  4. JavaScript
  5. HTML Tabelle Linux-Control Adapter
templatejavascript
201 Beiträge 7 Kommentatoren 51.6k Aufrufe 13 Beobachtet
  • liv-in-skyL liv-in-sky
    @dirk1962 benutze bitte immer code tag um solche meldungen im forum zu posten
    du kannst den spoiler tag nutzen und im spoiler tag auch noch das code tag reinkopieren
    hier posten
    code tag = </>
    dirk1962D Offline
    dirk1962D Offline
    dirk1962
    #166
    @liv-in-sky Sorry!
    2021-01-08 15:25:00.016 - info: host.ioBrokerNUC instance system.adapter.dwd.0 started with pid 20067
    2021-01-08 15:25:01.844 - info: dwd.0 (20067) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.1, js-controller: 3.1.6
    2021-01-08 15:25:07.319 - info: host.ioBrokerNUC stopInstance system.adapter.linux-control.0 (force=false, process=true)
    2021-01-08 15:25:07.319 - info: host.ioBrokerNUC stopInstance system.adapter.linux-control.0 send kill signal
    2021-01-08 15:25:07.321 - info: linux-control.0 (19946) Got terminate signal TERMINATE_YOURSELF
    2021-01-08 15:25:07.322 - info: linux-control.0 (19946) cleaned everything up...
    2021-01-08 15:25:07.322 - info: linux-control.0 (19946) terminating
    2021-01-08 15:25:07.323 - debug: linux-control.0 (19946) Plugin sentry destroyed
    2021-01-08 15:25:07.323 - info: linux-control.0 (19946) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-01-08 15:25:07.844 - info: host.ioBrokerNUC instance system.adapter.linux-control.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-01-08 15:25:10.351 - info: host.ioBrokerNUC instance system.adapter.linux-control.0 started with pid 20092
    2021-01-08 15:25:10.670 - debug: linux-control.0 (20092) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-01-08 15:25:10.692 - debug: linux-control.0 (20092) Objects client ready ... initialize now
    2021-01-08 15:25:10.694 - debug: linux-control.0 (20092) Objects create System PubSub Client
    2021-01-08 15:25:10.694 - debug: linux-control.0 (20092) Objects create User PubSub Client
    2021-01-08 15:25:10.699 - debug: linux-control.0 (20092) Objects client initialize lua scripts
    2021-01-08 15:25:10.708 - debug: linux-control.0 (20092) Objects connected to redis: 127.0.0.1:9001
    2021-01-08 15:25:10.710 - debug: linux-control.0 (20092) objectDB connected
    2021-01-08 15:25:10.711 - debug: linux-control.0 (20092) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-01-08 15:25:10.715 - debug: linux-control.0 (20092) States create User PubSub Client
    2021-01-08 15:25:10.716 - debug: linux-control.0 (20092) States create System PubSub Client
    2021-01-08 15:25:10.726 - debug: linux-control.0 (20092) States connected to redis: 127.0.0.1:9000
    2021-01-08 15:25:10.726 - debug: linux-control.0 (20092) statesDB connected
    2021-01-08 15:25:11.470 - debug: linux-control.0 (20092) Plugin sentry Initialize Plugin (enabled=true)
    2021-01-08 15:25:11.519 - info: linux-control.0 (20092) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.linux-control, node: v12.20.1, js-controller: 3.1.6
    2021-01-08 15:25:11.549 - info: linux-control.0 (20092) getting data from Proxmox (192.168.1.102:22, Adapter start)
    2021-01-08 15:25:11.634 - debug: linux-control.0 (20092) [distributionInfo] Proxmox (192.168.1.102:22): send command: 'cat /etc/os-release'
    2021-01-08 15:25:11.734 - debug: linux-control.0 (20092) [distributionInfo] Proxmox (192.168.1.102:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
    NAME="Debian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    2021-01-08 15:25:11.740 - debug: linux-control.0 (20092) [distributionInfo] Proxmox (192.168.1.102:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
    2021-01-08 15:25:11.749 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'apt-get update'
    2021-01-08 15:25:12.164 - info: dwd.0 (20067) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-01-08 15:25:12.669 - info: host.ioBrokerNUC instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-01-08 15:25:13.826 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout: Hit:1 http://security.debian.org buster/updates InRelease
    Hit:2 http://security.debian.org/debian-security buster/updates InRelease
    Hit:3 http://ftp.de.debian.org/debian buster InRelease
    Hit:4 http://ftp.de.debian.org/debian buster-updates InRelease
    Hit:5 http://download.proxmox.com/debian/pve buster InRelease
    Reading package lists...
    2021-01-08 15:25:13.827 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s\[([\w,\-,\d,\.,~,:,\+]+)\]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
    2021-01-08 15:25:14.122 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout:
    2021-01-08 15:25:14.122 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.newPackages: 0
    2021-01-08 15:25:14.168 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.upgradable: false
    2021-01-08 15:25:14.214 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
    ' -W | sort -nr | head -1'
    2021-01-08 15:25:14.228 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout: 1609669960
    2021-01-08 15:25:14.229 - debug: linux-control.0 (20092) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.lastUpdate: 1609669960000 -> 03.01.2021 11:32
    2021-01-08 15:25:14.273 - debug: linux-control.0 (20092) [servicesInfo] Proxmox (192.168.1.102:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
    2021-01-08 15:25:14.283 - debug: linux-control.0 (20092) [servicesInfo] Proxmox (192.168.1.102:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
    apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities
    apt-daily.service,loaded,inactive,dead, Daily apt download activities
    auditd.service,not-found,inactive,dead, auditd.service
    auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS
    blk-availability.service,loaded,active,exited, Availability of block devices
    ceph.service,not-found,inactive,dead, ceph.service
    connman.service,not-found,inactive,dead, connman.service
    console-getty.service,loaded,inactive,dead, Console Getty
    console-screen.service,not-found,inactive,dead, console-screen.service
    console-setup.service,loaded,active,exited, Set console font and keymap
    corosync.service,loaded,inactive,dead, Corosync Cluster Engine
    cron.service,loaded,active,running, Regular background program processing daemon
    dbus.service,loaded,active,running, D-Bus System Message Bus
    display-manager.service,not-found,inactive,dead, display-manager.service
    dm-event.service,loaded,active,running, Device-mapper event daemon
    dracut-mount.service,not-found,inactive,dead, dracut-mount.service
    emergency.service,loaded,inactive,dead, Emergency Shell
    exim4.service,not-found,inactive,dead, exim4.service
    fcoe.service,not-found,inactive,dead, fcoe.service
    getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available
    getty@tty1.service,loaded,active,running, Getty on tty1
    glusterd.service,not-found,inactive,dead, glusterd.service
    gssproxy.service,not-found,inactive,dead, gssproxy.service
    ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown
    iscsi-shutdown.service,not-found,inactive,dead, iscsi-shutdown.service
    iscsid.service,loaded,active,running, iSCSI initiator daemon (iscsid)
    kbd.service,not-found,inactive,dead, kbd.service
    keyboard-setup.service,loaded,active,exited, Set the console keyboard layout
    kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel
    ksmtuned.service,loaded,active,running, Kernel Samepage Merging (KSM) Tuning Daemon
    lm-sensors.service,loaded,active,exited, Initialize hardware monitoring sensors
    logrotate.service,loaded,inactive,dead, Rotate log files
    lvm2-activation.service,not-found,inactive,dead, lvm2-activation.service
    lvm2-lvmpolld.service,loaded,inactive,dead, LVM2 poll daemon
    lvm2-monitor.service,loaded,active,exited, Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling
    lvm2-pvscan@259:3.service,loaded,active,exited, LVM event activation on device 259:3
    lxc-monitord.service,loaded,active,running, LXC Container Monitoring Daemon
    lxc-net.service,loaded,active,exited, LXC network bridge setup
    lxc.service,loaded,active,exited, LXC Container Initialization and Autoboot Code
    lxcfs.service,loaded,active,running, FUSE filesystem for LXC
    man-db.service,loaded,inactive,dead, Daily man-db regeneration
    networking.service,loaded,active,exited, Raise network interfaces
    NetworkManager.service,not-found,inactive,dead, NetworkManager.service
    nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service
    nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration
    nfs-kernel-server.service,not-found,inactive,dead, nfs-kernel-server.service
    nfs-server.service,not-found,inactive,dead, nfs-server.service
    nfs-utils.service,loaded,inactive,dead, NFS server and client services
    open-iscsi.service,loaded,active,exited, Login to default iSCSI targets
    plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service
    plymouth-start.service,not-found,inactive,dead, plymouth-start.service
    postfix.service,loaded,active,exited, Postfix Mail Transport Agent
    postfix@-.service,loaded,active,running, Postfix Mail Transport Agent (instance -)
    pve-cluster.service,loaded,active,running, The Proxmox VE cluster filesystem
    pve-daily-update.service,loaded,inactive,dead, Daily PVE download activities
    pve-firewall.service,loaded,active,running, Proxmox VE firewall
    pve-guests.service,loaded,active,exited, PVE guests
    pve-ha-crm.service,loaded,active,running, PVE Cluster HA Resource Manager Daemon
    pve-ha-lrm.service,loaded,active,running, PVE Local HA Resource Manager Daemon
    pve-lxc-syscalld.service,loaded,active,running, Proxmox VE LXC Syscall Daemon
    pvebanner.service,loaded,active,exited, Proxmox VE Login Banner
    pvedaemon.service,loaded,active,running, PVE API Daemon
    pvefw-logger.service,loaded,active,running, Proxmox VE firewall logger
    pvenetcommit.service,loaded,active,exited, Commit Proxmox VE network changes
    pveproxy.service,loaded,active,running, PVE API Proxy Server
    pvesr.service,loaded,inactive,dead, Proxmox VE replication runner
    pvestatd.service,loaded,active,running, PVE Status Daemon
    qmeventd.service,loaded,active,running, PVE Qemu Event Daemon
    rbdmap.service,loaded,active,exited, Map RBD devices
    rc-local.service,loaded,inactive,dead, /etc/rc.local Compatibility
    rescue.service,loaded,inactive,dead, Rescue Shell
    rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server
    rpc-statd-notify.service,loaded,inactive,dead, Notify NFS peers of a restart
    rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server
    rpcbind.service,loaded,active,running, RPC bind portmap service
    rrdcached.service,loaded,active,running, LSB: start or stop rrdcached
    rsync.service,loaded,inactive,dead, fast remote file copy program daemon
    rsyslog.service,loaded,active,running, System Logging Service
    sendmail.service,not-found,inactive,dead, sendmail.service
    smartmontools.service,loaded,active,running, Self Monitoring and Reporting Technology (SMART) Daemon
    smb.service,not-found,inactive,dead, smb.service
    spiceproxy.service,loaded,active,running, PVE SPICE Proxy Server
    ssh.service,loaded,active,running, OpenBSD Secure Shell server
    systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console
    systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall
    systemd-backlight@backlight:acpi_video0.service,loaded,active,exited, Load/Save Screen Backlight Brightness of backlight:acpi_video0
    systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats
    systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device
    systemd-fsck@dev-disk-by\x2duuid-D782\x2dA871.service,loaded,active,exited, File System Check on /dev/disk/by-uuid/D782-A871
    systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status
    systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database
    systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon
    systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage
    systemd-journald.service,loaded,active,running, Journal Service
    systemd-logind.service,loaded,active,running, Login Service
    systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk
    systemd-modules-load.service,loaded,active,exited, Load Kernel Modules
    systemd-networkd.service,loaded,inactive,dead, Network Service
    systemd-quotacheck.service,loaded,inactive,dead, File System Quota Check
    systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed
    systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems
    systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status
    systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables
    systemd-sysusers.service,loaded,active,exited, Create System Users
    systemd-timesyncd.service,loaded,active,running, Network Time Synchronization
    systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories
    systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev
    systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories
    systemd-udev-settle.service,loaded,active,exited, udev Wait for Complete Device Initialization
    systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices
    systemd-udevd.service,loaded,active,running, udev Kernel Device Manager
    systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service
    systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes
    systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown
    systemd-user-sessions.service,loaded,active,exited, Permit User Sessions
    systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service
    user-runtime-dir@0.service,loaded,active,exited, User Runtime Directory /run/user/0
    user@0.service,loaded,active,running, User Manager for UID 0
    watchdog-mux.service,loaded,active,running, Proxmox VE watchdog multiplexer
    zfs-import-cache.service,loaded,active,exited, Import ZFS pools by cache file
    zfs-mount.service,loaded,active,exited, Mount ZFS filesystems
    zfs-share.service,loaded,active,exited, ZFS file system shares
    zfs-volume-wait.service,loaded,active,exited, Wait for ZFS Volume (zvol) links in /dev
    zfs-zed.service,loaded,active,running, ZFS Event Daemon (zed)
    2021-01-08 15:25:14.285 - debug: linux-control.0 (20092) [servicesInfo] Proxmox (192.168.1.102:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"blk-availability.service","load":"loaded","active":"active","running":"exited","description":"Availability of block devices"},{"id":"ceph.service","load":"not-found","active":"inactive","running":"dead","description":"ceph.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-getty.service","load":"loaded","active":"inactive","running":"dead","description":"Console Getty"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"corosync.service","load":"loaded","active":"inactive","running":"dead","description":"Corosync Cluster Engine"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"dm-event.service","load":"loaded","active":"active","running":"running","description":"Device-mapper event daemon"},{"id":"dracut-mount.service","load":"not-found","active":"inactive","running":"dead","description":"dracut-mount.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"exim4.service","load":"not-found","active":"inactive","running":"dead","description":"exim4.service"},{"id":"fcoe.service","load":"not-found","active":"inactive","running":"dead","description":"fcoe.service"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"glusterd.service","load":"not-found","active":"inactive","running":"dead","description":"glusterd.service"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"iscsi-shutdown.service","load":"not-found","active":"inactive","running":"dead","description":"iscsi-shutdown.service"},{"id":"iscsid.service","load":"loaded","active":"active","running":"running","description":"iSCSI initiator daemon (iscsid)"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"ksmtuned.service","load":"loaded","active":"active","running":"running","description":"Kernel Samepage Merging (KSM) Tuning Daemon"},{"id":"lm-sensors.service","load":"loaded","active":"active","running":"exited","description":"Initialize hardware monitoring sensors"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"lvm2-activation.service","load":"not-found","active":"inactive","running":"dead","description":"lvm2-activation.service"},{"id":"lvm2-lvmpolld.service","load":"loaded","active":"inactive","running":"dead","description":"LVM2 poll daemon"},{"id":"lvm2-monitor.service","load":"loaded","active":"active","running":"exited","description":"Monitoring of LVM2 mirrors","field6":"snapshots etc. using dmeventd or progress polling"},{"id":"lvm2-pvscan@259:3.service","load":"loaded","active":"active","running":"exited","description":"LVM event activation on device 259:3"},{"id":"lxc-monitord.service","load":"loaded","active":"active","running":"running","description":"LXC Container Monitoring Daemon"},{"id":"lxc-net.service","load":"loaded","active":"active","running":"exited","description":"LXC network bridge setup"},{"id":"lxc.service","load":"loaded","active":"active","running":"exited","description":"LXC Container Initialization and Autoboot Code"},{"id":"lxcfs.service","load":"loaded","active":"active","running":"running","description":"FUSE filesystem for LXC"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-kernel-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-kernel-server.service"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"open-iscsi.service","load":"loaded","active":"active","running":"exited","description":"Login to default iSCSI targets"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"postfix.service","load":"loaded","active":"active","running":"exited","description":"Postfix Mail Transport Agent"},{"id":"postfix@-.service","load":"loaded","active":"active","running":"running","description":"Postfix Mail Transport Agent (instance -)"},{"id":"pve-cluster.service","load":"loaded","active":"active","running":"running","description":"The Proxmox VE cluster filesystem"},{"id":"pve-daily-update.service","load":"loaded","active":"inactive","running":"dead","description":"Daily PVE download activities"},{"id":"pve-firewall.