  4. Beta Test js-controller 3.2.x auf GitHub
js-controller
287 Beiträge 25 Kommentatoren 125.2k Aufrufe 29 Beobachtet
    so, hab es auch mal gewagt😊
    alles soweit geklappt, die üblichen Meldungen für die jeweiligen Adapter, falls noch nicht bekannt, bzw dann dort direkt melden?
    state"alexa.....has no existing object, this might lead to an error in future versions
    state"tankerkönig...
    state"shuttercontrol...
    (26808) State "wiffi-wz.0.info.connection" has no existing object, this might lead to an error in future versions
    was ich aber nicht ganz verstehe, erreichbar ist das Gerät, allerdings war das Gerät dieses Jahr noch nicht an
    virtualpowermeter.0	2021-01-16 12:05:38.265	error	(26729) Could not check object existence of sonoff.0.Luefter.Virtual_Energy_Power: Error: Cannot check object existence of "sonoff.0.Luefter.Virtual_Energy_Power": Error: Connection is closed.
    virtualpowermeter.0	2021-01-16 12:05:38.265	error	at Virtualpowermeter.setForeignObjectNotExists (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3350:30)
    virtualpowermeter.0	2021-01-16 12:05:38.265	error	at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2252:17)
    virtualpowermeter.0	2021-01-16 12:05:38.265	error	(26729) Error: Could not check object existence of sonoff.0.Luefter.Virtual_Energy_Power: Error: Cannot check object existence of "sonoff.0.Luefter.Virtual_Energy_Power": Error: Connection is closed.
    virtualpowermeter.0	2021-01-16 12:05:38.263	error	(26729) unhandled promise rejection: Could not check object existence of sonoff.0.Luefter.Virtual_Energy_Power: Error: Cannot check object existence of "sonoff.0.Luefter.Virtual_Energy_Power": Error:
    virtualpowermeter.0	2021-01-16 12:05:38.262	error	(26729) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    virtualpowermeter.0	2021-01-16 12:05:38.254	error	(26729) Cannot check object existence of "sonoff.0.Luefter.Virtual_Energy_Power": Error: Connection is closed.
    virtualpowermeter.0	2021-01-16 12:05:38.095	error	(26729) Cannot find view "system" for search "enum" : Error: Connection is closed.
    virtualpowermeter.0	2021-01-16 12:05:36.997	warn	(26729) Terminated (UNCAUGHT_EXCEPTION): Without reason
    virtualpowermeter.0	2021-01-16 12:05:36.397	error	(26729) Cannot read property 'id' of undefined
    virtualpowermeter.0	2021-01-16 12:05:36.396	error	at Virtualpowermeter.onStateChange (/opt/iobroker/node_modules/iobroker.virtualpowermeter/main.js:70:18)
    virtualpowermeter.0	2021-01-16 12:05:36.396	error	at Virtualpowermeter.setPower (/opt/iobroker/node_modules/iobroker.virtualpowermeter/main.js:131:55)
    virtualpowermeter.0	2021-01-16 12:05:36.396	error	(26729) TypeError: Cannot read property 'id' of undefined
    virtualpowermeter.0	2021-01-16 12:05:36.395	error	(26729) unhandled promise rejection: Cannot read property 'id' of undefined
    virtualpowermeter.0	2021-01-16 12:05:36.387	error	(26729) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    apollon77A
    apollon77A
    #248
    @crunchip Am besten solche Fehler beim Adapter melden.
    Am Ende ist:
    • Fehlendes objekt ... es fehlt hat :-) muss man anlegen (also der Adapter)
    • sonoff.0 Ist recht wenig log, aber hier wurde ein State abgefragt als die DB Verbindung (schon? beim beenden) weg war ... sieht auch nach adpter issue aus das code noch läuft nachdem unload aufgerufen wurde
    • virtualpowermeter auch eher fehlendes Fehlerhanding im Adapter
    • apollon77A apollon77
      Am Ende ist:
      crunchipC
      crunchipC
      Developer Global Moderator Most Active Forum Testing
      #249
      @apollon77 said in Beta Test js-controller 3.2.x auf GitHub:
      ich wüsste nicht welches?? is ja alles da
      ansonsten..., mach ich und danke für die Rückmeldung👍
      • apollon77A
        apollon77A
        #250
        So, waren doch noch ein paar Kleinigkeiten: 3.6.2-3 auf npm
        Installation per `npm i iobroker.js-controller@next' oder wie oben beschrieben.
