade all when executed by admin
          • (AlCalzone) detect and allow short github URL format when (auto-)installing adapters (iobroker url User/repo#branchorcommit)
          • (foxriber76) Add notification system (see DOCS LINK TODO)
          • (foxriver76) enhance setup (and setup first) with redis to all port configuration
          • (foxriver76) set connectionName for redis connections and simulator support (see DOCS LINK TODO)
          Optimizations and Fixes
          • (foxriver76) Detect adapter restart loops and stop restarting after 3 crashes (an adapter is considered "working" when no crash by an exception happens within 10 minutes)
          • (foxriver76) Fix failed logins if username is uppercase, be reworking user logic and caching
          • (bluefox) Set for def states the quality: QUALITY_SUBS_INITIAL
          • (AlCalzone) fix npm uninstall loglevel argument
          • (foxriver76) delete pids.txt when iobroker was stopped
          • (bluefox) Add missing attributes by multihost if Redis is used for objects/states, Remove unused settings from iobroker-dist.json, Remove pass and user from connection settings. Use options.auth_pass
          • (AlCalzone) Package-Manager: log which packages were (already) installed
          • (foxriver76) replace redis "KEYS" command by "SCAN" to optimize redis access performance
          • (foxriver76) optimize redis library usage to prevent errors on redis outages
          • (bluefox) Catch errors by plugins load. At least log will work and could be checked for errors.
          • (foxriver76) allow migration of instances to already existing host
          • (foxriver76) also allow <adapter>.<instance-nr> for install/add cli command
          • (AlCalzone) buffer streams that are piped to stdout to fix weird Windows logging cases
          • (foxriver76/AlCalzone) Optimize upgrade/downgrade logic for adapters, ask for a downgrade only if lower version is to be installed
          • (foxriver76) allow redis redis migration when changing host of redis - fix bug where process crashes when controller is running when migrating
          • (bluefox) Catch errors for subscribe on alias without target
          • (foxriver76) only perform auto scaling on alias if not null
          • (foxriver76) if repository request fails also use cached sources on updating repository
          • (foxriver76) prevent host deletion from same host - otherwise it will remove the system.host states but instances will still be on the removed host, because transfer happens to itself
          • (foxriver76) use instanceObjects from system.adapter.* object instead from io-package.json
          • (foxriver76) notify of errors on readFileCertificates to show permission problems etc.
          • (foxriver76) multihost discovery now logs ignored messages on debug and also logs the senders address
          • (foxriver76) sync up created objects on instance start and instance creation by using helper function in tools.js, e.g. .loglevel was missing on instance creation
          • (bluefox) Package-Manager: Filter empty packets out to suppress error message
          • (foxriver76) rename repository names for new installations and on updates to beta/stable
          • (foxriver76) rewrite collectDiagInfo to Promises and fix minor issue with it
          • (foxriver76) only scale aliases if target or source is represented by unit %
          • (foxriver76) create meta.user on file sync cli, if not existing (see DOCS LINK TODO)
          • (Apollon77) also create meta.user on setup first if not existing
          • (foxriver76) fix enumInstances used by CLI commands
          • (foxriver76) when missing rights to access log dir do not crash hard anymore, instead fallback to default directory
          • (bluefox) Fix error if type of native data changed in the new version from basic type e.g. 'string' to 'object'.
          • (AlCalzone) Remove hardcoded references to GitHub master branch because newer repositories use "main"
          • (Apollon77) update _design objects also on js-controller upgrade/setup first
          • (Apollon77) optimize deletion of files in ioBroker file storage
          • (foxriver76) do not return an error if object does not exist on del*Object
          • (Apollon77) optimize logs when instance is restarted
          • (foxriver76) Preserve name field on instance object creation/update
          • (foxriver76) optimize parameters and flags on CLI
          • (foxriver76) Use yargs helper instead of building our own string output to allow showing --help for a specific command instead of the whole output and allow support for auto completion (iobroker _createCompletion >> ~/.bashrc)
          • (foxriver76, Apollon77) also accept pre-release version in some semver checks for dependencies
          • (foxriver76) replace outdated encryption mechanism of multihost
          • (Apollon77, foxriver, bluefox, AlCalzone) Several fixes and refactorings to prevent potential crash cases reported by Sentry and other sources
          Developer relevant DEPRECATIONS/WARNINGS
          • (foxriver76) we warn if object not exists when setting a state via adapter.setState. Adjust your code that a state value is NOT set before the object is successfully created. If this deep check is NOT wanted for performance reasons the adapter needs to be initialized with strictObjectChecks = false!! (see DOCS LINK TODO)
          • (foxriver76) readFile should not validate meta object, we now throw on writeFile if id is no valid meta object
          • (AlCalzone) update Forbidden ID Characters: use Unicode properties to define which characters are allowed instead of blacklisting. For ASCII the allowed characters are the same as before - for other languages mainly character class of Unicode are allowed! (see DOCS LINK TODO)
          • (foxriver76) Throw on invalid setState objects; was logged as deprecated before
          • (foxriver76) remove getMessage shim, no adapter uses it anymore; was logged as deprecated before
          Developer relevant new Features
          • (foxriver76) use aes-192-cbc as encryption - backward compatible with current encryption, nothing to do for adapter-developers (see DOCS LINK TODO)
          • (bluefox) Add system view to filter for "folder" objects
          • (bluefox) add set/clearTimeout and set/clearInterval to adapter methods and check on unload that they were all cleared and clear if needed with logging, so developers are reminded to clean up!