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE firewall"},{"id":"pve-guests.service","load":"loaded","active":"active","running":"exited","description":"PVE guests"},{"id":"pve-ha-crm.service","load":"loaded","active":"active","running":"running","description":"PVE Cluster HA Resource Manager Daemon"},{"id":"pve-ha-lrm.service","load":"loaded","active":"active","running":"running","description":"PVE Local HA Resource Manager Daemon"},{"id":"pve-lxc-syscalld.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE LXC Syscall Daemon"},{"id":"pvebanner.service","load":"loaded","active":"active","running":"exited","description":"Proxmox VE Login Banner"},{"id":"pvedaemon.service","load":"loaded","active":"active","running":"running","description":"PVE API Daemon"},{"id":"pvefw-logger.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE firewall logger"},{"id":"pvenetcommit.service","load":"loaded","active":"active","running":"exited","description":"Commit Proxmox VE network changes"},{"id":"pveproxy.service","load":"loaded","active":"active","running":"running","description":"PVE API Proxy Server"},{"id":"pvesr.service","load":"loaded","active":"inactive","running":"dead","description":"Proxmox VE replication runner"},{"id":"pvestatd.service","load":"loaded","active":"active","running":"running","description":"PVE Status Daemon"},{"id":"qmeventd.service","load":"loaded","active":"active","running":"running","description":"PVE Qemu Event Daemon"},{"id":"rbdmap.service","load":"loaded","active":"active","running":"exited","description":"Map RBD devices"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-statd-notify.service","load":"loaded","active":"inactive","running":"dead","description":"Notify NFS peers of a restart"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpcbind.service","load":"loaded","active":"active","running":"running","description":"RPC bind portmap service"},{"id":"rrdcached.service","load":"loaded","active":"active","running":"running","description":"LSB: start or stop rrdcached"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"sendmail.service","load":"not-found","active":"inactive","running":"dead","description":"sendmail.service"},{"id":"smartmontools.service","load":"loaded","active":"active","running":"running","description":"Self Monitoring and Reporting Technology (SMART) Daemon"},{"id":"smb.service","load":"not-found","active":"inactive","running":"dead","description":"smb.service"},{"id":"spiceproxy.service","load":"loaded","active":"active","running":"running","description":"PVE SPICE Proxy Server"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-backlight@backlight:acpi_video0.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Screen Backlight Brightness of backlight:acpi_video0"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsck@dev-disk-by\\x2duuid-D782\\x2dA871.service","load":"loaded","active":"active","running":"exited","description":"File System Check on /dev/disk/by-uuid/D782-A871"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-quotacheck.service","load":"loaded","active":"inactive","running":"dead","description":"File System Quota Check"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-settle.service","load":"loaded","active":"active","running":"exited","description":"udev Wait for Complete Device Initialization"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@0.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/0"},{"id":"user@0.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 0"},{"id":"watchdog-mux.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE watchdog multiplexer"},{"id":"zfs-import-cache.service","load":"loaded","active":"active","running":"exited","description":"Import ZFS pools by cache file"},{"id":"zfs-mount.service","load":"loaded","active":"active","running":"exited","description":"Mount ZFS filesystems"},{"id":"zfs-share.service","load":"loaded","active":"active","running":"exited","description":"ZFS file system shares"},{"id":"zfs-volume-wait.service","load":"loaded","active":"active","running":"exited","description":"Wait for ZFS Volume (zvol) links in /dev"},{"id":"zfs-zed.service","load":"loaded","active":"active","running":"running","description":"ZFS Event Daemon (zed)"}]
    2021-01-08 15:25:14.500 - debug: linux-control.0 (20092) [needrestart] Proxmox (192.168.1.102:22): no datapoints selected -> removing existing datapoints
    2021-01-08 15:25:14.507 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'du -sk /var/log/ | awk '{ print $1 /1024 }''
    2021-01-08 15:25:14.516 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 28.6914
    2021-01-08 15:25:14.518 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.size: 28.69 MB
    2021-01-08 15:25:14.559 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'find /var/log/ -name "*" | wc -l'
    2021-01-08 15:25:14.567 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1382
    2021-01-08 15:25:14.569 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.files: 1382 Dateien
    2021-01-08 15:25:14.611 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'tmp=$(find /var/log/ -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
    2021-01-08 15:25:15.627 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1610115911
    2021-01-08 15:25:15.629 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.lastChange: 1610115911000 -> 08.01.2021 15:25
    2021-01-08 15:25:15.671 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'du -sk /var/ | awk '{ print $1 /1024 }''
    2021-01-08 15:25:15.701 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1899.28
    2021-01-08 15:25:15.702 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.size: 1899.28 MB
    2021-01-08 15:25:15.748 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'find /var/ -name "*" | wc -l'
    2021-01-08 15:25:15.773 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 5349
    2021-01-08 15:25:15.777 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.files: 5349 Dateien
    2021-01-08 15:25:15.821 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): send command: 'tmp=$(find /var/ -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
    2021-01-08 15:25:19.713 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1610115919
    2021-01-08 15:25:19.715 - debug: linux-control.0 (20092) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.lastChange: 1610115919000 -> 08.01.2021 15:25
    2021-01-08 15:25:19.760 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
    2021-01-08 15:25:19.767 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: root, description: ): response stdout: 14
    2021-01-08 15:25:19.771 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
    2021-01-08 15:25:19.777 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: mem, description: ): response stdout: 31986;7014;24434
    2021-01-08 15:25:19.820 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: swap, description: ): send command: 'free -m | awk ' NR == 3 {print $2";"$3";"$4}''
    2021-01-08 15:25:19.827 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: swap, description: ): response stdout: 8191;0;8191
    2021-01-08 15:25:19.829 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
    2021-01-08 15:25:19.844 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: top-process, description: ): response stdout: 39.6;/usr/bin/kvm
    2021-01-08 15:25:19.889 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: cpu-temp, description: ): send command: 'sensors | grep Package -m 1 | awk '{print $4}' | awk '{print substr($1, length($0)-6,2)}''
    2021-01-08 15:25:19.898 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: cpu-temp, description: ): response stdout: 58
    2021-01-08 15:25:19.901 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_0, description: ): send command: 'sensors | grep 'Core 0:' | awk '{print $3}' | cut -c2-3'
    2021-01-08 15:25:19.909 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_0, description: ): response stdout: 57
    2021-01-08 15:25:19.911 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_1, description: ): send command: 'sensors | grep 'Core 1:' | awk '{print $3}' | cut -c2-3'
    2021-01-08 15:25:19.919 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_1, description: ): response stdout: 57
    2021-01-08 15:25:19.922 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_2, description: ): send command: 'sensors | grep 'Core 2:' | awk '{print $3}' | cut -c2-3'
    2021-01-08 15:25:19.930 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_2, description: ): response stdout: 58
    2021-01-08 15:25:19.933 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_3, description: ): send command: 'sensors | grep 'Core 3:' | awk '{print $3}' | cut -c2-3'
    2021-01-08 15:25:19.940 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_3, description: ): response stdout: 60
    2021-01-08 15:25:19.943 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Raspberrymatic, description: ): send command: 'qm status 100 | awk '{print substr($0, length($0)-6,7)}''
    2021-01-08 15:25:20.493 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Raspberrymatic, description: ): response stdout: running
    2021-01-08 15:25:20.496 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.ioBroker, description: ): send command: 'qm status 110 | awk '{print substr($0, length($0)-6,7)}''
    2021-01-08 15:25:21.050 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.ioBroker, description: ): response stdout: running
    2021-01-08 15:25:21.069 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Motioneye, description: ): send command: 'qm status 120 | awk '{print substr($0, length($0)-6,7)}''
    2021-01-08 15:25:21.594 - debug: linux-control.0 (20092) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Motioneye, description: ): response stdout: running
    2021-01-08 15:25:21.601 - info: linux-control.0 (20092) successful received data from Proxmox (192.168.1.102:22)
    2021-01-08 15:25:21.620 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.refresh' subscribed
    2021-01-08 15:25:21.621 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.aptUpdate' subscribed
    2021-01-08 15:25:21.621 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.aptUpgrade' subscribed
    2021-01-08 15:25:21.621 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.restart' subscribed
    2021-01-08 15:25:21.621 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.start' subscribed
    2021-01-08 15:25:21.621 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.stop' subscribed
    2021-01-08 15:25:21.622 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.restart' subscribed
    2021-01-08 15:25:21.622 - debug: linux-control.0 (20092) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.shutdown' subscribed
    2021-01-08 15:25:21.622 - info: linux-control.0 (20092) getting data from ioBroker (192.168.1.170:22, Adapter start)
    2021-01-08 15:25:21.632 - debug: linux-control.0 (20092) [getConnection] Host 'ioBroker' (192.168.1.170:22): using sudo for authentification
    2021-01-08 15:25:21.693 - debug: linux-control.0 (20092) [distributionInfo] ioBroker (192.168.1.170:22): send command: 'cat /etc/os-release'
    2021-01-08 15:25:21.795 - debug: linux-control.0 (20092) [distributionInfo] ioBroker (192.168.1.170:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
    VERSION_ID="10"
    ID=debian
    2021-01-08 15:25:21.797 - debug: linux-control.0 (20092) [distributionInfo] ioBroker (192.168.1.170:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
    2021-01-08 15:25:21.805 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'sudo -S apt-get update'
    2021-01-08 15:25:21.822 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout:
    [sudo] Passwort für dirk:
    Leider darf der Benutzer dirk »/usr/bin/apt-get update« als root auf ioBrokerNUC nicht ausführen.
    2021-01-08 15:25:21.822 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s\[([\w,\-,\d,\.,~,:,\+]+)\]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
    2021-01-08 15:25:22.174 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout:
    2021-01-08 15:25:22.174 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.newPackages: 0
    2021-01-08 15:25:22.178 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.upgradable: false
    2021-01-08 15:25:22.226 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
    2021-01-08 15:25:22.239 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout: 1609923124
    2021-01-08 15:25:22.239 - debug: linux-control.0 (20092) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.lastUpdate: 1609923124000 -> 06.01.2021 09:52
    2021-01-08 15:25:22.285 - debug: linux-control.0 (20092) [servicesInfo] ioBroker (192.168.1.170:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
    2021-01-08 15:25:22.293 - debug: linux-control.0 (20092) [servicesInfo] ioBroker (192.168.1.170:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
    ifup@ens18.service,loaded,active,exited, ifup for ens18
    influxdb.service,not-found,inactive,dead, influxdb.service
    iobroker.service,loaded,active,running, ioBroker Server
    mariadb-server.service,not-found,inactive,dead, mariadb-server.service
    mysql-server.service,not-found,inactive,dead, mysql-server.service
    redis.service,not-found,inactive,dead, redis.service
    user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000
    user@1000.service,loaded,active,running, User Manager for UID 1000
    2021-01-08 15:25:22.296 - debug: linux-control.0 (20092) [servicesInfo] ioBroker (192.168.1.170:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
    2021-01-08 15:25:22.432 - debug: linux-control.0 (20092) [needrestart] ioBroker (192.168.1.170:22): no datapoints selected -> removing existing datapoints
    2021-01-08 15:25:22.439 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
    2021-01-08 15:25:22.445 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: root, description: ): response stdout: 27
    2021-01-08 15:25:22.456 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
    2021-01-08 15:25:22.462 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: mem, description: ): response stdout: 7978;2289;4997
    2021-01-08 15:25:22.508 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: swap, description: ): send command: 'free -m | awk ' NR == 3 {print $2";"$3";"$4}''
    2021-01-08 15:25:22.515 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: swap, description: ): response stdout: 8189;0;8189
    2021-01-08 15:25:22.517 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
    2021-01-08 15:25:22.529 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: top-process, description: ): response stdout: 9.0;io.linux-control.0
    2021-01-08 15:25:22.532 - debug: linux-control.0 (20092) [userCommand] ioBroker (192.168.1.170:22): datapoint-id: ioB-stop, description: : create button
    2021-01-08 15:25:22.534 - debug: linux-control.0 (20092) [userCommand] ioBroker (192.168.1.170:22): datapoint-id: ioB-start, description: : create button
    2021-01-08 15:25:22.535 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: opt, description: ): send command: 'du -c /opt/iobroker | tail -1 | awk '{printf $1MB}''
    2021-01-08 15:25:22.851 - debug: linux-control.0 (20092) [userCommandExecute] ioBroker (192.168.1.170:22, id: opt, description: ): response stdout: 1833800
    2021-01-08 15:25:22.856 - info: linux-control.0 (20092) successful received data from ioBroker (192.168.1.170:22)
    2021-01-08 15:25:22.869 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.refresh' subscribed
    2021-01-08 15:25:22.870 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.aptUpdate' subscribed
    2021-01-08 15:25:22.870 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.aptUpgrade' subscribed
    2021-01-08 15:25:22.870 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.restart' subscribed
    2021-01-08 15:25:22.870 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.ioB-stop' subscribed
    2021-01-08 15:25:22.870 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.ioB-start' subscribed
    2021-01-08 15:25:22.871 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.start' subscribed
    2021-01-08 15:25:22.871 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.stop' subscribed
    2021-01-08 15:25:22.871 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.restart' subscribed
    2021-01-08 15:25:22.872 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.start' subscribed
    2021-01-08 15:25:22.872 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.stop' subscribed
    2021-01-08 15:25:22.872 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.restart' subscribed
    2021-01-08 15:25:22.873 - debug: linux-control.0 (20092) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.shutdown' subscribed
    2021-01-08 15:25:22.873 - info: linux-control.0 (20092) getting data from Raspberrymatic (192.168.1.171:22, Adapter start)
    2021-01-08 15:25:22.930 - debug: linux-control.0 (20092) [distributionInfo] Raspberrymatic (192.168.1.171:22): send command: 'cat /etc/os-release'
    2021-01-08 15:25:22.975 - debug: linux-control.0 (20092) [distributionInfo] Raspberrymatic (192.168.1.171:22): response stdout: NAME=Buildroot
    VERSION=2.15.5-20151101-2805-g412dbfc5
    ID=buildroot
    VERSION_ID=2020.11
    PRETTY_NAME="Buildroot 2020.11"
    2021-01-08 15:25:22.977 - debug: linux-control.0 (20092) [distributionInfo] Raspberrymatic (192.168.1.171:22): csvToJson result: [{"prop":"NAME","val":"Buildroot"},{"prop":"VERSION","val":"2.15.5-20151101-2805-g412dbfc5"},{"prop":"ID","val":"buildroot"},{"prop":"VERSION_ID","val":"2020.11"},{"prop":"PRETTY_NAME","val":"Buildroot 2020.11"}]
    2021-01-08 15:25:23.023 - warn: linux-control.0 (20092) [distributionInfo] Raspberrymatic (192.168.1.171:22): property 'VERSION_CODENAME' not exist in result!