        3.2.6-3 (2021-01-16)
        • (foxriver76) fix upgrade/upload commands
        • (foxriver76) Preserve name field on instance object creation/update
        • (foxriver76) Enhance extendObject to allow to preserve specified fields (e.g. common.name)
        • (Apollon77) Some more optimizations
        • (Apollon77) update sentry plugin
          @lobomau Ja, leider ein Admin issue und ja passiert nurbei den Prerelease versionen.
          neben dem von @sigi234 prüft wohl die Kachel ansicht auch keine Update Deps ;-)
          Aber ja nächstes ist Ja Latest und das wird die 3.2.7 (ok, vllt morgen früh noch ne 3.2.6-2 mit kleinkram)
          mrbungle64M
          mrbungle64M
          mrbungle64
          #251
          Hallo @apollon77
          gilt für die folgende Warnung das gleiche?
          admin.0	2021-01-16 12:14:56.394	warn	(6735) Error on version check for ecovacs-deebot: TypeError: Invalid Version: 1.0.10.alpha.0
          Die Angabe in io-package.json und package.json ist identisch - das scheint also nicht der Grund zu sein.
            Hallo an die Testerrunde, passend zum Wochenende mit mehr Zeit zum testen habe ich die 3.2.6-1 (aka Latest RC1) für Euch.
            Am Ende sollte diese Version so komische Error-Loops beim beenden von Adaptern vermeiden wie etwas weiter oben berichtet wurden (also die die dann CPU 100% hatten). Also bitte checkt:
            • generell adapter start, stop, restart, auch mal schnell hinterienander oder so. Auftretende Fehler werden ggf nur als "info" geloggt
            • gern nochmal check der CLI kommandos die Ihr so nutzt, vor allem wenn Sie Parameter brauchen
            Änderungen sind kleinere Optimierungen:
            • (foxriver76) propagate error on sendTo methods to prevent exception loops
            • (foxriver76) optimize parameters and flags on CLI
            • (foxriver76) Use yargs helper instead of building our own string output to allow showing --help for a specific command instead of the whole output and allow support for auto completion (iobroker _createCompletion >> ~/.bashrc)
            • (Apollon77) Do not reject the promise when no callback is used and a Database error occurs
            Vielen Dank für Eure Unterstützung.
            Ingo F
            crunchipC
            crunchipC
            #252
            ansonsten wollte ich das noch nachfragen, ob das so in Ordnung ist?, war allerdings vorher dem controller upgrade auch schon so
            host.IoBroker	2021-01-16 13:04:53.974	info	instance system.adapter.influxdb.1 started with pid 19412
            host.IoBroker	2021-01-16 13:04:50.992	info	Do not restart adapter system.adapter.influxdb.1 because desired by instance
            host.IoBroker	2021-01-16 13:04:50.991	error	instance system.adapter.influxdb.1 terminated by request of the instance itself and will not be restarted, before user restarts it.
            host.IoBroker	2021-01-16 13:04:49.532	info	stopInstance system.adapter.influxdb.1 (force=false, process=true)
            • mrbungle64M mrbungle64
              Hallo @apollon77
              apollon77A
              apollon77A
              #253
              @mrbungle64 eine solche Versionsnummer ist generell nicht "semanti" und damit ungültig ... Adapter entwickler muss das fixen oder du kannst manuell (io-)package.json oder so editieren. Muss eher 1.0.10-alpha.0 heissen
              mrbungle64M 1 Antwort Letzte Antwort
                apollon77A
                apollon77A
                #254
                @crunchip Was ist die Aktion die dazu führte? Ein restart manuell per Admin oder was?
                  mrbungle64M
                  mrbungle64M
                  mrbungle64
                  schrieb am zuletzt editiert von mrbungle64
                  #255
                  Stimmt! sorry, mein Fehler :man-facepalming: sollte ja auch 1.0.10-alpha.0 sein ...