          • (AlCalzone) Add ...Async version for getChannels - make sure to check before using or use correct js-controller version dependency!
          • (Apollon77) modularize databases into own npm packages and basically support adding new types of databases; add deprecation infos and logging to "old legacy" files in lib/states and lib/objects to not be used anymore; requires mostly updates in testing (see DOCS LINK TODO)
          • (foxriver76) allow to specify the instance for debug starts (iobroker debug adaptername.1)
          • (foxriver76) Enhance extendObject to allow to preserve specified fields (e.g. common.name)
          Developer relevant Optimizations and Fixes
          • (foxriver76) implement maybeCallback and maybeCallbackWithError and use it in adapter.js
          • (AlCalzone) use fs-extra instead of mkdirp
          • (AlCalzone) read JSON files using fs-extra's readJSONSync
          • (AlCalzone) fix callback definitions in adapter.js, We have signatures for (almost) everything in @types/iobroker and we should use them
          • (AlCalzone) move from Promises to async/await in some places, use a single readyPromise instead of an array
          • (bluefox) Added "http" and "stream" options for logs
          • (foxriver76) migrated ci tests to github actions
          • (foxriver76) resolve adapter main file as tools.js method
          • (foxriver76) optimize extendObject with def value
          • (AlCalzone) Handle existing, but undefined properties in validateSetStateObjectArgument
          • (foxriver76) also escape + char on regex, it's not forbidden
          • (bluefox) Set default state only for objects of type "state"
          • (AlCalzone) include folders in the result of getAdapterObjects
          • general dependency updates
          • code style optimizations
          Generell ist zu testen, ob alles noch so funktioniert wie vorher auch. Das ist das wichtigste!
          Wie Fehler melden?
          Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
          Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
          Wir wünschen allen viel Spaß beim Testen und vielen Dank für Eure Unterstützung!
          Ingo
          peterbaumertP Offline
          peterbaumert
          #85
          @apollon77
          Hi Zusammen,
          komme seit dem update nicht mehr auf die HTTPS admin Instanz:
          Malformed HTTP Header: 'Host: iobroker.xxx:8081'
          Let's Encrypt Zertifikat geht aber, kann sehen, dass er das aktualisierte geladen hat im Browser.
          LG
          Pete
          UncleSamU apollon77A 2 Antworten Letzte Antwort
          • peterbaumertP peterbaumert
            @apollon77
            Hi Zusammen,
            LG
            Pete
            UncleSamU Offline
            UncleSamU Offline
            UncleSam
            #86
            @peterbaumert Sieht nach diesem Fehler aus. Kannst du etwas mehr über dein Setup sagen? Hast du noch einen Reverse Proxy davor oder leitest du direkt :8081 von aussen weiter? Oder greifst du lokal auf deinen Host zu und hast eine lokale DNS-Auflösung?
            peterbaumertP 1 Antwort Letzte Antwort
            • UncleSamU UncleSam
              peterbaumert
              schrieb am zuletzt editiert von peterbaumert
              #87
              @unclesam danke für den Link.
              Nein ich habe keinen reverse Proxy laufen. Also nicht für lokal, da greife dich direkt darauf zu mit lokaler DNS-Auflösung genau.
              Ist ein debian vm auf einem ESXi mit Node14, brauchst du noch weitere infos?
              Wenn ich port auf 443 ändere geht es wirklich.