    2021-01-08 15:25:23.026 - debug: linux-control.0 (20092) [cmdAptUpdate] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
    2021-01-08 15:25:23.028 - debug: linux-control.0 (20092) [servicesInfo] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
    2021-01-08 15:25:23.033 - debug: linux-control.0 (20092) [needrestart] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
    2021-01-08 15:25:23.039 - debug: linux-control.0 (20092) [userCommandExecute] Raspberrymatic (192.168.1.171:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
    2021-01-08 15:25:23.045 - debug: linux-control.0 (20092) [userCommandExecute] Raspberrymatic (192.168.1.171:22, id: root, description: ): response stdout: 61
    2021-01-08 15:25:23.049 - info: linux-control.0 (20092) successful received data from Raspberrymatic (192.168.1.171:22)
    2021-01-08 15:25:23.062 - debug: linux-control.0 (20092) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.refresh' subscribed
    2021-01-08 15:25:23.062 - debug: linux-control.0 (20092) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.aptUpgrade' subscribed
    2021-01-08 15:25:23.062 - debug: linux-control.0 (20092) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.aptUpdate' subscribed
    2021-01-08 15:25:23.063 - debug: linux-control.0 (20092) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.restart' subscribed
    2021-01-08 15:25:23.063 - debug: linux-control.0 (20092) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.shutdown' subscribed
    2021-01-08 15:25:23.063 - info: linux-control.0 (20092) getting data from Motioneye (192.168.1.174:22, Adapter start)
    2021-01-08 15:25:23.072 - debug: linux-control.0 (20092) [getConnection] Host 'Motioneye' (192.168.1.174:22): using sudo for authentification
    2021-01-08 15:25:23.153 - debug: linux-control.0 (20092) [distributionInfo] Motioneye (192.168.1.174:22): send command: 'cat /etc/os-release'
    2021-01-08 15:25:23.187 - debug: linux-control.0 (20092) [distributionInfo] Motioneye (192.168.1.174:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
    VERSION_ID="10"
    ID=debian
    2021-01-08 15:25:23.188 - debug: linux-control.0 (20092) [distributionInfo] Motioneye (192.168.1.174:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
    2021-01-08 15:25:23.238 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'sudo -S apt-get update'
    2021-01-08 15:25:23.255 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout:
    dirk ist nicht in der sudoers-Datei. Dieser Vorfall wird gemeldet.
    2021-01-08 15:25:23.255 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s\[([\w,\-,\d,\.,~,:,\+]+)\]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
    2021-01-08 15:25:23.590 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout:
    2021-01-08 15:25:23.591 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.newPackages: 0
    2021-01-08 15:25:23.594 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.upgradable: false
    2021-01-08 15:25:23.598 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
    2021-01-08 15:25:23.613 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout: 1585325736
    2021-01-08 15:25:23.613 - debug: linux-control.0 (20092) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.lastUpdate: 1585325736000 -> 27.03.2020 17:15
    2021-01-08 15:25:23.656 - debug: linux-control.0 (20092) [servicesInfo] Motioneye (192.168.1.174:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
    2021-01-08 15:25:23.666 - debug: linux-control.0 (20092) [servicesInfo] Motioneye (192.168.1.174:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
    motion.service,loaded,active,exited, LSB: Start Motion detection
    motioneye.service,loaded,active,running, motionEye Server
    2021-01-08 15:25:23.667 - debug: linux-control.0 (20092) [servicesInfo] Motioneye (192.168.1.174:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"motion.service","load":"loaded","active":"active","running":"exited","description":"LSB: Start Motion detection"},{"id":"motioneye.service","load":"loaded","active":"active","running":"running","description":"motionEye Server"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
    2021-01-08 15:25:23.792 - debug: linux-control.0 (20092) [needrestart] Motioneye (192.168.1.174:22): no datapoints selected -> removing existing datapoints
    2021-01-08 15:25:23.798 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
    2021-01-08 15:25:23.805 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: root, description: ): response stdout: 28
    2021-01-08 15:25:23.808 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
    2021-01-08 15:25:23.813 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: mem, description: ): response stdout: 3946;222;3533
    2021-01-08 15:25:23.815 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
    2021-01-08 15:25:23.824 - debug: linux-control.0 (20092) [userCommandExecute] Motioneye (192.168.1.174:22, id: top-process, description: ): response stdout: 34.1;/usr/bin/motion
    2021-01-08 15:25:23.835 - info: linux-control.0 (20092) successful received data from Motioneye (192.168.1.174:22)
    2021-01-08 15:25:23.852 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.refresh' subscribed
    2021-01-08 15:25:23.852 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.aptUpdate' subscribed
    2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.aptUpgrade' subscribed
    2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.restart' subscribed
    2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.start' subscribed
    2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.stop' subscribed
    2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.restart' subscribed
    2021-01-08 15:25:23.853 - debug: linux-control.0 (20092) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.shutdown' subscribed
    NUC8i5 mit Proxmox; Raspberrymatic in VM, iobroker, Motioneye, infuxDB und Grafana in CT.
    • liv-in-skyL liv-in-sky
      @dirk1962 benutze bitte immer code tag um solche meldungen im forum zu posten
      du kannst den spoiler tag nutzen und im spoiler tag auch noch das code tag reinkopieren
      hier posten
      code tag = </>
      dirk1962D Offline
      dirk1962D Offline
      dirk1962
      #167
      @liv-in-sky @Scrounger Ich hatte den Ordner Befehl für Motioneye wieder rausgenommen. In diesem log ist er wieder mit drin.
      2021-01-08 15:49:06.639 - info: host.ioBrokerNUC stopInstance system.adapter.linux-control.0 (force=false, process=true)
      2021-01-08 15:49:06.642 - info: host.ioBrokerNUC stopInstance system.adapter.linux-control.0 send kill signal
      2021-01-08 15:49:06.644 - info: linux-control.0 (21211) Got terminate signal TERMINATE_YOURSELF
      2021-01-08 15:49:06.645 - info: linux-control.0 (21211) cleaned everything up...
      2021-01-08 15:49:06.645 - info: linux-control.0 (21211) terminating
      2021-01-08 15:49:06.645 - debug: linux-control.0 (21211) Plugin sentry destroyed
      2021-01-08 15:49:06.645 - info: linux-control.0 (21211) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-01-08 15:49:07.168 - info: host.ioBrokerNUC instance system.adapter.linux-control.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-01-08 15:49:09.673 - info: host.ioBrokerNUC instance system.adapter.linux-control.0 started with pid 21312
      2021-01-08 15:49:10.004 - debug: linux-control.0 (21312) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2021-01-08 15:49:10.030 - debug: linux-control.0 (21312) Objects client ready ... initialize now
      2021-01-08 15:49:10.031 - debug: linux-control.0 (21312) Objects create System PubSub Client
      2021-01-08 15:49:10.032 - debug: linux-control.0 (21312) Objects create User PubSub Client
      2021-01-08 15:49:10.032 - debug: linux-control.0 (21312) Objects client initialize lua scripts
      2021-01-08 15:49:10.041 - debug: linux-control.0 (21312) Objects connected to redis: 127.0.0.1:9001
      2021-01-08 15:49:10.043 - debug: linux-control.0 (21312) objectDB connected
      2021-01-08 15:49:10.044 - debug: linux-control.0 (21312) Redis States: Use Redis connection: 127.0.0.1:9000
      2021-01-08 15:49:10.049 - debug: linux-control.0 (21312) States create User PubSub Client
      2021-01-08 15:49:10.050 - debug: linux-control.0 (21312) States create System PubSub Client
      2021-01-08 15:49:10.057 - debug: linux-control.0 (21312) States connected to redis: 127.0.0.1:9000
      2021-01-08 15:49:10.058 - debug: linux-control.0 (21312) statesDB connected
      2021-01-08 15:49:11.034 - debug: linux-control.0 (21312) Plugin sentry Initialize Plugin (enabled=true)
      2021-01-08 15:49:11.082 - info: linux-control.0 (21312) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.linux-control, node: v12.20.1, js-controller: 3.1.6
      2021-01-08 15:49:11.114 - info: linux-control.0 (21312) getting data from Proxmox (192.168.1.102:22, Adapter start)
      2021-01-08 15:49:11.199 - debug: linux-control.0 (21312) [distributionInfo] Proxmox (192.168.1.102:22): send command: 'cat /etc/os-release'
      2021-01-08 15:49:11.290 - debug: linux-control.0 (21312) [distributionInfo] Proxmox (192.168.1.102:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
      NAME="Debian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      2021-01-08 15:49:11.296 - debug: linux-control.0 (21312) [distributionInfo] Proxmox (192.168.1.102:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
      2021-01-08 15:49:11.307 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'apt-get update'
      2021-01-08 15:49:13.285 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout: Hit:1 http://security.debian.org buster/updates InRelease
      Hit:2 http://security.debian.org/debian-security buster/updates InRelease
      Hit:3 http://download.proxmox.com/debian/pve buster InRelease
      Hit:4 http://ftp.de.debian.org/debian buster InRelease
      Hit:5 http://ftp.de.debian.org/debian buster-updates InRelease
      Reading package lists...