                  Hatte das übersehen, dass ich aus Versehen einen Punkt statt dem Bindestrich verwendet hatte
                    crunchipC
                    crunchipC
                    #256
                    @apollon77 wenn ich die Instanz neu lade, oder die Konfig aufrufe, etwas ändere und auf speichern/schliessen drücke
                    apollon77A 2 Antworten Letzte Antwort
                      apollon77A
                      apollon77A
                      #257
                      @crunchip Ja da sind die Meldungen etwas unglücklich, aber ja ist ok ... am Ende heisst es nur das der controller die instanz zum beenden auffordert was Sie auch tut ... dann startet controller direkt neu ... Mal schauen
                      • FeuersturmF Feuersturm
                        @apollon77 Update lief erfolgreich durch. Alle Instanzen sauber gestartet. Mal sehen was jetzt mein DWD Adapter macht :-)
                        FeuersturmF
                        FeuersturmF
                        Feuersturm
                        #258
                        @feuersturm said in Beta Test js-controller 3.2.x auf GitHub:
                        @apollon77 bisher verhält sich das System mit aktivem DWD Adapter ruhig. Das Update 3.2.6-1 hat wohl geholfen.
                          apollon77A
                          apollon77A
                          #259
                          @crunchip 3.2.6-4 verfügbar da ist das Logging optimiert dafür. Danke!
                            crunchipC
                            crunchipC
                            #260
                            @apollon77 erledigt, sieht jetzt so aus, bei nem Neustart der Instanz
                            host.IoBroker	2021-01-16 15:23:47.645	info	instance system.adapter.influxdb.1 started with pid 19424
                            host.IoBroker	2021-01-16 15:23:44.654	info	Adapter system.adapter.influxdb.1 will be restarted automatically
                            host.IoBroker	2021-01-16 15:23:44.653	error	instance system.adapter.influxdb.1 terminated for restart.
                            host.IoBroker	2021-01-16 15:23:42.623	info	stopInstance system.adapter.influxdb.1 (force=false, process=true)
                            nachdem iobroker neu gestartet wurde, diesmal...
                            virtuellpower kam nun ohne den sonoff Kram(issue ist aber schon angelegt)
                            host.IoBroker	2021-01-16 15:13:56.361	error	instance system.adapter.virtualpowermeter.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            virtualpowermeter.0	2021-01-16 15:13:53.055	warn	(14200) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            virtualpowermeter.0	2021-01-16 15:13:52.298	error	(14200) Cannot read property 'group' of undefined
                            virtualpowermeter.0	2021-01-16 15:13:52.298	error	(14200) TypeError: Cannot read property 'group' of undefined at Virtualpowermeter.onStateChange (/opt/iobroker/node_modules/iobroker.virtualpowermeter/main.js:72:51)
                            virtualpowermeter.0	2021-01-16 15:13:52.297	error	(14200) unhandled promise rejection: Cannot read property 'group' of undefined
                            virtualpowermeter.0	2021-01-16 15:13:52.296	error	(14200) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            zuvor beim Beenden vom iobroker
                            radar2
                            radar2.0	2021-01-16 15:08:44.012	warn	(20289) Uncaught Exception: Cannot read property 'init' of null
                            radar2.0	2021-01-16 15:08:44.011	info	(20289) sendToHost not processed because States database not connected
                            radar2.0	2021-01-16 15:08:44.010	error	(20289) Cannot read property 'init' of null
                            radar2.0	2021-01-16 15:08:44.010	error	at processTimers (internal/timers.js:497:7)
                            radar2.0	2021-01-16 15:08:44.010	error	at listOnTimeout (internal/timers.js:554:17)
                            radar2.0	2021-01-16 15:08:44.010	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.radar2/myNetworks.js:964:82)
                            radar2.0	2021-01-16 15:08:44.010	error	(20289) TypeError: Cannot read property 'init' of null
                            radar2.0	2021-01-16 15:08:44.009	error	(20289) uncaught exception: Cannot read property 'init' of null
                            broadlink
