RFlink (LOS GEHT ES ) Bestellung d.Hardware (20€) + 5€ Spende an Forum f.d. Adapter (crowdfunding like :-)
Sorry for bad news
Es gab eben ein update. Seitdem läuft RFlink gar nicht mehr:
! $ ./iobroker url "https://github.com/ioBroker/ioBroker.rflink/tarball/master" rflink
install https://github.com/ioBroker/ioBroker.rflink/tarball/master
npm install https://github.com/ioBroker/ioBroker.rflink/tarball/master --production --prefix "/opt/iobroker" (System call)
npm
WARN
cannot run in wd ws@0.4.32 (node-gyp rebuild 2> builderror.log) || (exit 0) (wd=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/avrga-tester/node_modules/express-ws/node_modules/ws)
node-pre-gyp
ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.6/serialport-v4.0.6-node-v46-linux-arm64.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.6 and node@4.6.1 (node-v46 ABI) (falling back to source compile with node-gyp)
! gypWARN
EACCES
user "root" does not have permission to access the dev dir "/root/.node-gyp/4.6.1"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/.node-gyp"
make: *** No rule to make target '../.node-gyp/4.6.1/include/node/common.gypi', needed by 'Makefile'. Stop.
gypERR!
build error
gyp
ERR! stack Error:makefailed with exit code: 2gyp
ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR!
stack at ChildProcess.emit (events.js:172:7)gyp ERR!
stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
gyp ERR! System Linux 3.10.104-pine64
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport! gyp ERR! node -v v4.6.1gyp ERR! node-gyp -v v3.4.0
gyp ERR! not ok
! node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack at emitTwo (events.js:87:13)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:172:7)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:829:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
node-pre-gyp ERR! System Linux 3.10.104-pine64
! node-pre-gyp
ERR! command
"/usr/local/bin/node" "/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp
ERR! cwd
/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialportnode-pre-gyp
ERR!
node -v v4.6.1
node-pre-gyp ERR!
node-pre-gyp -v v0.6.31
node-pre-gyp
ERR! not ok
gypWARN
EACCES
user "root" does not have permission to access the dev dir "/root/.node-gyp/4.6.1"gyp
WARN
EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/.node-gyp"
gypERR!
build error
gyp
ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack at emitTwo (events.js:87:13)! gyp
ERR!
stack at ChildProcess.emit (events.js:172:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release"
gyp ERR! cwd /opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport
gyp ERR! not ok
! node-pre-gyp
ERR! build error
node-pre-gyp
ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)node-pre-gyp
node-pre-gyp
ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.rflink/node_modules/serialportnode-pre-gyp
ERR!
node -v v4.6.1
node-pre-gyp ERR!
node-pre-gyp -v v0.6.26node-pre-gyp ERR! not oknpm
WARN optional dep failed, continuing avrgirl-arduino@1.10.0
npm
ERR! Linux 3.10.104-pine64npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "https://github.com/ioBroker/ioBroker.rflink/tarball/master" "--production" "--prefix" "/opt/iobroker"! npm
ERR!
node v4.6.1npm ERR! npm v2.15.9
! npm ERR! code ELIFECYCLE
npm ERR! serialport@2.1.2 install:node-pre-gyp install --fallback-to-build
npm ERR! Exit status 1
! npm
ERR! npm ERR! Failed at the serialport@2.1.2 install script 'node-pre-gyp install --fallback-to-build'.
npm ERR! This is most likely a problem with the serialport package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node-pre-gyp install --fallback-to-build
npm ERR! You can get information on how to open an issue for this project with:
npm ERR! npm bugs serialport
npm ERR! Or if that isn't available, you can get their info via:
npm ERR!
npm ERR! npm owner ls serialport
npm
ERR! There is likely additional logging output above.
! npm
ERR!