      2021-01-08 15:49:13.285 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s\[([\w,\-,\d,\.,~,:,\+]+)\]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
      2021-01-08 15:49:13.577 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout:
      2021-01-08 15:49:13.577 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.newPackages: 0
      2021-01-08 15:49:13.580 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.upgradable: false
      2021-01-08 15:49:13.626 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
      ' -W | sort -nr | head -1'
      2021-01-08 15:49:13.640 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout: 1609669960
      2021-01-08 15:49:13.640 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.lastUpdate: 1609669960000 -> 03.01.2021 11:32
      2021-01-08 15:49:13.685 - debug: linux-control.0 (21312) [servicesInfo] Proxmox (192.168.1.102:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
      2021-01-08 15:49:13.695 - debug: linux-control.0 (21312) [servicesInfo] Proxmox (192.168.1.102:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
      apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities
      apt-daily.service,loaded,inactive,dead, Daily apt download activities
      auditd.service,not-found,inactive,dead, auditd.service
      auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS
      blk-availability.service,loaded,active,exited, Availability of block devices
      ceph.service,not-found,inactive,dead, ceph.service
      connman.service,not-found,inactive,dead, connman.service
      console-getty.service,loaded,inactive,dead, Console Getty
      console-screen.service,not-found,inactive,dead, console-screen.service
      console-setup.service,loaded,active,exited, Set console font and keymap
      corosync.service,loaded,inactive,dead, Corosync Cluster Engine
      cron.service,loaded,active,running, Regular background program processing daemon
      dbus.service,loaded,active,running, D-Bus System Message Bus
      display-manager.service,not-found,inactive,dead, display-manager.service
      dm-event.service,loaded,active,running, Device-mapper event daemon
      dracut-mount.service,not-found,inactive,dead, dracut-mount.service
      emergency.service,loaded,inactive,dead, Emergency Shell
      exim4.service,not-found,inactive,dead, exim4.service
      fcoe.service,not-found,inactive,dead, fcoe.service
      getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available
      getty@tty1.service,loaded,active,running, Getty on tty1
      glusterd.service,not-found,inactive,dead, glusterd.service
      gssproxy.service,not-found,inactive,dead, gssproxy.service
      ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown
      iscsi-shutdown.service,not-found,inactive,dead, iscsi-shutdown.service
      iscsid.service,loaded,active,running, iSCSI initiator daemon (iscsid)
      kbd.service,not-found,inactive,dead, kbd.service
      keyboard-setup.service,loaded,active,exited, Set the console keyboard layout
      kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel
      ksmtuned.service,loaded,active,running, Kernel Samepage Merging (KSM) Tuning Daemon
      lm-sensors.service,loaded,active,exited, Initialize hardware monitoring sensors
      logrotate.service,loaded,inactive,dead, Rotate log files
      lvm2-activation.service,not-found,inactive,dead, lvm2-activation.service
      lvm2-lvmpolld.service,loaded,inactive,dead, LVM2 poll daemon
      lvm2-monitor.service,loaded,active,exited, Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling
      lvm2-pvscan@259:3.service,loaded,active,exited, LVM event activation on device 259:3
      lxc-monitord.service,loaded,active,running, LXC Container Monitoring Daemon
      lxc-net.service,loaded,active,exited, LXC network bridge setup
      lxc.service,loaded,active,exited, LXC Container Initialization and Autoboot Code
      lxcfs.service,loaded,active,running, FUSE filesystem for LXC
      man-db.service,loaded,inactive,dead, Daily man-db regeneration
      networking.service,loaded,active,exited, Raise network interfaces
      NetworkManager.service,not-found,inactive,dead, NetworkManager.service
      nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service
      nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration
      nfs-kernel-server.service,not-found,inactive,dead, nfs-kernel-server.service
      nfs-server.service,not-found,inactive,dead, nfs-server.service
      nfs-utils.service,loaded,inactive,dead, NFS server and client services
      open-iscsi.service,loaded,active,exited, Login to default iSCSI targets
      plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service
      plymouth-start.service,not-found,inactive,dead, plymouth-start.service
      postfix.service,loaded,active,exited, Postfix Mail Transport Agent
      postfix@-.service,loaded,active,running, Postfix Mail Transport Agent (instance -)
      pve-cluster.service,loaded,active,running, The Proxmox VE cluster filesystem
      pve-daily-update.service,loaded,inactive,dead, Daily PVE download activities
      pve-firewall.service,loaded,active,running, Proxmox VE firewall
      pve-guests.service,loaded,active,exited, PVE guests
      pve-ha-crm.service,loaded,active,running, PVE Cluster HA Resource Manager Daemon
      pve-ha-lrm.service,loaded,active,running, PVE Local HA Resource Manager Daemon
      pve-lxc-syscalld.service,loaded,active,running, Proxmox VE LXC Syscall Daemon
      pvebanner.service,loaded,active,exited, Proxmox VE Login Banner
      pvedaemon.service,loaded,active,running, PVE API Daemon
      pvefw-logger.service,loaded,active,running, Proxmox VE firewall logger
      pvenetcommit.service,loaded,active,exited, Commit Proxmox VE network changes
      pveproxy.service,loaded,active,running, PVE API Proxy Server
      pvesr.service,loaded,inactive,dead, Proxmox VE replication runner
      pvestatd.service,loaded,active,running, PVE Status Daemon
      qmeventd.service,loaded,active,running, PVE Qemu Event Daemon
      rbdmap.service,loaded,active,exited, Map RBD devices
      rc-local.service,loaded,inactive,dead, /etc/rc.local Compatibility
      rescue.service,loaded,inactive,dead, Rescue Shell
      rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server
      rpc-statd-notify.service,loaded,inactive,dead, Notify NFS peers of a restart
      rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server
      rpcbind.service,loaded,active,running, RPC bind portmap service
      rrdcached.service,loaded,active,running, LSB: start or stop rrdcached
      rsync.service,loaded,inactive,dead, fast remote file copy program daemon
      rsyslog.service,loaded,active,running, System Logging Service
      sendmail.service,not-found,inactive,dead, sendmail.service
      smartmontools.service,loaded,active,running, Self Monitoring and Reporting Technology (SMART) Daemon
      smb.service,not-found,inactive,dead, smb.service
      spiceproxy.service,loaded,active,running, PVE SPICE Proxy Server
      ssh.service,loaded,active,running, OpenBSD Secure Shell server
      systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console
      systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall
      systemd-backlight@backlight:acpi_video0.service,loaded,active,exited, Load/Save Screen Backlight Brightness of backlight:acpi_video0
      systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats
      systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device
      systemd-fsck@dev-disk-by\x2duuid-D782\x2dA871.service,loaded,active,exited, File System Check on /dev/disk/by-uuid/D782-A871
      systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status
      systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database
      systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon
      systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage
      systemd-journald.service,loaded,active,running, Journal Service
      systemd-logind.service,loaded,active,running, Login Service
      systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk
      systemd-modules-load.service,loaded,active,exited, Load Kernel Modules
      systemd-networkd.service,loaded,inactive,dead, Network Service
      systemd-quotacheck.service,loaded,inactive,dead, File System Quota Check
      systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed
      systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems
      systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status
      systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables
      systemd-sysusers.service,loaded,active,exited, Create System Users
      systemd-timesyncd.service,loaded,active,running, Network Time Synchronization
      systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories
      systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev
      systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories
      systemd-udev-settle.service,loaded,active,exited, udev Wait for Complete Device Initialization
      systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices
      systemd-udevd.service,loaded,active,running, udev Kernel Device Manager
      systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service
      systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes
      systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown
      systemd-user-sessions.service,loaded,active,exited, Permit User Sessions
      systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service
      user-runtime-dir@0.service,loaded,active,exited, User Runtime Directory /run/user/0
      user@0.service,loaded,active,running, User Manager for UID 0
      watchdog-mux.service,loaded,active,running, Proxmox VE watchdog multiplexer
      zfs-import-cache.service,loaded,active,exited, Import ZFS pools by cache file
      zfs-mount.service,loaded,active,exited, Mount ZFS filesystems
      zfs-share.service,loaded,active,exited, ZFS file system shares
      zfs-volume-wait.service,loaded,active,exited, Wait for ZFS Volume (zvol) links in /dev
      zfs-zed.service,loaded,active,running, ZFS Event Daemon (zed)
      2021-01-08 15:49:13.698 - debug: linux-control.0 (21312) [servicesInfo] Proxmox (192.168.1.102:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"blk-availability.service","load":"loaded","active":"active","running":"exited","description":"Availability of block devices"},{"id":"ceph.service","load":"not-found","active":"inactive","running":"dead","description":"ceph.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-getty.service","load":"loaded","active":"inactive","running":"dead","description":"Console Getty"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"corosync.service","load":"loaded","active":"inactive","running":"dead","description":"Corosync Cluster Engine"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"dm-event.service","load":"loaded","active":"active","running":"running","description":"Device-mapper event daemon"},{"id":"dracut-mount.service","load":"not-found","active":"inactive","running":"dead","description":"dracut-mount.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"exim4.service","load":"not-found","active":"inactive","running":"dead","description":"exim4.service"},{"id":"fcoe.service","load":"not-found","active":"inactive","running":"dead","description":"fcoe.service"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"glusterd.service","load":"not-found","active":"inactive","running":"dead","description":"glusterd.service"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"iscsi-shutdown.service","load":"not-found","active":"inactive","running":"dead","description":"iscsi-shutdown.service"},{"id":"iscsid.service","load":"loaded","active":"active","running":"running","description":"iSCSI initiator daemon (iscsid)"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"ksmtuned.service","load":"loaded","active":"active","running":"running","description":"Kernel Samepage Merging (KSM) Tuning Daemon"},{"id":"lm-sensors.service","load":"loaded","active":"active","running":"exited","description":"Initialize hardware monitoring sensors"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"lvm2-activation.service","load":"not-found","active":"inactive","running":"dead","description":"lvm2-activation.service"},{"id":"lvm2-lvmpolld.service","load":"loaded","active":"inactive","running":"dead","description":"LVM2 poll daemon"},{"id":"lvm2-monitor.service","load":"loaded","active":"active","running":"exited","description":"Monitoring of LVM2 mirrors","field6":"snapshots etc. using dmeventd or progress polling"},{"id":"lvm2-pvscan@259:3.service","load":"loaded","active":"active","running":"exited","description":"LVM event activation on device 259:3"},{"id":"lxc-monitord.service","load":"loaded","active":"active","running":"running","description":"LXC Container Monitoring Daemon"},{"id":"lxc-net.service","load":"loaded","active":"active","running":"exited","description":"LXC network bridge setup"},{"id":"lxc.service","load":"loaded","active":"active","running":"exited","description":"LXC Container Initialization and Autoboot Code"},{"id":"lxcfs.service","load":"loaded","active":"active","running":"running","description":"FUSE filesystem for LXC"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-kernel-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-kernel-server.service"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"open-iscsi.service","load":"loaded","active":"active","running":"exited","description":"Login to default iSCSI targets"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"postfix.service","load":"loaded","active":"active","running":"exited","description":"Postfix Mail Transport Agent"},{"id":"postfix@-.service","load":"loaded","active":"active","running":"running","description":"Postfix Mail Transport Agent (instance -)"},{"id":"pve-cluster.service","load":"loaded","active":"active","running":"running","description":"The Proxmox VE cluster filesystem"},{"id":"pve-daily-update.service","load":"loaded","active":"inactive","running":"dead","description":"Daily PVE download activities"},{"id":"pve-firewall.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE firewall"},{"id":"pve-guests.service","load":"loaded","active":"active","running":"exited","description":"PVE guests"},{"id":"pve-ha-crm.service","load":"loaded","active":"active","running":"running","description":"PVE Cluster HA Resource Manager Daemon"},{"id":"pve-ha-lrm.service","load":"loaded","active":"active","running":"running","description":"PVE Local HA Resource Manager Daemon"},{"id":"pve-lxc-syscalld.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE LXC Syscall Daemon"},{"id":"pvebanner.service","load":"loaded","active":"active","running":"exited","description":"Proxmox VE Login Banner"},{"id":"pvedaemon.service","load":"loaded","active":"active","running":"running","description":"PVE API Daemon"},{"id":"pvefw-logger.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE firewall logger"},{"id":"pvenetcommit.service","load":"loaded","active":"active","running":"exited","description":"Commit Proxmox VE network changes"},{"id":"pveproxy.service","load":"loaded","active":"active","running":"running","description":"PVE API Proxy Server"},{"id":"pvesr.service","load":"loaded","active":"inactive","running":"dead","description":"Proxmox VE replication runner"},{"id":"pvestatd.service","load":"loaded","active":"active","running":"running","description":"PVE Status Daemon"},{"id":"qmeventd.service","load":"loaded","active":"active","running":"running","description":"PVE Qemu Event Daemon"},{"id":"rbdmap.service","load":"loaded","active":"active","running":"exited","description":"Map RBD devices"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-statd-notify.service","load":"loaded","active":"inactive","running":"dead","description":"Notify NFS peers of a restart"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpcbind.service","load":"loaded","active":"active","running":"running","description":"RPC bind portmap service"},{"id":"rrdcached.service","load":"loaded","active":"active","running":"running","description":"LSB: start or stop rrdcached"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"sendmail.service","load":"not-found","active":"inactive","running":"dead","description":"sendmail.service"},{"id":"smartmontools.service","load":"loaded","active":"active","running":"running","description":"Self Monitoring and Reporting Technology (SMART) Daemon"},{"id":"smb.service","load":"not-found","active":"inactive","running":"dead","description":"smb.service"},{"id":"spiceproxy.service","load":"loaded","active":"active","running":"running","description":"PVE SPICE Proxy Server"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-backlight@backlight:acpi_video0.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Screen Backlight Brightness of backlight:acpi_video0"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsck@dev-disk-by\\x2duuid-D782\\x2dA871.service","load":"loaded","active":"active","running":"exited","description":"File System Check on /dev/disk/by-uuid/D782-A871"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-quotacheck.service","load":"loaded","active":"inactive","running":"dead","description":"File System Quota Check"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-settle.service","load":"loaded","active":"active","running":"exited","description":"udev Wait for Complete Device Initialization"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@0.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/0"},{"id":"user@0.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 0"},{"id":"watchdog-mux.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE watchdog multiplexer"},{"id":"zfs-import-cache.service","load":"loaded","active":"active","running":"exited","description":"Import ZFS pools by cache file"},{"id":"zfs-mount.service","load":"loaded","active":"active","running":"exited","description":"Mount ZFS filesystems"},{"id":"zfs-share.service","load":"loaded","active":"active","running":"exited","description":"ZFS file system shares"},{"id":"zfs-volume-wait.service","load":"loaded","active":"active","running":"exited","description":"Wait for ZFS Volume (zvol) links in /dev"},{"id":"zfs-zed.service","load":"loaded","active":"active","running":"running","description":"ZFS Event Daemon (zed)"}]
      2021-01-08 15:49:13.911 - debug: linux-control.0 (21312) [needrestart] Proxmox (192.168.1.102:22): no datapoints selected -> removing existing datapoints
      2021-01-08 15:49:13.918 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'du -sk /var/log/ | awk '{ print $1 /1024 }''
      2021-01-08 15:49:13.927 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 28.8086
      2021-01-08 15:49:13.928 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.size: 28.81 MB
      2021-01-08 15:49:13.971 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'find /var/log/ -name "*" | wc -l'
      2021-01-08 15:49:13.980 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1382
      2021-01-08 15:49:13.981 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.files: 1382 Dateien
      2021-01-08 15:49:14.023 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'tmp=$(find /var/log/ -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
      2021-01-08 15:49:15.018 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1610117351
      2021-01-08 15:49:15.020 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.lastChange: 1610117351000 -> 08.01.2021 15:49
      2021-01-08 15:49:15.064 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'du -sk /var/ | awk '{ print $1 /1024 }''
      2021-01-08 15:49:15.095 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1899.54
      2021-01-08 15:49:15.096 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.size: 1899.54 MB
      2021-01-08 15:49:15.140 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'find /var/ -name "*" | wc -l'
      2021-01-08 15:49:15.159 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 5349
      2021-01-08 15:49:15.161 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.files: 5349 Dateien
      2021-01-08 15:49:15.205 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'tmp=$(find /var/ -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
      2021-01-08 15:49:19.082 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1610117359
      2021-01-08 15:49:19.083 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.lastChange: 1610117359000 -> 08.01.2021 15:49
      2021-01-08 15:49:19.128 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
      2021-01-08 15:49:19.137 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: root, description: ): response stdout: 14
      2021-01-08 15:49:19.139 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
      2021-01-08 15:49:19.145 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: mem, description: ): response stdout: 31986;7015;24428
      2021-01-08 15:49:19.188 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: swap, description: ): send command: 'free -m | awk ' NR == 3 {print $2";"$3";"$4}''
      2021-01-08 15:49:19.195 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: swap, description: ): response stdout: 8191;0;8191
      2021-01-08 15:49:19.240 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
      2021-01-08 15:49:19.255 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: top-process, description: ): response stdout: 39.4;/usr/bin/kvm
      2021-01-08 15:49:19.300 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: cpu-temp, description: ): send command: 'sensors | grep Package -m 1 | awk '{print $4}' | awk '{print substr($1, length($0)-6,2)}''
      2021-01-08 15:49:19.307 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: cpu-temp, description: ): response stdout: 60
      2021-01-08 15:49:19.352 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_0, description: ): send command: 'sensors | grep 'Core 0:' | awk '{print $3}' | cut -c2-3'
      2021-01-08 15:49:19.359 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_0, description: ): response stdout: 60
      2021-01-08 15:49:19.404 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_1, description: ): send command: 'sensors | grep 'Core 1:' | awk '{print $3}' | cut -c2-3'
      2021-01-08 15:49:19.411 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_1, description: ): response stdout: 58
      2021-01-08 15:49:19.459 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_2, description: ): send command: 'sensors | grep 'Core 2:' | awk '{print $3}' | cut -c2-3'
      2021-01-08 15:49:19.468 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_2, description: ): response stdout: 58
      2021-01-08 15:49:19.470 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_3, description: ): send command: 'sensors | grep 'Core 3:' | awk '{print $3}' | cut -c2-3'
      2021-01-08 15:49:19.478 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_3, description: ): response stdout: 59
      2021-01-08 15:49:19.481 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Raspberrymatic, description: ): send command: 'qm status 100 | awk '{print substr($0, length($0)-6,7)}''
      2021-01-08 15:49:20.042 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Raspberrymatic, description: ): response stdout: running
      2021-01-08 15:49:20.056 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.ioBroker, description: ): send command: 'qm status 110 | awk '{print substr($0, length($0)-6,7)}''
      2021-01-08 15:49:20.646 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.ioBroker, description: ): response stdout: running
      2021-01-08 15:49:20.649 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Motioneye, description: ): send command: 'qm status 120 | awk '{print substr($0, length($0)-6,7)}''
      2021-01-08 15:49:21.202 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Motioneye, description: ): response stdout: running
      2021-01-08 15:49:21.210 - info: linux-control.0 (21312) successful received data from Proxmox (192.168.1.102:22)
      2021-01-08 15:49:21.232 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.refresh' subscribed
      2021-01-08 15:49:21.232 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.aptUpdate' subscribed
      2021-01-08 15:49:21.232 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.aptUpgrade' subscribed
      2021-01-08 15:49:21.232 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.restart' subscribed
      2021-01-08 15:49:21.233 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.start' subscribed
      2021-01-08 15:49:21.233 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.stop' subscribed
      2021-01-08 15:49:21.233 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.restart' subscribed
      2021-01-08 15:49:21.233 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.shutdown' subscribed
      2021-01-08 15:49:21.233 - info: linux-control.0 (21312) getting data from ioBroker (192.168.1.170:22, Adapter start)
      2021-01-08 15:49:21.244 - debug: linux-control.0 (21312) [getConnection] Host 'ioBroker' (192.168.1.170:22): using sudo for authentification
      2021-01-08 15:49:21.341 - debug: linux-control.0 (21312) [distributionInfo] ioBroker (192.168.1.170:22): send command: 'cat /etc/os-release'
      2021-01-08 15:49:21.374 - debug: linux-control.0 (21312) [distributionInfo] ioBroker (192.168.1.170:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
      VERSION_ID="10"
      ID=debian
      2021-01-08 15:49:21.376 - debug: linux-control.0 (21312) [distributionInfo] ioBroker (192.168.1.170:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
      2021-01-08 15:49:21.434 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'sudo -S apt-get update'
      2021-01-08 15:49:21.452 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout:
      [sudo] Passwort für dirk:
      Leider darf der Benutzer dirk »/usr/bin/apt-get update« als root auf ioBrokerNUC nicht ausführen.