                            broadlink2.0	2021-01-16 15:08:43.892	info	(21635) sendToHost not processed because States database not connected
                            broadlink2.0	2021-01-16 15:08:43.892	error	(21635) Cannot read property '78:0f:77:19:f8:fc' of null
                            broadlink2.0	2021-01-16 15:08:43.892	error	at UDP.onMessage [as onmessage] (dgram.js:921:8)
                            broadlink2.0	2021-01-16 15:08:43.892	error	at Socket.emit (events.js:314:20)
                            broadlink2.0	2021-01-16 15:08:43.892	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:45:12)
                            broadlink2.0	2021-01-16 15:08:43.892	error	at Udp.emit (events.js:314:20)
                            broadlink2.0	2021-01-16 15:08:43.892	error	at Udp.<anonymous> (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:2046:43)
                            broadlink2.0	2021-01-16 15:08:43.892	error	at Broadlink.parsePublic (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:1990:24)
                            broadlink2.0	2021-01-16 15:08:43.892	error	(21635) TypeError: Cannot read property '78:0f:77:19:f8:fc' of null
                            broadlink2.0	2021-01-16 15:08:43.891	error	(21635) uncaught exception: Cannot read property '78:0f:77:19:f8:fc' of null
                              radar2
                              broadlink
                              apollon77A
                              apollon77A
                              #261
                              @crunchip Und all diese Fehler beim beenden der Adapter? ggf dort issues anlegen
                              crunchipC FeuersturmF K 3 Antworten Letzte Antwort
                                crunchipC
                                crunchipC
                                #262
                                ja beim beenden,
                                mach ich
                                  FeuersturmF
                                  FeuersturmF
                                  Feuersturm
                                  #263
                                  @apollon77 Ich hatte heute Nacht mit der 3.2.6-1 gesehen, dass der unifi Adapter auch errors mit Unhandled promise rejection. und instance system.adapter.unifi.0 terminated with code 6 (UNCAUGHT_EXCEPTION) wirft. Aufgefallen ist es dadurch, dass der unifi container unter proxmox Nachts gebackupt wird und daher für eine paar Minuten nicht erreichbar ist.
                                  Ich hab daraufhin mal ein Ticket beim Adapter angelegt https://github.com/iobroker-community-adapters/ioBroker.unifi/issues/252 oder hängt das etwas für den js-controller?
                                    K
                                    K
                                    Kueppert
                                    #264
                                    @apollon77 habe eben SA auf die Alpha15 upgedated. Die Massenfehlermeldungen sind nun weg :) Top.
                                      apollon77A
                                      apollon77A
                                      #265
                                      @feuersturm Der Fehler hier liegt wohl aim Adapter weil der angegebene Host nicht erreichbar ist und der Fehler nicht sauber abgefangen wird
                                      • apollon77A
                                        apollon77A
                                        #266
                                        Hallo alle miteinander,
                                        Ich bedanke mich recht herzlich bei allen von Euch für Eure Tests und Unetrstützung.
                                        3.2.7 ist jetzt im Latest und damit geht es erst einmal hier weiter --> https://forum.iobroker.net/topic/41029/js-controller-3-2-jetzt-im-latest
                                        Ingo
                                          Aktuelle Test Version 3.2.x
                                          Veröffentlichungsdatum 09.01.2021
                                          Github Link npm install ioBroker/ioBroker.js-controller
                                          Hallo mal wieder in die Tester-Runde,
                                          mit etwas zeitlicher Verspätung, dafür aber um so besser, starten wir heute den Beta Test des neuen js-controller 3.2 (Releasename "Grace"). Wie auch bei den letzten Versionen starten wir die erste Teststufe direkt von GitHub. Also bitte nur mitmachen wenn Ihr wisst was das heisst :-) Aber auch der Weg zurück ist unten beschrieben.