Please include the following file with any support request:npm ERR! /opt/npm-debug.log
! ERROR: host.ioBroker_Pine64 Cannot install https://github.com/ioBroker/ioBroker.rflink/tarball/master: 1
ERROR: process exited with code 25</anonymous></anonymous>Gruß Rainer -
Sorry for bad news
npm install https://github.com/ioBroker/ioBroker.rflink/tarball/master --productionGruß Rainer `Ich hab auf 1.0.5 geupdatet, und funktioniert, Ampel auf grün und Werte von der Outdoor Bresser Temperatur Station werden übermittelt.
Das ganze am Raspi3.
Dadurch ergibt sich jetzt eine Frage an Maxtox (nur Frage, keine Kritik!): Wie groß ist denn die Reichweite der eingebauten Transceiver? Die Sensoren sind jetzt ca. 5m entfernt, hier bekomme ich nur zu einem Kontakt, bei 6m zu keinem.
Ich müsste dann um im Garten die Steckdosen zu schalten mitten im Garten einen Arduino montieren?
Rainer `
Bin da auch am Testen. Also wenn die Bresser Outdoor-Klima-Station 5-6m weit weg steht mit Doppleverglasung dazwischen geht es. Habe dann nochmal 10m weiter weg gestellt, dann ging es nicht mehr.Bzgl. Reichweite war ich vorher davon ausgegenagen, dass die Reichweite von 433 MHz nicht so gut ist wie von den Homematic-Teilen mit 868 Mhz. Aber Optimieren kann man immer mal versuchen…
Ich hab auf 1.0.5 geupdatet, und funktioniert, Ampel auf grün und Werte `
:oops: :oops: ich habe dann nochmal und nochmal das log von mir durchgelesen :idea: und jetzt läuft es auch.Das Update muss mal wieder über die Konsole als echter root durchgeführt werden.
Weder upgrade über den admin noch Neuinstallation über Octocat oder upgrade/neuinstallation als User mit sudo haben funktioniert.
Lediglich die Neuinstallation als root.
ich habe mir vorerst selbst ein Arduino zugelegt, da Maxtox noch einige Zeit braucht die weiteren Geräte fertigzustellen….
Ich habe einen guten Empfänger gekauft und bekomme gleich vier Wetterstationen angezeigt. Meine Werterstation ist gute 20 meter weg von dem Arduino und sogar eine Etage höher.... Das beste ist, dass ich noch weitere drei Wetterstationen der Nachbarn sehen kann. Dies spricht nur für den guten Empfänger und deren Leistung, denn diese Wetterstationen sind bestimmt noch weiter weg als mein Gerät :)
Der Sender lässt noch auf sich warten.... :(
1526_unbenannt.png -
Ich habe einen guten Empfänger gekauft und bekomme gleich vier Wetterstationen angezeigt. Meine Werterstation ist gute 20 meter weg von dem Arduino und sogar eine Etage höher.... Das beste ist, dass ich noch weitere drei Wetterstationen der Machbarn sehen kann. Dies spricht nur für den guten Empfänger und deren Leistung, denn diese Wetterstationen sind bestimmt noch weiter weg als mein Gerät :)
Der Sender für lässt noch auf sich warten.... :( `
Welche Hardware hast du benutzt? Rxb12? RXB8?
Welche antenne?
Ich habe, 1:1 hardware von rflink benutzt…
ja, die Hardware habe ich bereits vor einigen Tagen verlinkt!
Es ist ein RXB6 433 Mhz Superheterodyne Funkempfänger für 5€. In China gibt es die Teile für 2,50€, da weis ich aber nicht, ob es die Rev. 2.0 ist, denn die Empfänger gab es auch als Rev. 08 und dort sollte man ein Kondi einlöten…
Meine Antenne ist nicht besonderes...Ich habe einfach eine Strippe an den Antennenanschluß angeschlossen, selbst die Länge stimmt nicht ...
Sorry für die Qualität der Fotos! :mrgreen:
1526_img_20161113_122310.png -
EDIT: RXB6 433 Mhz Superheterodyne Funkempfänger
in der Bucht eingekauft!