      2021-01-08 15:49:21.452 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s\[([\w,\-,\d,\.,~,:,\+]+)\]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
      2021-01-08 15:49:21.805 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout:
      2021-01-08 15:49:21.806 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.newPackages: 0
      2021-01-08 15:49:21.809 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.upgradable: false
      2021-01-08 15:49:21.814 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
      2021-01-08 15:49:21.828 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout: 1609923124
      2021-01-08 15:49:21.829 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.lastUpdate: 1609923124000 -> 06.01.2021 09:52
      2021-01-08 15:49:21.873 - debug: linux-control.0 (21312) [servicesInfo] ioBroker (192.168.1.170:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
      2021-01-08 15:49:21.881 - debug: linux-control.0 (21312) [servicesInfo] ioBroker (192.168.1.170:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
      ifup@ens18.service,loaded,active,exited, ifup for ens18
      influxdb.service,not-found,inactive,dead, influxdb.service
      iobroker.service,loaded,active,running, ioBroker Server
      mariadb-server.service,not-found,inactive,dead, mariadb-server.service
      mysql-server.service,not-found,inactive,dead, mysql-server.service
      redis.service,not-found,inactive,dead, redis.service
      user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000
      user@1000.service,loaded,active,running, User Manager for UID 1000
      2021-01-08 15:49:21.884 - debug: linux-control.0 (21312) [servicesInfo] ioBroker (192.168.1.170:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
      2021-01-08 15:49:22.037 - debug: linux-control.0 (21312) [needrestart] ioBroker (192.168.1.170:22): no datapoints selected -> removing existing datapoints
      2021-01-08 15:49:22.043 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
      2021-01-08 15:49:22.048 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: root, description: ): response stdout: 27
      2021-01-08 15:49:22.051 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
      2021-01-08 15:49:22.056 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: mem, description: ): response stdout: 7978;2251;5034
      2021-01-08 15:49:22.058 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: swap, description: ): send command: 'free -m | awk ' NR == 3 {print $2";"$3";"$4}''
      2021-01-08 15:49:22.064 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: swap, description: ): response stdout: 8189;0;8189
      2021-01-08 15:49:22.066 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
      2021-01-08 15:49:22.080 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: top-process, description: ): response stdout: 8.4;io.linux-control.0
      2021-01-08 15:49:22.082 - debug: linux-control.0 (21312) [userCommand] ioBroker (192.168.1.170:22): datapoint-id: ioB-stop, description: : create button
      2021-01-08 15:49:22.083 - debug: linux-control.0 (21312) [userCommand] ioBroker (192.168.1.170:22): datapoint-id: ioB-start, description: : create button
      2021-01-08 15:49:22.084 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: opt, description: ): send command: 'du -c /opt/iobroker | tail -1 | awk '{printf $1MB}''
      2021-01-08 15:49:22.397 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: opt, description: ): response stdout: 1833808
      2021-01-08 15:49:22.402 - info: linux-control.0 (21312) successful received data from ioBroker (192.168.1.170:22)
      2021-01-08 15:49:22.417 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.refresh' subscribed
      2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.aptUpdate' subscribed
      2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.aptUpgrade' subscribed
      2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.restart' subscribed
      2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.ioB-stop' subscribed
      2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.ioB-start' subscribed
      2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.start' subscribed
      2021-01-08 15:49:22.419 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.stop' subscribed
      2021-01-08 15:49:22.419 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.restart' subscribed
      2021-01-08 15:49:22.419 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.start' subscribed
      2021-01-08 15:49:22.419 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.stop' subscribed
      2021-01-08 15:49:22.419 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.restart' subscribed
      2021-01-08 15:49:22.420 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.shutdown' subscribed
      2021-01-08 15:49:22.420 - info: linux-control.0 (21312) getting data from Raspberrymatic (192.168.1.171:22, Adapter start)
      2021-01-08 15:49:22.517 - debug: linux-control.0 (21312) [distributionInfo] Raspberrymatic (192.168.1.171:22): send command: 'cat /etc/os-release'
      2021-01-08 15:49:22.523 - debug: linux-control.0 (21312) [distributionInfo] Raspberrymatic (192.168.1.171:22): response stdout: NAME=Buildroot
      VERSION=2.15.5-20151101-2805-g412dbfc5
      ID=buildroot
      VERSION_ID=2020.11
      PRETTY_NAME="Buildroot 2020.11"
      2021-01-08 15:49:22.525 - debug: linux-control.0 (21312) [distributionInfo] Raspberrymatic (192.168.1.171:22): csvToJson result: [{"prop":"NAME","val":"Buildroot"},{"prop":"VERSION","val":"2.15.5-20151101-2805-g412dbfc5"},{"prop":"ID","val":"buildroot"},{"prop":"VERSION_ID","val":"2020.11"},{"prop":"PRETTY_NAME","val":"Buildroot 2020.11"}]
      2021-01-08 15:49:22.571 - warn: linux-control.0 (21312) [distributionInfo] Raspberrymatic (192.168.1.171:22): property 'VERSION_CODENAME' not exist in result!
      2021-01-08 15:49:22.617 - debug: linux-control.0 (21312) [cmdAptUpdate] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
      2021-01-08 15:49:22.619 - debug: linux-control.0 (21312) [servicesInfo] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
      2021-01-08 15:49:22.624 - debug: linux-control.0 (21312) [needrestart] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
      2021-01-08 15:49:22.630 - debug: linux-control.0 (21312) [userCommandExecute] Raspberrymatic (192.168.1.171:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
      2021-01-08 15:49:22.635 - debug: linux-control.0 (21312) [userCommandExecute] Raspberrymatic (192.168.1.171:22, id: root, description: ): response stdout: 61
      2021-01-08 15:49:22.683 - info: linux-control.0 (21312) successful received data from Raspberrymatic (192.168.1.171:22)
      2021-01-08 15:49:22.701 - debug: linux-control.0 (21312) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.refresh' subscribed
      2021-01-08 15:49:22.702 - debug: linux-control.0 (21312) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.aptUpgrade' subscribed
      2021-01-08 15:49:22.702 - debug: linux-control.0 (21312) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.aptUpdate' subscribed
      2021-01-08 15:49:22.702 - debug: linux-control.0 (21312) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.restart' subscribed
      2021-01-08 15:49:22.702 - debug: linux-control.0 (21312) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.shutdown' subscribed
      2021-01-08 15:49:22.702 - info: linux-control.0 (21312) getting data from Motioneye (192.168.1.174:22, Adapter start)
      2021-01-08 15:49:22.713 - debug: linux-control.0 (21312) [getConnection] Host 'Motioneye' (192.168.1.174:22): using sudo for authentification
      2021-01-08 15:49:22.795 - debug: linux-control.0 (21312) [distributionInfo] Motioneye (192.168.1.174:22): send command: 'cat /etc/os-release'
      2021-01-08 15:49:22.826 - debug: linux-control.0 (21312) [distributionInfo] Motioneye (192.168.1.174:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
      VERSION_ID="10"
      ID=debian
      2021-01-08 15:49:22.829 - debug: linux-control.0 (21312) [distributionInfo] Motioneye (192.168.1.174:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
      2021-01-08 15:49:22.837 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'sudo -S apt-get update'
      2021-01-08 15:49:22.858 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout:
      dirk ist nicht in der sudoers-Datei. Dieser Vorfall wird gemeldet.
      2021-01-08 15:49:22.858 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s\[([\w,\-,\d,\.,~,:,\+]+)\]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
      2021-01-08 15:49:23.192 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout:
      2021-01-08 15:49:23.192 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.newPackages: 0
      2021-01-08 15:49:23.195 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.upgradable: false
      2021-01-08 15:49:23.201 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
      2021-01-08 15:49:23.216 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout: 1585325736
      2021-01-08 15:49:23.217 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.lastUpdate: 1585325736000 -> 27.03.2020 17:15
      2021-01-08 15:49:23.260 - debug: linux-control.0 (21312) [servicesInfo] Motioneye (192.168.1.174:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
      2021-01-08 15:49:23.269 - debug: linux-control.0 (21312) [servicesInfo] Motioneye (192.168.1.174:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
      motion.service,loaded,active,exited, LSB: Start Motion detection
      motioneye.service,loaded,active,running, motionEye Server
      2021-01-08 15:49:23.270 - debug: linux-control.0 (21312) [servicesInfo] Motioneye (192.168.1.174:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"motion.service","load":"loaded","active":"active","running":"exited","description":"LSB: Start Motion detection"},{"id":"motioneye.service","load":"loaded","active":"active","running":"running","description":"motionEye Server"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
      2021-01-08 15:49:23.398 - debug: linux-control.0 (21312) [needrestart] Motioneye (192.168.1.174:22): no datapoints selected -> removing existing datapoints
      2021-01-08 15:49:23.403 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): send command: 'sudo -S du -sk /var/lib/motioneye | awk '{ print $1 /1024 }''
      2021-01-08 15:49:23.424 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): response stdout:
      2021-01-08 15:49:23.425 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): Motioneye.folders.motioneye.size: NaN MB
      2021-01-08 15:49:23.427 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): send command: 'sudo -S find /var/lib/motioneye -name "*" | wc -l'
      2021-01-08 15:49:23.443 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): response stdout:
      2021-01-08 15:49:23.444 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): Motioneye.folders.motioneye.files: NaN Dateien
      2021-01-08 15:49:23.487 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): send command: 'tmp=$(sudo -S find /var/lib/motioneye -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
      2021-01-08 15:49:23.508 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): response stdout:
      date: Diese Option benötigt ein Argument -- »r«
      „date --help“ liefert weitere Informationen.
      2021-01-08 15:49:23.509 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): Motioneye.folders.motioneye.lastChange: NaN ->
      2021-01-08 15:49:23.551 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
      2021-01-08 15:49:23.559 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: root, description: ): response stdout: 28
      2021-01-08 15:49:23.561 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
      2021-01-08 15:49:23.570 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: mem, description: ): response stdout: 3946;222;3532
      2021-01-08 15:49:23.582 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
      2021-01-08 15:49:23.596 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: top-process, description: ): response stdout: 33.9;/usr/bin/motion
      2021-01-08 15:49:23.606 - info: linux-control.0 (21312) successful received data from Motioneye (192.168.1.174:22)
      2021-01-08 15:49:23.619 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.refresh' subscribed
      2021-01-08 15:49:23.619 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.aptUpdate' subscribed
      2021-01-08 15:49:23.619 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.aptUpgrade' subscribed
      2021-01-08 15:49:23.620 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.restart' subscribed
      2021-01-08 15:49:23.620 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.start' subscribed
      2021-01-08 15:49:23.620 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.stop' subscribed
      2021-01-08 15:49:23.620 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.restart' subscribed
      2021-01-08 15:49:23.620 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.shutdown' subscribed
      NUC8i5 mit Proxmox; Raspberrymatic in VM, iobroker, Motioneye, infuxDB und Grafana in CT.
      ScroungerS 1 Antwort Letzte Antwort
      • dirk1962D dirk1962
        @liv-in-sky @Scrounger Ich hatte den Ordner Befehl für Motioneye wieder rausgenommen. In diesem log ist er wieder mit drin.