              UncleSamU 2 Antworten Letzte Antwort
                UncleSamU Offline
                UncleSamU Offline
                UncleSam
                #88
                @peterbaumert sagte in js-controller 3.2 jetzt im Latest!:
                Und du hast auch schon meinen nächsten Vorschlag erahnt :D
                Nein, danke, ich glaube wir haben alle Infos, sonst komme ich nochmals auf dich zu.
                  UncleSamU Offline
                  UncleSamU Offline
                  UncleSam
                  #89
                  @peterbaumert Ich habe das eben mit unserem Let's Encrypt Spezialisten angeschaut ;-) Fazit: Greenlock (unsere LE-Library) unterstützt das leider in der neuen Version nicht mehr. Wie du schon erkannt hast: Port 443 geht, ich hoffe du kannst damit leben.
                    peterbaumert
                    #90
                    @unclesam Ja habe damit an sich kein Problem :D wollte auch nur melden damit man darauf hinweissen kann :)
                    • sigi234S sigi234
                      @apollon77
                      Läuft. 👍
                      klassisch
                      #91
                      @sigi234 sagte in js-controller 3.2 jetzt im Latest!:
                      @apollon77
                      Läuft. 👍
                      Wie aktualisiert? Mit dem workaround von AlCalzone?
                      • K klassisch
                        @apollon77
                        Läuft. 👍
                        sigi234S Online
                        sigi234S Online
                        #92
                        @klassisch sagte in js-controller 3.2 jetzt im Latest!:
                        @apollon77
                        Läuft. 👍
                        iobroker stop
                        Iobroker update
                        Iobroker upgrade self
                        iobroker start
                        • sigi234S sigi234
                          @apollon77
                          Läuft. 👍
                          iobroker stop
                          Iobroker update
                          iobroker start
                          klassisch
                          #93
                          iobroker stop
                          Iobroker update
                          iobroker start
                          Danke, war das eine Installation vom Installer oder eine manuelle Installation?
                          • K klassisch
                            iobroker stop
                            Iobroker update
                            iobroker start
                            sigi234S Online
                            sigi234S Online
                            #94
                            iobroker stop
                            Iobroker update
                            iobroker start
                            Installer
                            • sigi234S sigi234
                              iobroker stop
                              Iobroker update
                              iobroker start
                              Installer
                              klassisch
                              #95
                              @sigi234 super, vielen Dank!
                              • Tom SonT Offline
                                Tom SonT Offline
                                Tom Son
                                #96
                                Hi all
                                ich weiss nicht wo ich das schreiben soll, aber seit dem Update bekomme ich laufend diese Warnung im Log:
                                web.0 State "nothing_selected" has no existing object, this might lead to an error in future versions
                                Was kann ich hier tun?
                                TI Board CC2652R1 / latest / js-Controler 3.3.18 / NodeJS 12.22.7
                                  Installation
                                  Windows
                                  • iobroker update
                                  • ioBroker starten
                                  Linux
                                  • iobroker update
                                  Bei Fehlern:
                                  BREAKING CHANGES
                                  Features
                                  Wie Fehler melden?
                                  Ingo
                                  #97
                                  @apollon77
                                  Eine Änderung von states.writeFileInterval in der Datei "conf/iobroker-dist.json" hat keinen Einfluss auf das tatsächliche Schreibintervall von 30 s.
                                  Ich finde keine Datei mehr, in der das Schreibintervall ausgeführt wird?
                                  foxriver76F apollon77A 3 Antworten Letzte Antwort
                                    @apollon77
                                    foxriver76F Offline
                                    foxriver76F Offline
                                    foxriver76
                                    #98
                                    @paul53 ist jetzt im Modul @iobroker/db-states-file
                                    Videotutorials & mehr
                                    • foxriver76F foxriver76
                                      #99
                                      @foxriver76 sagte:
                                      Wo findet man das Modul?
                                      MalleRalleM 1 Antwort Letzte Antwort
                                        @foxriver76 sagte:
                                        MalleRalleM Offline
                                        MalleRalleM Offline
                                        MalleRalle
                                        #100
                                        /opt/iobroker/node_modules/@iobroker/db-objects-file
                                        • MalleRalleM MalleRalle
                                          #101
                                          @malleralle
                                          Danke. Eine Änderung in der Datei
                                          /opt/iobroker/node_modules/@iobroker/db-states-file/lib/states/statesInMemFileDB.js
                                          zeigt Wirkung.
                                          foxriver76F apollon77A 2 Antworten Letzte Antwort