                                          Die unterstützten Node.js Versionen bleiben in diesem Update gleich: 10.x, 12.x und auch 14.x werden offiziell unterstützt. Aufgrund der übergreifenden Adapter-Kompatibilität bleibt die empfohlene Node.js Version für ioBroker aktuell weiterhin auf 12.x. Falls jemand wirklich mit Node.js 15.x experimentieren will, dann bitte AUSSCHLIESSLICH mit npm 6 !! (die npm Leute haben in npm 7 wieder dinge kaputt gemacht. es ist zum heulen)
                                          Neben einigen Features haben wir unter der Haube weiter aufgeräumt und sehr viel modernisiert und vereinheitlicht.
                                          Auch daran den Wildwuchs in der Umsetzung einiger Adapter etwas einzugrenzen wurde weiter gearbeitet, was ggf. zu neuen Log-meldungen für bestimmte Fälle führt. Bitte unterstützt hier wieder und legt bei den relevanten Adaptern im GitHub Issues an, damit diese Dinge gefixt werden können.
                                          Besonders zu erwähnen ist die Grundlage für das neue Benachrichtigungssystem (kommt dann in einem Admin-Update) und die Reaktivierung von Let's Encrypt zur automatischen Zertifikatsaktualisierung.
                                          Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog. Ich hoffe auch diesmal auf Eure tatkräftige Unterstützung, sodass der Latest-Release dann genau so reibungslos verläuft wie bei den letzten Versionen.
                                          In Summe sind in diese Version über 560 commits eingeflossen. Dafür bedenke mich diesmal besonders bei @foxriver76, @AlCalzone und natürlich @Bluefox und auch ein paar weiteren Entwicklern für die aktive Mitarbeit an dieser Version!
                                          Der js-controller 3.2 ist generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2 ist problemlos möglich. Nur die Node.js Version muss jetzt mindestens 10.x sein, wie oben bereits ausgeführt. Wer überlegt die Node.js Version anzuheben bitte weiter unten im Abschnitt "Was ist zu testen" lesen :-)
                                          Installation
                                          VOR der Installation
                                          Wie bei jedem Test dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt. Die alte Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version installiert werden und sollte alles wieder herstellen.
                                          Windows
                                          Auf Systemen, die mit dem neuen Windows Installer eingerichtet wurden weiss ich gerade nicht wie der aktuelle Prozess ist, da der Windows installer nicht ganz aktuell ist. Bitte hier berichten dann kann ich ergänzen.
                                          Linux
                                          Für den Beta-Test muss der js-controller direkt per npm installiert werden. Dazu bitte den ioBroker auf dem Server beenden und dann in einer Shell UNBEDINGT in das ioBroker Verzeichnis wechseln (cd /opt/iobroker unter Linux). Dann mittels npm install ioBroker/ioBroker.js-controller den Controller manuell aktualisieren. Bevor ihr loslegt, lest aber bitte erst noch die folgenden Hinweise! Der zweite Post in diesem Thread ist für eine FAQ reserviert. Bitte schaut auch dort gern einmal rein.
                                          Achtung: Slave-Systeme zuerst!
                                          Bei einem Multi-Host-System, welches auf js-controller 2.2 oder 3.1 läuft ist es beim Update auf Version 3.2 empfohlen, zuerst die Slave-Systeme zu aktualisieren. Der Master wird als letztes aktualisiert!
                                          Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher auf die 3.2 müssen zwingend zuerst die Slaves und der Master als letztes aktualisiert werden. Die Slaves bleiben nach dem Update offline und werden erst wieder funktionieren wenn auch der Master auf die 3.2 aktualisiert wurde!