        2021-01-08 15:49:06.639 - info: host.ioBrokerNUC stopInstance system.adapter.linux-control.0 (force=false, process=true)
        2021-01-08 15:49:06.642 - info: host.ioBrokerNUC stopInstance system.adapter.linux-control.0 send kill signal
        2021-01-08 15:49:06.644 - info: linux-control.0 (21211) Got terminate signal TERMINATE_YOURSELF
        2021-01-08 15:49:06.645 - info: linux-control.0 (21211) cleaned everything up...
        2021-01-08 15:49:06.645 - info: linux-control.0 (21211) terminating
        2021-01-08 15:49:06.645 - debug: linux-control.0 (21211) Plugin sentry destroyed
        2021-01-08 15:49:06.645 - info: linux-control.0 (21211) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-01-08 15:49:07.168 - info: host.ioBrokerNUC instance system.adapter.linux-control.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2021-01-08 15:49:09.673 - info: host.ioBrokerNUC instance system.adapter.linux-control.0 started with pid 21312
        2021-01-08 15:49:10.004 - debug: linux-control.0 (21312) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2021-01-08 15:49:10.030 - debug: linux-control.0 (21312) Objects client ready ... initialize now
        2021-01-08 15:49:10.031 - debug: linux-control.0 (21312) Objects create System PubSub Client
        2021-01-08 15:49:10.032 - debug: linux-control.0 (21312) Objects create User PubSub Client
        2021-01-08 15:49:10.032 - debug: linux-control.0 (21312) Objects client initialize lua scripts
        2021-01-08 15:49:10.041 - debug: linux-control.0 (21312) Objects connected to redis: 127.0.0.1:9001
        2021-01-08 15:49:10.043 - debug: linux-control.0 (21312) objectDB connected
        2021-01-08 15:49:10.044 - debug: linux-control.0 (21312) Redis States: Use Redis connection: 127.0.0.1:9000
        2021-01-08 15:49:10.049 - debug: linux-control.0 (21312) States create User PubSub Client
        2021-01-08 15:49:10.050 - debug: linux-control.0 (21312) States create System PubSub Client
        2021-01-08 15:49:10.057 - debug: linux-control.0 (21312) States connected to redis: 127.0.0.1:9000
        2021-01-08 15:49:10.058 - debug: linux-control.0 (21312) statesDB connected
        2021-01-08 15:49:11.034 - debug: linux-control.0 (21312) Plugin sentry Initialize Plugin (enabled=true)
        2021-01-08 15:49:11.082 - info: linux-control.0 (21312) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.linux-control, node: v12.20.1, js-controller: 3.1.6
        2021-01-08 15:49:11.114 - info: linux-control.0 (21312) getting data from Proxmox (192.168.1.102:22, Adapter start)
        2021-01-08 15:49:11.199 - debug: linux-control.0 (21312) [distributionInfo] Proxmox (192.168.1.102:22): send command: 'cat /etc/os-release'
        2021-01-08 15:49:11.290 - debug: linux-control.0 (21312) [distributionInfo] Proxmox (192.168.1.102:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
        NAME="Debian GNU/Linux"
        VERSION_ID="10"
        VERSION="10 (buster)"
        VERSION_CODENAME=buster
        ID=debian
        HOME_URL="https://www.debian.org/"
        SUPPORT_URL="https://www.debian.org/support"
        BUG_REPORT_URL="https://bugs.debian.org/"
        2021-01-08 15:49:11.296 - debug: linux-control.0 (21312) [distributionInfo] Proxmox (192.168.1.102:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
        2021-01-08 15:49:11.307 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'apt-get update'
        2021-01-08 15:49:13.285 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout: Hit:1 http://security.debian.org buster/updates InRelease
        Hit:2 http://security.debian.org/debian-security buster/updates InRelease
        Hit:3 http://download.proxmox.com/debian/pve buster InRelease
        Hit:4 http://ftp.de.debian.org/debian buster InRelease
        Hit:5 http://ftp.de.debian.org/debian buster-updates InRelease
        Reading package lists...
        2021-01-08 15:49:13.285 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s\[([\w,\-,\d,\.,~,:,\+]+)\]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
        2021-01-08 15:49:13.577 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout:
        2021-01-08 15:49:13.577 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.newPackages: 0
        2021-01-08 15:49:13.580 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.upgradable: false
        2021-01-08 15:49:13.626 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
        ' -W | sort -nr | head -1'
        2021-01-08 15:49:13.640 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout: 1609669960
        2021-01-08 15:49:13.640 - debug: linux-control.0 (21312) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.lastUpdate: 1609669960000 -> 03.01.2021 11:32
        2021-01-08 15:49:13.685 - debug: linux-control.0 (21312) [servicesInfo] Proxmox (192.168.1.102:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
        2021-01-08 15:49:13.695 - debug: linux-control.0 (21312) [servicesInfo] Proxmox (192.168.1.102:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
        apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities
        apt-daily.service,loaded,inactive,dead, Daily apt download activities
        auditd.service,not-found,inactive,dead, auditd.service
        auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS
        blk-availability.service,loaded,active,exited, Availability of block devices
        ceph.service,not-found,inactive,dead, ceph.service
        connman.service,not-found,inactive,dead, connman.service
        console-getty.service,loaded,inactive,dead, Console Getty
        console-screen.service,not-found,inactive,dead, console-screen.service
        console-setup.service,loaded,active,exited, Set console font and keymap
        corosync.service,loaded,inactive,dead, Corosync Cluster Engine
        cron.service,loaded,active,running, Regular background program processing daemon
        dbus.service,loaded,active,running, D-Bus System Message Bus
        display-manager.service,not-found,inactive,dead, display-manager.service
        dm-event.service,loaded,active,running, Device-mapper event daemon
        dracut-mount.service,not-found,inactive,dead, dracut-mount.service
        emergency.service,loaded,inactive,dead, Emergency Shell
        exim4.service,not-found,inactive,dead, exim4.service
        fcoe.service,not-found,inactive,dead, fcoe.service
        getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available
        getty@tty1.service,loaded,active,running, Getty on tty1
        glusterd.service,not-found,inactive,dead, glusterd.service
        gssproxy.service,not-found,inactive,dead, gssproxy.service
        ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown
        iscsi-shutdown.service,not-found,inactive,dead, iscsi-shutdown.service
        iscsid.service,loaded,active,running, iSCSI initiator daemon (iscsid)
        kbd.service,not-found,inactive,dead, kbd.service
        keyboard-setup.service,loaded,active,exited, Set the console keyboard layout
        kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel
        ksmtuned.service,loaded,active,running, Kernel Samepage Merging (KSM) Tuning Daemon
        lm-sensors.service,loaded,active,exited, Initialize hardware monitoring sensors
        logrotate.service,loaded,inactive,dead, Rotate log files
        lvm2-activation.service,not-found,inactive,dead, lvm2-activation.service
        lvm2-lvmpolld.service,loaded,inactive,dead, LVM2 poll daemon
        lvm2-monitor.service,loaded,active,exited, Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling
        lvm2-pvscan@259:3.service,loaded,active,exited, LVM event activation on device 259:3
        lxc-monitord.service,loaded,active,running, LXC Container Monitoring Daemon
        lxc-net.service,loaded,active,exited, LXC network bridge setup
        lxc.service,loaded,active,exited, LXC Container Initialization and Autoboot Code
        lxcfs.service,loaded,active,running, FUSE filesystem for LXC
        man-db.service,loaded,inactive,dead, Daily man-db regeneration
        networking.service,loaded,active,exited, Raise network interfaces
        NetworkManager.service,not-found,inactive,dead, NetworkManager.service
        nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service
        nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration
        nfs-kernel-server.service,not-found,inactive,dead, nfs-kernel-server.service
        nfs-server.service,not-found,inactive,dead, nfs-server.service
        nfs-utils.service,loaded,inactive,dead, NFS server and client services
        open-iscsi.service,loaded,active,exited, Login to default iSCSI targets
        plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service
        plymouth-start.service,not-found,inactive,dead, plymouth-start.service
        postfix.service,loaded,active,exited, Postfix Mail Transport Agent
        postfix@-.service,loaded,active,running, Postfix Mail Transport Agent (instance -)
        pve-cluster.service,loaded,active,running, The Proxmox VE cluster filesystem
        pve-daily-update.service,loaded,inactive,dead, Daily PVE download activities
        pve-firewall.service,loaded,active,running, Proxmox VE firewall
        pve-guests.service,loaded,active,exited, PVE guests
        pve-ha-crm.service,loaded,active,running, PVE Cluster HA Resource Manager Daemon
        pve-ha-lrm.service,loaded,active,running, PVE Local HA Resource Manager Daemon
        pve-lxc-syscalld.service,loaded,active,running, Proxmox VE LXC Syscall Daemon
        pvebanner.service,loaded,active,exited, Proxmox VE Login Banner
        pvedaemon.service,loaded,active,running, PVE API Daemon
        pvefw-logger.service,loaded,active,running, Proxmox VE firewall logger
        pvenetcommit.service,loaded,active,exited, Commit Proxmox VE network changes
        pveproxy.service,loaded,active,running, PVE API Proxy Server
        pvesr.service,loaded,inactive,dead, Proxmox VE replication runner
        pvestatd.service,loaded,active,running, PVE Status Daemon
        qmeventd.service,loaded,active,running, PVE Qemu Event Daemon
        rbdmap.service,loaded,active,exited, Map RBD devices
        rc-local.service,loaded,inactive,dead, /etc/rc.local Compatibility
        rescue.service,loaded,inactive,dead, Rescue Shell
        rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server
        rpc-statd-notify.service,loaded,inactive,dead, Notify NFS peers of a restart
        rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server
        rpcbind.service,loaded,active,running, RPC bind portmap service
        rrdcached.service,loaded,active,running, LSB: start or stop rrdcached
        rsync.service,loaded,inactive,dead, fast remote file copy program daemon
        rsyslog.service,loaded,active,running, System Logging Service
        sendmail.service,not-found,inactive,dead, sendmail.service
        smartmontools.service,loaded,active,running, Self Monitoring and Reporting Technology (SMART) Daemon
        smb.service,not-found,inactive,dead, smb.service
        spiceproxy.service,loaded,active,running, PVE SPICE Proxy Server
        ssh.service,loaded,active,running, OpenBSD Secure Shell server
        systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console
        systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall
        systemd-backlight@backlight:acpi_video0.service,loaded,active,exited, Load/Save Screen Backlight Brightness of backlight:acpi_video0
        systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats
        systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device
        systemd-fsck@dev-disk-by\x2duuid-D782\x2dA871.service,loaded,active,exited, File System Check on /dev/disk/by-uuid/D782-A871
        systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status
        systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database
        systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon
        systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage
        systemd-journald.service,loaded,active,running, Journal Service
        systemd-logind.service,loaded,active,running, Login Service
        systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk
        systemd-modules-load.service,loaded,active,exited, Load Kernel Modules
        systemd-networkd.service,loaded,inactive,dead, Network Service
        systemd-quotacheck.service,loaded,inactive,dead, File System Quota Check
        systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed
        systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems
        systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status
        systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables
        systemd-sysusers.service,loaded,active,exited, Create System Users
        systemd-timesyncd.service,loaded,active,running, Network Time Synchronization
        systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories
        systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev
        systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories
        systemd-udev-settle.service,loaded,active,exited, udev Wait for Complete Device Initialization
        systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices
        systemd-udevd.service,loaded,active,running, udev Kernel Device Manager
        systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service
        systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes
        systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown
        systemd-user-sessions.service,loaded,active,exited, Permit User Sessions
        systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service
        user-runtime-dir@0.service,loaded,active,exited, User Runtime Directory /run/user/0
        user@0.service,loaded,active,running, User Manager for UID 0
        watchdog-mux.service,loaded,active,running, Proxmox VE watchdog multiplexer
        zfs-import-cache.service,loaded,active,exited, Import ZFS pools by cache file
        zfs-mount.service,loaded,active,exited, Mount ZFS filesystems
        zfs-share.service,loaded,active,exited, ZFS file system shares
        zfs-volume-wait.service,loaded,active,exited, Wait for ZFS Volume (zvol) links in /dev
        zfs-zed.service,loaded,active,running, ZFS Event Daemon (zed)
        2021-01-08 15:49:13.698 - debug: linux-control.0 (21312) [servicesInfo] Proxmox (192.168.1.102:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"blk-availability.service","load":"loaded","active":"active","running":"exited","description":"Availability of block devices"},{"id":"ceph.service","load":"not-found","active":"inactive","running":"dead","description":"ceph.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-getty.service","load":"loaded","active":"inactive","running":"dead","description":"Console Getty"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"corosync.service","load":"loaded","active":"inactive","running":"dead","description":"Corosync Cluster Engine"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"dm-event.service","load":"loaded","active":"active","running":"running","description":"Device-mapper event daemon"},{"id":"dracut-mount.service","load":"not-found","active":"inactive","running":"dead","description":"dracut-mount.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"exim4.service","load":"not-found","active":"inactive","running":"dead","description":"exim4.service"},{"id":"fcoe.service","load":"not-found","active":"inactive","running":"dead","description":"fcoe.service"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"glusterd.service","load":"not-found","active":"inactive","running":"dead","description":"glusterd.service"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"iscsi-shutdown.service","load":"not-found","active":"inactive","running":"dead","description":"iscsi-shutdown.service"},{"id":"iscsid.service","load":"loaded","active":"active","running":"running","description":"iSCSI initiator daemon (iscsid)"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"ksmtuned.service","load":"loaded","active":"active","running":"running","description":"Kernel Samepage Merging (KSM) Tuning Daemon"},{"id":"lm-sensors.service","load":"loaded","active":"active","running":"exited","description":"Initialize hardware monitoring sensors"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"lvm2-activation.service","load":"not-found","active":"inactive","running":"dead","description":"lvm2-activation.service"},{"id":"lvm2-lvmpolld.service","load":"loaded","active":"inactive","running":"dead","description":"LVM2 poll daemon"},{"id":"lvm2-monitor.service","load":"loaded","active":"active","running":"exited","description":"Monitoring of LVM2 mirrors","field6":"snapshots etc. using dmeventd or progress polling"},{"id":"lvm2-pvscan@259:3.service","load":"loaded","active":"active","running":"exited","description":"LVM event activation on device 259:3"},{"id":"lxc-monitord.service","load":"loaded","active":"active","running":"running","description":"LXC Container Monitoring Daemon"},{"id":"lxc-net.service","load":"loaded","active":"active","running":"exited","description":"LXC network bridge setup"},{"id":"lxc.service","load":"loaded","active":"active","running":"exited","description":"LXC Container Initialization and Autoboot Code"},{"id":"lxcfs.service","load":"loaded","active":"active","running":"running","description":"FUSE filesystem for LXC"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-kernel-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-kernel-server.service"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"open-iscsi.service","load":"loaded","active":"active","running":"exited","description":"Login to default iSCSI targets"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"postfix.service","load":"loaded","active":"active","running":"exited","description":"Postfix Mail Transport Agent"},{"id":"postfix@-.service","load":"loaded","active":"active","running":"running","description":"Postfix Mail Transport Agent (instance -)"},{"id":"pve-cluster.service","load":"loaded","active":"active","running":"running","description":"The Proxmox VE cluster filesystem"},{"id":"pve-daily-update.service","load":"loaded","active":"inactive","running":"dead","description":"Daily PVE download activities"},{"id":"pve-firewall.