Kondensatore sind in allen von mir ausgelieferten teilen drin… Antenne, aheb ich schon bemängelt :-(
habe jetzt mal rxb8 v2 und rxb 6 V2 bestellt...schauen wir mal onb es besser wird :-)
mit RXB6 machst Du nichts falsch! Ich habe die Wetterstation weitere 5m nach draussen verfrachtet um die Außentemp. messen zu können. Der Adapter empfängt weiterhin regelmäßig die Daten. Bleibt auch die ganze Zeit aktiv (grüner Punkt).Unter Erreignisse in IObroker werden auch regelmäßig die Daten abgefragt.
Mit welchem Adapter bekomme ich jetzt die Daten in VIS intergriert ??? Ich würde gerne die Außentemperatur in die WEB-UI des VIS einbauen.
1526_unbenannt1.png -
@Lenny, Geil… :mrgreen:
kann Du das als Text einfügen, so das ich es importieren kann??? Das Widget finde ich bei mir nicht.
Ich habe es vorerst so gelöst!
Wenn ich es gewusst hätte dass meine Nachbarn unzählige Wetterstationen hier in der Umgebung betreiben, dann würde ich mir das Geld für meine eigene Sparen :mrgreen:
1526_unbenannt2.png -
kann Du das als Text einfügen, so das ich es importieren kann??? `
! [{"tpl":"tplRGtermometer","data":{"oid":"rflink.0.channels.RFTech_1.TEMP","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","min_value":"-30","max_value":"40","factor":"1","value_offset":"0","show_shadow":"true","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"control":false,"show_scale":true},"style":{"left":"664px","top":"138px","width":100,"height":400},"widgetSet":"rgraph"}]
Das Widget finde ich bei mir nicht. `
musste noch den Adapter "rgraph" installieren…
So ich war auch schon etwas ungeduldig und habe einen vorhanden Mega 2560 mit dem Aurel-Transceiver-Modul
verbunden. Die Antenne ist eine kleine Magnetfußantenne für 430 MHz (war noch im Fundus durch mein 2. Hobby ;-) )
Ich kann ausser meiner Wetterstation WS3600 auch einen Temp./Feuchte-Sensor eines Nachbarn empfangen
Und schnell mal mit den vorhanden Widgets gespielt
Wolfgang
Klasse :mrgreen:
ich habe gerade eine Fernbedienung für schaltbare Steckdosen ausprobiert.
In jeder Ecke des Hauses wird das Betätigen der Tasten erkannt.
Es handelt sich um dieses Model hier:
Leider fehlt mir noch das Sendermodul um es schalten zu können.
Der Empfänger ist erster Klasse, jetzt muß nur noch der Sender stark genug sein, dann sind wir zu Hause… :D
1526_pa_r1_01.jpg -
Hallo
Ich habe eine Lieferung aus China bekommen und kann sagen daß diese
Bewegungsmelder erkannt werden. Die haben selber keine Intelligenz sondern melden
nur daß Sie ausgelöst wurden. Über Empfindlichkeit kann ich noch nichts sagen.
Außerdem kann ich sagen daß diese Funksteckdosen von Pollin funktionieren. habe die aber
auf Intertechno umgestellt (dip schalter). Dann sind 256 Adressen möglich.
die Fernbedienung nutze ich nicht. Als Fernbedienung nutze ich die Intertechno ITS 150
Klasse…
Bewegungsmelder suche ich auch noch!
Bei Ali kosten 3 Stück um die 22 $
https://de.aliexpress.com/item/3pcs-Lot ... oryId=3008
Du schreibst dass die Bewegungsmelder erkannt werden, heißt es auch dass man sie auch in VIS auswerten kann und gleichzeitig auch in die ansteuerung für die Steckdosen verwenden kann?
hat jemand Erfahrungen schon mit Haustürklingeln? Ich habe den HM MP3 Gong, der echt leise ist.
Gruß Marco