                                          Nötige Adapter-Aktualisierungen
                                          Aktuell sind keine Inkompatibilitäten bekannt, damit allerdings Let's encrypt wieder funktioniert benötigt es einige Adapter in "Latest" Versionen von mindestens:
                                          • ioBroker.lovelace 1.4.1
                                          • ioBroker.simple-api 2.5.2
                                          • ioBroker.socketio 3.1.3
                                          • ioBroker.telegram 1.7.0
                                          • ioBroker.web 3.2.2
                                          • ioBroker.admin 4.2.1
                                            Bitte checkt aber das die Adapter generell auch in den bisherigen versionen mit dem neuen js-controller tun!
                                          Es werden aber, wie oben ausgeführt, einige Adapter ggf Warnungen ins Log schreiben. Falls das Problematisch ist ist aktuell die einzige Option das Loglevel der Instanz auf "Error" zu setzen.
                                          Fehler
                                          Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
                                          Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller versuchen.
                                          Nach der Installation
                                          Nach der Installation den ioBroker wieder starten (z.B. mittels iobroker start).
                                          Wenn alles klappt merkt Ihr außer der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
                                          Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
                                          Was hat sich geändert, was besonders ansehen/testen?
                                          Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
                                          • generell siehe Changelog, speziell auch für Features
                                          • Alle normalen Funktionalitäten, vor allem Adapter starten, stoppen, restarten, installieren, upgrade einzel/all, Instanzen hinzufügen, löschen, auf anderen Host schieben (npm Installs und auch GitHub installs)
                                          • Prüfen und vergleichen der CPU and RAM Nutzung, speziell für den js.controller Prozess an sich
                                          • Einige Adapter werden Warnungen ausgeben wenn State-Werte gesetzt werden VOR dem Anlegen von Objekten. Bitte bei den Adapter-Repos melden
                                          Speziell die Entwickler sollten bitte die genannten Deprecations anschauen und beachten
                                          Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
                                          3.2.1 (2021-01-09) Release Grace
                                          BREAKING CHANGES
                                          • None, Supported are nodejs 10.x, 12.x and 14.x (Node.js 15.x is also working in the automated tests, but formally not supported)
                                          Features
                                          • (raintonr) Update Let's encrypt implementation; all relevent adapters (web and such) need updates to use it! NEEDS NODE.JS 12.x+! (see DOCS LINK TODO)
                                          • (bluefox) Restart adapters that use Let's encrypt after certificates were updated
                                          • (bluefox) Provide min/max for convert alias functions
                                          • (foxriver76) handling major adapter upgrades more carefully (CLI on upgrade will show if it's a major upgrade and major upgrades will be skipped on upgrade all when executed by admin
                                          • (AlCalzone) detect and allow short github URL format when (auto-)installing adapters (iobroker url User/repo#branchorcommit)
                                          • (foxriber76) Add notification system (see DOCS LINK TODO)
                                          • (foxriver76) enhance setup (and setup first) with redis to all port configuration
                                          • (foxriver76) set connectionName for redis connections and simulator support (see DOCS LINK TODO)
                                          Optimizations and Fixes
                                          • (foxriver76) Detect adapter restart loops and stop restarting after 3 crashes (an adapter is considered "working" when no crash by an exception happens within 10 minutes)
                                          • (foxriver76) Fix failed logins if username is uppercase, be reworking user logic and caching
                                          • (bluefox) Set for def states the quality: QUALITY_SUBS_INITIAL
                                          • (AlCalzone) fix npm uninstall loglevel argument
                                          • (foxriver76) delete pids.txt when iobroker was stopped
                                          • (bluefox) Add missing attributes by multihost if Redis is used for objects/states, Remove unused settings from iobroker-dist.json, Remove pass and user from connection settings. Use options.auth_pass
                                          • (AlCalzone) Package-Manager: log which packages were (already) installed
                                          • (foxriver76) replace redis "KEYS" command by "SCAN" to optimize redis access performance
                                          • (foxriver76) optimize redis library usage to prevent errors on redis outages
                                          • (bluefox) Catch errors by plugins load. At least log will work and could be checked for errors.