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE firewall"},{"id":"pve-guests.service","load":"loaded","active":"active","running":"exited","description":"PVE guests"},{"id":"pve-ha-crm.service","load":"loaded","active":"active","running":"running","description":"PVE Cluster HA Resource Manager Daemon"},{"id":"pve-ha-lrm.service","load":"loaded","active":"active","running":"running","description":"PVE Local HA Resource Manager Daemon"},{"id":"pve-lxc-syscalld.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE LXC Syscall Daemon"},{"id":"pvebanner.service","load":"loaded","active":"active","running":"exited","description":"Proxmox VE Login Banner"},{"id":"pvedaemon.service","load":"loaded","active":"active","running":"running","description":"PVE API Daemon"},{"id":"pvefw-logger.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE firewall logger"},{"id":"pvenetcommit.service","load":"loaded","active":"active","running":"exited","description":"Commit Proxmox VE network changes"},{"id":"pveproxy.service","load":"loaded","active":"active","running":"running","description":"PVE API Proxy Server"},{"id":"pvesr.service","load":"loaded","active":"inactive","running":"dead","description":"Proxmox VE replication runner"},{"id":"pvestatd.service","load":"loaded","active":"active","running":"running","description":"PVE Status Daemon"},{"id":"qmeventd.service","load":"loaded","active":"active","running":"running","description":"PVE Qemu Event Daemon"},{"id":"rbdmap.service","load":"loaded","active":"active","running":"exited","description":"Map RBD devices"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-statd-notify.service","load":"loaded","active":"inactive","running":"dead","description":"Notify NFS peers of a restart"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpcbind.service","load":"loaded","active":"active","running":"running","description":"RPC bind portmap service"},{"id":"rrdcached.service","load":"loaded","active":"active","running":"running","description":"LSB: start or stop rrdcached"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"sendmail.service","load":"not-found","active":"inactive","running":"dead","description":"sendmail.service"},{"id":"smartmontools.service","load":"loaded","active":"active","running":"running","description":"Self Monitoring and Reporting Technology (SMART) Daemon"},{"id":"smb.service","load":"not-found","active":"inactive","running":"dead","description":"smb.service"},{"id":"spiceproxy.service","load":"loaded","active":"active","running":"running","description":"PVE SPICE Proxy Server"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-backlight@backlight:acpi_video0.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Screen Backlight Brightness of backlight:acpi_video0"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsck@dev-disk-by\\x2duuid-D782\\x2dA871.service","load":"loaded","active":"active","running":"exited","description":"File System Check on /dev/disk/by-uuid/D782-A871"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-quotacheck.service","load":"loaded","active":"inactive","running":"dead","description":"File System Quota Check"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-settle.service","load":"loaded","active":"active","running":"exited","description":"udev Wait for Complete Device Initialization"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@0.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/0"},{"id":"user@0.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 0"},{"id":"watchdog-mux.service","load":"loaded","active":"active","running":"running","description":"Proxmox VE watchdog multiplexer"},{"id":"zfs-import-cache.service","load":"loaded","active":"active","running":"exited","description":"Import ZFS pools by cache file"},{"id":"zfs-mount.service","load":"loaded","active":"active","running":"exited","description":"Mount ZFS filesystems"},{"id":"zfs-share.service","load":"loaded","active":"active","running":"exited","description":"ZFS file system shares"},{"id":"zfs-volume-wait.service","load":"loaded","active":"active","running":"exited","description":"Wait for ZFS Volume (zvol) links in /dev"},{"id":"zfs-zed.service","load":"loaded","active":"active","running":"running","description":"ZFS Event Daemon (zed)"}]
        2021-01-08 15:49:13.911 - debug: linux-control.0 (21312) [needrestart] Proxmox (192.168.1.102:22): no datapoints selected -> removing existing datapoints
        2021-01-08 15:49:13.918 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'du -sk /var/log/ | awk '{ print $1 /1024 }''
        2021-01-08 15:49:13.927 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 28.8086
        2021-01-08 15:49:13.928 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.size: 28.81 MB
        2021-01-08 15:49:13.971 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'find /var/log/ -name "*" | wc -l'
        2021-01-08 15:49:13.980 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1382
        2021-01-08 15:49:13.981 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.files: 1382 Dateien
        2021-01-08 15:49:14.023 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'tmp=$(find /var/log/ -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
        2021-01-08 15:49:15.018 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1610117351
        2021-01-08 15:49:15.020 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.log.lastChange: 1610117351000 -> 08.01.2021 15:49
        2021-01-08 15:49:15.064 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'du -sk /var/ | awk '{ print $1 /1024 }''
        2021-01-08 15:49:15.095 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1899.54
        2021-01-08 15:49:15.096 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.size: 1899.54 MB
        2021-01-08 15:49:15.140 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'find /var/ -name "*" | wc -l'
        2021-01-08 15:49:15.159 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 5349
        2021-01-08 15:49:15.161 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.files: 5349 Dateien
        2021-01-08 15:49:15.205 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): send command: 'tmp=$(find /var/ -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
        2021-01-08 15:49:19.082 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): response stdout: 1610117359
        2021-01-08 15:49:19.083 - debug: linux-control.0 (21312) [folderSizes] Proxmox (192.168.1.102:22): Proxmox.folders.var.lastChange: 1610117359000 -> 08.01.2021 15:49
        2021-01-08 15:49:19.128 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
        2021-01-08 15:49:19.137 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: root, description: ): response stdout: 14
        2021-01-08 15:49:19.139 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
        2021-01-08 15:49:19.145 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: mem, description: ): response stdout: 31986;7015;24428
        2021-01-08 15:49:19.188 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: swap, description: ): send command: 'free -m | awk ' NR == 3 {print $2";"$3";"$4}''
        2021-01-08 15:49:19.195 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: swap, description: ): response stdout: 8191;0;8191
        2021-01-08 15:49:19.240 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
        2021-01-08 15:49:19.255 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: top-process, description: ): response stdout: 39.4;/usr/bin/kvm
        2021-01-08 15:49:19.300 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: cpu-temp, description: ): send command: 'sensors | grep Package -m 1 | awk '{print $4}' | awk '{print substr($1, length($0)-6,2)}''
        2021-01-08 15:49:19.307 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: cpu-temp, description: ): response stdout: 60
        2021-01-08 15:49:19.352 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_0, description: ): send command: 'sensors | grep 'Core 0:' | awk '{print $3}' | cut -c2-3'
        2021-01-08 15:49:19.359 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_0, description: ): response stdout: 60
        2021-01-08 15:49:19.404 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_1, description: ): send command: 'sensors | grep 'Core 1:' | awk '{print $3}' | cut -c2-3'
        2021-01-08 15:49:19.411 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_1, description: ): response stdout: 58
        2021-01-08 15:49:19.459 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_2, description: ): send command: 'sensors | grep 'Core 2:' | awk '{print $3}' | cut -c2-3'
        2021-01-08 15:49:19.468 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_2, description: ): response stdout: 58
        2021-01-08 15:49:19.470 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_3, description: ): send command: 'sensors | grep 'Core 3:' | awk '{print $3}' | cut -c2-3'
        2021-01-08 15:49:19.478 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: Core_3, description: ): response stdout: 59
        2021-01-08 15:49:19.481 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Raspberrymatic, description: ): send command: 'qm status 100 | awk '{print substr($0, length($0)-6,7)}''
        2021-01-08 15:49:20.042 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Raspberrymatic, description: ): response stdout: running
        2021-01-08 15:49:20.056 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.ioBroker, description: ): send command: 'qm status 110 | awk '{print substr($0, length($0)-6,7)}''
        2021-01-08 15:49:20.646 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.ioBroker, description: ): response stdout: running
        2021-01-08 15:49:20.649 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Motioneye, description: ): send command: 'qm status 120 | awk '{print substr($0, length($0)-6,7)}''
        2021-01-08 15:49:21.202 - debug: linux-control.0 (21312) [userCommandExecute] Proxmox (192.168.1.102:22, id: befehle.Motioneye, description: ): response stdout: running
        2021-01-08 15:49:21.210 - info: linux-control.0 (21312) successful received data from Proxmox (192.168.1.102:22)
        2021-01-08 15:49:21.232 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.refresh' subscribed
        2021-01-08 15:49:21.232 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.aptUpdate' subscribed
        2021-01-08 15:49:21.232 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.aptUpgrade' subscribed
        2021-01-08 15:49:21.232 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.restart' subscribed
        2021-01-08 15:49:21.233 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.start' subscribed
        2021-01-08 15:49:21.233 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.services.ssh.stop' subscribed
        2021-01-08 15:49:21.233 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.restart' subscribed
        2021-01-08 15:49:21.233 - debug: linux-control.0 (21312) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.shutdown' subscribed
        2021-01-08 15:49:21.233 - info: linux-control.0 (21312) getting data from ioBroker (192.168.1.170:22, Adapter start)
        2021-01-08 15:49:21.244 - debug: linux-control.0 (21312) [getConnection] Host 'ioBroker' (192.168.1.170:22): using sudo for authentification
        2021-01-08 15:49:21.341 - debug: linux-control.0 (21312) [distributionInfo] ioBroker (192.168.1.170:22): send command: 'cat /etc/os-release'
        2021-01-08 15:49:21.374 - debug: linux-control.0 (21312) [distributionInfo] ioBroker (192.168.1.170:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
        VERSION_ID="10"
        ID=debian
        2021-01-08 15:49:21.376 - debug: linux-control.0 (21312) [distributionInfo] ioBroker (192.168.1.170:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
        2021-01-08 15:49:21.434 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'sudo -S apt-get update'
        2021-01-08 15:49:21.452 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout:
        [sudo] Passwort für dirk:
        Leider darf der Benutzer dirk »/usr/bin/apt-get update« als root auf ioBrokerNUC nicht ausführen.
        2021-01-08 15:49:21.452 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s\[([\w,\-,\d,\.,~,:,\+]+)\]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
        2021-01-08 15:49:21.805 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout:
        2021-01-08 15:49:21.806 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.newPackages: 0
        2021-01-08 15:49:21.809 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.upgradable: false
        2021-01-08 15:49:21.814 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
        2021-01-08 15:49:21.828 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): response stdout: 1609923124
        2021-01-08 15:49:21.829 - debug: linux-control.0 (21312) [cmdAptUpdate] ioBroker (192.168.1.170:22): ioBroker.updates.lastUpdate: 1609923124000 -> 06.01.2021 09:52
        2021-01-08 15:49:21.873 - debug: linux-control.0 (21312) [servicesInfo] ioBroker (192.168.1.170:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
        2021-01-08 15:49:21.881 - debug: linux-control.0 (21312) [servicesInfo] ioBroker (192.168.1.170:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
        ifup@ens18.service,loaded,active,exited, ifup for ens18
        influxdb.service,not-found,inactive,dead, influxdb.service
        iobroker.service,loaded,active,running, ioBroker Server
        mariadb-server.service,not-found,inactive,dead, mariadb-server.service
        mysql-server.service,not-found,inactive,dead, mysql-server.service
        redis.service,not-found,inactive,dead, redis.service
        user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000
        user@1000.service,loaded,active,running, User Manager for UID 1000
        2021-01-08 15:49:21.884 - debug: linux-control.0 (21312) [servicesInfo] ioBroker (192.168.1.170:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
        2021-01-08 15:49:22.037 - debug: linux-control.0 (21312) [needrestart] ioBroker (192.168.1.170:22): no datapoints selected -> removing existing datapoints
        2021-01-08 15:49:22.043 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
        2021-01-08 15:49:22.048 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: root, description: ): response stdout: 27
        2021-01-08 15:49:22.051 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
        2021-01-08 15:49:22.056 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: mem, description: ): response stdout: 7978;2251;5034
        2021-01-08 15:49:22.058 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: swap, description: ): send command: 'free -m | awk ' NR == 3 {print $2";"$3";"$4}''
        2021-01-08 15:49:22.064 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: swap, description: ): response stdout: 8189;0;8189
        2021-01-08 15:49:22.066 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
        2021-01-08 15:49:22.080 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: top-process, description: ): response stdout: 8.4;io.linux-control.0
        2021-01-08 15:49:22.082 - debug: linux-control.0 (21312) [userCommand] ioBroker (192.168.1.170:22): datapoint-id: ioB-stop, description: : create button
        2021-01-08 15:49:22.083 - debug: linux-control.0 (21312) [userCommand] ioBroker (192.168.1.170:22): datapoint-id: ioB-start, description: : create button
        2021-01-08 15:49:22.084 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: opt, description: ): send command: 'du -c /opt/iobroker | tail -1 | awk '{printf $1MB}''
        2021-01-08 15:49:22.397 - debug: linux-control.0 (21312) [userCommandExecute] ioBroker (192.168.1.170:22, id: opt, description: ): response stdout: 1833808
        2021-01-08 15:49:22.402 - info: linux-control.0 (21312) successful received data from ioBroker (192.168.1.170:22)
        2021-01-08 15:49:22.417 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.refresh' subscribed
        2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.aptUpdate' subscribed
        2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.aptUpgrade' subscribed
        2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.restart' subscribed
        2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.ioB-stop' subscribed
        2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.ioB-start' subscribed
        2021-01-08 15:49:22.418 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.start' subscribed
        2021-01-08 15:49:22.419 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.ssh.stop' subscribed
        2021-01-08 15:49:22.419 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.restart' subscribed
        2021-01-08 15:49:22.419 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.start' subscribed
        2021-01-08 15:49:22.419 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.services.iobroker.stop' subscribed
        2021-01-08 15:49:22.419 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.restart' subscribed
        2021-01-08 15:49:22.420 - debug: linux-control.0 (21312) [refreshHost] ioBroker (192.168.1.170:22): button 'linux-control.0.ioBroker.control.shutdown' subscribed
        2021-01-08 15:49:22.420 - info: linux-control.0 (21312) getting data from Raspberrymatic (192.168.1.171:22, Adapter start)
        2021-01-08 15:49:22.517 - debug: linux-control.0 (21312) [distributionInfo] Raspberrymatic (192.168.1.171:22): send command: 'cat /etc/os-release'
        2021-01-08 15:49:22.523 - debug: linux-control.0 (21312) [distributionInfo] Raspberrymatic (192.168.1.171:22): response stdout: NAME=Buildroot
        VERSION=2.15.5-20151101-2805-g412dbfc5
        ID=buildroot
        VERSION_ID=2020.11
        PRETTY_NAME="Buildroot 2020.11"
        2021-01-08 15:49:22.525 - debug: linux-control.0 (21312) [distributionInfo] Raspberrymatic (192.168.1.171:22): csvToJson result: [{"prop":"NAME","val":"Buildroot"},{"prop":"VERSION","val":"2.15.5-20151101-2805-g412dbfc5"},{"prop":"ID","val":"buildroot"},{"prop":"VERSION_ID","val":"2020.11"},{"prop":"PRETTY_NAME","val":"Buildroot 2020.11"}]
        2021-01-08 15:49:22.571 - warn: linux-control.0 (21312) [distributionInfo] Raspberrymatic (192.168.1.171:22): property 'VERSION_CODENAME' not exist in result!