                                          • (foxriver76) allow migration of instances to already existing host
                                          • (foxriver76) also allow <adapter>.<instance-nr> for install/add cli command
                                          • (AlCalzone) buffer streams that are piped to stdout to fix weird Windows logging cases
                                          • (foxriver76/AlCalzone) Optimize upgrade/downgrade logic for adapters, ask for a downgrade only if lower version is to be installed
                                          • (foxriver76) allow redis redis migration when changing host of redis - fix bug where process crashes when controller is running when migrating
                                          • (bluefox) Catch errors for subscribe on alias without target
                                          • (foxriver76) only perform auto scaling on alias if not null
                                          • (foxriver76) if repository request fails also use cached sources on updating repository
                                          • (foxriver76) prevent host deletion from same host - otherwise it will remove the system.host states but instances will still be on the removed host, because transfer happens to itself
                                          • (foxriver76) use instanceObjects from system.adapter.* object instead from io-package.json
                                          • (foxriver76) notify of errors on readFileCertificates to show permission problems etc.
                                          • (foxriver76) multihost discovery now logs ignored messages on debug and also logs the senders address
                                          • (foxriver76) sync up created objects on instance start and instance creation by using helper function in tools.js, e.g. .loglevel was missing on instance creation
                                          • (bluefox) Package-Manager: Filter empty packets out to suppress error message
                                          • (foxriver76) rename repository names for new installations and on updates to beta/stable
                                          • (foxriver76) rewrite collectDiagInfo to Promises and fix minor issue with it
                                          • (foxriver76) only scale aliases if target or source is represented by unit %
                                          • (foxriver76) create meta.user on file sync cli, if not existing (see DOCS LINK TODO)
                                          • (Apollon77) also create meta.user on setup first if not existing
                                          • (foxriver76) fix enumInstances used by CLI commands
                                          • (foxriver76) when missing rights to access log dir do not crash hard anymore, instead fallback to default directory
                                          • (bluefox) Fix error if type of native data changed in the new version from basic type e.g. 'string' to 'object'.
                                          • (AlCalzone) Remove hardcoded references to GitHub master branch because newer repositories use "main"
                                          • (Apollon77, foxriver, bluefox, AlCalzone) Several fixes and refactorings to prevent potential crash cases reported by Sentry and other sources
                                          Developer relevant DEPRECATIONS/WARNINGS
                                          • (foxriver76) we warn if object not exists when setting a state via adapter.setState. Adjust your code that a state value is NOT set before the object is successfully created. If this deep check is NOT wanted for performance reasons the adapter needs to be initialized with strictObjectChecks = false!! (see DOCS LINK TODO)
                                          • (foxriver76) readFile should not validate meta object, we now throw on writeFile if id is no valid meta object
                                          • (AlCalzone) update Forbidden ID Characters: use Unicode properties to define which characters are allowed instead of blacklisting. For ASCII the allowed characters are the same as before - for other languages mainly character class of Unicode are allowed! (see DOCS LINK TODO)
                                          • (foxriver76) Throw on invalid setState objects; was logged as deprecated before
                                          • (foxriver76) remove getMessage shim, no adapter uses it anymore; was logged as deprecated before
                                          Developer relevant new Features
                                          • (foxriver76) use aes-192-cbc as encryption - backward compatible with current encryption, nothing to do for adapter-developers (see DOCS LINK TODO)
                                          • (bluefox) Add system view to filter for "folder" objects
                                          • (bluefox) add set/clearTimeout and set/clearInterval to adapter methods and check on unload that they were all cleared and clear if needed with logging, so developers are reminded to clean up!
                                          • (AlCalzone) Add ...Async version for getChannels - make sure to check before using or use correct js-controller version dependency!
                                          • (Apollon77) modularize databases into own npm packages and basically support adding new types of databases; add deprecation infos and logging to "old legacy" files in lib/states and lib/objects to not be used anymore; requires mostly updates in testing (see DOCS LINK TODO)
                                          Developer relevant Optimizations and Fixes
                                          • (foxriver76) implement maybeCallback and maybeCallbackWithError and use it in adapter.js
                                          • (AlCalzone) use fs-extra instead of mkdirp
                                          • (AlCalzone) read JSON files using fs-extra's readJSONSync
                                          • (AlCalzone) fix callback definitions in adapter.js, We have signatures for (almost) everything in @types/iobroker and we should use them
                                          • (AlCalzone) move from Promises to async/await in some places, use a single readyPromise instead of an array
                                          • (bluefox) Added "http" and "stream" options for logs
                                          • (foxriver76) migrated ci tests to github actions
                                          • (foxriver76) resolve adapter main file as tools.js method
                                          • (foxriver76) optimize extendObject with def value
                                          • (AlCalzone) Handle existing, but undefined properties in validateSetStateObjectArgument
                                          • (foxriver76) also escape + char on regex, it's not forbidden
                                          • (bluefox) Set default state only for objects of type "state"
                                          • (AlCalzone) include folders in the result of getAdapterObjects
                                          • general dependency updates
                                          • code style optimizations
                                          Generell ist zu testen, ob alles noch so funktioniert wie vorher auch. Das ist das wichtigste!
                                          Wie Fehler melden?
                                          Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
                                          Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
                                          Wir wünschen allen viel Spaß beim Testen und vielen Dank für Eure Unterstützung!
                                          Ingo
                                          GarganoG
                                          GarganoG
                                          Gargano
                                          #267
                                          @apollon77
                                          Installieren aus eigener URL geht nicht mehr mit 3.2.7 und 3.2.8 (mit 3.1.6 geht es)
                                          node 12.20.1 npm 6.14.10
                                          npm ERR! premature close
                                          npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-01-23T10_41_58_613Z-debug.log
                                          ERROR: host.raspberrypi Cannot install Grizzelbee/ioBroker.resol#02688d5f04b27921be060f533d2fd02cbfd9892d: 1
                                          Inhalt vom Error log :
                                          0 info it worked if it ends with ok
                                          1 verbose cli [
                                          1 verbose cli '/usr/bin/node',
                                          1 verbose cli '/usr/bin/npm',
                                          1 verbose cli 'install',
                                          1 verbose cli 'Grizzelbee/ioBroker.resol#02688d5f04b27921be060f533d2fd02cbfd9892d',
                                          1 verbose cli '--loglevel',
                                          1 verbose cli 'error',
                                          1 verbose cli '--prefix',
                                          1 verbose cli '/opt/iobroker'
                                          1 verbose cli ]
                                          2 info using npm@6.14.10
                                          3 info using node@v12.20.1
                                          4 verbose npm-session 3649abc973e44642
                                          5 silly install loadCurrentTree
                                          6 silly install readLocalPackageData
                                          7 verbose prepareGitDep github:Grizzelbee/ioBroker.resol#02688d5f04b27921be060f533d2fd02cbfd9892d: installing devDeps and running prepare script.
                                          8 silly fetchPackageMetaData error for github:Grizzelbee/ioBroker.resol#02688d5f04b27921be060f533d2fd02cbfd9892d premature close
                                          9 timing stage:rollbackFailedOptional Completed in 2ms
                                          10 timing stage:runTopLevelLifecycles Completed in 13533ms
                                          11 verbose stack Error: premature close
                                          11 verbose stack at PassThrough.onclose (/usr/lib/node_modules/npm/node_modules/end-of-stream/index.js:47:67)
                                          11 verbose stack at PassThrough.emit (events.js:326:22)
                                          11 verbose stack at emitCloseNT (internal/streams/destroy.js:69:8)
                                          11 verbose stack at processTicksAndRejections (internal/process/task_queues.js:83:21)
                                          12 verbose cwd /opt/iobroker
                                          13 verbose Linux 5.4.83-v7l+
                                          14 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "Grizzelbee/ioBroker.resol#02688d5f04b27921be060f533d2fd02cbfd9892d" "--loglevel" "error" "--prefix" "/opt/iobroker"
                                          15 verbose node v12.20.1
                                          16 verbose npm v6.14.10
                                          17 error premature close
                                          18 verbose exit [ 1, true ]
                                          33.2k
                                          84.4k