        2021-01-08 15:49:22.617 - debug: linux-control.0 (21312) [cmdAptUpdate] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
        2021-01-08 15:49:22.619 - debug: linux-control.0 (21312) [servicesInfo] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
        2021-01-08 15:49:22.624 - debug: linux-control.0 (21312) [needrestart] Raspberrymatic (192.168.1.171:22): no datapoints selected -> removing existing datapoints
        2021-01-08 15:49:22.630 - debug: linux-control.0 (21312) [userCommandExecute] Raspberrymatic (192.168.1.171:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
        2021-01-08 15:49:22.635 - debug: linux-control.0 (21312) [userCommandExecute] Raspberrymatic (192.168.1.171:22, id: root, description: ): response stdout: 61
        2021-01-08 15:49:22.683 - info: linux-control.0 (21312) successful received data from Raspberrymatic (192.168.1.171:22)
        2021-01-08 15:49:22.701 - debug: linux-control.0 (21312) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.refresh' subscribed
        2021-01-08 15:49:22.702 - debug: linux-control.0 (21312) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.aptUpgrade' subscribed
        2021-01-08 15:49:22.702 - debug: linux-control.0 (21312) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.aptUpdate' subscribed
        2021-01-08 15:49:22.702 - debug: linux-control.0 (21312) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.restart' subscribed
        2021-01-08 15:49:22.702 - debug: linux-control.0 (21312) [refreshHost] Raspberrymatic (192.168.1.171:22): button 'linux-control.0.Raspberrymatic.control.shutdown' subscribed
        2021-01-08 15:49:22.702 - info: linux-control.0 (21312) getting data from Motioneye (192.168.1.174:22, Adapter start)
        2021-01-08 15:49:22.713 - debug: linux-control.0 (21312) [getConnection] Host 'Motioneye' (192.168.1.174:22): using sudo for authentification
        2021-01-08 15:49:22.795 - debug: linux-control.0 (21312) [distributionInfo] Motioneye (192.168.1.174:22): send command: 'cat /etc/os-release'
        2021-01-08 15:49:22.826 - debug: linux-control.0 (21312) [distributionInfo] Motioneye (192.168.1.174:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
        VERSION_ID="10"
        ID=debian
        2021-01-08 15:49:22.829 - debug: linux-control.0 (21312) [distributionInfo] Motioneye (192.168.1.174:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
        2021-01-08 15:49:22.837 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'sudo -S apt-get update'
        2021-01-08 15:49:22.858 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout:
        dirk ist nicht in der sudoers-Datei. Dieser Vorfall wird gemeldet.
        2021-01-08 15:49:22.858 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s\[([\w,\-,\d,\.,~,:,\+]+)\]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
        2021-01-08 15:49:23.192 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout:
        2021-01-08 15:49:23.192 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.newPackages: 0
        2021-01-08 15:49:23.195 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.upgradable: false
        2021-01-08 15:49:23.201 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
        2021-01-08 15:49:23.216 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): response stdout: 1585325736
        2021-01-08 15:49:23.217 - debug: linux-control.0 (21312) [cmdAptUpdate] Motioneye (192.168.1.174:22): Motioneye.updates.lastUpdate: 1585325736000 -> 27.03.2020 17:15
        2021-01-08 15:49:23.260 - debug: linux-control.0 (21312) [servicesInfo] Motioneye (192.168.1.174:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
        2021-01-08 15:49:23.269 - debug: linux-control.0 (21312) [servicesInfo] Motioneye (192.168.1.174:22): response stdout: apparmor.service,loaded,active,exited, Load AppArmor profiles
        motion.service,loaded,active,exited, LSB: Start Motion detection
        motioneye.service,loaded,active,running, motionEye Server
        2021-01-08 15:49:23.270 - debug: linux-control.0 (21312) [servicesInfo] Motioneye (192.168.1.174:22): csvToJson result: [{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"motion.service","load":"loaded","active":"active","running":"exited","description":"LSB: Start Motion detection"},{"id":"motioneye.service","load":"loaded","active":"active","running":"running","description":"motionEye Server"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
        2021-01-08 15:49:23.398 - debug: linux-control.0 (21312) [needrestart] Motioneye (192.168.1.174:22): no datapoints selected -> removing existing datapoints
        2021-01-08 15:49:23.403 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): send command: 'sudo -S du -sk /var/lib/motioneye | awk '{ print $1 /1024 }''
        2021-01-08 15:49:23.424 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): response stdout:
        2021-01-08 15:49:23.425 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): Motioneye.folders.motioneye.size: NaN MB
        2021-01-08 15:49:23.427 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): send command: 'sudo -S find /var/lib/motioneye -name "*" | wc -l'
        2021-01-08 15:49:23.443 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): response stdout:
        2021-01-08 15:49:23.444 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): Motioneye.folders.motioneye.files: NaN Dateien
        2021-01-08 15:49:23.487 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): send command: 'tmp=$(sudo -S find /var/lib/motioneye -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
        2021-01-08 15:49:23.508 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): response stdout:
        date: Diese Option benötigt ein Argument -- »r«
        „date --help“ liefert weitere Informationen.
        2021-01-08 15:49:23.509 - debug: linux-control.0 (21312) [folderSizes] Motioneye (192.168.1.174:22): Motioneye.folders.motioneye.lastChange: NaN ->
        2021-01-08 15:49:23.551 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
        2021-01-08 15:49:23.559 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: root, description: ): response stdout: 28
        2021-01-08 15:49:23.561 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: mem, description: ): send command: 'free -m | awk ' NR == 2 {print $2";"$3";"$4}''
        2021-01-08 15:49:23.570 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: mem, description: ): response stdout: 3946;222;3532
        2021-01-08 15:49:23.582 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: top-process, description: ): send command: 'ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}''
        2021-01-08 15:49:23.596 - debug: linux-control.0 (21312) [userCommandExecute] Motioneye (192.168.1.174:22, id: top-process, description: ): response stdout: 33.9;/usr/bin/motion
        2021-01-08 15:49:23.606 - info: linux-control.0 (21312) successful received data from Motioneye (192.168.1.174:22)
        2021-01-08 15:49:23.619 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.refresh' subscribed
        2021-01-08 15:49:23.619 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.aptUpdate' subscribed
        2021-01-08 15:49:23.619 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.aptUpgrade' subscribed
        2021-01-08 15:49:23.620 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.restart' subscribed
        2021-01-08 15:49:23.620 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.start' subscribed
        2021-01-08 15:49:23.620 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.services.ssh.stop' subscribed
        2021-01-08 15:49:23.620 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.restart' subscribed
        2021-01-08 15:49:23.620 - debug: linux-control.0 (21312) [refreshHost] Motioneye (192.168.1.174:22): button 'linux-control.0.Motioneye.control.shutdown' subscribed
        ScroungerS Offline
        ScroungerS Offline
        Scrounger
        #168
        @dirk1962 sagte in HTML Tabelle Linux-Control Adapter:
        @liv-in-sky @Scrounger Ich hatte den Ordner Befehl für Motioneye wieder rausgenommen. In diesem log ist er wieder mit drin.
        Coole Fehlermeldung, du wurdest gemeldet 😁
        User hat nicht ausreichend rechte.
        • ScroungerS Scrounger
          liv-in-skyL Offline
          liv-in-skyL Offline
          #169
          @Scrounger
          die bestrafung ist auf bewährung - da er sich ja selbst angezeigt hat :-)
          ScroungerS 1 Antwort Letzte Antwort
          • liv-in-skyL liv-in-sky
            @Scrounger
            ScroungerS Offline
            ScroungerS Offline
            Scrounger
            #170
            @liv-in-sky
            Abwarten, was da erst steht wenn er sich nach 20h einloggt 😁
            Blöd das das als response und nicht als Fehler kommt, muss ich mir was überlegen, wie man das abfangen bzw. im log als error ausgeben kann.
            dirk1962D 2 Antworten Letzte Antwort
              @liv-in-sky
              dirk1962D Offline
              dirk1962D Offline
              dirk1962
              #171
              @Scrounger @liv-in-sky Gerade war die Polizei da und wollte mich verhaften. Ich hab alles abgestritten und sie zu Euch geschickt, weil von Euch der Adapter und das Script ist. 😀 😀
              NUC8i5 mit Proxmox; Raspberrymatic in VM, iobroker, Motioneye, infuxDB und Grafana in CT.
              • dirk1962D dirk1962
                liv-in-skyL Offline
                liv-in-skyL Offline
                #172
                dirk1962D 1 Antwort Letzte Antwort
                  @liv-in-sky
                  dirk1962D Offline
                  dirk1962D Offline
                  dirk1962
                  #173
                  @Scrounger Mit dem Update von Linux Control wurden die nicht ausreichenden Rechte als error angezeigt. Seitdem ich die Rechte gesetzt habe, werden auch die Inhalte der Ordner korrekt angezeigt. Vielen Dank für Deine Hilfe.
                    dirk1962D Offline
                    dirk1962D Offline
                    dirk1962
                    #174
                    @liv-in-sky, ich habe für meine drei VM's unter Proxmox Datenpunkte für start/stop angelegt. Diese sind in den Objekten sichtbar und schaltbar. In der html-Tabelle von VIS sind sie ebenfalls schaltbar. In der materialdesign Icon List allerdings nicht. Habe ich irgendwas übersehen oder mache ich etwas falsch?
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #175
                      @dirk1962 leider check ich nicht, was du meinst - alle 6 schalter sind im untersten bild md-widget zu sehen - was genau fehlt dir ?
                        dirk1962D Offline
                        dirk1962D Offline
                        dirk1962
                        #176
                        @liv-in-sky mir fehlt nichts, die Schalter sind "tot". Wenn ich auf Motioneye-stop drücke passiert nichts.
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          #177
                          @dirk1962
                          sorry - schaltbar mit sichtbar verwechselt :-(
                          das kommt bei mir manchmal auch vor - da verliert die vis die verbindung vom socket (vermute ich) - da hilft ein browser refresh
                          egal ob in der tabelle oder im widget - es wird immer das selbe interne script ausgeführt
                            @dirk1962
                            dirk1962D Offline
                            dirk1962D Offline
                            dirk1962
                            #178
                            @liv-in-sky sagte in HTML Tabelle Linux-Control Adapter:
                            @dirk1962
                            Das ist mir auch klar. Nur wenn auf 4 verschiedenen Geräten das Schalten per html-Tabelle funktioniert und das Schalten per MD Widget nicht, dann ist der refresh des Browsers für mich nicht nachvollziehbar. 😕
                              @dirk1962
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              #179
                              @dirk1962 hast du mal in chrome die entwickler-console geöffnet, vielleicht sieht man da was, wenn du den button drückst
                                dirk1962D Offline
                                dirk1962D Offline
                                dirk1962
                                #180
                                @liv-in-sky das kommt beim Drücken auf Motioneye-stop
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #181
                                  @dirk1962
                                  script in html tabelle wird ausgeführt - anscheinend ist parameter übergabe im script nicht korrekt
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    #182
                                    @dirk1962
                                    hast du lust auf anydesk session - im moment sehe ich bei mir hier kein problem
                                      @dirk1962
                                      dirk1962D Offline
                                      dirk1962D Offline
                                      dirk1962
                                      #183
                                      @liv-in-sky, auf dem PC geht es mittlerweile. Frag mich aber bitte nicht, was ich gemacht habe. Auf dem Tablet und Handy muss ich noch prüfen. Da weiß ich auch noch nicht, wie ich da die Entwickler-console geöffnet bekomme.
                                      Du hast sicherlich Recht, dass das Problem bei mir liegt 😞 😞 .
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #184
                                        @dirk1962 hauptsache es funktioniert schon mal auf dem pc in chrome- damit ist die fehlersuche schon mal extrem eingeschränkt worden
                                          dirk1962D Offline
                                          dirk1962D Offline
                                          dirk1962
                                          #185
                                          @liv-in-sky habe heute Morgen rumprobiert. Auf dem PC konnte ich mit dem materialdesign-Icon List widget Motioneye nicht stoppen. Auch ein browser refresh hat nichts geändert. Dann habe ich es mit dem html widget probiert und ich konnte Motioneye stoppen. Dann habe ich wieder zum materialdesign widget gewechselt und konnte Motioneye starten. Danach konnte ich mit den buttons alles stoppen und starten.
                                          Exakt das gleiche war dann auch beim Tablet und beim Smartphone.
                                          Es sieht so aus, dass ich erst einmal über das html widget schalten muss um die buttons im materialdesign widget zu aktivieren.
                                          Keine Ahnung ob Dir das hilft, aber vielleicht kannst Du es auf Deinem System mal versuchen nachzuvollziehen.
